PSPICE-FOR-TI: Internal error occurred (-42)
Part Number: PSPICE-FOR-TI
I downloaded the installer. But I can't install the software and it reminded me that "An internal error occurred" with error code(-42)
The last part of file cdsPspiceTIlog.txt is:
20:36:12 21. oktober 2020 : DownloadServerPath is: software-dl.ti.com/.../installer
20:36:12 21. oktober 2020 : TILibPath is: software-dl.ti.com/.../library.zip
20:36:12 21. oktober 2020 : parameter count = 1
20:36:12 21. oktober 2020 : -wrapper
20:36:12 21. oktober 2020 : ReleaseVersion in XML: 17.40.004 InstalledVersion on system:
20:36:35 21. oktober 2020 : error_code cdsVblRegisterInstallation: VblInternalError
20:36:35 21. oktober 2020 : strErrorMsgDesc: An Internal error occurred. Please go to http://e2e.ti.com for further assistance. (-42)
How to solve it?
  • Hi Egon,
    I just sent you a message. Please check.
    JC
  • Hi JC,
    Thanks for your reply.
    This is the contend of cdsPspiceTIlog.txt:
    16:57:30 26. oktober 2020 : Response Content length = 1527
    16:57:30 26. oktober 2020 : C:\Users\Stationær Medion\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1527
    16:57:30 26. oktober 2020 : Reading Json URL File
    16:57:30 26. oktober 2020 : Setting TI Library URL from Json URL File
    16:57:30 26. oktober 2020 : setting media download server URL from Json File
    16:57:30 26. oktober 2020 : setting Dll path from Json File
    16:57:30 26. oktober 2020 : Chws URL is: cdsplicwc.cadence.com/.../v1
    16:57:30 26. oktober 2020 : DownloadServerPath is: software-dl.ti.com/.../installer
    16:57:30 26. oktober 2020 : TILibPath is: software-dl.ti.com/.../library.zip
    16:57:30 26. oktober 2020 : parameter count = 1
    16:57:30 26. oktober 2020 : -wrapper
    16:57:31 26. oktober 2020 : ReleaseVersion in XML: 17.40.004 InstalledVersion on system:
    16:58:10 26. oktober 2020 : error_code cdsVblRegisterInstallation: VblInternalError
    16:58:10 26. oktober 2020 : strErrorMsgDesc: An Internal error occurred. Please go to http://e2e.ti.com for further assistance. (-42)
    End of message.
  • Hi Egon,
    What is your operating system?
    JC
  • Hi JC,
    It is a Windows 10 Home 64-bit.
    /Egon
  • Hi JC,
    Is it not ok with Windows 10 Home?
    /Egon
  • Hi Egon,
    I don't believe so. Please check the message I just sent.
    JC
  • Hi JC,
    I think the file is attached now.
    /Egon
    16:57:30 26. oktober 2020 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
    16:57:30 26. oktober 2020 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
    16:57:30 26. oktober 2020 : TILibPath is: https://software-dl.ti.com/pspice/esd/models/library/library.zip
  • 16:57:30 26. oktober 2020 : Response Content length = 1527
    Hi JC,
    I try once more, even though it seams to be there.
    /Egon
  • Hi JC,
    Just read the help.html.
    Software Requirements, Operating System, Windows 10 (64-bit) Professional
    So Windows 10 (64-bit) Home may not work or...
    /Egon
  • Hi Egon,
    I noticed that your current login contains a non-ascii character. If it is possible, please try creating another login on the same computer with ascii characters only and try to install under that login. There's a problem with non-ascii character which the development team is working on.
    JC
  • Hi JC,
    When you talk about login, do you mean Windows login?
    My PC is a stationary office PC, not a laptop and I do not use login as no one else has access to it.
    Perhaps the computer name is the problem. It contains the danish character "æ" like "ae".
    /Egon
  • Hi Egon,
    Yes I think that is the issue and the R&D is working on a fix.
    We will update you when the fix is available.
    JC
  • Hi JC,
    22:20:15 12. november 2020 : Response Content length = 1527
    22:20:15 12. november 2020 : C:\Users\Stationær Medion\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1527
    22:20:15 12. november 2020 : Reading Json URL File
    22:20:15 12. november 2020 : Setting TI Library URL from Json URL File
    22:20:15 12. november 2020 : setting media download server URL from Json File
    22:20:15 12. november 2020 : setting Dll path from Json File
    22:20:15 12. november 2020 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
    22:20:15 12. november 2020 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
    22:20:15 12. november 2020 : TILibPath is: https://software-dl.ti.com/pspice/esd/models/library/library.zip
    22:20:16 12. november 2020 : parameter count = 1
    22:20:16 12. november 2020 : -wrapper
    22:20:16 12. november 2020 : ReleaseVersion in XML: 17.40.004 InstalledVersion on system:
    22:20:43 12. november 2020 : error_code cdsVblRegisterInstallation: VblDiskWriteError
    22:20:43 12. november 2020 : strErrorMsgDesc: Unable to write to disk. Check Permissions.
    I renamed my PC and the error code(-42) does not show up anymore:-).
    It did not solve all problems, new error message: Unable to write to disk. Check Permissions.
    /Egon
  • Egon,
    Yes, this error message "unable to write to disk" is known for the special character problem.
    we should have an update next week.
    JC
  • Hi JC,
    Now I have renamed the User Profile Folder. The "æ" is replaced by a "a".
    After this operation I was able to install pSpice For TI, without further problems.
    Thank you for your patience and your help.
    Best regards
    Egon
