CC2642R: CCS crash when downloading flash or debug
Part Number: CC2642R
Other Parts Discussed in Thread: UNIFLASH, CCSTUDIO
I have a strange issue with CCS and my project this is stangely similar to this issue except that this one was related to linux dependencies missing and I'm on windows 10 pro
using CCS 12
I'm using JTag probe of a CC26X2R Launchpad to flash and debug a custom board
when starting to work on that project I got issue when flashing or debuging from CCS
even if flashing from uniflash is working great with same binary
a bit later I dont know why I finaly succedded in flashing and debugging ( event with some strange behaviours when debuging)
for other reason I decided to restart from project-zero project and I refall into my first issu of ccs crash when lload or debug
I tested the XDS110 prob connection and it's ok
[Start: Texas Instruments XDS110 USB Debug Probe]
Execute the command:
%ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -S integrity
[Result]
-----[Print the board config pathname(s)]------------------------------------
C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\
    CCS\ccs1200\0\0\BrdDat\testBoard.dat
-----[Print the reset-command software log-file]-----------------------------
This utility has selected a 100/110/510 class product.
This utility will load the adapter 'jioxds110.dll'.
The library build date was 'Jun 17 2022'.
The library build time was '22:30:41'.
The library package version is '9.8.0.00235'.
The library component version is '35.35.0.0'.
The controller does not use a programmable FPGA.
The controller has a version number of '5' (0x00000005).
The controller has an insertion length of '0' (0x00000000).
This utility will attempt to reset the controller.
This utility has successfully reset the controller.
-----[Print the reset-command hardware log-file]-----------------------------
The scan-path will be reset by toggling the JTAG TRST signal.
The controller is the XDS110 with USB interface.
The link from controller to target is direct (without cable).
The software is configured for XDS110 features.
The controller cannot monitor the value on the EMU[0] pin.
The controller cannot monitor the value on the EMU[1] pin.
The controller cannot control the timing on output pins.
The controller cannot control the timing on input pins.
The scan-path link-delay has been set to exactly '0' (0x0000).
-----[Perform the Integrity scan-test on the JTAG IR]------------------------
This test will use blocks of 64 32-bit words.
This test will be applied just once.
Do a test using 0xFFFFFFFF.
Scan tests: 1, skipped: 0, failed: 0
Do a test using 0x00000000.
Scan tests: 2, skipped: 0, failed: 0
Do a test using 0xFE03E0E2.
Scan tests: 3, skipped: 0, failed: 0
Do a test using 0x01FC1F1D.
Scan tests: 4, skipped: 0, failed: 0
Do a test using 0x5533CCAA.
Scan tests: 5, skipped: 0, failed: 0
Do a test using 0xAACC3355.
Scan tests: 6, skipped: 0, failed: 0
All of the values were scanned correctly.
The JTAG IR Integrity scan-test has succeeded.
-----[Perform the Integrity scan-test on the JTAG DR]------------------------
The JTAG DR Integrity scan-test has succeeded.
[End: Texas Instruments XDS110 USB Debug Probe]
 I also looked at Eclipse Log
!SESSION 2022-10-18 09:34:58.439 -----------------------------------------------
eclipse.buildId=4.23.0.I20220308-0310
java.version=11.0.13
java.vendor=Eclipse Adoptium
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=fr_FR
Framework arguments:  -product com.ti.ccstudio.branding.product
Command-line arguments:  -os win32 -ws win32 -arch x86_64 -product com.ti.ccstudio.branding.product
!ENTRY org.eclipse.core.resources 2 10035 2022-10-18 09:35:00.050
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY com.ti.common.core 1 0 2022-10-18 09:35:00.140
!MESSAGE path=ccs_base/DebugServer
!ENTRY com.ti.common.core 1 0 2022-10-18 09:35:00.141
!MESSAGE debugServerDir=C:/ti/ccs1200/ccs/ccs_base/DebugServer
!ENTRY com.ti.ccstudio.ui 1 0 2022-10-18 09:35:07.577
!MESSAGE CCS IDE session started!
	CCS build: 12.0.0.00009
	CCS location: C:/ti/ccs1200/ccs
	Workspace location: C:/Users/o.gaste/workspace_v12
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2022-10-18 09:35:07.766
!MESSAGE constructor
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2022-10-18 09:35:07.768
!MESSAGE done with directories
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2022-10-18 09:35:07.770
!MESSAGE loading ti_logger
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2022-10-18 09:35:07.772
!MESSAGE Platform os: win32
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2022-10-18 09:35:07.774
!MESSAGE loading cToolsIF
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2022-10-18 09:35:07.779
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2022-10-18 09:35:07.785
!MESSAGE loading TraceFactory
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2022-10-18 09:35:07.789
!MESSAGE loading sqlite3
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2022-10-18 09:35:07.791
!MESSAGE loading CloudTrace
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2022-10-18 09:35:07.799
!MESSAGE CloudTrace interface loaded
!ENTRY com.ti.ccstudio.project.ui.webcontent 1 0 2022-10-18 09:35:07.926
!MESSAGE CCS HTTP adapter started! [ccs.port:49959] - Open 'http://localhost:49959/ide' in web browser to see listing of available APIs...
!ENTRY com.ti.ccstudio.debug.server 4 214294189 2022-10-18 09:35:08.034
!MESSAGE Unexpected CCS exit detected [17/10/2022 10:09]!!!
!ENTRY org.eclipse.equinox.p2.repository 2 0 2022-10-18 09:35:10.051
!MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2linux/artifacts.xml.xz, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.repository 2 0 2022-10-18 09:35:10.616
!MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2mac/artifacts.xml.xz, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.repository 2 0 2022-10-18 09:35:11.187
!MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2linux/content.xml.xz, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.repository 2 0 2022-10-18 09:35:12.332
!MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2mac/content.xml.xz, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.repository 2 0 2022-10-18 09:35:12.887
!MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/content.xml.xz, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.repository 2 0 2022-10-18 09:35:14.622
!ENTRY org.eclipse.equinox.p2.repository 2 0 2022-10-18 09:35:15.126
!ENTRY org.eclipse.equinox.p2.repository 2 0 2022-10-18 09:35:15.713
!MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/Updates/, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.repository 2 0 2022-10-18 09:35:16.228
!ENTRY org.eclipse.equinox.p2.repository 2 0 2022-10-18 09:35:17.278
!ENTRY org.eclipse.equinox.p2.repository 2 0 2022-10-18 09:35:18.002
!ENTRY org.eclipse.equinox.p2.repository 2 0 2022-10-18 09:35:18.537
!ENTRY org.eclipse.equinox.p2.repository 2 0 2022-10-18 09:35:19.896
!ENTRY org.eclipse.equinox.p2.repository 2 0 2022-10-18 09:35:20.366
!ENTRY org.eclipse.equinox.p2.repository 2 0 2022-10-18 09:35:21.177
!ENTRY org.eclipse.equinox.p2.repository 2 0 2022-10-18 09:35:30.540
!MESSAGE Using unsafe http transport to retrieve http://www.blackhawk-dsp.com/updates/win64/com.bh.ccstudio.emulation.win64_9.0.0.001, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.repository 2 0 2022-10-18 09:35:31.535
!MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.repository 2 0 2022-10-18 09:35:34.447
!MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2022-10-18 09:35:59.870
!MESSAGE Connection to https://software-dl.ti.com/ccs/esd/device_support_ccsv9/radar/p2.index failed on Connect to https://downloads.ti.com:443 [downloads.ti.com/104.85.54.235] failed: Connection timed out: connect. Retry attempt 0 started
!STACK 0
org.apache.hc.client5.http.HttpHostConnectException: Connect to https://downloads.ti.com:443 [downloads.ti.com/104.85.54.235] failed: Connection timed out: connect
	at java.base/java.net.PlainSocketImpl.waitForConnect(Native Method)
	at java.base/java.net.PlainSocketImpl.socketConnect(Unknown Source)
	at java.base/java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
	at java.base/java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
	at java.base/java.net.AbstractPlainSocketImpl.connect(Unknown Source)
	at java.base/java.net.SocksSocketImpl.connect(Unknown Source)
	at java.base/java.net.Socket.connect(Unknown Source)
	at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory$1.run(SSLConnectionSocketFactory.java:219)
	at java.base/java.security.AccessController.doPrivileged(Native Method)
	at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:216)
	at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148)
	at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396)
	at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158)
	at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168)
	at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136)
	at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51)
	at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57)
	at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175)
	at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96)
	at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133)
	at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115)
	at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170)
	at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75)
	at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009)
	at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001)
	at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997)
	at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
!ENTRY org.eclipse.equinox.p2.repository 2 0 2022-10-18 09:36:35.855
!ENTRY com.ti.ccstudio.debug 1 0 2022-10-18 09:38:11.764
!MESSAGE DS_ERROR: IcePick_C: Error initializing emulator: (Error -261 @ 0x0) Invalid response was received from the XDS110. (Emulation package 9.8.0.00235)
!ENTRY com.ti.ccstudio.debug 1 0 2022-10-18 09:38:11.863
!MESSAGE DS_ERROR: Error initializing emulator:
(Error -261 @ 0x0)
and here's DebugServerLog
0x00001C54 0 3  XPCOM R: ( (dsILogger*)000001BD2B35D280 )->redirect( C:\Users\o.gaste\workspace_v12\.metadata\DebugServerLog.log ) = 0x00000000
0x00001C54 0 3  XPCOM C: ( (dsILogger*)000001BD2B35D280 )->getLogFile( 0000000DA7EFBD30 )
0x00001C54 0 3  XPCOM R: ( (dsILogger*)000001BD2B35D280 )->getLogFile( *0000000DA7EFBD30 = C:\Users\o.gaste\workspace_v12\.metadata\DebugServerLog.log ) = 0x00000000
0x00001C54 0 3  XPCOM C: ( (dsILogger*)000001BD2B35D280 )->getLogFile( 0000000DA7EFBD00 )
0x00001C54 0 3  XPCOM R: ( (dsILogger*)000001BD2B35D280 )->getLogFile( *0000000DA7EFBD00 = C:\Users\o.gaste\workspace_v12\.metadata\DebugServerLog.log ) = 0x00000000
0x00001C54 9 3  XPCOM C: ( (dsILogger*)000001BD2B35D280 )->getLogFile( 0000000DA7EFBD00 )
0x00001C54 9 3  XPCOM R: ( (dsILogger*)000001BD2B35D280 )->getLogFile( *0000000DA7EFBD00 = C:\Users\o.gaste\workspace_v12\.metadata\DebugServerLog.log ) = 0x00000000
0x00002B00 21805 5  COM_DBG_IF I: Final Release for class XPCOMLogger::CoLogger (this = 000001BD2B35D288)
0x00002B00 23806 5  COM_DBG_IF I: Final Release for class XPCOMFramework::Event<class XPCOMFramework::EventTemplateArgs<class dsISimpleEvent,void,class dsISimpleEventCallback> > (this = 000001BD35CF23D8)
0x00002B00 26312 5  COM_DBG_IF I: Final Release for class XPCOMFramework::Event<class XPCOMFramework::EventTemplateArgs<class dsISimpleEvent,void,class dsISimpleEventCallback> > (this = 000001BD35CF1EC8)
0x00001494 26487 3  XPCOM C: ( (nsIComponentManager*)00007FFEF0132010 )->createInstanceByContractID( @ti.com/DSLogger;1, 0000000000000000, 000001BD2BB5FFB0, 0000000DAE9FE408 )
0x00001494 26487 3  XPCOM R: ( (nsIComponentManager*)00007FFEF0132010 )->createInstanceByContractID( @ti.com/DSLogger;1, 0000000000000000, 000001BD2BB5FFB0, *0000000DAE9FE408 = 000001BD2EA194F0 ) = 0x00000000
0x00001494 26487 3  XPCOM C: ( (dsILogger*)000001BD2EA194F0 )->onEnabledChanged( 0000000DAE9FE3D0 )
0x00001494 26487 3  XPCOM R: ( (dsILogger*)000001BD2EA194F0 )->onEnabledChanged( *0000000DAE9FE3D0 = 000001BD2C922BD0 ) = 0x00000000
0x00001494 26487 3  XPCOM C: ( (dsISimpleEvent*)000001BD2C922BD0 )->addListener( 000001BD2BB60250 )
0x00001494 26487 3  XPCOM R: ( (dsISimpleEvent*)000001BD2C922BD0 )->addListener( 000001BD2BB60250 ) = 0x00000000
0x00001494 26487 3  XPCOM C: ( (dsILogger*)000001BD2EA194F0 )->isEnabled( 0000000DAE9FE3E0 )
0x00001494 26487 3  XPCOM R: ( (dsILogger*)000001BD2EA194F0 )->isEnabled( *0000000DAE9FE3E0 = true ) = 0x00000000
0x00001494 26487 3  WBSKT D: Get CloudAgent Instance
0x00001494 27054 3  WBSKT D: Connecting to ws://localhost:55558 for module Agent
0x000047F0 27071 3  WBSKT D: Agent open
0x00001494 27071 3  XPCOM C: ( (dsIDebugger*)000001BD35627D80 )->startWebsocketInterface( true, 0000000DAE9FE418, 0000000DAE9FE430 )
0x00001494 27071 3  XPCOM R: ( (dsIDebugger*)000001BD35627D80 )->startWebsocketInterface( true, *0000000DAE9FE418 = (null), *0000000DAE9FE430 = 000001BD2F9ABB20 ) = 0x00000000
0x00001494 27071 3  XPCOM C: ( (dsIWebsocket*)000001BD2F9ABB20 )->getPort( 0000000DAE9FE410 )
0x00001494 27071 3  XPCOM R: ( (dsIWebsocket*)000001BD2F9ABB20 )->getPort( *0000000DAE9FE410 = 0xD522 ) = 0x00000000
0x00002340 27071 3  XPCOM C: ( (dsIWebsocket*)000001BD2F9ABB20 )->run( 0000000DAE7FEBF0 )
0x00001494 27071 3  WBSKT D: Agent: {"data":["DS",54562],"id":0,"command":"registerModuleWebSocket"}
0x000047F0 27087 3  WBSKT D: Agent: {"response":0}
0x00001D78 27087 3  WBSKT D: Agent: {"data":["desktopMode",true],"id":1,"command":"addConfigProperty"}
0x000047F0 27087 3  WBSKT D: Agent: {"response":1}
0x00001494 27087 3  WBSKT D: Agent: {"data":["DeviceDetector"],"id":2,"command":"createSubModule"}
0x000047F0 27087 3  WBSKT D: Agent: {"data":{"port":55563},"response":2}
0x000044D4 27087 3  WBSKT D: Connecting to ws://localhost:55563 for module DeviceDetector
0x00002098 27087 3  WBSKT D: DeviceDetector open
0x00001494 27087 3  WBSKT D: DeviceDetector: {"data":[],"id":0,"command":"detectDebugProbes"}
0x00002098 27119 3  WBSKT D: DeviceDetector: {"data":{"probes":[{"connectionXml":"TIXDS110_Connection","id":"0","serialNumber":"L11008CT","comPorts":["COM9"],"overrides":{"Debug Probe Selection":"1","-- Enter the serial number":"L11008CT"}}]},"response":0}
0x00001494 27134 3  XPCOM C: ( (dsIStringEvent*)000001BD301E7ED0 )->addListener( 000001BD2BB64010 )
0x00001494 27134 3  XPCOM R: ( (dsIStringEvent*)000001BD301E7ED0 )->addListener( 000001BD2BB64010 ) = 0x00000000
0x00001494 27134 3  XPCOM C: ( (dsIStringEvent*)000001BD301E8110 )->addListener( 000001BD2BB63FB0 )
0x00001494 27134 3  XPCOM R: ( (dsIStringEvent*)000001BD301E8110 )->addListener( 000001BD2BB63FB0 ) = 0x00000000
0x00001494 27134 3  XPCOM C: ( (dsIStringEvent*)000001BD301E86B0 )->addListener( 000001BD2BB63FD0 )
0x00001494 27134 3  XPCOM R: ( (dsIStringEvent*)000001BD301E86B0 )->addListener( 000001BD2BB63FD0 ) = 0x00000000
0x00001494 27134 3  XPCOM C: ( (dsIStringEvent*)000001BD301E7540 )->addListener( 000001BD2BB64350 )
0x00001494 27134 3  XPCOM R: ( (dsIStringEvent*)000001BD301E7540 )->addListener( 000001BD2BB64350 ) = 0x00000000
0x00001494 27134 3  XPCOM C: ( (dsIObjectEvent*)000001BD301E7420 )->addListener( 000001BD2BB64390 )
0x00001494 27134 3  XPCOM R: ( (dsIObjectEvent*)000001BD301E7420 )->addListener( 000001BD2BB64390 ) = 0x00000000
0x00001494 27134 3  XPCOM C: ( (dsIObjectEvent*)000001BD301E7660 )->addListener( 000001BD2BB64B10 )
0x00001494 27134 3  XPCOM R: ( (dsIObjectEvent*)000001BD301E7660 )->addListener( 000001BD2BB64B10 ) = 0x00000000
0x00001494 27134 3  XPCOM C: ( (nsIComponentManager*)00007FFEF0132010 )->createInstanceByContractID( @ti.com/DebugProperties;1, 0000000000000000, 000001BD2BB64CB0, 0000000DAE9FE388 )
0x00001494 27134 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\DebugServer\bin\DebugProperties.dll", 0 )
0x00001494 27134 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\DebugServer\bin\XPCOMUtility.dll", 0 )
0x00001494 27134 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\DebugServer\bin\XPCOMUtility.dll", 0 ) = 00007FFEF0530000
0x00001494 27134 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\DebugServer\bin\DebugProperties.dll", 0 ) = 00007FFED9150000
0x00001494 27134 3  LIB C: dlsym( 00007FFED9150000, "NSCreateInstanceByContractID" )
0x00001494 27134 3  LIB R: dlsym( 00007FFED9150000, "NSCreateInstanceByContractID" ) = 00007FFED916C2C0
0x00001494 27134 3  XPCOM R: ( (nsIComponentManager*)00007FFEF0132010 )->createInstanceByContractID( @ti.com/DebugProperties;1, 0000000000000000, 000001BD2BB64CB0, *0000000DAE9FE388 = 000001BD3CF3FF40 ) = 0x00000000
0x00001494 27134 3  XPCOM C: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugPropertiesWithAttributes( Texas Instruments XDS110 USB Debug Probe/IcePick_C, ICEPICK_C, , 0x00000008, 000001BD36B7FA30, 000001BD36B7FA80, 0000000DAE9FE530 )
0x00001494 27150 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnDisableStatusChanged()
0x00001494 27150 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnDisableStatusChanged()
0x00001494 27150 3  XPCOM R: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugPropertiesWithAttributes( Texas Instruments XDS110 USB Debug Probe/IcePick_C, ICEPICK_C, , 0x00000008, 000001BD36B7FA30, 000001BD36B7FA80, *0000000DAE9FE530 = 000001BD2E71A140 ) = 0x00000000
0x00001494 27150 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E71A140 )->queryInterface( 000001BD2C945B10, 0000000DAE9FE478 )
0x00001494 27150 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E71A140 )->queryInterface( 000001BD2C945B10, *0000000DAE9FE478 = 000001BD2E71A148 ) = 0x00000000
0x00001494 27150 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2E71A148 )->onDisableStatusChanged( 0000000DAE9FE450 )
0x00001494 27150 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2E71A148 )->onDisableStatusChanged( *0000000DAE9FE450 = 000001BD294815F0 ) = 0x00000000
0x00001494 27150 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2E71A148 )->onPropertyValueChanged( 0000000DAE9FE450 )
0x00001494 27150 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2E71A148 )->onPropertyValueChanged( *0000000DAE9FE450 = 000001BD29481200 ) = 0x00000000
0x00001494 27150 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E71A140 )->restoreDefault()
0x00001494 27150 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E71A140 )->restoreDefault() = 0x00000000
0x00001494 27150 3  XPCOM C: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugPropertiesWithAttributes( Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, CS_DAP, , 0x0000000A, 000001BD2EA1AB70, 000001BD2EA1BA10, 0000000DAE9FE530 )
0x00001494 27150 3  XPCOM R: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugPropertiesWithAttributes( Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, CS_DAP, , 0x0000000A, 000001BD2EA1AB70, 000001BD2EA1BA10, *0000000DAE9FE530 = 000001BD2E71A480 ) = 0x00000000
0x00001494 27150 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E71A480 )->queryInterface( 000001BD2C946370, 0000000DAE9FE478 )
0x00001494 27150 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E71A480 )->queryInterface( 000001BD2C946370, *0000000DAE9FE478 = 000001BD2E71A488 ) = 0x00000000
0x00001494 27150 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2E71A488 )->onDisableStatusChanged( 0000000DAE9FE450 )
0x00001494 27150 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2E71A488 )->onDisableStatusChanged( *0000000DAE9FE450 = 000001BD294810E0 ) = 0x00000000
0x00001494 27150 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2E71A488 )->onPropertyValueChanged( 0000000DAE9FE450 )
0x00001494 27150 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2E71A488 )->onPropertyValueChanged( *0000000DAE9FE450 = 000001BD29481440 ) = 0x00000000
0x00001494 27150 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E71A480 )->restoreDefault()
0x00001494 27150 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E71A480 )->restoreDefault() = 0x00000000
0x00001494 27150 3  XPCOM C: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugPropertiesWithAttributes( Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, Cortex_M4, , 0x00000009, 000001BD29D0ED40, 000001BD29D13430, 0000000DAE9FE530 )
0x00001494 27166 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnPropertyChanged()
0x00001494 27166 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnPropertyChanged()
0x00001494 27166 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnDisableStatusChanged()
0x00001494 27166 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnDisableStatusChanged()
0x00001494 27166 3  XPCOM R: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugPropertiesWithAttributes( Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, Cortex_M4, , 0x00000009, 000001BD29D0ED40, 000001BD29D13430, *0000000DAE9FE530 = 000001BD2E71A2E0 ) = 0x00000000
0x00001494 27166 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E71A2E0 )->queryInterface( 000001BD2C947790, 0000000DAE9FE478 )
0x00001494 27166 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E71A2E0 )->queryInterface( 000001BD2C947790, *0000000DAE9FE478 = 000001BD2E71A2E8 ) = 0x00000000
0x00001494 27166 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2E71A2E8 )->onDisableStatusChanged( 0000000DAE9FE450 )
0x00001494 27166 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2E71A2E8 )->onDisableStatusChanged( *0000000DAE9FE450 = 000001BD2B550460 ) = 0x00000000
0x00001494 27166 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2E71A2E8 )->onPropertyValueChanged( 0000000DAE9FE450 )
0x00001494 27166 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2E71A2E8 )->onPropertyValueChanged( *0000000DAE9FE450 = 000001BD2B54FF50 ) = 0x00000000
0x00001494 27166 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E71A2E0 )->restoreDefault()
0x00001494 27166 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E71A2E0 )->restoreDefault() = 0x00000000
0x00001494 27166 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E71A2E0 )->loadSettings( <?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<PropertyValues>
  <property id="AutoRunToLabelOnReset">
    <curValue>1</curValue>
  </property>
  <property id="ConnectOnStartup">
  </property>
  <property id="EnableInstalledBreakpoint">
  </property>
  <property id="IgnoreSoftLaunchFailures">
    <curValue>0</curValue>
  </property>
  <property id="FlashVerboseMode">
  </property>
</PropertyValues>
0x00001494 27166 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnPropertyValueChanged()
0x00001494 27166 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnPropertyValueChanged()
0x00001494 27166 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E71A2E0 )->loadSettings( <?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<PropertyValues>
  </property>
  </property>
  </property>
  </property>
  </property>
</PropertyValues>
 ) = 0x00000000
0x00001494 27166 3  XPCOM C: ( (dsIDebugger*)000001BD35627D80 )->configure( C:\Users\o.gaste\workspace_v12\project_zero_CC26X2R1_LAUNCHXL_tirtos7_ticlang\targetConfigs\CC2642R1F.ccxml, false )
0x00001494 27166 3  PERF I: Configure starting...
