Part Number: CC2652R
Other Parts Discussed in Thread: CC2640, CC2640R2F, SYSCONFIG
I have the LAUCHXL-CC2652 as a master and CC2640 as a slave.
But every time I try to connect CC2640, the connection will be broken after 30 seconds about. It seems that the master cannot receive the connection event from the slave or the slave cannot receive the connection event from the master. Is it true that connection event is sent in SimpleCentral_taskFxn(uintptr_t a0, uintptr_t a1) only? Can they send a connection event in whatever functions I'm calling?
I'm not very clear about how to establish a connection between two BLE devices. Is it OK if I call SimpleCentral_doSelectConn(0) to exchange MTU in case GAP_LINK_ESTABLISHED_EVENT in function SimpleCentral_processGapMsg(gapEventHdr_t *pMsg)?
And should I update the params of the link?
Here is the code of LAUCHXL-CC2652
@file simple_central.c
@brief This file contains the Simple Central sample application for use
with the CC2650 Bluetooth Low Energy Protocol Stack.
Group: WCS, BTS
Target Device: cc13xx_cc26xx
Copyright (c) 2013-2022, Texas Instruments Incorporated
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
* Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
its contributors may be used to endorse or promote products derived
from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* INCLUDES
#include <string.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/knl/Clock.h>
#include <ti/sysbios/knl/Event.h>
#include <ti/sysbios/knl/Queue.h>
#include <ti/display/Display.h>
#include "bcomdef.h"
#include <ti/drivers/GPIO.h>
#include <icall.h>
#include "util.h"
/* This Header file contains all BLE API and icall structure definition */
#include "icall_ble_api.h"
#include "osal_list.h"
#include "board_key.h"
#include <ti_drivers_config.h>
#include "ti_ble_config.h"
#include "ble_user_config.h"
#include "simple_gatt_profile.h"
#include <menu/two_btn_menu.h>
#include "simple_central.h"
#include "simple_central_menu.h"
//Author: Wang Jieqiong
#include "usrs.h"
Clock_Struct uart_clock;
Clock_Struct startDiscClock;
* MACROS
* CONSTANTS
// Application events
#define SC_EVT_KEY_CHANGE 0x01
#define SC_EVT_SCAN_ENABLED 0x02
#define SC_EVT_SCAN_DISABLED 0x03
#define SC_EVT_ADV_REPORT 0x04
#define SC_EVT_SVC_DISC 0x05
#define SC_EVT_READ_RSSI 0x06
#define SC_EVT_PAIR_STATE 0x07
#define SC_EVT_PASSCODE_NEEDED 0x08
#define SC_EVT_READ_RPA 0x09
#define SC_EVT_INSUFFICIENT_MEM 0x0A
// Simple Central Task Events
#define SC_ICALL_EVT ICALL_MSG_EVENT_ID // Event_Id_31
#define SC_QUEUE_EVT UTIL_QUEUE_EVENT_ID // Event_Id_30
#define SC_ALL_EVENTS (SC_ICALL_EVT | \
SC_QUEUE_EVT)
// Default connection interval when connecting to more then 8 connections and autoconnenct enabled
#define DEFAULT_MULTICON_INTERVAL 200 //250 ms (200 frames of 1.25ms)
// Default connection supervision timeout when connnecting to more then 8 connections and autoconnenct enabled
#define DEFAULT_MULTICON_LSTO 3200 // 32 secs
// Supervision timeout conversion rate to miliseconds
#define CONN_TIMEOUT_MS_CONVERSION 10
// Task configuration
#define SC_TASK_PRIORITY 1
#ifndef SC_TASK_STACK_SIZE
#define SC_TASK_STACK_SIZE 1024
#endif
// Size of string-converted device address ("0xXXXXXXXXXXXX")
#define SC_ADDR_STR_SIZE 15
// Row numbers for two-button menu
#define SC_ROW_SEPARATOR (TBM_ROW_APP + 0)
#define SC_ROW_CUR_CONN (TBM_ROW_APP + 1)
#define SC_ROW_ANY_CONN (TBM_ROW_APP + 2)
#define SC_ROW_NON_CONN (TBM_ROW_APP + 3)
#define SC_ROW_NUM_CONN (TBM_ROW_APP + 4)
#define SC_ROW_IDA (TBM_ROW_APP + 5)
#define SC_ROW_RPA (TBM_ROW_APP + 6)
#define SC_ROW_AC (TBM_ROW_APP + 8)
// Spin if the expression is not true
#define SIMPLECENTRAL_ASSERT(expr) if (!(expr)) SimpleCentral_spin();
// Timeout for the initiator to cancel connection if not successful
#define CONNECTION_TIMEOUT 3000
// Auto connect chosen group
#define GROUP_NAME_LENGTH 4
//Member defalult status when initalized
#define GROUP_MEMBER_INITIALIZED 0x00
//Member connected
#define GROUP_MEMBER_CONNECTED 0x01
//Default connection handle which is set when group member is created
#define GROUP_INITIALIZED_CONNECTION_HANDLE 0xFFFF
* TYPEDEFS
// Auto connect availble groups
enum
AUTOCONNECT_DISABLE = 0, // Disable
AUTOCONNECT_GROUP_A = 1, // Group A
AUTOCONNECT_GROUP_B = 2 // Group B
// Discovery states
enum
BLE_DISC_STATE_IDLE, // Idle
BLE_DISC_STATE_MTU, // Exchange ATT MTU size
BLE_DISC_STATE_SVC, // Service discovery
BLE_DISC_STATE_CHAR // Characteristic discovery
// App event passed from profiles.
typedef struct
appEvtHdr_t hdr; // event header
uint8_t *pData; // event data
} scEvt_t;
// Scanned device information record
typedef struct
uint8_t addrType; // Peer Device's Address Type
uint8_t addr[B_ADDR_LEN]; // Peer Device Address
} scanRec_t;
// Connected device information
typedef struct
uint16_t connHandle; // Connection Handle
uint16_t charHandle; // Characteristic Handle
Clock_Struct *pRssiClock; // pointer to clock struct
} connRec_t;
// Container to store paring state info when passing from gapbondmgr callback
// to app event. See the pfnPairStateCB_t documentation from the gapbondmgr.h
// header file for more information on each parameter.
typedef struct
uint8_t status;
} scPairStateData_t;
// Container to store passcode data when passing from gapbondmgr callback
// to app event. See the pfnPasscodeCB_t documentation from the gapbondmgr.h
typedef struct
uint8_t deviceAddr[B_ADDR_LEN];
uint8_t uiInputs;
uint8_t uiOutputs;
uint32_t numComparison;
} scPasscodeData_t;
typedef struct
osal_list_elem elem;
uint8_t addr[B_ADDR_LEN]; // member's BDADDR
uint8_t addrType; // member's Address Type
uint16_t connHandle; // member's connection handle
uint8_t status; // bitwise status flag
} groupListElem_t;
* GLOBAL VARIABLES
// Display Interface
Display_Handle dispHandle = NULL;
* EXTERNAL VARIABLES
#define APP_EVT_EVENT_MAX 0xA
char *appEventStrings[] = {
"APP_EVT_ZERO ",
"APP_EVT_KEY_CHANGE ",
"APP_EVT_SCAN_ENABLED ",
"APP_EVT_SCAN_DISABLED ",
"APP_EVT_ADV_REPORT ",
"APP_EVT_SVC_DISC ",
"APP_EVT_READ_RSSI ",
"APP_EVT_PAIR_STATE ",
"APP_EVT_PASSCODE_NEEDED ",
"APP_EVT_READ_RPA ",
"APP_EVT_INSUFFICIENT_MEM ",
* LOCAL VARIABLES
// Entity ID globally used to check for source and/or destination of messages
static ICall_EntityID selfEntity;
// Event globally used to post local events and pend on system and
// local events.
static ICall_SyncHandle syncEvent;
// Queue object used for app messages
static Queue_Struct appMsg;
static Queue_Handle appMsgQueue;
Task_Struct scTask;
#if defined __TI_COMPILER_VERSION__
#pragma DATA_ALIGN(scTaskStack, 8)
#else
#pragma data_alignment=8
#endif
uint8_t scTaskStack[SC_TASK_STACK_SIZE];
#if (DEFAULT_DEV_DISC_BY_SVC_UUID == TRUE)
// Number of scan results filtered by Service UUID
static uint8_t numScanRes = 0;
// Scan results filtered by Service UUID
static scanRec_t scanList[DEFAULT_MAX_SCAN_RES];
#endif // DEFAULT_DEV_DISC_BY_SVC_UUID
// Number of connected devices
static uint8_t numConn = 0;
// List of connections
static connRec_t connList[MAX_NUM_BLE_CONNS];
// Connection handle of current connection
static uint16_t scConnHandle = LINKDB_CONNHANDLE_INVALID;
// Accept or reject L2CAP connection parameter update request
static bool acceptParamUpdateReq = true;
// Discovery state
static uint8_t discState = BLE_DISC_STATE_IDLE;
// Discovered service start and end handle
static uint16_t svcStartHdl = 0;
static uint16_t svcEndHdl = 0;
// Value to write
static uint8_t charVal = 0;
// Maximum PDU size (default = 27 octets)
static uint16_t scMaxPduSize;
// Clock instance for RPA read events.
static Clock_Struct clkRpaRead;
// Address mode
static GAP_Addr_Modes_t addrMode = DEFAULT_ADDRESS_MODE;
// Current Random Private Address
static uint8 rpa[B_ADDR_LEN] = {0};
// Auto connect Disabled/Enabled {0 - Disabled, 1- Group A , 2-Group B, ...}
uint8_t autoConnect = AUTOCONNECT_GROUP_A;
//AutoConnect Group list
static osal_list_list groupList;
//AutoConnect ADV data filter according to local name short
//static uint8_t acGroup[4] = {
// 0x03,
// GAP_ADTYPE_LOCAL_NAME_SHORT,
// 'G',
// 'A'
0x02,
GAP_ADTYPE_FLAGS,
GAP_ADTYPE_FLAGS_GENERAL | GAP_ADTYPE_FLAGS_BREDR_NOT_SUPPORTED,
// service UUID, to notify central devices what services are included
// in this peripheral
#if !defined(FEATURE_OAD) || defined(FEATURE_OAD_ONCHIP)
0x03, // length of this data
#else //OAD for external flash
0x05, // length of this data
#endif //FEATURE_OAD
GAP_ADTYPE_16BIT_MORE, // some of the UUID's, but not all
#ifdef FEATURE_OAD
LO_UINT16(OAD_SERVICE_UUID),
HI_UINT16(OAD_SERVICE_UUID),
#ifndef FEATURE_OAD_ONCHIP
LO_UINT16(SIMPLEPROFILE_SERV_UUID),
HI_UINT16(SIMPLEPROFILE_SERV_UUID)
#endif //FEATURE_OAD_ONCHIP
//Number of group members found
static uint8_t numGroupMembers = 0;
//Connection in progress to avoid double initiate
static groupListElem_t *memberInProg;
* LOCAL FUNCTIONS
static void SimpleCentral_init(void);
static void SimpleCentral_taskFxn(uintptr_t a0, uintptr_t a1);
static uint8_t SimpleCentral_isMember(uint8_t *advData , uint8_t *groupName , uint8_t len);
static void SimpleCentral_autoConnect(void);
static void SimpleCentral_handleKeys(uint8_t keys);
static uint8_t SimpleCentral_processStackMsg(ICall_Hdr *pMsg);
static void SimpleCentral_processGapMsg(gapEventHdr_t *pMsg);
static void SimpleCentral_processGATTMsg(gattMsgEvent_t *pMsg);
static void SimpleCentral_processAppMsg(scEvt_t *pMsg);
static void SimpleCentral_processGATTDiscEvent(gattMsgEvent_t *pMsg);
static void SimpleCentral_startSvcDiscovery(void);
static bool SimpleCentral_findSvcUuid(uint16_t uuid, uint8_t *pData,
uint16_t dataLen);
static void SimpleCentral_addScanInfo(uint8_t *pAddr, uint8_t addrType);
static uint8_t SimpleCentral_addConnInfo(uint16_t connHandle, uint8_t *pAddr);
static uint8_t SimpleCentral_removeConnInfo(uint16_t connHandle);
static uint8_t SimpleCentral_getConnIndex(uint16_t connHandle);
#ifndef Display_DISABLE_ALL
static char* SimpleCentral_getConnAddrStr(uint16_t connHandle);
#endif
static void SimpleCentral_processPairState(uint8_t state,
scPairStateData_t* pPairStateData);
static void SimpleCentral_processPasscode(scPasscodeData_t *pData);
static void SimpleCentral_processCmdCompleteEvt(hciEvt_CmdComplete_t *pMsg);
static status_t SimpleCentral_StartRssi();
static status_t SimpleCentral_CancelRssi(uint16_t connHandle);
static void SimpleCentral_passcodeCb(uint8_t *deviceAddr, uint16_t connHandle,
uint8_t uiInputs, uint8_t uiOutputs,
uint32_t numComparison);
static void SimpleCentral_pairStateCb(uint16_t connHandle, uint8_t state,
uint8_t status);
static void SimpleCentral_keyChangeHandler(uint8 keys);
static void SimpleCentral_clockHandler(UArg arg);
static status_t SimpleCentral_enqueueMsg(uint8_t event, uint8_t status,
uint8_t *pData);
static void SimpleCentral_scanCb(uint32_t evt, void* msg, uintptr_t arg);
static void SimpleCentral_menuSwitchCb(tbmMenuObj_t* pMenuObjCurr,
tbmMenuObj_t* pMenuObjNext);
* EXTERN FUNCTIONS
extern void AssertHandler(uint8 assertCause, uint8 assertSubcause);
* PROFILE CALLBACKS
// Bond Manager Callbacks
static gapBondCBs_t bondMgrCBs =
SimpleCentral_passcodeCb, // Passcode callback
SimpleCentral_pairStateCb // Pairing/Bonding state Callback
* PUBLIC FUNCTIONS
* @fn SimpleCentral_isMember
* @brief Check if Advertiser is part of the group according to its Adv Data
* @param advData - pointer to adv data
* groupNmae - group name which need to be compared with
* len - length of the group name
* @return TRUE: part of the group
* FALSE: not part of the group
if (osal_memcmp((uint8_t *)advData, (uint8_t *)groupName, len))
return TRUE;
return FALSE;
* @fn SimpleCentral_autoConnect
* @param none
* @return none
status_t status;
int len = 9;
size_t bytesWritten;
if (memberInProg == NULL)
if (numConn < MAX_NUM_BLE_CONNS)
groupListElem_t *tempMember = (groupListElem_t *)osal_list_head(&groupList);
//If group member is not connected
if ((tempMember != NULL) && (!(tempMember->status & GROUP_MEMBER_CONNECTED)))
//Initiate a connection
status = GapInit_connect(tempMember->addrType & MASK_ADDRTYPE_ID,tempMember->addr, DEFAULT_INIT_PHY, CONNECTION_TIMEOUT);
if (status != SUCCESS)
//Couldn't create connection remove element from list and free the memory.
// char *str = "AutoConnect Failed. The status is 0";
// str[35] = status + '0';
// Uart_SendMsg(UART_HEADER_STR,36, str);
osal_list_remove(&groupList, (osal_list_elem *)tempMember);
ICall_free(tempMember);
else
//Save pointer to connection in progress untill connection is established.
memberInProg = tempMember;
// Uart_SendMsg(UART_HEADER_HEX,6, tempMember->addr);
else
Display_printf(dispHandle, SC_ROW_NON_CONN, 0, "AutoConnect turned off: Max connection reached.");
* @fn SimpleCentral_spin
* @brief Spin forever
* @param none
static void SimpleCentral_spin(void)
volatile uint8_t x;
// Uart_SendMsg(UART_HEADER_STR,9, "Spinning!");
while(1)
x++;
* @fn SimpleCentral_createTask
* @brief Task creation function for the Simple Central.
* @param none
* @return none
void SimpleCentral_createTask(void)
Task_Params taskParams;
// Configure task
Task_Params_init(&taskParams);
taskParams.stack = scTaskStack;
taskParams.stackSize = SC_TASK_STACK_SIZE;
taskParams.priority = SC_TASK_PRIORITY;
Task_construct(&scTask, SimpleCentral_taskFxn, &taskParams, NULL);
* @fn SimpleCentral_Init
* @brief Initialization function for the Simple Central App Task.
