Part Number: CC2652RB
PDM to PCM conversion, TI Team I referred to the audio plugin example (pdmstream).
In that Example I need some clarity about the input clock frequency that can be set.
We are using ICS-41352 PDM output sensor, there we have 3 power modes as described below.
I wanted to know whether can I use the Ultrasonic Mode by using the input CLK frequency as (4.1 - 4.8 MHz) instead of 1.024 MHz(mentioned in the example).
Thank you,
Manoj