0x00001494 27166 3  COM_DBG_IF C: class dsDebugger::OnTaskStart()
0x00001494 27166 3  XPCOM C: ( (dsIObjectEventCallback*)000001BD358D8FB0 )->onEvent( 000001BD30074F40 )
0x00001494 27166 3  XPCOM C: ( (nsISupports*)000001BD30074F48 )->queryInterface( 000001BD2C948270, 0000000DAE9FC148 )
0x00001494 27166 3  XPCOM R: ( (nsISupports*)000001BD30074F48 )->queryInterface( 000001BD2C948270, *0000000DAE9FC148 = 000001BD30074F40 ) = 0x00000000
0x00001494 27166 3  XPCOM C: ( (dsIProgressTask*)000001BD30074F40 )->onCompleted( 0000000DAE9FC0C0 )
0x00001494 27166 3  XPCOM R: ( (dsIProgressTask*)000001BD30074F40 )->onCompleted( *0000000DAE9FC0C0 = 000001BD2B550A00 ) = 0x00000000
0x00001494 27166 3  XPCOM C: ( (dsIProgressTask*)000001BD30074F40 )->onUpdate( 0000000DAE9FC0C0 )
0x00001494 27166 3  XPCOM R: ( (dsIProgressTask*)000001BD30074F40 )->onUpdate( *0000000DAE9FC0C0 = 000001BD2B550190 ) = 0x00000000
0x00001494 27166 3  XPCOM C: ( (dsIProgressTask*)000001BD30074F40 )->Name( 0000000DAE9FC1B0 )
0x00001494 27166 3  XPCOM R: ( (dsIProgressTask*)000001BD30074F40 )->Name( *0000000DAE9FC1B0 = Configuring Debugger (may take a few minutes on first launch)... ) = 0x00000000
0x00001494 27166 3  XPCOM C: ( (dsIProgressTask*)000001BD30074F40 )->SubActivity( 0000000DAE9FC120 )
0x00001494 27166 3  XPCOM R: ( (dsIProgressTask*)000001BD30074F40 )->SubActivity( *0000000DAE9FC120 =  ) = 0x00000000
0x00001494 27166 3  XPCOM C: ( (dsIProgressTask*)000001BD30074F40 )->CanCancel( 0000000DAE9FC120 )
0x00001494 27166 3  XPCOM R: ( (dsIProgressTask*)000001BD30074F40 )->CanCancel( *0000000DAE9FC120 = false ) = 0x00000000
0x00001494 27166 3  XPCOM C: ( (dsIProgressTask*)000001BD30074F40 )->Task( 0000000DAE9FC120 )
0x00001494 27166 3  XPCOM R: ( (dsIProgressTask*)000001BD30074F40 )->Task( *0000000DAE9FC120 =  ) = 0x00000000
0x00001494 27166 3  XPCOM C: ( (dsIProgressTask*)000001BD30074F40 )->HasPercentCompletion( 0000000DAE9FC120 )
0x00001494 27166 3  XPCOM R: ( (dsIProgressTask*)000001BD30074F40 )->HasPercentCompletion( *0000000DAE9FC120 = false ) = 0x00000000
0x00001494 27166 3  XPCOM C: ( (dsIStringEvent*)000001BD2B550A00 )->addListener( 000001BD2C948CD0 )
0x00001494 27166 3  XPCOM R: ( (dsIStringEvent*)000001BD2B550A00 )->addListener( 000001BD2C948CD0 ) = 0x00000000
0x00001494 27166 3  XPCOM C: ( (dsIObjectEvent*)000001BD2B550190 )->addListener( 000001BD2C948D10 )
0x00001494 27166 3  XPCOM R: ( (dsIObjectEvent*)000001BD2B550190 )->addListener( 000001BD2C948D10 ) = 0x00000000
0x00001494 27166 3  XPCOM R: ( (dsIObjectEventCallback*)000001BD358D8FB0 )->onEvent( 000001BD30074F40 ) = 0x00000000
0x00001494 27166 3  COM_DBG_IF R: class dsDebugger::OnTaskStart()
0x00001494 27166 3  XPCOM R: ( (dsIDebugger*)000001BD35627D80 )->configure( C:\Users\o.gaste\workspace_v12\project_zero_CC26X2R1_LAUNCHXL_tirtos7_ticlang\targetConfigs\CC2642R1F.ccxml, false ) = 0x00000000
0x00001CD4 27181 3  COM_DBG_IF C: class CoProgressTask::OnUpdate()
0x00001CD4 27181 3  XPCOM C: ( (dsIObjectEventCallback*)000001BD358DA030 )->onEvent( 000001BD2AF8AFA0 )
0x00001CD4 27181 3  XPCOM C: ( (nsISupports*)000001BD2AF8AFA8 )->queryInterface( 000001BD358A0C60, 0000000DAD8FB6D8 )
0x00001CD4 27181 3  XPCOM R: ( (nsISupports*)000001BD2AF8AFA8 )->queryInterface( 000001BD358A0C60, *0000000DAD8FB6D8 = 000001BD2AF8AFA0 ) = 0x00000000
0x00001CD4 27181 3  XPCOM C: ( (dsIProgressTaskData*)000001BD2AF8AFA0 )->PercentDone( 0000000DAD8FB730 )
0x00001CD4 27181 3  XPCOM R: ( (dsIProgressTaskData*)000001BD2AF8AFA0 )->PercentDone( *0000000DAD8FB730 = 0x00000000 ) = 0x00000000
0x00001CD4 27181 3  XPCOM C: ( (dsIProgressTaskData*)000001BD2AF8AFA0 )->SubActivity( 0000000DAD8FB730 )
0x00001CD4 27181 3  XPCOM R: ( (dsIProgressTaskData*)000001BD2AF8AFA0 )->SubActivity( *0000000DAD8FB730 = Initializing Register Database... ) = 0x00000000
0x00001CD4 27181 3  XPCOM R: ( (dsIObjectEventCallback*)000001BD358DA030 )->onEvent( 000001BD2AF8AFA0 ) = 0x00000000
0x00001CD4 27181 3  COM_DBG_IF R: class CoProgressTask::OnUpdate()
0x00001CD4 27181 3  SETUP C: OpenDatabase( C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\targetdb.dat, C:\ti\ccs1200\ccs\ccs_base\common\targetdb\timestamp )
0x00001CD4 27181 3  SETUP I: SELECT sql FROM sqlite_master ORDER BY tbl_name, name
0x00001CD4 27181 3  SETUP R: OpenDatabase( C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\targetdb.dat, C:\ti\ccs1200\ccs\ccs_base\common\targetdb\timestamp ) = 000001BD2B44CEB0
0x00001CD4 27181 3  SETUP I: Loading repository "C:\ti\ccs1200\ccs\ccs_base\common\targetdb\"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Repositories
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Repositories WHERE dbid=1
0x00001CD4 27181 3  SETUP I: PRAGMA journal_mode = MEMORY
0x00001CD4 27181 3  SETUP I: PRAGMA synchronous = OFF
0x00001CD4 27181 3  SETUP I: BEGIN IMMEDIATE TRANSACTION
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="CS_DAP_0_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=1
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="CS_DAP_PC_0_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=2
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_C_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=3
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_D_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=4
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_M_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=5
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="regids_mapping.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=6
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2000_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=7
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2001_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=8
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2002_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=9
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2003_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=10
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2004_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=11
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2005_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=12
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2006_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=13
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2007_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=14
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2008_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=15
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2010_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=16
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2011_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=17
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2012_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=18
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2013_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=19
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2014_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=20
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2015_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=21
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2026_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=22
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2027_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=23
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2028_regids.xml"
0x00001CD4 27181 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=24
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2029_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=25
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2030_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=26
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2031_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=27
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2032_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=28
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS225C00_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=29
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS225C100_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=30
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C28XX_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=31
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C55XX_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=32
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C64XX_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=33
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C66XX_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=34
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C674X_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=35
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C6XXX_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=36
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C71XX_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=37
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C75XX_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=38
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS3CXX_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=39
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R15X_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=40
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R25X_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=41
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R2X_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=42
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R33X_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=43
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R4X_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=44
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R53X_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=45
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R7X_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=46
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R9X_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=47
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RAX_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=48
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RCX_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=49
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RDX_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=50
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470REX_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=51
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RXX_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=52
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C40XX_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=53
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C41XX_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=54
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C4X_regids.xml"
0x00001CD4 27197 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=55
0x00001CD4 27197 3  SETUP I: END TRANSACTION
0x00001CD4 27197 3  SETUP I: SELECT count(*) FROM TargetDB_Files WHERE State=0
0x00001CD4 27197 3  SETUP I: Scrubbing database
0x00001CD4 27213 3  SETUP I: Loading file "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\2910475632580809234.cache"
0x00001CD4 27213 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="2910475632580809234.cache"
0x00001CD4 27213 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=116
0x00001CD4 27213 3  SETUP I: SELECT count(*) FROM TargetDB_Files WHERE State=0
0x00001CD4 27213 3  SETUP I: SELECT Systems.dbid FROM Systems, TargetDB_Files WHERE Systems.Source_File = TargetDB_Files.dbid AND TargetDB_Files.dbid = 116
0x00001CD4 27213 3  SETUP I: SELECT * FROM Systems WHERE dbid=9
0x00001CD4 27213 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\analysis\bin\ctools.dll", 0 )
0x00001CD4 27213 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\analysis\bin\ctools.dll", 0 ) = 00007FFEDF0F0000
0x00001CD4 27213 3  LIB C: dlsym( 00007FFEDF0F0000, "GetcToolsMgrIFDS" )
0x00001CD4 27213 3  LIB R: dlsym( 00007FFEDF0F0000, "GetcToolsMgrIFDS" ) = 00007FFEDF184760
0x00001CD4 27213 3  LIB C: dlsym( 00007FFEDF0F0000, "GetcToolsJobMgrIFDS" )
0x00001CD4 27213 3  LIB R: dlsym( 00007FFEDF0F0000, "GetcToolsJobMgrIFDS" ) = 00007FFEDF183B80
0x00001CD4 27213 3  LIB C: dlsym( 00007FFEDF0F0000, "SetDebugProperty" )
0x00001CD4 27213 3  LIB R: dlsym( 00007FFEDF0F0000, "SetDebugProperty" ) = 00007FFEDF184820
0x00001CD4 27213 3  CT C: GetcToolsMgrIFDS( 0000000DAD8FD628 )
0x00001CD4 27213 3  CT R: GetcToolsMgrIFDS( *0000000DAD8FD628 = 000001BD36C718B0 )
0x00001CD4 27213 3  CT C: GetcToolsJobMgrIFDS( 0000000DAD8FD630 )
0x00001CD4 27228 3  CT R: GetcToolsJobMgrIFDS( *0000000DAD8FD630 = 000001BD30369778 )
0x00001CD4 27228 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\analysis\bin\AETProperties.dll", 0 )
0x00001CD4 27228 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\analysis\bin\AETProperties.dll", 0 ) = 00007FFEDF810000
0x00001CD4 27228 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\DebugServer\bin\GTIRemoteProxy.dll", 0 )
0x00001CD4 27228 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\DebugServer\bin\GTIRemoteProxy.dll", 0 ) = 00007FFEDE6B0000
0x00001CD4 27228 3  LIB C: dlsym( 00007FFEDE6B0000, "remote_dlopen" )
0x00001CD4 27228 3  LIB R: dlsym( 00007FFEDE6B0000, "remote_dlopen" ) = 00007FFEDE6B4070
0x00001CD4 27228 3  LIB C: dlsym( 00007FFEDE6B0000, "remote_dlsym" )
0x00001CD4 27228 3  LIB R: dlsym( 00007FFEDE6B0000, "remote_dlsym" ) = 00007FFEDE6B44F0
0x00001CD4 27228 3  LIB C: dlsym( 00007FFEDE6B0000, "remote_dlclose" )
0x00001CD4 27228 3  LIB R: dlsym( 00007FFEDE6B0000, "remote_dlclose" ) = 00007FFEDE6B48A0
0x00001CD4 27228 3  LIB C: dlsym( 00007FFEDE6B0000, "remote_dlerror" )
0x00001CD4 27228 3  LIB R: dlsym( 00007FFEDE6B0000, "remote_dlerror" ) = 00007FFEDE6B4930
0x00001CD4 27228 3  GTI C: remote_dlopen( "" )
0x00001CD4 27228 3  GTI R: remote_dlopen( "" ) = 0x0000000000000000
0x00001CD4 27228 3  GTI C: remote_dlerror()
0x00001CD4 27228 3  GTI R: remote_dlerror() = ""
0x00001CD4 27228 3  GTI C: remote_dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510icepick_c.dvr" )
0x00001CD4 27228 3  GTI R: remote_dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510icepick_c.dvr" ) = 0x0000000000000000
0x00001CD4 27228 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510icepick_c.dvr", 0 )
0x00001CD4 27228 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510icepick_c.dvr", 0 ) = 000001BD38E30000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_BOARD_DATA_FILE_VERSION" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_BOARD_DATA_FILE_VERSION" ) = 000001BD38E333D0
0x00001CD4 27228 3  GTI C: GTI_GET_BOARD_DATA_FILE_VERSION( 0x0000000000000000 )
0x00001CD4 27228 3  GTI R: GTI_GET_BOARD_DATA_FILE_VERSION( 0x0000000000000000 ) = 0x00000002
0x00001CD4 27228 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\common\uscif\jtagdata.dll", 0 )
0x00001CD4 27228 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\common\uscif\jtagdata.dll", 0 ) = 000001BD38ED0000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38ED0000, "JTAGDataUM_AddFile" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38ED0000, "JTAGDataUM_AddFile" ) = 000001BD38ED2250
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38ED0000, "JTAGDataUM_AddVariable" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38ED0000, "JTAGDataUM_AddVariable" ) = 000001BD38ED21E0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38ED0000, "JTAGDataUM_CreateJtagDeviceList" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38ED0000, "JTAGDataUM_CreateJtagDeviceList" ) = 000001BD38ED2150
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38ED0000, "JTAGDataUM_GetErrorString" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38ED0000, "JTAGDataUM_GetErrorString" ) = 000001BD38ED2370
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38ED0000, "JTAGDataUM_Output" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38ED0000, "JTAGDataUM_Output" ) = 000001BD38ED2320
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38ED0000, "JTAGDataUM_DestroyJtagDeviceList" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38ED0000, "JTAGDataUM_DestroyJtagDeviceList" ) = 000001BD38ED21B0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38ED0000, "JTAGDataUM_AddDevice" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38ED0000, "JTAGDataUM_AddDevice" ) = 000001BD38ED2290
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38ED0000, "JTAGDataUM_AddDeviceEx" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38ED0000, "JTAGDataUM_AddDeviceEx" ) = 000001BD38ED22A0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38ED0000, "JTAGDataUM_AddSubpath" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38ED0000, "JTAGDataUM_AddSubpath" ) = 000001BD38ED22C0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38ED0000, "JTAGDataUM_AddVariableEx" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38ED0000, "JTAGDataUM_AddVariableEx" ) = 000001BD38ED21F0
0x00001CD4 27228 3  GTI C: JTAGData_CreateJtagDeviceList()
0x00001CD4 27228 3  GTI R: JTAGData_CreateJtagDeviceList() = 000001BD3023E950
0x00001CD4 27228 3  GTI C: JTAGData_AddVariable( 000001BD3023E950, BOARD_DATAFILE_VERSION, *0000000DAD8FD550 = 2 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariable( 000001BD3023E950, BOARD_DATAFILE_VERSION, *0000000DAD8FD550 = 2 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, SEPK.POD_DRVR, jioxds110.dll )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, SEPK.POD_DRVR, jioxds110.dll ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, SEPK.POD_PORT, 0 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, SEPK.POD_PORT, 0 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, SEPK.POD_SUPPLY, 1 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, SEPK.POD_SUPPLY, 1 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, SEPK.POD_VOLTAGE_SELECTION, 1 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, SEPK.POD_VOLTAGE_SELECTION, 1 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, SEPK.POD_VOLTAGE, 3.3 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, SEPK.POD_VOLTAGE, 3.3 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, SEPK.POD_POWER_ISOLATE, 0 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, SEPK.POD_POWER_ISOLATE, 0 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, PRODUCT.TITLE, Texas Instruments XDS110 USB )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, PRODUCT.TITLE, Texas Instruments XDS110 USB ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, PRODUCT.ALIAS, TI_XDS110_USB )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, PRODUCT.ALIAS, TI_XDS110_USB ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, PRODUCT.NAME, XDS110 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, PRODUCT.NAME, XDS110 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, USCIF.TDOEDGE, FALL )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, USCIF.TDOEDGE, FALL ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, USCIF.TCLK_PROGRAM, DEFAULT )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, USCIF.TCLK_PROGRAM, DEFAULT ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, USCIF.TCLK_FREQUENCY, 5.5MHz )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, USCIF.TCLK_FREQUENCY, 5.5MHz ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, USCIF.JTAG_ISOLATE, disable )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, USCIF.JTAG_ISOLATE, disable ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, DOT7.DTS_USAGE, enable )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, DOT7.DTS_USAGE, enable ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, DOT7.DTS_TYPE, xds110 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, DOT7.DTS_TYPE, xds110 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, DOT7.DTS_PROGRAM, emulator )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, DOT7.DTS_PROGRAM, emulator ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, DOT7.DTS_FREQUENCY, 1.0MHz )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, DOT7.DTS_FREQUENCY, 1.0MHz ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, DOT7.TS_FORMAT, oscan2 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, DOT7.TS_FORMAT, oscan2 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, DOT7.TS_PIN_WIDTH, only_two )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, DOT7.TS_PIN_WIDTH, only_two ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, SWD.SWD_DEBUG, disabled )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, SWD.SWD_DEBUG, disabled ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, SWD.SWO_DATA, tdo_pin )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, SWD.SWO_DATA, tdo_pin ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, SWD.SWJ_DP_DEFAULT_MODE, 0 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, SWD.SWJ_DP_DEFAULT_MODE, 0 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddDeviceEx( 000001BD3023E950, IcePick_C, 240, 2, 0, 5, ROUTER, 4294967295, 0, 2 )
0x00001CD4 27228 3  GTI R: JTAGData_AddDeviceEx( 000001BD3023E950, IcePick_C, 240, 2, 0, 5, ROUTER, 4294967295, 0, 2 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, device.SystemResetSupported, 1 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, device.SystemResetSupported, 1 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, device.SystemResetWhileConnected, 1 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, device.SystemResetWhileConnected, 1 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddSubpath( 000001BD3023E950, subpath_2, IcePick_C, 1 )
0x00001CD4 27228 3  GTI R: JTAGData_AddSubpath( 000001BD3023E950, subpath_2, IcePick_C, 1 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, subpath.address, 0x0 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, subpath.address, 0x0 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, subpath.initial, 0 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, subpath.initial, 0 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, subpath.custom, 1 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, subpath.custom, 1 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, subpath.force, 1 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, subpath.force, 1 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, subpath.cancelreset, 0x1 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, subpath.cancelreset, 0x1 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddDevice( 000001BD3023E950, bypass_0, 1023, 4095, 127, 7, BYPASS, 4 )
0x00001CD4 27228 3  GTI R: JTAGData_AddDevice( 000001BD3023E950, bypass_0, 1023, 4095, 127, 7, BYPASS, 4 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddSubpath( 000001BD3023E950, subpath_0, IcePick_C, 1 )
0x00001CD4 27228 3  GTI R: JTAGData_AddSubpath( 000001BD3023E950, subpath_0, IcePick_C, 1 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, subpath.address, 0x10 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, subpath.address, 0x10 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddDeviceEx( 000001BD3023E950, CS_DAP_0, 224, 1, 0, 5, ROUTER, 4294967295, 0, 1 )
0x00001CD4 27228 3  GTI R: JTAGData_AddDeviceEx( 000001BD3023E950, CS_DAP_0, 224, 1, 0, 5, ROUTER, 4294967295, 0, 1 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, device.identify, 0x4ba00477 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, device.identify, 0x4ba00477 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, device.Revision, Legacy )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, device.Revision, Legacy ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddSubpath( 000001BD3023E950, subpath_1, CS_DAP_0, 1 )
0x00001CD4 27228 3  GTI R: JTAGData_AddSubpath( 000001BD3023E950, subpath_1, CS_DAP_0, 1 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, subpath.type, debug )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, subpath.type, debug ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, subpath.pseudo, 0 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, subpath.pseudo, 0 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddDevice( 000001BD3023E950, Cortex_M4_0, 470, 14, 0, 0, DSP_CPU, -1 )
0x00001CD4 27228 3  GTI R: JTAGData_AddDevice( 000001BD3023E950, Cortex_M4_0, 470, 14, 0, 0, DSP_CPU, -1 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, device.identify, 0x02000000 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, device.identify, 0x02000000 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_AddVariableEx( 000001BD3023E950, device.traceId, 0x0 )
0x00001CD4 27228 3  GTI R: JTAGData_AddVariableEx( 000001BD3023E950, device.traceId, 0x0 ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_Output( 000001BD3023E950, C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat )
0x00001CD4 27228 3  GTI R: JTAGData_Output( 000001BD3023E950, C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat ) = 1
0x00001CD4 27228 3  GTI C: JTAGData_DestroyJtagDeviceList( 000001BD3023E950 )
0x00001CD4 27228 3  GTI R: JTAGData_DestroyJtagDeviceList( 000001BD3023E950 ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_VALIDATE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_VALIDATE" ) = 000001BD38E33310
0x00001CD4 27228 3  GTI C: GTI_VALIDATE( 0x0000000000000000, 0x00000029 )
0x00001CD4 27228 3  GTI R: GTI_VALIDATE( 0x0000000000000000, 0x00000029 ) = 0x00000029
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SET_DB_ACCESS" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SET_DB_ACCESS" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_SET_DB_ACCESS" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_SET_DB_ACCESS" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_INIT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_INIT" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_INIT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_INIT" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_QUIT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_QUIT" ) = 000001BD38E35020
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GETERRSTR" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GETERRSTR" ) = 000001BD38E33A10
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_RESET" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_RESET" ) = 000001BD38E39150
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_STEP" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_STEP" ) = 000001BD38E390D0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_RUN" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_RUN" ) = 000001BD38E398F0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GLOBALSTART" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GLOBALSTART" ) = 000001BD38E39140
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_STAT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_STAT" ) = 000001BD38E38E80
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_READREG" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_READREG" ) = 000001BD38E357F0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_WRITEREG" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_WRITEREG" ) = 000001BD38E35890
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_READMEM" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_READMEM" ) = 000001BD38E39A60
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_WRITEMEM" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_WRITEMEM" ) = 000001BD38E39A50
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SETBP" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SETBP" ) = 000001BD38E38E40
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_CLEARBP" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_CLEARBP" ) = 000001BD38E38E60
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SETBP_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SETBP_EX" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_SETBP_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_SETBP_EX" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_CLEARBP_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_CLEARBP_EX" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_CLEARBP_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_CLEARBP_EX" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_HALT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_HALT" ) = 000001BD38E38FD0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_ADD_MEMMAP" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_ADD_MEMMAP" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_ADD_MEMMAP" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_ADD_MEMMAP" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_CLEAR_MEMMAP" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_CLEAR_MEMMAP" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_CLEAR_MEMMAP" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_CLEAR_MEMMAP" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_RESET_MEMMAP" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_RESET_MEMMAP" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_RESET_MEMMAP" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_RESET_MEMMAP" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_INIT3" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_INIT3" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_INIT3" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_INIT3" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_INIT_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_INIT_EX" ) = 000001BD38E34F10
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_RUN_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_RUN_EX" ) = 000001BD38E39040
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_READMEM_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_READMEM_EX" ) = 000001BD38E39A20
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_WRITEMEM_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_WRITEMEM_EX" ) = 000001BD38E39A40
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_READMEM_BLK" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_READMEM_BLK" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_READMEM_BLK" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_READMEM_BLK" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_WRITEMEM_BLK" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_WRITEMEM_BLK" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_WRITEMEM_BLK" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_WRITEMEM_BLK" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GETPROCTYPE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GETPROCTYPE" ) = 000001BD38E32D30
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GETREV" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GETREV" ) = 000001BD38E32D20
0x00001CD4 27228 3 IcePick_C GTI C: GTI_GETREV( 0x0000000000000000 )
0x00001CD4 27228 3 IcePick_C GTI R: GTI_GETREV( 0x0000000000000000 ) = 0x00003200
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SET_PROFILE_TYPE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SET_PROFILE_TYPE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_SET_PROFILE_TYPE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_SET_PROFILE_TYPE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_NUM_PROFILE_TYPES" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_NUM_PROFILE_TYPES" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_NUM_PROFILE_TYPES" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_NUM_PROFILE_TYPES" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_PROFILE_TYPE_NAME" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_PROFILE_TYPE_NAME" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_PROFILE_TYPE_NAME" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_PROFILE_TYPE_NAME" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_NUM_HBP_TYPES" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_NUM_HBP_TYPES" ) = 000001BD38E33080
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_HBP_TYPE_NAME" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_HBP_TYPE_NAME" ) = 000001BD38E33090
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_ENABLE_GLOBAL_BKPTS" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_ENABLE_GLOBAL_BKPTS" ) = 000001BD38E330B0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_WAS_HBP_HIT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_WAS_HBP_HIT" ) = 000001BD38E330A0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_WAS_HBP_HIT_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_WAS_HBP_HIT_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_WAS_HBP_HIT_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_WAS_HBP_HIT_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_REALTIME_SWITCH" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_REALTIME_SWITCH" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_REALTIME_SWITCH" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_REALTIME_SWITCH" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GETBOARDINFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GETBOARDINFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GETBOARDINFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GETBOARDINFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_LOOKUP_REG_BY_NAME" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_LOOKUP_REG_BY_NAME" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_LOOKUP_REG_BY_NAME" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_LOOKUP_REG_BY_NAME" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GETPROCINFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GETPROCINFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GETPROCINFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GETPROCINFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_PROC_ID" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_PROC_ID" ) = 000001BD38E32D40
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_PROC_MINOR_ID" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_PROC_MINOR_ID" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_PROC_MINOR_ID" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_PROC_MINOR_ID" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_EXT_CAPABILITIES" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_EXT_CAPABILITIES" ) = 000001BD38E32D50
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_TARGET_PROPERTIES" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_TARGET_PROPERTIES" ) = 000001BD38E32D70
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_SIM_MODE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_SIM_MODE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_SIM_MODE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_SIM_MODE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SET_SIM_MODE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SET_SIM_MODE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_SET_SIM_MODE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_SET_SIM_MODE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GETERRSTR_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GETERRSTR_EX" ) = 000001BD38E339F0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GETERRSTR_EX2" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GETERRSTR_EX2" ) = 000001BD38E33B00
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SETERRRESPONSE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SETERRRESPONSE" ) = 000001BD38E338D0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GETERRSTR_EX3" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GETERRSTR_EX3" ) = 000001BD38E333E0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_PROCESS_GEL_COMMAND" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_PROCESS_GEL_COMMAND" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_PROCESS_GEL_COMMAND" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_PROCESS_GEL_COMMAND" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_PROCESS_GEL_COMMAND_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_PROCESS_GEL_COMMAND_EX" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_PROCESS_GEL_COMMAND_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_PROCESS_GEL_COMMAND_EX" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_EMURESET_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_EMURESET_EX" ) = 000001BD38E32F40
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_EMURESET_EX2" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_EMURESET_EX2" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_EMURESET_EX2" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_EMURESET_EX2" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_CONNECT2" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_CONNECT2" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_CONNECT2" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_CONNECT2" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_CONNECT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_CONNECT" ) = 000001BD38E350E0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_CONNECT3" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_CONNECT3" ) = 000001BD38E35120
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_DISCONNECT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_DISCONNECT" ) = 000001BD38E35180
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_DISCONNECT2" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_DISCONNECT2" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_DISCONNECT2" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_DISCONNECT2" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_DONE_REMOVING_DEBUG_STATE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_DONE_REMOVING_DEBUG_STATE" ) = 000001BD38E38E70
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_CONTEXT_CONST" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_CONTEXT_CONST" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_CONTEXT_CONST" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_CONTEXT_CONST" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_EXEC_PACKET_INFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_EXEC_PACKET_INFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_EXEC_PACKET_INFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_EXEC_PACKET_INFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_EXEC_PACKET_INFO_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_EXEC_PACKET_INFO_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_EXEC_PACKET_INFO_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_EXEC_PACKET_INFO_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_READMEM_WITH_STAT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_READMEM_WITH_STAT" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_READMEM_WITH_STAT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_READMEM_WITH_STAT" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_WRITEMEM_WITH_STAT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_WRITEMEM_WITH_STAT" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_WRITEMEM_WITH_STAT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_WRITEMEM_WITH_STAT" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_READMEM_WITH_STAT_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_READMEM_WITH_STAT_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_READMEM_WITH_STAT_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_READMEM_WITH_STAT_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_WRITEMEM_WITH_STAT_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_WRITEMEM_WITH_STAT_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_WRITEMEM_WITH_STAT_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_WRITEMEM_WITH_STAT_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_QUERY_INTERFACE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_QUERY_INTERFACE" ) = 000001BD38E353B0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_BLOCK_RESET" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_BLOCK_RESET" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_BLOCK_RESET" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_BLOCK_RESET" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" ) = 000001BD38E39400
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SET_ROUTER_SYSTEM_FEATURE" ) = 000001BD38E39780
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_ROUTER_SYSTEM_FEATURE" ) = 000001BD38E39810
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_WAIT_IN_RESET_MODE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_WAIT_IN_RESET_MODE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_WAIT_IN_RESET_MODE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_WAIT_IN_RESET_MODE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SET_WAIT_IN_RESET" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SET_WAIT_IN_RESET" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_SET_WAIT_IN_RESET" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_SET_WAIT_IN_RESET" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_STAT_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_STAT_EX" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_STAT_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_STAT_EX" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_BP_TEST" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_BP_TEST" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_BP_TEST" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_BP_TEST" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_STAT_EX2" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_STAT_EX2" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_STAT_EX2" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_STAT_EX2" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_NUM_RESETS" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_NUM_RESETS" ) = 000001BD38E39240
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_RESET_INFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_RESET_INFO" ) = 000001BD38E39280
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_RESET_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_RESET_EX" ) = 000001BD38E391B0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_MAKE_DEVICE_SECURE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_MAKE_DEVICE_SECURE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_MAKE_DEVICE_SECURE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_MAKE_DEVICE_SECURE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SET_PROGRESS_CALLBACK" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SET_PROGRESS_CALLBACK" ) = 000001BD38E357E0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_TARGET_VOLTAGE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_TARGET_VOLTAGE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_TARGET_VOLTAGE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_TARGET_VOLTAGE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_MEM_LEVEL_INFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_MEM_LEVEL_INFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_MEM_LEVEL_INFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_MEM_LEVEL_INFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_NON_INTRUSIVE_CAPABILITIES" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_NON_INTRUSIVE_CAPABILITIES" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_NON_INTRUSIVE_CAPABILITIES" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_NON_INTRUSIVE_CAPABILITIES" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SET_DIFF_FLASH_SUPPORT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SET_DIFF_FLASH_SUPPORT" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_SET_DIFF_FLASH_SUPPORT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_SET_DIFF_FLASH_SUPPORT" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_NUM_FLASH_LAYOUTS" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_NUM_FLASH_LAYOUTS" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_NUM_FLASH_LAYOUTS" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_NUM_FLASH_LAYOUTS" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_FLASH_LAYOUT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_FLASH_LAYOUT" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_FLASH_LAYOUT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_FLASH_LAYOUT" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_DSPEVENT2" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_DSPEVENT2" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_DSPEVENT2" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_DSPEVENT2" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GETCAPABILITIES" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GETCAPABILITIES" ) = 000001BD38E330D0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_MMU_STATE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_MMU_STATE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_MMU_STATE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_MMU_STATE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SET_MMU_STATE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SET_MMU_STATE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_SET_MMU_STATE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_SET_MMU_STATE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_NUM_MMU_TTBR_REGS" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_NUM_MMU_TTBR_REGS" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_NUM_MMU_TTBR_REGS" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_NUM_MMU_TTBR_REGS" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_TTBR_REG" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_TTBR_REG" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_TTBR_REG" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_TTBR_REG" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SET_TTBR_REG" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SET_TTBR_REG" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_SET_TTBR_REG" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_SET_TTBR_REG" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_CURRENT_PROCID" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_CURRENT_PROCID" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SET_CURRENT_PROCID" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_SET_CURRENT_PROCID" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_SET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_NUM_MMU_DOMAINS" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_NUM_MMU_DOMAINS" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_NUM_MMU_DOMAINS" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_NUM_MMU_DOMAINS" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_DOMAIN_ACCESS" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_DOMAIN_ACCESS" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SET_DOMAIN_ACCESS" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_SET_DOMAIN_ACCESS" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_SET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SET_ALL_DOMAIN_ACCESS" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SET_ALL_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_SET_ALL_DOMAIN_ACCESS" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_SET_ALL_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_COHERENCY_CONTROL" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_COHERENCY_CONTROL" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_COHERENCY_CONTROL" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_COHERENCY_CONTROL" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_COHERENCY_CNTRL_SPECIFIC" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_COHERENCY_CNTRL_SPECIFIC" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_COHERENCY_CNTRL_SPECIFIC" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_COHERENCY_CNTRL_SPECIFIC" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SYNCRUN_REQUEST" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SYNCRUN_REQUEST" ) = 000001BD38E39890
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_NUM_SYMBOL_INFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_NUM_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_NUM_SYMBOL_INFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_NUM_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_SYMBOL_INFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_SYMBOL_INFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SET_SYMBOL_INFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_SET_SYMBOL_INFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_SET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SET_SYMBOL_INFO_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SET_SYMBOL_INFO_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_SET_SYMBOL_INFO_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_SET_SYMBOL_INFO_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_READREG_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_READREG_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_READREG_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_READREG_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_WRITEREG_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_WRITEREG_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_WRITEREG_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_WRITEREG_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_GET_PHYSICAL_PAGE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_GET_PHYSICAL_PAGE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_GET_PHYSICAL_PAGE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_GET_PHYSICAL_PAGE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SET_LOW_POWER_MODE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SET_LOW_POWER_MODE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_SET_LOW_POWER_MODE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_SET_LOW_POWER_MODE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_NOTIFY_APP_MEMORY_INFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_NOTIFY_APP_MEMORY_INFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_NOTIFY_APP_MEMORY_INFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_NOTIFY_APP_MEMORY_INFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_NOTIFY_APP_MEMORY_INFO_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_NOTIFY_APP_MEMORY_INFO_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_NOTIFY_APP_MEMORY_INFO_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_NOTIFY_APP_MEMORY_INFO_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SETBP_EX_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SETBP_EX_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_SETBP_EX_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_SETBP_EX_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_CLEARBP_EX_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_CLEARBP_EX_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_CLEARBP_EX_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_CLEARBP_EX_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_BP_TEST_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_BP_TEST_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "_GTI_BP_TEST_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "_GTI_BP_TEST_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38E30000, "GTI_SETUP_PROPERTIES" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38E30000, "GTI_SETUP_PROPERTIES" ) = 000001BD38E35920
0x00001CD4 27228 3  GTI C: GTI_SETUP_PROPERTIES( "Texas Instruments XDS110 USB Debug Probe_IcePick_C", *0x000001BD35046DA0 = "Use Board Reset", *0x000001BD35046CB0 = "1", 0x00000005 )
0x00001CD4 27228 3  GTI R: GTI_SETUP_PROPERTIES( "Texas Instruments XDS110 USB Debug Probe_IcePick_C", *0x000001BD35046DA0 = "Use Board Reset", *0x000001BD35046CB0 = "1", 0x00000005 ) = 0x00000000
0x00001CD4 27228 3 IcePick_C FLASH I: FlashProgrammerManager::Constructor
0x00001CD4 27228 3  LIB C: dlclose( 000001BD38E30000 )
0x00001CD4 27228 3  LIB R: dlclose( 000001BD38E30000 ) = 1
0x00001CD4 27228 3  GTI C: remote_dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cs_dap.dvr" )
0x00001CD4 27228 3  GTI R: remote_dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cs_dap.dvr" ) = 0x0000000000000000
0x00001CD4 27228 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cs_dap.dvr", 0 )
0x00001CD4 27228 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cs_dap.dvr", 0 ) = 000001BD38F00000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_VALIDATE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_VALIDATE" ) = 000001BD38F03320
0x00001CD4 27228 3  GTI C: GTI_VALIDATE( 0x0000000000000000, 0x00004823 )
0x00001CD4 27228 3  GTI R: GTI_VALIDATE( 0x0000000000000000, 0x00004823 ) = 0x00004823
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_SET_DB_ACCESS" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_SET_DB_ACCESS" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_SET_DB_ACCESS" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_SET_DB_ACCESS" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_INIT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_INIT" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_INIT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_INIT" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_QUIT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_QUIT" ) = 000001BD38F05060
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GETERRSTR" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GETERRSTR" ) = 000001BD38F03A50
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_RESET" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_RESET" ) = 000001BD38F0A3E0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_STEP" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_STEP" ) = 000001BD38F0A360
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_RUN" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_RUN" ) = 000001BD38F0A440
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GLOBALSTART" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GLOBALSTART" ) = 000001BD38F0A3D0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_STAT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_STAT" ) = 000001BD38F0A110
