Part Number: CC2652RSIP
It turns out that the correct UART pins for the bootloader of the CC2652RSIP are DIO2 and DIO3. The typical application circuit in the datasheet doesn't indicate the proper connections for the built-in UART bootloader.
Hi Jean-Claude,
Thank you for raising awareness of this issue, I am working with the documentation team to address this in Section 3.2 of SWRA640.
Ryan
You may also want to address the information provided in an answer to my earlier question from Apr 06 2022 with the same title.
