Part Number: CC1352R
I am trying to reset the BLE stack in SDK 4.10. SP OAD off-chip example project. Unfortunately, it does not work.
What I do:
On a certain occasion I call HCI_ResetCmd. It returns SUCCESS.
I then wait for the HCI_RESET event, which comes up right after HCI_ResetCmd call.
Here I call GAP_DeviceInit, which returns bleIncorrectMode.
I got this solution from here and here.
In my understanding, GAP_DeviceInit returns bleIncorrectMode, when HCI_ResetCmd has NOT been called before.
What is the problem here?
most interesting code snippets:
Complete Code:
@file simple_peripheral_oad_offchip.c
@brief This file contains the Simple Peripheral sample application for use
with the CC2650 Bluetooth Low Energy Protocol Stack.
Group: WCS, BTS
Target Device: cc13x2_26x2
Copyright (c) 2013-2020, Texas Instruments Incorporated
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
* Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
its contributors may be used to endorse or promote products derived
from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* INCLUDES
#include <string.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/knl/Clock.h>
#include <ti/sysbios/knl/Event.h>
#include <ti/sysbios/knl/Queue.h>
#include <ti/display/Display.h>
#if !(defined __TI_COMPILER_VERSION__)
#include <intrinsics.h>
#endif
#include <ti/drivers/utils/List.h>
#include <icall.h>
#include "util.h"
#include "onboard.h"
#include <bcomdef.h>
/* This Header file contains all BLE API and icall structure definition */
#include <icall_ble_api.h>
#include <devinfoservice.h>
#include <simple_gatt_profile.h>
#ifdef USE_RCOSC
#include <rcosc_calibration.h>
#endif //USE_RCOSC
#include <ti_drivers_config.h>
#include <board_key.h>
#include <menu/two_btn_menu.h>
#include "ti_ble_config.h"
#ifdef LED_DEBUG
#include <ti/drivers/PIN.h>
#endif //LED_DEBUG
#include "simple_peripheral_oad_offchip_menu.h"
#include "simple_peripheral_oad_offchip.h"
// Used for imgHdr_t structure
#include <common/cc26xx/oad/oad_image_header.h>
#include "oad.h"
* MACROS
* CONSTANTS
// How often to perform periodic event (in ms)
#define SP_PERIODIC_EVT_PERIOD 5000
// Offset into the scanRspData string the software version info is stored
#define OAD_SOFT_VER_OFFSET 15
// Task configuration
#define SP_TASK_PRIORITY 1
#ifndef SP_TASK_STACK_SIZE
#define SP_TASK_STACK_SIZE 1408
#endif
// Application events
#define SP_STATE_CHANGE_EVT 0
#define SP_CHAR_CHANGE_EVT 1
#define SP_KEY_CHANGE_EVT 2
#define SP_ADV_EVT 3
#define SP_PAIR_STATE_EVT 4
#define SP_PASSCODE_EVT 5
#define SP_PERIODIC_EVT 6
#define SP_READ_RPA_EVT 7
#define SP_SEND_PARAM_UPDATE_EVT 8
#define SP_CONN_EVT 9
#define SP_TEST_EVT 10
#define SP_OAD_QUEUE_EVT OAD_QUEUE_EVT // Event_Id_01
#define SP_OAD_COMPLETE_EVT OAD_DL_COMPLETE_EVT // Event_Id_02
#define SP_OAD_NO_MEM_EVT OAD_OUT_OF_MEM_EVT // Event_Id_03
// Internal Events for RTOS application
#define SP_ICALL_EVT ICALL_MSG_EVENT_ID // Event_Id_31
#define SP_QUEUE_EVT UTIL_QUEUE_EVENT_ID // Event_Id_30
// Bitwise OR of all RTOS events to pend on
#define SP_ALL_EVENTS (SP_ICALL_EVT | \
SP_QUEUE_EVT | \
SP_OAD_QUEUE_EVT | \
SP_OAD_COMPLETE_EVT | \
SP_OAD_NO_MEM_EVT)
// Size of string-converted device address ("0xXXXXXXXXXXXX")
#define SP_ADDR_STR_SIZE 15
// Row numbers for two-button menu
#define SP_ROW_SEPARATOR_1 (TBM_ROW_APP + 0)
#define SP_ROW_STATUS_1 (TBM_ROW_APP + 1)
#define SP_ROW_STATUS_2 (TBM_ROW_APP + 2)
#define SP_ROW_CONNECTION (TBM_ROW_APP + 3)
#define SP_ROW_ADVSTATE (TBM_ROW_APP + 4)
#define SP_ROW_RSSI (TBM_ROW_APP + 5)
#define SP_ROW_IDA (TBM_ROW_APP + 6)
#define SP_ROW_RPA (TBM_ROW_APP + 7)
#define SP_ROW_DEBUG (TBM_ROW_APP + 8)
// For storing the active connections
#define SP_RSSI_TRACK_CHNLS 1 // Max possible channels can be GAP_BONDINGS_MAX
#define SP_MAX_RSSI_STORE_DEPTH 5
#define SP_INVALID_HANDLE 0xFFFF
#define RSSI_2M_THRSHLD -30 // -80 dB rssi
#define RSSI_1M_THRSHLD -40 // -90 dB rssi
#define RSSI_S2_THRSHLD -50 // -100 dB rssi
#define RSSI_S8_THRSHLD -60 // -120 dB rssi
#define SP_PHY_NONE LL_PHY_NONE // No PHY set
#define AUTO_PHY_UPDATE 0xFF
// Spin if the expression is not true
#define SIMPLEPERIPHERAL_ASSERT(expr) if (!(expr)) simple_peripheral_spin();
* TYPEDEFS
// App event passed from stack modules. This type is defined by the application
// since it can queue events to itself however it wants.
typedef struct
uint8_t event; // event type
void *pData; // pointer to message
} spEvt_t;
// Container to store passcode data when passing from gapbondmgr callback
// to app event. See the pfnPairStateCB_t documentation from the gapbondmgr.h
// header file for more information on each parameter.
typedef struct
uint8_t state;
uint16_t connHandle;
uint8_t status;
} spPairStateData_t;
// to app event. See the pfnPasscodeCB_t documentation from the gapbondmgr.h
typedef struct
uint8_t deviceAddr[B_ADDR_LEN];
uint8_t uiInputs;
uint8_t uiOutputs;
uint32_t numComparison;
} spPasscodeData_t;
// Container to store advertising event data when passing from advertising
// callback to app event. See the respective event in GapAdvScan_Event_IDs
// in gap_advertiser.h for the type that pBuf should be cast to.
typedef struct
uint32_t event;
void *pBuf;
} spGapAdvEventData_t;
// Container to store information from clock expiration using a flexible array
// since data is not always needed
typedef struct
uint8_t event; //
uint8_t data[];
} spClockEventData_t;
// List element for parameter update and PHY command status lists
typedef struct
List_Elem elem;
} spConnHandleEntry_t;
// Connected device information
typedef struct
uint16_t connHandle; // Connection Handle
Clock_Struct* pUpdateClock; // pointer to clock struct
int8_t rssiArr[SP_MAX_RSSI_STORE_DEPTH];
uint8_t rssiCntr;
int8_t rssiAvg;
bool phyCngRq; // Set to true if PHY change request is in progress
uint8_t currPhy;
uint8_t rqPhy;
uint8_t phyRqFailCnt; // PHY change request count
bool isAutoPHYEnable; // Flag to indicate auto phy change
} spConnRec_t;
* GLOBAL VARIABLES
// Display Interface
Display_Handle dispHandle = NULL;
extern const imgHdr_t _imgHdr;
Task_Struct spTask;
#if defined __TI_COMPILER_VERSION__
#pragma DATA_ALIGN(spTaskStack, 8)
#else
#pragma data_alignment=8
#endif
uint8_t spTaskStack[SP_TASK_STACK_SIZE];
* LOCAL VARIABLES
// Entity ID globally used to check for source and/or destination of messages
static ICall_EntityID selfEntity;
// Event globally used to post local events and pend on system and
// local events.
static ICall_SyncHandle syncEvent;
// Queue object used for app messages
static Queue_Struct appMsgQueue;
static Queue_Handle appMsgQueueHandle;
// Clock instance for internal periodic events. Only one is needed since
// GattServApp will handle notifying all connected GATT clients
static Clock_Struct clkPeriodic;
// Clock instance for RPA read events.