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_READREG" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_READREG" ) = 000001BD38F0A7D0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_WRITEREG" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_WRITEREG" ) = 000001BD38F0A870
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_READMEM" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_READMEM" ) = 000001BD38F05A10
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_WRITEMEM" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_WRITEMEM" ) = 000001BD38F059C0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_SETBP" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_SETBP" ) = 000001BD38F0A0B0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_CLEARBP" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_CLEARBP" ) = 000001BD38F0A0D0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_SETBP_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_SETBP_EX" ) = 000001BD38F0A0A0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_CLEARBP_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_CLEARBP_EX" ) = 000001BD38F0A0C0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_HALT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_HALT" ) = 000001BD38F0A260
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_ADD_MEMMAP" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_ADD_MEMMAP" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_ADD_MEMMAP" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_ADD_MEMMAP" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_CLEAR_MEMMAP" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_CLEAR_MEMMAP" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_CLEAR_MEMMAP" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_CLEAR_MEMMAP" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_RESET_MEMMAP" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_RESET_MEMMAP" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_RESET_MEMMAP" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_RESET_MEMMAP" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_INIT3" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_INIT3" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_INIT3" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_INIT3" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_INIT_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_INIT_EX" ) = 000001BD38F04F50
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_RUN_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_RUN_EX" ) = 000001BD38F0A2D0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_READMEM_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_READMEM_EX" ) = 000001BD38F058A0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_WRITEMEM_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_WRITEMEM_EX" ) = 000001BD38F05960
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_READMEM_BLK" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_READMEM_BLK" ) = 000001BD38F05840
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_WRITEMEM_BLK" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_WRITEMEM_BLK" ) = 000001BD38F05900
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GETPROCTYPE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GETPROCTYPE" ) = 000001BD38F02D30
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GETREV" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GETREV" ) = 000001BD38F02D20
0x00001CD4 27228 3 CS_DAP_0 GTI C: GTI_GETREV( 0x0000000000000000 )
0x00001CD4 27228 3 CS_DAP_0 GTI R: GTI_GETREV( 0x0000000000000000 ) = 0x00003200
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_SET_PROFILE_TYPE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_SET_PROFILE_TYPE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_SET_PROFILE_TYPE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_SET_PROFILE_TYPE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_NUM_PROFILE_TYPES" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_NUM_PROFILE_TYPES" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_NUM_PROFILE_TYPES" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_NUM_PROFILE_TYPES" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_PROFILE_TYPE_NAME" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_PROFILE_TYPE_NAME" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_PROFILE_TYPE_NAME" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_PROFILE_TYPE_NAME" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_NUM_HBP_TYPES" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_NUM_HBP_TYPES" ) = 000001BD38F030A0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_HBP_TYPE_NAME" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_HBP_TYPE_NAME" ) = 000001BD38F030B0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_ENABLE_GLOBAL_BKPTS" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_ENABLE_GLOBAL_BKPTS" ) = 000001BD38F030D0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_WAS_HBP_HIT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_WAS_HBP_HIT" ) = 000001BD38F030C0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_WAS_HBP_HIT_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_WAS_HBP_HIT_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_WAS_HBP_HIT_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_WAS_HBP_HIT_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_REALTIME_SWITCH" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_REALTIME_SWITCH" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_REALTIME_SWITCH" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_REALTIME_SWITCH" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GETBOARDINFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GETBOARDINFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GETBOARDINFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GETBOARDINFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_LOOKUP_REG_BY_NAME" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_LOOKUP_REG_BY_NAME" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_LOOKUP_REG_BY_NAME" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_LOOKUP_REG_BY_NAME" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GETPROCINFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GETPROCINFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GETPROCINFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GETPROCINFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_PROC_ID" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_PROC_ID" ) = 000001BD38F02D40
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_PROC_MINOR_ID" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_PROC_MINOR_ID" ) = 000001BD38F0A7A0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_EXT_CAPABILITIES" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_EXT_CAPABILITIES" ) = 000001BD38F02D50
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_TARGET_PROPERTIES" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_TARGET_PROPERTIES" ) = 000001BD38F02D70
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_SIM_MODE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_SIM_MODE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_SIM_MODE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_SIM_MODE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_SET_SIM_MODE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_SET_SIM_MODE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_SET_SIM_MODE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_SET_SIM_MODE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GETERRSTR_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GETERRSTR_EX" ) = 000001BD38F03A30
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GETERRSTR_EX2" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GETERRSTR_EX2" ) = 000001BD38F03B40
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_SETERRRESPONSE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_SETERRRESPONSE" ) = 000001BD38F03910
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GETERRSTR_EX3" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GETERRSTR_EX3" ) = 000001BD38F033F0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_PROCESS_GEL_COMMAND" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_PROCESS_GEL_COMMAND" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_PROCESS_GEL_COMMAND" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_PROCESS_GEL_COMMAND" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_PROCESS_GEL_COMMAND_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_PROCESS_GEL_COMMAND_EX" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_PROCESS_GEL_COMMAND_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_PROCESS_GEL_COMMAND_EX" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_EMURESET_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_EMURESET_EX" ) = 000001BD38F02F60
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_EMURESET_EX2" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_EMURESET_EX2" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_EMURESET_EX2" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_EMURESET_EX2" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_CONNECT2" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_CONNECT2" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_CONNECT2" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_CONNECT2" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_CONNECT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_CONNECT" ) = 000001BD38F05120
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_CONNECT3" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_CONNECT3" ) = 000001BD38F05160
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_DISCONNECT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_DISCONNECT" ) = 000001BD38F051C0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_DISCONNECT2" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_DISCONNECT2" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_DISCONNECT2" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_DISCONNECT2" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_DONE_REMOVING_DEBUG_STATE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_DONE_REMOVING_DEBUG_STATE" ) = 000001BD38F0A0E0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_CONTEXT_CONST" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_CONTEXT_CONST" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_CONTEXT_CONST" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_CONTEXT_CONST" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_EXEC_PACKET_INFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_EXEC_PACKET_INFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_EXEC_PACKET_INFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_EXEC_PACKET_INFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_EXEC_PACKET_INFO_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_EXEC_PACKET_INFO_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_EXEC_PACKET_INFO_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_EXEC_PACKET_INFO_64" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_READMEM_WITH_STAT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_READMEM_WITH_STAT" ) = 000001BD38F0C150
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_WRITEMEM_WITH_STAT" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_WRITEMEM_WITH_STAT" ) = 000001BD38F0C400
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_READMEM_WITH_STAT_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_READMEM_WITH_STAT_64" ) = 000001BD38F0C020
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_WRITEMEM_WITH_STAT_64" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_WRITEMEM_WITH_STAT_64" ) = 000001BD38F0C280
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_QUERY_INTERFACE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_QUERY_INTERFACE" ) = 000001BD38F053F0
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_BLOCK_RESET" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_BLOCK_RESET" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_BLOCK_RESET" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_BLOCK_RESET" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_SET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_SET_ROUTER_SYSTEM_FEATURE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_SET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_SET_ROUTER_SYSTEM_FEATURE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_ROUTER_SYSTEM_FEATURE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_ROUTER_SYSTEM_FEATURE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_WAIT_IN_RESET_MODE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_WAIT_IN_RESET_MODE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_WAIT_IN_RESET_MODE" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_WAIT_IN_RESET_MODE" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_SET_WAIT_IN_RESET" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_SET_WAIT_IN_RESET" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_SET_WAIT_IN_RESET" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_SET_WAIT_IN_RESET" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_STAT_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "GTI_STAT_EX" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "_GTI_STAT_EX" )
0x00001CD4 27228 3  LIB R: dlsym( 000001BD38F00000, "_GTI_STAT_EX" ) = 0000000000000000
0x00001CD4 27228 3  LIB C: dlsym( 000001BD38F00000, "GTI_BP_TEST" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_BP_TEST" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_BP_TEST" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_BP_TEST" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_STAT_EX2" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_STAT_EX2" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_STAT_EX2" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_STAT_EX2" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_NUM_RESETS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_NUM_RESETS" ) = 000001BD38F0A590
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_RESET_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_RESET_INFO" ) = 000001BD38F0A600
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_RESET_EX" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_RESET_EX" ) = 000001BD38F0A4E0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_MAKE_DEVICE_SECURE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_MAKE_DEVICE_SECURE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_MAKE_DEVICE_SECURE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_MAKE_DEVICE_SECURE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_SET_PROGRESS_CALLBACK" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_SET_PROGRESS_CALLBACK" ) = 000001BD38F05CF0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_TARGET_VOLTAGE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_TARGET_VOLTAGE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_TARGET_VOLTAGE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_TARGET_VOLTAGE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_MEM_LEVEL_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_MEM_LEVEL_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_MEM_LEVEL_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_MEM_LEVEL_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_NON_INTRUSIVE_CAPABILITIES" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_NON_INTRUSIVE_CAPABILITIES" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_NON_INTRUSIVE_CAPABILITIES" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_NON_INTRUSIVE_CAPABILITIES" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_SET_DIFF_FLASH_SUPPORT" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_SET_DIFF_FLASH_SUPPORT" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_SET_DIFF_FLASH_SUPPORT" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_SET_DIFF_FLASH_SUPPORT" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_NUM_FLASH_LAYOUTS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_NUM_FLASH_LAYOUTS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_NUM_FLASH_LAYOUTS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_NUM_FLASH_LAYOUTS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_FLASH_LAYOUT" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_FLASH_LAYOUT" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_FLASH_LAYOUT" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_FLASH_LAYOUT" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_DSPEVENT2" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_DSPEVENT2" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_DSPEVENT2" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_DSPEVENT2" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_GETCAPABILITIES" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_GETCAPABILITIES" ) = 000001BD38F030F0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_MMU_STATE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_MMU_STATE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_MMU_STATE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_MMU_STATE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_SET_MMU_STATE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_SET_MMU_STATE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_SET_MMU_STATE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_SET_MMU_STATE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_NUM_MMU_TTBR_REGS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_NUM_MMU_TTBR_REGS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_NUM_MMU_TTBR_REGS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_NUM_MMU_TTBR_REGS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_TTBR_REG" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_TTBR_REG" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_TTBR_REG" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_TTBR_REG" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_SET_TTBR_REG" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_SET_TTBR_REG" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_SET_TTBR_REG" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_SET_TTBR_REG" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_CURRENT_PROCID" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_CURRENT_PROCID" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_SET_CURRENT_PROCID" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_SET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_SET_CURRENT_PROCID" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_SET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_NUM_MMU_DOMAINS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_NUM_MMU_DOMAINS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_NUM_MMU_DOMAINS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_NUM_MMU_DOMAINS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_DOMAIN_ACCESS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_DOMAIN_ACCESS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_SET_DOMAIN_ACCESS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_SET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_SET_DOMAIN_ACCESS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_SET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_SET_ALL_DOMAIN_ACCESS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_SET_ALL_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_SET_ALL_DOMAIN_ACCESS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_SET_ALL_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_COHERENCY_CONTROL" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_COHERENCY_CONTROL" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_COHERENCY_CONTROL" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_COHERENCY_CONTROL" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_COHERENCY_CNTRL_SPECIFIC" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_COHERENCY_CNTRL_SPECIFIC" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_COHERENCY_CNTRL_SPECIFIC" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_COHERENCY_CNTRL_SPECIFIC" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_SYNCRUN_REQUEST" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_SYNCRUN_REQUEST" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_SYNCRUN_REQUEST" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_SYNCRUN_REQUEST" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_NUM_SYMBOL_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_NUM_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_NUM_SYMBOL_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_NUM_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_SYMBOL_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_SYMBOL_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_SET_SYMBOL_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_SET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_SET_SYMBOL_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_SET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_SET_SYMBOL_INFO_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_SET_SYMBOL_INFO_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_SET_SYMBOL_INFO_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_SET_SYMBOL_INFO_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_READREG_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_READREG_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_READREG_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_READREG_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_WRITEREG_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_WRITEREG_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_WRITEREG_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_WRITEREG_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_GET_PHYSICAL_PAGE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_GET_PHYSICAL_PAGE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_GET_PHYSICAL_PAGE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_GET_PHYSICAL_PAGE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_SET_LOW_POWER_MODE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_SET_LOW_POWER_MODE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_SET_LOW_POWER_MODE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_SET_LOW_POWER_MODE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_NOTIFY_APP_MEMORY_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_NOTIFY_APP_MEMORY_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_NOTIFY_APP_MEMORY_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_NOTIFY_APP_MEMORY_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_NOTIFY_APP_MEMORY_INFO_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_NOTIFY_APP_MEMORY_INFO_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_NOTIFY_APP_MEMORY_INFO_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_NOTIFY_APP_MEMORY_INFO_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_SETBP_EX_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_SETBP_EX_64" ) = 000001BD38F0A0F0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_CLEARBP_EX_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_CLEARBP_EX_64" ) = 000001BD38F0A100
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_BP_TEST_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_BP_TEST_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "_GTI_BP_TEST_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "_GTI_BP_TEST_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38F00000, "GTI_SETUP_PROPERTIES" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38F00000, "GTI_SETUP_PROPERTIES" ) = 000001BD38F09F60
0x00001CD4 27244 3  GTI C: GTI_SETUP_PROPERTIES( "Texas Instruments XDS110 USB Debug Probe_CS_DAP_0", *0x000001BD2EE8A740 = "Block Target Access on Free Run", *0x000001BD2EE8B200 = "1", 0x00000007 )
0x00001CD4 27244 3  GTI R: GTI_SETUP_PROPERTIES( "Texas Instruments XDS110 USB Debug Probe_CS_DAP_0", *0x000001BD2EE8A740 = "Block Target Access on Free Run", *0x000001BD2EE8B200 = "1", 0x00000007 ) = 0x00000000
0x00001CD4 27244 3 CS_DAP_0 FLASH I: FlashProgrammerManager::Constructor
0x00001CD4 27244 3  LIB C: dlclose( 000001BD38F00000 )
0x00001CD4 27244 3  LIB R: dlclose( 000001BD38F00000 ) = 1
0x00001CD4 27244 3  GTI C: remote_dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cortexM.dvr" )
0x00001CD4 27244 3  GTI R: remote_dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cortexM.dvr" ) = 0x0000000000000000
0x00001CD4 27244 3  GTI C: remote_dlerror()
0x00001CD4 27244 3  GTI R: remote_dlerror() = ""
0x00001CD4 27244 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cortexM.dvr", 0 )
0x00001CD4 27244 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cortexM.dvr", 0 ) = 000001BD38FA0000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_VALIDATE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_VALIDATE" ) = 000001BD38FAD240
0x00001CD4 27244 3  GTI C: GTI_VALIDATE( 0x0000000000000000, 0x000018BE )
0x00001CD4 27244 3  GTI R: GTI_VALIDATE( 0x0000000000000000, 0x000018BE ) = 0x000018BE
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SET_DB_ACCESS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SET_DB_ACCESS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_SET_DB_ACCESS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_SET_DB_ACCESS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_INIT" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_INIT" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_INIT" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_INIT" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_QUIT" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_QUIT" ) = 000001BD38FB1C50
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GETERRSTR" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GETERRSTR" ) = 000001BD38FADBC0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_RESET" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_RESET" ) = 000001BD38FB07C0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_STEP" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_STEP" ) = 000001BD38FB0630
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_RUN" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_RUN" ) = 000001BD38FB0810
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GLOBALSTART" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GLOBALSTART" ) = 000001BD38FB0750
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_STAT" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_STAT" ) = 000001BD38FAFF40
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_READREG" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_READREG" ) = 000001BD38FB2AF0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_WRITEREG" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_WRITEREG" ) = 000001BD38FB2B90
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_READMEM" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_READMEM" ) = 000001BD38FB2820
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_WRITEMEM" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_WRITEMEM" ) = 000001BD38FB27D0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SETBP" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SETBP" ) = 000001BD38FAD400
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_CLEARBP" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_CLEARBP" ) = 000001BD38FAD510
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SETBP_EX" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SETBP_EX" ) = 000001BD38FAD310
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_CLEARBP_EX" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_CLEARBP_EX" ) = 000001BD38FAD420
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_HALT" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_HALT" ) = 000001BD38FB00C0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_ADD_MEMMAP" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_ADD_MEMMAP" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_ADD_MEMMAP" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_ADD_MEMMAP" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_CLEAR_MEMMAP" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_CLEAR_MEMMAP" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_CLEAR_MEMMAP" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_CLEAR_MEMMAP" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_RESET_MEMMAP" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_RESET_MEMMAP" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_RESET_MEMMAP" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_RESET_MEMMAP" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_INIT3" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_INIT3" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_INIT3" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_INIT3" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_INIT_EX" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_INIT_EX" ) = 000001BD38FB1B40
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_RUN_EX" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_RUN_EX" ) = 000001BD38FB0280
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_READMEM_EX" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_READMEM_EX" ) = 000001BD38FB26B0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_WRITEMEM_EX" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_WRITEMEM_EX" ) = 000001BD38FB2770
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_READMEM_BLK" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_READMEM_BLK" ) = 000001BD38FB2650
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_WRITEMEM_BLK" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_WRITEMEM_BLK" ) = 000001BD38FB2710
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GETPROCTYPE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GETPROCTYPE" ) = 000001BD38FA3C30
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GETREV" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GETREV" ) = 000001BD38FACDE0
0x00001CD4 27244 3 Cortex_M4_0 GTI C: GTI_GETREV( 0x0000000000000000 )
0x00001CD4 27244 3 Cortex_M4_0 GTI R: GTI_GETREV( 0x0000000000000000 ) = 0x00003200
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SET_PROFILE_TYPE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SET_PROFILE_TYPE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_SET_PROFILE_TYPE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_SET_PROFILE_TYPE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_NUM_PROFILE_TYPES" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_NUM_PROFILE_TYPES" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_NUM_PROFILE_TYPES" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_NUM_PROFILE_TYPES" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_PROFILE_TYPE_NAME" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_PROFILE_TYPE_NAME" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_PROFILE_TYPE_NAME" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_PROFILE_TYPE_NAME" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_NUM_HBP_TYPES" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_NUM_HBP_TYPES" ) = 000001BD38FA1300
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_HBP_TYPE_NAME" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_HBP_TYPE_NAME" ) = 000001BD38FA1310
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_ENABLE_GLOBAL_BKPTS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_ENABLE_GLOBAL_BKPTS" ) = 000001BD38FA13E0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_WAS_HBP_HIT" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_WAS_HBP_HIT" ) = 000001BD38FA1340
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_WAS_HBP_HIT_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_WAS_HBP_HIT_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_WAS_HBP_HIT_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_WAS_HBP_HIT_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_REALTIME_SWITCH" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_REALTIME_SWITCH" ) = 000001BD38FB2AE0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GETBOARDINFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GETBOARDINFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GETBOARDINFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GETBOARDINFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_LOOKUP_REG_BY_NAME" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_LOOKUP_REG_BY_NAME" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_LOOKUP_REG_BY_NAME" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_LOOKUP_REG_BY_NAME" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GETPROCINFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GETPROCINFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GETPROCINFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GETPROCINFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_PROC_ID" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_PROC_ID" ) = 000001BD38FA3C40
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_PROC_MINOR_ID" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_PROC_MINOR_ID" ) = 000001BD38FA3C50
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_EXT_CAPABILITIES" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_EXT_CAPABILITIES" ) = 000001BD38FACDF0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_TARGET_PROPERTIES" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_TARGET_PROPERTIES" ) = 000001BD38FA3CA0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_SIM_MODE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_SIM_MODE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_SIM_MODE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_SIM_MODE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SET_SIM_MODE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SET_SIM_MODE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_SET_SIM_MODE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_SET_SIM_MODE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GETERRSTR_EX" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GETERRSTR_EX" ) = 000001BD38FADBA0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GETERRSTR_EX2" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GETERRSTR_EX2" ) = 000001BD38FADCB0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SETERRRESPONSE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SETERRRESPONSE" ) = 000001BD38FADA80
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GETERRSTR_EX3" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GETERRSTR_EX3" ) = 000001BD38FAD590
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_PROCESS_GEL_COMMAND" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_PROCESS_GEL_COMMAND" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_PROCESS_GEL_COMMAND" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_PROCESS_GEL_COMMAND" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_PROCESS_GEL_COMMAND_EX" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_PROCESS_GEL_COMMAND_EX" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_PROCESS_GEL_COMMAND_EX" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_PROCESS_GEL_COMMAND_EX" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_EMURESET_EX" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_EMURESET_EX" ) = 000001BD38FACEA0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_EMURESET_EX2" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_EMURESET_EX2" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_EMURESET_EX2" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_EMURESET_EX2" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_CONNECT2" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_CONNECT2" ) = 000001BD38FB1DC0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_CONNECT3" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_CONNECT3" ) = 000001BD38FB1E00
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_DISCONNECT" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_DISCONNECT" ) = 000001BD38FB1E60
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_DISCONNECT2" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_DISCONNECT2" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_DISCONNECT2" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_DISCONNECT2" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_DONE_REMOVING_DEBUG_STATE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_DONE_REMOVING_DEBUG_STATE" ) = 000001BD38FAD530
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_CONTEXT_CONST" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_CONTEXT_CONST" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_CONTEXT_CONST" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_CONTEXT_CONST" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_EXEC_PACKET_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_EXEC_PACKET_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_EXEC_PACKET_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_EXEC_PACKET_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_EXEC_PACKET_INFO_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_EXEC_PACKET_INFO_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_EXEC_PACKET_INFO_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_EXEC_PACKET_INFO_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_READMEM_WITH_STAT" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_READMEM_WITH_STAT" ) = 000001BD38FA1A40
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_WRITEMEM_WITH_STAT" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_WRITEMEM_WITH_STAT" ) = 000001BD38FA1B70
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_READMEM_WITH_STAT_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_READMEM_WITH_STAT_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_READMEM_WITH_STAT_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_READMEM_WITH_STAT_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_WRITEMEM_WITH_STAT_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_WRITEMEM_WITH_STAT_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_WRITEMEM_WITH_STAT_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_WRITEMEM_WITH_STAT_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_QUERY_INTERFACE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_QUERY_INTERFACE" ) = 000001BD38FB20B0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_BLOCK_RESET" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_BLOCK_RESET" ) = 000001BD38FAE6D0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SET_ROUTER_SYSTEM_FEATURE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_SET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_SET_ROUTER_SYSTEM_FEATURE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_ROUTER_SYSTEM_FEATURE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_ROUTER_SYSTEM_FEATURE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_WAIT_IN_RESET_MODE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_WAIT_IN_RESET_MODE" ) = 000001BD38FAE5E0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SET_WAIT_IN_RESET" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SET_WAIT_IN_RESET" ) = 000001BD38FAE520
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_STAT_EX" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_STAT_EX" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_STAT_EX" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_STAT_EX" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_BP_TEST" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_BP_TEST" ) = 000001BD38FAE7F0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_STAT_EX2" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_STAT_EX2" ) = 000001BD38FADD70
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_NUM_RESETS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_NUM_RESETS" ) = 000001BD38FAE370
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_RESET_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_RESET_INFO" ) = 000001BD38FAE420
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_RESET_EX" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_RESET_EX" ) = 000001BD38FAE250
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_MAKE_DEVICE_SECURE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_MAKE_DEVICE_SECURE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_MAKE_DEVICE_SECURE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_MAKE_DEVICE_SECURE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SET_PROGRESS_CALLBACK" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SET_PROGRESS_CALLBACK" ) = 000001BD38FB2AD0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_TARGET_VOLTAGE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_TARGET_VOLTAGE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_TARGET_VOLTAGE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_TARGET_VOLTAGE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_MEM_LEVEL_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_MEM_LEVEL_INFO" ) = 000001BD38FA1CF0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_NON_INTRUSIVE_CAPABILITIES" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_NON_INTRUSIVE_CAPABILITIES" ) = 000001BD38FACE10
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SET_DIFF_FLASH_SUPPORT" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SET_DIFF_FLASH_SUPPORT" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_SET_DIFF_FLASH_SUPPORT" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_SET_DIFF_FLASH_SUPPORT" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_NUM_FLASH_LAYOUTS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_NUM_FLASH_LAYOUTS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_NUM_FLASH_LAYOUTS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_NUM_FLASH_LAYOUTS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_FLASH_LAYOUT" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_FLASH_LAYOUT" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_FLASH_LAYOUT" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_FLASH_LAYOUT" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_DSPEVENT2" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_DSPEVENT2" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_DSPEVENT2" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_DSPEVENT2" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GETCAPABILITIES" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GETCAPABILITIES" ) = 000001BD38FACFE0
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_MMU_STATE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_MMU_STATE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_MMU_STATE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_MMU_STATE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SET_MMU_STATE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SET_MMU_STATE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_SET_MMU_STATE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_SET_MMU_STATE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_NUM_MMU_TTBR_REGS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_NUM_MMU_TTBR_REGS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_NUM_MMU_TTBR_REGS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_NUM_MMU_TTBR_REGS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_TTBR_REG" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_TTBR_REG" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_TTBR_REG" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_TTBR_REG" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SET_TTBR_REG" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SET_TTBR_REG" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_SET_TTBR_REG" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_SET_TTBR_REG" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_CURRENT_PROCID" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_CURRENT_PROCID" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SET_CURRENT_PROCID" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_SET_CURRENT_PROCID" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_SET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_NUM_MMU_DOMAINS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_NUM_MMU_DOMAINS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_NUM_MMU_DOMAINS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_NUM_MMU_DOMAINS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_DOMAIN_ACCESS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_DOMAIN_ACCESS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SET_DOMAIN_ACCESS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_SET_DOMAIN_ACCESS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_SET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SET_ALL_DOMAIN_ACCESS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SET_ALL_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_SET_ALL_DOMAIN_ACCESS" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_SET_ALL_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_COHERENCY_CONTROL" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_COHERENCY_CONTROL" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_COHERENCY_CONTROL" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_COHERENCY_CONTROL" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_COHERENCY_CNTRL_SPECIFIC" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_COHERENCY_CNTRL_SPECIFIC" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_COHERENCY_CNTRL_SPECIFIC" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_COHERENCY_CNTRL_SPECIFIC" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SYNCRUN_REQUEST" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SYNCRUN_REQUEST" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_SYNCRUN_REQUEST" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_SYNCRUN_REQUEST" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_NUM_SYMBOL_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_NUM_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_NUM_SYMBOL_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_NUM_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_SYMBOL_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_SYMBOL_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SET_SYMBOL_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_SET_SYMBOL_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_SET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SET_SYMBOL_INFO_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SET_SYMBOL_INFO_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_SET_SYMBOL_INFO_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_SET_SYMBOL_INFO_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_READREG_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_READREG_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_READREG_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_READREG_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_WRITEREG_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_WRITEREG_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_WRITEREG_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_WRITEREG_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_GET_PHYSICAL_PAGE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_GET_PHYSICAL_PAGE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_GET_PHYSICAL_PAGE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_GET_PHYSICAL_PAGE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SET_LOW_POWER_MODE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SET_LOW_POWER_MODE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_SET_LOW_POWER_MODE" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_SET_LOW_POWER_MODE" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_NOTIFY_APP_MEMORY_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_NOTIFY_APP_MEMORY_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_NOTIFY_APP_MEMORY_INFO" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_NOTIFY_APP_MEMORY_INFO" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_NOTIFY_APP_MEMORY_INFO_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_NOTIFY_APP_MEMORY_INFO_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_NOTIFY_APP_MEMORY_INFO_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_NOTIFY_APP_MEMORY_INFO_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SETBP_EX_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SETBP_EX_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_SETBP_EX_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_SETBP_EX_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_CLEARBP_EX_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_CLEARBP_EX_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_CLEARBP_EX_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_CLEARBP_EX_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_BP_TEST_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_BP_TEST_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "_GTI_BP_TEST_64" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "_GTI_BP_TEST_64" ) = 0000000000000000
0x00001CD4 27244 3  LIB C: dlsym( 000001BD38FA0000, "GTI_SETUP_PROPERTIES" )
0x00001CD4 27244 3  LIB R: dlsym( 000001BD38FA0000, "GTI_SETUP_PROPERTIES" ) = 000001BD38FB2C40
0x00001CD4 27244 3  GTI C: GTI_SETUP_PROPERTIES( "Texas Instruments XDS110 USB Debug Probe_Cortex_M4_0", *0x000001BD2EE94580 = "haltOnConnectByDefault", *0x000001BD2EE93740 = "true", 0x00000006 )
0x00001CD4 27244 3  GTI R: GTI_SETUP_PROPERTIES( "Texas Instruments XDS110 USB Debug Probe_Cortex_M4_0", *0x000001BD2EE94580 = "haltOnConnectByDefault", *0x000001BD2EE93740 = "true", 0x00000006 ) = 0x00000000
0x00001CD4 27244 3 Cortex_M4_0 FLASH I: FlashProgrammerManager::Constructor
0x00001CD4 27244 3  LIB C: dlclose( 000001BD38FA0000 )
0x00001CD4 27244 3  LIB R: dlclose( 000001BD38FA0000 ) = 1
0x00001CD4 27244 3  LIB C: dlclose( 000001BD38E30000 )
0x00001CD4 27244 3  LIB R: dlclose( 000001BD38E30000 ) = 1
0x00001CD4 27244 3  COM_DBG_IF C: class CoProgressTask::OnUpdate()
0x00001CD4 27244 3  XPCOM C: ( (dsIObjectEventCallback*)000001BD358DA030 )->onEvent( 000001BD305C6810 )
0x00001CD4 27244 3  XPCOM C: ( (nsISupports*)000001BD305C6818 )->queryInterface( 000001BD307D4E20, 0000000DAD8FC8F8 )
0x00001CD4 27244 3  XPCOM R: ( (nsISupports*)000001BD305C6818 )->queryInterface( 000001BD307D4E20, *0000000DAD8FC8F8 = 000001BD305C6810 ) = 0x00000000
0x00001CD4 27244 3  XPCOM C: ( (dsIProgressTaskData*)000001BD305C6810 )->PercentDone( 0000000DAD8FC950 )
0x00001CD4 27244 3  XPCOM R: ( (dsIProgressTaskData*)000001BD305C6810 )->PercentDone( *0000000DAD8FC950 = 0x00000000 ) = 0x00000000
0x00001CD4 27244 3  XPCOM C: ( (dsIProgressTaskData*)000001BD305C6810 )->SubActivity( 0000000DAD8FC950 )
0x00001CD4 27244 3  XPCOM R: ( (dsIProgressTaskData*)000001BD305C6810 )->SubActivity( *0000000DAD8FC950 = Initializing: IcePick_C ) = 0x00000000
0x00001CD4 27244 3  XPCOM R: ( (dsIObjectEventCallback*)000001BD358DA030 )->onEvent( 000001BD305C6810 ) = 0x00000000
0x00001CD4 27244 3  COM_DBG_IF R: class CoProgressTask::OnUpdate()
0x00001CD4 27244 3 IcePick_C POLL C: Polling with state CPU_ST_INITIALIZE and status EVENT_DSP_HALT
0x00001CD4 27244 3 IcePick_C GTI C: GTI_GETCAPABILITIES( 0x0000000000000000 )
0x00001CD4 27244 3 IcePick_C GTI R: GTI_GETCAPABILITIES( 0x0000000000000000 ) = 0x85030010
0x00001CD4 27244 3 IcePick_C GTI C: GTI_SET_PROGRESS_CALLBACK( 0x0000000000000000, *0x000001BD307D4EA0 = ??? )
0x00001CD4 27244 3 IcePick_C GTI R: GTI_SET_PROGRESS_CALLBACK( 0x0000000000000000, *0x000001BD307D4EA0 = ??? ) = 0x00000000
0x00001CD4 27244 3  PERF I: GTI_INIT starting...
0x00001CD4 27244 3 IcePick_C GTI C: GTI_INIT_EX( 0x0000, "Texas Instruments XDS110 USB Debug Probe_IcePick_C/IcePick_C", 0x00000240, "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat", 0x00000640, 0x0000D000, 0x0000000C, *0x0000000DAD8FDE00 = { 0x0000000B, 0x00000080, 0x0000000000000000, 0x0000000000000000, "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat", 0x0000000000000000, 0x000001BD35089828, "CC2642R1F", 0x0000000000000000, 0x000001BD305B8FB0, 0x000001BD3089A5E8, 0x000001BD2B8BA1B0, "" }, *0x000001BD36BE7408 = 0x0000000000000000 )
0x00001CD4 27244 3  XDS110 C: XDS_SetProperty((*XDSInform) 0000000DAD8FAC60, XDS_PROPERTY_LOGGING_ENABLED, 1 ("enable"))
0x00001CD4 27244 3  XDS110 R: XDS_SetProperty((*XDSInform) 0000000DAD8FAC60, XDS_PROPERTY_LOGGING_ENABLED, 1 ("enable")) = 0
0x00001CD4 27244 3  XDS110 C: Executing command 0x01 (XDS_CONNECT)
0x00001CD4 27872 3  XDS110 E: XDS_GETLOG() = 1, failed to retrieve log entries from XDS110
0x00001CD4 27872 3  XDS110 R: Executed command 0x01 (XDS_CONNECT), return code: 0xfffffefb
0x00001CD4 27872 3 IcePick_C GTI R: GTI_INIT_EX( 0x0000, "Texas Instruments XDS110 USB Debug Probe_IcePick_C/IcePick_C", 0x00000240, "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat", 0x00000640, 0x0000D000, 0x0000000C, *0x0000000DAD8FDE00 = { 0x0000000B, 0x00000080, 0x0000000000000000, 0x0000000000000000, "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat", 0x0000000000000000, 0x000001BD35089828, "CC2642R1F", 0x0000000000000000, 0x000001BD305B8FB0, 0x000001BD3089A5E8, 0x000001BD2B8BA1B0, "" }, *0x000001BD36BE7408 = 0x000001BD30899910 ) = 0xFFFFFFFF
0x00001CD4 27872 3  PERF I: GTI_INIT finished:  0.623915s wall, 0.218750s user + 0.046875s system = 0.265625s CPU (42.6%)
0x00001CD4 27872 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD30899910, *0x0000000DAD8FD828 = 0x00000000, *0x0000000DAD8FD820 = 0x00000000, *0x0000000DAD8FD838 = 0x00000000, *0x0000000DAD8FD850 = 0x00000000, *0x0000000DAD8FD858 = 0x00000000, *0x0000000DAD8FD848 = 0x00000000, *0x0000000DAD8FD840 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 27872 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD30899910, *0x0000000DAD8FD828 = 0x00000000, *0x0000000DAD8FD820 = 0xFFFFFEFB, *0x0000000DAD8FD838 = 0x20002000, *0x0000000DAD8FD850 = 0x00400000, *0x0000000DAD8FD858 = 0x00000000, *0x0000000DAD8FD848 = 0x00000008, *0x0000000DAD8FD840 = 0x00000000, "", 0x00000040, "(Error -261 @ 0x0)
Invalid response was received from the XDS110.
