Part Number: DAC38J84EVM
Other Parts Discussed in Thread: DAC38J84
Hi sir,
Hi sir,
Hi Bharat,
The default test waveform for the 25MHz may not match the actual data rate that you have setup for your system. Your actual data rate needed for the tone generator is 300MSPS.
You will need to refer to the DAC38J84 EVM user's guide on setting up the "data rate" of the tone generator to match the DAC38J84 GUI setup. Please see highlighted area.
You will also need to setup up the NCO accordingly to generate the mixing process.
All of these are your application dependent and TI is not able to comment. The better way is to provide your GUI screen shot so we can point out what you will need to do on your setup.
-Kang
