WEBENCH® Tools/TPS5420: Customer WEBENCH issue with export to Orcad and simulation in PSPICE
Part Number: TPS5420
Customer issue with export to Orcad
Customer has been working on Webench on a simulation of the TPS5420DR 5.5V-to-36V, 2A, 500kHz, Buck DC-DC Converter.
This design simulates in Webench, but the customer wanted to export it to ORcad PSPice in order to add a more representative output capacitor bank.  Webench doesn’t allow adding components to the simulation model, and the customer wanted to simulate with the three different output caps used in this design, rather than one or more of a single part number, which is all Webench appears to allow.
When the customer exported the design from Webench and imported it into Orcad, and then tried to run a Pspice transient simulation before changing any components, that simulation failed (See error messages in logfile copied below).  This was with the internal Pspice simulator. The customer reports that the WBSE simulation button also appears to fail.   When the customer runs that, a window appears partially off-screen stating that the simulation is running.  This soon closes, and a CMD window pops up momentarily.  Then that closes without displaying any text, and the process seems to end at that point.
What does the customer need to do to solve this problem?
Simulation Logfile
c:\users\customer_user_name\downloads\wbdesign2_cadenceorcad\exportfiles\simu...\transient.out.1
**** 11/18/20 08:31:47 ****** PSpice 17.2.0 (March 2016) ****** ID# 0 ********
** Profile: "SCHEMATIC1-transient" [ c:\users\customer_user_name\downloads\wbdesign2_cadenceor
cad\exportfiles\simulation\webench_design_6
**** CIRCUIT DESCRIPTION
** Creating circuit file "transient.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Profile Libraries :
* Local Libraries :
.LIB "../../../main_block_l1_wb_inductor.lib"
.LIB "../../../main_block_wb_tps5420_main_block_d1.lib"
.LIB "../../../main_block_u1_wb_tps5420.lib"
.LIB "../../../main_block_cout_wb_cap_tantalum.lib"
.LIB "../../../main_block_cin_wb_cap_polarized.lib"
.INC "../../../main_block.wb_tps5420_main_block.d1.enl"
**** INCLUDING main_block.wb_tps5420_main_block.d1.enl ****
-------- ENCRYPTED FILE --------
ERROR(ORPSIM-16316): Invalid device
PpwhBr+l8mU=
mAeL0GFssRDu7XLZzwOm9Da1SY07x9flSHj2TGDiR+ZZCd2BlXmQuM1wZHfu4ADcwwkibk1Ld9zut+9iuUmtaA==
ERROR -- Missing node
OicgPimDtWo3GxSKXbq8KWc3jvn+Poc596Zrvpx74TVQm9YTPScaFdyXUlNOVaz3fttF4MZZ
/EpA/uTFTgzRuqnX2IpeUHS24g/GsE39yo2uxLn/Z3qDybnAYwO0Vy8jZvAVl2QUVfN/NYlb
L370wNvH5k9x0DEWkVh9kNhS3VrIgNJQvrGpNOsxlH5fgw4iKJQ75sAfylol4Az1cRmdOrK9
gK0CJc2Jl/Zqenq1yHLLH+303RaggzYsvZjaJXsAZ/GxlmgP+y9FzzA3ed/JZrPDpnhYqA+R
7y3+Pdf/IDOBLG8y0BZQN9511DD8N4OIQjUwFtz5IiJw3O2SvcuM53tHhlsBnav8MpEiDTbI
