CC2564MODA: RF test issue
Part Number: CC2564MODA
Other Parts Discussed in Thread: CC2564
Hi team,
Here's an issue may need your help:
NCC testing setup issue!!
It will report the BLE low power & error, the customer would like to know is there anything wrong with the configuration or the modules for testing is broken?
Could you help check this case? Thanks.
Cherry
  • Hi Cherry,
    How are they testing the modules, what is their testing setup? Where is this error message popping up?
    BR,
    Jessica M. Torres
  • Hello Jessica,
    Thanks for your support here!
    The test unit is Intertek (National Notarization) in Taiwan, the lab is set up with an operating SOP, which is normal for the configuration, but the latter section about BLE shows low power, please see the figure below:
    And the operating SOP is as follows:
    PCtool(HCItester)_操作手順_CN.pdf
    Thanks and Best Regards,
    Cherry
  • Hi Cherry,
    Could you send me what is the HCI script they use to test BLE on the device?
    Also to clarify they are using the CC2564MODAEM to complete these tests?
    Jessica M. Torres
  • Hi Cherry,
    I will continue to look into the matter in the week.  In the meantime it may be that the HCI script is incorrect for BLE, try using the following lines from this BT core PLT with HCI Tester app note.
    Send_HCI_VS_DRPb_Tester_Con_TX 0xFD84, 0x4, 0x0, 0, 0, 0x00000000, 0x00000000
    Wait_HCI_Command_Complete_VS_DRPb_Tester_Con_TX_Event 5000, any, HCI_VS_DRPb_Tester_Con_TX, 0x00
    #PM generator on
    Send_HCI_VS_Write_Hardware_Register 0xFF01, 0x0019180c, 0x0101
    Wait_HCI_Command_Complete_VS_Write_Hardware_Register_Event 5000, any, HCI_VS_Write_Hardware_Register, 0x00
    # Disables Continuous Calibration
    Send_HCI_VS_DRPb_Enable_RF_Calibration 0xFD80, 0xFF, 0xFFFFFFFF, 0x01
    Wait_HCI_Command_Complete_VS_DRPb_Enable_RF_Calibration_Event 5000, any, HCI_VS_DRPb_Enable_RF_Calibration, 0x00
    2451.120215 BT BER PLT Test app note.pdf
    Jessica
  • Hello Jessica,
    Thanks for your help.
    Now it can communicate normally and the signal can also be transmitted. Please see the figure below:
    But the measured date is -53dBm, could you help check it?
    Thanks and regards,
    Cherry
  • Hi Cherry,
    That's great!
    I will look into the measured TX output in the lab, and get back to you next week at the latest.
    Jessica
  • Hi Jessica,
    Thanks for your support and expect your response!
    Cherry
  • Hello Jessica,
    Mau I know is there anything new be found?
    Thanks and Regards,
    Cherry
  • Hello Cherry,
    I am still trying to debug my HW setup, will give you an update on the results in a few days.
    Thanks for your patience,
    Jessica
  • Hi Cherry,
    I was not able to test this this week, will get back to you next week with my results.
    Jessica
  • Hi Jessica,
    Understood and expect the results!
    Thanks and regards,
    Cherry
  • Hi Cherry,
    I will be assisting with this issue, but I won't be able to conclude the test until next week. I will try my best to provide an update as soon as possible.
    Seong
  • Cherry,
    Apologies for the late reply. I'll get some measurements done by the end of this week.
    Also, as shown in the image below, I recommend etching off the solder mask in the green box to expose the GND pad, then soldering the cable's GND wire here instead. It is better to have direct connection to GND as opposed to how it is currently connected (yellow line).
    BR,
    Seong
  • Hi Seong,
    Thanks for your help here. I have updated to the customer, and expect the results from your side.
    Thanks and regards,
    Cherry
  • Cherry,
    Unfortunately, while soldering the pigtail SMA cable to the board, the RF filter was damaged so I am unable to complete this test at the moment as I do not have any spare EVM boards.
    I've just ordered CC2564MODAEM boards and they should arrive at my desk in a few days. I can continue the test then.
    So before I get the new boards, I will provide guidance on mounting the cable for RF measurements. Please see Figure 14 in this Antenna Appnote. It is advised that a semi-rigid pigtail cable is used instead of what is shown in provided image of the customer's test setup. This would make it easier to follow the guidelines in my previous post.
    Also, was the cable's insertion loss measured and taken into account?
    BR,
    Seong
  • Hi Seong,
    Noted and thanks again for your support!
    Here's some updates from the customer side:
    After changing the GND connection, the problem still remains. When set to 22_BLE_Lch (2402MHz) , it will be low power, when changing to 10_GFSK_Lch , it will be the normal signal.
    Thanks and regards,
    Cherry
  • Cherry,
    Thank you for providing these. While we are waiting for my samples to arrive, can you show me what the new cable connection looks like?
