Other Parts Discussed in Thread: TMS320C6657
Dear
Below mentioned controller’s timing parameters are required for DSP --- DDR3 intewrface analysis using Hyperlynx (analysis tool) and these parameters are assumed to be defined in the controller data sheet.
1. tACCSkew ---------
1. tACCSkew ---------- Output delay skew from CK falling to Addr/Cmd/Ctl (+/–)
2. tCKDQS ------------- Output delay skew from CK rising to DQS rising (+/–)
3. DQSDQQ ------------ Output delay skew from DQS to DQ (+/–)
4. tDS -------------------- Minimum DQ to DQS setup time, with 1/4 cycle DQS shift
5. tDH -------------------- Minimum DQS to DQ hold time, with 1/4 cycle DQS shift
Kindly advice about these parameters and about the the reference document.
