CC2640R2L: Runtime CC2640R2L stops executing functionality
Part Number: CC2640R2L
Hello Team,
SDK version 4.20
Example :Peripheral_Observer & Simple Central
Device type : Using CC2640R2L mains power based only
Issue :
Runtime device stops executing of functionality and after whatever number of power cycle given to the device but problem remains same. We are using second last sector-30  ( out of Sector 0 to Sector 31 ) for data storage purpose.We read image through Flash programmer from both working & Non working device and compared both which shows all sector data except sector - 30 remains unchanged.Same comparison done with other failure samples which shows same result.
We did some following experiments to reach root cause
1. We tried by exchanging CC2640R2L module from now working PCB to Working PCB then also Working PCB stops working.
2. While downloading image ( bin file ) from non working device and reprogram it with same downloaded image then device start working again.
What could be the issue if flash memory remains same even though it stops working ?
Bhavin P
    I think this is a good indicator that the PCB may not be the issue.
    Do you have details about how the issue occurs (e.g what actions do you expect for the device to be "working")?
    How long does it take to happen?
    Have you tried debugging a non-working PCB in CCS?
    Have you tried running default examples on the PCB?
    You mention 2 examples here. Do you see the issue happen with both?
    Do the flash contents of the all non-working devices match?
    Toby
  • Hi Toby,
    Please find your answers
    ANS : YES
    ANS : Compared two non working which flash data exactly matches except sector-30( Second Last )
    Bhavin P
    We tried to debug hanged device using debug without downloading feature in IAR and came to know that after constructing all tasks successfully, when at last code executes BIOS_start() function then it's not coming out of that function and code stucks.
    while holding code run we gets following debug info and for that I am putting some pics of debug window.
    Bhavin P
  • Thanks for sharing this. From offline discussion, looks like the PC = 0xd324 points to a memory read in HalFlashRead.
    For 4.40 SDK, team had introduced a fix for SNV. The fix was in the nvocop.c source file. Both ble5stack and blestack versions are copied here for convenience. Can you try these out and let us know if it resolves the issue?
     @file  nvocop.c
     @brief This module contains the OSAL simple non-volatile memory functions.
     Group: WCS, LPC, BTS
     Target Device: cc2640r2
     Copyright (c) 2009-2021, Texas Instruments Incorporated
     All rights reserved.
     Redistribution and use in source and binary forms, with or without
     modification, are permitted provided that the following conditions
     are met:
     *  Redistributions of source code must retain the above copyright
        notice, this list of conditions and the following disclaimer.
     *  Redistributions in binary form must reproduce the above copyright
        notice, this list of conditions and the following disclaimer in the
        documentation and/or other materials provided with the distribution.
     *  Neither the name of Texas Instruments Incorporated nor the names of
        its contributors may be used to endorse or promote products derived
        from this software without specific prior written permission.
     THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    // Design Overview
    This driver implements a non-volatile (NV) memory system that utilizes 1 page
    of on-chip Flash memory. After initialization, this page is ACTIVE
    and GPRAM, or Cache RAM, is available for "compaction" when the ACTIVE page does
    not have enough empty space for data write operation. Compaction can occur 'just
    in time' during a data write operation or 'on demand' by application request. The
    compaction process IS NOT designed to survive a power cycle before it completes.
    If power is cycled after the page is erased but before all contents have
    been written back to the clean page with the active bit of the page
    header set all data stored in this module will be lost. If a power cycle occurs
    before in compaction before the page is erased, the process is restarted
    during initialization.
    Each Flash page has a "page header" which indicates its current state (ERASED,
    ACTIVE, or XFER), located at the first byte of the Flash page. The remainder of
    the Flash page contains NV data items which are packed together following the
    page header. Each NV data item has two parts, (1) a data block which is stored
    first (lower memory address), (2) immediately followed by item header (higher
    memory address). The item header contains information necessary to traverse the
    packed data items, as well as, current status of each data item. A
    search for the newest instance of an item is sped up by starting the search at
    the last entry in the page (higher memory address).
