Part Number: TIDA-050047
Other Parts Discussed in Thread: TPS25750, BQ25792, TPS26750
Hi all,
I have a customer currently considering to use the BQ25792 and the TPS25750 but had a question about their interaction with each other and using a PSU:
- Does the interrupt pin need to be connected between the BQ25792 and the TPS25750 for correct operation?
- If you connect the USB input to a PSU (No D+/D- or CC lines) and set it on 5V @2A, will the battery charger still charge or will the TPS26750 cut off the supply?
Thank you,
Filipe Rubinstein