aInP7zYWLtLCLR8v4m83+vHINJ8Uo4ySuiXlGireMjqhV3WZx9RaGKtkwAFYgCnCB+85m0ww
nbaZ4DIG9B/kN57ggKCC2wmO1KtVljCWbh4SLQ==
**** RESUMING transient.cir ****
.INC "../../../main_block.u1.wb_tps5420.enl"
* From [PSPICE NETLIST] section of C:\Users\Customer_user_name\AppData\Roaming\SPB_Data\cdssetup
\OrCAD_PSpice\17.2.0\PSpice.ini file:
**** INCLUDING main_block.u1.wb_tps5420.enl ****
Page: 1
GTzDR0qzvbY=
9nJS/Q2j04ka81sqc8ydVB9QGO6PEK7zwe6kHcQ92SSOJGvcOhs9kxZS4Rxs+WOtyVISzqRT4i8CD42SNh6gtA==
61SuA5GQ4e5M2mhyrd6pv7MafuAl4IhMDQRhsi1wrnZJTxh4DMFBfzfBbAUNO1SSuQAcbuf/
pTjLjYpx7cUUBLAGirpQ8Sth2yNPddOWHJ6+McuEZSq38PV2KyllyRt/CRUAFpWtliMVZ1wj
7JZ5nE4Usm9wJ6fH2MJhP7gAIVNTu8HVeDd32JDcRc9mvfYS5Bct165cFleBzz8qT0IKlmXz
rrRrcvAIMmxnsGa93kgV1szasAHULDmKSlSzX7QQfinpdQ9TiJdLvwSChomFYwmZnTmuk6EY
QazjzcE/Fn9c0qRsH8oilfNNCTl4OJJrhrKPxL8vSVa/NSmNAUNYJeAqB80xRYQSLlgPJsvq
g5IpG942kBc6XPD+7HZLvqKcTVonT9ZE4d6yFTbDnnPulm9I44fLR1D0YKxAHvB02j5rthRB
l1Vv1ZHWce0+fVQcwgNy51cDG+hTvXzInNQOM8nvopXCjfr3WMiP/2W9/wEhwJpCe7teadNj
WBJHxJ18qaNTRXmV3oupHj/Kj6MbS0PjsFe6/LKa10hETBE7bCQEMeMWot5N1/zggTwTmbcr
ILaVbiGAVnHaRSCzytJD7+QR0llOv3ogApqyE75siLD3J9ptSaU19VY2fVL18ZZp1OwzWrgY
vK31p1h6cTMsJx9piYpFDQGSMDhmPMCUNnZYR3whQjtbn/683xw93vAbeT5QLOmQKyWxKVKM
Pg2uMPyMi4E670izJeNoSaFek/udtvqp2RAE35kw07idkZXgMP9LvXigg6NdX9DKAs8snzKS
0Iwd2cYrIqUUJdTY78AWh/HbXlmyABHL8gQ7qFtSDVdK7L7tSgd7//Yr5SAv5wQUqbWn8BS4
ElDjD7YZYMG+dVfncye5eNshFpOAebpedRZYRU2ZIjTvORyLgqgzxbE50YGSV1qoIHg+YLm1
ErLL0u96nAG77C+BEE1Fc+OYngWBLX+scdOm9TuiY3GMqBFeY/cT3vUTpWuqB09mNy2r5Mjj
sQ2rv9NlvKzzYDpyhopDJiJWdiJEYAajRrhSidjfKOO8EKUECYfx6ZLza8q2MwQ7XPRQ6M/d
1TPHrsh5m0cdgRV7fyO/CBhmFek8ugvFzikxsMoyoEN9URwpPrG+/gM4FWJV1eemLh1v7xyR
9wQcOFS4dcuFpIFszZ19jXEeboTI6xlf49NPlGx7Er3k0HUSe4Vp8EyL7RwhQq2MEvgge4iz
Qw+1Rdo1Ko4q6A4jOabA8TG8yM61ucrc3HFdzb2eZgtKCPGohTfHnWLxKaFjBeLr/6U+s7R1
y9QYsCEQg/ipLwvqlVsDfxosGWIe/m1EmOicLUBm8tfnOA8K0Na3F8tTsCt0tiO9ZFPnoMFA
KcWUEadzRtlouSMdvvperjigm/KkMqrQ6YGH/yARsf8MEn75R8hgc279zNGkF0nRM0dI2eQX
ERROR(ORPSIM-16389): Missing inductor
w/aQ8sWWsiO4GmVkRnTo1N6ZH48toSms4rmOOAvdfhg+Jk0Kg8LV9ivUpm9iXqYKVwa/sSdk
Page: 2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(ORPSIM-16503): Missing subcircuit name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: 3
UzIbvkelYbazhDkvKmUGoEtYYDGCwjN8Bu0NTMfWLqdNUBTGvjlVIH3/QiaQm3qVnl3w5XHq