* This is called during initialization and should contain
* any application specific initialization (ie. hardware
* initialization/setup, table initialization, power up
* notification).
* @param none
* @return none
uint8_t i;
BLE_LOG_INT_TIME(0, BLE_LOG_MODULE_APP, "APP : ---- init ", SC_TASK_PRIORITY);
// Create the menu
SimpleCentral_buildMenu();
// N0 STACK API CALLS CAN OCCUR BEFORE THIS CALL TO ICall_registerApp
// Register the current thread as an ICall dispatcher application
// so that the application can send and receive messages.
ICall_registerApp(&selfEntity, &syncEvent);
// Create an RTOS queue for message from profile to be sent to app.
appMsgQueue = Util_constructQueue(&appMsg);
// Initialize internal data
for (i = 0; i < MAX_NUM_BLE_CONNS; i++)
connList[i].connHandle = LINKDB_CONNHANDLE_INVALID;
connList[i].pRssiClock = NULL;
Board_initKeys(SimpleCentral_keyChangeHandler);
GGS_SetParameter(GGS_DEVICE_NAME_ATT, GAP_DEVICE_NAME_LEN,
(void *)attDeviceName);
//Set default values for Data Length Extension
//Extended Data Length Feature is already enabled by default
//in build_config.opt in stack project.
//Change initial values of RX/TX PDU and Time, RX is set to max. by default(251 octets, 2120us)
#define APP_SUGGESTED_RX_PDU_SIZE 251 //default is 251 octets(RX)
#define APP_SUGGESTED_RX_TIME 17000 //default is 17000us(RX)
#define APP_SUGGESTED_TX_PDU_SIZE 27 //default is 27 octets(TX)
#define APP_SUGGESTED_TX_TIME 328 //default is 328us(TX)
//This API is documented in hci.h
//See the LE Data Length Extension section in the BLE5-Stack User's Guide for information on using this command:
//http://software-dl.ti.com/lprf/ble5stack-latest/
// HCI_EXT_SetMaxDataLenCmd(APP_SUGGESTED_TX_PDU_SIZE, APP_SUGGESTED_TX_TIME, APP_SUGGESTED_RX_PDU_SIZE, APP_SUGGESTED_RX_TIME);
HCI_LE_WriteSuggestedDefaultDataLenCmd(APP_SUGGESTED_RX_PDU_SIZE, APP_SUGGESTED_TX_TIME);
HCI_LE_SetDefaultPhyCmd(LL_PHY_USE_ANY_PHY, LL_PHY_2_MBPS, LL_PHY_2_MBPS);
// Initialize GATT Client
VOID GATT_InitClient("");
// Register to receive incoming ATT Indications/Notifications
GATT_RegisterForInd(selfEntity);
// Initialize GATT attributes
// GGS_AddService(GAP_SERVICE); // GAP
GGS_AddService(GATT_ALL_SERVICES);
GATTServApp_AddService(GATT_ALL_SERVICES); // GATT attributes
// Register for GATT local events and ATT Responses pending for transmission
GATT_RegisterForMsgs(selfEntity);
// Set Bond Manager parameters
setBondManagerParameters();
// Start Bond Manager and register callback
// This must be done before initialing the GAP layer
VOID GAPBondMgr_Register(&bondMgrCBs);
// Accept all parameter update requests
GAP_SetParamValue(GAP_PARAM_LINK_UPDATE_DECISION, GAP_UPDATE_REQ_ACCEPT_ALL);
// Register with GAP for HCI/Host messages (for RSSI)
GAP_RegisterForMsgs(selfEntity);
BLE_LOG_INT_TIME(0, BLE_LOG_MODULE_APP, "APP : ---- call GAP_DeviceInit", GAP_PROFILE_CENTRAL);
// Initialize GAP layer for Central role and register to receive GAP events
GAP_DeviceInit(GAP_PROFILE_CENTRAL, selfEntity, addrMode, &pRandomAddress);
dispHandle = Display_open(Display_Type_ANY, NULL);
// Disable all items in the main menu
tbm_setItemStatus(&scMenuMain, SC_ITEM_NONE, SC_ITEM_ALL);
// Initialize Two-button Menu
tbm_initTwoBtnMenu(dispHandle, &scMenuMain, 5, SimpleCentral_menuSwitchCb);
Display_printf(dispHandle, SC_ROW_SEPARATOR, 0, "====================");
UART2_Params_init(&uart_params);
uart_params.writeMode = UART2_Mode_CALLBACK;
uart_params.writeCallback = UART_WRITE_CALLBACK;
uart_params.baudRate = 256000;
uart = UART2_open(CONFIG_UART2_0, &uart_params);
LED_init();
LED_Params LED_params;
LED_Params_init(&LED_params);
led_red = LED_open(CONFIG_LED_0, &LED_params);
led_green = LED_open(CONFIG_LED_1, &LED_params);
if(!uart){
while(1);
// LED_setOn(led_green, 100);
Util_constructClock(&uart_clock, SimpleCentral_clockHandler,
UART_PERIOD, 0, true, SC_EVT_UART_WRITE);
Util_constructClock(&startDiscClock, SimpleCentral_clockHandler,
DEFAULT_SVC_DISCOVERY_DELAY, 0, false, SC_EVT_START_DISCOVERY);
// Util_startClock(&uart_clock);
} //SimpleCentral_init()
//UART2_Callback UART_WRITE_CALLBACK(UART2_Handle handle, void *buf, size_t count, void *userArg, int_fast16_t status){
* @fn SimpleCentral_taskFxn
* @brief Application task entry point for the Simple Central.
* @param none
* @return events not processed
// Initialize application
SimpleCentral_init();
// Uart_SendMsg(UART_HEADER_STR,50, "====================================================");
// Application main loop
for (;;)
uint32_t events;
events = Event_pend(syncEvent, Event_Id_NONE, SC_ALL_EVENTS | SC_UART_EVT,
ICALL_TIMEOUT_FOREVER);
if (events)
ICall_EntityID dest;
ICall_ServiceEnum src;
ICall_HciExtEvt *pMsg = NULL;
if (ICall_fetchServiceMsg(&src, &dest,
(void **)&pMsg) == ICALL_ERRNO_SUCCESS)
uint8 safeToDealloc = TRUE;
if ((src == ICALL_SERVICE_CLASS_BLE) && (dest == selfEntity))
ICall_Stack_Event *pEvt = (ICall_Stack_Event *)pMsg;
// Check for BLE stack events first
if (pEvt->signature != 0xffff)
// Process inter-task message
safeToDealloc = SimpleCentral_processStackMsg((ICall_Hdr *)pMsg);
if (pMsg && safeToDealloc)
ICall_freeMsg(pMsg);
// If RTOS queue is not empty, process app message
if (events & SC_QUEUE_EVT)
scEvt_t *pMsg;
while ((pMsg = (scEvt_t *)Util_dequeueMsg(appMsgQueue)))
// Process message
SimpleCentral_processAppMsg(pMsg);
// Free the space from the message
ICall_free(pMsg);
}//events & SC_QUEUE_EVT
if(events & SC_UART_EVT){
// SimpleCentral_doSelectConn(0);
// Uart_SendMsg(UART_HEADER_STR,14, "Clock working.");
// led_red_status = !led_red_status;
* @fn SimpleCentral_processStackMsg
* @brief Process an incoming task message.
* @param pMsg - message to process
* @return TRUE if safe to deallocate incoming message, FALSE otherwise.
uint8_t safeToDealloc = TRUE;
BLE_LOG_INT_INT(0, BLE_LOG_MODULE_APP, "APP : Stack msg status=%d, event=0x%x\n", pMsg->status, pMsg->event);
switch (pMsg->event)
case GAP_MSG_EVENT:
SimpleCentral_processGapMsg((gapEventHdr_t*) pMsg);
break;
case GATT_MSG_EVENT:
SimpleCentral_processGATTMsg((gattMsgEvent_t *)pMsg);
break;
case HCI_GAP_EVENT_EVENT:
// Process HCI message
switch (pMsg->status)
case HCI_COMMAND_COMPLETE_EVENT_CODE:
SimpleCentral_processCmdCompleteEvt((hciEvt_CmdComplete_t *) pMsg);
break;
case HCI_BLE_HARDWARE_ERROR_EVENT_CODE:
AssertHandler(HAL_ASSERT_CAUSE_HARDWARE_ERROR,0);
break;
// HCI Commands Events
case HCI_COMMAND_STATUS_EVENT_CODE:
hciEvt_CommandStatus_t *pMyMsg = (hciEvt_CommandStatus_t *)pMsg;
switch ( pMyMsg->cmdOpcode )
case HCI_LE_SET_PHY:
if (pMyMsg->cmdStatus ==
HCI_ERROR_CODE_UNSUPPORTED_REMOTE_FEATURE)
Display_printf(dispHandle, SC_ROW_CUR_CONN, 0,
"PHY Change failure, peer does not support this");
else
"PHY Update Status: 0x%02x",
pMyMsg->cmdStatus);
break;
case HCI_DISCONNECT:
break;
default:
"Unknown Cmd Status: 0x%04x::0x%02x",
pMyMsg->cmdOpcode, pMyMsg->cmdStatus);
break;
break;
// LE Events
case HCI_LE_EVENT_CODE:
hciEvt_BLEPhyUpdateComplete_t *pPUC
= (hciEvt_BLEPhyUpdateComplete_t*) pMsg;
if (pPUC->BLEEventCode == HCI_BLE_PHY_UPDATE_COMPLETE_EVENT)
if (pPUC->status != SUCCESS)
Display_printf(dispHandle, SC_ROW_ANY_CONN, 0,
"%s: PHY change failure",
SimpleCentral_getConnAddrStr(pPUC->connHandle));
else
"%s: PHY updated to %s",
SimpleCentral_getConnAddrStr(pPUC->connHandle),
// Only symmetrical PHY is supported.
// rxPhy should be equal to txPhy.
(pPUC->rxPhy == PHY_UPDATE_COMPLETE_EVENT_1M) ? "1 Mbps" :
(pPUC->rxPhy == PHY_UPDATE_COMPLETE_EVENT_2M) ? "2 Mbps" :
(pPUC->rxPhy == PHY_UPDATE_COMPLETE_EVENT_CODED) ? "CODED" : "Unexpected PHY Value");
break;
default:
break;
break;
case L2CAP_SIGNAL_EVENT:
// place holder for L2CAP Connection Parameter Reply
break;
default:
break;
return (safeToDealloc);
* @fn SimpleCentral_processAppMsg
* @brief Scanner application event processing function.
* @param pMsg - pointer to event structure
* @return none
bool safeToDealloc = TRUE;
if (pMsg->hdr.event <= APP_EVT_EVENT_MAX)
BLE_LOG_INT_STR(0, BLE_LOG_MODULE_APP, "APP : App msg status=%d, event=%s\n", 0, appEventStrings[pMsg->hdr.event]);
else
BLE_LOG_INT_INT(0, BLE_LOG_MODULE_APP, "APP : App msg status=%d, event=0x%x\n", 0, pMsg->hdr.event);
switch (pMsg->hdr.event)
case SC_EVT_KEY_CHANGE:
SimpleCentral_handleKeys(pMsg->hdr.state);
break;
case SC_EVT_ADV_REPORT:
// Uart_SendMsg(UART_HEADER_STR,17, "SC_EVT_ADV_REPORT");
GapScan_Evt_AdvRpt_t* pAdvRpt = (GapScan_Evt_AdvRpt_t*) (pMsg->pData);
// Uart_SendMsg(UART_HEADER_HEX, B_ADDR_LEN, pAdvRpt->addr);
//Auto connect is enabled
if (autoConnect)
if (numGroupMembers == MAX_NUM_BLE_CONNS)
GapScan_disable("");
break;
//Check if advertiser is part of the group
if (SimpleCentral_isMember(pAdvRpt->pData , acGroup, GROUP_NAME_LENGTH))
groupListElem_t *tempMember;
//Traverse list to search if advertiser already in list.
for (tempMember = (groupListElem_t *)osal_list_head(&groupList); tempMember != NULL; tempMember = (groupListElem_t *)osal_list_next((osal_list_elem *)tempMember))
if (osal_memcmp((uint8_t *)tempMember->addr ,(uint8_t *)pAdvRpt->addr,B_ADDR_LEN))
break;
//If tempMemer is NULL this meams advertiser not in list.
if (tempMember == NULL)
groupListElem_t *groupMember = (groupListElem_t *)ICall_malloc(sizeof(groupListElem_t));
if (groupMember != NULL)
//Copy member's details into Member's list.
osal_memcpy((uint8_t *)groupMember->addr , (uint8_t *)pAdvRpt->addr,B_ADDR_LEN);
groupMember->addrType = pAdvRpt->addrType;
groupMember->status = GROUP_MEMBER_INITIALIZED;
groupMember->connHandle = GROUP_INITIALIZED_CONNECTION_HANDLE;
//Add group member into list.
osal_list_putHead(&groupList,(osal_list_elem *)groupMember);
numGroupMembers++;
else
Display_printf(dispHandle, SC_ROW_AC, 0, "AutoConnect: Allocation failed!");
break;
if (SimpleCentral_findSvcUuid(SIMPLEPROFILE_SERV_UUID,
pAdvRpt->pData, pAdvRpt->dataLen))
SimpleCentral_addScanInfo(pAdvRpt->addr, pAdvRpt->addrType);
Display_printf(dispHandle, SC_ROW_NON_CONN, 0, "Discovered: %s",
Util_convertBdAddr2Str(pAdvRpt->addr));
#else // !DEFAULT_DEV_DISC_BY_SVC_UUID
// Free report payload data
if (pAdvRpt->pData != NULL)
ICall_free(pAdvRpt->pData);
break;
case SC_EVT_SCAN_ENABLED:
// Disable everything but "Stop Discovering" on the menu
tbm_setItemStatus(&scMenuMain, SC_ITEM_STOPDISC,
(SC_ITEM_ALL & ~SC_ITEM_STOPDISC));
Display_printf(dispHandle, SC_ROW_NON_CONN, 0, "Discovering...");
LED_startBlinking(led_green, 100, LED_BLINK_FOREVER);
break;
case SC_EVT_SCAN_DISABLED:
// Uart_SendMsg(UART_HEADER_STR,14, "scan disabled.");
LED_stopBlinking(led_green);
uint16_t itemsToEnable = SC_ITEM_STARTDISC | SC_ITEM_SCANPHY;
if (osal_list_head(&groupList) == NULL){
SimpleCentral_doDiscoverDevices(0);
return;
if (autoConnect)
itemsToEnable |= SC_ITEM_AUTOCONNECT;
if (numGroupMembers < MAX_NUM_BLE_CONNS)
Display_printf(dispHandle, SC_ROW_AC, 0, "AutoConnect: Not all members found, only %d members were found",numGroupMembers);
else
Display_printf(dispHandle, SC_ROW_AC, 0, "AutoConnect: Number of members in the group %d",numGroupMembers);
SimpleCentral_autoConnect();
if (numConn > 0)
// Also enable "Work with"
itemsToEnable |= SC_ITEM_SELECTCONN;
// Enable "Discover Devices", "Set Scanning PHY", and possibly
// "Connect to" and/or "Work with".