(Emulation package 9.8.0.00235)
", 0x00000400 ) = 0x00000001
0x00001CD4 27872 3  COM_DBG_IF C: class dsDebugger::OnFatal()
0x00001CD4 27872 3  XPCOM C: ( (dsIStringEventCallback*)000001BD358D91B0 )->onEvent( IcePick_C: Error initializing emulator: (Error -261 @ 0x0) Invalid response was received from the XDS110. (Emulation package 9.8.0.00235)
0x00001CD4 27885 3  XPCOM R: ( (dsIStringEventCallback*)000001BD358D91B0 )->onEvent( IcePick_C: Error initializing emulator: (Error -261 @ 0x0) Invalid response was received from the XDS110. (Emulation package 9.8.0.00235)
 ) = 0x00000000
0x00001CD4 27885 3  COM_DBG_IF R: class dsDebugger::OnFatal()
0x00001CD4 27885 3 IcePick_C POLL C: Firing DSP_TASK_ERROR_MESSAGE_FATAL to all DSP_USER's
0x00001CD4 27885 3 IcePick_C POLL C: Firing of DSP_TASK_ERROR_MESSAGE_FATAL complete
0x00001CD4 27885 3  COM_DBG_IF C: class dsDebugger::OnMessageDialog()
0x00001CD4 27885 3  XPCOM C: ( (dsIObjectEventCallback*)000001BD358D87B0 )->onEvent( 000001BD35BDB080 )
0x00001CD4 27885 3  XPCOM C: ( (nsISupports*)000001BD35BDB090 )->queryInterface( 000001BD358A4C40, 0000000DAD8FC3D8 )
0x00001CD4 27885 3  XPCOM R: ( (nsISupports*)000001BD35BDB090 )->queryInterface( 000001BD358A4C40, *0000000DAD8FC3D8 = 000001BD35BDB080 ) = 0x00000000
0x00001CD4 27885 3  XPCOM C: ( (dsIMessageDialog*)000001BD35BDB080 )->setDisplayed( 0000000DAD8FC290 )
0x00001CD4 27885 3  XPCOM R: ( (dsIMessageDialog*)000001BD35BDB080 )->setDisplayed( *0000000DAD8FC290 = true ) = 0x00000000
0x00001CD4 27885 3  XPCOM R: ( (dsIObjectEventCallback*)000001BD358D87B0 )->onEvent( 000001BD35BDB080 ) = 0x00000000
0x00001CD4 27885 3  COM_DBG_IF R: class dsDebugger::OnMessageDialog()
0x00001CD4 27885 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 27885 3 IcePick_C POLL R: Poll() returning
0x00001CD4 27885 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::SystemInitializerPollFrequencyManager
0x00001CD4 27885 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 27885 4  POLL I: TimeToSleep() found shorter sleep time of 500 ms from class DevicePollFrequencyManager
0x00001494 27901 3  XPCOM C: ( (dsIMessageDialog*)000001BD35BDB080 )->onDismissed( 0000000DAE9FDDD0 )
0x00001494 27901 3  XPCOM R: ( (dsIMessageDialog*)000001BD35BDB080 )->onDismissed( *0000000DAE9FDDD0 = 000001BD2CD80820 ) = 0x00000000
0x00001494 27901 3  XPCOM C: ( (dsISimpleEvent*)000001BD2CD80820 )->addListener( 000001BD2C94B450 )
0x00001494 27901 3  XPCOM R: ( (dsISimpleEvent*)000001BD2CD80820 )->addListener( 000001BD2C94B450 ) = 0x00000000
0x00001C54 27962 3  XPCOM C: ( (dsIMessageDialog*)000001BD35BDB080 )->Title( 0000000DA7EFD3F0 )
0x00001C54 27962 3  XPCOM R: ( (dsIMessageDialog*)000001BD35BDB080 )->Title( *0000000DA7EFD3F0 = Texas Instruments XDS110 USB Debug Probe/IcePick_C ) = 0x00000000
0x00001C54 27962 3  XPCOM C: ( (dsIMessageDialog*)000001BD35BDB080 )->Icon( 0000000DA7EFD2F0 )
0x00001C54 27962 3  XPCOM R: ( (dsIMessageDialog*)000001BD35BDB080 )->Icon( *0000000DA7EFD2F0 = 0x00000000 ) = 0x00000000
0x00001C54 27971 3  XPCOM C: ( (dsIMessageDialog*)000001BD35BDB080 )->Text( 0000000DA7EFD360 )
0x00001C54 27971 3  XPCOM R: ( (dsIMessageDialog*)000001BD35BDB080 )->Text( *0000000DA7EFD360 = Error initializing emulator:
(Error -261 @ 0x0)
 ) = 0x00000000
0x00001C54 27971 3  XPCOM C: ( (dsIMessageDialog*)000001BD35BDB080 )->CanAutoRetry( 0000000DA7EFD360 )
0x00001C54 27971 3  XPCOM R: ( (dsIMessageDialog*)000001BD35BDB080 )->CanAutoRetry( *0000000DA7EFD360 = false ) = 0x00000000
0x00001C54 27971 3  XPCOM C: ( (dsIMessageDialog*)000001BD35BDB080 )->DefaultButton( 0000000DA7EFD330 )
0x00001C54 27971 3  XPCOM R: ( (dsIMessageDialog*)000001BD35BDB080 )->DefaultButton( *0000000DA7EFD330 = 0x00000000 ) = 0x00000000
0x00001C54 27971 3  XPCOM C: ( (dsIMessageDialog*)000001BD35BDB080 )->NumButtons( 0000000DA7EFD330 )
0x00001C54 27971 3  XPCOM R: ( (dsIMessageDialog*)000001BD35BDB080 )->NumButtons( *0000000DA7EFD330 = 0x00000002 ) = 0x00000000
0x00001C54 27971 3  XPCOM C: ( (dsIMessageDialog*)000001BD35BDB080 )->getButtonLabel( 0x00000000, 0000000DA7EFD338 )
0x00001C54 27971 3  XPCOM R: ( (dsIMessageDialog*)000001BD35BDB080 )->getButtonLabel( 0x00000000, *0000000DA7EFD338 = Cancel ) = 0x00000000
0x00001C54 27971 3  XPCOM C: ( (dsIMessageDialog*)000001BD35BDB080 )->getButtonLabel( 0x00000001, 0000000DA7EFD338 )
0x00001C54 27971 3  XPCOM R: ( (dsIMessageDialog*)000001BD35BDB080 )->getButtonLabel( 0x00000001, *0000000DA7EFD338 = Retry ) = 0x00000000
0x00001CD4 28393 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 0 ms
0x00001CD4 28393 3 IcePick_C POLL C: Polling with state STATE_ERROR and status EVENT_DSP_HALT
0x00001CD4 28393 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 28393 3 IcePick_C POLL R: Poll() returning
0x00001CD4 28393 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::SystemInitializerPollFrequencyManager
0x00001CD4 28393 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 28393 4  POLL I: TimeToSleep() found shorter sleep time of 500 ms from class DevicePollFrequencyManager
0x00001CD4 28899 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 0 ms
0x00001CD4 28899 3 IcePick_C POLL C: Polling with state STATE_ERROR and status EVENT_DSP_HALT
0x00001CD4 28899 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 28899 3 IcePick_C POLL R: Poll() returning
0x00001CD4 28899 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::SystemInitializerPollFrequencyManager
0x00001CD4 28899 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 28899 4  POLL I: TimeToSleep() found shorter sleep time of 500 ms from class DevicePollFrequencyManager
0x00001CD4 29414 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 0 ms
0x00001CD4 29414 3 IcePick_C POLL C: Polling with state STATE_ERROR and status EVENT_DSP_HALT
0x00001CD4 29414 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 29414 3 IcePick_C POLL R: Poll() returning
0x00001CD4 29414 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::SystemInitializerPollFrequencyManager
0x00001CD4 29414 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 29414 4  POLL I: TimeToSleep() found shorter sleep time of 500 ms from class DevicePollFrequencyManager
0x00001CD4 29923 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 0 ms
0x00001CD4 29923 3 IcePick_C POLL C: Polling with state STATE_ERROR and status EVENT_DSP_HALT
0x00001CD4 29923 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 29923 3 IcePick_C POLL R: Poll() returning
0x00001CD4 29923 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::SystemInitializerPollFrequencyManager
0x00001CD4 29923 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 29923 4  POLL I: TimeToSleep() found shorter sleep time of 500 ms from class DevicePollFrequencyManager
0x00001CD4 30427 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 0 ms
0x00001CD4 30427 3 IcePick_C POLL C: Polling with state STATE_ERROR and status EVENT_DSP_HALT
0x00001CD4 30427 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 30427 3 IcePick_C POLL R: Poll() returning
0x00001CD4 30427 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::SystemInitializerPollFrequencyManager
0x00001CD4 30427 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 30427 4  POLL I: TimeToSleep() found shorter sleep time of 500 ms from class DevicePollFrequencyManager
0x00001CD4 30932 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 0 ms
0x00001CD4 30932 3 IcePick_C POLL C: Polling with state STATE_ERROR and status EVENT_DSP_HALT
0x00001CD4 30932 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 30932 3 IcePick_C POLL R: Poll() returning
0x00001CD4 30932 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::SystemInitializerPollFrequencyManager
0x00001CD4 30932 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 30932 4  POLL I: TimeToSleep() found shorter sleep time of 500 ms from class DevicePollFrequencyManager
0x00001CD4 31445 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 0 ms
0x00001CD4 31445 3 IcePick_C POLL C: Polling with state STATE_ERROR and status EVENT_DSP_HALT
0x00001CD4 31445 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 31445 3 IcePick_C POLL R: Poll() returning
0x00001CD4 31445 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::SystemInitializerPollFrequencyManager
0x00001CD4 31445 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 31445 4  POLL I: TimeToSleep() found shorter sleep time of 500 ms from class DevicePollFrequencyManager
0x00001CD4 31948 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 0 ms
0x00001CD4 31948 3 IcePick_C POLL C: Polling with state STATE_ERROR and status EVENT_DSP_HALT
0x00001CD4 31948 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 31948 3 IcePick_C POLL R: Poll() returning
0x00001CD4 31948 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::SystemInitializerPollFrequencyManager
0x00001CD4 31948 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 31948 4  POLL I: TimeToSleep() found shorter sleep time of 500 ms from class DevicePollFrequencyManager
0x00001C54 32191 3  XPCOM C: ( (dsIMessageDialog*)000001BD35BDB080 )->setButtonResponse( 0x00000000 )
0x00001C54 32191 3  XPCOM R: ( (dsIMessageDialog*)000001BD35BDB080 )->setButtonResponse( 0x00000000 ) = 0x00000000
0x00001CD4 32191 3 IcePick_C POLL C: Polling with state STATE_ERROR and status EVENT_DSP_HALT
0x00001CD4 32191 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 32191 3 IcePick_C POLL R: Poll() returning
0x00001CD4 32191 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::SystemInitializerPollFrequencyManager
0x00001CD4 32191 4 IcePick_C POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 32191 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 32191 4  POLL I: Yielding to other threads
0x00001CD4 32191 3 IcePick_C POLL C: Polling with state CPU_ST_INITIALIZE_FAILED and status EVENT_DSP_HALT
0x00001CD4 32191 3  PERF I: GTI_QUIT starting...
0x00001CD4 32191 3 IcePick_C GTI C: GTI_QUIT( 0x000001BD30899910 )
0x00001CD4 32191 3 IcePick_C GTI R: GTI_QUIT( 0x000001BD30899910 ) = 0xFFFFFFFF
0x00001CD4 32191 3  PERF I: GTI_QUIT finished:  0.000065s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 32207 3  PERF I: Configure finished:  5.034957s wall, 1.578125s user + 0.312500s system = 1.890625s CPU (37.5%)
0x00001CD4 32207 3  COM_DBG_IF C: class CoProgressTask::OnCompleted()
0x00001CD4 32207 3  XPCOM C: ( (dsIStringEventCallback*)000001BD358D8B30 )->onEvent(  )
0x00001CD4 32208 3  XPCOM R: ( (dsIStringEventCallback*)000001BD358D8B30 )->onEvent(  ) = 0x00000000
0x00001CD4 32208 3  COM_DBG_IF R: class CoProgressTask::OnCompleted()
0x00001CD4 32208 3  PERF I: Deconfigure() starting...
0x00001CD4 32208 4  POLL I: Yielding to other threads
0x00001CD4 32208 3  POLL C: SystemDeInitializerImpl::Poll()
0x00001CD4 32208 3  POLL C: SystemDeInitializerImpl::BeginShutdown()
0x00001CD4 32208 1  COM_DBG_IF C: ImplementationValidity::MarkInvalid()
0x00001CD4 32208 1  COM_DBG_IF R: ImplementationValidity::MarkInvalid()
0x00001CD4 32208 3  LIB C: dlsym( 00007FFEDF0F0000, "CleanupCtools" )
0x00001CD4 32208 3  LIB R: dlsym( 00007FFEDF0F0000, "CleanupCtools" ) = 00007FFEDF181D40
0x00001CD4 32208 3  LIB C: dlsym( 00007FFEDF0F0000, "CleanupCtoolsAsync" )
0x00001CD4 32208 3  LIB R: dlsym( 00007FFEDF0F0000, "CleanupCtoolsAsync" ) = 00007FFEDF182210
0x00001CD4 32208 3  CT C: CleanupCtoolsAsync()
0x00001CD4 32208 3  PERF I: CleanupCtoolsAsync() starting...
0x000036DC 32208 3  CT C: CleanupCallback::OnComplete()
0x000036DC 32208 3  PERF I: CleanupCtoolsAsync() finished:  0.000596s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x000036DC 32208 3  CT R: CleanupCallback::OnComplete()
0x00001CD4 32465 3  CT R: CleanupCtoolsAsync()
0x00001CD4 32465 3  POLL R: SystemDeInitializerImpl::BeginShutdown()
0x00001CD4 32465 3  POLL R: SystemDeInitializerImpl::Poll()
0x00001CD4 32465 4  POLL I: Yielding to other threads
0x00001CD4 32465 3  POLL C: SystemDeInitializerImpl::Poll()
0x00001CD4 32465 3  POLL C: SystemDeInitializerImpl::ThreadsCompleted()
0x00001CD4 32465 3  POLL R: SystemDeInitializerImpl::ThreadsCompleted() = 1, m_nActiveThreads = 0
0x00001CD4 32465 3  POLL C: SystemDeInitializerImpl::FinishShutdown()
0x00001CD4 32465 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_QUEUE_MARKER added to polling loop by unknown
0x00001CD4 32465 3  LIB C: dlclose( 000001BD38FA0000 )
0x00001CD4 32465 3  LIB R: dlclose( 000001BD38FA0000 ) = 1
0x00001CD4 32465 3 CS_DAP_0 POLL D: New request of type DSP_RQ_QUEUE_MARKER added to polling loop by unknown
0x00001CD4 32465 3  LIB C: dlclose( 000001BD38F00000 )
0x00001CD4 32465 3  LIB R: dlclose( 000001BD38F00000 ) = 1
0x00001CD4 32465 3 IcePick_C POLL D: New request of type DSP_RQ_QUEUE_MARKER added to polling loop by unknown
0x00001CD4 32465 3  LIB C: dlclose( 000001BD38E30000 )
0x00001CD4 32465 3  LIB R: dlclose( 000001BD38E30000 ) = 1
0x00001CD4 32465 1  COM_DBG_IF C: ImplementationValidity::MarkInvalid()
0x00001CD4 32465 1  COM_DBG_IF R: ImplementationValidity::MarkInvalid()
0x00001CD4 32465 3  LIB C: dlclose( 00007FFEDF810000 )
0x00001CD4 32465 3  LIB R: dlclose( 00007FFEDF810000 ) = 1
0x00001CD4 32465 3  LIB C: dlclose( 00007FFEDF0F0000 )
0x00001CD4 32465 3  LIB R: dlclose( 00007FFEDF0F0000 ) = 1
0x00001CD4 32465 3  PERF I: Deconfigure() finished:  0.259661s wall, 0.125000s user + 0.015625s system = 0.140625s CPU (54.2%)
0x00001CD4 32465 3  COM_DBG_IF C: class dsDebugger::OnConfigureFailed()
0x00001CD4 32465 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD351BB1F0 )->onEvent()
0x00001CD4 32465 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD351BB1F0 )->onEvent() = 0x00000000
0x00001CD4 32465 3  COM_DBG_IF R: class dsDebugger::OnConfigureFailed()
0x00001CD4 32465 3  POLL R: SystemDeInitializerImpl::FinishShutdown()
0x00003614 32465 3  XPCOM C: ( (dsIDebugger*)000001BD35627D80 )->Initialized( 0000000DAF1FE9A0 )
0x00003614 32465 3  XPCOM R: ( (dsIDebugger*)000001BD35627D80 )->Initialized( *0000000DAF1FE9A0 = false ) = 0x00000000
0x00003614 32465 3  XPCOM C: ( (dsIDebugger*)000001BD35627D80 )->getInitError( 0000000DAF1FE930, 0000000DAF1FE948 )
0x00003614 32465 3  XPCOM R: ( (dsIDebugger*)000001BD35627D80 )->getInitError( *0000000DAF1FE930 = true, *0000000DAF1FE948 = IcePick_C: Error initializing emulator: (Error -261 @ 0x0)
 ) = 0x00000000
0x00002098 37991 3  WBSKT D: DeviceDetector: {"event":"detach"}
0x00002098 42563 3  WBSKT D: DeviceDetector: {"event":"attach"}
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class CoProgressTaskEventData (this = 000001BD305C6818)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class CoMessageDialog (this = 000001BD35BDB090)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::DebugProperties (this = 000001BD2E71A490)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C1BC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD29C42798)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307C12D8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BEA38)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C2998)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD2EEEA388)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD2F08FE78)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD29B87BC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD29B88DA8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD2F08FB38)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD29B846F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD2EEEA118)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD2F090698)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD2C5FF5D8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C28C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C2658)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C1A28)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C17B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C27F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::TextProperty (this = 000001BD3064D7B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C1D68)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BE968)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C1E38)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C1958)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C1548)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BE898)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD299E2C48)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::TextProperty (this = 000001BD3064DA78)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C0C58)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C2728)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C0F98)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C1068)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD2C6BDE58)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C2A68)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C16E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C20A8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C1FD8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C2B38)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C2178)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C1478)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C1AF8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C23E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307C1888)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307C06A8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BF808)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BFB48)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307C09E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BE488)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BF598)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BF188)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BF258)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BF668)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BEB08)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BE6F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307C0AB8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BE628)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BF328)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BF4C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BF738)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BF8D8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307C0B88)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BFC18)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BE7C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307C2318)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD299F6FE8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACC0F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACC1B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACBAF8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACC338)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACBBB8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACC638)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACC278)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACBC78)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACB978)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23C1C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::ChoiceListProperty (this = 000001BD2CC452C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::ChoiceListProperty (this = 000001BD2CC42028)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACC6F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACBA38)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACBD38)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::ChoiceListProperty (this = 000001BD2CC436A8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23E0C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23CDC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23C2C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACBDF8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACBEB8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACC038)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACBF78)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACC7B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACC3F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACC4B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FACC578)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2E80A6F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2E80A578)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2E80AF38)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2E80AFF8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::NumericProperty (this = 000001BD307C2248)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23D0C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23B8C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23B9C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2E80ACF8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2E80A878)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23B4C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23A7C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23BDC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23D6C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2E80A7B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2E80ADB8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23BAC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23BBC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::ChoiceListProperty (this = 000001BD2CC44E48)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23BEC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2E80A9F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2E80A1B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2E80AE78)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23BCC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2E80AC38)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23B1C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2E80A278)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23DDC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23B2C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23A8C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2E80A3F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23A4C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2E80A338)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23C7C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::ChoiceListProperty (this = 000001BD2CC453E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23D1C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2E80AAB8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23B6C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23DEC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23CBC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23B3C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23DCC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23B7C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23B5C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23BFC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2E80A638)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::NumericProperty (this = 000001BD2C97D968)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2E80A4B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2E80A938)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23CEC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class XPCOMFramework::Event<class XPCOMFramework::EventTemplateArgs<class dsIObjectEvent,class nsISupports * __ptr64,class dsIObjectEventCallback> > (this = 000001BD29481718)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class XPCOMFramework::Event<class XPCOMFramework::EventTemplateArgs<class dsIStringEvent,char const * __ptr64,class dsIStringEventCallback> > (this = 000001BD29481448)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::DebugProperties (this = 000001BD2E71A2F0)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595F478)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD3595E508)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595F7B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595F138)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD35960DA8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595EC58)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD359610E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD359611B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595F208)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD3595E438)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD35960CD8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD35961288)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD35961358)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595E1C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD359603E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595E368)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595EAB8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595F3A8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::TextProperty (this = 000001BD2E809A68)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595FD68)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595F2D8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595F958)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD35960178)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595F888)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595E778)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD3595E298)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::TextProperty (this = 000001BD2E8092D8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595EEC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595E0F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD359608C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595F6E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD3595E5D8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595F068)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD359604B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595FA28)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595FAF8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595FBC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595FF08)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD3595FFD8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD35960B38)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD35960998)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD35960A68)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD2F0B6C18)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD35545DE8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD35961018)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD359600A8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD3595F618)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD35960658)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD35960588)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD35961428)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD3595ED28)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD35960728)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD3595E6A8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD3595EDF8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD359607F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD35960E78)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD35960248)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD3595FE38)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD3595F548)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD3595FC98)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD3595EB88)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD3595E9E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD35960C08)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC05868)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC06168)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC05F28)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC05E68)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC05DA8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC06228)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC05AA8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC05B68)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC062E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC056E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC05FE8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23B0C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::ChoiceListProperty (this = 000001BD2CC45508)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::ChoiceListProperty (this = 000001BD2CC44F68)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC05C28)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC05CE8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC063A8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::ChoiceListProperty (this = 000001BD2CC45628)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23C0C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23C3C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23CFC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC05568)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC05628)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC05928)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC059E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC060A8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2FC057A8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD30422078)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD30421EF8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD30422138)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD304224F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD304225B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD30421A78)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD304221F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::NumericProperty (this = 000001BD35960318)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23C4C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23C5C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23D2C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD30422678)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD30422738)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23C6C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23C8C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23ACC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23CAC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD30421D78)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD304227F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23D3C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23D4C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::ChoiceListProperty (this = 000001BD2CC426E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23D5C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD304219B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD304222B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD30422378)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23A1C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD30421BF8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23AFC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD30421B38)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23D8C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23D7C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23ABC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD30421E38)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23DAC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD30421FB8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23DBC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::ChoiceListProperty (this = 000001BD2CC42808)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23A2C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD30422438)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23A3C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23A5C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23A6C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23A9C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23AAC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23ADC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23AEC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23E8C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD355AE018)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::NumericProperty (this = 000001BD3595E848)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD355AE0D8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD355AD418)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23E5C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class XPCOMFramework::Event<class XPCOMFramework::EventTemplateArgs<class dsIObjectEvent,class nsISupports * __ptr64,class dsIObjectEventCallback> > (this = 000001BD2B54FDA8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class XPCOMFramework::Event<class XPCOMFramework::EventTemplateArgs<class dsIStringEvent,char const * __ptr64,class dsIStringEventCallback> > (this = 000001BD2B54FF58)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class CoProgressTask (this = 000001BD30074F48)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class XPCOMFramework::Event<class XPCOMFramework::EventTemplateArgs<class dsIStringEvent,char const * __ptr64,class dsIStringEventCallback> > (this = 000001BD2B550468)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class CoProgressTaskEventData (this = 000001BD2AF8AFA8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class XPCOMFramework::Event<class XPCOMFramework::EventTemplateArgs<class dsIStringEvent,char const * __ptr64,class dsIStringEventCallback> > (this = 000001BD294810E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::DebugProperties (this = 000001BD2E71A150)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BBE58)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD307C01C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD2C6F1018)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BD518)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BE2E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD307BE078)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BFCE8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD307C0778)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD307BE218)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BE558)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD307BFA78)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BFDB8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD307BEF18)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD307C0918)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BBA48)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BB978)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BAFB8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BB3C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BB708)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::TextProperty (this = 000001BD3064D708)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BB568)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BD378)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BBFF8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BD1D8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BD5E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BB498)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD307BE3B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::TextProperty (this = 000001BD36EBD638)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BC8E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BB2F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BC5A8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BC9B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Button (this = 000001BD307C0508)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BDB98)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BCA88)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BD6B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BDFA8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BB228)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BD788)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BDC68)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BCF68)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BB638)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Group (this = 000001BD307BDD38)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD2C6F10E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD2C6F1EB8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD2C6F1288)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD2C6F2058)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD2C6F14F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD2C6F15C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD2C6F1AA8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD2C6F2128)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD2C6F21F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD2C6F2878)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD2C6F2948)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD2C6F2A18)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD2C6F2AE8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD2C6F2BB8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD2C6F2C88)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD2C6F7A88)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BC748)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BDAC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BC818)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BC4D8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::Node (this = 000001BD307BCDC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD296A51E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD296A4FA8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE16AB8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE16938)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE17238)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE16CF8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE16878)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE16638)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE169F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE16B78)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2393C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::ChoiceListProperty (this = 000001BD2CC42148)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::ChoiceListProperty (this = 000001BD2CC41DE8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE17178)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE16C38)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE16578)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::ChoiceListProperty (this = 000001BD2CC41F08)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2395C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B238FC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B236FC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE166F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE16FF8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE16DB8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE16E78)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE16F38)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE170B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE164B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE172F8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD2EE167B8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD299F6AA8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD299F76A8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD299F7168)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::NumericProperty (this = 000001BD307BDE08)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2374C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2386C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2387C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD299F6928)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD299F6B68)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B236EC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2390C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2368C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2370C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD299F73A8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD299F7228)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2391C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2392C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::ChoiceListProperty (this = 000001BD2CC44548)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2398C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD299F6E68)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD299F6868)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD299F69E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2399C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD299F7468)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B239AC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD299F7528)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2371C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B239BC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2372C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD299F75E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2363C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD299F72E8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2375C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::ChoiceListProperty (this = 000001BD2CC42EC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B239DC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD299F70A8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B239FC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2378C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2361C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2379C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B237AC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B2362C8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B237BC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23CCC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD299F6CE8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::NumericProperty (this = 000001BD307C05D8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD299F6DA8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::BooleanProperty (this = 000001BD299F6F28)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class DbgProperties::StringProperty (this = 000001BD2B23DFC8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class XPCOMFramework::Event<class XPCOMFramework::EventTemplateArgs<class dsIObjectEvent,class nsISupports * __ptr64,class dsIObjectEventCallback> > (this = 000001BD29480CF8)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class XPCOMFramework::Event<class XPCOMFramework::EventTemplateArgs<class dsIStringEvent,char const * __ptr64,class dsIStringEventCallback> > (this = 000001BD29481208)
0x00002B00 44720 5  COM_DBG_IF I: Final Release for class XPCOMFramework::Event<class XPCOMFramework::EventTemplateArgs<class dsIStringEvent,char const * __ptr64,class dsIStringEventCallback> > (this = 000001BD294815F8)
0x00002B00 45663 5  COM_DBG_IF I: Final Release for class XPCOMFramework::Event<class XPCOMFramework::EventTemplateArgs<class dsIStringEvent,char const * __ptr64,class dsIStringEventCallback> > (this = 000001BD2B550A08)
0x00002B00 45663 5  COM_DBG_IF I: Final Release for class XPCOMFramework::Event<class XPCOMFramework::EventTemplateArgs<class dsIObjectEvent,class nsISupports * __ptr64,class dsIObjectEventCallback> > (this = 000001BD2B550198)
0x00002B00 45663 5  COM_DBG_IF I: Final Release for class XPCOMFramework::Event<class XPCOMFramework::EventTemplateArgs<class dsISimpleEvent,void,class dsISimpleEventCallback> > (this = 000001BD2CD80828)
0x00003E54 48033 3  WBSKT D: Get CloudAgent Instance
0x00003E54 48033 3  WBSKT D: Agent: {"data":["DeviceDetector"],"id":3,"command":"createSubModule"}
0x000047F0 48033 3  WBSKT D: Agent: {"data":{"port":55563},"response":3}
0x000044D4 48033 3  WBSKT D: Connecting to ws://localhost:55563 for module DeviceDetector
0x00004524 48033 3  WBSKT D: DeviceDetector open
0x00003E54 48033 3  WBSKT D: DeviceDetector: {"data":[],"id":0,"command":"detectDebugProbes"}
0x00004524 48049 3  WBSKT D: DeviceDetector: {"data":{"probes":[{"connectionXml":"TIXDS110_Connection","id":"0","serialNumber":"L11008CT","comPorts":["COM9"],"overrides":{"Debug Probe Selection":"1","-- Enter the serial number":"L11008CT"}}]},"response":0}
0x00003E54 48049 3  XPCOM C: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugPropertiesWithAttributes( Texas Instruments XDS110 USB Debug Probe/IcePick_C, ICEPICK_C, , 0x00000008, 000001BD2B988020, 000001BD2B988CF0, 0000000DAA8FE3F0 )
0x00003E54 48065 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnDisableStatusChanged()
0x00003E54 48065 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnDisableStatusChanged()
0x00003E54 48065 3  XPCOM R: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugPropertiesWithAttributes( Texas Instruments XDS110 USB Debug Probe/IcePick_C, ICEPICK_C, , 0x00000008, 000001BD2B988020, 000001BD2B988CF0, *0000000DAA8FE3F0 = 000001BD2C543570 ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIDebugProperties*)000001BD2C543570 )->queryInterface( 000001BD36C79130, 0000000DAA8FE338 )
0x00003E54 48065 3  XPCOM R: ( (dsIDebugProperties*)000001BD2C543570 )->queryInterface( 000001BD36C79130, *0000000DAA8FE338 = 000001BD2C543578 ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2C543578 )->onDisableStatusChanged( 0000000DAA8FE310 )
0x00003E54 48065 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2C543578 )->onDisableStatusChanged( *0000000DAA8FE310 = 000001BD289B4D70 ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2C543578 )->onPropertyValueChanged( 0000000DAA8FE310 )
0x00003E54 48065 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2C543578 )->onPropertyValueChanged( *0000000DAA8FE310 = 000001BD289B3ED0 ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIDebugProperties*)000001BD2C543570 )->restoreDefault()
0x00003E54 48065 3  XPCOM R: ( (dsIDebugProperties*)000001BD2C543570 )->restoreDefault() = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugPropertiesWithAttributes( Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, CS_DAP, , 0x0000000A, 000001BD305AEC30, 000001BD305ADF70, 0000000DAA8FE3F0 )
0x00003E54 48065 3  XPCOM R: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugPropertiesWithAttributes( Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, CS_DAP, , 0x0000000A, 000001BD305AEC30, 000001BD305ADF70, *0000000DAA8FE3F0 = 000001BD2E414D40 ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E414D40 )->queryInterface( 000001BD307E1360, 0000000DAA8FE338 )
0x00003E54 48065 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E414D40 )->queryInterface( 000001BD307E1360, *0000000DAA8FE338 = 000001BD2E414D48 ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2E414D48 )->onDisableStatusChanged( 0000000DAA8FE310 )
0x00003E54 48065 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2E414D48 )->onDisableStatusChanged( *0000000DAA8FE310 = 000001BD2CC67260 ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2E414D48 )->onPropertyValueChanged( 0000000DAA8FE310 )
0x00003E54 48065 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2E414D48 )->onPropertyValueChanged( *0000000DAA8FE310 = 000001BD2CC67BF0 ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E414D40 )->restoreDefault()
0x00003E54 48065 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E414D40 )->restoreDefault() = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugPropertiesWithAttributes( Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, Cortex_M4, , 0x00000009, 000001BD308A26F0, 000001BD308A83C0, 0000000DAA8FE3F0 )
0x00003E54 48065 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnPropertyChanged()
0x00003E54 48065 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnPropertyChanged()
0x00003E54 48065 3  XPCOM R: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugPropertiesWithAttributes( Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, Cortex_M4, , 0x00000009, 000001BD308A26F0, 000001BD308A83C0, *0000000DAA8FE3F0 = 000001BD2E4139C0 ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E4139C0 )->queryInterface( 000001BD30440560, 0000000DAA8FE338 )
0x00003E54 48065 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E4139C0 )->queryInterface( 000001BD30440560, *0000000DAA8FE338 = 000001BD2E4139C8 ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2E4139C8 )->onDisableStatusChanged( 0000000DAA8FE310 )
0x00003E54 48065 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2E4139C8 )->onDisableStatusChanged( *0000000DAA8FE310 = 000001BD2CC675C0 ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2E4139C8 )->onPropertyValueChanged( 0000000DAA8FE310 )
0x00003E54 48065 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2E4139C8 )->onPropertyValueChanged( *0000000DAA8FE310 = 000001BD2CC67380 ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E4139C0 )->restoreDefault()
0x00003E54 48065 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E4139C0 )->restoreDefault() = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E4139C0 )->loadSettings( <?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<PropertyValues>
  <property id="AutoRunToLabelOnReset">
    <curValue>1</curValue>
  </property>
  <property id="ConnectOnStartup">
  </property>
  <property id="EnableInstalledBreakpoint">
  </property>
  <property id="IgnoreSoftLaunchFailures">
    <curValue>0</curValue>
  </property>
  <property id="FlashVerboseMode">
  </property>
</PropertyValues>
0x00003E54 48065 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnPropertyValueChanged()
0x00003E54 48065 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnPropertyValueChanged()
0x00003E54 48065 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E4139C0 )->loadSettings( <?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<PropertyValues>
  </property>
  </property>
  </property>
  </property>
  </property>
</PropertyValues>
 ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIDebugger*)000001BD35627D80 )->configure( C:\Users\o.gaste\workspace_v12\project_zero_CC26X2R1_LAUNCHXL_tirtos7_ticlang\targetConfigs\CC2642R1F.ccxml, false )
0x00003E54 48065 3  PERF I: Configure starting...