     * INCLUDES
    #include <string.h>
    #include "hal_adc.h"
    #include "hal_flash.h"
    #include "hal_types.h"
    #include "pwrmon.h"
    #include "osal.h"
    #include "osal_snv.h"
    #include "hal_assert.h"
    #include <driverlib/vims.h>
    #include "nvocop.h"
     * CONSTANTS
    // Length in bytes of a flash word
    #define FLASH_WORD_SIZE            HAL_FLASH_WORD_SIZE
    // NV page header size in bytes
    #define NV_PAGE_HDR_SIZE           FLASH_WORD_SIZE
    // In case pages 0-1 are ever used, define a null page value.
    #define NV_PAGE_NULL               0
    // In case item Id 0 is ever used, define a null item value.
    #define NV_ITEM_NULL               0
    // NV page header offset within a page
    #define NV_PAGE_HDR_OFFSET         0
    // Flag in a length field of an item header to indicate validity
    // of the length field
    #define NV_INVALID_LEN_MARK        0x8000
    // Flag in an ID field of an item header to indicate validity of
    // the identifier field
    #define NV_INVALID_ID_MARK         0x8000
    // Bit difference between active page state indicator value and
    // transfer page state indicator value
    #define NV_ACTIVE_XFER_DIFF        0x00100000
    // active page state indicator value
    #define NV_ACTIVE_PAGE_STATE       NV_ACTIVE_XFER_DIFF
    #define NV_XFER_PAGE_STATE         (NV_ACTIVE_PAGE_STATE ^ NV_ACTIVE_XFER_DIFF)
    #define NV_PAGE                    (uint8)(((uint32)NV_FLASH) / ((uint32)OSAL_NV_PAGE_SIZE))
    // Cache RAM buffer used as a temporary storage buffer during compaction
    // This is volatile memory!
    #define RAM_BUFFER_ADDRESS         (uint8*)0x11000000
     * MACROS
    // Checks whether CC26xx voltage high enough to erase/write NV
    #ifdef NV_VOLTAGE_CHECK
    #define NV_CHECK_VOLTAGE()  (PWRMON_check(MIN_VDD_FLASH))
    #else
    #define NV_CHECK_VOLTAGE()  (TRUE)
    #endif //NV_VOLTAGE_CHECK
     * TYPEDEFS
    // NV item header structure
    typedef struct
      uint16 id;
      uint16 len;
    } NvItemHdr_t;
    // Note that osalSnvId_t and osalSnvLen_t cannot be bigger than uint16
     * EXTERNAL FUNCTIONS
    extern uint8* HalFlashGetAddress( uint8 pg, uint16 offset );
     * GLOBAL VARIABLES
     * LOCAL VARIABLES
    #if defined(__IAR_SYSTEMS_ICC__)
    #if !defined(CC26X2) && !defined(CC13X2)
    #pragma data_alignment=4096
    #else //Agama CC26X2 || CC13X2
    #pragma data_alignment=8192
    #endif ////Agama CC26X2 || CC13X2
    #pragma location = ".snvSectors"
    const uint8 NV_FLASH[FLASH_PAGE_SIZE]  = {0xFF};
    #elif defined __TI_COMPILER_VERSION || defined __TI_COMPILER_VERSION__
    #pragma location = (OSAL_NV_PAGE_BEGIN * OSAL_NV_PAGE_SIZE)
    #else
    #error "Unknown Compiler! Support for SNV not provided!"
    #endif
    // active page offset
    static uint16 pgOff;
    // Flag to indicate that a fatal error occurred while writing to or erasing the
    // Flash memory. If flag is set, it's unsafe to attempt another write or erase.
    // This flag locks writes to Flash until the next system reset.
    static uint8 failF = NVINTF_FAILURE;
    // Flag to indicate that a non-fatal error occurred while writing to or erasing
    // Flash memory. If flag is set, it's safe to attempt another write or erase.
    // This flag is reset by any API calls that cause an erase/write to Flash.
    static uint8 failW;
     * LOCAL FUNCTIONS
    static void   setActivePage( void );
    static void   setXferPage(void);
    static void   erasePage( void );
    static uint16 compactPage( void );
    static void   writeWord( uint16 offset, uint8 *pBuf, osalSnvLen_t cnt );
    static void   writeItem(uint16 offset, osalSnvId_t id, uint16 alignedLen,
                            uint8 *pBuf );
    static uint16 findItemInCache(uint16 offset, osalSnvId_t id);
    static uint16 findItem( uint16 offset, osalSnvId_t id );
    static void   findOffset( void );
    static void   enableCache ( uint8 state );
    static uint8  disableCache ( void );
    // API Functions - NV driver
     * @fn      NV_initNV
     * @brief   Initialize the NV flash pages.
     * @param   param - not used.
     * @return  NVINTF_SUCCESS if initialization succeeds, NVINTF_FAILURE otherwise.
    uint8 NVOCOP_initNV( void *param )
      failW = failF;
    #if !defined( NO_OSAL_SNV )
      uint32 pgHdr;
      failF = failW = NVINTF_SUCCESS;
      // Pick active page and clean up erased page if necessary
      HalFlashRead(NV_PAGE, NV_PAGE_HDR_OFFSET, (uint8 *)(&pgHdr), NV_PAGE_HDR_SIZE);
      if ( pgHdr == NV_ACTIVE_PAGE_STATE )
        findOffset();
      else if ( pgHdr == NV_XFER_PAGE_STATE)
        findOffset();
        compactPage();
      else
        // Erase this page if it is not erased.
        // This is to ensure that any page that we're in the middle of
        // compacting gets erased.
        erasePage();
        setActivePage();
        pgOff = NV_PAGE_HDR_SIZE;
      return failW;
    #else
      return NVINTF_FAILURE;
    #endif // NO_OSAL_SNV
     * @fn      NV_compactNV
     * @brief   Compacts NV if fewer byte are free than minAvail bytes.
     * @param   minAvail - number of free bytes in NV for a compaction to not
     *                     immediately occur.  If set to zero compaction will
     *                     always occur.
     * @return  NVINTF_SUCCESS if successful,
     *          NVINTF_FAILURE if failed
    uint8 NVOCOP_compactNV( uint16 minAvail )
      uint8 ret = failF;
      uint16 remainder;
      if (ret != NVINTF_SUCCESS)
      // Number of bytes left on active page
      remainder = FLASH_PAGE_SIZE - pgOff;
      // Time to do a compaction?
      if( (remainder < minAvail) || (minAvail == 0) )
        // Change the ACTIVE page to XFER mode
        setXferPage();
        // Reset failW
        // Compact page.
        remainder = compactPage();
        if (remainder == 0)
          ret = (failW == NVINTF_SUCCESS) ? NVINTF_FAILURE : failW;
    #endif // !NO_OSAL_SNV
      return ret;
    // API Functions - NV Data Items
     * @fn      NV_readItem
     * @brief   Read data from NV.
     * @param   nv_id  - Valid NV item Id.
     * @param   len    - Length of data to read.
     * @param   *pBuf  - Data is read into this buffer.
     * @return  NVINTF_SUCCESS if successful.
     *          Otherwise, NVINTF_FAILURE for failure.
    uint8 NVOCOP_readItem( NVINTF_itemID_t nv_id, uint16 offset, uint16 len, void *pBuf )
      osalSnvId_t id = nv_id.itemID;
      uint16 itemOffset = findItem(pgOff, id);
      if (itemOffset != 0)
        HalFlashRead(NV_PAGE, itemOffset, pBuf, len);
        return NVINTF_SUCCESS;
     * @fn      NV_writeItem
     * @brief   Write a data item to NV.
     * @param   len   - Length of data to write.
     * @param   *pBuf - Data to write.
     * @return  NVINTF_SUCCESS if successful, failure code otherwise.
    uint8 NVOCOP_writeItem( NVINTF_itemID_t nv_id, uint16 len, void *pBuf )
      uint16 alignedLen;
      // Reset failW
        uint16 offset = findItem(pgOff, id);
        if (offset > 0)
          uint8 tmp;
          osalSnvLen_t i;
          for (i = 0; i < len; i++)
            HalFlashRead(NV_PAGE, offset, &tmp, 1);
            if (tmp != ((uint8 *)pBuf)[i])
              break;
            offset++;
          if (i == len)
            // Changed value is the same value as before.
            // Return here instead of re-writing the same value to NV.
      alignedLen = ((len + FLASH_WORD_SIZE - 1) / FLASH_WORD_SIZE) * FLASH_WORD_SIZE;
      if ( pgOff + alignedLen + FLASH_WORD_SIZE > FLASH_PAGE_SIZE )
        setXferPage();
        compactPage();
      // pBuf shall be referenced beyond its valid length to save code size.
      writeItem(pgOff, id, alignedLen, pBuf);
      // Check if failed
      if (failW != NVINTF_SUCCESS)
        return failW;
      pgOff += alignedLen + FLASH_WORD_SIZE;
    #else
    // Local NV Driver Utility Functions
     * @fn      setActivePage
     * @brief   Set page header active state to be active.
     * @param   none
     * @return  none
    static void setActivePage(void)
      uint32 pgHdr;
      pgHdr = NV_ACTIVE_PAGE_STATE;
      writeWord( NV_PAGE_HDR_OFFSET, (uint8*) &pgHdr, 1);
     * @fn      setXferPage
     * @brief   Set active page header state to be transfer state.
     * @param   none
     * @return  none
      uint32 pgHdr;
      // erase difference bit between active state and xfer state
      pgHdr = NV_XFER_PAGE_STATE;
      writeWord( NV_PAGE_HDR_OFFSET, (uint8*)&pgHdr, 1 );
     * @fn      erasePage
     * @brief   Erases a page in Flash.
     * @param   none
     * @return  none
      if (!NV_CHECK_VOLTAGE())
        // Power monitor indicates low voltage
        failW = NVINTF_FAILURE;
        return;
      else
        halIntState_t cs;
        uint8 state;
        uint32_t err;
        HAL_ENTER_CRITICAL_SECTION(cs);
        // Disable the cache.
        state = disableCache();
        // Erase the page.
        err = FlashSectorErase( (uint32)HalFlashGetAddress(NV_PAGE, 0));
        // Enable the cache.
        enableCache(state);
          // Page erase failed, further usage is unsafe.
        if (err != FAPI_STATUS_SUCCESS)
          failF = failW = NVINTF_FAILURE;
        HAL_EXIT_CRITICAL_SECTION(cs);
     * @fn      findOffset
     * @brief   find an offset of an empty space in active page
     *          where to write a new item to.
     * @param   None
     * @return  none
    static void findOffset(void)
      uint16 offset;
      for (offset = FLASH_PAGE_SIZE - FLASH_WORD_SIZE;
           offset >= NV_PAGE_HDR_SIZE;
           offset -= FLASH_WORD_SIZE)
        uint32 tmp;
        HalFlashRead(NV_PAGE, offset, (uint8 *)&tmp, FLASH_WORD_SIZE);
        if (tmp != 0xFFFFFFFF)
          break;
      pgOff = offset + FLASH_WORD_SIZE;
     * @fn      findItem
     * @brief   find a valid item from a designated page and offset
     * @param   offset - offset in the NV page from where to start search up.
     *                   Usually this parameter is set to the empty space offset.
     * @param   id     - NV item ID to search for
     * @return  offset of the item, 0 when not found
    static uint16 findItem(uint16 offset, osalSnvId_t id)
      offset -= FLASH_WORD_SIZE;
      while (offset >= NV_PAGE_HDR_SIZE)
        NvItemHdr_t hdr;
        HalFlashRead(NV_PAGE, offset, (uint8 *) &hdr, FLASH_WORD_SIZE);
        if (hdr.id == id)
          // item found
          // length field could be corrupt. Mask invalid length mark.
          osalSnvLen_t len = hdr.len & ~NV_INVALID_LEN_MARK;
          return offset - len;
        else if (hdr.len & NV_INVALID_LEN_MARK)
        else
          // valid length field
          if (hdr.len + FLASH_WORD_SIZE <= offset)
            // valid length
            offset -= hdr.len + FLASH_WORD_SIZE;
          else
            // active page is corrupt
            // This could happen if NV initialization failed upon failure to erase
            // page and active page is set to uncleanly erased page.
            HAL_ASSERT_FORCED();
            return 0;
      return 0;
     * @fn      findItemInCache
     * @brief   find a valid item from cache
     * @param   ramBuffer - Points buffer to the start of cache ram 0x11000000.
     * @param   offset    - offset in cache.
     * @param   id        - NV item ID to search for.
      while (offset >= NV_PAGE_HDR_SIZE  && offset < FLASH_PAGE_SIZE)
        NvItemHdr_t hdr;
        // Read header
        memcpy( &hdr, RAM_BUFFER_ADDRESS + offset, FLASH_WORD_SIZE);
        //If you find id return true else update offset and search again
        if ( hdr.id == id )
          return 1;
        else
      return 0;
     * @fn      writeItem
     * @brief   Write a data item to NV. Function can write an entire item to NV
     * @param   offset     - offset within the NV page where to write the new item
     * @param   alignedLen - Length of data to write, alinged in flash word
     *                       boundary
     * @param   pBuf - Data to write.
     * @return  none
    static void writeItem(uint16 offset, osalSnvId_t id, uint16 alignedLen, uint8 *pBuf )
      NvItemHdr_t hdr;
      hdr.id = 0xFFFF;
      hdr.len = alignedLen | NV_INVALID_LEN_MARK;
      // Write the len portion of the header first
      writeWord(offset + alignedLen, (uint8 *) &hdr, 1);
      // remove invalid len mark
      hdr.len &= ~NV_INVALID_LEN_MARK;
      // Copy over the data
      writeWord(offset, pBuf, alignedLen / FLASH_WORD_SIZE);
      // value is valid. Write header except for the most significant bit.
      hdr.id = id | NV_INVALID_ID_MARK;
      // write the most significant bit
      hdr.id &= ~NV_INVALID_ID_MARK;
     * @fn      compactPage
     * @brief   Compacts the page specified.
     * @param   none
     * @return  remaining unused bytes on the flash page.
    static uint16 compactPage()
      uint8 state;
      uint16 srcOff, dstOff;
      osalSnvId_t lastId = (osalSnvId_t) 0xFFFF;
      // Start writing to base of RAM buffer.
      dstOff = 0;
      // Disable cache to use as a temporary storage buffer during compaction.
      // Read from the latest value
      srcOff = pgOff - sizeof(NvItemHdr_t);
      while (srcOff >= NV_PAGE_HDR_SIZE)
        NvItemHdr_t hdr;
        HalFlashRead(NV_PAGE, srcOff, (uint8 *) &hdr, FLASH_WORD_SIZE);
        if (hdr.len + FLASH_WORD_SIZE > srcOff)
          // invalid length. Source page must be a corrupt page.
          // This is possible only if the NV initialization failed upon erasing
          // what is selected as active page.
          // This is supposed to be a very rare case, as power should be
          // shutdown exactly during erase and then the page header is
          // still retained as either the Xfer or the Active state.
          // For production code, it might be useful to attempt to erase the page
          // so that at next power cycle at least the device is runnable
          // (with all entries removed).
          // However, it might be still better not to attempt erasing the page
          // just to see if this very rare case actually happened.
          erasePage();
          // Enable cache use
          enableCache(state);
          return 0;
        if (hdr.id == 0xFFFF || hdr.id == NV_ITEM_NULL)
          // Invalid entry. Skip this one.
            srcOff -= FLASH_WORD_SIZE;
          else
            srcOff -= hdr.len + FLASH_WORD_SIZE;
          continue;
        // Consider only valid item
        if (!(hdr.id & NV_INVALID_ID_MARK) && hdr.id != lastId)
          // lastId is used to speed up compacting in case the same item ID
          // items were neighboring each other contiguously.
          lastId = (osalSnvId_t) hdr.id;
          // Check if the latest value of the item was already written
          if (findItemInCache(dstOff, lastId) == 0)
            // This item was not copied over yet, This must be the latest value.