// Disable "Stop Discovering".
tbm_setItemStatus(&scMenuMain, itemsToEnable, SC_ITEM_STOPDISC);
else
uint8_t numReport;
uint8_t i;
static uint8_t* pAddrs = NULL;
uint8_t* pAddrTemp;
numReport = numScanRes;
GapScan_Evt_AdvRpt_t advRpt;
numReport = ((GapScan_Evt_End_t*) (pMsg->pData))->numReport;
"%d devices discovered", numReport);
if (numReport > 0)
// Also enable "Connect to"
itemsToEnable |= SC_ITEM_CONNECT;
if (numConn > 0)
// Allocate buffer to display addresses
if (pAddrs != NULL)
// A scan has been done previously, release the previously allocated buffer
ICall_free(pAddrs);
pAddrs = ICall_malloc(numReport * SC_ADDR_STR_SIZE);
if (pAddrs == NULL)
numReport = 0;
TBM_SET_NUM_ITEM(&scMenuConnect, numReport);
if (pAddrs != NULL)
pAddrTemp = pAddrs;
for (i = 0; i < numReport; i++, pAddrTemp += SC_ADDR_STR_SIZE)
// Get the address from the list, convert it to string, and
// copy the string to the address buffer
memcpy(pAddrTemp, Util_convertBdAddr2Str(scanList[i].addr),
SC_ADDR_STR_SIZE);
// Get the address from the report, convert it to string, and
GapScan_getAdvReport(i, &advRpt);
memcpy(pAddrTemp, Util_convertBdAddr2Str(advRpt.addr),
SC_ADDR_STR_SIZE);
// Assign the string to the corresponding action description of the menu
TBM_SET_ACTION_DESC(&scMenuConnect, i, pAddrTemp);
// Disable any non-active scan results
for (; i < DEFAULT_MAX_SCAN_RES; i++)
tbm_setItemStatus(&scMenuConnect, TBM_ITEM_NONE, (1 << i));
// Note: pAddrs is not freed since it will be used by the two button menu
// to display the discovered address.
// This implies that at least the last discovered addresses
// will be maintained until a new scan is done.
break;
case SC_EVT_SVC_DISC:
// Uart_SendMsg(UART_HEADER_STR, 14, "SC_EVT_SVC_DISC");
SimpleCentral_startSvcDiscovery();
break;
case SC_EVT_READ_RSSI:
uint8_t connIndex = pMsg->hdr.state;
uint16_t connHandle = connList[connIndex].connHandle;
// Uart_SendMsg(UART_HEADER_STR, 16, "SC_EVT_READ_RSSI");
// If link is still valid
if (connHandle != LINKDB_CONNHANDLE_INVALID)
// char ch[] = "Rssi clock started and conindex is 0";
// ch[35] += connIndex;
// Uart_SendMsg(UART_HEADER_STR, 36, ch);
// Restart timer
Util_startClock(connList[connIndex].pRssiClock);
// Uart_SendMsg(UART_HEADER_STR, 11, "111111111111");
// Read RSSI
// VOID HCI_ReadRssiCmd(connHandle);
hciStatus_t rssiStatus = HCI_ReadRssiCmd(connHandle);
// ch[35] = rssiStatus + '0';
break;
// Pairing event
case SC_EVT_PAIR_STATE:
SimpleCentral_processPairState(pMsg->hdr.state,
(scPairStateData_t*) (pMsg->pData));
break;
// Passcode event
case SC_EVT_PASSCODE_NEEDED:
SimpleCentral_processPasscode((scPasscodeData_t *)(pMsg->pData));
break;
case SC_EVT_READ_RPA:
uint8_t* pRpaNew;
// Read the current RPA.
pRpaNew = GAP_GetDevAddress(FALSE);
if (memcmp(pRpaNew, rpa, B_ADDR_LEN))
// If the RPA has changed, update the display
Display_printf(dispHandle, SC_ROW_RPA, 0, "RP Addr: %s",
Util_convertBdAddr2Str(pRpaNew));
memcpy(rpa, pRpaNew, B_ADDR_LEN);
break;
// Insufficient memory
case SC_EVT_INSUFFICIENT_MEM:
// We are running out of memory.
Display_printf(dispHandle, SC_ROW_ANY_CONN, 0, "Insufficient Memory");
// We might be in the middle of scanning, try stopping it.
break;
default:
// Do nothing.
break;
if ((safeToDealloc == TRUE) && (pMsg->pData != NULL))
ICall_free(pMsg->pData);
* @fn SimpleCentral_processGapMsg
* @brief GAP message processing function.
* @param pMsg - pointer to event message structure
* @return none
switch (pMsg->opcode)
case GAP_DEVICE_INIT_DONE_EVENT:
uint8_t temp8;
uint16_t temp16;
gapDeviceInitDoneEvent_t *pPkt = (gapDeviceInitDoneEvent_t *)pMsg;
BLE_LOG_INT_TIME(0, BLE_LOG_MODULE_APP, "APP : ---- got GAP_DEVICE_INIT_DONE_EVENT", 0);
// Setup scanning
// For more information, see the GAP section in the User's Guide:
// http://software-dl.ti.com/lprf/ble5stack-latest/
// Register callback to process Scanner events
GapScan_registerCb(SimpleCentral_scanCb, NULL);
// Set Scanner Event Mask
GapScan_setEventMask(GAP_EVT_SCAN_ENABLED | GAP_EVT_SCAN_DISABLED |
GAP_EVT_ADV_REPORT);
// Set Scan PHY parameters
GapScan_setPhyParams(DEFAULT_SCAN_PHY, DEFAULT_SCAN_TYPE,
DEFAULT_SCAN_INTERVAL, DEFAULT_SCAN_WINDOW);
// Set Advertising report fields to keep
temp16 = ADV_RPT_FIELDS;
GapScan_setParam(SCAN_PARAM_RPT_FIELDS, &temp16);
// Set Scanning Primary PHY
temp8 = DEFAULT_SCAN_PHY;
GapScan_setParam(SCAN_PARAM_PRIM_PHYS, &temp8);
// Set LL Duplicate Filter
temp8 = SCANNER_DUPLICATE_FILTER;
GapScan_setParam(SCAN_PARAM_FLT_DUP, &temp8);
// Set PDU type filter -
// Only 'Connectable' and 'Complete' packets are desired.
// It doesn't matter if received packets are
// whether Scannable or Non-Scannable, whether Directed or Undirected,
// whether Scan_Rsp's or Advertisements, and whether Legacy or Extended.
temp16 = SCAN_FLT_PDU_CONNECTABLE_ONLY | SCAN_FLT_PDU_COMPLETE_ONLY;
BLE_LOG_INT_TIME(0, BLE_LOG_MODULE_APP, "APP : ---- GapScan_setParam", 0);
GapScan_setParam(SCAN_PARAM_FLT_PDU_TYPE, &temp16);
// Set initiating PHY parameters
GapInit_setPhyParam(DEFAULT_INIT_PHY, INIT_PHYPARAM_CONN_INT_MIN,
INIT_PHYPARAM_MIN_CONN_INT);
GapInit_setPhyParam(DEFAULT_INIT_PHY, INIT_PHYPARAM_CONN_INT_MAX,
INIT_PHYPARAM_MAX_CONN_INT);
scMaxPduSize = pPkt->dataPktLen;
// Enable "Discover Devices", "Set Scanning PHY", "AutoConnect" , and "Set Address Type"
// in the main menu
SC_ITEM_STARTDISC | SC_ITEM_SCANPHY | SC_ITEM_AUTOCONNECT, SC_ITEM_NONE);
Display_printf(dispHandle, SC_ROW_NON_CONN, 0, "Initialized");
Display_printf(dispHandle, SC_ROW_NUM_CONN, 0, "Num Conns: %d", numConn);
// Display device address
Display_printf(dispHandle, SC_ROW_IDA, 0, "%s Addr: %s",
(addrMode <= ADDRMODE_RANDOM) ? "Dev" : "ID",
Util_convertBdAddr2Str(pPkt->devAddr));
if (addrMode > ADDRMODE_RANDOM)
// Update the current RPA.
memcpy(rpa, GAP_GetDevAddress(FALSE), B_ADDR_LEN);
Util_convertBdAddr2Str(rpa));
// Create one-shot clock for RPA check event.
Util_constructClock(&clkRpaRead, SimpleCentral_clockHandler,
READ_RPA_PERIOD, 0, true, SC_EVT_READ_RPA);
break;
case GAP_CONNECTING_CANCELLED_EVENT:
// Uart_SendMsg(UART_HEADER_STR, 30, "GAP_CONNECTING_CANCELLED_EVENT");
uint16_t itemsToEnable = SC_ITEM_SCANPHY | SC_ITEM_STARTDISC |
SC_ITEM_CONNECT | SC_ITEM_AUTOCONNECT;
if (autoConnect)
if (memberInProg != NULL)
//Remove node from member's group and free its memory.
osal_list_remove(&groupList, (osal_list_elem *)memberInProg);
ICall_free(memberInProg);
numGroupMembers--;
memberInProg = NULL;
//Keep on connecting to the remaining members in the list
if (numConn > 0)
"Conneting attempt cancelled");
// Enable "Discover Devices", "Connect To", and "Set Scanning PHY"
// and disable everything else.
itemsToEnable, SC_ITEM_ALL & ~itemsToEnable);
break;
case GAP_LINK_ESTABLISHED_EVENT:
uint16_t connHandle = ((gapEstLinkReqEvent_t*) pMsg)->connectionHandle;
uint8_t* pAddr = ((gapEstLinkReqEvent_t*) pMsg)->devAddr;
BLE_LOG_INT_TIME(0, BLE_LOG_MODULE_APP, "APP : ---- got GAP_LINK_ESTABLISHED_EVENT", 0);
// Uart_SendMsg(UART_HEADER_STR,9, "connected");
if (autoConnect)
if (osal_memcmp((uint8_t *)pAddr, (uint8_t *)memberInProg->addr, B_ADDR_LEN))
//Move the connected member to the tail of the list.
osal_list_remove(&groupList,(osal_list_elem *)memberInProg);
osal_list_put(&groupList,(osal_list_elem *)memberInProg);
//Set the connected bit.;
memberInProg->status |= GROUP_MEMBER_CONNECTED;
//Store the connection handle.
memberInProg->connHandle = connHandle;
uint8_t connIndex;
uint32_t itemsToDisable = SC_ITEM_STOPDISC | SC_ITEM_CANCELCONN;
uint8_t* pStrAddr;
uint8_t i;
uint8_t numConnectable = 0;
uint8_t pairMode = 0;
// Add this connection info to the list
connIndex = SimpleCentral_addConnInfo(connHandle, pAddr);
// connIndex cannot be equal to or greater than MAX_NUM_BLE_CONNS
SIMPLECENTRAL_ASSERT(connIndex < MAX_NUM_BLE_CONNS);
connList[connIndex].charHandle = 0;
pStrAddr = (uint8_t*) Util_convertBdAddr2Str(connList[connIndex].addr);
Display_printf(dispHandle, SC_ROW_NON_CONN, 0, "Connected to %s", pStrAddr);
// Disable "Connect To" until another discovery is performed
itemsToDisable |= SC_ITEM_CONNECT;
// If we already have maximum allowed number of connections,
// disable device discovery and additional connection making.
if (numConn >= MAX_NUM_BLE_CONNS)
itemsToDisable |= SC_ITEM_SCANPHY | SC_ITEM_STARTDISC;
for (i = 0; i < TBM_GET_NUM_ITEM(&scMenuConnect); i++)
if (!memcmp(TBM_GET_ACTION_DESC(&scMenuConnect, i), pStrAddr,
SC_ADDR_STR_SIZE))
// Disable this device from the connection choices
tbm_setItemStatus(&scMenuConnect, SC_ITEM_NONE, 1 << i);
else if (TBM_IS_ITEM_ACTIVE(&scMenuConnect, i))
numConnectable++;
// Enable/disable Main menu items properly
SC_ITEM_ALL & ~(itemsToDisable), itemsToDisable);
GAPBondMgr_GetParameter(GAPBOND_PAIRING_MODE, &pairMode);
if ((autoConnect) && (pairMode != GAPBOND_PAIRING_MODE_INITIATE))
// Uart_SendMsg(UART_HEADER_STR,20, "What are you doing1?");
scConnHandle = connHandle;
// SimpleCentral_autoConnect();
// SimpleCentral_doRssiRead(2);
break;
case GAP_LINK_TERMINATED_EVENT:
LED_setOff(led_green);
// Uart_SendMsg(UART_HEADER_STR, 15, "link terminated.");
uint8_t connIndex;
BLE_LOG_INT_STR(0, BLE_LOG_MODULE_APP, "APP : GAP msg status=%d, opcode=%s\n", 0, "GAP_LINK_TERMINATED_EVENT");
uint32_t itemsToEnable = SC_ITEM_STARTDISC | SC_ITEM_SCANPHY | SC_ITEM_AUTOCONNECT;
uint8_t* pStrAddr;
uint8_t i;
uint16_t connHandle = ((gapTerminateLinkEvent_t*) pMsg)->connectionHandle;
if (autoConnect)
//Traverse from tail to head because of the sorting which put the connected at the end of the list.
for (tempMember = (groupListElem_t *)osal_list_tail(&groupList); tempMember != NULL; tempMember = (groupListElem_t *)osal_list_prev((osal_list_elem *)tempMember))
if (tempMember->connHandle == connHandle)
//Move disconnected member to the head of the list for next connection.
osal_list_remove(&groupList,(osal_list_elem *)tempMember);
osal_list_putHead(&groupList,(osal_list_elem *)tempMember);
//Clear the connected flag.
tempMember->status &= ~GROUP_MEMBER_CONNECTED;
//Clear the connnection handle.
tempMember->connHandle = GROUP_INITIALIZED_CONNECTION_HANDLE;
// Cancel timers
SimpleCentral_CancelRssi(connHandle);
// Mark this connection deleted in the connected device list.
connIndex = SimpleCentral_removeConnInfo(connHandle);
if (autoConnect)
// Uart_SendMsg(UART_HEADER_STR,20, "What are you doing2?");
Display_printf(dispHandle, SC_ROW_NON_CONN, 0, "%s is disconnected",
pStrAddr);
SC_ADDR_STR_SIZE))
// Enable this device in the connection choices
tbm_setItemStatus(&scMenuConnect, 1 << i, SC_ITEM_NONE);
numConnectable++;
if (numConn > 0)
// There still is an active connection to select
// Enable/disable items properly.
// If we are in the context which the teminated connection was associated
// with, go to main menu.
if (connHandle == scConnHandle)
tbm_goTo(&scMenuMain);
break;
case GAP_UPDATE_LINK_PARAM_REQ_EVENT:
// Uart_SendMsg(UART_HEADER_STR, 31, "GAP_UPDATE_LINK_PARAM_REQ_EVENT");
gapUpdateLinkParamReqReply_t rsp;
gapUpdateLinkParamReq_t *pReq;
pReq = &((gapUpdateLinkParamReqEvent_t *)pMsg)->req;
rsp.connectionHandle = pReq->connectionHandle;
rsp.signalIdentifier = pReq->signalIdentifier;
if (acceptParamUpdateReq)
rsp.intervalMin = pReq->intervalMin;
rsp.intervalMax = pReq->intervalMax;
rsp.connLatency = pReq->connLatency;
rsp.connTimeout = pReq->connTimeout;
rsp.accepted = TRUE;
else
// Reject the request.
rsp.accepted = FALSE;
// Send Reply
VOID GAP_UpdateLinkParamReqReply(&rsp);
if (autoConnect)
// Uart_SendMsg(UART_HEADER_STR,20, "What are you doing3?");
break;
case GAP_LINK_PARAM_UPDATE_EVENT:
// Uart_SendMsg(UART_HEADER_STR, 27, "GAP_LINK_PARAM_UPDATE_EVENT");
gapLinkUpdateEvent_t *pPkt = (gapLinkUpdateEvent_t *)pMsg;
// Get the address from the connection handle
linkDBInfo_t linkInfo;
BLE_LOG_INT_STR(0, BLE_LOG_MODULE_APP, "APP : GAP msg status=%d, opcode=%s\n", 0, "GAP_LINK_PARAM_UPDATE_EVENT");
if (linkDB_GetInfo(pPkt->connectionHandle, &linkInfo) == SUCCESS)
if(pPkt->status == SUCCESS)
"Updated: %s, connTimeout:%d",
Util_convertBdAddr2Str(linkInfo.addr),
linkInfo.connTimeout*CONN_TIMEOUT_MS_CONVERSION);
else
// Display the address of the connection update failure
"Update Failed 0x%h: %s", pPkt->opcode,
Util_convertBdAddr2Str(linkInfo.addr));
if (autoConnect)
// Uart_SendMsg(UART_HEADER_STR,20, "What are you doing4?");
break;
#if defined ( NOTIFY_PARAM_UPDATE_RJCT )
case GAP_LINK_PARAM_UPDATE_REJECT_EVENT:
linkDB_GetInfo(pPkt->connectionHandle, &linkInfo);
"Peer Device's Update Request Rejected 0x%h: %s", pPkt->opcode,
break;
#endif
default:
break;
* @fn SimpleCentral_handleKeys
* @brief Handles all key events for this device.