static Clock_Struct clkRpaRead;
// Memory to pass periodic event ID to clock handler
spClockEventData_t argPeriodic =
{ .event = SP_PERIODIC_EVT };
// Memory to pass RPA read event ID to clock handler
spClockEventData_t argRpaRead =
{ .event = SP_READ_RPA_EVT };
// Per-handle connection info
static spConnRec_t connList[MAX_NUM_BLE_CONNS];
// Current connection handle as chosen by menu
static uint16_t menuConnHandle = LINKDB_CONNHANDLE_INVALID;
// List to store connection handles for set phy command status's
static List_List setPhyCommStatList;
// List to store connection handles for queued param updates
static List_List paramUpdateList;
// Variable used to store the number of messages pending once OAD completes
// The application cannot reboot until all pending messages are sent
static uint8_t numPendingMsgs = 0;
static bool oadWaitReboot = false;
// Flag to be stored in NV that tracks whether service changed
// indications needs to be sent out
static uint32_t sendSvcChngdOnNextBoot = FALSE;
#ifdef LED_DEBUG
// State variable for debugging LEDs
static PIN_State sbpLedState;
// Pin table for LED debug pins
static const PIN_Config sbpLedPins[] = {
CONFIG_PIN_RLED | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
CONFIG_PIN_GLED | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
PIN_TERMINATE
#endif //LED_DEBUG
// Advertising handles
static uint8 advHandleLegacy;
static uint8 advHandleLongRange;
// Address mode
static GAP_Addr_Modes_t addrMode = DEFAULT_ADDRESS_MODE;
// Current Random Private Address
static uint8 rpa[B_ADDR_LEN] = {0};
/** clock module instance data structure */
static Clock_Struct clockStruct;
/** clock module instance handle */
static Clock_Handle clockHandle;
/** clock module instance parameters */
static Clock_Params clockParams;
* LOCAL FUNCTIONS
static void SimplePeripheral_init( void );
static void SimplePeripheral_taskFxn(UArg a0, UArg a1);
static uint8_t SimplePeripheral_processStackMsg(ICall_Hdr *pMsg);
static uint8_t SimplePeripheral_processGATTMsg(gattMsgEvent_t *pMsg);
static void SimplePeripheral_processGapMessage(gapEventHdr_t *pMsg);
static void SimplePeripheral_advCallback(uint32_t event, void *pBuf, uintptr_t arg);
static void SimplePeripheral_processAdvEvent(spGapAdvEventData_t *pEventData);
static void SimplePeripheral_processAppMsg(spEvt_t *pMsg);
static void SimplePeripheral_processCharValueChangeEvt(uint8_t paramId);
static void SimplePeripheral_performPeriodicTask(void);
static void SimplePeripheral_updateRPA(void);
static void SimplePeripheral_clockHandler(UArg arg);
static void SimplePeripheral_passcodeCb(uint8_t *pDeviceAddr, uint16_t connHandle,
uint8_t uiInputs, uint8_t uiOutputs,
uint32_t numComparison);
static void SimplePeripheral_pairStateCb(uint16_t connHandle, uint8_t state,
uint8_t status);
static void SimplePeripheral_processPairState(spPairStateData_t *pPairState);
static void SimplePeripheral_processPasscode(spPasscodeData_t *pPasscodeData);
static void SimplePeripheral_charValueChangeCB(uint8_t paramId);
static status_t SimplePeripheral_enqueueMsg(uint8_t event, void *pData);
static void SimplePeripheral_processOadWriteCB(uint8_t event, uint16_t arg);
static void SimplePeripheral_keyChangeHandler(uint8 keys);
static void SimplePeripheral_handleKeys(uint8_t keys);
static void SimplePeripheral_processCmdCompleteEvt(hciEvt_CmdComplete_t *pMsg);
static void SimplePeripheral_initPHYRSSIArray(void);
static void SimplePeripheral_updatePHYStat(uint16_t eventCode, uint8_t *pMsg);
static uint8_t SimplePeripheral_addConn(uint16_t connHandle);
static uint8_t SimplePeripheral_getConnIndex(uint16_t connHandle);
static uint8_t SimplePeripheral_removeConn(uint16_t connHandle);
static void SimplePeripheral_processParamUpdate(uint16_t connHandle);
static uint8_t SimplePeripheral_processL2CAPMsg(l2capSignalEvent_t *pMsg);
static status_t SimplePeripheral_startAutoPhyChange(uint16_t connHandle);
static status_t SimplePeripheral_stopAutoPhyChange(uint16_t connHandle);
static status_t SimplePeripheral_setPhy(uint16_t connHandle, uint8_t allPhys,
uint8_t txPhy, uint8_t rxPhy,
uint16_t phyOpts);
static uint8_t SimplePeripheral_clearConnListEntry(uint16_t connHandle);
static void SimplePeripheral_menuSwitchCb(tbmMenuObj_t* pMenuObjCurr,
tbmMenuObj_t* pMenuObjNext);
static void SimplePeripheral_connEvtCB(Gap_ConnEventRpt_t *pReport);
static void SimplePeripheral_processConnEvt(Gap_ConnEventRpt_t *pReport);
static void ClockEventHandler(UArg arg);
* EXTERN FUNCTIONS
extern void AssertHandler(uint8 assertCause, uint8 assertSubcause);
* PROFILE CALLBACKS
// GAP Bond Manager Callbacks
static gapBondCBs_t SimplePeripheral_BondMgrCBs =
SimplePeripheral_passcodeCb, // Passcode callback
SimplePeripheral_pairStateCb // Pairing/Bonding state Callback
// Simple GATT Profile Callbacks
static simpleProfileCBs_t SimplePeripheral_simpleProfileCBs =
SimplePeripheral_charValueChangeCB // Simple GATT Characteristic value change callback
static oadTargetCBs_t SimplePeripheral_oadCBs =
SimplePeripheral_processOadWriteCB // Write Callback.
* PUBLIC FUNCTIONS
* @fn simple_peripheral_spin
* @brief Spin forever
* @param none
static void simple_peripheral_spin(void)
volatile uint8_t x = 0;
while(1)
x++;
* @fn SimplePeripheral_createTask
* @brief Task creation function for the Simple Peripheral OAD User App.
void SimplePeripheral_createTask(void)
Task_Params taskParams;
// Configure task
Task_Params_init(&taskParams);
taskParams.stack = spTaskStack;
taskParams.stackSize = SP_TASK_STACK_SIZE;
taskParams.priority = SP_TASK_PRIORITY;
Task_construct(&spTask, SimplePeripheral_taskFxn, &taskParams, NULL);
* @fn SimplePeripheral_init
* @brief Called during initialization and contains application
* specific initialization (ie. hardware initialization/setup,
* table initialization, power up notification, etc), and
* profile initialization/setup.
static void SimplePeripheral_init(void)
// Create the menu
SimplePeripheral_buildMenu();
// N0 STACK API CALLS CAN OCCUR BEFORE THIS CALL TO ICall_registerApp
// Register the current thread as an ICall dispatcher application
// so that the application can send and receive messages.
ICall_registerApp(&selfEntity, &syncEvent);
/* initialize clock */
Clock_Params_init(&clockParams); /* init clock params for clock to be one-shot and halted */
clockParams.startFlag = true;
Clock_construct(&clockStruct,
ClockEventHandler,
10000000/Clock_tickPeriod, /* 10 seconds */
&clockParams);
clockHandle = Clock_handle(&clockStruct);
#ifdef LED_DEBUG
// Open the LED debug pins
if (!PIN_open(&sbpLedState, sbpLedPins))
Display_print0(dispHandle, 0, 0, "Debug PINs failed to open");
else
PIN_Id activeLed;
uint8_t blinkCnt = 15;
PIN_setOutputValue(&sbpLedState, CONFIG_PIN_RLED, 0);
PIN_setOutputValue(&sbpLedState, CONFIG_PIN_GLED, 0);
if (blinkCnt < 12)
activeLed = CONFIG_PIN_RLED;
else
activeLed = CONFIG_PIN_GLED;
for(uint8_t numBlinks = 0; numBlinks < blinkCnt; ++numBlinks)
PIN_setOutputValue(&sbpLedState, activeLed, !PIN_getOutputValue(activeLed));
// Sleep for 100ms, sys-tick for BLE-Stack is 10us,
// Task sleep is in # of ticks
Task_sleep(10000);
// Close the pins after using
PIN_close(&sbpLedState);
#endif //LED_DEBUG
#ifdef USE_RCOSC
// Set device's Sleep Clock Accuracy
#if ( HOST_CONFIG & ( CENTRAL_CFG | PERIPHERAL_CFG ) )
HCI_EXT_SetSCACmd(500);
#endif // (CENTRAL_CFG | PERIPHERAL_CFG)
RCOSC_enableCalibration();
#endif // USE_RCOSC
// Create an RTOS queue for message from profile to be sent to app.
appMsgQueueHandle = Util_constructQueue(&appMsgQueue);
// Create one-shot clock for internal periodic events.
