SDK: simplelink_cc13x2_26x2_sdk_4_40_04_04
Hardware: CC2640R2F LaunchPad
Code example: simple_peripheral_oad_off_chip
Using Btool to perform off-chip OAD for CC2640R2F, after modifying the block size in Btool from 120kB to 80kB, the first OAD can succuss but the second OAD attemption(with 80kB block size) will fail.
It was stuck on "OAD send UUID discovery", with Unknown Status Type #58.
Please find the Btool log as below. Any idea about the cause of the failure? Thanks.
[110] : <Info> - 11:56:58.054
Start OAD Download
[111] : <Info> - 11:56:58.057
Image Service Discovery
[112] : <Info> - 11:56:58.065
OAD Send UUID Discovery
[113] : <Tx> - 11:56:58.053
-Type : 0x01 (Command)
-OpCode : 0x2016 (HCI_LEReadRemoteUsedFeatures)
-Data Length : 0x02 (2) byte(s)
Handle : 0x0000 (0)
Dump(Tx):
0000:01 16 20 02 00 00 .. ...
[114] : <Tx> - 11:56:58.076
-OpCode : 0xFD86 (GATT_DiscPrimaryServiceByUUID)
-Data Length : 0x12 (18) byte(s)
ConnHandle : 0x0000 (0)
Value : 00:00:00:00:00:00:00:B0:00:40:51:04:C0:FF:00:F0
Dump(Tx):
0000:01 86 FD 12 00 00 00 00 00 00 00 00 00 B0 00 40 ...............@
0010:51 04 C0 FF 00 F0 Q.....
[115] : <Rx> - 11:56:58.106
-Type : 0x04 (Event)
-EventCode : 0x003E (HCI_LE_GenericReportEvent)
-Data Length : 0x0C (12) bytes(s)
LE Event Code : 0x04 (4) (HCI_LE_ReadRemoteUsedFeaturesCompleteEvent)
Status : 0x00 (0) (SUCCESS)
ConnectionId : 0x0000 (0)
Features : 0x00000000000000FD (253) (
Encryption
Reject_Extended_Indication
Slave_Features_Exchange
Ping
Data_Packet_Length_Extension
Privacy
Extended_Scanner_Filter_Policies)
Dump(Rx):
0000:04 3E 0C 04 00 00 00 FD 00 00 00 00 00 00 00 .>.............
[116] : <Rx> - 11:56:58.138
-EventCode : 0x00FF (HCI_LE_ExtEvent)
-Data Length : 0x06 (6) bytes(s)
Event : 0x067F (1663) (GAP_HCI_ExtentionCommandStatus)
Status : 0x17 (23) (bleTimeout)
DataLength : 0x00 (0)
Dump(Rx):
0000:04 FF 06 7F 06 17 86 FD 00 .........
[117] : <Tx> - 11:56:58.138
-OpCode : 0xFE11 (GAP_UpdateLinkParamReq)
-Data Length : 0x0A (10) byte(s)
IntervalMin : 0x0008 (8)
IntervalMax : 0x0008 (8)
ConnLatency : 0x0000 (0)
ConnTimeout : 0x0032 (50)
Dump(Tx):
0000:01 11 FE 0A 00 00 08 00 08 00 00 00 32 00 ............2.
[118] : <Rx> - 11:56:58.215
Dump(Rx):
0000:04 FF 06 7F 06 00 11 FE 00 .........
[119] : <Info> - 11:57:27.111
Device Disconnected
Handle = 0x0000
Addr Type = 0x00 (ADDRTYPE_PUBLIC)
BDAddr = F8:8A:5E:8C:BF:4F
[120] : <Info> - 11:57:27.151
OAD - Restore Connection Settings
[121] : <Error> - 11:57:27.181
OAD Download Not Successful
BR,
Shuyang