* @param keys - bit field for key events. Valid entries:
* KEY_LEFT
* KEY_RIGHT
* @return none
if (keys & KEY_LEFT)
// Check if the key is still pressed. Workaround for possible bouncing.
if (GPIO_read(CONFIG_GPIO_BTN1) == 0)
tbm_buttonLeft();
else if (keys & KEY_RIGHT)
if (GPIO_read(CONFIG_GPIO_BTN2) == 0)
tbm_buttonRight();
* @fn SimpleCentral_processGATTMsg
* @brief Process GATT messages and events.
* @return none
if (linkDB_Up(pMsg->connHandle))
// See if GATT server was unable to transmit an ATT response
if (pMsg->hdr.status == blePending)
// Uart_SendMsg(UART_HEADER_STR, 20, "GATTMsg() -> Pending");
// No HCI buffer was available. App can try to retransmit the response
// on the next connection event. Drop it for now.
"ATT Rsp dropped %d", pMsg->method);
else if ((pMsg->method == ATT_READ_RSP) ||
((pMsg->method == ATT_ERROR_RSP) &&
(pMsg->msg.errorRsp.reqOpcode == ATT_READ_REQ)))
if (pMsg->method == ATT_ERROR_RSP)
// Uart_SendMsg(UART_HEADER_STR, 23, "GATTMsg() -> Read Error");
"Read Error %d", pMsg->msg.errorRsp.errCode);
else
// Uart_SendMsg(UART_HEADER_STR, 21, "GATTMsg() -> Read rsp");
// After a successful read, display the read value
"Read rsp: 0x%02x", pMsg->msg.readRsp.pValue[0]);
else if ((pMsg->method == ATT_WRITE_RSP) ||
(pMsg->msg.errorRsp.reqOpcode == ATT_WRITE_REQ)))
"Write Error %d", pMsg->msg.errorRsp.errCode);
// Uart_SendMsg(UART_HEADER_STR, 24, "GATTMsg() -> Write Error");
else
// After a successful write, display the value that was written and
// increment value
"Write sent: 0x%02x", charVal);
// Uart_SendMsg(UART_HEADER_STR, 23, "GATTMsg() -> Write sent");
tbm_goTo(&scMenuPerConn);
else if (pMsg->method == ATT_FLOW_CTRL_VIOLATED_EVENT)
// ATT request-response or indication-confirmation flow control is
// violated. All subsequent ATT requests or indications will be dropped.
// The app is informed in case it wants to drop the connection.
// Display the opcode of the message that caused the violation.
"FC Violated: %d", pMsg->msg.flowCtrlEvt.opcode);
// Uart_SendMsg(UART_HEADER_STR, 24, "GATTMsg() -> FC Violated");
else if (pMsg->method == ATT_MTU_UPDATED_EVENT)
// MTU size updated
"MTU Size: %d", pMsg->msg.mtuEvt.MTU);
// Uart_SendMsg(UART_HEADER_STR, 21, "GATTMsg() -> MTU Size");
}else if(pMsg->method == ATT_HANDLE_VALUE_NOTI){
LED_write(led_red, led_red_status);
// Uart_SendMsg(UART_HEADER_STR, 19, "GATTMsg() -> NOTIFY");
// Uart_SendMsg(UART_HEADER_HEX, pMsg->msg.handleValueNoti.len, pMsg->msg.handleValueNoti.pValue);
else if (discState != BLE_DISC_STATE_IDLE)
SimpleCentral_processGATTDiscEvent(pMsg);
} // else - in case a GATT message came after a connection has dropped, ignore it.
// Needed only for ATT Protocol messages
GATT_bm_free(&pMsg->msg, pMsg->method);
* @fn SimpleCentral_processCmdCompleteEvt
* @brief Process an incoming OSAL HCI Command Complete Event.
* @return none
switch (pMsg->cmdOpcode)
case HCI_READ_RSSI:
uint16_t connHandle = BUILD_UINT16(pMsg->pReturnParam[1],
pMsg->pReturnParam[2]);
int8 rssi = (int8)pMsg->pReturnParam[3];
// char *str = "Rssi is 0";
// str[8] += rssi;
// Uart_SendMsg(UART_HEADER_STR,9, str);
Display_printf(dispHandle, SC_ROW_ANY_CONN, 0, "%s: RSSI %d dBm",
SimpleCentral_getConnAddrStr(connHandle), rssi);
#endif
break;
default:
break;
* @fn SimpleCentral_StartRssi
* @brief Start periodic RSSI reads on the current link.
* @return SUCCESS: RSSI Read timer started
* bleIncorrectMode: Aready started
* bleNoResources: No resources
static status_t SimpleCentral_StartRssi(void)
// Uart_SendMsg(UART_HEADER_STR, 26, "SimpleCentral_StartRssi()");
uint8_t connIndex = SimpleCentral_getConnIndex(scConnHandle);
// char *str = "The index of connection is 0";
// str[27] += connIndex;
// Uart_SendMsg(UART_HEADER_STR,28, str);
// Uart_SendMsg(UART_HEADER_STR, 31, "SimpleCentral_StartRssi() exit");
// If already running
if (connList[connIndex].pRssiClock != NULL)
return bleIncorrectMode;
// Create a clock object and start
= (Clock_Struct*) ICall_malloc(sizeof(Clock_Struct));
if (connList[connIndex].pRssiClock)
Util_constructClock(connList[connIndex].pRssiClock,
DEFAULT_RSSI_PERIOD, 0, true,
(connIndex << 8) | SC_EVT_READ_RSSI);
else
return bleNoResources;
return SUCCESS;
* @fn SimpleCentral_CancelRssi
* @brief Cancel periodic RSSI reads on a link.
* @param connection handle
* @return SUCCESS: Operation successful
* bleIncorrectMode: Has not started
// Uart_SendMsg(UART_HEADER_STR, 27, "SimpleCentral_CancelRssi()");
uint8_t connIndex = SimpleCentral_getConnIndex(connHandle);
if (connList[connIndex].pRssiClock == NULL)
// Stop timer
Util_stopClock(connList[connIndex].pRssiClock);
// Destroy the clock object
Clock_destruct(connList[connIndex].pRssiClock);
// Free clock struct
ICall_free(connList[connIndex].pRssiClock);
connList[connIndex].pRssiClock = NULL;
Display_clearLine(dispHandle, SC_ROW_ANY_CONN);
// Uart_SendMsg(UART_HEADER_STR, 32, "SimpleCentral_CancelRssi() exit");
return SUCCESS;
* @fn SimpleCentral_processPairState
* @brief Process the new paring state.
* @return none
scPairStateData_t* pPairData)
// Uart_SendMsg(UART_HEADER_STR, 33, "SimpleCentral_processPairState()");
uint8_t status = pPairData->status;
if (state == GAPBOND_PAIRING_STATE_STARTED)
Display_printf(dispHandle, SC_ROW_CUR_CONN, 0, "Pairing started");
else if (state == GAPBOND_PAIRING_STATE_COMPLETE)
if (status == SUCCESS)
Display_printf(dispHandle, SC_ROW_CUR_CONN, 0, "Pairing success");
if (linkDB_GetInfo(pPairData->connHandle, &linkInfo) == SUCCESS)
// If the peer was using private address, update with ID address
if ((linkInfo.addrType == ADDRTYPE_PUBLIC_ID ||
linkInfo.addrType == ADDRTYPE_RANDOM_ID) &&
!Util_isBufSet(linkInfo.addrPriv, 0, B_ADDR_LEN))
// Update the address of the peer to the ID address
Display_printf(dispHandle, SC_ROW_NON_CONN, 0, "Addr updated: %s",
// Update the connection list with the ID address
uint8_t i = SimpleCentral_getConnIndex(pPairData->connHandle);
SIMPLECENTRAL_ASSERT(i < MAX_NUM_BLE_CONNS);
memcpy(connList[i].addr, linkInfo.addr, B_ADDR_LEN);
else
Display_printf(dispHandle, SC_ROW_CUR_CONN, 0, "Pairing fail: %d", status);
if ((autoConnect) && (pairMode == GAPBOND_PAIRING_MODE_INITIATE))
else if (state == GAPBOND_PAIRING_STATE_ENCRYPTED)
Display_printf(dispHandle, SC_ROW_CUR_CONN, 0, "Encryption success");
else
Display_printf(dispHandle, SC_ROW_CUR_CONN, 0, "Encryption failed: %d", status);
else if (state == GAPBOND_PAIRING_STATE_BOND_SAVED)
Display_printf(dispHandle, SC_ROW_CUR_CONN, 0, "Bond save success");
else
Display_printf(dispHandle, SC_ROW_CUR_CONN, 0, "Bond save failed: %d", status);
// Uart_SendMsg(UART_HEADER_STR, 38, "SimpleCentral_processPairState() exit");
* @fn SimpleCentral_processPasscode
* @brief Process the Passcode request.
* @return none
// Display passcode to user
if (pData->uiOutputs != 0)
Display_printf(dispHandle, SC_ROW_CUR_CONN, 0, "Passcode: %d",
B_APP_DEFAULT_PASSCODE);
// Send passcode response
GAPBondMgr_PasscodeRsp(pData->connHandle, SUCCESS, B_APP_DEFAULT_PASSCODE);
* @fn SimpleCentral_startSvcDiscovery
* @brief Start service discovery.
* @return none
attExchangeMTUReq_t req;
// Initialize cached handles
svcStartHdl = svcEndHdl = 0;
discState = BLE_DISC_STATE_MTU;
// Discover GATT Server's Rx MTU size
req.clientRxMTU = scMaxPduSize - L2CAP_HDR_SIZE;
// ATT MTU size should be set to the minimum of the Client Rx MTU
// and Server Rx MTU values
bStatus_t res = GATT_ExchangeMTU(scConnHandle, &req, selfEntity);
LED_setOn(led_red, 100);
// if(res == SUCCESS){
// Uart_SendMsg(UART_HEADER_STR, 19, "ExchangeMTU SUCCESS");
// }else{
// uint8_t res_p[] = {0x00, 0x11, 0x22, 0x33};
// res_p[3] = res;
// Uart_SendMsg(UART_HEADER_HEX, 4, res_p);
* @fn SimpleCentral_processGATTDiscEvent
* @brief Process GATT discovery event
* @return none
if (discState == BLE_DISC_STATE_MTU)
// Uart_SendMsg(UART_HEADER_STR, 20, "GATTDiscEvent -> MTU");
// MTU size response received, discover simple service
if (pMsg->method == ATT_EXCHANGE_MTU_RSP)
uint8_t uuid[ATT_BT_UUID_SIZE] = { LO_UINT16(SIMPLEPROFILE_SERV_UUID),
HI_UINT16(SIMPLEPROFILE_SERV_UUID) };
discState = BLE_DISC_STATE_SVC;
// Discovery simple service
// VOID GATT_DiscPrimaryServiceByUUID(pMsg->connHandle, uuid,
// ATT_BT_UUID_SIZE, selfEntity);
bStatus_t res = GATT_DiscPrimaryServiceByUUID(pMsg->connHandle, uuid,
}else{
// Uart_SendMsg(UART_HEADER_STR, 23+4, "GATTDiscEvent -> MTU : None");
else if (discState == BLE_DISC_STATE_SVC)
// Uart_SendMsg(UART_HEADER_STR, 20, "GATTDiscEvent -> SVC");
// Service found, store handles
if (pMsg->method == ATT_FIND_BY_TYPE_VALUE_RSP &&
pMsg->msg.findByTypeValueRsp.numInfo > 0)
svcStartHdl = ATT_ATTR_HANDLE(pMsg->msg.findByTypeValueRsp.pHandlesInfo, 0);
svcEndHdl = ATT_GRP_END_HANDLE(pMsg->msg.findByTypeValueRsp.pHandlesInfo, 0);
// If procedure complete
if (((pMsg->method == ATT_FIND_BY_TYPE_VALUE_RSP) &&
(pMsg->hdr.status == bleProcedureComplete)) ||
(pMsg->method == ATT_ERROR_RSP))
if (svcStartHdl != 0)
attReadByTypeReq_t req;
// Discover characteristic
discState = BLE_DISC_STATE_CHAR;
req.startHandle = svcStartHdl;
req.endHandle = svcEndHdl;
req.type.len = ATT_BT_UUID_SIZE;
req.type.uuid[0] = LO_UINT16(SIMPLEPROFILE_CHAR1_UUID);
req.type.uuid[1] = HI_UINT16(SIMPLEPROFILE_CHAR1_UUID);
VOID GATT_DiscCharsByUUID(pMsg->connHandle, &req, selfEntity);
else if (discState == BLE_DISC_STATE_CHAR)
// Uart_SendMsg(UART_HEADER_STR, 21, "GATTDiscEvent -> CHAR");
// Characteristic found, store handle
if ((pMsg->method == ATT_READ_BY_TYPE_RSP) &&
(pMsg->msg.readByTypeRsp.numPairs > 0))
// Store the handle of the simpleprofile characteristic 1 value
= BUILD_UINT16(pMsg->msg.readByTypeRsp.pDataList[3],
pMsg->msg.readByTypeRsp.pDataList[4]);
Display_printf(dispHandle, SC_ROW_CUR_CONN, 0, "Simple Svc Found");
// Now we can use GATT Read/Write
tbm_setItemStatus(&scMenuPerConn,
SC_ITEM_GATTREAD | SC_ITEM_GATTWRITE, SC_ITEM_NONE);
* @fn SimpleCentral_findSvcUuid
* @brief Find a given UUID in an advertiser's service UUID list.
* @return TRUE if service UUID found
uint16_t dataLen)
uint8_t adLen;
uint8_t adType;
uint8_t *pEnd;
if (dataLen > 0)
pEnd = pData + dataLen - 1;
// While end of data not reached
while (pData < pEnd)
// Get length of next AD item
adLen = *pData++;
if (adLen > 0)
adType = *pData;
// If AD type is for 16-bit service UUID
if ((adType == GAP_ADTYPE_16BIT_MORE) ||
(adType == GAP_ADTYPE_16BIT_COMPLETE))
pData++;
adLen--;
// For each UUID in list
while (adLen >= 2 && pData < pEnd)
// Check for match
if ((pData[0] == LO_UINT16(uuid)) && (pData[1] == HI_UINT16(uuid)))
// Match found
return TRUE;
// Go to next
pData += 2;
adLen -= 2;
// Handle possible erroneous extra byte in UUID list
if (adLen == 1)
pData++;
else
// Go to next item
pData += adLen;
// Match not found
return FALSE;
* @fn SimpleCentral_addScanInfo
* @brief Add a device to the scanned device list
* @return none
uint8_t i;
// If result count not at max
if (numScanRes < DEFAULT_MAX_SCAN_RES)
// Check if device is already in scan results
for (i = 0; i < numScanRes; i++)
if (memcmp(pAddr, scanList[i].addr , B_ADDR_LEN) == 0)
return;
// Add addr to scan result list
memcpy(scanList[numScanRes].addr, pAddr, B_ADDR_LEN);
scanList[numScanRes].addrType = addrType;
// Increment scan result count
numScanRes++;
* @fn SimpleCentral_addConnInfo
* @brief Add a device to the connected device list
* @return index of the connected device list entry where the new connection
* info is put in.
* if there is no room, MAX_NUM_BLE_CONNS will be returned.
uint8_t i;
if (connList[i].connHandle == LINKDB_CONNHANDLE_INVALID)
// Found available entry to put a new connection info in
connList[i].connHandle = connHandle;
memcpy(connList[i].addr, pAddr, B_ADDR_LEN);
numConn++;
break;
return i;
* @fn SimpleCentral_removeConnInfo
* @brief Remove a device from the connected device list
* info is removed from.
* if connHandle is not found, MAX_NUM_BLE_CONNS will be returned.
uint8_t i;
if (connList[i].connHandle == connHandle)
// Found the entry to mark as deleted
numConn--;
break;
return i;
* @fn SimpleCentral_getConnIndex
* @brief Find index in the connected device list by connHandle
* @return the index of the entry that has the given connection handle.
