cc2540 new firmware
Other Parts Discussed in Thread: CC2540
I'm trying to use cc2540 dongle together with bluetooth linux stack. I found some not standard behavior like: incorrect local feature mask. I heard that TI is going to release new firmware for this dongle which fix this. Is that correct ? How I could get this ?
Lukasz
  • You are correct that it will be fixed in the next version of our BLE stack. Note that in any case, you will not be able to use the Linux BT stack because our SDK only presents our BLE entire stack (controller+host) on the CC2540, and not the controller only, in which the host stack would run on a separate platform such as Linux.
    Under certain business cases (top tier customers) we can work with you on this type of application. If you are in contact with a TI representative they should be able to assist you with this.