0x00003E54 48065 3  COM_DBG_IF C: class dsDebugger::OnTaskStart()
0x00003E54 48065 3  XPCOM C: ( (dsIObjectEventCallback*)000001BD358D8FB0 )->onEvent( 000001BD29337450 )
0x00003E54 48065 3  XPCOM C: ( (nsISupports*)000001BD29337458 )->queryInterface( 000001BD304D5430, 0000000DAA8FC008 )
0x00003E54 48065 3  XPCOM R: ( (nsISupports*)000001BD29337458 )->queryInterface( 000001BD304D5430, *0000000DAA8FC008 = 000001BD29337450 ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIProgressTask*)000001BD29337450 )->onCompleted( 0000000DAA8FBF80 )
0x00003E54 48065 3  XPCOM R: ( (dsIProgressTask*)000001BD29337450 )->onCompleted( *0000000DAA8FBF80 = 000001BD2CC67770 ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIProgressTask*)000001BD29337450 )->onUpdate( 0000000DAA8FBF80 )
0x00003E54 48065 3  XPCOM R: ( (dsIProgressTask*)000001BD29337450 )->onUpdate( *0000000DAA8FBF80 = 000001BD2CC684F0 ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIProgressTask*)000001BD29337450 )->Name( 0000000DAA8FC070 )
0x00003E54 48065 3  XPCOM R: ( (dsIProgressTask*)000001BD29337450 )->Name( *0000000DAA8FC070 = Configuring Debugger (may take a few minutes on first launch)... ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIProgressTask*)000001BD29337450 )->SubActivity( 0000000DAA8FBFE0 )
0x00003E54 48065 3  XPCOM R: ( (dsIProgressTask*)000001BD29337450 )->SubActivity( *0000000DAA8FBFE0 =  ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIProgressTask*)000001BD29337450 )->CanCancel( 0000000DAA8FBFE0 )
0x00003E54 48065 3  XPCOM R: ( (dsIProgressTask*)000001BD29337450 )->CanCancel( *0000000DAA8FBFE0 = false ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIProgressTask*)000001BD29337450 )->Task( 0000000DAA8FBFE0 )
0x00003E54 48065 3  XPCOM R: ( (dsIProgressTask*)000001BD29337450 )->Task( *0000000DAA8FBFE0 =  ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIProgressTask*)000001BD29337450 )->HasPercentCompletion( 0000000DAA8FBFE0 )
0x00003E54 48065 3  XPCOM R: ( (dsIProgressTask*)000001BD29337450 )->HasPercentCompletion( *0000000DAA8FBFE0 = false ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIStringEvent*)000001BD2CC67770 )->addListener( 000001BD304D53D0 )
0x00003E54 48065 3  XPCOM R: ( (dsIStringEvent*)000001BD2CC67770 )->addListener( 000001BD304D53D0 ) = 0x00000000
0x00003E54 48065 3  XPCOM C: ( (dsIObjectEvent*)000001BD2CC684F0 )->addListener( 000001BD304D55B0 )
0x00003E54 48065 3  XPCOM R: ( (dsIObjectEvent*)000001BD2CC684F0 )->addListener( 000001BD304D55B0 ) = 0x00000000
0x00003E54 48065 3  XPCOM R: ( (dsIObjectEventCallback*)000001BD358D8FB0 )->onEvent( 000001BD29337450 ) = 0x00000000
0x00003E54 48065 3  COM_DBG_IF R: class dsDebugger::OnTaskStart()
0x00003E54 48065 3  XPCOM R: ( (dsIDebugger*)000001BD35627D80 )->configure( C:\Users\o.gaste\workspace_v12\project_zero_CC26X2R1_LAUNCHXL_tirtos7_ticlang\targetConfigs\CC2642R1F.ccxml, false ) = 0x00000000
0x00001CD4 48081 3  COM_DBG_IF C: class CoProgressTask::OnUpdate()
0x00001CD4 48081 3  XPCOM C: ( (dsIObjectEventCallback*)000001BD3541E5C0 )->onEvent( 000001BD2E44EF40 )
0x00001CD4 48081 3  XPCOM C: ( (nsISupports*)000001BD2E44EF48 )->queryInterface( 000001BD36C794D0, 0000000DAD8FB6D8 )
0x00001CD4 48081 3  XPCOM R: ( (nsISupports*)000001BD2E44EF48 )->queryInterface( 000001BD36C794D0, *0000000DAD8FB6D8 = 000001BD2E44EF40 ) = 0x00000000
0x00001CD4 48081 3  XPCOM C: ( (dsIProgressTaskData*)000001BD2E44EF40 )->PercentDone( 0000000DAD8FB730 )
0x00001CD4 48081 3  XPCOM R: ( (dsIProgressTaskData*)000001BD2E44EF40 )->PercentDone( *0000000DAD8FB730 = 0x00000000 ) = 0x00000000
0x00001CD4 48081 3  XPCOM C: ( (dsIProgressTaskData*)000001BD2E44EF40 )->SubActivity( 0000000DAD8FB730 )
0x00001CD4 48081 3  XPCOM R: ( (dsIProgressTaskData*)000001BD2E44EF40 )->SubActivity( *0000000DAD8FB730 = Initializing Register Database... ) = 0x00000000
0x00001CD4 48081 3  XPCOM R: ( (dsIObjectEventCallback*)000001BD3541E5C0 )->onEvent( 000001BD2E44EF40 ) = 0x00000000
0x00001CD4 48081 3  COM_DBG_IF R: class CoProgressTask::OnUpdate()
0x00001CD4 48081 3  SETUP C: OpenDatabase( C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\targetdb.dat, C:\ti\ccs1200\ccs\ccs_base\common\targetdb\timestamp )
0x00001CD4 48081 3  SETUP I: SELECT sql FROM sqlite_master ORDER BY tbl_name, name
0x00001CD4 48081 3  SETUP R: OpenDatabase( C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\targetdb.dat, C:\ti\ccs1200\ccs\ccs_base\common\targetdb\timestamp ) = 000001BD2E442F10
0x00001CD4 48081 3  SETUP I: Loading repository "C:\ti\ccs1200\ccs\ccs_base\common\targetdb\"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Repositories
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Repositories WHERE dbid=1
0x00001CD4 48081 3  SETUP I: PRAGMA journal_mode = MEMORY
0x00001CD4 48081 3  SETUP I: PRAGMA synchronous = OFF
0x00001CD4 48081 3  SETUP I: BEGIN IMMEDIATE TRANSACTION
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="CS_DAP_0_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=1
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="CS_DAP_PC_0_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=2
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_C_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=3
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_D_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=4
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_M_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=5
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="regids_mapping.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=6
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2000_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=7
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2001_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=8
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2002_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=9
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2003_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=10
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2004_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=11
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2005_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=12
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2006_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=13
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2007_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=14
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2008_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=15
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2010_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=16
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2011_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=17
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2012_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=18
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2013_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=19
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2014_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=20
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2015_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=21
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2026_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=22
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2027_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=23
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2028_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=24
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2029_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=25
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2030_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=26
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2031_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=27
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2032_regids.xml"
0x00001CD4 48081 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=28
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS225C00_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=29
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS225C100_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=30
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C28XX_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=31
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C55XX_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=32
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C64XX_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=33
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C66XX_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=34
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C674X_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=35
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C6XXX_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=36
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C71XX_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=37
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C75XX_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=38
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS3CXX_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=39
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R15X_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=40
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R25X_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=41
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R2X_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=42
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R33X_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=43
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R4X_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=44
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R53X_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=45
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R7X_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=46
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R9X_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=47
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RAX_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=48
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RCX_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=49
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RDX_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=50
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470REX_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=51
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RXX_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=52
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C40XX_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=53
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C41XX_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=54
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C4X_regids.xml"
0x00001CD4 48096 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=55
0x00001CD4 48096 3  SETUP I: END TRANSACTION
0x00001CD4 48096 3  SETUP I: SELECT count(*) FROM TargetDB_Files WHERE State=0
0x00001CD4 48096 3  SETUP I: Scrubbing database
0x00001CD4 48114 3  SETUP I: Loading file "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\2910475632580809234.cache"
0x00001CD4 48114 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="2910475632580809234.cache"
0x00001CD4 48114 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=116
0x00001CD4 48114 3  SETUP I: SELECT count(*) FROM TargetDB_Files WHERE State=0
0x00001CD4 48114 3  SETUP I: SELECT Systems.dbid FROM Systems, TargetDB_Files WHERE Systems.Source_File = TargetDB_Files.dbid AND TargetDB_Files.dbid = 116
0x00001CD4 48114 3  SETUP I: SELECT * FROM Systems WHERE dbid=9
0x00001CD4 48114 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\analysis\bin\ctools.dll", 0 )
0x00001CD4 48114 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\analysis\bin\ctools.dll", 0 ) = 00007FFEDF0F0000
0x00001CD4 48114 3  LIB C: dlsym( 00007FFEDF0F0000, "GetcToolsMgrIFDS" )
0x00001CD4 48114 3  LIB R: dlsym( 00007FFEDF0F0000, "GetcToolsMgrIFDS" ) = 00007FFEDF184760
0x00001CD4 48114 3  LIB C: dlsym( 00007FFEDF0F0000, "GetcToolsJobMgrIFDS" )
0x00001CD4 48114 3  LIB R: dlsym( 00007FFEDF0F0000, "GetcToolsJobMgrIFDS" ) = 00007FFEDF183B80
0x00001CD4 48114 3  LIB C: dlsym( 00007FFEDF0F0000, "SetDebugProperty" )
0x00001CD4 48114 3  LIB R: dlsym( 00007FFEDF0F0000, "SetDebugProperty" ) = 00007FFEDF184820
0x00001CD4 48114 3  CT C: GetcToolsMgrIFDS( 0000000DAD8FD628 )
0x00001CD4 48114 3  CT R: GetcToolsMgrIFDS( *0000000DAD8FD628 = 000001BD36C7C8D0 )
0x00001CD4 48114 3  CT C: GetcToolsJobMgrIFDS( 0000000DAD8FD630 )
0x00001CD4 48114 3  CT R: GetcToolsJobMgrIFDS( *0000000DAD8FD630 = 000001BD2F9C1168 )
0x00001CD4 48114 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\analysis\bin\AETProperties.dll", 0 )
0x00001CD4 48114 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\analysis\bin\AETProperties.dll", 0 ) = 00007FFEDF810000
0x00001CD4 48114 3  GTI C: remote_dlopen( "" )
0x00001CD4 48114 3  GTI R: remote_dlopen( "" ) = 0x0000000000000000
0x00001CD4 48114 3  GTI C: remote_dlerror()
0x00001CD4 48114 3  GTI R: remote_dlerror() = ""
0x00001CD4 48114 3  GTI C: remote_dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510icepick_c.dvr" )
0x00001CD4 48114 3  GTI R: remote_dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510icepick_c.dvr" ) = 0x0000000000000000
0x00001CD4 48114 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510icepick_c.dvr", 0 )
0x00001CD4 48114 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510icepick_c.dvr", 0 ) = 000001BD38E90000
0x00001CD4 48114 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_BOARD_DATA_FILE_VERSION" )
0x00001CD4 48114 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_BOARD_DATA_FILE_VERSION" ) = 000001BD38E933D0
0x00001CD4 48114 3  GTI C: GTI_GET_BOARD_DATA_FILE_VERSION( 0x0000000000000000 )
0x00001CD4 48114 3  GTI R: GTI_GET_BOARD_DATA_FILE_VERSION( 0x0000000000000000 ) = 0x00000002
0x00001CD4 48114 3  GTI C: JTAGData_CreateJtagDeviceList()
0x00001CD4 48114 3  GTI R: JTAGData_CreateJtagDeviceList() = 000001BD2B2C83D0
0x00001CD4 48114 3  GTI C: JTAGData_AddVariable( 000001BD2B2C83D0, BOARD_DATAFILE_VERSION, *0000000DAD8FD550 = 2 )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariable( 000001BD2B2C83D0, BOARD_DATAFILE_VERSION, *0000000DAD8FD550 = 2 ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, SEPK.POD_DRVR, jioxds110.dll )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, SEPK.POD_DRVR, jioxds110.dll ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, SEPK.POD_PORT, 0 )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, SEPK.POD_PORT, 0 ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, SEPK.POD_SUPPLY, 1 )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, SEPK.POD_SUPPLY, 1 ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, SEPK.POD_VOLTAGE_SELECTION, 1 )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, SEPK.POD_VOLTAGE_SELECTION, 1 ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, SEPK.POD_VOLTAGE, 3.3 )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, SEPK.POD_VOLTAGE, 3.3 ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, SEPK.POD_POWER_ISOLATE, 0 )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, SEPK.POD_POWER_ISOLATE, 0 ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, PRODUCT.TITLE, Texas Instruments XDS110 USB )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, PRODUCT.TITLE, Texas Instruments XDS110 USB ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, PRODUCT.ALIAS, TI_XDS110_USB )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, PRODUCT.ALIAS, TI_XDS110_USB ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, PRODUCT.NAME, XDS110 )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, PRODUCT.NAME, XDS110 ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, USCIF.TDOEDGE, FALL )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, USCIF.TDOEDGE, FALL ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, USCIF.TCLK_PROGRAM, DEFAULT )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, USCIF.TCLK_PROGRAM, DEFAULT ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, USCIF.TCLK_FREQUENCY, 5.5MHz )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, USCIF.TCLK_FREQUENCY, 5.5MHz ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, USCIF.JTAG_ISOLATE, disable )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, USCIF.JTAG_ISOLATE, disable ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, DOT7.DTS_USAGE, enable )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, DOT7.DTS_USAGE, enable ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, DOT7.DTS_TYPE, xds110 )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, DOT7.DTS_TYPE, xds110 ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, DOT7.DTS_PROGRAM, emulator )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, DOT7.DTS_PROGRAM, emulator ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, DOT7.DTS_FREQUENCY, 1.0MHz )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, DOT7.DTS_FREQUENCY, 1.0MHz ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, DOT7.TS_FORMAT, oscan2 )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, DOT7.TS_FORMAT, oscan2 ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, DOT7.TS_PIN_WIDTH, only_two )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, DOT7.TS_PIN_WIDTH, only_two ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, SWD.SWD_DEBUG, disabled )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, SWD.SWD_DEBUG, disabled ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, SWD.SWO_DATA, tdo_pin )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, SWD.SWO_DATA, tdo_pin ) = 1
0x00001CD4 48114 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, SWD.SWJ_DP_DEFAULT_MODE, 0 )
0x00001CD4 48114 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, SWD.SWJ_DP_DEFAULT_MODE, 0 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddDeviceEx( 000001BD2B2C83D0, IcePick_C, 240, 2, 0, 5, ROUTER, 4294967295, 0, 2 )
0x00001CD4 48130 3  GTI R: JTAGData_AddDeviceEx( 000001BD2B2C83D0, IcePick_C, 240, 2, 0, 5, ROUTER, 4294967295, 0, 2 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, device.SystemResetSupported, 1 )
0x00001CD4 48130 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, device.SystemResetSupported, 1 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, device.SystemResetWhileConnected, 1 )
0x00001CD4 48130 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, device.SystemResetWhileConnected, 1 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddSubpath( 000001BD2B2C83D0, subpath_2, IcePick_C, 1 )
0x00001CD4 48130 3  GTI R: JTAGData_AddSubpath( 000001BD2B2C83D0, subpath_2, IcePick_C, 1 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, subpath.address, 0x0 )
0x00001CD4 48130 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, subpath.address, 0x0 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, subpath.initial, 0 )
0x00001CD4 48130 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, subpath.initial, 0 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, subpath.custom, 1 )
0x00001CD4 48130 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, subpath.custom, 1 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, subpath.force, 1 )
0x00001CD4 48130 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, subpath.force, 1 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, subpath.cancelreset, 0x1 )
0x00001CD4 48130 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, subpath.cancelreset, 0x1 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddDevice( 000001BD2B2C83D0, bypass_0, 1023, 4095, 127, 7, BYPASS, 4 )
0x00001CD4 48130 3  GTI R: JTAGData_AddDevice( 000001BD2B2C83D0, bypass_0, 1023, 4095, 127, 7, BYPASS, 4 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddSubpath( 000001BD2B2C83D0, subpath_0, IcePick_C, 1 )
0x00001CD4 48130 3  GTI R: JTAGData_AddSubpath( 000001BD2B2C83D0, subpath_0, IcePick_C, 1 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, subpath.address, 0x10 )
0x00001CD4 48130 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, subpath.address, 0x10 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddDeviceEx( 000001BD2B2C83D0, CS_DAP_0, 224, 1, 0, 5, ROUTER, 4294967295, 0, 1 )
0x00001CD4 48130 3  GTI R: JTAGData_AddDeviceEx( 000001BD2B2C83D0, CS_DAP_0, 224, 1, 0, 5, ROUTER, 4294967295, 0, 1 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, device.identify, 0x4ba00477 )
0x00001CD4 48130 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, device.identify, 0x4ba00477 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, device.Revision, Legacy )
0x00001CD4 48130 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, device.Revision, Legacy ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddSubpath( 000001BD2B2C83D0, subpath_1, CS_DAP_0, 1 )
0x00001CD4 48130 3  GTI R: JTAGData_AddSubpath( 000001BD2B2C83D0, subpath_1, CS_DAP_0, 1 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, subpath.type, debug )
0x00001CD4 48130 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, subpath.type, debug ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, subpath.pseudo, 0 )
0x00001CD4 48130 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, subpath.pseudo, 0 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddDevice( 000001BD2B2C83D0, Cortex_M4_0, 470, 14, 0, 0, DSP_CPU, -1 )
0x00001CD4 48130 3  GTI R: JTAGData_AddDevice( 000001BD2B2C83D0, Cortex_M4_0, 470, 14, 0, 0, DSP_CPU, -1 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, device.identify, 0x02000000 )
0x00001CD4 48130 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, device.identify, 0x02000000 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_AddVariableEx( 000001BD2B2C83D0, device.traceId, 0x0 )
0x00001CD4 48130 3  GTI R: JTAGData_AddVariableEx( 000001BD2B2C83D0, device.traceId, 0x0 ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_Output( 000001BD2B2C83D0, C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat )
0x00001CD4 48130 3  GTI R: JTAGData_Output( 000001BD2B2C83D0, C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat ) = 1
0x00001CD4 48130 3  GTI C: JTAGData_DestroyJtagDeviceList( 000001BD2B2C83D0 )
0x00001CD4 48130 3  GTI R: JTAGData_DestroyJtagDeviceList( 000001BD2B2C83D0 ) = 0000000000000000
0x00001CD4 48130 3  GTI C: remote_dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510icepick_c.dvr" )
0x00001CD4 48130 3  GTI R: remote_dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510icepick_c.dvr" ) = 0x0000000000000000
0x00001CD4 48130 3  GTI C: remote_dlerror()
0x00001CD4 48130 3  GTI R: remote_dlerror() = ""
0x00001CD4 48130 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510icepick_c.dvr", 0 )
0x00001CD4 48130 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510icepick_c.dvr", 0 ) = 000001BD38E90000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_VALIDATE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_VALIDATE" ) = 000001BD38E93310
0x00001CD4 48130 3  GTI C: GTI_VALIDATE( 0x0000000000000000, 0x00006784 )
0x00001CD4 48130 3  GTI R: GTI_VALIDATE( 0x0000000000000000, 0x00006784 ) = 0x00006784
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SET_DB_ACCESS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SET_DB_ACCESS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_SET_DB_ACCESS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_SET_DB_ACCESS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_INIT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_INIT" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_INIT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_INIT" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_QUIT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_QUIT" ) = 000001BD38E95020
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GETERRSTR" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GETERRSTR" ) = 000001BD38E93A10
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_RESET" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_RESET" ) = 000001BD38E99150
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_STEP" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_STEP" ) = 000001BD38E990D0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_RUN" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_RUN" ) = 000001BD38E998F0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GLOBALSTART" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GLOBALSTART" ) = 000001BD38E99140
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_STAT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_STAT" ) = 000001BD38E98E80
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_READREG" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_READREG" ) = 000001BD38E957F0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_WRITEREG" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_WRITEREG" ) = 000001BD38E95890
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_READMEM" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_READMEM" ) = 000001BD38E99A60
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_WRITEMEM" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_WRITEMEM" ) = 000001BD38E99A50
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SETBP" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SETBP" ) = 000001BD38E98E40
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_CLEARBP" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_CLEARBP" ) = 000001BD38E98E60
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SETBP_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SETBP_EX" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_SETBP_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_SETBP_EX" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_CLEARBP_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_CLEARBP_EX" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_CLEARBP_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_CLEARBP_EX" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_HALT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_HALT" ) = 000001BD38E98FD0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_ADD_MEMMAP" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_ADD_MEMMAP" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_ADD_MEMMAP" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_ADD_MEMMAP" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_CLEAR_MEMMAP" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_CLEAR_MEMMAP" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_CLEAR_MEMMAP" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_CLEAR_MEMMAP" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_RESET_MEMMAP" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_RESET_MEMMAP" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_RESET_MEMMAP" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_RESET_MEMMAP" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_INIT3" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_INIT3" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_INIT3" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_INIT3" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_INIT_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_INIT_EX" ) = 000001BD38E94F10
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_RUN_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_RUN_EX" ) = 000001BD38E99040
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_READMEM_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_READMEM_EX" ) = 000001BD38E99A20
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_WRITEMEM_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_WRITEMEM_EX" ) = 000001BD38E99A40
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_READMEM_BLK" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_READMEM_BLK" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_READMEM_BLK" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_READMEM_BLK" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_WRITEMEM_BLK" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_WRITEMEM_BLK" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_WRITEMEM_BLK" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_WRITEMEM_BLK" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GETPROCTYPE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GETPROCTYPE" ) = 000001BD38E92D30
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GETREV" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GETREV" ) = 000001BD38E92D20
0x00001CD4 48130 3 IcePick_C GTI C: GTI_GETREV( 0x0000000000000000 )
0x00001CD4 48130 3 IcePick_C GTI R: GTI_GETREV( 0x0000000000000000 ) = 0x00003200
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SET_PROFILE_TYPE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SET_PROFILE_TYPE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_SET_PROFILE_TYPE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_SET_PROFILE_TYPE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_NUM_PROFILE_TYPES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_NUM_PROFILE_TYPES" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_NUM_PROFILE_TYPES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_NUM_PROFILE_TYPES" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_PROFILE_TYPE_NAME" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_PROFILE_TYPE_NAME" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_PROFILE_TYPE_NAME" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_PROFILE_TYPE_NAME" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_NUM_HBP_TYPES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_NUM_HBP_TYPES" ) = 000001BD38E93080
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_HBP_TYPE_NAME" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_HBP_TYPE_NAME" ) = 000001BD38E93090
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_ENABLE_GLOBAL_BKPTS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_ENABLE_GLOBAL_BKPTS" ) = 000001BD38E930B0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_WAS_HBP_HIT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_WAS_HBP_HIT" ) = 000001BD38E930A0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_WAS_HBP_HIT_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_WAS_HBP_HIT_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_WAS_HBP_HIT_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_WAS_HBP_HIT_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_REALTIME_SWITCH" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_REALTIME_SWITCH" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_REALTIME_SWITCH" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_REALTIME_SWITCH" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GETBOARDINFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GETBOARDINFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GETBOARDINFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GETBOARDINFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_LOOKUP_REG_BY_NAME" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_LOOKUP_REG_BY_NAME" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_LOOKUP_REG_BY_NAME" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_LOOKUP_REG_BY_NAME" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GETPROCINFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GETPROCINFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GETPROCINFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GETPROCINFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_PROC_ID" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_PROC_ID" ) = 000001BD38E92D40
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_PROC_MINOR_ID" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_PROC_MINOR_ID" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_PROC_MINOR_ID" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_PROC_MINOR_ID" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_EXT_CAPABILITIES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_EXT_CAPABILITIES" ) = 000001BD38E92D50
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_TARGET_PROPERTIES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_TARGET_PROPERTIES" ) = 000001BD38E92D70
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_SIM_MODE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_SIM_MODE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_SIM_MODE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_SIM_MODE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SET_SIM_MODE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SET_SIM_MODE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_SET_SIM_MODE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_SET_SIM_MODE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GETERRSTR_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GETERRSTR_EX" ) = 000001BD38E939F0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GETERRSTR_EX2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GETERRSTR_EX2" ) = 000001BD38E93B00
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SETERRRESPONSE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SETERRRESPONSE" ) = 000001BD38E938D0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GETERRSTR_EX3" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GETERRSTR_EX3" ) = 000001BD38E933E0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_PROCESS_GEL_COMMAND" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_PROCESS_GEL_COMMAND" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_PROCESS_GEL_COMMAND" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_PROCESS_GEL_COMMAND" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_PROCESS_GEL_COMMAND_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_PROCESS_GEL_COMMAND_EX" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_PROCESS_GEL_COMMAND_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_PROCESS_GEL_COMMAND_EX" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_EMURESET_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_EMURESET_EX" ) = 000001BD38E92F40
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_EMURESET_EX2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_EMURESET_EX2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_EMURESET_EX2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_EMURESET_EX2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_CONNECT2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_CONNECT2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_CONNECT2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_CONNECT2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_CONNECT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_CONNECT" ) = 000001BD38E950E0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_CONNECT3" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_CONNECT3" ) = 000001BD38E95120
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_DISCONNECT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_DISCONNECT" ) = 000001BD38E95180
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_DISCONNECT2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_DISCONNECT2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_DISCONNECT2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_DISCONNECT2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_DONE_REMOVING_DEBUG_STATE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_DONE_REMOVING_DEBUG_STATE" ) = 000001BD38E98E70
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_CONTEXT_CONST" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_CONTEXT_CONST" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_CONTEXT_CONST" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_CONTEXT_CONST" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_EXEC_PACKET_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_EXEC_PACKET_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_EXEC_PACKET_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_EXEC_PACKET_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_EXEC_PACKET_INFO_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_EXEC_PACKET_INFO_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_EXEC_PACKET_INFO_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_EXEC_PACKET_INFO_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_READMEM_WITH_STAT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_READMEM_WITH_STAT" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_READMEM_WITH_STAT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_READMEM_WITH_STAT" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_WRITEMEM_WITH_STAT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_WRITEMEM_WITH_STAT" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_WRITEMEM_WITH_STAT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_WRITEMEM_WITH_STAT" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_READMEM_WITH_STAT_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_READMEM_WITH_STAT_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_READMEM_WITH_STAT_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_READMEM_WITH_STAT_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_WRITEMEM_WITH_STAT_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_WRITEMEM_WITH_STAT_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_WRITEMEM_WITH_STAT_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_WRITEMEM_WITH_STAT_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_QUERY_INTERFACE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_QUERY_INTERFACE" ) = 000001BD38E953B0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_BLOCK_RESET" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_BLOCK_RESET" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_BLOCK_RESET" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_BLOCK_RESET" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" ) = 000001BD38E99400
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SET_ROUTER_SYSTEM_FEATURE" ) = 000001BD38E99780
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_ROUTER_SYSTEM_FEATURE" ) = 000001BD38E99810
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_WAIT_IN_RESET_MODE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_WAIT_IN_RESET_MODE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_WAIT_IN_RESET_MODE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_WAIT_IN_RESET_MODE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SET_WAIT_IN_RESET" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SET_WAIT_IN_RESET" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_SET_WAIT_IN_RESET" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_SET_WAIT_IN_RESET" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_STAT_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_STAT_EX" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_STAT_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_STAT_EX" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_BP_TEST" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_BP_TEST" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_BP_TEST" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_BP_TEST" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_STAT_EX2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_STAT_EX2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_STAT_EX2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_STAT_EX2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_NUM_RESETS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_NUM_RESETS" ) = 000001BD38E99240
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_RESET_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_RESET_INFO" ) = 000001BD38E99280
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_RESET_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_RESET_EX" ) = 000001BD38E991B0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_MAKE_DEVICE_SECURE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_MAKE_DEVICE_SECURE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_MAKE_DEVICE_SECURE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_MAKE_DEVICE_SECURE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SET_PROGRESS_CALLBACK" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SET_PROGRESS_CALLBACK" ) = 000001BD38E957E0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_TARGET_VOLTAGE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_TARGET_VOLTAGE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_TARGET_VOLTAGE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_TARGET_VOLTAGE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_MEM_LEVEL_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_MEM_LEVEL_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_MEM_LEVEL_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_MEM_LEVEL_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_NON_INTRUSIVE_CAPABILITIES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_NON_INTRUSIVE_CAPABILITIES" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_NON_INTRUSIVE_CAPABILITIES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_NON_INTRUSIVE_CAPABILITIES" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SET_DIFF_FLASH_SUPPORT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SET_DIFF_FLASH_SUPPORT" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_SET_DIFF_FLASH_SUPPORT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_SET_DIFF_FLASH_SUPPORT" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_NUM_FLASH_LAYOUTS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_NUM_FLASH_LAYOUTS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_NUM_FLASH_LAYOUTS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_NUM_FLASH_LAYOUTS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_FLASH_LAYOUT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_FLASH_LAYOUT" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_FLASH_LAYOUT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_FLASH_LAYOUT" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_DSPEVENT2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_DSPEVENT2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_DSPEVENT2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_DSPEVENT2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GETCAPABILITIES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GETCAPABILITIES" ) = 000001BD38E930D0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_MMU_STATE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_MMU_STATE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_MMU_STATE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_MMU_STATE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SET_MMU_STATE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SET_MMU_STATE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_SET_MMU_STATE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_SET_MMU_STATE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_NUM_MMU_TTBR_REGS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_NUM_MMU_TTBR_REGS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_NUM_MMU_TTBR_REGS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_NUM_MMU_TTBR_REGS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_TTBR_REG" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_TTBR_REG" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_TTBR_REG" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_TTBR_REG" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SET_TTBR_REG" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SET_TTBR_REG" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_SET_TTBR_REG" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_SET_TTBR_REG" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_CURRENT_PROCID" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_CURRENT_PROCID" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SET_CURRENT_PROCID" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_SET_CURRENT_PROCID" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_SET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_NUM_MMU_DOMAINS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_NUM_MMU_DOMAINS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_NUM_MMU_DOMAINS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_NUM_MMU_DOMAINS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_DOMAIN_ACCESS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_DOMAIN_ACCESS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SET_DOMAIN_ACCESS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_SET_DOMAIN_ACCESS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_SET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SET_ALL_DOMAIN_ACCESS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SET_ALL_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_SET_ALL_DOMAIN_ACCESS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_SET_ALL_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_COHERENCY_CONTROL" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_COHERENCY_CONTROL" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_COHERENCY_CONTROL" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_COHERENCY_CONTROL" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_COHERENCY_CNTRL_SPECIFIC" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_COHERENCY_CNTRL_SPECIFIC" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_COHERENCY_CNTRL_SPECIFIC" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_COHERENCY_CNTRL_SPECIFIC" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SYNCRUN_REQUEST" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SYNCRUN_REQUEST" ) = 000001BD38E99890
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_NUM_SYMBOL_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_NUM_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_NUM_SYMBOL_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_NUM_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_SYMBOL_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_SYMBOL_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SET_SYMBOL_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_SET_SYMBOL_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_SET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SET_SYMBOL_INFO_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SET_SYMBOL_INFO_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_SET_SYMBOL_INFO_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_SET_SYMBOL_INFO_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_READREG_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_READREG_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_READREG_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_READREG_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_WRITEREG_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_WRITEREG_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_WRITEREG_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_WRITEREG_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_PHYSICAL_PAGE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_PHYSICAL_PAGE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_PHYSICAL_PAGE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_PHYSICAL_PAGE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SET_LOW_POWER_MODE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SET_LOW_POWER_MODE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_SET_LOW_POWER_MODE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_SET_LOW_POWER_MODE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_NOTIFY_APP_MEMORY_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_NOTIFY_APP_MEMORY_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_NOTIFY_APP_MEMORY_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_NOTIFY_APP_MEMORY_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_NOTIFY_APP_MEMORY_INFO_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_NOTIFY_APP_MEMORY_INFO_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_NOTIFY_APP_MEMORY_INFO_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_NOTIFY_APP_MEMORY_INFO_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SETBP_EX_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SETBP_EX_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_SETBP_EX_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_SETBP_EX_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_CLEARBP_EX_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_CLEARBP_EX_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_CLEARBP_EX_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_CLEARBP_EX_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_BP_TEST_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_BP_TEST_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "_GTI_BP_TEST_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "_GTI_BP_TEST_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38E90000, "GTI_SETUP_PROPERTIES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38E90000, "GTI_SETUP_PROPERTIES" ) = 000001BD38E95920
0x00001CD4 48130 3  GTI C: GTI_SETUP_PROPERTIES( "Texas Instruments XDS110 USB Debug Probe_IcePick_C", *0x000001BD2E443960 = "Use Board Reset", *0x000001BD2E443FF0 = "1", 0x00000005 )
0x00001CD4 48130 3  GTI R: GTI_SETUP_PROPERTIES( "Texas Instruments XDS110 USB Debug Probe_IcePick_C", *0x000001BD2E443960 = "Use Board Reset", *0x000001BD2E443FF0 = "1", 0x00000005 ) = 0x00000000
0x00001CD4 48130 3 IcePick_C FLASH I: FlashProgrammerManager::Constructor
0x00001CD4 48130 3  LIB C: dlclose( 000001BD38E90000 )
0x00001CD4 48130 3  LIB R: dlclose( 000001BD38E90000 ) = 1
0x00001CD4 48130 3  GTI C: remote_dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cs_dap.dvr" )
0x00001CD4 48130 3  GTI R: remote_dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cs_dap.dvr" ) = 0x0000000000000000
0x00001CD4 48130 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cs_dap.dvr", 0 )
0x00001CD4 48130 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cs_dap.dvr", 0 ) = 000001BD38F60000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_VALIDATE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_VALIDATE" ) = 000001BD38F63320
0x00001CD4 48130 3  GTI C: GTI_VALIDATE( 0x0000000000000000, 0x00004AE1 )
0x00001CD4 48130 3  GTI R: GTI_VALIDATE( 0x0000000000000000, 0x00004AE1 ) = 0x00004AE1
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SET_DB_ACCESS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SET_DB_ACCESS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_SET_DB_ACCESS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_SET_DB_ACCESS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_INIT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_INIT" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_INIT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_INIT" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_QUIT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_QUIT" ) = 000001BD38F65060
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GETERRSTR" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GETERRSTR" ) = 000001BD38F63A50
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_RESET" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_RESET" ) = 000001BD38F6A3E0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_STEP" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_STEP" ) = 000001BD38F6A360
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_RUN" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_RUN" ) = 000001BD38F6A440
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GLOBALSTART" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GLOBALSTART" ) = 000001BD38F6A3D0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_STAT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_STAT" ) = 000001BD38F6A110
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_READREG" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_READREG" ) = 000001BD38F6A7D0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_WRITEREG" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_WRITEREG" ) = 000001BD38F6A870
