Multiple Pages
I am starting a simulation of a reasonably large circuit and was wondering how to make multiple pages each with a Title Block. I prefer to work in "Page Layout View", and to have (and see) different parts of the circuit on separate pages. I can not figure out how to have a Title Block on each page in TINA, it is fine if the title block is repeated on each page, or a new one must be added to each page.
Can this be done? If so, how?
  • NJC,
    The answer to your question is yes it can be done. If you are using the "Page Layout" view and you want to add a tittle block to each page just click anywhere inside the gray lines that borders the page that you are trying to assign the tittle block to and then go to insert....tittle block from the insert menu. After you are have selected a corner for the tittle block and filled out the required information press ok and a new tittle block will appear on that specific page. Let me know if this solves your problem.
    -Marcos
