LAUNCHXL-CC26X2R1: Serial socket example in simple link SDK2.3
Part Number: LAUNCHXL-CC26X2R1
We are currently working on the TI SDK 2.3 where I din't get the example project for for serial profile . Form forum I got link for 4.1 SDK where I found the serail socket example for high data stream.
My question is can I port serial socket example from 4.1 to 2.3 SDK does it works?? or is there any  example available for 2.4 please let me know
Thanks in advance
  • Hi Chethan,
    I would recommend using the latest SDK version available on the example. As SDK's age, many issues have been fixed and at a certain point the QDID for the Bluetooth SIG certification on that SDK will expire, which means you wouldn't be able to take it to production if you did your end product listing in time before it's expiration.
  • thanks for reply
    Our  BLE chipset supports cc26x2 SDK version 2.30.00.34 only as it is a pre-production chipset. We need to send 16bytes of data at a time to BLE peripheral device. So we thought to use serial socket example is to possible serial socket example to above mentioned SDK version.
  • Chethan,
    Pre-production silicon is no longer supported. Please update your silicon to production qualified silicon.