Util_constructClock(&clkPeriodic, SimplePeripheral_clockHandler,
SP_PERIODIC_EVT_PERIOD, 0, false, (UArg)&argPeriodic);
// Read in the OAD Software version
uint8_t swVer[OAD_SW_VER_LEN];
OAD_getSWVersion(swVer, OAD_SW_VER_LEN);
// Set the Device Name characteristic in the GAP GATT Service
// For more information, see the section in the User's Guide:
// http://software-dl.ti.com/lprf/ble5stack-latest/
GGS_SetParameter(GGS_DEVICE_NAME_ATT, GAP_DEVICE_NAME_LEN, attDeviceName);
// Configure GAP
uint16_t paramUpdateDecision = DEFAULT_PARAM_UPDATE_REQ_DECISION;
// Pass all parameter update requests to the app for it to decide
GAP_SetParamValue(GAP_PARAM_LINK_UPDATE_DECISION, paramUpdateDecision);
// Setup the GAP Bond Manager. For more information see the GAP Bond Manager
// section in the User's Guide
setBondManagerParameters();
// Initialize GATT attributes
GGS_AddService(GATT_ALL_SERVICES); // GAP GATT Service
GATTServApp_AddService(GATT_ALL_SERVICES); // GATT Service
DevInfo_AddService(); // Device Information Service
SimpleProfile_AddService(GATT_ALL_SERVICES); // Simple GATT Profile
// Setup the SimpleProfile Characteristic Values
// For more information, see the GATT and GATTServApp sections in the User's Guide:
uint8_t charValue1 = 1;
uint8_t charValue2 = 2;
uint8_t charValue3 = 3;
uint8_t charValue4 = 4;
uint8_t charValue5[SIMPLEPROFILE_CHAR5_LEN] = { 1, 2, 3, 4, 5 };
SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR1, sizeof(uint8_t),
&charValue1);
SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR2, sizeof(uint8_t),
&charValue2);
SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR3, sizeof(uint8_t),
&charValue3);
SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR4, sizeof(uint8_t),
&charValue4);
SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR5, SIMPLEPROFILE_CHAR5_LEN,
charValue5);
// Register callback with SimpleGATTprofile
SimpleProfile_RegisterAppCBs(&SimplePeripheral_simpleProfileCBs);
// Start Bond Manager and register callback
VOID GAPBondMgr_Register(&SimplePeripheral_BondMgrCBs);
// Register with GAP for HCI/Host messages. This is needed to receive HCI
// events. For more information, see the HCI section in the User's Guide:
GAP_RegisterForMsgs(selfEntity);
// Register for GATT local events and ATT Responses pending for transmission
GATT_RegisterForMsgs(selfEntity);
// Set default values for Data Length Extension
// Extended Data Length Feature is already enabled by default
// Set initial values to maximum, RX is set to max. by default(251 octets, 2120us)
// Some brand smartphone is essentially needing 251/2120, so we set them here.
#define APP_SUGGESTED_PDU_SIZE 251 //default is 27 octets(TX)
#define APP_SUGGESTED_TX_TIME 2120 //default is 328us(TX)
// This API is documented in hci.h
// See the LE Data Length Extension section in the BLE5-Stack User's Guide for information on using this command:
HCI_LE_WriteSuggestedDefaultDataLenCmd(APP_SUGGESTED_PDU_SIZE, APP_SUGGESTED_TX_TIME);
// Initialize GATT Client
GATT_InitClient();
// Init key debouncer
Board_initKeys(SimplePeripheral_keyChangeHandler);
// Initialize Connection List
SimplePeripheral_clearConnListEntry(LINKDB_CONNHANDLE_ALL);
//Initialize GAP layer for Peripheral role and register to receive GAP events
GAP_DeviceInit(GAP_PROFILE_PERIPHERAL, selfEntity, addrMode, &pRandomAddress);
// Initialize array to store connection handle and RSSI values
SimplePeripheral_initPHYRSSIArray();
// The type of display is configured based on the BOARD_DISPLAY_USE...
// preprocessor definitions
dispHandle = Display_open(Display_Type_ANY, NULL);
// Initialize Two-Button Menu module
TBM_SET_TITLE(&spMenuMain, "Simple Peripheral");
tbm_setItemStatus(&spMenuMain, SP_ITEM_SELECT_OAD_DBG, SP_ITEM_SELECT_CONN);
tbm_initTwoBtnMenu(dispHandle, &spMenuMain, 4, SimplePeripheral_menuSwitchCb);
Display_printf(dispHandle, SP_ROW_SEPARATOR_1, 0, "====================");
uint8_t versionStr[OAD_SW_VER_LEN + 1];
memcpy(versionStr, swVer, OAD_SW_VER_LEN);
// Add in Null terminator
versionStr[OAD_SW_VER_LEN] = NULL;
// Display Image version
Display_print1(dispHandle, 0, 0, "SBP Off-chip OAD v%s",
versionStr);
// Open the OAD module and add the OAD service to the application
if(OAD_SUCCESS != OAD_open(OAD_DEFAULT_INACTIVITY_TIME))
Display_print0(dispHandle, 0, 0, "OAD failed to open");
else
// Resiter the OAD callback with the application
OAD_register(&SimplePeripheral_oadCBs);
* @fn SimplePeripheral_taskFxn
* @brief Application task entry point for the Simple Peripheral.
* @param a0, a1 - not used.
// Initialize application
SimplePeripheral_init();
// Application main loop
for (;;)
uint32_t events;
// Waits for an event to be posted associated with the calling thread.
// Note that an event associated with a thread is posted when a
// message is queued to the message receive queue of the thread
events = Event_pend(syncEvent, Event_Id_NONE, SP_ALL_EVENTS,
ICALL_TIMEOUT_FOREVER);
if (events)
ICall_EntityID dest;
ICall_ServiceEnum src;
ICall_HciExtEvt *pMsg = NULL;
// Fetch any available messages that might have been sent from the stack
if (ICall_fetchServiceMsg(&src, &dest,
(void **)&pMsg) == ICALL_ERRNO_SUCCESS)
uint8 safeToDealloc = TRUE;
if ((src == ICALL_SERVICE_CLASS_BLE) && (dest == selfEntity))
ICall_Stack_Event *pEvt = (ICall_Stack_Event *)pMsg;
// Check for BLE stack events first
if (pEvt->signature != 0xffff)
// Process inter-task message
safeToDealloc = SimplePeripheral_processStackMsg((ICall_Hdr *)pMsg);
if (pMsg && safeToDealloc)
ICall_freeMsg(pMsg);
// If RTOS queue is not empty, process app message.
if (events & SP_QUEUE_EVT)
while (!Queue_empty(appMsgQueueHandle))
spEvt_t *pMsg = (spEvt_t *)Util_dequeueMsg(appMsgQueueHandle);
if (pMsg)
// Process message.
SimplePeripheral_processAppMsg(pMsg);
// Free the space from the message.
ICall_free(pMsg);
// OAD events
if(events & SP_OAD_NO_MEM_EVT)
// The OAD module is unable to allocate memory, print failure, cancel OAD
Display_print0(dispHandle, SP_ROW_STATUS_1, 0,
"OAD malloc fail, cancelling OAD");
OAD_cancel();
#ifdef LED_DEBUG
// Diplay is not enabled in persist app so use LED
if(PIN_open(&sbpLedState, sbpLedPins))
PIN_setOutputValue(&sbpLedState, CONFIG_PIN_RLED, 1);
#endif //LED_DEBUG
// OAD queue processing
if(events & SP_OAD_QUEUE_EVT)
// Process the OAD Message Queue
uint8_t status = OAD_processQueue();
// If the OAD state machine encountered an error, print it
// Return codes can be found in oad_constants.h
if(status == OAD_DL_COMPLETE)
Display_print0(dispHandle, SP_ROW_STATUS_1, 0, "OAD DL Complete, wait for Enable");
else if(status == OAD_IMG_ID_TIMEOUT)
Display_print0(dispHandle, SP_ROW_STATUS_1, 0, "ImgID Timeout, disconnecting");
// This may be an attack, terminate the link,
// Note HCI_DISCONNECT_REMOTE_USER_TERM seems to most closet reason for
// termination at this state
MAP_GAP_TerminateLinkReq(OAD_getactiveCxnHandle(), HCI_DISCONNECT_REMOTE_USER_TERM);
else if(status != OAD_SUCCESS)
Display_print1(dispHandle, SP_ROW_STATUS_1, 0, "OAD Error: %d", status);
if(events & SP_OAD_COMPLETE_EVT)
// Register for L2CAP Flow Control Events
L2CAP_RegisterFlowCtrlTask(selfEntity);
* @fn SimplePeripheral_processStackMsg
* @brief Process an incoming stack message.
* @param pMsg - message to process
* @return TRUE if safe to deallocate incoming message, FALSE otherwise.