    Below image shows how a semi-rigid cable cable should be soldered onto a board for RF conducted measurements. Note how the GND connection is close to the conductor pin.
    Seong
  • Hi Seong,
    Thanks and regards,
    Cherry
  • Cherry,
    It is hard to see what is actually going on in this picture, but I will provide my test results within the next few days.
    Seong
  • Hi Seong,
    No problem! Thanks for your help again!
    Cherry
  • Hi Cherry,
    I just measured the BLE output power on my board and I am measuring ~10dBm.
    Attached are the INIT, BLE add-on SP, and TX command scripts I used.
    # Description : Orca L PG 2.0 ROM Initialization Script
    # Compatibility: Orca, 7.0.16 ROM
    # Last Updated: 10-Jun-2019  11:42:14.51
    # Version     : TI_P7_16.42
    # Notes       : Use this script on Orca L PG 2.0, 7.0.16 ROM device only (FW v7.0.16)
    ## START of CC256x Add-On
    ## Change UART baudrate
    Send_HCI_VS_Update_Uart_HCI_Baudrate 0xFF36, 0x0001c200
    Wait_HCI_Command_Complete_VS_Update_Uart_HCI_Baudrate_Event 5000, any, 0xff36, 0x00
    Com_SetParams 115200, 1
    ## END of CC256x Add-On
    Send_HCI_VS_Start_VS_Lock 0xFE37, 0x07, 0x10
    Wait_HCI_Command_Complete_VS_Start_VS_Lock_Event 5000, any, 0xfe37, 0x00
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00086140, 0xfa, "07:10:47:2A:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:FF:B5:00:90:47:68:FF:20:26:30:C0:5D:00:28:26:D0:01:38:1D:D0:01:38:2A:D1:FF:24:95:34:E5:19:29:88:08:20:01:26:B6:46:37:4A:FE:44:10:47:00:29:01:D1:02:20:07:E0:E5:19:29:88:08:20:B6:46:31:4A:FE:44:10:47:48:1C:E9:88:0C:1C:44:43:60:2C:0F:D9:0F:E0:FF:20:99:30:C0:5B:5E:28:09:DB:C4:1C:08:E0:FF:20:ED:30:C4:5B:10:2C:02:DD:06:20:44:43:00:E0:60:24:41:20:00:21:01:22:96:46:1C:4A:FE:44:10:47:01:90:61:08:40:18:01:30:80:01:80:09:02:90:18:4D:00:26:A8:7B:00:28:1F:D0:28:7C:39:78:81:42:1B:D1:15:48:00:2E:00:D0:14:30:00:68:80:06:80:0E:01:99:08:18:80:01:80:09:02:99:01:22:96:46:0F:4A:FE:44:10:47:29:7B:03:91:01:22:96:46:0C:4A:FE:44:10:47:02:28:01:DA"
    Wait_HCI_Command_Complete_VS_Write_Memory_Block_Event 5000, any, 0xff05, 0x00
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x0008623a, 0xfa, "03:98:04:19:28:35:01:36:02:2E:D8:D3:00:98:44:60:07:48:33:30:00:90:FF:BD:C0:46:93:E4:04:00:38:1D:08:00:0C:05:1A:00:39:7A:04:00:AD:45:05:00:7B:BF:02:00:AD:45:05:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:78:B5:01:24:A6:46:DB:48:FE:44:00:47:06:1C:DA:4D:28:68:DA:49:09:88:08:18:80:01:80:09:31:1C:A6:46:D7:4A:FE:44:10:47:00:28:0C:D4:D6:48:00:78:04:28:08:D1:D5:48:00:78:03:28:04:D1:2E:60:A6:46:E4:48:FE:44:00:47:E3:4D:28:68:19:21:49:01:08:18:80:01:80:09:31:1C:A6:46:CA:4A:FE:44:10:47:00:28:4C:D4:2E:60:DD:48:01:78:DD:48"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00086334, 0xfa, "00:88:08:43:1A:D0:00:29:18:D0:22:21:E4:48:20:22:12:5C:01:2A:12:D1:09:5C:00:29:0F:D0:41:7F:08:29:0C:D1:09:21:41:77:DF:48:03:21:A6:46:DE:4A:FE:44:10:47:04:20:A6:46:DD:49:FE:44:08:47:00:25:68:1C:00:04:00:0C:A6:46:DA:49:FE:44:08:47:00:28:1D:D0:81:7C:0A:02:C1:7C:11:43:0A:02:01:7D:11:43:0A:02:41:7D:11:43:00:91:69:1C:00:78:A8:22:42:43:D2:48:80:5C:40:00:CF:4A:12:5A:D1:48:40:5D:CF:4B:1B:56:7B:20:80:00:A6:46:CF:4E:FE:44:30:47:01:35:07:2D:D5:DB:E5:48:00:68:50:28:05:D9:E4:48:00:21:A6:46:C1:4A:FE:44:10:47:78:BD:30:B5:05:1C:9C:4C:7E:34:A0:78:03:28:0F:D1:20:88:00:28:0C:D1:E8:69:02:28:09:D1:01:20:86:46:DA:48:FE:44:00:47:02:20:A0:70:D8:48:CA:30:28:62:30:BD:F8:B5:06:1C:B7:69:B0:8A:00:90:E4:49:40:1A:0A:D0:97:38:51:D0:8C:38:45:D0:01:38:3C:D0:22:38:2B:D0:01:38"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x0008642e, 0xfa, "25:D0:F8:BD:21:20:C5:5D:38:1C:00:21:01:24:A6:46:DC:4A:FE:44:10:47:7D:21:C9:00:41:43:D8:48:01:60:00:2D:41:D0:FF:2D:3F:D0:38:1C:29:1C:A6:46:D5:4A:FE:44:10:47:D5:48:02:21:A6:46:D4:4A:FE:44:10:47:00:28:0E:D1:CE:48:D2:49:09:68:01:60:09:E0:01:20:D1:49:08:80:05:E0:38:1C:01:21:8E:46:E6:49:FE:44:08:47:38:1C:00:99:00:22:01:23:9E:46:E3:4B:FE:44:18:47:0C:E0:38:1C:01:21:8E:46:E0:49:FE:44:08:47:05:E0:38:1C:01:21:8E:46:DE:49:FE:44:08:47:DD:48:9E:30:30:62:F8:BD:01:24:A6:46:DB:48:FE:44:00:47:A6:46:DA:48:FE:44:00:47:F8:BD:70:B5:85:69:00:7D:44:21:40:1A:01:28:26:D9:0F:38:0C:D0:28:38:2B:D1:28:78:03:28:28:D1:3B:20:C0:43:05:21:49:57:81:42:22:DD:68:71:70:BD:28:78:00:28:1D:D1:CD:4E:30:1C:01:24:A6:46:CC:49:FE:44:08:47:A8:70:E8:1C:31:1C:0A:22:A6:46:C9:4B:FE:44:18:47"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00086528, 0xfa, "28:1C:A6:46:C7:49:FE:44:08:47:70:BD:46:48:00:78:04:28:04:D1:01:20:86:46:BE:48:FE:44:00:47:70:BD:70:B5:04:1C:66:69:20:7F:17:22:80:1A:3E:4D:24:D0:68:38:34:D1:FF:20:7D:30:80:5D:0D:28:2F:D1:20:69:01:78:30:1C:01:24:A6:46:DA:4A:FE:44:10:47:01:1C:25:D0:08:68:B0:42:22:D1:77:3D:28:78:01:28:1E:D0:08:79:00:28:1B:D0:D4:4D:2C:70:4D:20:A6:46:D3:4A:FE:44:10:47:00:20:28:70:70:BD:82:3D:28:78:05:28:0D:DB:FF:20:79:30:81:5D:30:1C:24:23:01:25:AE:46:CB:4D:FE:44:28:47:CC:48:CA:49:08:18:20:62:70:BD:70:B5:05:1C:2C:69:A2:8E:23:8F:93:42:32:DD:C7:48:01:78:60:8D:01:30:41:43:08:04:00:0C:82:42:29:DA:C6:26:31:5D:C9:09:25:D1:10:1A:C1:49:08:18:83:42:20:DD:C5:20:00:5D:01:28:01:D0:03:28:1A:D1:30:5D:01:28:05:D1:CE:21:09:5D:10:29:04:D0:11:29:02:D0:02:28:0A:D0:70:BD:B5:20:00:5D"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00086622, 