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_READMEM" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_READMEM" ) = 000001BD38F65A10
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_WRITEMEM" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_WRITEMEM" ) = 000001BD38F659C0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SETBP" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SETBP" ) = 000001BD38F6A0B0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_CLEARBP" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_CLEARBP" ) = 000001BD38F6A0D0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SETBP_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SETBP_EX" ) = 000001BD38F6A0A0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_CLEARBP_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_CLEARBP_EX" ) = 000001BD38F6A0C0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_HALT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_HALT" ) = 000001BD38F6A260
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_ADD_MEMMAP" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_ADD_MEMMAP" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_ADD_MEMMAP" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_ADD_MEMMAP" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_CLEAR_MEMMAP" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_CLEAR_MEMMAP" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_CLEAR_MEMMAP" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_CLEAR_MEMMAP" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_RESET_MEMMAP" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_RESET_MEMMAP" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_RESET_MEMMAP" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_RESET_MEMMAP" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_INIT3" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_INIT3" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_INIT3" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_INIT3" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_INIT_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_INIT_EX" ) = 000001BD38F64F50
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_RUN_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_RUN_EX" ) = 000001BD38F6A2D0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_READMEM_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_READMEM_EX" ) = 000001BD38F658A0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_WRITEMEM_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_WRITEMEM_EX" ) = 000001BD38F65960
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_READMEM_BLK" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_READMEM_BLK" ) = 000001BD38F65840
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_WRITEMEM_BLK" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_WRITEMEM_BLK" ) = 000001BD38F65900
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GETPROCTYPE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GETPROCTYPE" ) = 000001BD38F62D30
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GETREV" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GETREV" ) = 000001BD38F62D20
0x00001CD4 48130 3 CS_DAP_0 GTI C: GTI_GETREV( 0x0000000000000000 )
0x00001CD4 48130 3 CS_DAP_0 GTI R: GTI_GETREV( 0x0000000000000000 ) = 0x00003200
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SET_PROFILE_TYPE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SET_PROFILE_TYPE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_SET_PROFILE_TYPE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_SET_PROFILE_TYPE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_NUM_PROFILE_TYPES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_NUM_PROFILE_TYPES" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_NUM_PROFILE_TYPES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_NUM_PROFILE_TYPES" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_PROFILE_TYPE_NAME" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_PROFILE_TYPE_NAME" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_PROFILE_TYPE_NAME" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_PROFILE_TYPE_NAME" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_NUM_HBP_TYPES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_NUM_HBP_TYPES" ) = 000001BD38F630A0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_HBP_TYPE_NAME" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_HBP_TYPE_NAME" ) = 000001BD38F630B0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_ENABLE_GLOBAL_BKPTS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_ENABLE_GLOBAL_BKPTS" ) = 000001BD38F630D0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_WAS_HBP_HIT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_WAS_HBP_HIT" ) = 000001BD38F630C0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_WAS_HBP_HIT_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_WAS_HBP_HIT_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_WAS_HBP_HIT_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_WAS_HBP_HIT_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_REALTIME_SWITCH" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_REALTIME_SWITCH" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_REALTIME_SWITCH" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_REALTIME_SWITCH" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GETBOARDINFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GETBOARDINFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GETBOARDINFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GETBOARDINFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_LOOKUP_REG_BY_NAME" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_LOOKUP_REG_BY_NAME" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_LOOKUP_REG_BY_NAME" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_LOOKUP_REG_BY_NAME" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GETPROCINFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GETPROCINFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GETPROCINFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GETPROCINFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_PROC_ID" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_PROC_ID" ) = 000001BD38F62D40
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_PROC_MINOR_ID" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_PROC_MINOR_ID" ) = 000001BD38F6A7A0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_EXT_CAPABILITIES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_EXT_CAPABILITIES" ) = 000001BD38F62D50
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_TARGET_PROPERTIES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_TARGET_PROPERTIES" ) = 000001BD38F62D70
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_SIM_MODE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_SIM_MODE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_SIM_MODE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_SIM_MODE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SET_SIM_MODE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SET_SIM_MODE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_SET_SIM_MODE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_SET_SIM_MODE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GETERRSTR_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GETERRSTR_EX" ) = 000001BD38F63A30
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GETERRSTR_EX2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GETERRSTR_EX2" ) = 000001BD38F63B40
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SETERRRESPONSE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SETERRRESPONSE" ) = 000001BD38F63910
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GETERRSTR_EX3" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GETERRSTR_EX3" ) = 000001BD38F633F0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_PROCESS_GEL_COMMAND" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_PROCESS_GEL_COMMAND" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_PROCESS_GEL_COMMAND" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_PROCESS_GEL_COMMAND" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_PROCESS_GEL_COMMAND_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_PROCESS_GEL_COMMAND_EX" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_PROCESS_GEL_COMMAND_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_PROCESS_GEL_COMMAND_EX" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_EMURESET_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_EMURESET_EX" ) = 000001BD38F62F60
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_EMURESET_EX2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_EMURESET_EX2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_EMURESET_EX2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_EMURESET_EX2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_CONNECT2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_CONNECT2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_CONNECT2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_CONNECT2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_CONNECT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_CONNECT" ) = 000001BD38F65120
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_CONNECT3" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_CONNECT3" ) = 000001BD38F65160
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_DISCONNECT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_DISCONNECT" ) = 000001BD38F651C0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_DISCONNECT2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_DISCONNECT2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_DISCONNECT2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_DISCONNECT2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_DONE_REMOVING_DEBUG_STATE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_DONE_REMOVING_DEBUG_STATE" ) = 000001BD38F6A0E0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_CONTEXT_CONST" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_CONTEXT_CONST" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_CONTEXT_CONST" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_CONTEXT_CONST" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_EXEC_PACKET_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_EXEC_PACKET_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_EXEC_PACKET_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_EXEC_PACKET_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_EXEC_PACKET_INFO_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_EXEC_PACKET_INFO_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_EXEC_PACKET_INFO_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_EXEC_PACKET_INFO_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_READMEM_WITH_STAT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_READMEM_WITH_STAT" ) = 000001BD38F6C150
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_WRITEMEM_WITH_STAT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_WRITEMEM_WITH_STAT" ) = 000001BD38F6C400
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_READMEM_WITH_STAT_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_READMEM_WITH_STAT_64" ) = 000001BD38F6C020
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_WRITEMEM_WITH_STAT_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_WRITEMEM_WITH_STAT_64" ) = 000001BD38F6C280
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_QUERY_INTERFACE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_QUERY_INTERFACE" ) = 000001BD38F653F0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_BLOCK_RESET" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_BLOCK_RESET" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_BLOCK_RESET" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_BLOCK_RESET" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SET_ROUTER_SYSTEM_FEATURE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_SET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_SET_ROUTER_SYSTEM_FEATURE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_ROUTER_SYSTEM_FEATURE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_ROUTER_SYSTEM_FEATURE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_WAIT_IN_RESET_MODE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_WAIT_IN_RESET_MODE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_WAIT_IN_RESET_MODE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_WAIT_IN_RESET_MODE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SET_WAIT_IN_RESET" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SET_WAIT_IN_RESET" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_SET_WAIT_IN_RESET" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_SET_WAIT_IN_RESET" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_STAT_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_STAT_EX" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_STAT_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_STAT_EX" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_BP_TEST" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_BP_TEST" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_BP_TEST" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_BP_TEST" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_STAT_EX2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_STAT_EX2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_STAT_EX2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_STAT_EX2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_NUM_RESETS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_NUM_RESETS" ) = 000001BD38F6A590
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_RESET_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_RESET_INFO" ) = 000001BD38F6A600
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_RESET_EX" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_RESET_EX" ) = 000001BD38F6A4E0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_MAKE_DEVICE_SECURE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_MAKE_DEVICE_SECURE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_MAKE_DEVICE_SECURE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_MAKE_DEVICE_SECURE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SET_PROGRESS_CALLBACK" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SET_PROGRESS_CALLBACK" ) = 000001BD38F65CF0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_TARGET_VOLTAGE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_TARGET_VOLTAGE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_TARGET_VOLTAGE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_TARGET_VOLTAGE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_MEM_LEVEL_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_MEM_LEVEL_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_MEM_LEVEL_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_MEM_LEVEL_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_NON_INTRUSIVE_CAPABILITIES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_NON_INTRUSIVE_CAPABILITIES" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_NON_INTRUSIVE_CAPABILITIES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_NON_INTRUSIVE_CAPABILITIES" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SET_DIFF_FLASH_SUPPORT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SET_DIFF_FLASH_SUPPORT" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_SET_DIFF_FLASH_SUPPORT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_SET_DIFF_FLASH_SUPPORT" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_NUM_FLASH_LAYOUTS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_NUM_FLASH_LAYOUTS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_NUM_FLASH_LAYOUTS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_NUM_FLASH_LAYOUTS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_FLASH_LAYOUT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_FLASH_LAYOUT" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_FLASH_LAYOUT" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_FLASH_LAYOUT" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_DSPEVENT2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_DSPEVENT2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_DSPEVENT2" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_DSPEVENT2" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GETCAPABILITIES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GETCAPABILITIES" ) = 000001BD38F630F0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_MMU_STATE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_MMU_STATE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_MMU_STATE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_MMU_STATE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SET_MMU_STATE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SET_MMU_STATE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_SET_MMU_STATE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_SET_MMU_STATE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_NUM_MMU_TTBR_REGS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_NUM_MMU_TTBR_REGS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_NUM_MMU_TTBR_REGS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_NUM_MMU_TTBR_REGS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_TTBR_REG" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_TTBR_REG" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_TTBR_REG" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_TTBR_REG" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SET_TTBR_REG" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SET_TTBR_REG" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_SET_TTBR_REG" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_SET_TTBR_REG" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_CURRENT_PROCID" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_CURRENT_PROCID" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SET_CURRENT_PROCID" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_SET_CURRENT_PROCID" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_SET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_NUM_MMU_DOMAINS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_NUM_MMU_DOMAINS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_NUM_MMU_DOMAINS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_NUM_MMU_DOMAINS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_DOMAIN_ACCESS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_DOMAIN_ACCESS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SET_DOMAIN_ACCESS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_SET_DOMAIN_ACCESS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_SET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SET_ALL_DOMAIN_ACCESS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SET_ALL_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_SET_ALL_DOMAIN_ACCESS" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_SET_ALL_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_COHERENCY_CONTROL" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_COHERENCY_CONTROL" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_COHERENCY_CONTROL" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_COHERENCY_CONTROL" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_COHERENCY_CNTRL_SPECIFIC" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_COHERENCY_CNTRL_SPECIFIC" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_COHERENCY_CNTRL_SPECIFIC" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_COHERENCY_CNTRL_SPECIFIC" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SYNCRUN_REQUEST" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SYNCRUN_REQUEST" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_SYNCRUN_REQUEST" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_SYNCRUN_REQUEST" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_NUM_SYMBOL_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_NUM_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_NUM_SYMBOL_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_NUM_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_SYMBOL_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_SYMBOL_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SET_SYMBOL_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_SET_SYMBOL_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_SET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SET_SYMBOL_INFO_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SET_SYMBOL_INFO_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_SET_SYMBOL_INFO_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_SET_SYMBOL_INFO_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_READREG_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_READREG_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_READREG_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_READREG_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_WRITEREG_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_WRITEREG_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_WRITEREG_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_WRITEREG_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_PHYSICAL_PAGE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_PHYSICAL_PAGE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_GET_PHYSICAL_PAGE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_GET_PHYSICAL_PAGE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SET_LOW_POWER_MODE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SET_LOW_POWER_MODE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_SET_LOW_POWER_MODE" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_SET_LOW_POWER_MODE" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_NOTIFY_APP_MEMORY_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_NOTIFY_APP_MEMORY_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_NOTIFY_APP_MEMORY_INFO" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_NOTIFY_APP_MEMORY_INFO" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_NOTIFY_APP_MEMORY_INFO_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_NOTIFY_APP_MEMORY_INFO_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_NOTIFY_APP_MEMORY_INFO_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_NOTIFY_APP_MEMORY_INFO_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SETBP_EX_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SETBP_EX_64" ) = 000001BD38F6A0F0
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_CLEARBP_EX_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_CLEARBP_EX_64" ) = 000001BD38F6A100
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_BP_TEST_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_BP_TEST_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "_GTI_BP_TEST_64" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "_GTI_BP_TEST_64" ) = 0000000000000000
0x00001CD4 48130 3  LIB C: dlsym( 000001BD38F60000, "GTI_SETUP_PROPERTIES" )
0x00001CD4 48130 3  LIB R: dlsym( 000001BD38F60000, "GTI_SETUP_PROPERTIES" ) = 000001BD38F69F60
0x00001CD4 48130 3  GTI C: GTI_SETUP_PROPERTIES( "Texas Instruments XDS110 USB Debug Probe_CS_DAP_0", *0x000001BD364BFF60 = "Block Target Access on Free Run", *0x000001BD364BF520 = "1", 0x00000007 )
0x00001CD4 48130 3  GTI R: GTI_SETUP_PROPERTIES( "Texas Instruments XDS110 USB Debug Probe_CS_DAP_0", *0x000001BD364BFF60 = "Block Target Access on Free Run", *0x000001BD364BF520 = "1", 0x00000007 ) = 0x00000000
0x00001CD4 48130 3 CS_DAP_0 FLASH I: FlashProgrammerManager::Constructor
0x00001CD4 48130 3  LIB C: dlclose( 000001BD38F60000 )
0x00001CD4 48130 3  LIB R: dlclose( 000001BD38F60000 ) = 1
0x00001CD4 48130 3  GTI C: remote_dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cortexM.dvr" )
0x00001CD4 48130 3  GTI R: remote_dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cortexM.dvr" ) = 0x0000000000000000
0x00001CD4 48130 3  GTI C: remote_dlerror()
0x00001CD4 48130 3  GTI R: remote_dlerror() = ""
0x00001CD4 48130 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cortexM.dvr", 0 )
0x00001CD4 48130 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cortexM.dvr", 0 ) = 000001BD39090000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_VALIDATE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_VALIDATE" ) = 000001BD3909D240
0x00001CD4 48145 3  GTI C: GTI_VALIDATE( 0x0000000000000000, 0x00003D6C )
0x00001CD4 48145 3  GTI R: GTI_VALIDATE( 0x0000000000000000, 0x00003D6C ) = 0x00003D6C
0x00001CD4 48145 3  GTI C: remote_dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cortexM.dvr" )
0x00001CD4 48145 3  GTI R: remote_dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cortexM.dvr" ) = 0x0000000000000000
0x00001CD4 48145 3  GTI C: remote_dlerror()
0x00001CD4 48145 3  GTI R: remote_dlerror() = ""
0x00001CD4 48145 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cortexM.dvr", 0 )
0x00001CD4 48145 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\emulation\drivers\tixds510cortexM.dvr", 0 ) = 000001BD39090000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SET_DB_ACCESS" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SET_DB_ACCESS" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_SET_DB_ACCESS" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_SET_DB_ACCESS" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_INIT" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_INIT" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_INIT" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_INIT" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_QUIT" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_QUIT" ) = 000001BD390A1C50
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GETERRSTR" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GETERRSTR" ) = 000001BD3909DBC0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_RESET" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_RESET" ) = 000001BD390A07C0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_STEP" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_STEP" ) = 000001BD390A0630
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_RUN" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_RUN" ) = 000001BD390A0810
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GLOBALSTART" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GLOBALSTART" ) = 000001BD390A0750
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_STAT" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_STAT" ) = 000001BD3909FF40
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_READREG" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_READREG" ) = 000001BD390A2AF0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_WRITEREG" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_WRITEREG" ) = 000001BD390A2B90
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_READMEM" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_READMEM" ) = 000001BD390A2820
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_WRITEMEM" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_WRITEMEM" ) = 000001BD390A27D0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SETBP" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SETBP" ) = 000001BD3909D400
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_CLEARBP" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_CLEARBP" ) = 000001BD3909D510
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SETBP_EX" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SETBP_EX" ) = 000001BD3909D310
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_CLEARBP_EX" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_CLEARBP_EX" ) = 000001BD3909D420
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_HALT" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_HALT" ) = 000001BD390A00C0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_ADD_MEMMAP" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_ADD_MEMMAP" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_ADD_MEMMAP" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_ADD_MEMMAP" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_CLEAR_MEMMAP" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_CLEAR_MEMMAP" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_CLEAR_MEMMAP" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_CLEAR_MEMMAP" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_RESET_MEMMAP" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_RESET_MEMMAP" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_RESET_MEMMAP" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_RESET_MEMMAP" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_INIT3" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_INIT3" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_INIT3" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_INIT3" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_INIT_EX" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_INIT_EX" ) = 000001BD390A1B40
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_RUN_EX" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_RUN_EX" ) = 000001BD390A0280
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_READMEM_EX" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_READMEM_EX" ) = 000001BD390A26B0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_WRITEMEM_EX" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_WRITEMEM_EX" ) = 000001BD390A2770
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_READMEM_BLK" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_READMEM_BLK" ) = 000001BD390A2650
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_WRITEMEM_BLK" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_WRITEMEM_BLK" ) = 000001BD390A2710
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GETPROCTYPE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GETPROCTYPE" ) = 000001BD39093C30
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GETREV" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GETREV" ) = 000001BD3909CDE0
0x00001CD4 48145 3 Cortex_M4_0 GTI C: GTI_GETREV( 0x0000000000000000 )
0x00001CD4 48145 3 Cortex_M4_0 GTI R: GTI_GETREV( 0x0000000000000000 ) = 0x00003200
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SET_PROFILE_TYPE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SET_PROFILE_TYPE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_SET_PROFILE_TYPE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_SET_PROFILE_TYPE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_NUM_PROFILE_TYPES" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_NUM_PROFILE_TYPES" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_NUM_PROFILE_TYPES" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_NUM_PROFILE_TYPES" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_PROFILE_TYPE_NAME" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_PROFILE_TYPE_NAME" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_PROFILE_TYPE_NAME" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_PROFILE_TYPE_NAME" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_NUM_HBP_TYPES" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_NUM_HBP_TYPES" ) = 000001BD39091300
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_HBP_TYPE_NAME" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_HBP_TYPE_NAME" ) = 000001BD39091310
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_ENABLE_GLOBAL_BKPTS" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_ENABLE_GLOBAL_BKPTS" ) = 000001BD390913E0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_WAS_HBP_HIT" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_WAS_HBP_HIT" ) = 000001BD39091340
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_WAS_HBP_HIT_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_WAS_HBP_HIT_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_WAS_HBP_HIT_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_WAS_HBP_HIT_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_REALTIME_SWITCH" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_REALTIME_SWITCH" ) = 000001BD390A2AE0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GETBOARDINFO" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GETBOARDINFO" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GETBOARDINFO" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GETBOARDINFO" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_LOOKUP_REG_BY_NAME" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_LOOKUP_REG_BY_NAME" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_LOOKUP_REG_BY_NAME" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_LOOKUP_REG_BY_NAME" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GETPROCINFO" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GETPROCINFO" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GETPROCINFO" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GETPROCINFO" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_PROC_ID" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_PROC_ID" ) = 000001BD39093C40
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_PROC_MINOR_ID" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_PROC_MINOR_ID" ) = 000001BD39093C50
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_EXT_CAPABILITIES" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_EXT_CAPABILITIES" ) = 000001BD3909CDF0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_TARGET_PROPERTIES" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_TARGET_PROPERTIES" ) = 000001BD39093CA0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_SIM_MODE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_SIM_MODE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_SIM_MODE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_SIM_MODE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SET_SIM_MODE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SET_SIM_MODE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_SET_SIM_MODE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_SET_SIM_MODE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GETERRSTR_EX" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GETERRSTR_EX" ) = 000001BD3909DBA0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GETERRSTR_EX2" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GETERRSTR_EX2" ) = 000001BD3909DCB0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SETERRRESPONSE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SETERRRESPONSE" ) = 000001BD3909DA80
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GETERRSTR_EX3" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GETERRSTR_EX3" ) = 000001BD3909D590
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_PROCESS_GEL_COMMAND" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_PROCESS_GEL_COMMAND" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_PROCESS_GEL_COMMAND" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_PROCESS_GEL_COMMAND" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_PROCESS_GEL_COMMAND_EX" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_PROCESS_GEL_COMMAND_EX" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_PROCESS_GEL_COMMAND_EX" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_PROCESS_GEL_COMMAND_EX" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_EMURESET_EX" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_EMURESET_EX" ) = 000001BD3909CEA0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_EMURESET_EX2" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_EMURESET_EX2" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_EMURESET_EX2" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_EMURESET_EX2" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_CONNECT2" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_CONNECT2" ) = 000001BD390A1DC0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_CONNECT3" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_CONNECT3" ) = 000001BD390A1E00
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_DISCONNECT" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_DISCONNECT" ) = 000001BD390A1E60
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_DISCONNECT2" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_DISCONNECT2" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_DISCONNECT2" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_DISCONNECT2" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_DONE_REMOVING_DEBUG_STATE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_DONE_REMOVING_DEBUG_STATE" ) = 000001BD3909D530
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_CONTEXT_CONST" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_CONTEXT_CONST" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_CONTEXT_CONST" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_CONTEXT_CONST" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_EXEC_PACKET_INFO" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_EXEC_PACKET_INFO" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_EXEC_PACKET_INFO" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_EXEC_PACKET_INFO" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_EXEC_PACKET_INFO_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_EXEC_PACKET_INFO_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_EXEC_PACKET_INFO_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_EXEC_PACKET_INFO_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_READMEM_WITH_STAT" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_READMEM_WITH_STAT" ) = 000001BD39091A40
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_WRITEMEM_WITH_STAT" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_WRITEMEM_WITH_STAT" ) = 000001BD39091B70
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_READMEM_WITH_STAT_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_READMEM_WITH_STAT_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_READMEM_WITH_STAT_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_READMEM_WITH_STAT_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_WRITEMEM_WITH_STAT_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_WRITEMEM_WITH_STAT_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_WRITEMEM_WITH_STAT_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_WRITEMEM_WITH_STAT_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_QUERY_INTERFACE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_QUERY_INTERFACE" ) = 000001BD390A20B0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_BLOCK_RESET" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_BLOCK_RESET" ) = 000001BD3909E6D0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_NUM_ROUTER_SYSTEM_FEATURES" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_ROUTER_SYSTEM_FEATURES_INFO" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SET_ROUTER_SYSTEM_FEATURE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_SET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_SET_ROUTER_SYSTEM_FEATURE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_ROUTER_SYSTEM_FEATURE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_ROUTER_SYSTEM_FEATURE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_ROUTER_SYSTEM_FEATURE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_WAIT_IN_RESET_MODE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_WAIT_IN_RESET_MODE" ) = 000001BD3909E5E0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SET_WAIT_IN_RESET" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SET_WAIT_IN_RESET" ) = 000001BD3909E520
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_STAT_EX" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_STAT_EX" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_STAT_EX" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_STAT_EX" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_BP_TEST" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_BP_TEST" ) = 000001BD3909E7F0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_STAT_EX2" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_STAT_EX2" ) = 000001BD3909DD70
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_NUM_RESETS" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_NUM_RESETS" ) = 000001BD3909E370
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_RESET_INFO" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_RESET_INFO" ) = 000001BD3909E420
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_RESET_EX" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_RESET_EX" ) = 000001BD3909E250
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_MAKE_DEVICE_SECURE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_MAKE_DEVICE_SECURE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_MAKE_DEVICE_SECURE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_MAKE_DEVICE_SECURE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SET_PROGRESS_CALLBACK" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SET_PROGRESS_CALLBACK" ) = 000001BD390A2AD0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_TARGET_VOLTAGE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_TARGET_VOLTAGE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_TARGET_VOLTAGE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_TARGET_VOLTAGE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_MEM_LEVEL_INFO" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_MEM_LEVEL_INFO" ) = 000001BD39091CF0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_NON_INTRUSIVE_CAPABILITIES" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_NON_INTRUSIVE_CAPABILITIES" ) = 000001BD3909CE10
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SET_DIFF_FLASH_SUPPORT" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SET_DIFF_FLASH_SUPPORT" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_SET_DIFF_FLASH_SUPPORT" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_SET_DIFF_FLASH_SUPPORT" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_NUM_FLASH_LAYOUTS" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_NUM_FLASH_LAYOUTS" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_NUM_FLASH_LAYOUTS" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_NUM_FLASH_LAYOUTS" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_FLASH_LAYOUT" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_FLASH_LAYOUT" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_FLASH_LAYOUT" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_FLASH_LAYOUT" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_DSPEVENT2" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_DSPEVENT2" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_DSPEVENT2" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_DSPEVENT2" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GETCAPABILITIES" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GETCAPABILITIES" ) = 000001BD3909CFE0
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_MMU_STATE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_MMU_STATE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_MMU_STATE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_MMU_STATE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SET_MMU_STATE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SET_MMU_STATE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_SET_MMU_STATE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_SET_MMU_STATE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_NUM_MMU_TTBR_REGS" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_NUM_MMU_TTBR_REGS" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_NUM_MMU_TTBR_REGS" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_NUM_MMU_TTBR_REGS" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_TTBR_REG" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_TTBR_REG" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_TTBR_REG" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_TTBR_REG" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SET_TTBR_REG" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SET_TTBR_REG" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_SET_TTBR_REG" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_SET_TTBR_REG" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_CURRENT_PROCID" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_CURRENT_PROCID" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SET_CURRENT_PROCID" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_SET_CURRENT_PROCID" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_SET_CURRENT_PROCID" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_NUM_MMU_DOMAINS" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_NUM_MMU_DOMAINS" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_NUM_MMU_DOMAINS" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_NUM_MMU_DOMAINS" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_DOMAIN_ACCESS" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_DOMAIN_ACCESS" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SET_DOMAIN_ACCESS" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_SET_DOMAIN_ACCESS" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_SET_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SET_ALL_DOMAIN_ACCESS" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SET_ALL_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_SET_ALL_DOMAIN_ACCESS" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_SET_ALL_DOMAIN_ACCESS" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_COHERENCY_CONTROL" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_COHERENCY_CONTROL" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_COHERENCY_CONTROL" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_COHERENCY_CONTROL" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_COHERENCY_CNTRL_SPECIFIC" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_COHERENCY_CNTRL_SPECIFIC" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_COHERENCY_CNTRL_SPECIFIC" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_COHERENCY_CNTRL_SPECIFIC" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SYNCRUN_REQUEST" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SYNCRUN_REQUEST" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_SYNCRUN_REQUEST" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_SYNCRUN_REQUEST" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_NUM_SYMBOL_INFO" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_NUM_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_NUM_SYMBOL_INFO" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_NUM_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_SYMBOL_INFO" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_SYMBOL_INFO" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SET_SYMBOL_INFO" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_SET_SYMBOL_INFO" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_SET_SYMBOL_INFO" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SET_SYMBOL_INFO_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SET_SYMBOL_INFO_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_SET_SYMBOL_INFO_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_SET_SYMBOL_INFO_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_READREG_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_READREG_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_READREG_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_READREG_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_WRITEREG_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_WRITEREG_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_WRITEREG_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_WRITEREG_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_PHYSICAL_PAGE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_PHYSICAL_PAGE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_GET_PHYSICAL_PAGE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_GET_PHYSICAL_PAGE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SET_LOW_POWER_MODE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SET_LOW_POWER_MODE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_SET_LOW_POWER_MODE" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_SET_LOW_POWER_MODE" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_NOTIFY_APP_MEMORY_INFO" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_NOTIFY_APP_MEMORY_INFO" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_NOTIFY_APP_MEMORY_INFO" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_NOTIFY_APP_MEMORY_INFO" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_NOTIFY_APP_MEMORY_INFO_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_NOTIFY_APP_MEMORY_INFO_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_NOTIFY_APP_MEMORY_INFO_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_NOTIFY_APP_MEMORY_INFO_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SETBP_EX_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SETBP_EX_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_SETBP_EX_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_SETBP_EX_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_CLEARBP_EX_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_CLEARBP_EX_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_CLEARBP_EX_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_CLEARBP_EX_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_BP_TEST_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_BP_TEST_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "_GTI_BP_TEST_64" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "_GTI_BP_TEST_64" ) = 0000000000000000
0x00001CD4 48145 3  LIB C: dlsym( 000001BD39090000, "GTI_SETUP_PROPERTIES" )
0x00001CD4 48145 3  LIB R: dlsym( 000001BD39090000, "GTI_SETUP_PROPERTIES" ) = 000001BD390A2C40
0x00001CD4 48145 3  GTI C: GTI_SETUP_PROPERTIES( "Texas Instruments XDS110 USB Debug Probe_Cortex_M4_0", *0x000001BD364C88A0 = "haltOnConnectByDefault", *0x000001BD364C8E60 = "true", 0x00000006 )
0x00001CD4 48145 3  GTI R: GTI_SETUP_PROPERTIES( "Texas Instruments XDS110 USB Debug Probe_Cortex_M4_0", *0x000001BD364C88A0 = "haltOnConnectByDefault", *0x000001BD364C8E60 = "true", 0x00000006 ) = 0x00000000
0x00001CD4 48145 3 Cortex_M4_0 FLASH I: FlashProgrammerManager::Constructor
0x00001CD4 48145 3  LIB C: dlclose( 000001BD39090000 )
0x00001CD4 48145 3  LIB R: dlclose( 000001BD39090000 ) = 1
0x00001CD4 48145 3  LIB C: dlclose( 000001BD38E90000 )
0x00001CD4 48145 3  LIB R: dlclose( 000001BD38E90000 ) = 1
0x00001CD4 48145 3  COM_DBG_IF C: class CoProgressTask::OnUpdate()
0x00001CD4 48145 3  XPCOM C: ( (dsIObjectEventCallback*)000001BD3541E5C0 )->onEvent( 000001BD2B315CC0 )
0x00001CD4 48145 3  XPCOM C: ( (nsISupports*)000001BD2B315CC8 )->queryInterface( 000001BD36C78B50, 0000000DAD8FC8F8 )
0x00001CD4 48145 3  XPCOM R: ( (nsISupports*)000001BD2B315CC8 )->queryInterface( 000001BD36C78B50, *0000000DAD8FC8F8 = 000001BD2B315CC0 ) = 0x00000000
0x00001CD4 48145 3  XPCOM C: ( (dsIProgressTaskData*)000001BD2B315CC0 )->PercentDone( 0000000DAD8FC950 )
0x00001CD4 48145 3  XPCOM R: ( (dsIProgressTaskData*)000001BD2B315CC0 )->PercentDone( *0000000DAD8FC950 = 0x00000000 ) = 0x00000000
0x00001CD4 48145 3  XPCOM C: ( (dsIProgressTaskData*)000001BD2B315CC0 )->SubActivity( 0000000DAD8FC950 )
0x00001CD4 48145 3  XPCOM R: ( (dsIProgressTaskData*)000001BD2B315CC0 )->SubActivity( *0000000DAD8FC950 = Initializing: IcePick_C ) = 0x00000000
0x00001CD4 48145 3  XPCOM R: ( (dsIObjectEventCallback*)000001BD3541E5C0 )->onEvent( 000001BD2B315CC0 ) = 0x00000000
0x00001CD4 48145 3  COM_DBG_IF R: class CoProgressTask::OnUpdate()
0x00001CD4 48145 3 IcePick_C POLL C: Polling with state CPU_ST_INITIALIZE and status EVENT_DSP_HALT
0x00001CD4 48145 3 IcePick_C GTI C: GTI_GETCAPABILITIES( 0x0000000000000000 )
0x00001CD4 48145 3 IcePick_C GTI R: GTI_GETCAPABILITIES( 0x0000000000000000 ) = 0x85030010
0x00001CD4 48145 3 IcePick_C GTI C: GTI_SET_PROGRESS_CALLBACK( 0x0000000000000000, *0x000001BD36C6F3F0 = ??? )
0x00001CD4 48145 3 IcePick_C GTI R: GTI_SET_PROGRESS_CALLBACK( 0x0000000000000000, *0x000001BD36C6F3F0 = ??? ) = 0x00000000
0x00001CD4 48145 3  PERF I: GTI_INIT starting...
