CC2640R2F: 10.3.0 CCS Stack build Error
Part Number: CC2640R2F
Other Parts Discussed in Thread: CC2640, CC2650
Following Error occring while stack build .....please suggest me what will do for to solving these error
**** Build of configuration FlashROM_Library for project multi_role_cc2640r2lp_stack_library ****
"C:\\ti\\ccs1030\\ccs\\utils\\bin\\gmake" -k -j 4 all -O
C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/../../../tools/blestack/lib_search/lib_search C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/blelib C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/FlashROM_Library/lib_linker.cmd cc2640 C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/../../../tools/blestack/lib_search/lib_search.xml C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/symbols
makefile:222: recipe for target 'pre-build' failed
usage: lib_search [-h] [-v] opt lib_dir cmd device xml symbol_src
lib_search: error: unrecognized arguments: C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/../../../tools/blestack/lib_search/lib_search.xml C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/symbols
gmake[1]: [pre-build] Error 2 (ignored)
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/hal_flash_wrapper.c"
Invoking: Arm Compiler
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="HAL/Target/CC2650/Drivers/hal_flash_wrapper.d_raw" --obj_directory="HAL/Target/CC2650/Drivers" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/hal_flash_wrapper.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/hal_flash_wrapper.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/common/hal_assert.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="HAL/Common/hal_assert.d_raw" --obj_directory="HAL/Common" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/common/hal_assert.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/common/hal_assert.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/hal_trng_wrapper.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="HAL/Target/CC2650/Drivers/hal_trng_wrapper.d_raw" --obj_directory="HAL/Target/CC2650/Drivers" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/hal_trng_wrapper.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/hal_trng_wrapper.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/hal_rtc_wrapper.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="HAL/Target/CC2650/Drivers/hal_rtc_wrapper.d_raw" --obj_directory="HAL/Target/CC2650/Drivers" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/hal_rtc_wrapper.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/hal_rtc_wrapper.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/host/gatt_uuid.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Host/gatt_uuid.d_raw" --obj_directory="Host" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/host/gatt_uuid.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/host/gatt_uuid.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx/mb_patch.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="HAL/Target/CC2650/_common/mb_patch.d_raw" --obj_directory="HAL/Target/CC2650/_common" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx/mb_patch.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx/mb_patch.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/stack/ble_dispatch_JT.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ICallBLE/ble_dispatch_JT.d_raw" --obj_directory="ICallBLE" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/stack/ble_dispatch_JT.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/stack/ble_dispatch_JT.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/icall_lite_translation.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ICallBLE/icall_lite_translation.d_raw" --obj_directory="ICallBLE" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/icall_lite_translation.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/icall_lite_translation.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/stack/ble_dispatch_lite.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ICallBLE/ble_dispatch_lite.d_raw" --obj_directory="ICallBLE" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/stack/ble_dispatch_lite.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/stack/ble_dispatch_lite.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack/npi.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="NPI/npi.d_raw" --obj_directory="NPI" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack/npi.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack/npi.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal_cbtimer.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="OSAL/osal_cbtimer.d_raw" --obj_directory="OSAL" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal_cbtimer.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal_cbtimer.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal_bufmgr.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="OSAL/osal_bufmgr.d_raw" --obj_directory="OSAL" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal_bufmgr.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal_bufmgr.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="OSAL/osal.d_raw" --obj_directory="OSAL" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal_clock.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="OSAL/osal_clock.d_raw" --obj_directory="OSAL" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal_clock.