0xfa, "00:21:01:22:96:46:B4:4A:FE:44:10:47:02:20:30:55:B3:49:97:20:C0:00:40:18:28:62:70:BD:C0:46:47:76:04:00:5C:61:08:00:4A:61:08:00:39:7A:04:00:45:10:08:00:2C:24:08:00:70:B5:02:69:D4:8E:15:8F:A5:42:1A:DD:C8:21:8B:5C:40:21:19:40:DE:11:F6:01:31:43:12:D1:2C:1B:52:49:86:31:09:78:09:02:8C:42:0B:DD:02:2B:09:D1:C7:21:89:5C:01:29:01:D0:03:29:03:D1:DE:49:DC:4A:51:18:01:62:70:BD:C1:6B:08:00:58:61:08:00:84:18:08:00:46:61:08:00:30:B5:D8:49:D8:4A:13:32:1F:20:00:23:01:24:A6:46:D6:4D:FE:44:28:47:D7:48:00:88:40:0A:00:D2:00:24:D3:48:04:70:30:BD:C0:46:50:17:08:00:00:04:1A:00:B5:F5:04:00:F9:15:05:00:D9:8F:01:00:20:0C:1A:00:CD:18:08:00:78:20:08:00:59:15:08:00:85:87:04:00:F0:B5:06:1C:35:69:30:7E:00:28:1D:D1:C7:27:78:5D:01:28:19:D1:28:1C:01:21:0C:1C:8E:46:C2:4A:FE:44"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x0008671c, 0xfa, "10:47:28:1C:A6:46:BA:49:FE:44:08:47:C8:21:48:5D:1B:28:06:D1:CD:20:40:5D:01:28:02:D1:00:20:78:55:48:55:E7:48:3A:30:30:62:E6:49:E5:4A:5D:32:1F:20:00:23:01:24:A6:46:B1:4C:FE:44:20:47:F0:BD:C0:46:C8:62:08:00:F8:21:19:00:3F:83:02:00:11:24:03:00:10:B5:61:4B:1B:78:40:8D:01:30:43:43:1C:04:24:0C:5E:4B:91:42:07:DB:88:1A:19:1B:88:42:0C:DD:01:21:09:04:40:1A:10:BD:A1:42:02:DA:18:1B:82:42:01:DC:88:1A:10:BD:88:1A:18:18:10:BD:C0:46:06:FD:00:00:BC:62:08:00:51:2A:00:00:C9:67:08:00:04:50:1A:00:6B:F7:04:00:6C:4F:08:00:62:61:08:00:F8:B5:0D:1C:06:1C:00:90:01:24:A6:46:C3:49:FE:44:08:47:30:1C:03:21:A6:46:E5:4A:FE:44:10:47:07:1C:E4:4E:35:80:00:98:07:21:A6:46:E9:4A:FE:44:10:47:00:28:01:D1:68:08:70:80:E6:48:02:21:A6:46:E6:4A:FE:44:10:47:00:28:07:D1:38:1C:68:43:E3:49"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00086816, 0xfa, "08:60:A6:46:DE:49:FE:44:08:47:F8:BD:C0:46:81:6B:08:00:A9:25:05:00:71:70:08:00:05:71:08:00:7D:5E:00:00:C9:6E:08:00:FD:6F:08:00:60:12:08:00:ED:2F:01:00:09:59:05:00:51:BC:04:00:F8:B5:00:90:45:69:68:7C:10:28:11:D1:28:7C:D2:49:06:28:0B:D0:0A:88:01:2A:0A:D1:01:28:01:D0:00:20:05:E0:00:20:08:80:03:20:28:74:01:E0:01:20:08:80:68:7C:0D:28:1B:D1:28:7C:00:28:18:D1:C7:4F:02:26:38:1C:01:24:A6:46:C6:49:FE:44:08:47:03:E0:A6:46:C4:49:FE:44:08:47:00:28:06:D0:01:7A:0D:29:F6:D1:C1:49:4C:31:00:98:01:62:0C:37:01:3E:E8:D1:68:7C:06:28:0A:D1:28:7C:BD:49:06:28:04:D0:08:88:01:28:03:D1:00:20:00:E0:01:20:08:80:F8:BD:69:7D:02:00:64:61:08:00:93:E4:04:00:85:F8:00:00:18:0F:00:00:1D:E4:00:00:2E:2E:08:00:FF:FF:00:00:CB:A3:00:00:ED:92:00:00:F8:B5:00:90:82:69:51:78:C7:69:0B:1F"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00086910, 0xfa, "70:D0:21:3B:E6:48:33:D0:01:3B:73:D1:04:23:BB:80:0C:23:DE:19:49:00:12:78:0A:43:32:70:01:36:00:78:00:28:02:D1:06:25:28:1C:01:E0:07:20:06:25:30:70:01:36:30:1C:0D:21:01:24:A6:46:DE:4A:FE:44:10:47:06:1C:A6:46:DD:48:FE:44:00:47:C0:06:C0:0E:81:02:D9:48:00:78:40:06:40:0E:08:43:07:21:C9:01:01:43:09:04:09:0C:30:1C:A6:46:D2:4A:FE:44:10:47:30:E0:04:23:BB:80:0C:23:DE:19:49:00:12:78:0A:43:32:70:01:36:00:78:00:28:02:D1:06:25:28:1C:01:E0:07:20:06:25:30:70:01:36:30:1C:0D:21:01:24:A6:46:C5:4A:FE:44:10:47:06:1C:A6:46:C4:48:FE:44:00:47:C0:06:C0:0E:81:02:C0:48:00:78:40:06:40:0E:08:43:07:21:C9:01:01:43:09:04:09:0C:30:1C:A6:46:B9:4A:FE:44:10:47:7D:80:03:20:38:80:BA:48:B9:49:09:18:00:98:01:62:F8:BD:10:79:27:28:04:D1:50:79:1E:28:01:D1:23:20:50:71:F8:BD:C0:46:82:04"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00086a0a, 0xfa, "00:00:45:9F:00:00:3F:72:08:00:A9:86:00:00:11:72:08:00:55:31:19:00:3E:A6:1B:00:89:83:00:00:F0:B5:06:1C:F4:69:22:88:10:04:00:0E:01:02:25:20:00:02:09:1A:9C:48:32:D0:05:23:9B:02:C9:1A:10:D0:1B:20:00:02:09:1A:43:D1:10:06:00:0E:04:28:3F:D1:60:7A:01:21:8E:46:CF:49:FE:44:08:47:00:28:2D:D0:F0:BD:C0:78:00:28:33:D0:20:1C:01:24:A6:46:CA:49:FE:44:08:47:C9:4D:2F:1C:C9:48:00:78:01:28:01:D1:00:2F:06:D1:AF:42:1F:D2:A6:46:C6:48:FE:44:00:47:1A:E0:A6:46:C6:48:FE:44:00:47:01:3F:EC:E7:21:78:A8:22:4A:43:C3:4B:9A:5C:00:2A:11:D0:C0:38:00:78:00:28:0D:D1:C0:48:40:5C:07:28:09:DB:20:1C:01:21:8E:46:BE:49:FE:44:08:47:B8:48:B7:49:08:18:30:62:F0:BD:C0:46:AD:99:00:00:FF:72:08:00:B1:2F:00:00:30:B5:05:69:B7:48:00:21:01:24:A6:46:2A:4A:FE:44:10:47:B5:49:01:28:01:D0:00:20:01:E0"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00086b04, 0xfa, "08:68:01:30:08:60:A6:46:AE:48:FE:44:00:47:00:28:08:D0:A6:46:E5:48:FE:44:00:47:00:28:02:D0:02:20:E3:49:08:80:E3:49:E8:68:88:42:22:D1:E2:48:00:78:80:08:1E:D2:E2:48:41:7F:05:29:1A:D1:02:21:41:77:DE:48:00:78:E8:70:59:48:C1:38:00:78:FF:28:05:D1:E6:48:03:21:A6:46:E6:4A:FE:44:10:47:E1:4D:2C:80:A6:46:E1:48:FE:44:00:47:2C:80:A6:46:DE:48:FE:44:00:47:30:BD:65:2A:00:00:00:50:1A:00:00:B5:00:21:01:22:96:46:DC:4A:FE:44:10:47:DA:49:08:80:00:BD:CD:16:03:00:51:2A:00:00:04:50:1A:00:6B:F7:04:00:6C:4F:08:00:44:61:08:00:5C:18:08:00:4F:0C:04:00:5B:0C:04:00:89:3F:04:00:46:61:08:00:F8:B5:CF:48:00:88:C0:08:CE:4C:22:88:D4:49:8A:42:39:D0:D4:49:09:78:03:29:35:D1:61:88:8D:1A:CA:4A:83:1A:88:42:02:D5:00:22:D7:43:00:E0:01:27:00:2D:02:D5:00:22:D6:43:00:E0:01:26:C4:4A:12:78"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00086bfe, 