WEBENCH Power Designer is a great tool to compare different DCDC solutions to given problems, here are some issues though:
1. The efficiency slider goes in large steps from 0-99%, which can only be set to 89% efficiency minimum. This filtered out no design :D Let us type in the boundaries we want.
These are other things that annoy me sometimes, sorted by importance:
2. Design attribute, add IC Cost to filter. It helps when we know what external components we want to use but are looking for the best value IC to power our device (just figured out you can add column in LIST view)
3. Allow us to export CAD even if schematic is broken. I couldnt download a project to EAGLE because one of the MOSFET pins wasnt mapped correctly even though i didnt even want to use that MOSFET. Also, allow us to change power blocks in designs. Often, these cannot be changed.
4. Add multiple output voltages as system requirement.
Thanks!!