* if there is no match, MAX_NUM_BLE_CONNS will be returned.
uint8_t i;
break;
// Uart_SendMsg(UART_HEADER_STR, 20, "Get connection index");
// str1[13] = i + '0';
return i;
* @fn SimpleCentral_getConnAddrStr
* @brief Return, in string form, the address of the peer associated with
* the connHandle.
* @return A null-terminated string of the address.
* if there is no match, NULL will be returned.
uint8_t i;
return Util_convertBdAddr2Str(connList[i].addr);
return NULL;
#endif
* @fn SimpleCentral_pairStateCb
* @brief Pairing state callback.
* @return none
uint8_t status)
scPairStateData_t *pData;
// Allocate space for the event data.
if ((pData = ICall_malloc(sizeof(scPairStateData_t))))
pData->connHandle = connHandle;
pData->status = status;
// Queue the event.
if(SimpleCentral_enqueueMsg(SC_EVT_PAIR_STATE, state, (uint8_t*) pData) != SUCCESS)
ICall_free(pData);
* @fn SimpleCentral_passcodeCb
* @brief Passcode callback.
* @param deviceAddr - pointer to device address
* @param connHandle - the connection handle
* @param uiInputs - pairing User Interface Inputs
* @param uiOutputs - pairing User Interface Outputs
* @param numComparison - numeric Comparison 20 bits
* @return none
scPasscodeData_t *pData = ICall_malloc(sizeof(scPasscodeData_t));
// Allocate space for the passcode event.
if (pData)
memcpy(pData->deviceAddr, deviceAddr, B_ADDR_LEN);
pData->uiInputs = uiInputs;
pData->uiOutputs = uiOutputs;
pData->numComparison = numComparison;
// Enqueue the event.
if (SimpleCentral_enqueueMsg(SC_EVT_PASSCODE_NEEDED, 0,(uint8_t *) pData) != SUCCESS)
ICall_free(pData);
* @fn SimpleCentral_keyChangeHandler
* @brief Key event handler function
* @param a0 - ignored
* @return none
SimpleCentral_enqueueMsg(SC_EVT_KEY_CHANGE, keys, NULL);
* @fn SimpleCentral_clockHandler
* @brief clock handler function
* @param arg - argument from the clock initiator
* @return none
uint8_t evtId = (uint8_t) (arg & 0xFF);
switch (evtId)
SimpleCentral_enqueueMsg(SC_EVT_READ_RSSI, (uint8_t) (arg >> 8) , NULL);
break;
// Restart timer
Util_startClock(&clkRpaRead);
// Let the application handle the event
SimpleCentral_enqueueMsg(SC_EVT_READ_RPA, 0, NULL);
break;
case SC_EVT_UART_WRITE:
Event_post(syncEvent, SC_UART_EVT);
break;
case SC_EVT_START_DISCOVERY:
SimpleCentral_enqueueMsg(SC_EVT_SVC_DISC, 0, NULL);
default:
break;
* @fn SimpleCentral_enqueueMsg
* @brief Creates a message and puts the message in RTOS queue.
* @param event - message event.
* @param state - message state.
* @param pData - message data pointer.
* @return TRUE or FALSE
static status_t SimpleCentral_enqueueMsg(uint8_t event, uint8_t state,
uint8_t *pData)
uint8_t success;
scEvt_t *pMsg = ICall_malloc(sizeof(scEvt_t));
// Create dynamic pointer to message.
if (pMsg)
pMsg->hdr.event = event;
pMsg->hdr.state = state;
pMsg->pData = pData;
// Enqueue the message.
success = Util_enqueueMsg(appMsgQueue, syncEvent, (uint8_t *)pMsg);
return (success) ? SUCCESS : FAILURE;
return(bleMemAllocError);
* @fn SimpleCentral_scanCb
* @brief Callback called by GapScan module
* @param evt - event
* @param msg - message coming with the event
* @param arg - user argument
* @return none
void SimpleCentral_scanCb(uint32_t evt, void* pMsg, uintptr_t arg)
uint8_t event;
if (evt & GAP_EVT_ADV_REPORT)
event = SC_EVT_ADV_REPORT;
else if (evt & GAP_EVT_SCAN_ENABLED)
event = SC_EVT_SCAN_ENABLED;
else if (evt & GAP_EVT_SCAN_DISABLED)
event = SC_EVT_SCAN_DISABLED;
else if (evt & GAP_EVT_INSUFFICIENT_MEMORY)
event = SC_EVT_INSUFFICIENT_MEM;
else
return;
if(SimpleCentral_enqueueMsg(event, SUCCESS, pMsg) != SUCCESS)
ICall_free(pMsg);
* @fn SimpleCentral_doAutoConnect
* @brief Enable/Disable AutoConnect.
* @param index - 0 : Disable AutoConnect
* 1 : Enable Group A
* 2 : Enable Group B
* @return always true
bool SimpleCentral_doAutoConnect(uint8_t index)
if (index == 1)
if ((autoConnect) && (autoConnect != AUTOCONNECT_GROUP_A))
Display_printf(dispHandle, SC_ROW_AC, 0, "AutoConnect enabled: Group A");
acGroup[3] = 'A';
else if (index == 2)
if ((autoConnect) && (autoConnect != AUTOCONNECT_GROUP_B))
Display_printf(dispHandle, SC_ROW_AC, 0, "AutoConnect enabled: Group B");
autoConnect = AUTOCONNECT_GROUP_B;
acGroup[3] = 'B';
else
autoConnect = AUTOCONNECT_DISABLE;
Display_printf(dispHandle, SC_ROW_AC, 0, "AutoConnect disabled");
if ((autoConnect) && (MAX_NUM_BLE_CONNS > 8))
//Disable accepting L2CAP param upadte request
acceptParamUpdateReq = false;
//Disable all parameter update requests
GAP_SetParamValue(GAP_PARAM_LINK_UPDATE_DECISION, GAP_UPDATE_REQ_DENY_ALL);
//Set connection interval and supervision timeout
GapInit_setPhyParam(INIT_PHY_1M | INIT_PHY_2M | INIT_PHY_CODED,INIT_PHYPARAM_CONN_INT_MAX,DEFAULT_MULTICON_INTERVAL);
GapInit_setPhyParam(INIT_PHY_1M | INIT_PHY_2M | INIT_PHY_CODED,INIT_PHYPARAM_CONN_INT_MIN,DEFAULT_MULTICON_INTERVAL);
GapInit_setPhyParam(INIT_PHY_1M | INIT_PHY_2M | INIT_PHY_CODED,INIT_PHYPARAM_SUP_TIMEOUT,DEFAULT_MULTICON_LSTO);
return (true);
* @fn SimpleCentral_doSetScanPhy
* @brief Set PHYs for scanning.
* @param index - 0: 1M PHY
* 1: CODED PHY (Long range)
bool SimpleCentral_doSetScanPhy(uint8_t index)
uint8_t temp8;
if (index == 0)
temp8 = SCAN_PRIM_PHY_1M;
else
temp8 = SCAN_PRIM_PHY_CODED;
// Set scanning primary PHY
Display_printf(dispHandle, SC_ROW_NON_CONN, 0, "Primary Scan PHY: %s",
TBM_GET_ACTION_DESC(&scMenuScanPhy, index));
return (true);
* @fn SimpleCentral_doDiscoverDevices
* @brief Enables scanning
* @param index - item index from the menu
bool SimpleCentral_doDiscoverDevices(uint8_t index)
(void) index;
// Scanning for DEFAULT_SCAN_DURATION x 10 ms.
// The stack does not need to record advertising reports
// since the application will filter them by Service UUID and save.
// Reset number of scan results to 0 before starting scan
numScanRes = 0;
GapScan_enable(0, DEFAULT_SCAN_DURATION, 0);
// Let the stack record the advertising reports as many as up to DEFAULT_MAX_SCAN_RES.
GapScan_enable(0, DEFAULT_SCAN_DURATION, DEFAULT_MAX_SCAN_RES);
// Enable only "Stop Discovering" and disable all others in the main menu
return (true);
* @fn SimpleCentral_doStopDiscovering
* @brief Stop on-going scanning
bool SimpleCentral_doStopDiscovering(uint8_t index)
(void) index;
return (true);
* @fn SimpleCentral_doEstablishLink
* @brief Establish a link to a peer device
bool SimpleCentral_doConnect(uint8_t index)
GapInit_connect(scanList[index].addrType & MASK_ADDRTYPE_ID,
scanList[index].addr, DEFAULT_INIT_PHY, 0);
GapScan_getAdvReport(index, &advRpt);
GapInit_connect(advRpt.addrType & MASK_ADDRTYPE_ID,
advRpt.addr, DEFAULT_INIT_PHY, 0);
// Enable only "Cancel Connecting" and disable all others in the main menu
tbm_setItemStatus(&scMenuMain, SC_ITEM_CANCELCONN,
(SC_ITEM_ALL & ~SC_ITEM_CANCELCONN));
Display_printf(dispHandle, SC_ROW_NON_CONN, 0, "Connecting...");
return (true);
* @fn SimpleCentral_doCancelConnecting
* @brief Cancel on-going connection attempt
bool SimpleCentral_doCancelConnecting(uint8_t index)
(void) index;
// Uart_SendMsg(UART_HEADER_STR, 15, "CancelConnecting");
GapInit_cancelConnect("");
return (true);
* @fn SimpleCentral_doSelectConn
* @brief Select a connection to communicate with
bool SimpleCentral_doSelectConn(uint8_t index)
uint32_t itemsToDisable = SC_ITEM_NONE;
// index cannot be equal to or greater than MAX_NUM_BLE_CONNS
SIMPLECENTRAL_ASSERT(index < MAX_NUM_BLE_CONNS);
scConnHandle = connList[index].connHandle;
if (connList[index].charHandle == 0)
// Initiate service discovery
// Diable GATT Read/Write until simple service is found
itemsToDisable = SC_ITEM_GATTREAD | SC_ITEM_GATTWRITE;
// Set the menu title and go to this connection's context
TBM_SET_TITLE(&scMenuPerConn, TBM_GET_ACTION_DESC(&scMenuSelectConn, index));
// Set RSSI items properly depending on current state
if (connList[index].pRssiClock == NULL)
SC_ITEM_STRTRSSI, SC_ITEM_STOPRSSI | itemsToDisable);
else
SC_ITEM_STOPRSSI, SC_ITEM_STRTRSSI | itemsToDisable);
// Clear non-connection-related message
Display_clearLine(dispHandle, SC_ROW_NON_CONN);
return (true);
* @fn SimpleCentral_doGattRead
* @brief GATT Read
bool SimpleCentral_doGattRead(uint8_t index)
attReadReq_t req;
// Uart_SendMsg(UART_HEADER_STR, 27, "SimpleCentral_doGattRead()");
req.handle = connList[connIndex].charHandle;
GATT_ReadCharValue(scConnHandle, &req, selfEntity);
// Uart_SendMsg(UART_HEADER_STR, 32, "SimpleCentral_doGattRead() exit");
return (true);
* @fn SimpleCentral_doGattWrite
* @brief GATT Write
bool SimpleCentral_doGattWrite(uint8_t index)
// Uart_SendMsg(UART_HEADER_STR, 28, "SimpleCentral_doGattWrite()");
status_t status;
uint8_t charVals[4] = { 0x00, 0x55, 0xAA, 0xFF }; // Should be consistent with
// those in scMenuGattWrite
attWriteReq_t req;
req.pValue = GATT_bm_alloc(scConnHandle, ATT_WRITE_REQ, 1, NULL);
if ( req.pValue != NULL )
req.len = 1;
charVal = charVals[index];
req.pValue[0] = charVal;
req.sig = 0;
req.cmd = 0;
status = GATT_WriteCharValue(scConnHandle, &req, selfEntity);
if ( status != SUCCESS )
GATT_bm_free((gattMsg_t *)&req, ATT_WRITE_REQ);
// Uart_SendMsg(UART_HEADER_STR, 33, "SimpleCentral_doGattWrite() exit");
return (true);
* @fn SimpleCentral_doRssiRead
* @brief Toggle RSSI Read
bool SimpleCentral_doRssiRead(uint8_t index)
status_t status;
if ((1 << index) == SC_ITEM_STRTRSSI)
// Uart_SendMsg(UART_HEADER_STR,18, "Start to read rssi");
if ((status = SimpleCentral_StartRssi()) == SUCCESS)
// Uart_SendMsg(UART_HEADER_STR,17, "Rssi read started");
tbm_setItemStatus(&scMenuPerConn, SC_ITEM_STOPRSSI, SC_ITEM_STRTRSSI);
}else{
// Uart_SendMsg(UART_HEADER_STR,16, "Rssi read failed");
else // SC_ITEM_STOP_RSSI
// Uart_SendMsg(UART_HEADER_STR,17, "Stop reading rssi");
if ((status = SimpleCentral_CancelRssi(scConnHandle)) == SUCCESS)
tbm_setItemStatus(&scMenuPerConn, SC_ITEM_STRTRSSI, SC_ITEM_STOPRSSI);
return ((status == SUCCESS) ? true : false);
* @fn SimpleCentral_doConnUpdate
* @brief Initiate Connection Update procedure
bool SimpleCentral_doConnUpdate(uint8_t index)
gapUpdateLinkParamReq_t params;
(void) index;
params.connectionHandle = scConnHandle;
params.intervalMin = DEFAULT_UPDATE_MIN_CONN_INTERVAL;
params.intervalMax = DEFAULT_UPDATE_MAX_CONN_INTERVAL;
params.connLatency = DEFAULT_UPDATE_SLAVE_LATENCY;
if (linkDB_GetInfo(scConnHandle, &linkInfo) == SUCCESS)
if (linkInfo.connTimeout == DEFAULT_UPDATE_CONN_TIMEOUT)
params.connTimeout = DEFAULT_UPDATE_CONN_TIMEOUT + 200;
else
params.connTimeout = DEFAULT_UPDATE_CONN_TIMEOUT;
GAP_UpdateLinkParamReq(¶ms);
Display_printf(dispHandle, SC_ROW_CUR_CONN, 0, "Param update Request:connTimeout =%d",
params.connTimeout*CONN_TIMEOUT_MS_CONVERSION);
else
"update :%s, Unable to find link information",
return (true);
* @fn SimpleCentral_doSetConnPhy
* @brief Set Connection PHY preference.
* 1: 2M PHY
* 2: 1M + 2M PHY
* 3: CODED PHY (Long range)
* 4: 1M + 2M + CODED PHY
bool SimpleCentral_doSetConnPhy(uint8_t index)
static uint8_t phy[] = {
HCI_PHY_1_MBPS, HCI_PHY_2_MBPS, HCI_PHY_1_MBPS | HCI_PHY_2_MBPS,
HCI_PHY_CODED, HCI_PHY_1_MBPS | HCI_PHY_2_MBPS | HCI_PHY_CODED,
// Set Phy Preference on the current connection. Apply the same value
// for RX and TX. For more information, see the LE 2M PHY section in the User's Guide:
// Note PHYs are already enabled by default in build_config.opt in stack project.
HCI_LE_SetPhyCmd(scConnHandle, 0, phy[index], phy[index], 0);
Display_printf(dispHandle, SC_ROW_CUR_CONN, 0, "PHY preference: %s",
TBM_GET_ACTION_DESC(&scMenuConnPhy, index));
return (true);
* @fn SimpleCentral_doDisconnect
* @brief Disconnect the specified link
bool SimpleCentral_doDisconnect(uint8_t index)
(void) index;
// Uart_SendMsg(UART_HEADER_STR, 10, "Disconnect");
GAP_TerminateLinkReq(scConnHandle, HCI_DISCONNECT_REMOTE_USER_TERM);
return (true);
* @fn SimpleCentral_menuSwitchCb
* @brief Detect menu context switching
* @param pMenuObjCurr - the current menu object
* @param pMenuObjNext - the menu object the context is about to switch to
* @return none
uint8_t i, j;
// interested in only the events of
// entering scMenuConnect, scMenuSelectConn, and scMenuMain for now
if (pMenuObjNext == &scMenuConnect)
for (j = 0; j < MAX_NUM_BLE_CONNS; j++)
if ((connList[j].connHandle != LINKDB_CONNHANDLE_INVALID) &&
Util_convertBdAddr2Str(connList[j].addr),
SC_ADDR_STR_SIZE))
// Already connected. Add to the set to be disabled.
itemsToDisable |= (1 << i);
// Eventually only non-connected device addresses will be displayed.