0xfa, "96:46:C3:4A:12:78:94:46:01:22:00:92:C2:4A:B7:42:11:D1:76:46:36:06:36:16:5E:43:67:46:3E:41:00:2D:04:DC:00:2B:0B:DD:12:78:96:19:08:E0:00:2B:06:DC:12:78:B6:1A:03:E0:16:78:00:2B:00:DC:76:42:B7:4A:12:78:B5:4B:1A:70:02:E0:61:88:00:26:00:96:B6:4A:12:68:13:1C:73:43:1B:15:21:80:60:80:E2:48:00:78:31:1C:00:DA:49:42:81:42:04:DD:00:2E:00:D5:40:42:50:43:03:15:0F:4D:41:3D:E8:6F:1E:18:DB:48:00:78:50:43:00:0D:B1:1A:00:DA:49:42:81:42:19:D8:00:98:00:28:16:D0:D6:48:00:78:00:28:12:D0:D5:48:02:21:01:24:A6:46:D4:4A:FE:44:10:47:00:28:09:D1:02:E0:C0:46:31:4F:08:00:EE:67:30:1C:A6:46:CF:49:FE:44:08:47:F8:BD:C0:46:E7:2A:00:00:FB:4F:08:00:89:91:04:00:CA:04:00:00:61:DE:00:00:F0:B5:05:1C:AE:69:EF:69:38:88:DF:49:40:1A:3E:D0:DE:49:40:1A:01:28:2F:D9:25:38:51:D1:DD:48:00:88"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00086cf8, 0xfa, "00:28:4D:D0:30:1C:01:24:A6:46:D9:49:FE:44:08:47:FF:20:1C:30:81:5D:00:29:01:D1:02:21:81:55:FF:21:1E:31:89:5D:00:29:04:D1:82:5D:01:2A:01:D0:00:2A:06:D1:01:29:0A:D1:80:5D:03:28:07:D0:02:28:05:D0:30:1C:A6:46:EC:49:FE:44:08:47:24:E0:30:1C:A6:46:EA:49:FE:44:08:47:1E:E0:3A:20:80:5D:00:28:1F:D0:38:1C:01:21:8E:46:19:49:FE:44:08:47:13:E0:E1:48:00:78:05:28:14:DB:FF:20:26:30:82:5D:30:1C:07:21:00:23:01:24:A6:46:DF:4E:FE:44:30:47:38:1C:A6:46:0E:49:FE:44:08:47:DA:49:5F:20:00:01:40:18:28:62:F0:BD:C0:46:0B:34:04:00:F3:1A:02:00:A0:86:01:00:0F:54:08:00:0F:1A:02:00:42:05:00:00:D9:A3:02:00:17:8F:03:00:C8:18:08:00:50:15:08:00:8D:08:04:00:19:DE:01:00:F8:21:19:00:C8:62:08:00:F0:B5:85:B0:07:1C:B8:69:04:90:B9:8A:E9:48:08:1A:26:D0:E9:49:40:1A:5E:D1:E8:4D:C4:48:00:78"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00086df2, 0xfa, "02:28:59:D1:01:24:A6:46:E6:48:FE:44:00:47:00:28:52:D1:A6:46:E4:48:FE:44:00:47:00:28:4C:D1:A6:46:27:48:FE:44:00:47:00:28:46:D1:28:78:00:28:43:D1:A8:78:00:28:40:D1:A6:20:A6:46:DB:49:FE:44:08:47:3A:E0:04:98:00:21:6A:46:01:24:A6:46:D8:4B:FE:44:18:47:02:A8:00:21:06:22:A6:46:D5:4B:FE:44:18:47:00:25:02:E0:68:1C:05:04:2D:0C:D2:48:00:78:85:42:22:DA:11:20:40:01:68:43:D0:49:0E:18:10:20:80:19:69:46:A6:46:CE:4A:FE:44:10:47:00:28:EA:D1:68:46:02:A9:A6:46:CA:4A:FE:44:10:47:00:28:E2:D0:B0:78:01:28:DF:D0:04:98:BB:49:3A:22:A6:46:C5:4B:FE:44:18:47:C4:48:E2:30:38:62:05:B0:F0:BD:C0:46:CD:33:04:00:4A:24:19:00:7B:86:03:00:11:22:08:00:4A:56:08:00:50:17:08:00:10:B5:15:4C:0C:48:04:80:01:20:86:46:B9:48:FE:44:00:47:B9:49:08:60:09:48:04:80:44:80:10:BD:C0:46:82:07:1A:00"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00086eec, 0xfa, "F9:8E:03:00:00:04:1A:00:B5:F5:04:00:60:61:08:00:51:2A:00:00:50:1D:18:00:54:61:08:00:68:10:00:00:4E:61:08:00:4F:61:08:00:52:61:08:00:4D:61:08:00:4C:61:08:00:FF:FF:00:00:2C:24:08:00:BC:62:08:00:F0:B5:06:1C:35:69:D5:27:7F:00:B1:69:00:29:52:D0:8A:88:50:18:52:18:13:7A:5A:08:F8:2B:01:D3:43:7A:00:E0:00:23:00:7A:C0:07:C0:0F:84:46:39:20:40:5D:9C:4C:25:28:01:D1:13:2A:32:D0:0A:28:03:D1:0F:2A:25:D0:13:2A:23:D0:3A:20:40:5D:20:28:01:D1:19:2B:13:D0:18:2A:2F:D1:24:28:2D:D1:78:5D:02:28:05:D1:28:1C:01:21:8E:46:8C:49:FE:44:08:47:28:1C:01:21:8E:46:8A:49:FE:44:08:47:F0:BD:FF:20:6D:30:40:19:01:22:96:46:86:4A:FE:44:10:47:F6:34:12:E0:28:1C:61:46:24:23:01:25:AE:46:83:4D:FE:44:28:47:08:E0:28:1C:61:46:13:22:24:23:01:25:AE:46:7E:4D:FE:44:28:47:EC:34:34:62:F0:BD:51:61"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00086fe6, 0xfa, "08:00:53:61:08:00:50:61:08:00:04:50:1A:00:6B:F7:04:00:CD:16:03:00:78:B5:00:26:00:96:01:24:A6:46:74:48:FE:44:00:47:73:4D:A8:6D:69:46:A6:46:72:4A:FE:44:10:47:17:21:00:98:01:70:A8:6D:00:99:32:1C:A6:46:6E:4B:FE:44:18:47:6E:4D:0C:20:A8:81:28:69:40:88:0C:28:0C:D0:01:26:B6:02:00:2E:08:D0:A6:46:69:48:FE:44:00:47:01:3E:28:69:40:88:0C:28:F4:D1:A6:46:65:48:FE:44:00:47:78:BD:03:08:00:00:F0:F4:00:00:05:68:03:00:62:61:08:00:F0:B5:87:B0:06:90:5F:48:07:68:01:24:A6:46:56:48:FE:44:00:47:5C:4E:30:1C:01:30:C0:5D:6D:46:28:71:F0:5D:68:71:A8:1D:0B:21:C9:01:C9:59:A6:46:57:4A:FE:44:10:47:AF:21:C9:00:C9:59:A6:46:53:4A:FE:44:10:47:57:21:09:01:C9:59:A6:46:50:4A:FE:44:10:47:22:3E:F1:59:A6:46:4D:4A:FE:44:10:47:A6:46:48:48:FE:44:00:47:12:20:28:70:06:98:49:49:00:22:01:AB"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x000870e0, 0xfa, "A6:46:48:4C:FE:44:20:47:07:B0:F0:BD:C3:0F:08:00:17:08:05:00:35:F7:01:00:D9:E5:01:00:1D:42:02:00:45:10:08:00:F8:B5:00:90:3A:48:07:68:01:25:AE:46:31:48:FE:44:00:47:00:24:37:4E:30:1C:32:38:C4:51:30:1C:2A:38:C4:51:30:1C:22:38:C4:51:B1:20:C0:00:C4:51:30:1C:1A:38:C4:51:59:20:00:01:C4:51:30:1C:12:38:C4:51:08:20:C0:19:04:21:AE:46:2E:4A:FE:44:10:47:B3:20:C0:00:C4:51:57:20:00:01:C4:51:AF:20:C0:00:C4:51:0B:20:C0:01:C4:51:01:3E:F4:55:AE:46:1F:48:FE:44:00:47:00:98:21:49:01:39:22:1C:AE:46:22:4B:FE:44:18:47:F8:BD:05:04:00:00:19:1C:00:00:C1:0F:08:00:99:51:03:00:9B:33:03:00:89:E4:04:00:81:2A:00:00:15:5F:05:00:33:4F:08:00:00:00:08:00:81:94:03:00:D9:3E:02:00:25:00:00:00:47:76:04:00:5C:61:08:00:91:74:04:00:91:F7:01:00:8B:09:04:00:8B:F7:00:00:85:F8:00:00:47:15"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x000871da, 