Part Number: LAUNCHXL-CC26X2R1
I am, evaluating TI Direction Finding solution with this LAUNCHXL-CC26X2R1 and BOOSTXL-AoA. I’ve install all required software and the SDK 5.20.x.x and was able to run the coordinator and responder firmware with both rtls_connectionless.py and rtls_connected.py.
Now I am going through your documents to learn how to change the antenna array pattern and found out that the documents and the example codes are different. The documents are referring to the OLD implementation with SDK 3.x.x.x or something.
1) Do you have the latest documents for direction finding AOA example that goes with SDK 5.20.x.x?
2) Do you have an example code to convert I/Q samples to angles? The documents refer back to the old SDK for angle conversion example, but the old SDK cannot be found.
Thanks in advance,
Sammy