// Always dealloc pMsg unless set otherwise
uint8_t safeToDealloc = TRUE;
switch (pMsg->event)
case GAP_MSG_EVENT:
SimplePeripheral_processGapMessage((gapEventHdr_t*) pMsg);
break;
case GATT_MSG_EVENT:
// Process GATT message
safeToDealloc = SimplePeripheral_processGATTMsg((gattMsgEvent_t *)pMsg);
break;
case HCI_GAP_EVENT_EVENT:
// Process HCI message
switch(pMsg->status)
case HCI_COMMAND_COMPLETE_EVENT_CODE:
// Process HCI Command Complete Events here
SimplePeripheral_processCmdCompleteEvt((hciEvt_CmdComplete_t *) pMsg);
break;
case HCI_BLE_HARDWARE_ERROR_EVENT_CODE:
AssertHandler(HAL_ASSERT_CAUSE_HARDWARE_ERROR,0);
break;
// HCI Commands Events
case HCI_COMMAND_STATUS_EVENT_CODE:
hciEvt_CommandStatus_t *pMyMsg = (hciEvt_CommandStatus_t *)pMsg;
switch ( pMyMsg->cmdOpcode )
case HCI_LE_SET_PHY:
if (pMyMsg->cmdStatus == HCI_ERROR_CODE_UNSUPPORTED_REMOTE_FEATURE)
Display_printf(dispHandle, SP_ROW_STATUS_1, 0,
"PHY Change failure, peer does not support this");
else
"PHY Update Status Event: 0x%x",
pMyMsg->cmdStatus);
SimplePeripheral_updatePHYStat(HCI_LE_SET_PHY, (uint8_t *)pMsg);
break;
default:
break;
break;
// LE Events
case HCI_LE_EVENT_CODE:
hciEvt_BLEPhyUpdateComplete_t *pPUC =
(hciEvt_BLEPhyUpdateComplete_t*) pMsg;
// A Phy Update Has Completed or Failed
if (pPUC->BLEEventCode == HCI_BLE_PHY_UPDATE_COMPLETE_EVENT)
if (pPUC->status != SUCCESS)
"PHY Change failure");
else
// Only symmetrical PHY is supported.
// rxPhy should be equal to txPhy.
Display_printf(dispHandle, SP_ROW_STATUS_2, 0,
"PHY Updated to %s",
(pPUC->rxPhy == PHY_UPDATE_COMPLETE_EVENT_1M) ? "1M" :
(pPUC->rxPhy == PHY_UPDATE_COMPLETE_EVENT_2M) ? "2M" :
(pPUC->rxPhy == PHY_UPDATE_COMPLETE_EVENT_CODED) ? "CODED" : "Unexpected PHY Value");
SimplePeripheral_updatePHYStat(HCI_BLE_PHY_UPDATE_COMPLETE_EVENT, (uint8_t *)pMsg);
break;
default:
break;
break;
case L2CAP_SIGNAL_EVENT:
// Process L2CAP signal
safeToDealloc = SimplePeripheral_processL2CAPMsg((l2capSignalEvent_t *)pMsg);
break;
default:
// do nothing
break;
return (safeToDealloc);
* @fn SimplePeripheral_processL2CAPMsg
* @brief Process L2CAP messages and events.
static bool firstRun = TRUE;
switch (pMsg->opcode)
case L2CAP_NUM_CTRL_DATA_PKT_EVT:
* We cannot reboot the device immediately after receiving
* the enable command, we must allow the stack enough time
* to process and respond to the OAD_EXT_CTRL_ENABLE_IMG
* command. This command will determine the number of
* packets currently queued up by the LE controller.
* BIM var is already set via OadPersistApp_processOadWriteCB
if(firstRun)
firstRun = false;
// We only want to set the numPendingMsgs once
numPendingMsgs = MAX_NUM_PDU - pMsg->cmd.numCtrlDataPktEvt.numDataPkt;
// Wait until all PDU have been sent on cxn events
Gap_RegisterConnEventCb(SimplePeripheral_connEvtCB,
GAP_CB_REGISTER,
OAD_getactiveCxnHandle());
/* Set the flag so that the connection event callback will
* be processed in the context of a pending OAD reboot
oadWaitReboot = true;
break;
default:
// do nothing
break;
* @fn SimplePeripheral_processGATTMsg
* @brief Process GATT messages and events.
if (pMsg->method == ATT_FLOW_CTRL_VIOLATED_EVENT)
// ATT request-response or indication-confirmation flow control is
// violated. All subsequent ATT requests or indications will be dropped.
// The app is informed in case it wants to drop the connection.
// Display the opcode of the message that caused the violation.
Display_printf(dispHandle, SP_ROW_STATUS_1, 0, "FC Violated: %d", pMsg->msg.flowCtrlEvt.opcode);
else if (pMsg->method == ATT_MTU_UPDATED_EVENT)
// MTU size updated
OAD_setBlockSize(pMsg->msg.mtuEvt.MTU);
Display_printf(dispHandle, SP_ROW_STATUS_1, 0, "MTU Size: %d", pMsg->msg.mtuEvt.MTU);
// Free message payload. Needed only for ATT Protocol messages
GATT_bm_free(&pMsg->msg, pMsg->method);
// It's safe to free the incoming message
return (TRUE);
* @fn SimplePeripheral_processAppMsg
* @brief Process an incoming callback from a profile.
* @return None.
bool dealloc = TRUE;
case SP_CHAR_CHANGE_EVT:
SimplePeripheral_processCharValueChangeEvt(*(uint8_t*)(pMsg->pData));
break;
case SP_KEY_CHANGE_EVT:
SimplePeripheral_handleKeys(*(uint8_t*)(pMsg->pData));
break;
case SP_ADV_EVT:
SimplePeripheral_processAdvEvent((spGapAdvEventData_t*)(pMsg->pData));
break;
case SP_PAIR_STATE_EVT:
SimplePeripheral_processPairState((spPairStateData_t*)(pMsg->pData));
break;
case SP_PASSCODE_EVT:
SimplePeripheral_processPasscode((spPasscodeData_t*)(pMsg->pData));
break;
case SP_PERIODIC_EVT:
SimplePeripheral_performPeriodicTask();
break;
case SP_READ_RPA_EVT:
SimplePeripheral_updateRPA();
break;
case SP_SEND_PARAM_UPDATE_EVT:
// Extract connection handle from data
uint16_t connHandle = *(uint16_t *)(((spClockEventData_t *)pMsg->pData)->data);
SimplePeripheral_processParamUpdate(connHandle);
// This data is not dynamically allocated
dealloc = FALSE;
break;
case SP_CONN_EVT:
SimplePeripheral_processConnEvt((Gap_ConnEventRpt_t *)(pMsg->pData));
break;
case SP_TEST_EVT:
Status_t status = SUCCESS;
status = HCI_ResetCmd();
if (status != SUCCESS)
/* ohoh... very bad... consider a sysReset */
break;
default:
// Do nothing.
break;
// Free message data if it exists and we are to dealloc
if ((dealloc == TRUE) && (pMsg->pData != NULL))
ICall_free(pMsg->pData);
* @fn SimplePeripheral_processGapMessage
* @brief Process an incoming GAP event.
switch(pMsg->opcode)
case GAP_DEVICE_INIT_DONE_EVENT:
bStatus_t status = FAILURE;
gapDeviceInitDoneEvent_t *pPkt = (gapDeviceInitDoneEvent_t *)pMsg;
if(pPkt->hdr.status == SUCCESS)
// Store the system ID
uint8_t systemId[DEVINFO_SYSTEM_ID_LEN];
// use 6 bytes of device address for 8 bytes of system ID value
systemId[0] = pPkt->devAddr[0];
systemId[1] = pPkt->devAddr[1];
systemId[2] = pPkt->devAddr[2];
// set middle bytes to zero
systemId[4] = 0x00;
systemId[3] = 0x00;
// shift three bytes up
systemId[7] = pPkt->devAddr[5];
systemId[6] = pPkt->devAddr[4];
systemId[5] = pPkt->devAddr[3];
// Set Device Info Service Parameter
DevInfo_SetParameter(DEVINFO_SYSTEM_ID, DEVINFO_SYSTEM_ID_LEN, systemId);
Display_printf(dispHandle, SP_ROW_STATUS_1, 0, "Initialized");
// Setup and start Advertising
// For more information, see the GAP section in the User's Guide:
// Create Advertisement set #1 and assign handle
status = GapAdv_create(&SimplePeripheral_advCallback, &advParams1,
&advHandleLegacy);
SIMPLEPERIPHERAL_ASSERT(status == SUCCESS);
// Load advertising data for set #1 that is statically allocated by the app
status = GapAdv_loadByHandle(advHandleLegacy, GAP_ADV_DATA_TYPE_ADV,
sizeof(advData1), advData1);
// Load scan response data for set #1 that is statically allocated by the app
status = GapAdv_loadByHandle(advHandleLegacy, GAP_ADV_DATA_TYPE_SCAN_RSP,
sizeof(scanResData1), scanResData1);
// Set event mask for set #1
status = GapAdv_setEventMask(advHandleLegacy,
GAP_ADV_EVT_MASK_START_AFTER_ENABLE |
GAP_ADV_EVT_MASK_END_AFTER_DISABLE |
GAP_ADV_EVT_MASK_SET_TERMINATED);
// Enable legacy advertising for set #1
status = GapAdv_enable(advHandleLegacy, GAP_ADV_ENABLE_OPTIONS_USE_MAX , 0);
// Create Advertisement set #2 and assign handle
status = GapAdv_create(&SimplePeripheral_advCallback, &advParams2,
&advHandleLongRange);
// Load advertising data for set #2 that is statically allocated by the app
status = GapAdv_loadByHandle(advHandleLongRange, GAP_ADV_DATA_TYPE_ADV,
sizeof(advData2), advData2);
// Set event mask for set #2
status = GapAdv_setEventMask(advHandleLongRange,
// Enable long range advertising for set #2
status = GapAdv_enable(advHandleLongRange, GAP_ADV_ENABLE_OPTIONS_USE_MAX , 0);
// Display device address
Display_printf(dispHandle, SP_ROW_IDA, 0, "%s Addr: %s",
(addrMode <= ADDRMODE_RANDOM) ? "Dev" : "ID",
Util_convertBdAddr2Str(pPkt->devAddr));
if (addrMode > ADDRMODE_RANDOM)
// Create one-shot clock for RPA check event.