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal_clock.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal_memory_icall.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="OSAL/osal_memory_icall.d_raw" --obj_directory="OSAL" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal_memory_icall.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal_memory_icall.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal_pwrmgr.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="OSAL/osal_pwrmgr.d_raw" --obj_directory="OSAL" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal_pwrmgr.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal_pwrmgr.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/mcu/cc26xx/osal_snv_wrapper.c"
Invoking: Arm Compiler
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="OSAL/osal_snv_wrapper.d_raw" --obj_directory="OSAL" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/mcu/cc26xx/osal_snv_wrapper.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/mcu/cc26xx/osal_snv_wrapper.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal_timers.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="OSAL/osal_timers.d_raw" --obj_directory="OSAL" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal_timers.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/common/osal_timers.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles/gap.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="PROFILES/gap.d_raw" --obj_directory="PROFILES" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles/gap.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles/gap.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/host/gattservapp_util.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="PROFILES/gattservapp_util.d_raw" --obj_directory="PROFILES" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/host/gattservapp_util.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/host/gattservapp_util.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom/r2/common_rom_init.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ROM/common_rom_init.d_raw" --obj_directory="ROM" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom/r2/common_rom_init.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom/r2/common_rom_init.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/host/sm_ecc.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="PROFILES/sm_ecc.d_raw" --obj_directory="PROFILES" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/host/sm_ecc.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/host/sm_ecc.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles/gapbondmgr.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="PROFILES/gapbondmgr.d_raw" --obj_directory="PROFILES" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles/gapbondmgr.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles/gapbondmgr.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/icall_startup.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/icall_startup.d_raw" --obj_directory="Startup" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/icall_startup.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/icall_startup.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx/oad_image_header_stack.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/oad_image_header_stack.d_raw" --obj_directory="Startup" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx/oad_image_header_stack.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx/oad_image_header_stack.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/stack/ble_user_config.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/ble_user_config.d_raw" --obj_directory="Startup" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/stack/ble_user_config.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/stack/ble_user_config.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom/r2/rom_init.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ROM/rom_init.d_raw" --obj_directory="ROM" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom/r2/rom_init.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom/r2/rom_init.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/onboard.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="TOOLS/onboard.d_raw" --obj_directory="TOOLS" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/onboard.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/onboard.c"
Building file: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack/osal_icall_ble.c"
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/controller/cc26xx_r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/rom" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/roles" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/profiles/oad/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target/_common/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/target" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/hal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/icall/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/npi/src" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/osal/src/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/nv" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/services/src/saddr" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/rf_patches" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/inc" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source" --include_path="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/kernel/tirtos/packages" --include_path="C:/ti/ccs1030/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/osal_icall_ble.d_raw" --obj_directory="Startup" "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack/osal_icall_ble.c"
