Modifying DbreakZ model
Using PSpice for TI, How do you edit BV parameter for the generic breakout zener model? It has not been addressed in other threads. Thank you
    The breakout zener uses a model in C:\Cadence\PSpiceTI\tools\pspice\library\breakout.lib:
    .model Dbreak D Is=1e-14 Cjo=.1pF Rs=.1
    If you don't need to use another diode model, please create a file myzener.lib (or another name you like) and put your diode model in there. Add this LIB file into your simulation profile as the first entry on the configuration -> library tab.
    JC
  • A new part that allows user set the Zener voltage has been added to the library:
