CC2650: Store status between each wakeup
Part Number: CC2650
to store a status between entering shutdown mode, is there any register can be used since the ble-sending activity shall not be activated once the battery is inserte.
It should only activate after 2nd wakeup. Is there alternative way to do it?
Thanks in advance
Kind regards,
Nanjun
  • Nanjun,
    Thanks for your inquiry. I notified a colleague and he will reply as soon as possible.
    In the meanttime, did you check the pin shutdown example of the TI-RTOS? Since shutdown preserves the contents of RAM, I think such flag could be simply a global variable.
    Rafael