SC_ITEM_ALL & ~itemsToDisable, itemsToDisable);
else if (pMenuObjNext == &scMenuSelectConn)
static uint8_t* pAddrs;
uint8_t* pAddrTemp;
if (pAddrs != NULL)
ICall_free(pAddrs);
pAddrs = ICall_malloc(numConn * SC_ADDR_STR_SIZE);
if (pAddrs == NULL)
TBM_SET_NUM_ITEM(&scMenuSelectConn, 0);
else
TBM_SET_NUM_ITEM(&scMenuSelectConn, MAX_NUM_BLE_CONNS);
pAddrTemp = pAddrs;
// Add active connection info to the menu object
if (connList[i].connHandle != LINKDB_CONNHANDLE_INVALID)
// This connection is active. Set the corresponding menu item with
// the address of this connection and enable the item.
memcpy(pAddrTemp, Util_convertBdAddr2Str(connList[i].addr),
SC_ADDR_STR_SIZE);
TBM_SET_ACTION_DESC(&scMenuSelectConn, i, pAddrTemp);
tbm_setItemStatus(&scMenuSelectConn, (1 << i), SC_ITEM_NONE);
pAddrTemp += SC_ADDR_STR_SIZE;
else
// This connection is not active. Disable the corresponding menu item.
tbm_setItemStatus(&scMenuSelectConn, SC_ITEM_NONE, (1 << i));
else if (pMenuObjNext == &scMenuMain)
// Now we are not in a specific connection's context
// Clear connection-related message
Display_clearLine(dispHandle, SC_ROW_CUR_CONN);
And the code of CC2640
@file simple_peripheral.c
@brief This file contains the Simple Peripheral sample application for use
with the CC2650 Bluetooth Low Energy Protocol Stack.
Group: CMCU, SCS
Target Device: CC2640R2
Copyright (c) 2013-2017, Texas Instruments Incorporated
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
* Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
its contributors may be used to endorse or promote products derived
from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Release Name: simplelink_cc2640r2_sdk_1_40_00_45
Release Date: 2017-07-20 17:16:59
* INCLUDES
#include <string.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/knl/Clock.h>
#include <ti/sysbios/knl/Event.h>
#include <ti/sysbios/knl/Queue.h>
#include <ti/display/Display.h>
#if defined( USE_FPGA ) || defined( DEBUG_SW_TRACE )
#include <driverlib/ioc.h>
#endif // USE_FPGA | DEBUG_SW_TRACE
#include <icall.h>
#include "util.h"
/* This Header file contains all BLE API and icall structure definition */
#include "icall_ble_api.h"
#include "devinfoservice.h"
#include "simple_gatt_profile.h"
#if defined(FEATURE_OAD) || defined(IMAGE_INVALIDATE)
#include "oad_target.h"
#include "oad.h"
#endif //FEATURE_OAD || IMAGE_INVALIDATE
#include "peripheral.h"
#ifdef USE_RCOSC
#include "rcosc_calibration.h"
#endif //USE_RCOSC
#include "board.h"
#if !defined(Display_DISABLE_ALL)
#include "board_key.h"
#include <menu/two_btn_menu.h>
#include "simple_peripheral_menu.h"
#endif // !Display_DISABLE_ALL
#include "simple_peripheral.h"
#include "usrs.h"
Clock_Struct noti_clock;
* CONSTANTS
// Advertising interval when device is discoverable (units of 625us, 160=100ms)
#define DEFAULT_ADVERTISING_INTERVAL 160
// General discoverable mode: advertise indefinitely
#define DEFAULT_DISCOVERABLE_MODE GAP_ADTYPE_FLAGS_GENERAL
#ifndef FEATURE_OAD
// Minimum connection interval (units of 1.25ms, 80=100ms) for automatic
// parameter update request
#define DEFAULT_DESIRED_MIN_CONN_INTERVAL 80
// Maximum connection interval (units of 1.25ms, 800=1000ms) for automatic
#define DEFAULT_DESIRED_MAX_CONN_INTERVAL 800
#else // FEATURE_OAD
// Increase the the connection interval to allow for higher throughput for OAD
// Minimum connection interval (units of 1.25ms, 8=10ms) for automatic
// Maximum connection interval (units of 1.25ms, 8=10ms) for automatic
#endif // FEATURE_OAD
// Slave latency to use for automatic parameter update request
#define DEFAULT_DESIRED_SLAVE_LATENCY 0
// Supervision timeout value (units of 10ms, 1000=10s) for automatic parameter
// update request
#define DEFAULT_DESIRED_CONN_TIMEOUT 3200//1000
// After the connection is formed, the peripheral waits until the central
// device asks for its preferred connection parameters
#define DEFAULT_ENABLE_UPDATE_REQUEST GAPROLE_LINK_PARAM_UPDATE_WAIT_REMOTE_PARAMS
// Connection Pause Peripheral time value (in seconds)
#define DEFAULT_CONN_PAUSE_PERIPHERAL 1//6
// How often to perform periodic event (in msec)
#define SBP_PERIODIC_EVT_PERIOD 5000
// Application specific event ID for HCI Connection Event End Events
#define SBP_HCI_CONN_EVT_END_EVT 0x0001
// Type of Display to open
#if defined(BOARD_DISPLAY_USE_LCD) && (BOARD_DISPLAY_USE_LCD!=0)
#define SBP_DISPLAY_TYPE Display_Type_LCD
#elif defined (BOARD_DISPLAY_USE_UART) && (BOARD_DISPLAY_USE_UART!=0)
#define SBP_DISPLAY_TYPE Display_Type_UART
#else // !BOARD_DISPLAY_USE_LCD && !BOARD_DISPLAY_USE_UART
#define SBP_DISPLAY_TYPE 0 // Option not supported
#endif // BOARD_DISPLAY_USE_LCD && BOARD_DISPLAY_USE_UART
#else // BOARD_DISPLAY_USE_LCD && BOARD_DISPLAY_USE_UART
#define SBP_DISPLAY_TYPE 0 // No Display
#ifdef FEATURE_OAD
// The size of an OAD packet.
#define OAD_PACKET_SIZE ((OAD_BLOCK_SIZE) + 2)
// Task configuration
#define SBP_TASK_PRIORITY 1
#ifndef SBP_TASK_STACK_SIZE
#define SBP_TASK_STACK_SIZE 644
#endif
// Application events
#define SBP_STATE_CHANGE_EVT 0x0001
#define SBP_CHAR_CHANGE_EVT 0x0002
#define SBP_KEY_CHANGE_EVT 0x0004
// Internal Events for RTOS application
#define SBP_ICALL_EVT ICALL_MSG_EVENT_ID // Event_Id_31
#define SBP_QUEUE_EVT UTIL_QUEUE_EVENT_ID // Event_Id_30
#define SBP_PERIODIC_EVT Event_Id_00
#ifdef FEATURE_OAD
// Additional Application Events for OAD
#define SBP_QUEUE_PING_EVT Event_Id_01
// Bitwise OR of all events to pend on with OAD
#define SBP_ALL_EVENTS (SBP_ICALL_EVT | \
SBP_QUEUE_EVT | \
SBP_PERIODIC_EVT | \
SBP_QUEUE_PING_EVT)
#else
SBP_QUEUE_EVT | \
SBP_PERIODIC_EVT)
#endif /* FEATURE_OAD */
// Row numbers for two-button menu
#define SBP_ROW_RESULT TBM_ROW_APP
#define SBP_ROW_STATUS_1 (TBM_ROW_APP + 1)
#define SBP_ROW_STATUS_2 (TBM_ROW_APP + 2)
#define SBP_ROW_ROLESTATE (TBM_ROW_APP + 3)
#define SBP_ROW_BDADDR (TBM_ROW_APP + 4)
* TYPEDEFS
// App event passed from profiles.
typedef struct
appEvtHdr_t hdr; // event header.
} sbpEvt_t;
* GLOBAL VARIABLES
// Display Interface
Display_Handle dispHandle = NULL;
* LOCAL VARIABLES
// Entity ID globally used to check for source and/or destination of messages
static ICall_EntityID selfEntity;
// Event globally used to post local events and pend on system and
// local events.
static ICall_SyncHandle syncEvent;
// Clock instances for internal periodic events.
static Clock_Struct periodicClock;
// Queue object used for app messages
static Queue_Struct appMsg;
static Queue_Handle appMsgQueue;
// Event data from OAD profile.
static Queue_Struct oadQ;
static Queue_Handle hOadQ;
Task_Struct sbpTask;
Char sbpTaskStack[SBP_TASK_STACK_SIZE];
// Scan response data (max size = 31 bytes)
static uint8_t scanRspData[] =
// complete name
0x14, // length of this data
GAP_ADTYPE_LOCAL_NAME_COMPLETE,
'S',
'i',
'm',
'p',
'l',
'e',
'B',
'L',
'E',
'P',
'e',
'r',
'i',
'p',
'h',
'e',
'r',
'a',
'l',
// connection interval range
0x05, // length of this data
GAP_ADTYPE_SLAVE_CONN_INTERVAL_RANGE,
LO_UINT16(DEFAULT_DESIRED_MIN_CONN_INTERVAL), // 100ms
HI_UINT16(DEFAULT_DESIRED_MIN_CONN_INTERVAL),
LO_UINT16(DEFAULT_DESIRED_MAX_CONN_INTERVAL), // 1s
HI_UINT16(DEFAULT_DESIRED_MAX_CONN_INTERVAL),
// Tx power level
0x02, // length of this data
GAP_ADTYPE_POWER_LEVEL,
0 // 0dBm
// Advertisement data (max size = 31 bytes, though this is
// best kept short to conserve power while advertising)
static uint8_t advertData[] =
// Flags: this field sets the device to use general discoverable
// mode (advertises indefinitely) instead of general
// discoverable mode (advertise for 30 seconds at a time)
GAP_ADTYPE_FLAGS,
DEFAULT_DISCOVERABLE_MODE | GAP_ADTYPE_FLAGS_BREDR_NOT_SUPPORTED,
// service UUID, to notify central devices what services are included
// in this peripheral
#if !defined(FEATURE_OAD) || defined(FEATURE_OAD_ONCHIP)
0x03, // length of this data
#else //OAD for external flash
GAP_ADTYPE_16BIT_MORE, // some of the UUID's, but not all
#ifdef FEATURE_OAD
LO_UINT16(OAD_SERVICE_UUID),
HI_UINT16(OAD_SERVICE_UUID),
#ifndef FEATURE_OAD_ONCHIP
#endif //FEATURE_OAD_ONCHIP
// GAP GATT Attributes
static uint8_t attDeviceName[GAP_DEVICE_NAME_LEN] = "Simple Peripheral";
// Globals used for ATT Response retransmission
static gattMsgEvent_t *pAttRsp = NULL;
static uint8_t rspTxRetry = 0;
* LOCAL FUNCTIONS
static void SimpleBLEPeripheral_init( void );
static void SimpleBLEPeripheral_taskFxn(UArg a0, UArg a1);
static uint8_t SimpleBLEPeripheral_processStackMsg(ICall_Hdr *pMsg);
static uint8_t SimpleBLEPeripheral_processGATTMsg(gattMsgEvent_t *pMsg);
static void SimpleBLEPeripheral_processAppMsg(sbpEvt_t *pMsg);
static void SimpleBLEPeripheral_processStateChangeEvt(gaprole_States_t newState);
static void SimpleBLEPeripheral_processCharValueChangeEvt(uint8_t paramID);
static void SimpleBLEPeripheral_performPeriodicTask(void);
static void SimpleBLEPeripheral_clockHandler(UArg arg);
static void SimpleBLEPeripheral_sendAttRsp(void);
static void SimpleBLEPeripheral_freeAttRsp(uint8_t status);
static void SimpleBLEPeripheral_stateChangeCB(gaprole_States_t newState);
static void SimpleBLEPeripheral_charValueChangeCB(uint8_t paramID);
#endif //!FEATURE_OAD_ONCHIP
static void SimpleBLEPeripheral_enqueueMsg(uint8_t event, uint8_t state);
#ifdef FEATURE_OAD
void SimpleBLEPeripheral_processOadWriteCB(uint8_t event, uint16_t connHandle,
uint8_t *pData);
void SimpleBLEPeripheral_keyChangeHandler(uint8 keys);
static void SimpleBLEPeripheral_handleKeys(uint8_t keys);
* EXTERN FUNCTIONS
extern void AssertHandler(uint8 assertCause, uint8 assertSubcause);
* PROFILE CALLBACKS
// Peripheral GAPRole Callbacks
static gapRolesCBs_t SimpleBLEPeripheral_gapRoleCBs =
SimpleBLEPeripheral_stateChangeCB // GAPRole State Change Callbacks
// GAP Bond Manager Callbacks
// These are set to NULL since they are not needed. The application
// is set up to only perform justworks pairing.
static gapBondCBs_t simpleBLEPeripheral_BondMgrCBs =
NULL, // Passcode callback
NULL // Pairing / Bonding state Callback
// Simple GATT Profile Callbacks
static simpleProfileCBs_t SimpleBLEPeripheral_simpleProfileCBs =
SimpleBLEPeripheral_charValueChangeCB // Simple GATT Characteristic value change callback
#ifdef FEATURE_OAD
static oadTargetCBs_t simpleBLEPeripheral_oadCBs =
SimpleBLEPeripheral_processOadWriteCB // OAD Profile Characteristic value change callback.
* PUBLIC FUNCTIONS
* @fn SimpleBLEPeripheral_createTask
* @brief Task creation function for the Simple Peripheral.
* @param None.
* @return None.
void SimpleBLEPeripheral_createTask(void)
Task_Params taskParams;
// Configure task
Task_Params_init(&taskParams);
taskParams.stack = sbpTaskStack;
taskParams.stackSize = SBP_TASK_STACK_SIZE;
taskParams.priority = SBP_TASK_PRIORITY;
Task_construct(&sbpTask, SimpleBLEPeripheral_taskFxn, &taskParams, NULL);
* @fn SimpleBLEPeripheral_init
* @brief Called during initialization and contains application
* specific initialization (ie. hardware initialization/setup,
* table initialization, power up notification, etc), and
* profile initialization/setup.
* @param None.
* @return None.
static void SimpleBLEPeripheral_init(void)
// N0 STACK API CALLS CAN OCCUR BEFORE THIS CALL TO ICall_registerApp
// Register the current thread as an ICall dispatcher application
// so that the application can send and receive messages.
ICall_registerApp(&selfEntity, &syncEvent);
#ifdef USE_RCOSC
RCOSC_enableCalibration();
#endif // USE_RCOSC
// configure RF Core SMI Data Link
IOCPortConfigureSet(IOID_12, IOC_PORT_RFC_GPO0, IOC_STD_OUTPUT);
IOCPortConfigureSet(IOID_11, IOC_PORT_RFC_GPI0, IOC_STD_INPUT);
// configure RF Core SMI Command Link
IOCPortConfigureSet(IOID_10, IOC_IOCFG0_PORT_ID_RFC_SMI_CL_OUT, IOC_STD_OUTPUT);
IOCPortConfigureSet(IOID_9, IOC_IOCFG0_PORT_ID_RFC_SMI_CL_IN, IOC_STD_INPUT);
// configure RF Core tracer IO
IOCPortConfigureSet(IOID_8, IOC_PORT_RFC_TRC, IOC_STD_OUTPUT);
#else // !USE_FPGA
#if defined( DEBUG_SW_TRACE )
IOCPortConfigureSet(IOID_8, IOC_PORT_RFC_TRC, IOC_STD_OUTPUT | IOC_CURRENT_4MA | IOC_SLEW_ENABLE);
#endif // DEBUG_SW_TRACE
#endif // USE_FPGA
// Create an RTOS queue for message from profile to be sent to app.
appMsgQueue = Util_constructQueue(&appMsg);
// Create one-shot clocks for internal periodic events.
