TINA-TI: Significant difference between Tina-TI and Spice model
Part Number: TINA-TI
Other Parts Discussed in Thread: LM358
Hi there,
i just tried to simulate the LM358 and encountered some problems. After some tries, i found out that the model included in TINA-TI and the SPICE Model that can be found at the product page is very different. I thought that the TI-tool should simulate the part from TI better, but simulating with LTSpice, i get exactly the resut from the datasheet, whereas with TINA-Ti i get something very different.
here the Simulations:
result:
Tina with LM358.
result:
with the output oscillating.
According to the Datasheet, the output should look like this:
I find these results troubleing. Can i use the Spice-Model for simulation? Why is the model in TI-Tina so off? Did I choose the wrong part (I also tried the LM358/101)? I have the strong feeling that i made a mistake setting up the simulation in TI-Tina. Please find attached both simulations.
simulatoins.zip
  • Hi Dominik,
    Our PSPICE code is usually generated from our TINA macromodel. So it is odd that the results don't match. I will go ahead and test the PSPICE and macromodel again to see what's causing this difference. If I don't get back to you by end of today then I will follow-up with you on Tuesday.
    Bala Ravi
  • Hi Dominik,
    Looks like you somehow found the older LM358 TINA-TI model. Did you download it from our product folder: http://www.ti.com/product/LM358/toolssoftware ?
    Once I replaced your circuit with our latest TINA-TI macromodel, your circuit worked fine. Please find below:
    I've also attached the edited TINA-TI file for your reference: Test mit Tina_TI.TSC
    Bala Ravi
  • Hi Bala,
    I did not download the LM358 Model, I took the one that comes integrated with TI-Tina in the current version. Glad you found the issue.
    Dominik