            // Transfer item from flash active page to cache memory after while loop completes a
            // compacted version of the flash memory will exist in cache.
            HalFlashRead(NV_PAGE, srcOff - hdr.len, RAM_BUFFER_ADDRESS + dstOff,
                         hdr.len + FLASH_WORD_SIZE);
            dstOff += hdr.len + FLASH_WORD_SIZE;
      // Erase the currently active page
      erasePage();
      // Write items back from cache to srcPg
      if (dstOff > 0)
        if (NV_CHECK_VOLTAGE())
          HalFlashWrite((uint32)NV_FLASH + NV_PAGE_HDR_SIZE, RAM_BUFFER_ADDRESS,
                        dstOff);
          // Set srcPg as the active page
          setActivePage();
        else
      // Enable cache use
      enableCache(state);
      if (!failW)
        pgOff = dstOff + NV_PAGE_HDR_SIZE; // update active page offset
        return ( FLASH_PAGE_SIZE - dstOff );
      else
        pgOff = 0;
        return 0;
     * @fn      verifyWordM
     * @brief   verify the written word.
     * @param   offset - A valid offset into the page.
     * @param   pBuf   - Pointer to source buffer.
     * @param   cnt    - Number of 4-byte blocks to verify.
     * @return  none
    static void verifyWordM(uint16 offset, uint8 *pBuf, osalSnvLen_t cnt )
      uint8 tmp[FLASH_WORD_SIZE];
      while (cnt--)
        // Reading byte per byte will reduce code size but will slow down
        // and not sure it will meet the timing requirements.
        HalFlashRead(NV_PAGE, offset, tmp, FLASH_WORD_SIZE);
        if (memcmp(tmp, pBuf, FLASH_WORD_SIZE))
          return;
        offset += FLASH_WORD_SIZE;
        pBuf += FLASH_WORD_SIZE;
     * @fn      writeWord
     * @brief   Writes a Flash-WORD to NV.
     * @param   cnt    - Number of words to write.
     * @return  none
      uint32 addr = (uint32) HalFlashGetAddress(NV_PAGE, offset);
        // Enter Critical Section
        halIntState_t cs;
        // Disable Cache
        uint8 state;
        // Write data.
        HalFlashWrite(addr, pBuf, cnt * (FLASH_WORD_SIZE) );
        // Enable cache.
        enableCache(state);
        verifyWordM(offset, pBuf, cnt);
      else
     * @fn      enableCache
     * @brief   enable cache.
     * @param   state - the VIMS state returned from disableCache.
     * @return  none.
      if ( state != VIMS_MODE_DISABLED )
        // Enable the Cache.
        VIMSModeSet( VIMS_BASE, VIMS_MODE_ENABLED );
     * @fn      disableCache
     * @brief   invalidate and disable cache.
     * @param   none
     * @return  VIMS state
      uint8 state = VIMSModeGet( VIMS_BASE );
      // Check VIMS state
        // Invalidate cache
        VIMSModeSet( VIMS_BASE, VIMS_MODE_DISABLED );
        // Wait for disabling to be complete
        while ( VIMSModeGet( VIMS_BASE ) != VIMS_MODE_DISABLED );
      return state;
     @file  nvocop.c
     are met:
    // Design Overview
     * INCLUDES
    #include <string.h>
    #include "pwrmon.h"
    #include "osal.h"
    #include "nvocop.h"
     * CONSTANTS
    #define NV_PAGE                    (uint8)((uint32)NV_FLASH >> 12)
     * MACROS
    #else
     * TYPEDEFS
    typedef struct
      uint16 id;
      uint16 len;
    } NvItemHdr_t;
     * GLOBAL VARIABLES
     * LOCAL VARIABLES
    // Allocate SNV area in flash.