Util_constructClock(&periodicClock, SimpleBLEPeripheral_clockHandler,
SBP_PERIODIC_EVT_PERIOD, 0, false, SBP_PERIODIC_EVT);
dispHandle = Display_open(SBP_DISPLAY_TYPE, NULL);
// Set GAP Parameters: After a connection was established, delay in seconds
// before sending when GAPRole_SetParameter(GAPROLE_PARAM_UPDATE_ENABLE,...)
// uses GAPROLE_LINK_PARAM_UPDATE_INITIATE_BOTH_PARAMS or
// GAPROLE_LINK_PARAM_UPDATE_INITIATE_APP_PARAMS
// For current defaults, this has no effect.
GAP_SetParamValue(TGAP_CONN_PAUSE_PERIPHERAL, DEFAULT_CONN_PAUSE_PERIPHERAL);
// Setup the Peripheral GAPRole Profile. For more information see the User's Guide:
// http://software-dl.ti.com/lprf/ble5stack-docs-latest/html/ble-stack/gaprole.html
// Device starts advertising upon initialization of GAP
uint8_t initialAdvertEnable = TRUE;
// By setting this to zero, the device will go into the waiting state after
// being discoverable for 30.72 second, and will not being advertising again
// until re-enabled by the application
uint16_t advertOffTime = 0;
uint8_t enableUpdateRequest = DEFAULT_ENABLE_UPDATE_REQUEST;
uint16_t desiredMinInterval = DEFAULT_DESIRED_MIN_CONN_INTERVAL;
uint16_t desiredMaxInterval = DEFAULT_DESIRED_MAX_CONN_INTERVAL;
uint16_t desiredSlaveLatency = DEFAULT_DESIRED_SLAVE_LATENCY;
uint16_t desiredConnTimeout = DEFAULT_DESIRED_CONN_TIMEOUT;
// Set the Peripheral GAPRole Parameters
GAPRole_SetParameter(GAPROLE_ADVERT_ENABLED, sizeof(uint8_t),
&initialAdvertEnable);
GAPRole_SetParameter(GAPROLE_ADVERT_OFF_TIME, sizeof(uint16_t),
&advertOffTime);
GAPRole_SetParameter(GAPROLE_SCAN_RSP_DATA, sizeof(scanRspData),
scanRspData);
GAPRole_SetParameter(GAPROLE_ADVERT_DATA, sizeof(advertData), advertData);
GAPRole_SetParameter(GAPROLE_PARAM_UPDATE_ENABLE, sizeof(uint8_t),
&enableUpdateRequest);
GAPRole_SetParameter(GAPROLE_MIN_CONN_INTERVAL, sizeof(uint16_t),
&desiredMinInterval);
GAPRole_SetParameter(GAPROLE_MAX_CONN_INTERVAL, sizeof(uint16_t),
&desiredMaxInterval);
GAPRole_SetParameter(GAPROLE_SLAVE_LATENCY, sizeof(uint16_t),
&desiredSlaveLatency);
GAPRole_SetParameter(GAPROLE_TIMEOUT_MULTIPLIER, sizeof(uint16_t),
&desiredConnTimeout);
// Set the Device Name characteristic in the GAP GATT Service
// For more information, see the section in the User's Guide:
GGS_SetParameter(GGS_DEVICE_NAME_ATT, GAP_DEVICE_NAME_LEN, attDeviceName);
// Set GAP Parameters to set the advertising interval
// For more information, see the GAP section of the User's Guide:
// http://software-dl.ti.com/lprf/ble5stack-docs-latest/html/ble-stack/gatt.html#gap-gatt-service-ggs
// Use the same interval for general and limited advertising.
// Note that only general advertising will occur based on the above configuration
uint16_t advInt = DEFAULT_ADVERTISING_INTERVAL;
GAP_SetParamValue(TGAP_LIM_DISC_ADV_INT_MIN, advInt);
GAP_SetParamValue(TGAP_LIM_DISC_ADV_INT_MAX, advInt);
GAP_SetParamValue(TGAP_GEN_DISC_ADV_INT_MIN, advInt);
GAP_SetParamValue(TGAP_GEN_DISC_ADV_INT_MAX, advInt);
// Setup the GAP Bond Manager. For more information see the section in the
// User's Guide:
// http://software-dl.ti.com/lprf/ble5stack-docs-latest/html/ble-stack/gapbondmngr.html#
// Hard code the passkey that will be used for pairing. The GAPBondMgr will
// use this key instead of issuing a callback to the application. This only
// works if both sides of the connection know to use this same key at
// compile-time.
uint32_t passkey = 0; // passkey "000000"
// Don't send a pairing request after connecting; the peer device must
// initiate pairing
uint8_t pairMode = GAPBOND_PAIRING_MODE_WAIT_FOR_REQ;
// Use authenticated pairing: require passcode.
uint8_t mitm = TRUE;
// This device only has display capabilities. Therefore, it will display the
// passcode during pairing. However, since the default passcode is being
// used, there is no need to display anything.
uint8_t ioCap = GAPBOND_IO_CAP_DISPLAY_ONLY;
// Request bonding (storing long-term keys for re-encryption upon subsequent
// connections without repairing)
uint8_t bonding = TRUE;
GAPBondMgr_SetParameter(GAPBOND_DEFAULT_PASSCODE, sizeof(uint32_t),
&passkey);
GAPBondMgr_SetParameter(GAPBOND_PAIRING_MODE, sizeof(uint8_t), &pairMode);
GAPBondMgr_SetParameter(GAPBOND_MITM_PROTECTION, sizeof(uint8_t), &mitm);
GAPBondMgr_SetParameter(GAPBOND_IO_CAPABILITIES, sizeof(uint8_t), &ioCap);
GAPBondMgr_SetParameter(GAPBOND_BONDING_ENABLED, sizeof(uint8_t), &bonding);
// Initialize GATT attributes
GGS_AddService(GATT_ALL_SERVICES); // GAP GATT Service
GATTServApp_AddService(GATT_ALL_SERVICES); // GATT Service
DevInfo_AddService(); // Device Information Service
SimpleProfile_AddService(GATT_ALL_SERVICES); // Simple GATT Profile
#ifdef FEATURE_OAD
VOID OAD_addService(); // OAD Profile
OAD_register((oadTargetCBs_t *)&simpleBLEPeripheral_oadCBs);
hOadQ = Util_constructQueue(&oadQ);
#ifdef IMAGE_INVALIDATE
Reset_addService();
#endif //IMAGE_INVALIDATE
// Setup the SimpleProfile Characteristic Values
// For more information, see the sections in the User's Guide:
// http://software-dl.ti.com/lprf/ble5stack-docs-latest/html/ble-stack/gatt.html#gattservapp-module
uint8_t charValue1 = 1;
uint8_t charValue2 = 2;
uint8_t charValue3 = 3;
uint8_t charValue4 = 4;
uint8_t charValue5[SIMPLEPROFILE_CHAR5_LEN] = { 1, 2, 3, 4, 5 };
SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR1, sizeof(uint8_t),
&charValue1);
SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR2, sizeof(uint8_t),
&charValue2);
SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR3, sizeof(uint8_t),
&charValue3);
SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR4, sizeof(uint8_t),
&charValue4);
SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR5, SIMPLEPROFILE_CHAR5_LEN,
charValue5);
// Register callback with SimpleGATTprofile
SimpleProfile_RegisterAppCBs(&SimpleBLEPeripheral_simpleProfileCBs);
// Start Bond Manager and register callback
VOID GAPBondMgr_Register(&simpleBLEPeripheral_BondMgrCBs);
// Register with GAP for HCI/Host messages. This is needed to receive HCI
// events. For more information, see the section in the User's Guide:
// http://software-dl.ti.com/lprf/ble5stack-docs-latest/html/ble-stack/hci.html
GAP_RegisterForMsgs(selfEntity);
// Register for GATT local events and ATT Responses pending for transmission
GATT_RegisterForMsgs(selfEntity);
// Set default values for Data Length Extension
// This should be included only if Extended Data Length Feature is enabled
// in build_config.opt in stack project.
//Set initial values to maximum, RX is set to max. by default(251 octets, 2120us)
#define APP_SUGGESTED_PDU_SIZE 251 //default is 27 octets(TX)
#define APP_SUGGESTED_TX_TIME 2120 //default is 328us(TX)
// This API is documented in hci.h
// See BLE5-Stack User's Guide for information on using this command:
// http://software-dl.ti.com/lprf/ble5stack-docs-latest/html/ble-stack/data-length-extensions.html
// HCI_LE_WriteSuggestedDefaultDataLenCmd(APP_SUGGESTED_PDU_SIZE, APP_SUGGESTED_TX_TIME);
#if defined (BLE_V42_FEATURES) && (BLE_V42_FEATURES & PRIVACY_1_2_CFG)
// Initialize GATT Client
GATT_InitClient();
// This line masks the Resolvable Private Address Only (RPAO) Characteristic
// in the GAP GATT Server from being detected by remote devices. This value
// cannot be toggled without power cycling but should remain consistent across
// power-cycles. Removing this command when Privacy is used will cause this
// device to be treated in Network Privacy Mode by bonded devices - this means
// that after disconnecting they will not respond to this device's PDUs which
// contain its Identity Address.
// Devices wanting to use Network Privacy Mode with other BT5 devices, this
// line should be commented out.
GGS_SetParamValue(GGS_DISABLE_RPAO_CHARACTERISTIC);
#endif // BLE_V42_FEATURES & PRIVACY_1_2_CFG
// Set the title of the main menu
#if defined FEATURE_OAD
#if defined (HAL_IMAGE_A)
TBM_SET_TITLE(&sbpMenuMain, "BLE Peripheral A");
#else
TBM_SET_TITLE(&sbpMenuMain, "BLE Peripheral B");
#endif // HAL_IMAGE_A
#else
TBM_SET_TITLE(&sbpMenuMain, "BLE Peripheral");
// Initialize Two-Button Menu module
tbm_setItemStatus(&sbpMenuMain, TBM_ITEM_NONE, TBM_ITEM_ALL);
tbm_initTwoBtnMenu(dispHandle, &sbpMenuMain, 3, NULL);
// Init key debouncer
Board_initKeys(SimpleBLEPeripheral_keyChangeHandler);
#if !defined (USE_LL_CONN_PARAM_UPDATE)
// Get the currently set local supported LE features
// The will result in a HCI_LE_READ_LOCAL_SUPPORTED_FEATURES event that
// will get received in the main task processing loop. At this point,
// feature bits can be set / cleared and the features can be updated.
HCI_LE_ReadLocalSupportedFeaturesCmd();
#endif // !defined (USE_LL_CONN_PARAM_UPDATE)
// Start the GAPRole
VOID GAPRole_StartDevice(&SimpleBLEPeripheral_gapRoleCBs);
HCI_EXT_SetTxPowerCmd(HCI_EXT_TX_POWER_5_DBM);
Uart_Ini();
led_handle = PIN_open(&led_pins, led_cfg);
Util_constructClock(¬i_clock, SimpleBLEPeripheral_clockHandler, SBP_NOTI_EVT_PERIOD, 0, false, SBP_NOTI_EVT);
// PIN_setOutputValue(led_handle, LED1, 1);
void SimplePeripheral_SendNotify(){
uint16_t connectionHandle;
GAPRole_GetParameter(GAPROLE_CONNHANDLE, &connectionHandle);
if(connectionHandle == INVALID_CONNHANDLE){
return;
attHandleValueNoti_t noti;
noti.handle = 0x29; //simpleProfileAttrTbl[11].handle;
uint16_t len_msg = 9;
noti.len = len_msg;
bStatus_t status;
noti.pValue = (uint8 *)GATT_bm_alloc(connectionHandle, ATT_HANDLE_VALUE_NOTI, len_msg, &len_msg );
if(noti.pValue!=NULL){
for(int i = 0;i < 9; i++){
noti.pValue[i] = i;
status = GATT_Notification( connectionHandle, ¬i, 0);
if ( status != SUCCESS ){ //if noti not sent
GATT_bm_free( (gattMsg_t *)¬i, ATT_HANDLE_VALUE_NOTI );
else{
status = bleNoResources;
// bleNoResources was returned
asm(" NOP ");
* @fn SimpleBLEPeripheral_taskFxn
* @brief Application task entry point for the Simple Peripheral.
* @param a0, a1 - not used.
* @return None.
// Initialize application
SimpleBLEPeripheral_init();
// Application main loop
for (;;)
uint32_t events;
// Waits for an event to be posted associated with the calling thread.
// Note that an event associated with a thread is posted when a
// message is queued to the message receive queue of the thread
events = Event_pend(syncEvent, Event_Id_NONE, SBP_ALL_EVENTS | SBP_NOTI_EVT,
ICALL_TIMEOUT_FOREVER);
if (events)
ICall_EntityID dest;
ICall_ServiceEnum src;
ICall_HciExtEvt *pMsg = NULL;
// Fetch any available messages that might have been sent from the stack
if (ICall_fetchServiceMsg(&src, &dest,
(void **)&pMsg) == ICALL_ERRNO_SUCCESS)
uint8 safeToDealloc = TRUE;
if ((src == ICALL_SERVICE_CLASS_BLE) && (dest == selfEntity))
ICall_Stack_Event *pEvt = (ICall_Stack_Event *)pMsg;
// Check for BLE stack events first
if (pEvt->signature == 0xffff)
// The GATT server might have returned a blePending as it was trying
// to process an ATT Response. Now that we finished with this
// connection event, let's try sending any remaining ATT Responses
if (pEvt->event_flag & SBP_HCI_CONN_EVT_END_EVT)
// Try to retransmit pending ATT Response (if any)
SimpleBLEPeripheral_sendAttRsp();
else
// Process inter-task message
safeToDealloc = SimpleBLEPeripheral_processStackMsg((ICall_Hdr *)pMsg);
if (pMsg && safeToDealloc)
ICall_freeMsg(pMsg);
// If RTOS queue is not empty, process app message.
if (events & SBP_QUEUE_EVT)
while (!Queue_empty(appMsgQueue))
sbpEvt_t *pMsg = (sbpEvt_t *)Util_dequeueMsg(appMsgQueue);
if (pMsg)
// Process message.
SimpleBLEPeripheral_processAppMsg(pMsg);
// Free the space from the message.
ICall_free(pMsg);
if (events & SBP_PERIODIC_EVT)
Util_startClock(&periodicClock);
// Perform periodic application task
SimpleBLEPeripheral_performPeriodicTask();
if(events & SBP_NOTI_EVT){
Util_startClock(¬i_clock);
SimplePeripheral_SendNotify();
#ifdef FEATURE_OAD
if (events & SBP_QUEUE_PING_EVT)
while (!Queue_empty(hOadQ))
oadTargetWrite_t *oadWriteEvt = Queue_get(hOadQ);
// Identify new image.
if (oadWriteEvt->event == OAD_WRITE_IDENTIFY_REQ)
OAD_imgIdentifyWrite(oadWriteEvt->connHandle, oadWriteEvt->pData);
// Write a next block request.
else if (oadWriteEvt->event == OAD_WRITE_BLOCK_REQ)
OAD_imgBlockWrite(oadWriteEvt->connHandle, oadWriteEvt->pData);
// Free buffer.
ICall_free(oadWriteEvt);
* @fn SimpleBLEPeripheral_processStackMsg
* @brief Process an incoming stack message.
* @param pMsg - message to process
* @return TRUE if safe to deallocate incoming message, FALSE otherwise.
uint8_t safeToDealloc = TRUE;
switch (pMsg->event)
case GATT_MSG_EVENT:
// Process GATT message
safeToDealloc = SimpleBLEPeripheral_processGATTMsg((gattMsgEvent_t *)pMsg);
break;
case HCI_GAP_EVENT_EVENT:
// Process HCI message
switch(pMsg->status)
case HCI_COMMAND_COMPLETE_EVENT_CODE:
// Process HCI Command Complete Event
// This code will disable the use of the LL_CONNECTION_PARAM_REQ
// control procedure (for connection parameter updates, the
// L2CAP Connection Parameter Update procedure will be used
// instead). To re-enable the LL_CONNECTION_PARAM_REQ control
// procedures, define the symbol USE_LL_CONN_PARAM_UPDATE
// The L2CAP Connection Parameter Update procedure is used to
// support a delta between the minimum and maximum connection
// intervals required by some iOS devices.
