Part Number: LAUNCHXL-CC26X2R1
Other Parts Discussed in Thread: CC2642R
Hi Team,
Our customer is using TI CC26x2R1LP for AoA measurement with BOOSTXL-AoA antenna board. The device failed to connect to a CC26x2R1LP responder. He had soldered the capacitor as stated in the User's Guide. It gives him the I/Q values when he use two unmodified launchpads. When he used the Coordinator with BOOSXL-AoA board, it identifies the Responder then trying to connect but it failed. He is using the SDK ver. 6.20.00.29 and he also tried the ver SDK ver. 5.10 with the same result.
He also added,
Even if I use 5:10 SDK, Master device fails to connect with slave device. But, if I use the antenna board with the passive while slave and responder connect each other with the on board antenna, I get some IQ results related to the passive one.
Can you please help us with this issue?
Danilo