0xfa, "05:00:14:54:08:00:BD:59:05:00:E7:59:05:00:14:24:08:00:21:8F:03:00:85:26:04:00:DC:50:08:00:A6:05:00:00:D5:2A:00:00:2A:FE:00:00:1D:26:05:00:99:94:03:00:A9:25:05:00:40:1E:80:00:D8:4B:19:50:D6:49:0A:50:F7:46:00:B5:D6:4A:01:8B:91:42:07:D0:40:69:40:30:2C:21:01:22:96:46:EC:4A:FE:44:10:47:EB:48:2B:30:00:BD:FC:B5:01:90:45:69:00:24:B8:20:40:5D:01:28:37:D1:C7:26:70:5D:01:28:0D:D0:03:28:0B:D0:28:1C:01:21:8E:46:EA:49:FE:44:08:47:BF:20:40:5D:01:28:27:D1:6C:8D:25:E0:C0:20:44:55:77:5D:74:55:28:1C:01:21:8E:46:E2:49:FE:44:08:47:77:55:BF:26:70:5D:01:28:16:D1:E9:8E:2A:8F:28:1C:01:23:9E:46:DD:4B:FE:44:18:47:00:04:00:0C:04:28:06:DD:6C:8D:C0:1E:84:42:06:DB:04:04:24:0C:03:E0:03:21:C0:20:41:55:74:55:28:8D:61:1C:41:43:08:04:00:0C:01:99:88:61:D1:49:FC:39:09:78:C9:09"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x000872d4, 0xfa, "10:D3:2E:8D:31:1C:01:24:A6:46:EC:4A:FE:44:10:47:00:96:EB:48:02:78:BB:20:43:5D:3A:20:A6:46:EE:4C:FE:44:20:47:ED:48:B5:30:FC:BD:01:1C:0A:7B:EC:48:00:2A:02:D0:C9:69:02:29:01:D1:63:30:F7:46:E9:49:43:39:08:18:F7:46:02:8A:01:79:0A:29:00:DB:0A:21:E5:48:8A:42:01:DD:65:30:F7:46:5B:30:F7:46:01:6A:C8:7B:00:02:89:7B:01:43:B5:48:52:30:02:88:DF:48:91:42:01:D1:2D:30:F7:46:29:30:F7:46:F0:B5:DC:49:00:7F:C0:00:40:18:02:1F:13:88:87:48:DA:38:18:40:10:80:2F:27:3F:02:EF:4D:2F:82:0C:04:24:0C:2C:80:14:26:08:E0:64:20:01:21:8E:46:EB:49:FE:44:08:47:70:1E:06:06:36:0E:A8:89:80:0B:01:D2:00:2E:F1:D1:A8:89:40:05:40:0F:17:D0:07:20:00:02:68:81:2F:82:EB:48:28:81:2C:80:14:24:08:E0:64:20:01:21:8E:46:DD:49:FE:44:08:47:60:1E:04:06:24:0E:A8:89:80:0B:01:D2:00:2C:F1:D1:A8:89:68:88"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x000873ce, 0xfa, "BC:48:FF:30:34:30:F0:BD:10:B5:01:6A:DF:4A:12:68:92:88:12:13:92:07:93:0F:DD:4A:02:2B:01:D0:13:88:00:E0:03:8B:44:68:0C:19:44:60:83:61:48:88:18:1A:10:80:AF:48:E7:30:10:BD:70:B5:05:1C:68:68:00:28:1A:D1:D3:4E:35:20:00:01:84:19:20:68:01:21:8E:46:D1:49:FE:44:08:47:20:7F:00:28:0D:D0:CF:48:00:78:02:28:09:D0:E0:7F:50:21:41:43:71:18:48:8E:01:30:48:86:60:8A:01:38:60:82:00:20:C3:49:08:60:01:20:86:46:C6:48:FE:44:00:47:68:60:C5:48:65:30:70:BD:C5:48:D5:30:F7:46:00:B5:40:69:01:21:8E:46:C2:49:FE:44:08:47:C2:48:35:30:00:BD:41:69:09:7C:06:29:02:D1:01:21:BF:4A:11:80:0F:21:81:60:BE:48:53:30:F7:46:C1:68:43:68:0A:78:0C:2A:07:D1:BB:4A:12:78:00:2A:01:D1:06:22:00:E0:07:22:4A:70:43:61:B7:48:09:30:F7:46:10:B5:80:69:B4:49:09:78:00:29:09:D1:06:24:04:70:01:30:00:21:01:22"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x000874c8, 0xfa, "96:46:B1:4A:FE:44:10:47:08:E0:07:24:04:70:01:30:00:21:01:22:96:46:AC:4A:FE:44:10:47:04:70:01:30:0D:21:01:24:A6:46:A8:4A:FE:44:10:47:E9:49:A6:46:A5:4A:FE:44:10:47:E8:48:5D:30:10:BD:01:1C:E8:48:02:78:E6:48:00:2A:01:D0:5D:30:F7:46:28:22:8A:60:C0:1C:F7:46:E3:49:09:78:05:29:02:D1:01:21:E2:4A:11:70:23:21:81:60:E1:48:27:30:F7:46:10:B5:01:7E:00:7D:08:43:DE:4C:0A:D0:00:20:ED:49:08:70:01:20:86:46:EC:48:FE:44:00:47:20:1C:79:30:10:BD:20:1C:71:30:10:BD:81:69:4A:78:C2:60:49:78:18:29:01:DB:17:21:C1:60:E4:48:39:30:F7:46:C0:46:04:F3:1A:00:80:7B:08:00:D9:FC:00:00:F0:B5:45:68:87:68:01:24:A4:02:05:E0:01:20:86:46:E7:48:FE:44:00:47:01:3C:A8:78:69:78:09:1A:E5:4E:03:29:10:D0:C9:1C:0E:D0:00:2C:0E:D0:03:28:02:DB:C0:1E:00:06:00:0E:34:21:41:43:48:19:03:30:38:60:30:1C"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x000875c2, 0xfa, "21:30:F0:BD:00:2C:E0:D1:04:21:DA:48:0A:1C:23:1C:01:24:A6:46:D9:4C:FE:44:20:47:30:1C:25:30:F0:BD:C0:46:99:94:03:00:F9:8C:00:00:10:B5:D4:4C:A0:88:01:21:8E:46:D3:49:FE:44:08:47:00:28:01:D1:EC:48:A0:80:EA:48:FF:30:6E:30:10:BD:15:86:00:00:6D:67:08:00:62:4F:08:00:F8:B5:04:1C:A0:69:0E:21:0E:18:21:7F:00:29:2C:D1:30:1C:01:25:AE:46:EC:49:FE:44:08:47:00:28:01:D1:00:27:08:E0:AE:46:E9:49:FE:44:08:47:00:78:A8:21:41:43:E7:48:47:5C:38:1C:AE:46:EA:49:FE:44:08:47:80:00:00:90:38:1C:AE:46:E2:49:FE:44:08:47:AE:46:E1:49:FE:44:08:47:02:1C:02:36:30:1C:00:99:51:18:AE:46:DE:4A:FE:44:10:47:A0:69:60:60:DC:48:81:30:F8:BD:DD:48:1B:30:F7:46:AD:45:05:00:A5:21:08:00:DA:49:0A:1C:3A:32:12:78:09:78:89:18:41:60:D8:48:83:30:F7:46:FB:8B:04:00:A9:86:00:00:AD:99:00:00:C6:05:00:00"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x000876bc, 0xfa, "0F:AA:00:00:55:DE:02:00:00:A0:1B:00:F8:B5:00:25:00:95:B9:49:D3:48:00:88:88:42:01:D0:01:26:06:E0:28:1C:01:21:8E:46:CA:4A:FE:44:10:47:2E:1C:95:4F:01:24:3C:76:A6:46:C7:48:FE:44:00:47:3D:72:C6:4F:B8:6D:69:46:A6:46:8C:4A:FE:44:10:47:15:21:00:98:01:70:00:98:46:70:B8:6D:00:99:2A:1C:A6:46:BF:4B:FE:44:18:47:BE:48:3B:30:F8:BD:C0:46:18:80:1B:00:C3:8E:03:00:10:B5:04:1C:9F:49:BA:48:00:88:88:42:05:D1:00:20:01:21:8E:46:B1:4A:FE:44:10:47:01:20:A0:60:B5:48:57:30:10:BD:03:13:00:00:D4:48:08:00:48:61:08:00:84:45:08:00:A3:56:05:00:CE:0F:08:00:29:19:02:00:0F:1A:02:00:81:26:01:00:DB:EF:04:00:B9:28:05:00:44:61:08:00:DB:22:03:00:31:4F:08:00:5D:86:02:00:E7:2A:00:00:FE:B5:00:90:86:69:00:6A:01:90:30:89:00:28:01:D1:00:24:73:E0:31:68:2D:24:64:4A:2C:20:80:18:02:90:3E:23"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x000877b6, 