Part Number: CC1352P
Other Parts Discussed in Thread: CC2652P
Hello TI,
I am facing a small issue which I am unable to sort it out. I am using 1 CC1352P lanuchpad as RX and 4 CC2652P slaves as TX.
I saw that during Initial connection or any reconnection if any connection drop. I saw a behavior where if the sensor fails to connect, then it will wait till 20 second to reconnect again and the way it reconnects again is by dropping the connection and reconnecting again.
While looking at this issue, I saw that my Supervision timeout is also not 20 seconds, its around 3 seconds. My connection timeout is also 250. Still I see this 20 seconds every time my slave fail to connect with Master.
Can someone help me out by knowing what actually is causing this issue (Why 20 seconds ?). Also anytime my sensor disconnects and reconnects within Connection timeout, I see this issue again. So after 20 seconds the connection drops and again connects.
Ankit
