Part Number: TPS54340
Hi
I have designed a 6 layer PCB board having configuration TOP--GROUND---SIGNAL----SIGNAL----POWER--BOTTOM is there any reference design for multi-layer PCB. or any document regarding connecting high voltage buck converters within multi-layer boards.
The low voltage buck converters work efficiently but I end up having grounding problems when converting high voltage to low voltage buck converters within the board.
Pranav
