Part Number: TPS54061
Dear Webench support team..
Using this design https://webench.ti.com/appinfo/webench/scripts/SDP.cgi?ID=5DD2BDD506BE440B
Hi James,
You are correct. According to Datasheet device should work up to 150 degC. And hence the Webench will fail the design if device temperature goes above 150 degC. In your case this is just an alert which Webench produces for 125 degC (not an failure) giving message that we are operating at higher temperature, however Webench allows the design creation for this case. Hopefully this explains. Let us know if you have any further queries.
Bhushan