Finished building: "C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/examples/rtos/CC2640R2_LAUNCHXL/blestack/multi_role/src/stack/osal_icall_ble.c"
Building target: "multi_role_cc2640r2lp_stack_library.out"
Invoking: Arm Linker
"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --define=CC26XX --define=CC26XX_R2 --define=DeviceFamily_CC26X0R2 --define=EXT_HAL_ASSERT --define=FLASH_ROM_BUILD --define=SPLIT_APP_STACK_IMAGE --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=OSAL_CBTIMER_NUM_TASKS=1 --define=OSAL_SNV=1 --define=POWER_SAVING --define=USE_ICALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi -z -m"multi_role_cc2640r2lp_stack_library.map" --heap_size=0 --stack_size=256 -i"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/lib" -i"C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/include" --reread_libs --define=CC26X0ROM=2 --define=OSAL_SNV=1 --define=PAGE_ALIGN --diag_suppress=16002-D --diag_suppress=10247-D --diag_suppress=10325-D --diag_suppress=10229-D --diag_suppress=16032-D --diag_wrap=off --display_error_number --warn_sections --xml_link_info="multi_role_cc2640r2lp_stack_library_linkInfo.xml" --entry_point=startup_entry --rom_model -o "multi_role_cc2640r2lp_stack_library.out" "./HAL/Common/hal_assert.obj" "./HAL/Target/CC2650/Drivers/hal_flash_wrapper.obj" "./HAL/Target/CC2650/Drivers/hal_rtc_wrapper.obj" "./HAL/Target/CC2650/Drivers/hal_trng_wrapper.obj" "./HAL/Target/CC2650/_common/mb_patch.obj" "./Host/gatt_uuid.obj" "./ICallBLE/ble_dispatch_JT.obj" "./ICallBLE/ble_dispatch_lite.obj" "./ICallBLE/icall_lite_translation.obj" "./NPI/npi.obj" "./OSAL/osal.obj" "./OSAL/osal_bufmgr.obj" "./OSAL/osal_cbtimer.obj" "./OSAL/osal_clock.obj" "./OSAL/osal_memory_icall.obj" "./OSAL/osal_pwrmgr.obj" "./OSAL/osal_snv_wrapper.obj" "./OSAL/osal_timers.obj" "./PROFILES/gap.obj" "./PROFILES/gapbondmgr.obj" "./PROFILES/gattservapp_util.obj" "./PROFILES/sm_ecc.obj" "./ROM/common_rom_init.obj" "./ROM/rom_init.obj" "./Startup/ble_user_config.obj" "./Startup/icall_startup.obj" "./Startup/oad_image_header_stack.obj" "./Startup/osal_icall_ble.obj" "./TOOLS/onboard.obj" "../TOOLS/ccs_linker_defines.cmd" -l"C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/devices/cc26x0r2/driverlib/bin/ccs/driverlib.lib" -l"C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/FlashROM_Library/lib_linker.cmd" -l"C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/FlashROM_Library/ble_r2.symbols" -l"C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/common/cc26xx/ccs/cc26xx_stack_oad.cmd" -llibc.a
<Linking>
Finished building target: "multi_role_cc2640r2lp_stack_library.out"
C:/ti/ccs1030/ccs/tools/compiler/ti-cgt-arm_20.2.4.LTS/bin/armhex -order MS --memwidth=8 --romwidth=8 --intel -o multi_role_cc2640r2lp_stack_library_FlashROM_Library.hex multi_role_cc2640r2lp_stack_library.out
Translating to Intel format...
"multi_role_cc2640r2lp_stack_library.out" .image_header ==> .image_header
"multi_role_cc2640r2lp_stack_library.out" .text ==> .text
"multi_role_cc2640r2lp_stack_library.out" .const ==> .const
"multi_role_cc2640r2lp_stack_library.out" .rodata ==> .rodata
"multi_role_cc2640r2lp_stack_library.out" .cinit ==> .cinit
"multi_role_cc2640r2lp_stack_library.out" EntrySection ==> EntrySection
"multi_role_cc2640r2lp_stack_library.out" .snvSectors ==> .snvSectors
C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/../../../tools/blestack/frontier/frontier ccs C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/FlashROM_Library/multi_role_cc2640r2lp_stack_library_linkInfo.xml C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/ccs_compiler_defines.bcfg C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/ccs_linker_defines.cmd
makefile:226: recipe for target 'post-build' failed
usage: Frontier [-h] [-b {0,1}] {iar,ccs} map cdef ldef
Frontier: error: unrecognized arguments: Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/ccs_compiler_defines.bcfg C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/ccs_linker_defines.cmd
C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/blestack/../../../tools/blestack/oad/oad_image_tool ccs C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library 2 -hex1 FlashROM_Library/multi_role_cc2640r2lp_stack_library_FlashROM_Library.hex -bdf C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/TOOLS/ccs_compiler_defines.bcfg -o C:/Ganesh/Codes/Gateway Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library/FlashROM_Library/multi_role_cc2640r2lp_stack_library_FlashROM_Library_oad
gmake[3]: [post-build] Error 2 (ignored)
usage: oad_image_tool [-h] [-v] [-verbose] [-hex1 HEXPATH1] [-bdf BDFILEPATH]
[-hex2 [HEXPATH2]] [-k [KEYFILE]] -o OUTPUT
ProjType ProjDir BinaryType
oad_image_tool: error: argument BinaryType: invalid int value: 'Code/wokspace/Gateway_porject/multi_role_cc2640r2lp_stack_library'
**** Build Finished ****