0x00001CD4 48145 3 IcePick_C GTI C: GTI_INIT_EX( 0x0000, "Texas Instruments XDS110 USB Debug Probe_IcePick_C/IcePick_C", 0x00000240, "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat", 0x00000640, 0x0000D000, 0x0000000C, *0x0000000DAD8FDE00 = { 0x0000000B, 0x00000080, 0x0000000000000000, 0x0000000000000000, "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat", 0x0000000000000000, 0x000001BD3508A1B8, "CC2642R1F", 0x0000000000000000, 0x000001BD2E450E60, 0x000001BD29E17E88, 0x000001BD36013570, "" }, *0x000001BD367E8B18 = 0x0000000000000000 )
0x00001CD4 48161 3  XDS110 C: XDS_SetProperty((*XDSInform) 0000000DAD8FAC60, XDS_PROPERTY_LOGGING_ENABLED, 1 ("enable"))
0x00001CD4 48161 3  XDS110 R: XDS_SetProperty((*XDSInform) 0000000DAD8FAC60, XDS_PROPERTY_LOGGING_ENABLED, 1 ("enable")) = 0
0x00001CD4 48161 3  XDS110 C: Executing command 0x01 (XDS_CONNECT)
0x00001CD4 48255 3  XDS110 R: Executed command 0x01 (XDS_CONNECT), return code: 0x00000000
0x00001CD4 48255 3  XDS110 C: Executing command 0x03 (XDS_VERSION)
0x00001CD4 48255 3  XDS110 R: Executed command 0x03 (XDS_VERSION), return code: 0x00000000
0x00001CD4 48255 3  XDS110 C: Executing command 0x02 (XDS_DISCONNECT)
0x00001CD4 48363 3  XDS110 R: Executed command 0x02 (XDS_DISCONNECT), return code: 0x00000000
0x00001CD4 48405 3  XDS110 C: Executing command 0x28 (XDS_CONNECTET)
0x00001CD4 48500 3  XDS110 R: Executed command 0x28 (XDS_CONNECTET), return code: 0x00000000
0x00001CD4 48500 3  XDS110 C: Executing command 0x03 (XDS_VERSION)
0x00001CD4 48500 3  XDS110 R: Executed command 0x03 (XDS_VERSION), return code: 0x00000000
0x00001CD4 48500 3  XDS110 C: Executing command 0x02 (XDS_DISCONNECT)
0x00001CD4 48610 3  XDS110 R: Executed command 0x02 (XDS_DISCONNECT), return code: 0x00000000
0x00001CD4 48610 3 IcePick_C GTI R: GTI_INIT_EX( 0x0000, "Texas Instruments XDS110 USB Debug Probe_IcePick_C/IcePick_C", 0x00000240, "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat", 0x00000640, 0x0000D000, 0x0000000C, *0x0000000DAD8FDE00 = { 0x0000000B, 0x00000080, 0x0000000000000000, 0x0000000000000000, "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat", 0x0000000000000000, 0x000001BD3508A1B8, "CC2642R1F", 0x0000000000000000, 0x000001BD2E450E60, 0x000001BD29E17E88, 0x000001BD36013570, "" }, *0x000001BD367E8B18 = 0x000001BD29E173E0 ) = 0x00000000
0x00001CD4 48610 3  PERF I: GTI_INIT finished:  0.470102s wall, 0.125000s user + 0.078125s system = 0.203125s CPU (43.2%)
0x00001CD4 48610 3 IcePick_C GTI C: GTI_GETCAPABILITIES( 0x000001BD29E173E0 )
0x00001CD4 48610 3 IcePick_C GTI R: GTI_GETCAPABILITIES( 0x000001BD29E173E0 ) = 0x85030010
0x00001CD4 48610 3 IcePick_C GTI C: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E173E0, 0 )
0x00001CD4 48610 3 IcePick_C GTI R: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E173E0, 0 ) = 0x85030010
0x00001CD4 48610 3 IcePick_C GTI C: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E173E0, 2 )
0x00001CD4 48610 3 IcePick_C GTI R: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E173E0, 2 ) = 0x04000000
0x00001CD4 48610 3 IcePick_C GTI C: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E173E0, 1 )
0x00001CD4 48610 3 IcePick_C GTI R: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E173E0, 1 ) = 0x00000000
0x00001CD4 48610 3 IcePick_C GTI C: GTI_SET_PROGRESS_CALLBACK( 0x000001BD29E173E0, *0x000001BD36C6F3F0 = ??? )
0x00001CD4 48610 3 IcePick_C GTI R: GTI_SET_PROGRESS_CALLBACK( 0x000001BD29E173E0, *0x000001BD36C6F3F0 = ??? ) = 0x00000000
0x00001CD4 48610 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\DebugServer\bin\..\..\emulation\tpi\tpi_icepick.dll", 0 )
0x00001CD4 48610 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\DebugServer\bin\..\..\emulation\tpi\tpi_icepick.dll", 0 ) = 000001BD390F0000
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "TpiGenAPI" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "TpiGenAPI" ) = 000001BD390F17E0
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "TpiRegWinAPI" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "TpiRegWinAPI" ) = 000001BD390F21B0
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "TpiStackAPI" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "TpiStackAPI" ) = 000001BD390F2640
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "TpiStepAPI" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "TpiStepAPI" ) = 000001BD390F27B0
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "TpiDisasmAPI" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "TpiDisasmAPI" ) = 000001BD390F1470
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "TpiPatchAsmAPI" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "TpiPatchAsmAPI" ) = 000001BD390F1E50
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "TpiProfileAPI" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "TpiProfileAPI" ) = 0000000000000000
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "_TpiProfileAPI" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "_TpiProfileAPI" ) = 0000000000000000
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "TpiDataWinAPI" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "TpiDataWinAPI" ) = 000001BD390F12F0
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "TpiGenAPI64" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "TpiGenAPI64" ) = 0000000000000000
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "_TpiGenAPI64" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "_TpiGenAPI64" ) = 0000000000000000
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "TpiStepAPI64" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "TpiStepAPI64" ) = 0000000000000000
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "_TpiStepAPI64" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "_TpiStepAPI64" ) = 0000000000000000
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "TpiDisasmAPI64" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "TpiDisasmAPI64" ) = 0000000000000000
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "_TpiDisasmAPI64" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "_TpiDisasmAPI64" ) = 0000000000000000
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "TpiPatchAsmAPI64" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "TpiPatchAsmAPI64" ) = 0000000000000000
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "_TpiPatchAsmAPI64" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "_TpiPatchAsmAPI64" ) = 0000000000000000
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "TpiProfileAPI64" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "TpiProfileAPI64" ) = 0000000000000000
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "_TpiProfileAPI64" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "_TpiProfileAPI64" ) = 0000000000000000
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "TpiDataWinAPI64" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "TpiDataWinAPI64" ) = 0000000000000000
0x00001CD4 48610 3  LIB C: dlsym( 000001BD390F0000, "_TpiDataWinAPI64" )
0x00001CD4 48610 3  LIB R: dlsym( 000001BD390F0000, "_TpiDataWinAPI64" ) = 0000000000000000
0x00001CD4 48610 3 IcePick_C TPI C: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_GET_REVISION, *0000000DAD8FDDD0 )
0x00001CD4 48610 3 IcePick_C TPI R: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_GET_REVISION, *0000000DAD8FDDD0 = 0x00000065 ) = 0x00000000
0x00001CD4 48610 3 IcePick_C TPI C: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_CONSTRUCTOR, 0x0000000D3C000805, 0x0000000000000000, 0x000001BD367E9B00 )
0x00001CD4 48610 3 IcePick_C TPI R: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_CONSTRUCTOR, 0x0000000D3C000805, 0x0000000000000000, 0x000001BD367E9B00 ) = 0x00000000
0x00001CD4 48610 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_SET_DS_VERSION, 0x0000000D0000000C, 0x0000000000000000, 0x000001BD00000000 )
0x00001CD4 48610 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_SET_DS_VERSION, 0x0000000D0000000C, 0x0000000000000000, 0x000001BD00000000 ) = 0x00000002
0x00001CD4 48610 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_NUM_PAGES, *0000000DAD8FDD80 )
0x00001CD4 48610 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_NUM_PAGES, *0000000DAD8FDD80 = 0x00000001 ) = 0x00000000
0x00001CD4 48610 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000000 )
0x00001CD4 48610 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000000 ) = 0x00000000
0x00001CD4 48610 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000000, 0x0000000DAD8FDC08 )
0x00001CD4 48610 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000000, 0x0000000DAD8FDC08 ) = 0x00000000
0x00001CD4 48610 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000000, *0000000DAD8FDC48 )
0x00001CD4 48610 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000000, *0000000DAD8FDC48 = 0x00000002 ) = 0x00000000
0x00001CD4 48610 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000000, *0000000DAD8FDC50 )
0x00001CD4 48610 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000000, *0000000DAD8FDC50 = 0xAD8FDD00 ) = 0x00000002
0x00001CD4 48610 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000000, *0000000DAD8FDC4C )
0x00001CD4 48610 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000000, *0000000DAD8FDC4C = 0x00000004 ) = 0x00000002
0x00001CD4 48610 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_DEFAULT_PAGE, *000001BD2B315A08 )
0x00001CD4 48610 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_DEFAULT_PAGE, *000001BD2B315A08 = 0x00000000 ) = 0x00000002
0x00001CD4 48610 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_REG_PAGES, *0000000DAD8FDD88, *0000000DAD8FDD80 )
0x00001CD4 48610 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_REG_PAGES, *0000000DAD8FDD88 = 0x00000001, *0000000DAD8FDD80 = 0x00000079 ) = 0x00000002
0x00001CD4 48610 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_REGBUS_BITS, 0x0000000DAD8FDC00, 0x0000000000000079 )
0x00001CD4 48610 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_REGBUS_BITS, 0x0000000DAD8FDC00, 0x0000000000000079 ) = 0x00000000
0x00001CD4 48610 3  SETUP I: SELECT count(Connections.dbid) FROM Configurations, Connections WHERE Connections.parent_dbid=Configurations.dbid AND Configurations.parent_dbid=9
0x00001CD4 48610 3  SETUP I: SELECT Connections.dbid AS dbid, Connections.Name AS Name, Connections.Class AS Class, Connections.Short_Description AS Short_Description, Connections.Long_Description AS Long_Description FROM Configurations, Connections WHERE Connections.parent_dbid=Configurations.dbid AND Configurations.parent_dbid=9
0x00001CD4 48610 3  SETUP I: SELECT count(*) FROM Processors WHERE Connection=9
0x00001CD4 48610 3  SETUP I: SELECT * FROM Processors WHERE Connection=9
0x00001CD4 48610 3  SETUP I: SELECT count(*) FROM Module_Instances WHERE Hidden = 0 AND parent_dbid=33 AND parent_type="Processors"
0x00001CD4 48610 3  SETUP I: SELECT COUNT(*) FROM Register_Pages WHERE Processor=33
0x00001CD4 48610 3 IcePick_C GTI C: GTI_GET_NUM_RESETS( 0x000001BD29E173E0 )
0x00001CD4 48610 3 IcePick_C GTI R: GTI_GET_NUM_RESETS( 0x000001BD29E173E0 ) = 0x00000002
0x00001CD4 48610 3 IcePick_C GTI C: GTI_GET_RESET_INFO( 0x000001BD29E173E0, 0x00000000, *0x0000000DAD8FDBD0 = ??? )
0x00001CD4 48610 3 IcePick_C GTI R: GTI_GET_RESET_INFO( 0x000001BD29E173E0, 0x00000000, *0x0000000DAD8FDBD0 = ??? ) = 0x00000000
0x00001CD4 48610 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD3F8 = 0x00000000, *0x0000000DAD8FD3F0 = 0x00000000, *0x0000000DAD8FD408 = 0x00000000, *0x0000000DAD8FD420 = 0x00000000, *0x0000000DAD8FD428 = 0x00000000, *0x0000000DAD8FD418 = 0x00000000, *0x0000000DAD8FD410 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 48610 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD3F8 = 0x00000000, *0x0000000DAD8FD3F0 = 0x00000000, *0x0000000DAD8FD408 = 0x00000000, *0x0000000DAD8FD420 = 0x00000002, *0x0000000DAD8FD428 = 0x00000000, *0x0000000DAD8FD418 = 0x00000008, *0x0000000DAD8FD410 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 48610 3 IcePick_C GTI C: GTI_GET_RESET_INFO( 0x000001BD29E173E0, 0x00000001, *0x0000000DAD8FDBD0 = ??? )
0x00001CD4 48610 3 IcePick_C GTI R: GTI_GET_RESET_INFO( 0x000001BD29E173E0, 0x00000001, *0x0000000DAD8FDBD0 = ??? ) = 0x00000000
0x00001CD4 48610 3 IcePick_C POLL D: New request of type DSP_RQ_NONE added to polling loop by class MemMapChangeBroadcaster
0x00001CD4 48610 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_SET_CALLBACK, 0x000001BD3D1FAC00, 0x00007FFEC49C30E0 )
0x00001CD4 48610 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_SET_CALLBACK, 0x000001BD3D1FAC00, 0x00007FFEC49C30E0 ) = 0x00000002
0x00001CD4 48610 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='CLK' AND Register_Cache.Processor=33
0x00001CD4 48610 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDB78 )
0x00001CD4 48610 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDB78 ) = 0x00000000
0x00001CD4 48610 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDB70 )
0x00001CD4 48610 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDB70 ) = 0x00000002
0x00001CD4 48610 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDB18 )
0x00001CD4 48610 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDB18 ) = 0x00000000
0x00001CD4 48610 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDB10 )
0x00001CD4 48610 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDB10 ) = 0x00000002
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDB18 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDB18 ) = 0x00000000
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDB10 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDB10 ) = 0x00000002
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDB08 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDB08 ) = 0x00000000
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDB00 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDB00 ) = 0x00000002
0x00001CD4 48625 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='FP' AND Register_Cache.Processor=33
0x00001CD4 48625 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775808 AND Register_Cache.Address<=-9223372036854775808 AND Register_Cache.Page=0 AND Register_Cache.Processor=33
0x00001CD4 48625 3  SETUP I: SELECT MAX( Register_Cache.Address ) FROM Register_Cache, Registers, Module_Instances WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address<-9223372036854775808 AND Register_Cache.Page=0 AND Register_Cache.Processor=33 AND Module_Instances.dbid=Register_Cache.Module AND Module_Instances.Hidden=0
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD758 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD758 ) = 0x00000000
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD750 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD750 ) = 0x00000002
0x00001CD4 48625 3 IcePick_C GEL I: Evaluating "0"
0x00001CD4 48625 3 IcePick_C POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 48625 3 IcePick_C GEL I: Evaluating "5"
0x00001CD4 48625 3 IcePick_C GEL I: Evaluating "1"
0x00001CD4 48625 3 IcePick_C GEL I: Evaluating "80"
0x00001CD4 48625 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 48625 3 IcePick_C POLL R: Poll() returning
0x00001CD4 48625 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class `anonymous namespace'::SystemInitializerPollFrequencyManager
0x00001CD4 48625 4  POLL I: Yielding to other threads
0x00001CD4 48625 3  COM_DBG_IF C: class CoProgressTask::OnUpdate()
0x00001CD4 48625 3  XPCOM C: ( (dsIObjectEventCallback*)000001BD3541E5C0 )->onEvent( 000001BD2B319680 )
0x00001CD4 48625 3  XPCOM C: ( (nsISupports*)000001BD2B319688 )->queryInterface( 000001BD3D1FD360, 0000000DAD8FC8D8 )
0x00001CD4 48625 3  XPCOM R: ( (nsISupports*)000001BD2B319688 )->queryInterface( 000001BD3D1FD360, *0000000DAD8FC8D8 = 000001BD2B319680 ) = 0x00000000
0x00001CD4 48625 3  XPCOM C: ( (dsIProgressTaskData*)000001BD2B319680 )->PercentDone( 0000000DAD8FC930 )
0x00001CD4 48625 3  XPCOM R: ( (dsIProgressTaskData*)000001BD2B319680 )->PercentDone( *0000000DAD8FC930 = 0x00000000 ) = 0x00000000
0x00001CD4 48625 3  XPCOM C: ( (dsIProgressTaskData*)000001BD2B319680 )->SubActivity( 0000000DAD8FC930 )
0x00001CD4 48625 3  XPCOM R: ( (dsIProgressTaskData*)000001BD2B319680 )->SubActivity( *0000000DAD8FC930 = Executing Startup Scripts: IcePick_C ) = 0x00000000
0x00001CD4 48625 3  XPCOM R: ( (dsIObjectEventCallback*)000001BD3541E5C0 )->onEvent( 000001BD2B319680 ) = 0x00000000
0x00001CD4 48625 3  COM_DBG_IF R: class CoProgressTask::OnUpdate()
0x00001CD4 48625 3  SEQUENCE I: Finished sequence step at 0000000DAD8FE2A8
0x00001CD4 48625 3  SEQUENCE I: Beginning class `anonymous namespace'::LoadStartupGelStep at 000001BD35502AF0
0x00001CD4 48625 3  PERF I: GEL OnStartUp() starting...
0x00001CD4 48625 3 IcePick_C POLL C: Firing DSP_GEL_FILE_LIST_CHANGED to all DSP_USER's
0x00001CD4 48625 3 IcePick_C POLL C: Firing of DSP_GEL_FILE_LIST_CHANGED complete
0x00001CD4 48625 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='SP' AND Register_Cache.Processor=33
0x00001CD4 48625 3 IcePick_C POLL C: Firing DSP_NEW_SYMBOLS to all DSP_USER's
0x00001CD4 48625 3 IcePick_C POLL D: New request of type DSP_RQ_NONE added to polling loop by class DebuggerListeners
0x00001CD4 48625 3 IcePick_C POLL C: Firing of DSP_NEW_SYMBOLS complete
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDAE8 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDAE8 ) = 0x00000000
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDAE0 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDAE0 ) = 0x00000002
0x00001CD4 48625 3 IcePick_C GEL I: Evaluating "StartUp(12, 0, 0, 2795)"
0x00001CD4 48625 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::SystemInitializerPollFrequencyManager
0x00001CD4 48625 4 IcePick_C POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 48625 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 48625 3 IcePick_C POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 48625 3 IcePick_C POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 48625 3 IcePick_C POLL C: Firing DSP_REQ_EVENT to class MemMapChangeBroadcaster
0x00001CD4 48625 3 IcePick_C POLL D: New request of type DSP_RQ_NONE added to polling loop by class MemMapChangeBroadcaster
0x00001CD4 48625 3 IcePick_C POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 48625 3 IcePick_C POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD518 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD518 ) = 0x00000000
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD510 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD510 ) = 0x00000002
0x00001CD4 48625 3 IcePick_C GEL I: Evaluation of "0" completed - Value: 0 Location: unknown
0x00001CD4 48625 3 IcePick_C GEL I: Evaluation of "5" completed - Value: 5 Location: unknown
0x00001CD4 48625 3 IcePick_C GEL I: Evaluation of "1" completed - Value: 1 Location: unknown
0x00001CD4 48625 3 IcePick_C GEL I: Evaluation of "80" completed - Value: 80 Location: unknown
0x00001CD4 48625 3 IcePick_C POLL C: Firing DSP_REQ_EVENT to class DebuggerListeners
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD318 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD318 ) = 0x00000000
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD310 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD310 ) = 0x00000002
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCFE8 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCFE8 ) = 0x00000000
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCFE0 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCFE0 ) = 0x00000002
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCCB8 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCCB8 ) = 0x00000000
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCCB0 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCCB0 ) = 0x00000002
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FC988 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FC988 ) = 0x00000000
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FC980 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FC980 ) = 0x00000002
0x00001CD4 48625 2 IcePick_C GEL I: cc26xx_icepick.gel:8	Enter function StartUp
0x00001CD4 48625 3 IcePick_C POLL C: Firing DSP_MEM_MAP_UPDATED to all DSP_USER's
0x00001CD4 48625 3 IcePick_C POLL C: Firing of DSP_MEM_MAP_UPDATED complete
0x00001CD4 48625 2 IcePick_C GEL I: cc26xx_icepick.gel:10	   GEL_LoadGel("$(GEL_file_dir)/cc26xx_connect_util.gel")
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD368 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD368 ) = 0x00000000
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD360 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD360 ) = 0x00000002
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCA08 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCA08 ) = 0x00000000
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCA00 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCA00 ) = 0x00000002
0x00001CD4 48625 3 IcePick_C GEL I: Evaluating "-(1)"
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD498 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD498 ) = 0x00000000
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD490 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD490 ) = 0x00000002
0x00001CD4 48625 2 IcePick_C GEL I: cc26xx_icepick.gel:10	Leave function StartUp
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD0C8 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD0C8 ) = 0x00000000
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD0C0 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD0C0 ) = 0x00000002
0x00001CD4 48625 3 IcePick_C GEL I: Evaluation of "StartUp(12, 0, 0, 2795)" completed - Value: 0 Location: unknown
0x00001CD4 48625 3  PERF I: GEL OnStartUp() finished:  0.005789s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 48625 3  SEQUENCE I: Finished sequence step at 000001BD35502AF0
0x00001CD4 48625 3  SEQUENCE I: Beginning class Debugger::LambdaSequenceStep<class <lambda_bcb20481c62572668180f439a17adeae> > at 000001BD3D1FD360
0x00001CD4 48625 3  SEQUENCE I: Finished sequence step at 000001BD3D1FD360
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD478 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD478 ) = 0x00000000
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD470 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD470 ) = 0x00000002
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD1B8 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD1B8 ) = 0x00000000
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD1B0 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD1B0 ) = 0x00000002
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD288 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD288 ) = 0x00000000
0x00001CD4 48625 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD280 )
0x00001CD4 48625 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD280 ) = 0x00000002
0x00001CD4 48625 3 IcePick_C GEL I: Evaluation of "-(1)" completed - Value: -1 Location: unknown
0x00001CD4 48625 3  XPCOM C: ( (dsIObjectEventCallback*)000001BD3541E5C0 )->onEvent( 000001BD2B318780 )
0x00001CD4 48625 3  XPCOM C: ( (nsISupports*)000001BD2B318788 )->queryInterface( 000001BD3D1FCDA0, 0000000DAD8FC848 )
0x00001CD4 48625 3  XPCOM R: ( (nsISupports*)000001BD2B318788 )->queryInterface( 000001BD3D1FCDA0, *0000000DAD8FC848 = 000001BD2B318780 ) = 0x00000000
0x00001CD4 48625 3  XPCOM C: ( (dsIProgressTaskData*)000001BD2B318780 )->PercentDone( 0000000DAD8FC8A0 )
0x00001CD4 48625 3  XPCOM R: ( (dsIProgressTaskData*)000001BD2B318780 )->PercentDone( *0000000DAD8FC8A0 = 0x00000000 ) = 0x00000000
0x00001CD4 48625 3  XPCOM C: ( (dsIProgressTaskData*)000001BD2B318780 )->SubActivity( 0000000DAD8FC8A0 )
0x00001CD4 48625 3  XPCOM R: ( (dsIProgressTaskData*)000001BD2B318780 )->SubActivity( *0000000DAD8FC8A0 = Initializing: CS_DAP_0 ) = 0x00000000
0x00001CD4 48625 3  XPCOM R: ( (dsIObjectEventCallback*)000001BD3541E5C0 )->onEvent( 000001BD2B318780 ) = 0x00000000
0x00001CD4 48625 3 CS_DAP_0 POLL C: Polling with state CPU_ST_INITIALIZE and status EVENT_DSP_HALT
0x00001CD4 48625 3 CS_DAP_0 GTI C: GTI_GETCAPABILITIES( 0x0000000000000000 )
0x00001CD4 48625 3 CS_DAP_0 GTI R: GTI_GETCAPABILITIES( 0x0000000000000000 ) = 0x41030010
0x00001CD4 48625 3 CS_DAP_0 GTI C: GTI_SET_PROGRESS_CALLBACK( 0x0000000000000000, *0x000001BD3D1FCFC0 = ??? )
0x00001CD4 48625 3 CS_DAP_0 GTI R: GTI_SET_PROGRESS_CALLBACK( 0x0000000000000000, *0x000001BD3D1FCFC0 = ??? ) = 0x00000000
0x00001CD4 48625 3  PERF I: GTI_INIT starting...
0x00001CD4 48625 3 CS_DAP_0 GTI C: GTI_INIT_EX( 0x0001, "Texas Instruments XDS110 USB Debug Probe_CS_DAP_0/CS_DAP_0", 0x00000240, "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat", 0x00000640, 0x0000D000, 0x0000000C, *0x0000000DAD8FDD50 = { 0x0000000B, 0x00000080, 0x0000000000000000, 0x0000000000000000, "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat", 0x000001BD3D0BAF60, 0x000001BD35082568, "CC2642R1F", 0x0000000000000000, 0x000001BD36E0F690, 0x000001BD29E1BC18, 0x000001BD2B9B9400, "" }, *0x000001BD36174A98 = 0x0000000000000000 )
0x00001CD4 48625 3  PRSC C: prsc_LoadBoardData: brdDataFile=C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat
0x00001CD4 48641 3  PRSC R: prsc_LoadBoardData: Loaded brdDataFile=C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat, pBrdData=0x1bd3d1fdde0, brdDataId=0
0x00001CD4 48641 3  PRSC C: prsc_GetBoardData: brdDataId=0
0x00001CD4 48641 3  PRSC R: prsc_GetBoardData: brdDataId=0, pBrdData=0x1bd3d1fdde0
0x00001CD4 48641 3  PRSC C: PRSC_ConInit: cpuName=Texas Instruments XDS110 USB Debug Probe_CS_DAP_0/CS_DAP_0, boardfileName=C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat, pParentPRSC=0x1bd3d0baf60
0x00001CD4 48641 3  PRSC C: GRTR:RtrInit: boardId=0x0, routerId=0x9, parentHandle=0x1bd3d0baf60, revision=0x0
0x00001CD4 48641 3  PRSC I: GRTR:RtrInit_M: Mem allocated for gRtrHandles=0x1bd2b839760
0x00001CD4 48641 3  PRSC I: GRTR:RtrInit: Mem allocated for rtrHandle=0x1bd2b9beca0
0x00001CD4 48641 3 IcePick_C TA C: GetRegisterId( IP_CNTL, 000001BD2B9BECB8 )
0x00001CD4 48641 3 IcePick_C TA C: GetRegisterId( IP_CNTL, 0x0000000000000000 )
0x00001CD4 48641 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='IP_CNTL' AND Register_Cache.Processor=33
0x00001CD4 48641 3 IcePick_C TA R: GetRegisterId( IP_CNTL, 0x0000000000000012 ) = 0
0x00001CD4 48641 3 IcePick_C TA R: GetRegisterId( IP_CNTL, *000001BD2B9BECB8 = 0x00000012 ) = 0
0x00001CD4 48641 3  PRSC R: GRTR:RtrInit: *pRouterHandle=0x1bd2b9beca0,revision=0x0, parentHandle=0x1bd3d0baf60, prscRtn=0x0
0x00001CD4 48641 3  PRSC C: GRTR:SubInit: routerHandle=0x1bd2b9beca0boardId=0x0, subPathId=0xf, subAddress=0x10, subPathType=0x0, subPathPseudo=0x0, subPathForce=0x1
0x00001CD4 48641 3 IcePick_C TA C: GetRegisterId( IP_TAP_CNTL_0, 0000000DAD8FD784 )
0x00001CD4 48641 3 IcePick_C TA C: GetRegisterId( IP_TAP_CNTL_0, 0x0000000000000000 )
0x00001CD4 48641 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='IP_TAP_CNTL_0' AND Register_Cache.Processor=33
0x00001CD4 48641 3 IcePick_C TA R: GetRegisterId( IP_TAP_CNTL_0, 0x0000000000000002 ) = 0
0x00001CD4 48641 3 IcePick_C TA R: GetRegisterId( IP_TAP_CNTL_0, *0000000DAD8FD784 = 0x00000002 ) = 0
0x00001CD4 48641 3  PRSC I: GRTR:SUBInit: Mem allocated for gSubHandle=0x1bd2b83f7c0
0x00001CD4 48641 3  PRSC I: GRTR:SUBInit: Mem allocated for subHandle=0x1bd3d1fe4e0
0x00001CD4 48641 3  PRSC R: GRTR:SUBInit: subHandle.index=0x2, .force =0x1, rtn =0x0
0x00001CD4 48641 3 IcePick_C TA C: GetParent()
0x00001CD4 48641 3 IcePick_C TA R: GetParent() = 0000000000000000
0x00001CD4 48641 3  PRSC C: prsc_GetPRSCCapabilities: prscHandle =0x1bd29e1b120
0x00001CD4 48641 3  PRSC R: prsc_GetPRSCCapabilities_R: ret = 0x0, cap =0x0
0x00001CD4 48641 3  PRSC I: Data Structure logging for device Texas Instruments XDS110 USB Debug Probe_CS_DAP_0/CS_DAP_0 and handle 0x1bd29e1b120
0x00001CD4 48641 3  PRSC I: Number of devices is 0x1
0x00001CD4 48641 3  PRSC I: Dev Caps are 0x0
0x00001CD4 48641 3  PRSC I: Logging for Device number 0x0
0x00001CD4 48641 3  PRSC I: device ID is 0xb
0x00001CD4 48641 3  PRSC I: deviceIsRouter is 0x1
0x00001CD4 48641 3  PRSC I: deviceRouterType is 0x3
0x00001CD4 48641 3  PRSC I: routerOfDeviceFeature is 0x0, 0x0
0x00001CD4 48641 3  PRSC I: subPathInfo is 0xf
0x00001CD4 48641 3  PRSC I: subAddress is 0x10
0x00001CD4 48641 3  PRSC I: subType is 0x0
0x00001CD4 48641 3  PRSC I: subPseudo is 0x0
0x00001CD4 48641 3  PRSC I: SubForce is 0x1
0x00001CD4 48641 3  PRSC I: Subpath handle is 0x1bd3d1fe4e0
0x00001CD4 48641 3  PRSC I: subPathIdValid is 0x1
0x00001CD4 48641 3  PRSC I: routerId is 0x9
0x00001CD4 48641 3  PRSC I: routerType is 0x2
0x00001CD4 48641 3  PRSC I: routerFeatureType is 0x1, 0x1
0x00001CD4 48641 3  PRSC I: pRouterFuncHandle is 0x1bd2b9beca0
0x00001CD4 48641 3  PRSC R: PRSC_ConInit: pPRSCHandle=0x1bd29e1b120
0x00001CD4 48641 3  PRSC C: PRSC_GetPRSCCapabilities: prscHandle =0x1bd29e1b120
0x00001CD4 48641 3  PRSC R: prsc_GetPRSCCapabilities: ret = 0x0, cap =0x0
0x00001CD4 48641 3 CS_DAP_0 GTI R: GTI_INIT_EX( 0x0001, "Texas Instruments XDS110 USB Debug Probe_CS_DAP_0/CS_DAP_0", 0x00000240, "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat", 0x00000640, 0x0000D000, 0x0000000C, *0x0000000DAD8FDD50 = { 0x0000000B, 0x00000080, 0x0000000000000000, 0x0000000000000000, "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat", 0x000001BD3D0BAF60, 0x000001BD35082568, "CC2642R1F", 0x0000000000000000, 0x000001BD36E0F690, 0x000001BD29E1BC18, 0x000001BD2B9B9400, "" }, *0x000001BD36174A98 = 0x000001BD29E1AA40 ) = 0x00000000
0x00001CD4 48641 3  PERF I: GTI_INIT finished:  0.006636s wall, 0.015625s user + 0.000000s system = 0.015625s CPU (235.4%)
0x00001CD4 48641 3 CS_DAP_0 GTI C: GTI_GETCAPABILITIES( 0x000001BD29E1AA40 )
0x00001CD4 48641 3 CS_DAP_0 GTI R: GTI_GETCAPABILITIES( 0x000001BD29E1AA40 ) = 0x41030010
0x00001CD4 48641 3 CS_DAP_0 GTI C: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E1AA40, 0 )
0x00001CD4 48641 3 CS_DAP_0 GTI R: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E1AA40, 0 ) = 0x41030010
0x00001CD4 48641 3 CS_DAP_0 GTI C: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E1AA40, 2 )
0x00001CD4 48641 3 CS_DAP_0 GTI R: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E1AA40, 2 ) = 0x00000001
0x00001CD4 48641 3 CS_DAP_0 GTI C: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E1AA40, 1 )
0x00001CD4 48641 3 CS_DAP_0 GTI R: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E1AA40, 1 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 GTI C: GTI_SET_PROGRESS_CALLBACK( 0x000001BD29E1AA40, *0x000001BD3D1FCFC0 = ??? )
0x00001CD4 48641 3 CS_DAP_0 GTI R: GTI_SET_PROGRESS_CALLBACK( 0x000001BD29E1AA40, *0x000001BD3D1FCFC0 = ??? ) = 0x00000000
0x00001CD4 48641 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\DebugServer\bin\..\..\emulation\tpi\tpi_cs_dap.dll", 0 )
0x00001CD4 48641 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\DebugServer\bin\..\..\emulation\tpi\tpi_cs_dap.dll", 0 ) = 000001BD39270000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "TpiGenAPI" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "TpiGenAPI" ) = 000001BD39272400
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "TpiRegWinAPI" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "TpiRegWinAPI" ) = 000001BD39273230
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "TpiStackAPI" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "TpiStackAPI" ) = 000001BD392736C0
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "TpiStepAPI" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "TpiStepAPI" ) = 000001BD39273940
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "TpiDisasmAPI" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "TpiDisasmAPI" ) = 000001BD39271A70
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "TpiPatchAsmAPI" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "TpiPatchAsmAPI" ) = 000001BD39272CA0
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "TpiProfileAPI" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "TpiProfileAPI" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "_TpiProfileAPI" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "_TpiProfileAPI" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "TpiDataWinAPI" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "TpiDataWinAPI" ) = 000001BD392717E0
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "TpiGenAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "TpiGenAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "_TpiGenAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "_TpiGenAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "TpiStepAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "TpiStepAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "_TpiStepAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "_TpiStepAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "TpiDisasmAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "TpiDisasmAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "_TpiDisasmAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "_TpiDisasmAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "TpiPatchAsmAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "TpiPatchAsmAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "_TpiPatchAsmAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "_TpiPatchAsmAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "TpiProfileAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "TpiProfileAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "_TpiProfileAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "_TpiProfileAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "TpiDataWinAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "TpiDataWinAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD39270000, "_TpiDataWinAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD39270000, "_TpiDataWinAPI64" ) = 0000000000000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_GET_REVISION, *0000000DAD8FDD20 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_GET_REVISION, *0000000DAD8FDD20 = 0x00000065 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_CONSTRUCTOR, 0x0000000D38000405, 0x0000000000000000, 0x000001BD36175A80 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_CONSTRUCTOR, 0x0000000D38000405, 0x0000000000000000, 0x000001BD36175A80 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SET_DS_VERSION, 0x0000000D0000000C, 0x0000000000000000, 0x000001BD00000000 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SET_DS_VERSION, 0x0000000D0000000C, 0x0000000000000000, 0x000001BD00000000 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_NUM_PAGES, *0000000DAD8FDCD0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_NUM_PAGES, *0000000DAD8FDCD0 = 0x00000015 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000000 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000000 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000000, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000000, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000000, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000000, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000000, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000000, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000000, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000000, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000001 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000001, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000001, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000001, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000001, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000001, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000001, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000001, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000001, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000002 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000002, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000002, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000002, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000002, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000002, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000002, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000002, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000002, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000003 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000003 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000003, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000003, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000003, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000003, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000003, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000003, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000003, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000003, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000004 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000004 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000004, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000004, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000004, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000004, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000004, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000004, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000004, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000004, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000005 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000005 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000005, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000005, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000005, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000005, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000005, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000005, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000005, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000005, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000006 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000006 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000006, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000006, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000006, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000006, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000006, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000006, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000006, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000006, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000007 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000007 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000007, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000007, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000007, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000007, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000007, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000007, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000007, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000007, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000008 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000008 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000008, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000008, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000008, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000008, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000008, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000008, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000008, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000008, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000009 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000009 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000009, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000009, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000009, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000009, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000009, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000009, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000009, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000009, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000A )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000A ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000A, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000A, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000A, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000A, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000A, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000A, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000A, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000A, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000B )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000B ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000B, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000B, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000B, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000B, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000B, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000B, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000B, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000B, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000C ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000C, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000C, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000C, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000C, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000C, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000C, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000C, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000C, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000D )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000D ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000D, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000D, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000D, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000D, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000D, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000D, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000D, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000D, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000E )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000E ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000E, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000E, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000E, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000E, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000E, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000E, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000E, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000E, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000F )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000F ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000F, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000F, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000F, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000F, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000F, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000F, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000F, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000F, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000010 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000010 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000010, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000010, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000010, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000010, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000010, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000010, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000010, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000010, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000011 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000011 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000011, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000011, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000011, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000011, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000011, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000011, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000011, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000011, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000012 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000012 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000012, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000012, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000012, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000012, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000012, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000012, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000012, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000012, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000013 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000013 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000013, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000013, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000013, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000013, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000013, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000013, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000013, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000013, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000014 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000014 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000014, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000014, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000014, *0000000DAD8FDB98 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000014, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000014, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000014, *0000000DAD8FDBA0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000014, *0000000DAD8FDB9C )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000014, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_PAGE, *000001BD2B3189A8 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_DEFAULT_PAGE, *000001BD2B3189A8 = 0x00000000 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_REG_PAGES, *0000000DAD8FDCD8, *0000000DAD8FDCD0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_REG_PAGES, *0000000DAD8FDCD8 = 0x00000001, *0000000DAD8FDCD0 = 0x00000079 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_REGBUS_BITS, 0x0000000DAD8FDB50, 0x0000000000000079 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_REGBUS_BITS, 0x0000000DAD8FDB50, 0x0000000000000079 ) = 0x00000000
0x00001CD4 48641 3  SETUP I: SELECT count(*) FROM Module_Instances WHERE Hidden = 0 AND parent_dbid=34 AND parent_type="Processors"
0x00001CD4 48641 3  SETUP I: SELECT COUNT(*) FROM Register_Pages WHERE Processor=34
0x00001CD4 48641 3 CS_DAP_0 GTI C: GTI_GET_NUM_RESETS( 0x000001BD29E1AA40 )
0x00001CD4 48641 3  PRSC C: PRSC_QueryResetCapabilities: prscHandle=0x1bd29e1b120
0x00001CD4 48641 3  PRSC R: PRSC_QueryResetCapabilities: resetType =0x0
0x00001CD4 48641 3 CS_DAP_0 GTI R: GTI_GET_NUM_RESETS( 0x000001BD29E1AA40 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class MemMapChangeBroadcaster
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SET_CALLBACK, 0x000001BD3D1FE620, 0x00007FFEC49C30E0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_SET_CALLBACK, 0x000001BD3D1FE620, 0x00007FFEC49C30E0 ) = 0x00000002
0x00001CD4 48641 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='CLK' AND Register_Cache.Processor=34
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDAC8 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDAC8 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDAC0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDAC0 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDA68 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDA68 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDA60 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDA60 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDA58 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDA58 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDA50 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDA50 ) = 0x00000002
0x00001CD4 48641 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='FP' AND Register_Cache.Processor=34
0x00001CD4 48641 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775808 AND Register_Cache.Address<=-9223372036854775808 AND Register_Cache.Page=0 AND Register_Cache.Processor=34
0x00001CD4 48641 3  SETUP I: SELECT MAX( Register_Cache.Address ) FROM Register_Cache, Registers, Module_Instances WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address<-9223372036854775808 AND Register_Cache.Page=0 AND Register_Cache.Processor=34 AND Module_Instances.dbid=Register_Cache.Module AND Module_Instances.Hidden=0
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD6A8 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD6A8 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD6A0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD6A0 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 GEL I: Evaluating "0"
0x00001CD4 48641 3 CS_DAP_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 48641 3 CS_DAP_0 GEL I: Evaluating "5"
0x00001CD4 48641 3 CS_DAP_0 GEL I: Evaluating "1"
0x00001CD4 48641 3 CS_DAP_0 GEL I: Evaluating "80"
0x00001CD4 48641 4 CS_DAP_0 POLL I: Yielding to other threads
0x00001CD4 48641 3 CS_DAP_0 POLL R: Poll() returning
0x00001CD4 48641 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class `anonymous namespace'::SystemInitializerPollFrequencyManager
0x00001CD4 48641 4  POLL I: Yielding to other threads
0x00001CD4 48641 3  COM_DBG_IF C: class CoProgressTask::OnUpdate()
0x00001CD4 48641 3  XPCOM C: ( (dsIObjectEventCallback*)000001BD3541E5C0 )->onEvent( 000001BD2B312000 )
0x00001CD4 48641 3  XPCOM C: ( (nsISupports*)000001BD2B312008 )->queryInterface( 000001BD3D200720, 0000000DAD8FC8D8 )
0x00001CD4 48641 3  XPCOM R: ( (nsISupports*)000001BD2B312008 )->queryInterface( 000001BD3D200720, *0000000DAD8FC8D8 = 000001BD2B312000 ) = 0x00000000
0x00001CD4 48641 3  XPCOM C: ( (dsIProgressTaskData*)000001BD2B312000 )->PercentDone( 0000000DAD8FC930 )
0x00001CD4 48641 3  XPCOM R: ( (dsIProgressTaskData*)000001BD2B312000 )->PercentDone( *0000000DAD8FC930 = 0x00000000 ) = 0x00000000
0x00001CD4 48641 3  XPCOM C: ( (dsIProgressTaskData*)000001BD2B312000 )->SubActivity( 0000000DAD8FC930 )
0x00001CD4 48641 3  XPCOM R: ( (dsIProgressTaskData*)000001BD2B312000 )->SubActivity( *0000000DAD8FC930 = Executing Startup Scripts: CS_DAP_0 ) = 0x00000000
0x00001CD4 48641 3  XPCOM R: ( (dsIObjectEventCallback*)000001BD3541E5C0 )->onEvent( 000001BD2B312000 ) = 0x00000000
0x00001CD4 48641 3  COM_DBG_IF R: class CoProgressTask::OnUpdate()
0x00001CD4 48641 3  SEQUENCE I: Finished sequence step at 0000000DAD8FE2A8
0x00001CD4 48641 3  SEQUENCE I: Beginning class `anonymous namespace'::LoadStartupGelStep at 000001BD35504CB0
0x00001CD4 48641 3  PERF I: GEL OnStartUp() starting...