0xfa, "01:9D:5B:5D:00:78:83:42:06:D0:A0:5C:83:42:01:D1:01:27:02:E0:02:27:00:E0:00:27:48:68:00:0F:1D:D2:30:1C:01:25:AE:46:93:49:FE:44:08:47:04:1C:30:68:00:28:05:D0:00:1F:31:1C:AE:46:8F:4A:FE:44:10:47:30:89:00:28:49:D1:4A:21:01:98:08:5C:00:28:44:D1:02:2F:42:D0:FF:21:02:98:39:54:3E:E0:08:25:4C:1B:87:48:00:2F:11:D1:21:88:00:29:03:D1:00:20:30:60:70:60:07:E0:21:88:40:18:31:1C:01:22:96:46:7E:4A:FE:44:10:47:00:20:20:80:11:E0:01:2F:0F:D1:A1:88:00:29:03:D1:00:20:30:60:70:60:06:E0:40:18:31:1C:01:22:96:46:75:4A:FE:44:10:47:00:20:A0:80:30:89:01:38:30:81:E0:78:40:07:40:0F:05:43:E5:70:30:89:00:28:09:D1:4A:21:01:98:08:5C:00:28:04:D1:02:2F:02:D0:FF:21:02:98:39:54:08:34:00:98:44:60:64:48:51:30:FE:BD:C0:46:AA:1B:00:00:5D:15:00:00:A5:E0:01:00:64:61:08:00:6D:17:08:00"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x000878b0, 0xfa, "29:22:08:00:2F:85:03:00:C1:CB:03:00:F0:B5:05:1C:AE:69:00:24:6C:60:10:E0:11:20:40:01:60:43:5A:49:0F:18:10:20:C0:19:31:1C:01:22:96:46:57:4A:FE:44:10:47:00:28:00:D1:6F:60:01:34:55:48:00:78:84:42:EA:DB:54:48:47:30:F0:BD:1E:17:08:00:F1:CA:03:00:91:90:03:00:30:B5:45:69:68:7A:FF:28:0D:D0:01:24:A6:46:4D:49:FE:44:08:47:C2:21:08:5C:02:28:04:D0:68:7A:A6:46:49:49:FE:44:08:47:49:48:CF:30:30:BD:17:8F:03:00:BD:59:05:00:1F:03:00:00:DF:87:04:00:14:24:08:00:19:90:01:00:F0:B5:81:68:81:61:46:68:B8:20:80:5D:41:4F:02:28:0C:D1:01:24:A6:46:3D:48:FE:44:00:47:00:28:05:D0:A6:46:3B:48:FE:44:00:47:01:28:02:D0:38:1C:C0:1C:F0:BD:00:25:68:1C:00:04:00:0C:A6:46:17:49:FE:44:08:47:00:28:0A:D0:FF:21:C1:31:08:18:01:78:02:29:02:D0:00:7D:02:28:01:D1:BC:20:84:55:01:35:07:2D:E8:DB"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x000879aa, 0xfa, "38:1C:8F:30:F0:BD:89:8D:01:00:FF:FF:00:00:29:49:09:78:80:69:C1:70:28:48:63:30:F7:46:29:48:00:78:00:07:40:0E:89:6B:49:06:89:0C:08:18:24:49:08:80:25:48:C5:30:F7:46:F5:2A:00:00:D9:8F:01:00:CB:18:08:00:E9:76:04:00:C5:76:04:00:D5:2A:00:00:39:14:02:00:C5:79:04:00:9D:B1:03:00:87:0F:08:00:79:95:01:00:29:D9:00:00:11:DE:02:00:14:54:08:00:E7:59:05:00:59:DD:02:00:60:61:08:00:D5:44:00:00:ED:20:05:00:4D:0B:04:00:13:22:05:00:00:00:18:00:00:00:08:00:81:94:03:00:33:4F:08:00:8D:D0:03:00:0B:34:04:00:1F:33:04:00:5D:27:05:00:19:DE:01:00:CD:33:04:00:BD:A6:00:00:5A:56:08:00:B1:82:00:00:1C:30:19:00:96:A5:1B:00:B1:35:03:00:FF:B5:68:46:FE:F7:EE:FD:FF:BD:FF:B5:68:46:FE:F7:13:FE:FF:BD:FF:B5:68:46:FD:F0:30:FA:FF:BD:FF:B5:68:46:FE:F7:97:FD:FF:BD:FF:B5:68:46:FD:F0:B6:FA"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00087aa4, 0x8e, "FF:BD:FF:B5:68:46:FD:F0:F9:F9:FF:BD:FF:B5:68:46:FE:F7:22:FE:FF:BD:FF:B5:68:46:FE:F7:8D:FC:FF:BD:FF:B5:68:46:FF:F7:84:F9:FF:BD:FF:B5:68:46:FE:F7:01:FD:FF:BD:FF:B5:68:46:FE:F7:B8:FE:FF:BD:FF:B5:68:46:FE:F7:2F:FD:FF:BD:FF:B5:68:46:FE:F7:EC:FB:FF:BD:FF:B5:68:46:FE:F7:87:FC:FF:BD:FF:B5:68:46:FF:F7:12:FA:FF:BD:FF:B5:68:46:FF:F7:E3:F8:FF:BD:FF:B5:68:46:FE:F7:E6:FF:FF:BD:FF:B5:68:46:FE:F7:EF:FE:FF:BD:FF:B5:68:46:FE:F7:7C:FF:FF:BD"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00087b78, 0x88, "00:B5:F8:F0:41:FA:00:BD:1F:72:08:00:79:74:08:00:D7:73:08:00:07:74:08:00:91:74:08:00:65:74:08:00:B3:74:08:00:05:75:08:00:1D:75:08:00:5F:74:08:00:69:61:08:00:C7:79:08:00:35:75:08:00:5D:75:08:00:ED:75:08:00:05:79:08:00:81:75:08:00:33:73:08:00:51:73:08:00:C9:76:08:00:31:77:08:00:49:79:08:00:B9:79:08:00:19:76:08:00:8B:76:08:00:99:76:08:00:95:77:08:00:BD:78:08:00:A5:50:18:00:B9:50:18:00:3F:72:08:00:1B:73:08:00"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x001af304, 0x80, "1E:8D:00:00:2C:23:03:00:3A:DF:02:00:3A:1A:02:00:64:86:02:00:E8:28:05:00:7E:15:00:00:A6:E0:01:00:54:85:03:00:52:27:01:00:7C:BF:02:00:6C:36:03:00:2E:CC:03:00:C8:90:03:00:F0:8E:01:00:22:28:05:00:BE:59:05:00:72:DE:02:00:6E:DF:02:00:64:DD:02:00:22:45:00:00:BE:A6:00:00:08:83:00:00:B8:14:02:00:AE:B1:03:00:F8:95:01:00:F4:20:05:00:CE:D0:03:00:C6:16:02:00:70:A5:01:00:BC:86:00:00:66:AA:00:00"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00180000, 0xfa, "F0:B5:64:4E:07:22:10:1C:30:70:10:23:73:70:47:20:B0:70:2A:20:F0:70:03:25:28:1C:60:49:01:39:01:24:A6:46:5D:4F:FE:44:38:47:B2:78:F3:78:28:1C:5B:49:A6:46:59:4E:FE:44:30:47:28:1C:58:49:01:31:A6:46:57:4A:FE:44:10:47:28:1C:B9:21:C9:00:A6:46:54:4A:FE:44:10:47:A6:46:53:48:FE:44:00:47:52:4B:00:21:08:1C:1A:68:00:2A:04:D0:02:07:15:0F:22:1C:AA:40:11:43:02:07:12:0F:0F:2A:05:D1:C5:08:06:22:2A:40:4A:4D:A9:52:00:21:04:33:01:30:20:28:E9:D3:3F:21:68:48:41:75:A6:46:47:48:FE:44:00:47:44:49:08:60:C8:20:45:49:08:80:3C:23:44:48:03:70:02:20:44:49:08:70:FF:22:43:48:02:70:43:48:04:70:43:48:04:70:43:48:04:70:43:48:03:70:28:23:43:70:14:23:83:70:08:20:41:4B:18:70:41:48:0C:25:05:73:0B:23:83:73:0D:23:43:73:81:20:00:03:3D:4B:18:60:40:48:03:1C:5A:33:1C:60:00:27:3B:4B:1F:70"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x001800fa, 