Util_constructClock(&clkRpaRead, SimplePeripheral_clockHandler,
READ_RPA_PERIOD, 0, true,
(UArg) &argRpaRead);
break;
case GAP_LINK_ESTABLISHED_EVENT:
gapEstLinkReqEvent_t *pPkt = (gapEstLinkReqEvent_t *)pMsg;
// Display the amount of current connections
uint8_t numActive = linkDB_NumActive();
Display_printf(dispHandle, SP_ROW_STATUS_2, 0, "Num Conns: %d",
(uint16_t)numActive);
if (pPkt->hdr.status == SUCCESS)
// Add connection to list and start RSSI
SimplePeripheral_addConn(pPkt->connectionHandle);
// Display the address of this connection
Display_printf(dispHandle, SP_ROW_STATUS_1, 0, "Connected to %s",
// Enable connection selection option
tbm_setItemStatus(&spMenuMain, SP_ITEM_SELECT_CONN, TBM_ITEM_NONE);
// Start Periodic Clock.
Util_startClock(&clkPeriodic);
if (numActive < MAX_NUM_BLE_CONNS)
// Start advertising since there is room for more connections
else
// Stop advertising since there is no room for more connections
GapAdv_disable(advHandleLongRange, GAP_ADV_ENABLE_OPTIONS_USE_MAX , 0);
GapAdv_disable(advHandleLegacy, GAP_ADV_ENABLE_OPTIONS_USE_MAX , 0);
break;
case GAP_LINK_TERMINATED_EVENT:
gapTerminateLinkEvent_t *pPkt = (gapTerminateLinkEvent_t *)pMsg;
Display_printf(dispHandle, SP_ROW_STATUS_1, 0, "Device Disconnected!");
// Remove the connection from the list and disable RSSI if needed
SimplePeripheral_removeConn(pPkt->connectionHandle);
// If no active connections
if (numActive == 0)
// Stop periodic clock
Util_stopClock(&clkPeriodic);
// Disable Connection Selection option
tbm_setItemStatus(&spMenuMain, TBM_ITEM_NONE, SP_ITEM_SELECT_CONN);
// Clear remaining lines
Display_clearLine(dispHandle, SP_ROW_CONNECTION);
// Cancel the OAD if one is going on
// A disconnect forces the peer to re-identify
OAD_cancel();
break;
case GAP_UPDATE_LINK_PARAM_REQ_EVENT:
gapUpdateLinkParamReqReply_t rsp;
gapUpdateLinkParamReqEvent_t *pReq = (gapUpdateLinkParamReqEvent_t *)pMsg;
rsp.connectionHandle = pReq->req.connectionHandle;
rsp.signalIdentifier = pReq->req.signalIdentifier;
// Only accept connection intervals with slave latency of 0
// This is just an example of how the application can send a response
if(pReq->req.connLatency == 0)
rsp.intervalMin = pReq->req.intervalMin;
rsp.intervalMax = pReq->req.intervalMax;
rsp.connLatency = pReq->req.connLatency;
rsp.connTimeout = pReq->req.connTimeout;
rsp.accepted = TRUE;
else
rsp.accepted = FALSE;
// Send Reply
VOID GAP_UpdateLinkParamReqReply(&rsp);
break;
case GAP_LINK_PARAM_UPDATE_EVENT:
gapLinkUpdateEvent_t *pPkt = (gapLinkUpdateEvent_t *)pMsg;
// Get the address from the connection handle
linkDBInfo_t linkInfo;
linkDB_GetInfo(pPkt->connectionHandle, &linkInfo);
if(pPkt->status == SUCCESS)
// Display the address of the connection update
Display_printf(dispHandle, SP_ROW_STATUS_2, 0, "Link Param Updated: %s",
Util_convertBdAddr2Str(linkInfo.addr));
else
// Display the address of the connection update failure
"Link Param Update Failed 0x%x: %s", pPkt->opcode,
// Check if there are any queued parameter updates
spConnHandleEntry_t *connHandleEntry = (spConnHandleEntry_t *)List_get(¶mUpdateList);
if (connHandleEntry != NULL)
// Attempt to send queued update now
SimplePeripheral_processParamUpdate(connHandleEntry->connHandle);
// Free list element
ICall_free(connHandleEntry);
break;
#if defined ( NOTIFY_PARAM_UPDATE_RJCT )
case GAP_LINK_PARAM_UPDATE_REJECT_EVENT:
"Peer Device's Update Request Rejected 0x%x: %s", pPkt->opcode,
break;
#endif
default:
Display_clearLines(dispHandle, SP_ROW_STATUS_1, SP_ROW_STATUS_2);
break;
* @fn SimplePeripheral_charValueChangeCB
* @brief Callback from Simple Profile indicating a characteristic
* value change.
* @param paramId - parameter Id of the value that was changed.
* @return None.
uint8_t *pValue = ICall_malloc(sizeof(uint8_t));
if (pValue)
*pValue = paramId;
if (SimplePeripheral_enqueueMsg(SP_CHAR_CHANGE_EVT, pValue) != SUCCESS)
ICall_free(pValue);
* @fn SimplePeripheral_processOadWriteCB
* @brief Process a write request to the OAD reset service
* @param connHandle - the connection Handle this request is from.
* @param bim_var - bim_var to set before resetting.
* @return None.
Event_post(syncEvent, event);
* @fn SimplePeripheral_processCharValueChangeEvt
* @brief Process a pending Simple Profile characteristic value change
* event.
* @param paramID - parameter ID of the value that was changed.
uint8_t newValue;
switch(paramId)
case SIMPLEPROFILE_CHAR1:
SimpleProfile_GetParameter(SIMPLEPROFILE_CHAR1, &newValue);
Display_printf(dispHandle, SP_ROW_STATUS_1, 0, "Char 1: %d", (uint16_t)newValue);
break;
case SIMPLEPROFILE_CHAR3:
SimpleProfile_GetParameter(SIMPLEPROFILE_CHAR3, &newValue);
Display_printf(dispHandle, SP_ROW_STATUS_1, 0, "Char 3: %d", (uint16_t)newValue);
break;
default:
// should not reach here!
break;
* @fn SimplePeripheral_performPeriodicTask
* @brief Perform a periodic application task. This function gets called
* every five seconds (SP_PERIODIC_EVT_PERIOD). In this example,
* the value of the third characteristic in the SimpleGATTProfile
* service is retrieved from the profile, and then copied into the
* value of the the fourth characteristic.
* @param None.
* @return None.
uint8_t valueToCopy;
// Call to retrieve the value of the third characteristic in the profile
if (SimpleProfile_GetParameter(SIMPLEPROFILE_CHAR3, &valueToCopy) == SUCCESS)
// Call to set that value of the fourth characteristic in the profile.
// Note that if notifications of the fourth characteristic have been
// enabled by a GATT client device, then a notification will be sent
// every time this function is called.
&valueToCopy);
* @fn SimplePeripheral_updateRPA
* @brief Read the current RPA from the stack and update display
* if the RPA has changed.
* @param None.
* @return None.
// Read the current RPA.
// The parameters for the call to HCI_LE_ReadLocalResolvableAddressCmd
// are not needed to be accurate to retrieve the local resolvable address.
