CC2640: ANCS
Part Number: CC2640
In ANCS profile, how to Differentiate Whatsapp call and Whatsapp msg from Normal call and  Normal msg.
BLE Stack Version - 4.2.
    I am afraid there is no way to differentiate the the calls coming from different apps and or the "normal" phone. Similarly, there is no way to retrieve the app a message is coming from.
    This limitation is coming from the ANCS specifications. As you can see in Table 3-1 (copied below for convenience), the CategoryID depends on the type of event (call, email, social, etc.), not on the app.
    I hope this will help,
    Thank you for your quick response !
    Is that possible  with any other BLE stack version (higher version) or BLE chip ? (Identifying Normal Call/Msg or Whatsapp Call/Msg)
    This limitation is due to the ANCS specifications (owned by Apple). As a consequence, I am afraid changing the device or the Bluetooth stack version used will not solve the issue.
    If you wish, I wanted to share a personal experience... I had been complaining of my smart watch for the same reasons (i.e. not knowing from which app the messages come from)... then I read the ANCS specs and realized the real issue was not the watch. All this to tell you this is a "problem" you are not the only one to experience :)