ERROR(ORPSIM-16483): Missing primitive type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: 4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: 5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: 6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: 7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: 8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: 9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: 10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: 11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: 12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: 13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: 14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: 15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: 16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: 17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: 18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: 19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: 20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: 21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: 22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: 23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: 24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: 25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: 26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: 27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: 28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: 29
JeePr7dld7li0EqG/lSeh2Su68TsLJasgVL2zNFr8EMp+hGH1fofhxuYv2A2jDywDHASRdok
BJxBQxeXxcW6uAOg1lIJQBIJmHRGtNnAz5El6IpnVHJqeKbgVAq+X06pamXJXRdxFXuPDoeT
xK6xfCt5PBDBmyWRnL5GA3pvmCDgt1pfmjzf6L6zENhWopvNGpPxHPIFV/mje+NWb7PgjvE1
RZPiu4XCPSuy8ixnGG0EqVrau467rB/ZZPHirENb4wh1zBWrBvfIEYorS3xlnikzEk+dDMd1
rCvfaf0NUvUQwuPZCW0KCrPeqQVyttqCLrbKVR7iLbV6Y9QOjzNqQDiOTeUMs1rJ8Vib8LVq
efRE5sVHRhajrInYj9M9am6SV1FMHzUVa03onWdpK0j5nhA+LX+ZHWgi/BwEPx+HSHqWRAn2
kFDFgjgLPHsZTThOg3avt4Vg7RdHlHQ3GL3Ym/MiHzg8Cf5ikiVaVkQg7PAYfU3unCcQRWov
8LIBo/on9Q70JfeFvWa9nFKJ/72zvtvn1a1fTssVFNjROyh9ymwctYxnH20IYBX1JOkTKN+i
iHlkpp4jx7zWkUl1vYHNimfnbd/dgXL3CbIQyjDte8TTW548sRtEpe/zKzN5tu+PIvUTFhXB
1iGOp3caPGViphpYymeBr3kTcem4/S08N3thPO2+pPxNz2v4CsXRErS5rukptcgUh2NvuA1F
cxOL+PBMCpxtjYp5J0NwvnuOwnh4thKVT49vHQkb9YPFWPL5BSzfUQw43VleI1yUjfQpm9JS
6JsmLqXQukRkB64vfhVYOMJEWXyG1u12FYwFuAL5BXTbuYUjUrPhGZUt+hb/Co1XgjJPICyF
1HkXmaGIOz9gl/vcoQzBlSoTIwUnyYR5nUY8Dr+pFDvUsbeUI2o55QUIIxoqfwQGXXSuvnSb
BP76Rx1Mv0S+YwOxlQipwHeVbax22AU4PZKH70wmrWfmpU6Z7K6yU45owCXH0toWAgjjHC3T
zu0wG1E8QruMNmpw4oT/nJDNwFDCxh+drf/G14FXxizjzS38L3AZifaZ9FtZlPn4heEx7PdT
0pNfL3KjhAh24znXvJiN8rTYfC48Eou3y0m6FQLiBMo7o7+/99XZ8ZUIaoucXOpKWnBbu9ID
jM38L7hF8CguRNxFIhhSvXQo+GgTWjSbWTOxbglPuUONZF58kAXOnq+FFluZTiOwBZIQ9U4D
EgPsUg32w7izQp9/kBCZ1pvQ9obqImOsYlARdjDFEdtgWqhGJkFlGz0nXO8DSmtK+HKdrvxN
yQQWu0FjJehmi5OMw5gNsx3kch1YliW1uDpqBYgX1TL7HBHiJ4/ga0rm+4XXDUKCzkF7Q/a4
mqLRpXVa1kMRMBAmvmm6DliMTWw2fBM62M2BUqb7afjZMi8wc0vmPUqnDk+8oxHQN3/MDM+d
sek95ELo9EXjxCz0//NReE/VsWqAx5Sl53B+EOpP/1WLp5OHzB3GN5qZoaNr+6R9Ehll6F8J
WTz19gxMYdmVuX2eSwszPAX2sWWKULcv1zORX68xHp1kPP2Qub8eR2I8IVGzGVLG/EJTz0vd