// The 1st parameter can be any of ADDRMODE_PUBLIC and ADDRMODE_RANDOM.
// The 2nd parameter only has to be not NULL.
// The result will come with HCI_LE_READ_LOCAL_RESOLVABLE_ADDRESS
// complete event.
HCI_LE_ReadLocalResolvableAddressCmd(0, rpa);
* @fn SimplePeripheral_clockHandler
* @brief Handler function for clock timeouts.
* @param arg - event type
* @return None.
spClockEventData_t *pData = (spClockEventData_t *)arg;
if (pData->event == SP_PERIODIC_EVT)
// Start the next period
// Post event to wake up the application
SimplePeripheral_enqueueMsg(SP_PERIODIC_EVT, NULL);
else if (pData->event == SP_READ_RPA_EVT)
Util_startClock(&clkRpaRead);
// Post event to read the current RPA
SimplePeripheral_enqueueMsg(SP_READ_RPA_EVT, NULL);
else if (pData->event == SP_SEND_PARAM_UPDATE_EVT)
// Send message to app
SimplePeripheral_enqueueMsg(SP_SEND_PARAM_UPDATE_EVT, pData);
* @fn SimplePeripheral_keyChangeHandler
* @brief Key event handler function
* @param keys - bitmap of pressed keys
* @return none
static void SimplePeripheral_keyChangeHandler(uint8_t keys)
if (pValue)
*pValue = keys;
if(SimplePeripheral_enqueueMsg(SP_KEY_CHANGE_EVT, pValue) != SUCCESS)
ICall_free(pValue);
* @fn SimplePeripheral_handleKeys
* @brief Handles all key events for this device.
* @param keys - bit field for key events. Valid entries:
* KEY_LEFT
* KEY_RIGHT
if (keys & KEY_LEFT)
// Check if the key is still pressed. Workaround for possible bouncing.
if (PIN_getInputValue(CONFIG_PIN_BTN1) == 0)
tbm_buttonLeft();
else if (keys & KEY_RIGHT)
if (PIN_getInputValue(CONFIG_PIN_BTN2) == 0)
tbm_buttonRight();
* @fn SimplePeripheral_doSetConnPhy
* @brief Set PHY preference.
* @param index - 0: 1M PHY
* 1: 2M PHY
* 2: 1M + 2M PHY
* 3: CODED PHY (Long range)
* 4: 1M + 2M + CODED PHY
* @return always true
bool SimplePeripheral_doSetConnPhy(uint8 index)
bool status = TRUE;
static uint8_t phy[] = {
HCI_PHY_1_MBPS, HCI_PHY_2_MBPS, HCI_PHY_1_MBPS | HCI_PHY_2_MBPS,
HCI_PHY_CODED, HCI_PHY_1_MBPS | HCI_PHY_2_MBPS | HCI_PHY_CODED,
AUTO_PHY_UPDATE
uint8_t connIndex = SimplePeripheral_getConnIndex(menuConnHandle);
SIMPLEPERIPHERAL_ASSERT(connIndex < MAX_NUM_BLE_CONNS);
// Set Phy Preference on the current connection. Apply the same value
// for RX and TX.
// If auto PHY update is not selected and if auto PHY update is enabled, then
// stop auto PHY update
// Note PHYs are already enabled by default in build_config.opt in stack project.
if(phy[index] != AUTO_PHY_UPDATE)
// Cancel RSSI reading and auto phy changing
SimplePeripheral_stopAutoPhyChange(connList[connIndex].connHandle);
SimplePeripheral_setPhy(menuConnHandle, 0, phy[index], phy[index], 0);
Display_printf(dispHandle, SP_ROW_STATUS_1, 0, "PHY preference: %s",
TBM_GET_ACTION_DESC(&spMenuConnPhy, index));
else
// Start RSSI read for auto PHY update (if it is disabled)
SimplePeripheral_startAutoPhyChange(menuConnHandle);
return status;
* @fn SimplePeripheral_advCallback
* @brief GapAdv module callback
spGapAdvEventData_t *pData = ICall_malloc(sizeof(spGapAdvEventData_t));
if (pData)
pData->event = event;
pData->pBuf = pBuf;
if(SimplePeripheral_enqueueMsg(SP_ADV_EVT, pData) != SUCCESS)
ICall_free(pData);
* @fn SimplePeripheral_processAdvEvent
* @brief Process advertising event in app context
* @param pEventData
switch (pEventData->event)
case GAP_EVT_ADV_START_AFTER_ENABLE:
Display_printf(dispHandle, SP_ROW_ADVSTATE, 0, "Adv Set %d Enabled",
*(uint8_t *)(pEventData->pBuf));
break;
case GAP_EVT_ADV_END_AFTER_DISABLE:
Display_printf(dispHandle, SP_ROW_ADVSTATE, 0, "Adv Set %d Disabled",
break;
case GAP_EVT_ADV_START:
break;
case GAP_EVT_ADV_END:
break;
case GAP_EVT_ADV_SET_TERMINATED:
#ifndef Display_DISABLE_ALL
GapAdv_setTerm_t *advSetTerm = (GapAdv_setTerm_t *)(pEventData->pBuf);
Display_printf(dispHandle, SP_ROW_ADVSTATE, 0, "Adv Set %d disabled after conn %d",
advSetTerm->handle, advSetTerm->connHandle );
#endif
break;
case GAP_EVT_SCAN_REQ_RECEIVED:
break;
case GAP_EVT_INSUFFICIENT_MEMORY:
break;
default:
break;
// All events have associated memory to free except the insufficient memory
// event
if (pEventData->event != GAP_EVT_INSUFFICIENT_MEMORY)
ICall_free(pEventData->pBuf);
* @fn SimplePeripheral_pairStateCb
* @brief Pairing state callback.
* @return none
uint8_t status)
spPairStateData_t *pData = ICall_malloc(sizeof(spPairStateData_t));
// Allocate space for the event data.
if (pData)
pData->state = state;
pData->connHandle = connHandle;
pData->status = status;
// Queue the event.
if(SimplePeripheral_enqueueMsg(SP_PAIR_STATE_EVT, pData) != SUCCESS)
ICall_free(pData);
* @fn SimplePeripheral_passcodeCb
* @brief Passcode callback.
* @return none
uint8_t uiInputs,
uint8_t uiOutputs,
spPasscodeData_t *pData = ICall_malloc(sizeof(spPasscodeData_t));
// Allocate space for the passcode event.
if (pData )
memcpy(pData->deviceAddr, pDeviceAddr, B_ADDR_LEN);
pData->uiInputs = uiInputs;
pData->uiOutputs = uiOutputs;
pData->numComparison = numComparison;
// Enqueue the event.
if(SimplePeripheral_enqueueMsg(SP_PASSCODE_EVT, pData) != SUCCESS)
ICall_free(pData);
* @fn SimplePeripheral_processPairState
* @brief Process the new paring state.
* @return none
static void SimplePeripheral_processPairState(spPairStateData_t *pPairData)
uint8_t state = pPairData->state;
uint8_t status = pPairData->status;
switch (state)
case GAPBOND_PAIRING_STATE_STARTED:
Display_printf(dispHandle, SP_ROW_CONNECTION, 0, "Pairing started");
break;
case GAPBOND_PAIRING_STATE_COMPLETE:
if (status == SUCCESS)
Display_printf(dispHandle, SP_ROW_CONNECTION, 0, "Pairing success");
else
Display_printf(dispHandle, SP_ROW_CONNECTION, 0, "Pairing fail: %d", status);
break;
case GAPBOND_PAIRING_STATE_ENCRYPTED:
Display_printf(dispHandle, SP_ROW_CONNECTION, 0, "Encryption success");
else
Display_printf(dispHandle, SP_ROW_CONNECTION, 0, "Encryption failed: %d", status);
break;
case GAPBOND_PAIRING_STATE_BOND_SAVED:
Display_printf(dispHandle, SP_ROW_CONNECTION, 0, "Bond save success");
else
Display_printf(dispHandle, SP_ROW_CONNECTION, 0, "Bond save failed: %d", status);
break;
default:
break;
* @fn SimplePeripheral_processPasscode
* @brief Process the Passcode request.
* @return none
// Display passcode to user
if (pPasscodeData->uiOutputs != 0)
Display_printf(dispHandle, SP_ROW_CONNECTION, 0, "Passcode: %d",
B_APP_DEFAULT_PASSCODE);
// Send passcode response
GAPBondMgr_PasscodeRsp(pPasscodeData->connHandle , SUCCESS,
* @fn SimplePeripheral_connEvtCB
* @brief Connection event callback.
* @param pReport pointer to connection event report
// Enqueue the event for processing in the app context.
if(SimplePeripheral_enqueueMsg(SP_CONN_EVT, pReport) != SUCCESS)
ICall_free(pReport);
* @fn SimplePeripheral_processConnEvt
* @brief Process connection event.
