PSpice for TI 2020. Error when I try to install it
Other Parts Discussed in Thread: PSPICE-FOR-TI
I have downloaded 'PSpice-For-TI_setup.exe' from TI. I have an account and an 'Access Key'. When i execute 'PSpice-For-TI_setup.exe', i write the e-mail and access key and when I press the 'Sign In' button, a window opens with this error:
'And error occurred and PSpice for TI 2020 needs to close. Refer to cdsPspiceTIlog.txt at C:\Users\'my_user_name'\AppData\Roaming\Cadence\PspiceTIInstall for erros details."
I copy the contents of the file:
7:41:59 lunes, 10 de mayo de 2021 : Message: An error occurred and PSpice for TI 2020 needs to close.
Refer to cdsPspiceTIlog.txt at C:\Users\(my_user_name)\AppData\Roaming\Cadence\PspiceTIInstall for error details.
7:45:39 lunes, 10 de mayo de 2021 : Initializing
7:45:39 lunes, 10 de mayo de 2021 : Deleting file : C:\Users\(my_user_name)\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
7:45:39 lunes, 10 de mayo de 2021 : Downloading URLs file from : pcb.cadence.com/.../TI_URLs.txt
7:45:39 lunes, 10 de mayo de 2021 : Response Content length = 1724
7:45:39 lunes, 10 de mayo de 2021 : C:\Users\(my_user_name)\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
7:45:39 lunes, 10 de mayo de 2021 : Reading Json URL File
7:45:39 lunes, 10 de mayo de 2021 : setting media download server URL from Json File
7:45:39 lunes, 10 de mayo de 2021 : setting Dll path from Json File
7:45:39 lunes, 10 de mayo de 2021 : Chws URL is: cdsplicwc.cadence.com/.../v1
7:45:39 lunes, 10 de mayo de 2021 : DownloadServerPath is: software-dl.ti.com/.../installer
7:45:39 lunes, 10 de mayo de 2021 : parameter count = 1
7:45:39 lunes, 10 de mayo de 2021 : -wrapper
7:45:40 lunes, 10 de mayo de 2021 : ReleaseVersion in XML: 17.40.006 InstalledVersion on system:
7:45:58 lunes, 10 de mayo de 2021 : An exception occured which is causing the program to close.
7:45:58 lunes, 10 de mayo de 2021 : Details of exception are : Intento de leer o escribir en la memoria protegida. A menudo, esto indica que hay otra memoria dañada.
7:45:58 lunes, 10 de mayo de 2021 : Stack Trace for the exception is en TIPSpice.Utilities.cdsVblRegisterInstallation(String productKey, String bundleName, String chwsUrl)
en TIPSpice.Utilities.RegisterInstallation(String ProdKey)
en TIPSpice.AuthWindow.AuthenticateUser()
en System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
en System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
en System.Windows.Controls.Primitives.ButtonBase.OnClick()
en System.Windows.Controls.Button.OnClick()
en System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
en System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
en System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
en System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
en System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
en System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
en System.Windows.Input.InputManager.ProcessStagingArea()
en System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
en System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
en System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
en System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
en System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
en MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
en MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
en System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
en System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
en System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
en MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
en MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
en System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
en System.Windows.Application.RunDispatcher(Object ignore)
en System.Windows.Application.RunInternal(Window window)
en TIPSpice.App.Main()
7:45:58 lunes, 10 de mayo de 2021 : Message: An error occurred and PSpice for TI 2020 needs to close.
Refer to cdsPspiceTIlog.txt at C:\Users\I_MAS_D\AppData\Roaming\Cadence\PspiceTIInstall for error details.
