Error screenshot,
Hi JC,
Please find the cdsPspiceTIlog.txt file attached here.
11:58:28 AM Friday, January 15, 2021 : Response Content length = 1527
11:58:28 AM Friday, January 15, 2021 : C:\Users\Uib10234\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1527
11:58:28 AM Friday, January 15, 2021 : Reading Json URL File
11:58:28 AM Friday, January 15, 2021 : Setting TI Library URL from Json URL File
11:58:28 AM Friday, January 15, 2021 : setting media download server URL from Json File
11:58:28 AM Friday, January 15, 2021 : setting Dll path from Json File
11:58:28 AM Friday, January 15, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
11:58:28 AM Friday, January 15, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
11:58:28 AM Friday, January 15, 2021 : TILibPath is: https://software-dl.ti.com/pspice/esd/models/library/library.zip
11:58:28 AM Friday, January 15, 2021 : parameter count = 1
11:58:28 AM Friday, January 15, 2021 : -wrapper
11:58:29 AM Friday, January 15, 2021 : ReleaseVersion in XML: 17.40.004 InstalledVersion on system:
11:59:14 AM Friday, January 15, 2021 : error_code cdsVblRegisterInstallation: VblSuccess
11:59:15 AM Friday, January 15, 2021 : error_code cdsVblRequestLicense: VblSuccess
11:59:22 AM Friday, January 15, 2021 : Setting default Installation directory : C:\Cadence\PSpiceTI
11:59:25 AM Friday, January 15, 2021 : Checking for memory space
11:59:25 AM Friday, January 15, 2021 : Memory space available
11:59:25 AM Friday, January 15, 2021 : Target Dir: C:\Cadence\PSpiceTI
11:59:25 AM Friday, January 15, 2021 : Working Dir: C:\CAx\App\CR5000\home
11:59:31 AM Friday, January 15, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.ini?tracked=1 Status is OK
11:59:31 AM Friday, January 15, 2021 : Starting download of setup.ini Attempt no 1 DataSize is 2440
11:59:31 AM Friday, January 15, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
11:59:31 AM Friday, January 15, 2021 : Completing download of setup.ini
11:59:31 AM Friday, January 15, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.inx?tracked=1 Status is OK
11:59:31 AM Friday, January 15, 2021 : Starting download of setup.inx Attempt no 1 DataSize is 558491
11:59:31 AM Friday, January 15, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
11:59:31 AM Friday, January 15, 2021 : Completing download of setup.inx
11:59:33 AM Friday, January 15, 2021 : https://downloads.ti.com/pspice/esd/installer/software/0x0409.ini?tracked=1 Status is OK
11:59:33 AM Friday, January 15, 2021 : Starting download of 0x0409.ini Attempt no 1 DataSize is 22480
11:59:33 AM Friday, January 15, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
11:59:33 AM Friday, January 15, 2021 : Completing download of 0x0409.ini
11:59:33 AM Friday, January 15, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data1.cab?tracked=1 Status is OK
11:59:33 AM Friday, January 15, 2021 : Starting download of data1.cab Attempt no 1 DataSize is 31725431
11:59:36 AM Friday, January 15, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data1.hdr?tracked=1 Status is OK
11:59:36 AM Friday, January 15, 2021 : Starting download of data1.hdr Attempt no 1 DataSize is 4250556
11:59:37 AM Friday, January 15, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
11:59:37 AM Friday, January 15, 2021 : Completing download of data1.hdr
11:59:38 AM Friday, January 15, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
11:59:38 AM Friday, January 15, 2021 : Completing download of data1.cab
11:59:39 AM Friday, January 15, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data2.cab?tracked=1 Status is OK
11:59:39 AM Friday, January 15, 2021 : Starting download of data2.cab Attempt no 1 DataSize is 170870784
11:59:41 AM Friday, January 15, 2021 : https://downloads.ti.com/pspice/esd/installer/software/ISSetup.dll?tracked=1 Status is OK
11:59:41 AM Friday, January 15, 2021 : Starting download of ISSetup.dll Attempt no 1 DataSize is 1634216
11:59:42 AM Friday, January 15, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
11:59:42 AM Friday, January 15, 2021 : Completing download of ISSetup.dll
11:59:45 AM Friday, January 15, 2021 : https://downloads.ti.com/pspice/esd/installer/software/layout.bin?tracked=1 Status is OK
11:59:45 AM Friday, January 15, 2021 : Starting download of layout.bin Attempt no 1 DataSize is 886
11:59:45 AM Friday, January 15, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
11:59:45 AM Friday, January 15, 2021 : Completing download of layout.bin
11:59:46 AM Friday, January 15, 2021 : https://downloads.ti.com/pspice/esd/installer/software/pspInstall.pdf Status is OK
11:59:46 AM Friday, January 15, 2021 : Starting download of pspInstall.pdf Attempt no 1 DataSize is 85357
11:59:46 AM Friday, January 15, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
11:59:46 AM Friday, January 15, 2021 : Completing download of pspInstall.pdf
11:59:48 AM Friday, January 15, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.bmp?tracked=1 Status is OK
11:59:48 AM Friday, January 15, 2021 : Starting download of setup.bmp Attempt no 1 DataSize is 552056
11:59:49 AM Friday, January 15, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
11:59:49 AM Friday, January 15, 2021 : Completing download of setup.bmp
11:59:52 AM Friday, January 15, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data7.cab?tracked=1 Status is OK
11:59:52 AM Friday, January 15, 2021 : Starting download of data7.cab Attempt no 1 DataSize is 8329915
11:59:59 AM Friday, January 15, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
11:59:59 AM Friday, January 15, 2021 : Completing download of data7.cab
12:00:02 PM Friday, January 15, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data6.cab?tracked=1 Status is OK
12:00:02 PM Friday, January 15, 2021 : Starting download of data6.cab Attempt no 1 DataSize is 209715200
12:00:43 PM Friday, January 15, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
12:00:44 PM Friday, January 15, 2021 : Completing download of data2.cab
12:00:47 PM Friday, January 15, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data5.cab?tracked=1 Status is OK
12:00:47 PM Friday, January 15, 2021 : Starting download of data5.cab Attempt no 1 DataSize is 209715200
12:01:10 PM Friday, January 15, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
12:01:11 PM Friday, January 15, 2021 : Completing download of data6.cab
12:01:14 PM Friday, January 15, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data4.cab?tracked=1 Status is OK
12:01:14 PM Friday, January 15, 2021 : Starting download of data4.cab Attempt no 1 DataSize is 209715200
12:01:50 PM Friday, January 15, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
12:01:51 PM Friday, January 15, 2021 : Completing download of data5.cab
12:01:55 PM Friday, January 15, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data3.cab?tracked=1 Status is OK
12:01:55 PM Friday, January 15, 2021 : Starting download of data3.cab Attempt no 1 DataSize is 209715200
12:02:11 PM Friday, January 15, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
12:02:13 PM Friday, January 15, 2021 : Completing download of data4.cab
12:02:15 PM Friday, January 15, 2021 : https://downloads.ti.com/pspice/esd/installer/software/installsetup.exe?tracked=1 Status is OK
12:02:15 PM Friday, January 15, 2021 : Starting download of installsetup.exe Attempt no 1 DataSize is 951208
12:02:16 PM Friday, January 15, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
12:02:16 PM Friday, January 15, 2021 : Completing download of installsetup.exe
12:03:05 PM Friday, January 15, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
12:03:06 PM Friday, January 15, 2021 : Library URL: https://software-dl.ti.com/pspice/esd/models/library/library.zip
12:03:09 PM Friday, January 15, 2021 : Response Content length = 92751260
12:03:37 PM Friday, January 15, 2021 : Comparing content length
12:03:37 PM Friday, January 15, 2021 : Content Match Success.