/* If we are waiting for an OAD Reboot, process connection events to ensure
* that we are not waiting to send data before restarting
if(oadWaitReboot)
// Wait until all pending messages are sent
if(numPendingMsgs == 0)
// Store the flag to indicate that a service changed IND will
// be sent at the next boot
sendSvcChngdOnNextBoot = TRUE;
uint8_t status = osal_snv_write(BLE_NVID_CUST_START,
sizeof(sendSvcChngdOnNextBoot),
(uint8 *)&sendSvcChngdOnNextBoot);
if(status != SUCCESS)
Display_print1(dispHandle, 5, 0, "SNV WRITE FAIL: %d", status);
// Reset the system
SystemReset();
else
numPendingMsgs--;
else
// Get index from handle
uint8_t connIndex = SimplePeripheral_getConnIndex(pReport->handle);
// If auto phy change is enabled
if (connList[connIndex].isAutoPHYEnable == TRUE)
// Read the RSSI
HCI_ReadRssiCmd(pReport->handle);
* @fn SimplePeripheral_enqueueMsg
* @brief Creates a message and puts the message in RTOS queue.
* @param event - message event.
* @param state - message state.
uint8_t success;
spEvt_t *pMsg = ICall_malloc(sizeof(spEvt_t));
// Create dynamic pointer to message.
if(pMsg)
pMsg->event = event;
pMsg->pData = pData;
// Enqueue the message.
success = Util_enqueueMsg(appMsgQueueHandle, syncEvent, (uint8_t *)pMsg);
return (success) ? SUCCESS : FAILURE;
return(bleMemAllocError);
* @fn SimplePeripheral_doSelectConn
* @brief Select a connection to communicate with
* @param index - item index from the menu
bool SimplePeripheral_doSelectConn(uint8_t index)
menuConnHandle = connList[index].connHandle;
// Set the menu title and go to this connection's context
TBM_SET_TITLE(&spMenuPerConn, TBM_GET_ACTION_DESC(&spMenuSelectConn, index));
// Clear non-connection-related message
tbm_goTo(&spMenuPerConn);
return (true);
* @fn SimplePeripheral_addConn
* @brief Add a device to the connected device list
* @return index of the connected device list entry where the new connection
* info is put in.
* if there is no room, MAX_NUM_BLE_CONNS will be returned.
uint8_t i;
uint8_t status = bleNoResources;
spClockEventData_t *paramUpdateEventData;
// Try to find an available entry
for (i = 0; i < MAX_NUM_BLE_CONNS; i++)
if (connList[i].connHandle == LINKDB_CONNHANDLE_INVALID)
// Found available entry to put a new connection info in
connList[i].connHandle = connHandle;
// Allocate data to send through clock handler
paramUpdateEventData = ICall_malloc(sizeof(spClockEventData_t) +
sizeof (uint16_t));
if(paramUpdateEventData)
paramUpdateEventData->event = SP_SEND_PARAM_UPDATE_EVT;
*((uint16_t *)paramUpdateEventData->data) = connHandle;
// Create a clock object and start
connList[i].pUpdateClock
= (Clock_Struct*) ICall_malloc(sizeof(Clock_Struct));
if (connList[i].pUpdateClock)
Util_constructClock(connList[i].pUpdateClock,
SEND_PARAM_UPDATE_DELAY, 0, true,
(UArg) paramUpdateEventData);
else
status = bleMemAllocError;
// Set default PHY to 1M
connList[i].currPhy = HCI_PHY_1_MBPS;
break;
return status;
* @fn SimplePeripheral_getConnIndex
* @brief Find index in the connected device list by connHandle
* @return the index of the entry that has the given connection handle.
* if there is no match, MAX_NUM_BLE_CONNS will be returned.
uint8_t i;
if (connList[i].connHandle == connHandle)
return i;
return(MAX_NUM_BLE_CONNS);
* @return SUCCESS if connHandle found valid index or bleInvalidRange
* if index wasn't found. LINKDB_CONNHANDLE_ALL will always succeed.
uint8_t i;
// Set to invalid connection index initially
uint8_t connIndex = MAX_NUM_BLE_CONNS;
if(connHandle != LINKDB_CONNHANDLE_ALL)
// Get connection index from handle
connIndex = SimplePeripheral_getConnIndex(connHandle);
if(connIndex >= MAX_NUM_BLE_CONNS)
return(bleInvalidRange);
// Clear specific handle or all handles
for(i = 0; i < MAX_NUM_BLE_CONNS; i++)
if((connIndex == i) || (connHandle == LINKDB_CONNHANDLE_ALL))
connList[i].connHandle = LINKDB_CONNHANDLE_INVALID;
connList[i].currPhy = 0;
connList[i].phyCngRq = 0;
connList[i].phyRqFailCnt = 0;
connList[i].rqPhy = 0;
memset(connList[i].rssiArr, 0, SP_MAX_RSSI_STORE_DEPTH);
connList[i].rssiAvg = 0;
connList[i].rssiCntr = 0;
connList[i].isAutoPHYEnable = FALSE;
return(SUCCESS);
* @fn SimplePeripheral_removeConn
* @brief Remove a device from the connected device list
* info is removed from.
* if connHandle is not found, MAX_NUM_BLE_CONNS will be returned.
uint8_t connIndex = SimplePeripheral_getConnIndex(connHandle);
if(connIndex != MAX_NUM_BLE_CONNS)
Clock_Struct* pUpdateClock = connList[connIndex].pUpdateClock;
if (pUpdateClock != NULL)
// Stop and destruct the RTOS clock if it's still alive
if (Util_isActive(pUpdateClock))
Util_stopClock(pUpdateClock);
// Destruct the clock object
Clock_destruct(pUpdateClock);
// Free clock struct
ICall_free(pUpdateClock);
// Stop Auto PHY Change
SimplePeripheral_stopAutoPhyChange(connHandle);
// Clear Connection List Entry
SimplePeripheral_clearConnListEntry(connHandle);
return connIndex;
* @fn SimplePeripheral_processParamUpdate
gapUpdateLinkParamReq_t req;
uint8_t connIndex;
req.connectionHandle = connHandle;
req.connLatency = DEFAULT_DESIRED_SLAVE_LATENCY;
req.connTimeout = DEFAULT_DESIRED_CONN_TIMEOUT;
req.intervalMin = DEFAULT_DESIRED_MIN_CONN_INTERVAL;
req.intervalMax = DEFAULT_DESIRED_MAX_CONN_INTERVAL;
// Deconstruct the clock object
Clock_destruct(connList[connIndex].pUpdateClock);
ICall_free(connList[connIndex].pUpdateClock);
connList[connIndex].pUpdateClock = NULL;
// Send parameter update
bStatus_t status = GAP_UpdateLinkParamReq(&req);
// If there is an ongoing update, queue this for when the udpate completes
if (status == bleAlreadyInRequestedMode)
spConnHandleEntry_t *connHandleEntry = ICall_malloc(sizeof(spConnHandleEntry_t));
if (connHandleEntry)
connHandleEntry->connHandle = connHandle;
List_put(¶mUpdateList, (List_Elem *)&connHandleEntry);
* @fn SimpleCentral_processCmdCompleteEvt
* @brief Process an incoming OSAL HCI Command Complete Event.