yGNzUc0PcNt99USslmg/iTXF2E4dLnxesbcXDrakujExfrfJ9htJst/2Hf5o3Is5vsWMrkVe
aK1Isz+WoT1jm6CMMaFMk5sEME99eAMD2tmbamMkvZVuwzj8whhR/g6TdT3hf3aa7NnSzQ3r
Page: 30
MfvJWiYwbf+JxfuzhFggvnPyqn8iutz6uKz2+Kn0FWaEeqv6TdueQR7Lz+tRa+syxNgT4SUO
35Riv5UF1boc5NbN0kumPFeeDyd9RWdDDl576WA7+ks8ddm6Mq1xgwDE99osCr3x7jpN/C2N
9xvVSX/8vW4Ym4FJkb6j5bq96hhY+TABGIT69mt9cH8vk7GJeI6FO7qbPJ+erE9XfIbtPF+8
hcRr0AzNUgqrbaVW0J+zOL58dmbHuJR59B0KCtBWpl1+p5r9/nIVgNbmOAeBgAHc1CPIUMI1
59cSNor7YBkXieonAAZEVgCA7FStMAk7/z7lmBxpAMAMIMkQTEY+bTfCBcVXycZxOFXNy0zk
jn4EDXyOET2mmr284zwpMbo6vOI+QBHJFmI5t9XTKk5vogxvJqUGwgit08p74616r3XC2djH
U1XXEBz0mxqWf2dTZll4W/1hd7j+xwVp7FmNeuO9vHPvebSJJSKlopAHpGEv2lwIha7w4QRO
V8W5iXVgxK4uyH/whYULloq1XEMoKhcsvxfWztnUYxaFfGEtTfaykloBTDU4IYnbdHvr/Znz
ASv9XWYMqWw0O6MBJOanXr/7Uuq3EGE8w63pIS8nqBdCPgN/k7/ZDczTR4lO7PjU/8AamOsI
/14FZ7lE14FEZyuMw5h8XDqC8QRAOLoOQELddBJjW6b8aSPeX8rEtVX+yasnXcDJuoF7q/Bh
M6JABLe8xzVIyffUWItURW8Sr9gDlxOjT13rjlpFZhUXWJpKfyMQn3u4Tfo1S8PL/ObP9vJV
/kKFcr62b6+Y3ot1/uh3NXPgQmm6EBUQbtPhCJtY53Lo1ALXfTEuJchivPn0+WTSsQRZnmBv
ja6pFWGpXRuF1GL8abT8+0Wqu1iGSg==
.lib "nom.lib"
*Analysis directives:
.TRAN 0 1000ns 0
.OPTIONS ADVCONV
.PROBE64 V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
.INC "..\SCHEMATIC1.net"
**** INCLUDING SCHEMATIC1.net ****
* source WEBENCH_DESIGN_6470560_2_SPB16_SIM
V_IOut VOUT N00281 0
X_U1 M_UN0001 0 N00269 VSWITCH N00263 N00317
+ MAIN_BLOCK_U1_WB_TPS5420_ENCR
R_Rload N00351 0 2.5 TC=0,0
X_L1 VOUT N00259 MAIN_BLOCK_L1_WB_INDUCTOR
V_Vin_2 N00289 0
+PULSE 0V 14.5V 2E-6s 1E-6s
X_Cout N00283 0 MAIN_BLOCK_Cout_WB_CAP_TANTALUM
C_Cboot N00263 VSWITCH 1E-8 TC=0,0
V_ICout VOUT N00283 0
V_IInductor VSWITCH N00259 0
V_IIn N00289 VIN 0
R_Rfbb N00269 0 3240 TC=0,0
R_Rfbt N00269 VOUT 10000 TC=0,0
X_D1 0 VSWITCH MAIN_BLOCK_WB_TPS5420_MAIN_BLOCK_D1_ENCR
Page: 31
X_Cin VIN 0 MAIN_BLOCK_Cin_WB_CAP_POLARIZED
V_IIC VIN N00317 0
V_ILoad N00281 N00351 0
.END
  • Hi Russell,
    We are looking into this issue. Could you please share the WEBENCH design using the 'Share Design' option?. This will help us to debug the issue.
    Thanks & Regards,
    Praveen
  • Hi Russell,
    We verified the WEBENCH OrCAD exported design for condition Vin=5.5V-to-36V,Vout=4V Iout= 2A, 500kHz.The export works fine in 16.6 version of Pspice Allegro tool. Please follow the below procedure for simulation
    1.Export the WEBENECH design into OrCAD.
    2.Open the XML file in Allegro as shown below.
    3. Create the netlist
    Once the netlist is generated following message shows up.
    4. Run the simulation.
    5. Once the simulation is completed , open the .dat file in the AMS simulator.
    Please let us know if you are facing any issues.
    Thanks & Regards,
    Praveen
