Part Number: CC2564C
Hi team,
Here's an issue from the customer may need your help:
The CC256x Testing Guide - Texas Instruments Wiki.pdf contains methods to build BT SIG tests and RF.TS.p30e2.pdf contains the various test metrics defined by SIG, such as: RF/TRM/CA/BV-01-C [Output Power], RF/TRM/CA/BV-02-C [Power density], RF/RCV/CA/BV-01-C [Sensitivity – single slot packages].
Issue: after tester and DUT establish tests (test activate is complete), how to control DUT to switch between each test case? (Such as switching from test RF/TRM/CA/BV-01-C [Output Power] to test RF/RCV/CA/BV-01-C [Sensitivity – single slot packets])
Could you help check this case? Thanks.
Cherry