    #pragma data_alignment=FLASH_PAGE_SIZE
    __no_init const uint8 NV_FLASH[FLASH_PAGE_SIZE];
    #pragma DATA_SECTION(NV_FLASH, ".snvSectors")
    #pragma DATA_ALIGN(NV_FLASH, FLASH_PAGE_SIZE)
    #pragma RETAIN(NV_FLASH)
    #else
    #endif
    static uint8 failW;
     * LOCAL FUNCTIONS
                            uint8 *pBuf );
     * @fn      NV_initNV
      failW = failF;
      uint32 pgHdr;
        findOffset();
        findOffset();
        compactPage();
      else
        erasePage();
        setActivePage();
      return failW;
    #else
     * @fn      NV_compactNV
     *                     always occur.
      uint8 ret = failF;
      uint16 remainder;
        setXferPage();
        // Reset failW
        // Compact page.
        if (remainder == 0)
      return ret;
     * @fn      NV_readItem
     * @fn      NV_writeItem
      uint16 alignedLen;
      // Reset failW
        if (offset > 0)
          uint8 tmp;
          osalSnvLen_t i;
              break;
            offset++;
          if (i == len)
        setXferPage();
        compactPage();
      // Check if failed
        return failW;
    #else
     * @fn      setActivePage
     * @param   none
     * @return  none
      uint32 pgHdr;
     * @fn      setXferPage
     * @param   none
     * @return  none
      uint32 pgHdr;
     * @fn      erasePage
     * @param   none
     * @return  none
        return;
      else
        halIntState_t cs;
        uint8 state;
        uint32_t err;
        // Erase the page.
        enableCache(state);
     * @fn      findOffset
     * @param   None
     * @return  none
      uint16 offset;
        uint32 tmp;
          break;
     * @fn      findItem
        NvItemHdr_t hdr;
        if (hdr.id == id)
          // item found
        else
            // valid length
          else
            return 0;
      return 0;
        NvItemHdr_t hdr;
        // Read header
        if ( hdr.id == id )
          return 1;
        else
      return 0;
     * @fn      writeItem
     *                       boundary
     * @return  none
      NvItemHdr_t hdr;
      hdr.id = 0xFFFF;
     * @fn      compactPage
     * @param   none
      uint8 state;
      dstOff = 0;
        NvItemHdr_t hdr;
          erasePage();
          // Enable cache use
          enableCache(state);
          return 0;
          else
          continue;
      erasePage();
      if (dstOff > 0)
                        dstOff);
          setActivePage();
        else
      // Enable cache use
      enableCache(state);
      if (!failW)
      else
        pgOff = 0;
        return 0;
     * @fn      verifyWordM
     * @return  none
      while (cnt--)
          return;
     * @fn      writeWord
     * @return  none
        halIntState_t cs;
        // Disable Cache
        uint8 state;
        // Write data.
        // Enable cache.
        enableCache(state);
      else
     * @fn      enableCache
     * @return  none.
     * @fn      disableCache
     * @param   none
      // Check VIMS state
        // Invalidate cache
      return state;
  • Some further thoughts:
    As another debug point (if previous code does not solve the issue):
    You have the flow like this:
    1. PCB not working
    2. Read flash from device on non-working PCB to bin
    3. Flash bin to same non-working PCB
    4. Non-working PCB is now working
    After step 4, can you take a reading of the flash and compare that to the bin from step 2?
    If something persists across power cycles, I reason that this is very likely related to something which is also persistent across power cycles (e.g. non-volatile flash). The only difference here is the sector used for NVS.
    If the previously shared nvocop.c file(s) do not work, we will need to investigate why the device reaches this state in the first place.
  • Hi Toby,
    It seems that with using patch in our existing SDK 4.20 issue of hanging is resolved but one more observation found is that SNV area ( Sector - 30 ) is corrupted in devices.
    We kept 12 devices for long run and in 11 devices SNV area is corrupted.
    Bhavin P
  • Apologies for delayed response.
    Are the devices reset at all during the long run?
    From the nvocop.c comment:
    // Design Overview
    Can you check what the page header indicates?
    It seems that a compaction may be occurring, but the process is interrupted (e.g. brownout).