0xfa, "3C:4B:3A:4E:33:80:02:70:3C:4A:13:80:4F:30:04:70:09:20:21:21:C9:00:0F:22:39:4B:A6:46:39:4E:FE:44:30:47:3A:4E:30:1C:36:38:04:21:A6:46:36:4A:FE:44:10:47:20:1C:A6:46:34:49:FE:44:08:47:30:1C:29:1C:A6:46:30:4A:FE:44:10:47:30:1C:29:1C:A6:46:30:4A:FE:44:10:47:30:4E:A8:19:A6:46:2F:49:FE:44:08:47:30:1C:A6:46:2D:49:FE:44:08:47:A6:46:2C:48:FE:44:00:47:38:1C:A6:46:2B:49:FE:44:08:47:29:49:08:60:2A:48:07:60:2A:48:07:60:2A:48:07:80:0A:20:29:49:08:70:29:48:07:21:01:70:F0:BD:F8:4F:08:00:7B:88:04:00:C6:05:00:00:65:88:04:00:6B:02:18:00:80:7B:08:00:84:F3:1A:00:58:61:08:00:47:76:04:00:4A:61:08:00:51:61:08:00:52:61:08:00:53:61:08:00:4E:61:08:00:4F:61:08:00:50:61:08:00:10:31:19:00:15:13:08:00:D8:11:08:00:F4:20:08:00:64:61:08:00:60:61:08:00:FF:FF:00:00:62:4F:08:00"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x001801f4, 0xfa, "18:24:08:00:B0:3E:18:00:31:06:04:00:9D:F5:04:00:C3:8E:03:00:36:02:1A:00:B5:F5:04:00:A0:17:08:00:CB:07:04:00:07:58:02:00:C0:62:08:00:C5:79:04:00:C4:62:08:00:C8:62:08:00:62:61:08:00:2D:22:08:00:AA:11:08:00:70:B5:45:4D:AE:7F:01:24:A6:46:41:48:FE:44:00:47:B0:42:F8:D1:03:20:17:21:89:01:A6:46:3D:4A:FE:44:10:47:AD:7F:A6:46:3A:48:FE:44:00:47:A8:42:F9:D1:FE:E7:70:B5:3A:49:08:1F:3A:4A:10:60:04:24:37:48:04:70:46:48:02:1C:70:3A:21:23:9B:18:01:25:1D:70:35:4D:0D:60:02:25:55:71:34:4D:4D:60:03:25:15:70:33:4D:8D:60:14:71:33:4C:CC:60:16:24:A4:18:05:25:25:70:31:4D:0D:61:06:25:D5:74:30:4D:4D:61:07:25:95:71:95:1D:2E:4E:8E:61:08:26:A6:77:2D:4C:CC:61:09:24:94:70:2C:4C:0C:62:0A:24:AC:77:2B:4C:4C:62:0B:24:5C:77:2A:4C:8C:62:0C:24:D4:71:29:4A:CA:62:0D:22:5A:75:28:4A"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x001802ee, 0xde, "0A:63:0E:22:02:70:28:4A:4A:63:0F:22:42:70:27:4A:8A:63:10:22:C2:73:26:4A:CA:63:01:38:11:22:02:70:25:4A:0A:64:12:22:02:71:24:4A:4A:64:13:22:C2:77:23:48:88:64:00:20:25:49:08:80:25:49:08:80:19:21:49:01:1F:4A:11:80:4B:21:09:01:1E:4A:11:80:21:49:22:4A:11:80:1D:49:08:70:70:BD:C5:83:04:00:65:88:04:00:3C:4E:08:00:F2:4F:08:00:70:62:08:00:70:52:08:00:E3:7A:08:00:CF:7A:08:00:ED:7A:08:00:F7:7A:08:00:D9:7A:08:00:1F:7B:08:00:29:7B:08:00:15:7B:08:00:0B:7B:08:00:01:7B:08:00:C5:7A:08:00:89:7A:08:00:A7:7A:08:00:E4:52:08:00:93:7A:08:00:75:7A:08:00:7F:7A:08:00:B1:7A:08:00:BB:7A:08:00:9D:7A:08:00:98:23:08:00:32:24:08:00:54:1D:18:00:44:61:08:00:46:61:08:00:FF:FF:00:00:50:1D:18:00"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00184ea0, 0xfa, "70:B5:06:1C:68:4C:A0:8A:0F:28:1D:DA:20:89:00:28:1A:D0:66:48:04:21:01:25:AE:46:68:4A:FE:44:10:47:00:28:11:D1:20:1C:AE:46:61:49:FE:44:08:47:01:1C:08:30:60:4A:10:80:0C:20:00:19:AE:46:60:4A:FE:44:10:47:A0:8A:0F:28:E1:DB:5B:48:40:30:30:62:70:BD:F8:B5:80:8A:FF:21:0B:31:88:42:5B:D0:FF:21:45:31:88:42:16:D1:63:48:00:78:02:28:12:D1:62:49:FF:20:3D:30:40:18:00:90:53:48:40:5C:00:26:86:42:10:D3:51:25:AD:00:28:1C:01:24:A6:46:4F:49:FE:44:08:47:00:28:6C:D1:28:1C:4D:49:A6:46:4D:4A:FE:44:10:47:F8:BD:B1:00:00:98:45:58:00:2D:2F:D0:C2:20:40:5D:00:28:2B:D0:B6:20:41:5D:00:29:27:D1:C5:20:40:5D:01:28:23:D0:24:20:01:24:A6:46:4C:4A:FE:44:10:47:00:06:00:0E:B7:22:51:5D:81:42:17:D0:50:55:00:28:14:D1:2F:8D:39:1C:3B:48:A6:46:3B:4A:FE:44:10:47:29:8E:79:18:08:1A:40:1E:39:1C"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00184f9a, 0xfa, "A6:46:36:4A:FE:44:10:47:40:00:28:86:28:8E:40:08:28:86:01:36:33:48:00:78:B3:E7:00:20:01:24:A6:46:31:49:FE:44:08:47:01:1C:00:90:2F:4D:28:68:01:30:28:60:2B:27:FF:00:2D:4E:2E:48:00:8C:32:68:10:18:80:01:80:09:A6:46:2F:4A:FE:44:10:47:00:28:11:DD:00:98:30:60:28:68:03:28:0A:D9:00:20:A6:46:25:49:FE:44:08:47:23:48:38:5C:A6:46:22:49:FE:44:08:47:00:20:28:60:F8:BD:30:B5:85:69:24:20:00:21:01:24:A6:46:1F:4A:FE:44:10:47:B7:21:48:55:51:25:AD:00:28:1C:A6:46:0E:49:FE:44:08:47:00:28:05:D1:28:1C:0C:49:A6:46:0C:4A:FE:44:10:47:30:BD:C0:46:A0:17:08:00:4A:0C:1A:00:4D:0B:04:00:32:02:1A:00:A5:57:02:00:6B:F7:04:00:8B:09:04:00:1B:0A:00:00:CB:D7:03:00:00:66:E3:01:C7:D5:03:00:FF:FF:FF:01:AD:45:05:00:2F:2E:08:00:C5:79:04:00:C4:62:08:00:C0:62:08:00:48:10:08:00:49:11:02:00"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00185094, 0xf8, "45:10:08:00:14:24:08:00:93:E4:04:00:39:7A:04:00:00:B5:40:68:01:21:8E:46:2D:49:FE:44:08:47:2B:48:57:30:00:BD:FC:B5:00:90:2F:48:BE:30:00:78:02:28:42:D1:2E:49:FF:20:3D:30:40:18:01:90:25:48:40:5C:00:26:37:E0:B1:00:01:98:45:58:00:2D:2F:D0:C2:20:40:5D:00:28:2B:D0:B6:20:41:5D:00:29:27:D1:C5:20:40:5D:01:28:23:D0:24:20:01:24:A6:46:20:4A:FE:44:10:47:00:06:00:0E:B7:22:51:5D:81:42:17:D0:50:55:00:28:14:D1:2F:8D:39:1C:13:48:A6:46:19:4A:FE:44:10:47:29:8E:79:18:08:1A:40:1E:39:1C:A6:46:15:4A:FE:44:10:47:40:00:28:86:28:8E:40:08:28:86:01:36:0A:48:00:78:86:42:C5:D3:00:98:41:68:81:61:FF:21:41:60:08:48:06:49:08:18:FC:BD:C0:46:73:16:02:00:DB:EF:04:00:1B:0A:00:00:FF:FF:FF:01:2F:2E:08:00:77:02:00:00:FD:A2:01:00:87:0F:08:00:14:24:08:00:93:E4:04:00:AD:45:05:00"
    Send_HCI_VS_Goto_Address 0xFF83, 0x00087b79, 0x00000000, 0x00000000, 0x00000000, 0x00000000
    Wait_HCI_Command_Complete_VS_Goto_Address_Event 5000, any, 0xff83, 0x00