* @return none
uint8_t status = pMsg->pReturnParam[0];
//Find which command this command complete is for
switch (pMsg->cmdOpcode)
case HCI_READ_RSSI:
// Display RSSI value, if RSSI is higher than threshold, change to faster PHY
uint16_t handle = BUILD_UINT16(pMsg->pReturnParam[1], pMsg->pReturnParam[2]);
uint8_t index = SimplePeripheral_getConnIndex(handle);
SIMPLEPERIPHERAL_ASSERT(index < MAX_NUM_BLE_CONNS);
connList[index].rssiArr[connList[index].rssiCntr++] =
(int8_t)pMsg->pReturnParam[3];
connList[index].rssiCntr %= SP_MAX_RSSI_STORE_DEPTH;
int16_t sum_rssi = 0;
for(uint8_t cnt=0; cnt<SP_MAX_RSSI_STORE_DEPTH; cnt++)
sum_rssi += connList[index].rssiArr[cnt];
connList[index].rssiAvg = (uint32_t)(sum_rssi/SP_MAX_RSSI_STORE_DEPTH);
Display_printf(dispHandle, SP_ROW_RSSI, 0,
"RSSI:-%d, AVG RSSI:-%d",
(uint32_t)(-(int8_t)pMsg->pReturnParam[3]),
(uint32_t)(-sum_rssi/SP_MAX_RSSI_STORE_DEPTH));
uint8_t phyRq = SP_PHY_NONE;
uint8_t phyRqS = SP_PHY_NONE;
uint8_t phyOpt = LL_PHY_OPT_NONE;
if(connList[index].phyCngRq == FALSE)
if((connList[index].rssiAvg >= RSSI_2M_THRSHLD) &&
(connList[index].currPhy != HCI_PHY_2_MBPS) &&
(connList[index].currPhy != SP_PHY_NONE))
// try to go to higher data rate
phyRqS = phyRq = HCI_PHY_2_MBPS;
else if((connList[index].rssiAvg < RSSI_2M_THRSHLD) &&
(connList[index].rssiAvg >= RSSI_1M_THRSHLD) &&
(connList[index].currPhy != HCI_PHY_1_MBPS) &&
// try to go to legacy regular data rate
phyRqS = phyRq = HCI_PHY_1_MBPS;
else if((connList[index].rssiAvg >= RSSI_S2_THRSHLD) &&
(connList[index].rssiAvg < RSSI_1M_THRSHLD) &&
// try to go to lower data rate S=2(500kb/s)
phyRqS = HCI_PHY_CODED;
phyOpt = LL_PHY_OPT_S2;
phyRq = BLE5_CODED_S2_PHY;
else if(connList[index].rssiAvg < RSSI_S2_THRSHLD )
// try to go to lowest data rate S=8(125kb/s)
phyOpt = LL_PHY_OPT_S8;
phyRq = BLE5_CODED_S8_PHY;
if((phyRq != SP_PHY_NONE) &&
// First check if the request for this phy change is already not honored then don't request for change
(((connList[index].rqPhy == phyRq) &&
(connList[index].phyRqFailCnt < 2)) ||
(connList[index].rqPhy != phyRq)))
//Initiate PHY change based on RSSI
SimplePeripheral_setPhy(connList[index].connHandle, 0,
phyRqS, phyRqS, phyOpt);
connList[index].phyCngRq = TRUE;
// If it a request for different phy than failed request, reset the count
if(connList[index].rqPhy != phyRq)
// then reset the request phy counter and requested phy
connList[index].phyRqFailCnt = 0;
if(phyOpt == LL_PHY_OPT_NONE)
connList[index].rqPhy = phyRq;
else if(phyOpt == LL_PHY_OPT_S2)
connList[index].rqPhy = BLE5_CODED_S2_PHY;
else
connList[index].rqPhy = BLE5_CODED_S8_PHY;
} // end of if(connList[index].phyCngRq == FALSE)
} // end of if (status == SUCCESS)
break;
case HCI_LE_READ_PHY:
Display_printf(dispHandle, SP_ROW_RSSI + 2, 0, "RXPh: %d, TXPh: %d",
pMsg->pReturnParam[3], pMsg->pReturnParam[4]);
break;
case HCI_LE_READ_LOCAL_RESOLVABLE_ADDRESS:
uint8_t* pRpaNew = &(pMsg->pReturnParam[1]);
if (memcmp(pRpaNew, rpa, B_ADDR_LEN))
// If the RPA has changed, update the display
Display_printf(dispHandle, SP_ROW_RPA, 0, "RP Addr: %s",
Util_convertBdAddr2Str(pRpaNew));
memcpy(rpa, pRpaNew, B_ADDR_LEN);
break;
case HCI_RESET:
status = GAP_DeviceInit(GAP_PROFILE_PERIPHERAL, selfEntity, addrMode, &pRandomAddress);
/* ohoh, very bad :( */
break;
default:
break;
} // end of switch (pMsg->cmdOpcode)
* @fn SimplePeripheral_initPHYRSSIArray
* @brief Initializes the array of structure/s to store data related
* RSSI based auto PHy change
* @param connHandle - the connection handle
* @param addr - pointer to device address
* @return index of connection handle
//Initialize array to store connection handle and RSSI values
memset(connList, 0, sizeof(connList));
for (uint8_t index = 0; index < MAX_NUM_BLE_CONNS; index++)
connList[index].connHandle = SP_INVALID_HANDLE;
* @fn SimplePeripheral_startAutoPhyChange
* @brief Start periodic RSSI reads on a link.
* @param connHandle - connection handle of link
* @param devAddr - device address
* @return SUCCESS: Terminate started
* bleIncorrectMode: No link
* bleNoResources: No resources
status_t status = FAILURE;
// Start Connection Event notice for RSSI calculation
Gap_RegisterConnEventCb(SimplePeripheral_connEvtCB, GAP_CB_REGISTER, connHandle);
// Flag in connection info if successful
connList[connIndex].isAutoPHYEnable = TRUE;
return status;
* @fn SimplePeripheral_stopAutoPhyChange
* @brief Cancel periodic RSSI reads on a link.
* @return SUCCESS: Operation successful
// Stop connection event notice
Gap_RegisterConnEventCb(NULL, GAP_CB_UNREGISTER, connHandle);
// Also update the phychange request status for active RSSI tracking connection
connList[connIndex].phyCngRq = FALSE;
connList[connIndex].isAutoPHYEnable = FALSE;
return SUCCESS;
* @fn SimplePeripheral_setPhy
* @brief Call the HCI set phy API and and add the handle to a
* list to match it to an incoming command status event
uint16_t phyOpts)
// Allocate list entry to store handle for command status
// Add entry to the phy command status list
List_put(&setPhyCommStatList, (List_Elem *)connHandleEntry);
// Send PHY Update
HCI_LE_SetPhyCmd(connHandle, allPhys, txPhy, rxPhy, phyOpts);
return SUCCESS;
* @fn SimplePeripheral_updatePHYStat
* @brief Update the auto phy update state machine
* @return None
uint8_t connIndex;
switch (eventCode)
// Get connection handle from list
(spConnHandleEntry_t *)List_get(&setPhyCommStatList);
// Get index from connection handle
connIndex = SimplePeripheral_getConnIndex(connHandleEntry->connHandle);
// Is this connection still valid?
if (connIndex < MAX_NUM_BLE_CONNS)
// Update the phychange request status for active RSSI tracking connection
connList[connIndex].phyRqFailCnt++;
break;
// LE Event - a Phy update has completed or failed
case HCI_BLE_PHY_UPDATE_COMPLETE_EVENT:
if(pPUC)
connIndex = SimplePeripheral_getConnIndex(pPUC->connHandle);
if (pPUC->status == SUCCESS)
connList[connIndex].currPhy = pPUC->rxPhy;
if(pPUC->rxPhy != connList[connIndex].rqPhy)
else
// Reset the request phy counter and requested phy
connList[connIndex].phyRqFailCnt = 0;
connList[connIndex].rqPhy = 0;
break;
default:
break;
} // end of switch (eventCode)
* @fn SimplePeripheral_menuSwitchCb
* @brief Detect menu context switching
* @param pMenuObjCurr - the current menu object
* @param pMenuObjNext - the menu object the context is about to switch to
* @return none
uint8_t NUMB_ACTIVE_CONNS = linkDB_NumActive();
// interested in only the events of
// entering scMenuConnect, spMenuSelectConn, and scMenuMain for now
if (pMenuObjNext == &spMenuSelectConn)
static uint8_t* pAddrs;
uint8_t* pAddrTemp;
if (pAddrs != NULL)
ICall_free(pAddrs);
// Allocate buffer to display addresses
pAddrs = ICall_malloc(NUMB_ACTIVE_CONNS * SP_ADDR_STR_SIZE);
if (pAddrs == NULL)
TBM_SET_NUM_ITEM(&spMenuSelectConn, 0);
else
uint8_t i;
TBM_SET_NUM_ITEM(&spMenuSelectConn, MAX_NUM_BLE_CONNS);
pAddrTemp = pAddrs;
// Add active connection info to the menu object
if (connList[i].connHandle != LINKDB_CONNHANDLE_INVALID)
linkDB_GetInfo(connList[i].connHandle, &linkInfo);
// This connection is active. Set the corresponding menu item with
// the address of this connection and enable the item.
memcpy(pAddrTemp, Util_convertBdAddr2Str(linkInfo.addr),
SP_ADDR_STR_SIZE);
TBM_SET_ACTION_DESC(&spMenuSelectConn, i, pAddrTemp);
tbm_setItemStatus(&spMenuSelectConn, (1 << i), SP_ITEM_NONE);
pAddrTemp += SP_ADDR_STR_SIZE;
else
// This connection is not active. Disable the corresponding menu item.
tbm_setItemStatus(&spMenuSelectConn, SP_ITEM_NONE, (1 << i));
else if (pMenuObjNext == &spMenuMain)
// Now we are not in a specific connection's context
// Clear connection-related message
* @fn ClockEventHandler
* @brief Gets calles by clock after timeout - icall reinit test helper
* input parameters
* @param arg - create time user argument
* output parameters
* @param None.
* @return None.
SimplePeripheral_enqueueMsg(SP_TEST_EVT, NULL);
