I'm using a LaunchXL-CC2652R1.
I have changed the simple_bradcast example to be able to broadcast extended advertisings with Coded PHY, but the broadcast doesn't work. I have follow this guide to change the application: https://software-dl.ti.com/simplelink/esd/simplelink_cc2640r2_sdk/2.20.00.49/exports/docs/ble5stack/ble_user_guide/html/ble-stack-5.x/phy.html
I did't know why, so I tried to initiate a Long Range Connection with the project_zero as peripheral and host_test as central following the section Bonus Task 1 of this lab: Bluetooth Low Energy Connections . But it doesn't work either. When I press Scan, no device is found.
Also, I have tried to advertise on LE 2M PHY following the Bonus Task 2 of this lab: Bluetooth 5 PHY (ti.com) . But it doesn't work either.
So, I have as a conclusion that when I use the extended features of my devices, don't work.
Can you please explain me why this is happening?
Daniel