// Parse Command Complete Event for opcode and status
hciEvt_CmdComplete_t* command_complete = (hciEvt_CmdComplete_t*) pMsg;
uint8_t pktStatus = command_complete->pReturnParam[0];
//find which command this command complete is for
switch (command_complete->cmdOpcode)
case HCI_LE_READ_LOCAL_SUPPORTED_FEATURES:
if (pktStatus == SUCCESS)
uint8_t featSet[8];
// Get current feature set from received event (bits 1-9
// of the returned data
memcpy( featSet, &command_complete->pReturnParam[1], 8 );
// Clear bit 1 of byte 0 of feature set to disable LL
// Connection Parameter Updates
CLR_FEATURE_FLAG( featSet[0], LL_FEATURE_CONN_PARAMS_REQ );
// Update controller with modified features
HCI_EXT_SetLocalSupportedFeaturesCmd( featSet );
break;
default:
//do nothing
break;
break;
case HCI_BLE_HARDWARE_ERROR_EVENT_CODE:
AssertHandler(HAL_ASSERT_CAUSE_HARDWARE_ERROR,0);
break;
// LE Events
case HCI_LE_EVENT_CODE:
hciEvt_BLEPhyUpdateComplete_t *pPUC
= (hciEvt_BLEPhyUpdateComplete_t*) pMsg;
// A Phy Update Has Completed or Failed
if (pPUC->BLEEventCode == HCI_BLE_PHY_UPDATE_COMPLETE_EVENT)
if (pPUC->status != SUCCESS)
Display_print0(dispHandle, SBP_ROW_STATUS_1, 0,
"PHY Change failure");
else
"PHY Update Complete");
// Only symmetrical PHY is supported.
// rxPhy should be equal to txPhy.
Display_print1(dispHandle, SBP_ROW_STATUS_2, 0,
"Current PHY: %s",
(pPUC->rxPhy == HCI_PHY_1_MBPS) ? "1 Mbps" :
// Note: BLE_V50_FEATURES is always defined and long range phy (PHY_LR_CFG) is
// defined in build_config.opt
#if (BLE_V50_FEATURES & PHY_LR_CFG)
((pPUC->rxPhy == HCI_PHY_2_MBPS) ? "2 Mbps" :
"Coded:S2"));
#else // !PHY_LR_CFG
"2 Mbps");
#endif // PHY_LR_CFG
break;
default:
break;
break;
default:
// do nothing
break;
return (safeToDealloc);
* @fn SimpleBLEPeripheral_processGATTMsg
PIN_setOutputValue(led_handle, LED4, 1);
// No HCI buffer was available. Let's try to retransmit the response
if (HCI_EXT_ConnEventNoticeCmd(pMsg->connHandle, selfEntity,
SBP_HCI_CONN_EVT_END_EVT) == SUCCESS)
// First free any pending response
SimpleBLEPeripheral_freeAttRsp(FAILURE);
// Hold on to the response message for retransmission
pAttRsp = pMsg;
// Don't free the response message yet
return (FALSE);
PIN_setOutputValue(led_handle, LED3, 1);
Display_print1(dispHandle, SBP_ROW_RESULT, 0, "FC Violated: %d", pMsg->msg.flowCtrlEvt.opcode);
// MTU size updated
PIN_setOutputValue(led_handle, LED2, 1);
Display_print1(dispHandle, SBP_ROW_RESULT, 0, "MTU Size: %d", pMsg->msg.mtuEvt.MTU);
// Free message payload. Needed only for ATT Protocol messages
// It's safe to free the incoming message
return (TRUE);
* @fn SimpleBLEPeripheral_sendAttRsp
* @brief Send a pending ATT response message.
* @param none
* @return none
// See if there's a pending ATT Response to be transmitted
if (pAttRsp != NULL)
uint8_t status;
// Increment retransmission count
rspTxRetry++;
// Try to retransmit ATT response till either we're successful or
// the ATT Client times out (after 30s) and drops the connection.
status = GATT_SendRsp(pAttRsp->connHandle, pAttRsp->method, &(pAttRsp->msg));
if ((status != blePending) && (status != MSG_BUFFER_NOT_AVAIL))
// Disable connection event end notice
HCI_EXT_ConnEventNoticeCmd(pAttRsp->connHandle, selfEntity, 0);
// We're done with the response message
SimpleBLEPeripheral_freeAttRsp(status);
else
// Continue retrying
Display_print1(dispHandle, SBP_ROW_STATUS_1, 0, "Rsp send retry: %d", rspTxRetry);
* @fn SimpleBLEPeripheral_freeAttRsp
* @brief Free ATT response message.
* @param status - response transmit status
* @return none
// See if there's a pending ATT response message
// See if the response was sent out successfully
Display_print1(dispHandle, SBP_ROW_STATUS_1, 0, "Rsp sent retry: %d", rspTxRetry);
else
// Free response payload
GATT_bm_free(&pAttRsp->msg, pAttRsp->method);
Display_print1(dispHandle, SBP_ROW_STATUS_1, 0, "Rsp retry failed: %d", rspTxRetry);
// Free response message
ICall_freeMsg(pAttRsp);
// Reset our globals
pAttRsp = NULL;
rspTxRetry = 0;
* @fn SimpleBLEPeripheral_processAppMsg
* @brief Process an incoming callback from a profile.
* @return None.
switch (pMsg->hdr.event)
case SBP_STATE_CHANGE_EVT:
SimpleBLEPeripheral_processStateChangeEvt((gaprole_States_t)pMsg->
hdr.state);
break;
case SBP_CHAR_CHANGE_EVT:
SimpleBLEPeripheral_processCharValueChangeEvt(pMsg->hdr.state);
break;
case SBP_KEY_CHANGE_EVT:
SimpleBLEPeripheral_handleKeys(pMsg->hdr.state);
break;
default:
// Do nothing.
break;
* @fn SimpleBLEPeripheral_stateChangeCB
* @brief Callback from GAP Role indicating a role state change.
* @param newState - new state
* @return None.
SimpleBLEPeripheral_enqueueMsg(SBP_STATE_CHANGE_EVT, newState);
* @fn SimpleBLEPeripheral_processStateChangeEvt
* @brief Process a pending GAP Role state change event.
* @return None.
#ifdef PLUS_BROADCASTER
static bool firstConnFlag = false;
#endif // PLUS_BROADCASTER
switch ( newState )
case GAPROLE_STARTED:
uint8_t ownAddress[B_ADDR_LEN];
uint8_t systemId[DEVINFO_SYSTEM_ID_LEN];
GAPRole_GetParameter(GAPROLE_BD_ADDR, ownAddress);
// use 6 bytes of device address for 8 bytes of system ID value
systemId[0] = ownAddress[0];
systemId[1] = ownAddress[1];
systemId[2] = ownAddress[2];
// set middle bytes to zero
systemId[4] = 0x00;
systemId[3] = 0x00;
// shift three bytes up
systemId[7] = ownAddress[5];
systemId[6] = ownAddress[4];
systemId[5] = ownAddress[3];
DevInfo_SetParameter(DEVINFO_SYSTEM_ID, DEVINFO_SYSTEM_ID_LEN, systemId);
// Display device address
Display_print0(dispHandle, SBP_ROW_BDADDR, 0, Util_convertBdAddr2Str(ownAddress));
Display_print0(dispHandle, SBP_ROW_ROLESTATE, 0, "Initialized");
break;
case GAPROLE_ADVERTISING:
Display_print0(dispHandle, SBP_ROW_ROLESTATE, 0, "Advertising");
break;
// After a connection is dropped, a device in PLUS_BROADCASTER will continue
// sending non-connectable advertisements and shall send this change of
// state to the application. These are then disabled here so that sending
// connectable advertisements can resume.
case GAPROLE_ADVERTISING_NONCONN:
uint8_t advertEnabled = FALSE;
// Disable non-connectable advertising.
GAPRole_SetParameter(GAPROLE_ADV_NONCONN_ENABLED, sizeof(uint8_t),
&advertEnabled);
advertEnabled = TRUE;
// Enabled connectable advertising.
&advertEnabled);
// Reset flag for next connection.
SimpleBLEPeripheral_freeAttRsp(bleNotConnected);
break;
#endif //PLUS_BROADCASTER
case GAPROLE_CONNECTED:
uint8_t numActive = 0;
numActive = linkDB_NumActive();
// Use numActive to determine the connection handle of the last
// connection
if ( linkDB_GetInfo( numActive - 1, &linkInfo ) == SUCCESS )
Display_print1(dispHandle, SBP_ROW_ROLESTATE, 0, "Num Conns: %d", (uint16_t)numActive);
Display_print0(dispHandle, SBP_ROW_STATUS_1, 0, Util_convertBdAddr2Str(linkInfo.addr));
else
uint8_t peerAddress[B_ADDR_LEN];
GAPRole_GetParameter(GAPROLE_CONN_BD_ADDR, peerAddress);
Display_print0(dispHandle, SBP_ROW_ROLESTATE, 0, "Connected");
Display_print0(dispHandle, SBP_ROW_STATUS_1, 0, Util_convertBdAddr2Str(peerAddress));
tbm_setItemStatus(&sbpMenuMain, TBM_ITEM_ALL, TBM_ITEM_NONE);
// Only turn advertising on for this state when we first connect
// otherwise, when we go from connected_advertising back to this state
// we will be turning advertising back on.
if (firstConnFlag == false)
uint8_t advertEnabled = FALSE; // Turn on Advertising
// Disable connectable advertising.
&advertEnabled);
// Set to true for non-connectable advertising.
// Enable non-connectable advertising.
&advertEnabled);
firstConnFlag = true;
// Uart_SendMsg(UART_HEADER_STR, "Connected", 9);
break;
case GAPROLE_CONNECTED_ADV:
Display_print0(dispHandle, SBP_ROW_ROLESTATE, 0, "Connected Advertising");
break;
case GAPROLE_WAITING:
PIN_setOutputValue(led_handle, LED1, 0);
Util_stopClock(&periodicClock);
// Uart_SendMsg(UART_HEADER_STR, "Disconnected", 12);
Display_print0(dispHandle, SBP_ROW_ROLESTATE, 0, "Disconnected");
// Disable PHY change
// Clear remaining lines
Display_clearLines(dispHandle, SBP_ROW_RESULT, SBP_ROW_STATUS_2);
Util_stopClock(¬i_clock);
break;
case GAPROLE_WAITING_AFTER_TIMEOUT:
// Uart_SendMsg(UART_HEADER_STR, "Time Out.", 9);
Display_print0(dispHandle, SBP_ROW_RESULT, 0, "Timed Out");
Display_clearLines(dispHandle, SBP_ROW_STATUS_1, SBP_ROW_STATUS_2);
break;
case GAPROLE_ERROR:
Display_print0(dispHandle, SBP_ROW_RESULT, 0, "Error");
break;
default:
break;
* @fn SimpleBLEPeripheral_charValueChangeCB
* @brief Callback from Simple Profile indicating a characteristic
* value change.
* @param paramID - parameter ID of the value that was changed.
* @return None.
SimpleBLEPeripheral_enqueueMsg(SBP_CHAR_CHANGE_EVT, paramID);
* @fn SimpleBLEPeripheral_processCharValueChangeEvt
* @brief Process a pending Simple Profile characteristic value change
* event.
* @return None.
uint8_t newValue;
switch(paramID)
case SIMPLEPROFILE_CHAR1:
SimpleProfile_GetParameter(SIMPLEPROFILE_CHAR1, &newValue);
Display_print1(dispHandle, SBP_ROW_STATUS_1, 0, "Char 1: %d", (uint16_t)newValue);
break;
case SIMPLEPROFILE_CHAR3:
SimpleProfile_GetParameter(SIMPLEPROFILE_CHAR3, &newValue);
Display_print1(dispHandle, SBP_ROW_STATUS_1, 0, "Char 3: %d", (uint16_t)newValue);
break;
default:
// should not reach here!
break;
* @fn SimpleBLEPeripheral_performPeriodicTask
* @brief Perform a periodic application task. This function gets called
* every five seconds (SBP_PERIODIC_EVT_PERIOD). In this example,
* the value of the third characteristic in the SimpleGATTProfile
* service is retrieved from the profile, and then copied into the
* value of the the fourth characteristic.
* @param None.
* @return None.
uint8_t valueToCopy;
// Call to retrieve the value of the third characteristic in the profile
if (SimpleProfile_GetParameter(SIMPLEPROFILE_CHAR3, &valueToCopy) == SUCCESS)
// Call to set that value of the fourth characteristic in the profile.
// Note that if notifications of the fourth characteristic have been
// enabled by a GATT client device, then a notification will be sent
// every time this function is called.
&valueToCopy);
#ifdef FEATURE_OAD
* @fn SimpleBLEPeripheral_processOadWriteCB
* @brief Process a write request to the OAD profile.
* @param event - event type:
* OAD_WRITE_IDENTIFY_REQ
* OAD_WRITE_BLOCK_REQ
* @param connHandle - the connection Handle this request is from.
* @param pData - pointer to data for processing and/or storing.
* @return None.
uint8_t *pData)
oadTargetWrite_t *oadWriteEvt = ICall_malloc( sizeof(oadTargetWrite_t) + \
sizeof(uint8_t) * OAD_PACKET_SIZE);
if ( oadWriteEvt != NULL )
oadWriteEvt->event = event;
oadWriteEvt->connHandle = connHandle;
oadWriteEvt->pData = (uint8_t *)(&oadWriteEvt->pData + 1);
memcpy(oadWriteEvt->pData, pData, OAD_PACKET_SIZE);
Queue_put(hOadQ, (Queue_Elem *)oadWriteEvt);
// Post the application's event. For OAD, no event flag is used.
Event_post(syncEvent, SBP_QUEUE_PING_EVT);
else
// Fail silently.
* @fn SimpleBLEPeripheral_clockHandler
* @brief Handler function for clock timeouts.
* @param arg - event type
* @return None.
// Wake up the application.
Event_post(syncEvent, arg);
* @fn SimpleBLEPeripheral_keyChangeHandler
* @param keys - bitmap of pressed keys
* @return none
SimpleBLEPeripheral_enqueueMsg(SBP_KEY_CHANGE_EVT, keys);
* @fn SimpleBLEPeripheral_enqueueMsg
* @return None.
sbpEvt_t *pMsg;
if ((pMsg = ICall_malloc(sizeof(sbpEvt_t))))
Util_enqueueMsg(appMsgQueue, syncEvent, (uint8*)pMsg);
* @fn SimpleBLEPeripheral_handleKeys
* @brief Handles all key events for this device.
* @param keys - bit field for key events. Valid entries:
* KEY_LEFT
* KEY_RIGHT
* @return none
if (keys & KEY_LEFT)
// Check if the key is still pressed. WA for possible bouncing.
#if defined(CC2650DK_7ID)
if (PIN_getInputValue(Board_KEY_LEFT) == 0)
#elif defined(CC2650_LAUNCHXL) || defined(CC2640R2_LAUNCHXL)
if (PIN_getInputValue(Board_PIN_BUTTON0) == 0)
#endif // CC2650DK_7ID, CC2650_LAUNCHXL, CC2640R2_LAUNCHXL
tbm_buttonLeft();
else if (keys & KEY_RIGHT)
if (PIN_getInputValue(Board_KEY_RIGHT) == 0)
if (PIN_getInputValue(Board_PIN_BUTTON1) == 0)
tbm_buttonRight();
* @fn SimpleBLEPeripheral_doSetPhy
* @brief Set PHY preference.
* 1: 2M PHY
* 2: 1M + 2M PHY
* 3: CODED PHY (Long range) (when PHY_LR_CFG is defined)
* 4: 1M + 2M + CODED PHY (when PHY_LR_CFG is defined)
bool SimpleBLEPeripheral_doSetPhy(uint8 index)
uint8_t gapRoleState;
// To use the long range phy, HCI_PHY_CODED needs to be included
GAPRole_GetParameter(GAPROLE_STATE, &gapRoleState);
// for RX and TX.
HCI_LE_SetPhyCmd(connectionHandle, 0, phy[index], phy[index], 0);
Display_print1(dispHandle, SBP_ROW_RESULT, 0, "PHY preference: %s",
TBM_GET_ACTION_DESC(&sbpMenuMain, index));
Display_clearLine(dispHandle, SBP_ROW_STATUS_1);
return true;