    Send_HCI_VS_Sleep_Mode_Configurations 0xFD0C, 0x01, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0064
    Wait_HCI_Command_Complete_VS_Sleep_Mode_Configurations_Event 5000, any, 0xfd0c, 0x00
    Send_HCI_VS_Read_Modify_Write_Hardware_Register 0xFD09, 0x001a6058, 0x1000, 0x1000
    Wait_HCI_Command_Complete_VS_Read_Modify_Write_Hardware_Register_Event 5000, any, 0xfd09, 0x00
    Send_HCI_VS_Read_Modify_Write_Hardware_Register 0xFD09, 0x001a6010, 0x0010, 0x0010
    Send_HCI_VS_DRPb_Set_RF_Calibration_Info 0xFD76, 0x01, 0x00005421, 0x00005761, 0x14, 0x05, 0x0a, 0x05, 0x00, 0x07, 0x06, 0x0a, 0x04, 0x05, 0x08, 0x09, 0x0b, 0x0c, 0x0d, 0x0e, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x00000000
    Wait_HCI_Command_Complete_VS_DRPb_Set_RF_Calibration_Info_Event 5000, any, 0xfd76, 0x00
    Send_HCI_VS_DRPb_Enable_RF_Calibration 0xFD80, 0x00, 0x00000001, 0x01
    Wait_HCI_Command_Complete_VS_DRPb_Enable_RF_Calibration_Event 5000, any, 0xfd80, 0x00
    Send_HCI_VS_DRPb_Enable_RF_Calibration 0xFD80, 0x3c, 0x00005ff0, 0x00
    Send_HCI_VS_Fast_Clock_Configuration_btip 0xFD1C, 0xff, 0x00001388, 0x000007d0, 0xff, 0xff, 0x01, 0xff, 0xff, 0xff, 0xfa, 0x00, 0x00, 0x0000
    Wait_HCI_Command_Complete_VS_Fast_Clock_Configuration_btip_Event 5000, any, 0xfd1c, 0x00
    Send_HCI_VS_Stop_VS_Lock 0xFE38
    Wait_HCI_Command_Complete_VS_Stop_VS_Lock_Event 5000, any, 0xfe38, 0x00
    ## START of CC2564 Adds-On
    ## Enable fast clock XTAL support
    Send_HCI_VS_Fast_Clock_Configuration_btip 0xFD1C, 0x01, 0x00001388, 0x000007d0, 0xff, 0xff, 0x04, 0xff, 0xff, 0xff, 0xfa, 0x00, 0x00, 0x0000
    ## Enable eHCILL
    Send_HCI_VS_hcill_parameters 0xFD2B, 0x0010, 0x0050, 0x96
    Wait_HCI_Command_Complete_VS_hcill_parameters_Event 5000, any, 0xfd2b, 0x00
    #Send_HCI_VS_Sleep_Mode_Configurations 0xFD0C, 0x01, 0x01, 0x00, 0xff, 0xff, 0xff, 0xff, 0x0064
    #Wait_HCI_Command_Complete_VS_Sleep_Mode_Configurations_Event 5000, any, 0xfd0c, 0x00
    ## END of CC2564 Adds-On
    # Description:   BLE FW Initialization Script
    # Compatibility: BL6450B
    # Last Updated:  19-Oct-2014  13:57:11.15
    # Version:       2.0
    #LE Enable
    Send_HCI_VS_LE_Enable 0xFD5B, 0x01, 0x01
    Wait_HCI_Command_Complete_VS_LE_Enable_Event 5000, any, 0xfd5b, 0x00
    # Disable Cortex Sleep
    Send_HCI_VS_LOAD_Cortex 0xFDA8, 0x01
    Wait_HCI_Command_Complete_VS_LOAD_Cortex_Event 5000, any, 0xfda8, 0x00
    # Cortex Reset (hold in reset while loading IMEM)
    Send_HCI_VS_Read_Modify_Write_Hardware_Register 0xFD09, 0x001bc000, 0x0001, 0x0001
    # Patch Start
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x001b4bac, 0x08, "91:FF:47:F2:9B:35:47:F2"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x001b6320, 0x50, "30:BD:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00"
    Send_HCI_VS_Write_Memory_Block 0xFF05, 0x001b7398, 0x58, "70:47:02:46:14:3A:1E:D0:52:1E:24:D1:8A:78:02:2A:11:D9:12:1F:02:2A:0E:D9:1D:3A:1C:D0:92:1F:02:2A:19:D9:09:3A:17:D0:89:88:40:F2:00:00:C2:F2:30:00:08:43:FD:F7:4B:BE:09:89:40:F2:00:00:C2:F2:30:00:08:43:FD:F7:43:BE:89:88:40:F2:00:00:C2:F2:30:00:08:43:FD:F7:3B:BE:70:47"
    # Patch End
    #release Cortex Reset
    Send_HCI_VS_Read_Modify_Write_Hardware_Register 0xFD09, 0x001bc000, 0x0000, 0x0001
    # Enable Cortex Sleep
    #Send_HCI_VS_LOAD_Cortex 0xFDA8, 0x00
    #Wait_HCI_Command_Complete_VS_LOAD_Cortex_Event 5000, any, 0xfda8, 0x00
    #RESET BLE
    Send_HCI_VS_LE_Enable 0xFD5B, 0x01, 0x00
    Send_HCI_VS_LE_Output_Power 0xFDDD, 0x01
    Wait_HCI_Command_Complete_VS_LE_Output_Power_Event 5000, any, 0xfddd, 0x00
    Send_HCI_VS_Set_LE_Test_Mode_Parameters 0xFD77, 0xF, 1, 0, 0x71764129, 0, 0, 10, 20, 0, 0
    Send_HCI_BLE_Transmitter_Test 0x00, 37, 5
    # HCI_BLE_Test_End 0x201F
    Images below are to show how the semi-rigid cable was soldered on.
    BR,
    Seong
  • Hi Seong,
    But the customer is still a little confused. Could you help provide detailed SOP for reference, e.p at where to adjust the instructions from the test tool and what instructions are needed to be executed.
    Thanks and regards,
    Cherry
  • Cherry,
    The CC256x Testing Guide should help the customer. See the BLE Testing - Transmitter Test section that starts from pg5.
    The steps are simple:
    1. After connecting HCI Tool to the CC2564MODAEM board, load the TIInit_6.7.16.xml file.
    2. Open and run the CC2564B_init.txt script shared in my previous post. This initializes the CC2564 device.
    3. Open and run the CC2564B_BLE_init.txt script shared in my previous post. This enables BLE mode.
    4. Open and run the BLE_Test_Script.txt script shared in my previous post. This sets the BLE parameters and starts the TX test.
    BR,
    Seong
  • Hi Seong,
    Thanks.
    Could you help provide the TIInit_6.7.16.xml file?
    Cherry
  • Cherry,
    Yes, you can download it from here -> https://www.ti.com/tool/CC256XB-BT-SP
    BR,
    Seong
