LAUNCHXL-CC2650: CC2650 LAUNCH XL PROJECT ZERO
Part Number: LAUNCHXL-CC2650
Other Parts Discussed in Thread: CC2650
I am trying to run project zero from simplelink but whenever i attempt to bulid and debug the project its coming with a lot of error and im not sure how to make project zero run.
Description Resource Path Location Type
Cannot build project. Referenced project 'project_zero_stack_cc2650' contains build-errors. project_zero_app_cc2650launchxl project_zero_app_cc2650launchxl Problem
gmake: *** [all] Error 2 project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/common/cc26xx/icall_startup.c', needed by 'Startup/icall_startup.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/common/cc26xx/npi/stack/npi.c', needed by 'NPI/npi.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/common/cc26xx/onboard.c', needed by 'TOOLS/onboard.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/components/hal/src/common/hal_assert.c', needed by 'HAL/Common/hal_assert.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/components/hal/src/target/_common/cc26xx/mb_patch.c', needed by 'HAL/Target/CC2650/_common/mb_patch.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/components/hal/src/target/_common/hal_flash_wrapper.c', needed by 'HAL/Target/CC2650/Drivers/hal_flash_wrapper.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/components/hal/src/target/_common/hal_rtc_wrapper.c', needed by 'HAL/Target/CC2650/Drivers/hal_rtc_wrapper.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/components/hal/src/target/_common/hal_trng_wrapper.c', needed by 'HAL/Target/CC2650/Drivers/hal_trng_wrapper.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/components/osal/src/common/osal_bufmgr.c', needed by 'OSAL/osal_bufmgr.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/components/osal/src/common/osal_cbtimer.c', needed by 'OSAL/osal_cbtimer.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/components/osal/src/common/osal_clock.c', needed by 'OSAL/osal_clock.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/components/osal/src/common/osal_memory_icall.c', needed by 'OSAL/osal_memory_icall.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/components/osal/src/common/osal_pwrmgr.c', needed by 'OSAL/osal_pwrmgr.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/components/osal/src/common/osal_timers.c', needed by 'OSAL/osal_timers.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/components/osal/src/common/osal.c', needed by 'OSAL/osal.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/components/osal/src/mcu/cc26xx/osal_snv_wrapper.c', needed by 'OSAL/osal_snv_wrapper.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/examples/simple_peripheral/cc26xx/stack/osal_icall_ble.c', needed by 'Startup/osal_icall_ble.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/host/gattservapp_util.c', needed by 'PROFILES/gattservapp_util.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/icall/stack/ble_dispatch.c', needed by 'ICallBLE/ble_dispatch.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/icall/stack/ble_user_config.c', needed by 'Startup/ble_user_config.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/profiles/roles/gap.c', needed by 'PROFILES/gap.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/profiles/roles/gapbondmgr.c', needed by 'PROFILES/gapbondmgr.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/rom/r1/common_rom_init.c', needed by 'Startup/common_rom_init.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: *** No rule to make target 'C:/ti/simplelink/ble_sdk_2_02_01_18/src/rom/r1/rom_init.c', needed by 'Startup/rom_init.obj'. project_zero_stack_cc2650 C/C++ Problem
gmake[1]: Target 'main-build' not remade because of errors. project_zero_stack_cc2650 C/C++ Problem