12:03:37 PM Friday, January 15, 2021 : C:\Cadence\PSpiceTI\PSpiceTI\Lib\library.zip bytes downloaded = 92751260
12:03:37 PM Friday, January 15, 2021 : Lib downloaded sucessfully at: C:\Cadence\PSpiceTI\PSpiceTI\Lib\library.zip
12:03:37 PM Friday, January 15, 2021 : Completing download of data3.cab
12:03:37 PM Friday, January 15, 2021 : 984980 984980
12:03:37 PM Friday, January 15, 2021 : Setup exe path: C:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe
12:03:37 PM Friday, January 15, 2021 : Allegro Installation Start pid: 19280
12:03:46 PM Friday, January 15, 2021 : NumberOfComponentsToBeInstalled = 34906
12:03:46 PM Friday, January 15, 2021 : Updated NumberOfComponentsToBeInstalled = 35608.56
12:03:46 PM Friday, January 15, 2021 : Updated NumberOfComponentsInstalled = 350
12:11:23 PM Friday, January 15, 2021 : Feature transfer complete..disabling close button
12:11:23 PM Friday, January 15, 2021 : Installing: Runtime packages and redistributables
12:11:23 PM Friday, January 15, 2021 : Installing: Configuring documentation
12:11:27 PM Friday, January 15, 2021 : Installing: Configuring file associations
12:11:28 PM Friday, January 15, 2021 : Installing: Setting permissions for files and folders
12:11:52 PM Friday, January 15, 2021 : Installing: Creating Registries
12:11:53 PM Friday, January 15, 2021 : Installing: Finishing Installation
12:12:12 PM Friday, January 15, 2021 : Unzipping Library start
12:12:12 PM Friday, January 15, 2021 : ExtractZipFile start:
12:12:12 PM Friday, January 15, 2021 : Extraction command: C:\Cadence\PSpiceTI\tools\bin\cdsUnzip.exe -o "C:\Cadence\PSpiceTI\PSpiceTI\Lib\library.zip" -d "C:\CAx\App\CR5000\home\cdssetup\pspTILibDir"
12:13:50 PM Friday, January 15, 2021 : Unzipping finished
12:13:50 PM Friday, January 15, 2021 : Downloading License file
12:13:51 PM Friday, January 15, 2021 : error_code cdsVblDownloadLicense: VblSuccess
12:13:51 PM Friday, January 15, 2021 : Downloading License file finish
12:13:51 PM Friday, January 15, 2021 : PrepareUninstallation
12:13:51 PM Friday, January 15, 2021 : strLocalPath: C:\Users\Uib10234\AppData\Roaming\Cadence\PSpiceTIInstall\TIPSpice.exe
12:13:51 PM Friday, January 15, 2021 : strLocalConfigPath: C:\Users\Uib10234\AppData\Roaming\Cadence\PSpiceTIInstall\TIPSpice.exe.config
12:13:51 PM Friday, January 15, 2021 : strCachedLocForFV174Installer: "C:\Users\Uib10234\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\Uninstall.exe" -runfromtemp -l0x0409 Uninstall -removeonly
12:13:51 PM Friday, January 15, 2021 : ClearRunOnceIfNotNeeded()
12:13:51 PM Friday, January 15, 2021 : installSetupValue =
Touship
Touship,
Do you have any other Cadence software installed on the same computer? Based on the log file, the installation was successful.
How did you launch PSpice for TI?
JC
Touship,
Would you please check if you can access https://cdsplicwc.cadence.com/chws/test/connection.html?
JC
Hi Touship,
Please create a new Windows environment variable CDS_LIC_QA_TesT, the value should be a file you can write to, e.g. C:\Cadence\PSpiceTI\licLog.txt.
Now, close and restart PSpice for TI and proceed with what you were doing.
When the error message comes up, close PSpice for TI. Share the log file licLog.txt with me. You can attach it to this thread or send me a private message.
JC
