My current application uses the MSP430F55xx family and at the current time I cannot switch processors. I would like to use the PAN1315 with my project and was wondering if I could get the Bluetooth stack to run on the MSP430F55xx family?
NJC
NJC
NJC,
My recommendation in your case is to use Simply use an EZ430 as a complete bluetooth solution and create a simple program that will receive and send data. The stack will run on the BT5190. Then, connect to the EZ430-RF2560 using the MSP430F55xx using a UART interface. Many TI Experimenter boards include a EZ430 header just for these purposes.
Gustavo
Gustavo,
Thank you for your quick response. Sadly that is not an option since the project I am working on has dimension requirements and an EZ module is too big. Additionally this project is being design for production.
I'll keep looking around for a solution. Thank you again for your help.
NJC