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD2A8 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD2A8 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD2A0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD2A0 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 GEL I: Evaluating "-(1)"
0x00001CD4 48641 3 CS_DAP_0 POLL C: Firing DSP_GEL_FILE_LIST_CHANGED to all DSP_USER's
0x00001CD4 48641 3 CS_DAP_0 POLL C: Firing of DSP_GEL_FILE_LIST_CHANGED complete
0x00001CD4 48641 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='SP' AND Register_Cache.Processor=34
0x00001CD4 48641 3 CS_DAP_0 POLL C: Firing DSP_NEW_SYMBOLS to all DSP_USER's
0x00001CD4 48641 3 CS_DAP_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class DebuggerListeners
0x00001CD4 48641 3 CS_DAP_0 POLL C: Firing of DSP_NEW_SYMBOLS complete
0x00001CD4 48641 3  PERF I: GEL OnStartUp() finished:  0.000609s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 48641 3  SEQUENCE I: Finished sequence step at 000001BD35504CB0
0x00001CD4 48641 3  SEQUENCE I: Beginning class Debugger::LambdaSequenceStep<class <lambda_bcb20481c62572668180f439a17adeae> > at 000001BD3D200AC0
0x00001CD4 48641 3  SEQUENCE I: Finished sequence step at 000001BD3D200AC0
0x00001CD4 48641 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::SystemInitializerPollFrequencyManager
0x00001CD4 48641 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 484 ms
0x00001CD4 48641 4  POLL I: TimeToSleep() found shorter sleep time of 484 ms from class DevicePollFrequencyManager
0x00001CD4 48641 4 CS_DAP_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 48641 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 48641 3 CS_DAP_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 48641 3 CS_DAP_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 48641 3 CS_DAP_0 POLL C: Firing DSP_REQ_EVENT to class MemMapChangeBroadcaster
0x00001CD4 48641 3 CS_DAP_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 48641 3 CS_DAP_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD518 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD518 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD510 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD510 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 GEL I: Evaluation of "0" completed - Value: 0 Location: unknown
0x00001CD4 48641 3 CS_DAP_0 GEL I: Evaluation of "5" completed - Value: 5 Location: unknown
0x00001CD4 48641 3 CS_DAP_0 GEL I: Evaluation of "1" completed - Value: 1 Location: unknown
0x00001CD4 48641 3 CS_DAP_0 GEL I: Evaluation of "80" completed - Value: 80 Location: unknown
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD478 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD478 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD470 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD470 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD1B8 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD1B8 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD1B0 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD1B0 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD288 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD288 ) = 0x00000000
0x00001CD4 48641 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD280 )
0x00001CD4 48641 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD280 ) = 0x00000002
0x00001CD4 48641 3 CS_DAP_0 GEL I: Evaluation of "-(1)" completed - Value: -1 Location: unknown
0x00001CD4 48641 3 CS_DAP_0 POLL C: Firing DSP_REQ_EVENT to class DebuggerListeners
0x00001CD4 48641 3 CS_DAP_0 POLL C: Firing DSP_MEM_MAP_UPDATED to all DSP_USER's
0x00001CD4 48641 3 CS_DAP_0 POLL C: Firing of DSP_MEM_MAP_UPDATED complete
0x00001CD4 48641 3  XPCOM C: ( (dsIObjectEventCallback*)000001BD3541E5C0 )->onEvent( 000001BD2B312060 )
0x00001CD4 48641 3  XPCOM C: ( (nsISupports*)000001BD2B312068 )->queryInterface( 000001BD3D1FE8C0, 0000000DAD8FC848 )
0x00001CD4 48641 3  XPCOM R: ( (nsISupports*)000001BD2B312068 )->queryInterface( 000001BD3D1FE8C0, *0000000DAD8FC848 = 000001BD2B312060 ) = 0x00000000
0x00001CD4 48641 3  XPCOM C: ( (dsIProgressTaskData*)000001BD2B312060 )->PercentDone( 0000000DAD8FC8A0 )
0x00001CD4 48641 3  XPCOM R: ( (dsIProgressTaskData*)000001BD2B312060 )->PercentDone( *0000000DAD8FC8A0 = 0x00000000 ) = 0x00000000
0x00001CD4 48641 3  XPCOM C: ( (dsIProgressTaskData*)000001BD2B312060 )->SubActivity( 0000000DAD8FC8A0 )
0x00001CD4 48641 3  XPCOM R: ( (dsIProgressTaskData*)000001BD2B312060 )->SubActivity( *0000000DAD8FC8A0 = Initializing: Cortex_M4_0 ) = 0x00000000
0x00001CD4 48641 3  XPCOM R: ( (dsIObjectEventCallback*)000001BD3541E5C0 )->onEvent( 000001BD2B312060 ) = 0x00000000
0x00001CD4 48641 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_INITIALIZE and status EVENT_DSP_HALT
0x00001CD4 48641 3 Cortex_M4_0 GTI C: GTI_GETCAPABILITIES( 0x0000000000000000 )
0x00001CD4 48641 3 Cortex_M4_0 GTI R: GTI_GETCAPABILITIES( 0x0000000000000000 ) = 0x11DA041B
0x00001CD4 48641 3 Cortex_M4_0 GTI C: GTI_SET_PROGRESS_CALLBACK( 0x0000000000000000, *0x000001BD3D1FD680 = ??? )
0x00001CD4 48641 3 Cortex_M4_0 GTI R: GTI_SET_PROGRESS_CALLBACK( 0x0000000000000000, *0x000001BD3D1FD680 = ??? ) = 0x00000000
0x00001CD4 48641 3  PERF I: GTI_INIT starting...
0x00001CD4 48641 3 Cortex_M4_0 GTI C: GTI_INIT_EX( 0x0002, "Texas Instruments XDS110 USB Debug Probe_Cortex_M4_0/Cortex_M4_0", 0x00000240, "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat", 0x00000640, 0x0000D000, 0x0000000C, *0x0000000DAD8FDD50 = { 0x0000000B, 0x00000080, 0x0000000000000000, 0x0000000000000000, "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat", 0x000001BD3E2F4420, 0x000001BD35082898, "CC2642R1F", 0x0000000000000000, 0x000001BD36C310F0, 0x000001BD29E1C2F8, 0x000001BD2B9BC130, "" }, *0x000001BD3D1D88F8 = 0x0000000000000000 )
0x00001CD4 48641 3  PRSC C: prsc_LoadBoardData: brdDataFile=C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat
0x00001CD4 48641 3  PRSC C: PRSC_ConInit: cpuName=Texas Instruments XDS110 USB Debug Probe_Cortex_M4_0/Cortex_M4_0, boardfileName=C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat, pParentPRSC=0x1bd3e2f4420
0x00001CD4 48641 3 CS_DAP_0 TA C: GetParent()
0x00001CD4 48641 3 CS_DAP_0 TA R: GetParent() = 000001BD3D0BAF60
0x00001CD4 48641 3  PRSC C: GRTR:SubInit: routerHandle=0x1bd2b9beca0boardId=0x0, subPathId=0x10, subAddress=0x0, subPathType=0x1, subPathPseudo=0x0, subPathForce=0x1
0x00001CD4 48641 3 IcePick_C TA C: GetRegisterId( IP_TAP_CNTL_0, 0000000DAD8FD864 )
0x00001CD4 48641 3 IcePick_C TA R: GetRegisterId( IP_TAP_CNTL_0, *0000000DAD8FD864 = 0x00000002 ) = 0
0x00001CD4 48641 3  PRSC I: GRTR:SUBInit: Mem allocated for subHandle=0x1bd3d1fdea0
0x00001CD4 48641 3  PRSC C: prsc_GetPRSCCapabilities: prscHandle =0x1bd29e1cbb0
0x00001CD4 48641 3  PRSC C: prsc_SendRouter: connectionNeeded=0x0
0x00001CD4 48641 3  PRSC C: GRTR:GetCAP: routerHandle =0x1bd2b9beca0subPathHandle=0x1bd3d1fdea0
0x00001CD4 48641 3 IcePick_C TA C: IsConnected()
0x00001CD4 48641 3 IcePick_C TA R: IsConnected() = false
0x00001CD4 48641 3  PRSC R: GRTR:GetCap:  pCap =0x55d0
0x00001CD4 48641 3  PRSC C: prsc_SendRouter: error =0x0
0x00001CD4 48641 3  PRSC R: prsc_GetPRSCCapabilities_R: ret = 0x0, cap =0x55d0
0x00001CD4 48641 3  PRSC I: Data Structure logging for device Texas Instruments XDS110 USB Debug Probe_Cortex_M4_0/Cortex_M4_0 and handle 0x1bd29e1cbb0
0x00001CD4 48641 3  PRSC I: Number of devices is 0x2
0x00001CD4 48641 3  PRSC I: Dev Caps are 0x55d0
0x00001CD4 48641 3  PRSC I: device ID is 0xc
0x00001CD4 48641 3  PRSC I: deviceIsRouter is 0x0
0x00001CD4 48641 3  PRSC I: deviceRouterType is 0x5
0x00001CD4 48641 3  PRSC I: routerOfDeviceFeature is 0x2, 0x2
0x00001CD4 48641 3  PRSC I: subPathInfo is 0x10
0x00001CD4 48641 3  PRSC I: subAddress is 0x0
0x00001CD4 48641 3  PRSC I: subType is 0x1
0x00001CD4 48641 3  PRSC I: Subpath handle is 0x1bd3d1fdea0
0x00001CD4 48641 3  PRSC I: routerId is 0xb
0x00001CD4 48641 3  PRSC I: routerType is 0x3
0x00001CD4 48641 3  PRSC I: routerFeatureType is 0x0, 0x0
0x00001CD4 48641 3  PRSC I: pRouterFuncHandle is 0x0
0x00001CD4 48641 3  PRSC I: Logging for Device number 0x1
0x00001CD4 48641 3  PRSC R: PRSC_ConInit: pPRSCHandle=0x1bd29e1cbb0
0x00001CD4 48641 3  PRSC C: PRSC_GetPRSCCapabilities: prscHandle =0x1bd29e1cbb0
0x00001CD4 48641 3  PRSC R: prsc_GetPRSCCapabilities: ret = 0x0, cap =0x55d0
0x00001CD4 48641 3 Cortex_M4_0 GTI R: GTI_INIT_EX( 0x0002, "Texas Instruments XDS110 USB Debug Probe_Cortex_M4_0/Cortex_M4_0", 0x00000240, "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat", 0x00000640, 0x0000D000, 0x0000000C, *0x0000000DAD8FDD50 = { 0x0000000B, 0x00000080, 0x0000000000000000, 0x0000000000000000, "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\BrdDat\ccBoard0.dat", 0x000001BD3E2F4420, 0x000001BD35082898, "CC2642R1F", 0x0000000000000000, 0x000001BD36C310F0, 0x000001BD29E1C2F8, 0x000001BD2B9BC130, "" }, *0x000001BD3D1D88F8 = 0x000001BD362E2770 ) = 0x00000000
0x00001CD4 48641 3  PERF I: GTI_INIT finished:  0.003816s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 48641 3 Cortex_M4_0 GTI C: GTI_GETCAPABILITIES( 0x000001BD362E2770 )
0x00001CD4 48641 3 Cortex_M4_0 GTI R: GTI_GETCAPABILITIES( 0x000001BD362E2770 ) = 0x11DA041B
0x00001CD4 48641 3 Cortex_M4_0 GTI C: GTI_GET_EXT_CAPABILITIES( 0x000001BD362E2770, 0 )
0x00001CD4 48641 3 Cortex_M4_0 GTI R: GTI_GET_EXT_CAPABILITIES( 0x000001BD362E2770, 0 ) = 0x11DA041B
0x00001CD4 48641 3 Cortex_M4_0 GTI C: GTI_GET_EXT_CAPABILITIES( 0x000001BD362E2770, 2 )
0x00001CD4 48641 3 Cortex_M4_0 GTI R: GTI_GET_EXT_CAPABILITIES( 0x000001BD362E2770, 2 ) = 0x00000017
0x00001CD4 48641 3 Cortex_M4_0 GTI C: GTI_GET_EXT_CAPABILITIES( 0x000001BD362E2770, 1 )
0x00001CD4 48641 3 Cortex_M4_0 GTI R: GTI_GET_EXT_CAPABILITIES( 0x000001BD362E2770, 1 ) = 0x00000000
0x00001CD4 48641 3 Cortex_M4_0 GTI C: GTI_SET_PROGRESS_CALLBACK( 0x000001BD362E2770, *0x000001BD3D1FD680 = ??? )
0x00001CD4 48641 3 Cortex_M4_0 GTI R: GTI_SET_PROGRESS_CALLBACK( 0x000001BD362E2770, *0x000001BD3D1FD680 = ??? ) = 0x00000000
0x00001CD4 48641 3 Cortex_M4_0 GTI C: GTI_GET_NON_INTRUSIVE_CAPABILITIES( 0x000001BD362E2770 )
0x00001CD4 48641 3 Cortex_M4_0 GTI R: GTI_GET_NON_INTRUSIVE_CAPABILITIES( 0x000001BD362E2770 ) = 0x0000003F
0x00001CD4 48641 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\DebugServer\bin\..\..\emulation\tpi\tpiarm_x.dll", 0 )
0x00001CD4 48641 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\DebugServer\bin\..\..\emulation\tpi\tpiarm_x.dll", 0 ) = 000001BD392A0000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "TpiGenAPI" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "TpiGenAPI" ) = 000001BD392A4650
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "TpiRegWinAPI" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "TpiRegWinAPI" ) = 000001BD392A5330
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "TpiStackAPI" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "TpiStackAPI" ) = 000001BD392A57F0
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "TpiStepAPI" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "TpiStepAPI" ) = 000001BD392A6C40
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "TpiDisasmAPI" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "TpiDisasmAPI" ) = 000001BD392A3600
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "TpiPatchAsmAPI" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "TpiPatchAsmAPI" ) = 000001BD392A4D90
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "TpiProfileAPI" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "TpiProfileAPI" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "_TpiProfileAPI" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "_TpiProfileAPI" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "TpiDataWinAPI" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "TpiDataWinAPI" ) = 000001BD392A2080
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "TpiGenAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "TpiGenAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "_TpiGenAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "_TpiGenAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "TpiStepAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "TpiStepAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "_TpiStepAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "_TpiStepAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "TpiDisasmAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "TpiDisasmAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "_TpiDisasmAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "_TpiDisasmAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "TpiPatchAsmAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "TpiPatchAsmAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "_TpiPatchAsmAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "_TpiPatchAsmAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "TpiProfileAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "TpiProfileAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "_TpiProfileAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "_TpiProfileAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "TpiDataWinAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "TpiDataWinAPI64" ) = 0000000000000000
0x00001CD4 48641 3  LIB C: dlsym( 000001BD392A0000, "_TpiDataWinAPI64" )
0x00001CD4 48641 3  LIB R: dlsym( 000001BD392A0000, "_TpiDataWinAPI64" ) = 0000000000000000
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_GET_REVISION, *0000000DAD8FDD20 )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_GET_REVISION, *0000000DAD8FDD20 = 0x00000065 ) = 0x00000000
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_CONSTRUCTOR, 0x0000000D75803800, 0x0000000000000000, 0x000001BD3D1D98E0 )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_CONSTRUCTOR, 0x0000000D75803800, 0x0000000000000000, 0x000001BD3D1D98E0 ) = 0x00000000
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_SET_DS_VERSION, 0x0000000D0000000C, 0x0000000000000000, 0x000001BD00000000 )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_SET_DS_VERSION, 0x0000000D0000000C, 0x0000000000000000, 0x000001BD00000000 ) = 0x00000002
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_NUM_PAGES, *0000000DAD8FDCD0 )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_NUM_PAGES, *0000000DAD8FDCD0 = 0x00000001 ) = 0x00000000
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000000 )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000000 ) = 0x00000000
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000000, 0x0000000DAD8FDB58 )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000000, 0x0000000DAD8FDB58 ) = 0x00000000
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000000, *0000000DAD8FDB98 )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000000, *0000000DAD8FDB98 = 0x00000002 ) = 0x00000000
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000000, *0000000DAD8FDBA0 )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000000, *0000000DAD8FDBA0 = 0xAD8FDC00 ) = 0x00000002
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000000, *0000000DAD8FDB9C )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000000, *0000000DAD8FDB9C = 0x00000004 ) = 0x00000002
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_DEFAULT_PAGE, *000001BD2B312168 )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_DEFAULT_PAGE, *000001BD2B312168 = 0x00000000 ) = 0x00000002
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_REG_PAGES, *0000000DAD8FDCD8, *0000000DAD8FDCD0 )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_REG_PAGES, *0000000DAD8FDCD8 = 0x00000001, *0000000DAD8FDCD0 = 0x00000079 ) = 0x00000002
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_REGBUS_BITS, 0x0000000DAD8FDB50, 0x0000000000000079 )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_REGBUS_BITS, 0x0000000DAD8FDB50, 0x0000000000000079 ) = 0x00000000
0x00001CD4 48641 3  SETUP I: SELECT count(*) FROM Module_Instances WHERE Hidden = 0 AND parent_dbid=35 AND parent_type="Processors"
0x00001CD4 48641 3  SETUP I: SELECT COUNT(*) FROM Register_Pages WHERE Processor=35
0x00001CD4 48641 3 Cortex_M4_0 GTI C: GTI_GET_NUM_RESETS( 0x000001BD362E2770 )
0x00001CD4 48641 3  PRSC C: PRSC_QueryResetCapabilities: prscHandle=0x1bd29e1cbb0
0x00001CD4 48641 3  PRSC C: GRTR:QueryResetGlobal: routerHandle=0x1bd2b9beca0
0x00001CD4 48641 3 IcePick_C TA C: GetNumResets()
0x00001CD4 48641 3 IcePick_C TA R: GetNumResets() = 2
0x00001CD4 48641 3  PRSC R: GRTR:QueryResetCapGlobal rstCAP=0x1
0x00001CD4 48641 3  PRSC C: GRTR:QueryResetLoc: routerHandle=0x1bd2b9beca0
0x00001CD4 48641 3  PRSC R: GRTR:QueryResetCapLoc rstCAP=0x10
0x00001CD4 48641 3  PRSC R: PRSC_QueryResetCapabilities: resetType =0x11
0x00001CD4 48641 3 Cortex_M4_0 GTI R: GTI_GET_NUM_RESETS( 0x000001BD362E2770 ) = 0x00000004
0x00001CD4 48641 3 Cortex_M4_0 GTI C: GTI_GET_RESET_INFO( 0x000001BD362E2770, 0x00000000, *0x0000000DAD8FDB20 = ??? )
0x00001CD4 48641 3 Cortex_M4_0 GTI R: GTI_GET_RESET_INFO( 0x000001BD362E2770, 0x00000000, *0x0000000DAD8FDB20 = ??? ) = 0x00000000
0x00001CD4 48641 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD348 = 0x00000000, *0x0000000DAD8FD340 = 0x00000000, *0x0000000DAD8FD358 = 0x00000000, *0x0000000DAD8FD370 = 0x00000000, *0x0000000DAD8FD378 = 0x00000000, *0x0000000DAD8FD368 = 0x00000000, *0x0000000DAD8FD360 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 48641 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD348 = 0x00000000, *0x0000000DAD8FD340 = 0x00000000, *0x0000000DAD8FD358 = 0x00000000, *0x0000000DAD8FD370 = 0x00000002, *0x0000000DAD8FD378 = 0x00000000, *0x0000000DAD8FD368 = 0x00000008, *0x0000000DAD8FD360 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 48641 3 Cortex_M4_0 GTI C: GTI_GET_RESET_INFO( 0x000001BD362E2770, 0x00000001, *0x0000000DAD8FDB20 = ??? )
0x00001CD4 48641 3  PRSC C: PRSC_GetResetInfo: prscHandle=0x1bd29e1cbb0, resetType=0x1
0x00001CD4 48641 3  PRSC C: GRTR:GetResetInfoGlb: routerHandle=0x1bd2b9beca0
0x00001CD4 48641 3 IcePick_C TA C: QueryResetType( 0, 0000000DAD8FD5C0 )
0x00001CD4 48641 3 IcePick_C TA R: QueryResetType( 0, *0000000DAD8FD5C0 = 000001BD3D1FE400 ) = 0
0x00001CD4 48641 3  RA C: ResetAdapterImpl::GetName()
0x00001CD4 48641 3  RA R: ResetAdapterImpl::GetName() = GetReset().GetName().c_str()
0x00001CD4 48641 3  RA C: ResetAdapterImpl::GetToolTip()
0x00001CD4 48641 3  RA R: ResetAdapterImpl::GetToolTip() = GetReset().GetToolTip().c_str()
0x00001CD4 48641 3  PRSC R: GRTR:GetResetInfoGlb: pName=System Reset, pToolTip =ICEPick Generated System Warm Reset, pRequires=0x0, ret=0x0
0x00001CD4 48641 3  PRSC R: PRSC:GetResetInfo: ret=0x0, pName=System Reset, pToolTip =ICEPick Generated System Warm Reset, pRequires=0x0
0x00001CD4 48641 3 Cortex_M4_0 GTI R: GTI_GET_RESET_INFO( 0x000001BD362E2770, 0x00000001, *0x0000000DAD8FDB20 = ??? ) = 0x00000000
0x00001CD4 48641 3 Cortex_M4_0 GTI C: GTI_GET_RESET_INFO( 0x000001BD362E2770, 0x00000002, *0x0000000DAD8FDB20 = ??? )
0x00001CD4 48641 3 Cortex_M4_0 GTI R: GTI_GET_RESET_INFO( 0x000001BD362E2770, 0x00000002, *0x0000000DAD8FDB20 = ??? ) = 0x00000000
0x00001CD4 48641 3 Cortex_M4_0 GTI C: GTI_GET_RESET_INFO( 0x000001BD362E2770, 0x00000003, *0x0000000DAD8FDB20 = ??? )
0x00001CD4 48641 3 Cortex_M4_0 GTI R: GTI_GET_RESET_INFO( 0x000001BD362E2770, 0x00000003, *0x0000000DAD8FDB20 = ??? ) = 0x00000000
0x00001CD4 48641 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class MemMapChangeBroadcaster
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_SET_CALLBACK, 0x000001BD3D1FDFC0, 0x00007FFEC49C30E0 )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_SET_CALLBACK, 0x000001BD3D1FDFC0, 0x00007FFEC49C30E0 ) = 0x00000000
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_STATUS_REG, *0000000DAD8FDDF0 )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_STATUS_REG, *0000000DAD8FDDF0 = 0x392D2440 ) = 0x00000000
0x00001CD4 48641 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='REG_ENDIAN' AND Register_Cache.Processor=35
0x00001CD4 48641 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_READ_MEM added to polling loop by class `anonymous namespace'::TpiStatusRegistersImpl
0x00001CD4 48641 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='PC' AND Register_Cache.Processor=35
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD808 )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD808 ) = 0x00000000
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD800 )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD800 ) = 0x00000002
0x00001CD4 48641 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='FP' AND Register_Cache.Processor=35
0x00001CD4 48641 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='CLK' AND Register_Cache.Processor=35
0x00001CD4 48641 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775808 AND Register_Cache.Address<=-9223372036854775808 AND Register_Cache.Page=0 AND Register_Cache.Processor=35
0x00001CD4 48641 3  SETUP I: SELECT MAX( Register_Cache.Address ) FROM Register_Cache, Registers, Module_Instances WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address<-9223372036854775808 AND Register_Cache.Page=0 AND Register_Cache.Processor=35 AND Module_Instances.dbid=Register_Cache.Module AND Module_Instances.Hidden=0
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD028 )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD028 ) = 0x00000000
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD020 )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD020 ) = 0x00000002
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCE08 )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCE08 ) = 0x00000000
0x00001CD4 48641 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCE00 )
0x00001CD4 48641 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCE00 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD068 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD068 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD060 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD060 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCE48 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCE48 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCE40 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCE40 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDB18 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDB18 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDB10 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDB10 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDAC8 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDAC8 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDAC0 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDAC0 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDA68 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDA68 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDA60 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDA60 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDA58 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDA58 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDA50 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDA50 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD268 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD268 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD260 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD260 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD048 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD048 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD040 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD040 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCF38 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCF38 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCF30 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCF30 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCD18 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCD18 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCD10 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCD10 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCF78 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCF78 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCF70 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCF70 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCD58 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCD58 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCD50 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCD50 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD7B8 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD7B8 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD7B0 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD7B0 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluating "C$$IO$$"
0x00001CD4 48656 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluating "C$$IOE$$"
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCE18 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCE18 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCE10 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCE10 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCBF8 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCBF8 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCBF0 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCBF0 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCE58 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCE58 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCE50 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCE50 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCC38 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCC38 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCC30 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCC30 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD698 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD698 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD690 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD690 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluating "SVC_Handler"
0x00001CD4 48656 4 Cortex_M4_0 SEMIHOSTING I: Failed to enable/disable breakpoint: Symbols must be loaded to attempt to resolve "SVC_Handler" to an address
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD6A8 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD6A8 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD6A0 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD6A0 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluating "0"
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluating "5"
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluating "1"
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluating "80"
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCFB8 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCFB8 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCFB0 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCFB0 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCD98 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCD98 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCD90 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCD90 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD7F8 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD7F8 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD7F0 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD7F0 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluating "C$$EXIT"
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluating "C$$EXITE"
0x00001CD4 48656 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 48656 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 48656 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class `anonymous namespace'::SystemInitializerPollFrequencyManager
0x00001CD4 48656 4  POLL I: Yielding to other threads
0x00001CD4 48656 3  COM_DBG_IF C: class CoProgressTask::OnUpdate()
0x00001CD4 48656 3  XPCOM C: ( (dsIObjectEventCallback*)000001BD3541E5C0 )->onEvent( 000001BD2F219E20 )
0x00001CD4 48656 3  XPCOM C: ( (nsISupports*)000001BD2F219E28 )->queryInterface( 000001BD3D203CE0, 0000000DAD8FC8D8 )
0x00001CD4 48656 3  XPCOM R: ( (nsISupports*)000001BD2F219E28 )->queryInterface( 000001BD3D203CE0, *0000000DAD8FC8D8 = 000001BD2F219E20 ) = 0x00000000
0x00001CD4 48656 3  XPCOM C: ( (dsIProgressTaskData*)000001BD2F219E20 )->PercentDone( 0000000DAD8FC930 )
0x00001CD4 48656 3  XPCOM R: ( (dsIProgressTaskData*)000001BD2F219E20 )->PercentDone( *0000000DAD8FC930 = 0x00000000 ) = 0x00000000
0x00001CD4 48656 3  XPCOM C: ( (dsIProgressTaskData*)000001BD2F219E20 )->SubActivity( 0000000DAD8FC930 )
0x00001CD4 48656 3  XPCOM R: ( (dsIProgressTaskData*)000001BD2F219E20 )->SubActivity( *0000000DAD8FC930 = Executing Startup Scripts: Cortex_M4_0 ) = 0x00000000
0x00001CD4 48656 3  XPCOM R: ( (dsIObjectEventCallback*)000001BD3541E5C0 )->onEvent( 000001BD2F219E20 ) = 0x00000000
0x00001CD4 48656 3  COM_DBG_IF R: class CoProgressTask::OnUpdate()
0x00001CD4 48656 3  SEQUENCE I: Finished sequence step at 0000000DAD8FE2A8
0x00001CD4 48656 3  SEQUENCE I: Beginning class `anonymous namespace'::LoadStartupGelStep at 000001BD35507430
0x00001CD4 48656 3  PERF I: GEL OnStartUp() starting...
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD2A8 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD2A8 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD2A0 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD2A0 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluating "-(1)"
0x00001CD4 48656 3 Cortex_M4_0 POLL C: Firing DSP_GEL_FILE_LIST_CHANGED to all DSP_USER's
0x00001CD4 48656 3 Cortex_M4_0 POLL C: Firing of DSP_GEL_FILE_LIST_CHANGED complete
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD418 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD418 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD410 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD410 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 POLL C: Firing DSP_NEW_SYMBOLS to all DSP_USER's
0x00001CD4 48656 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class DebuggerListeners
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD3E8 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD3E8 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD3E0 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD3E0 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 POLL C: Firing of DSP_NEW_SYMBOLS complete
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDAE8 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FDAE8 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDAE0 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FDAE0 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluating "StartUp(12, 0, 0, 2795)"
0x00001CD4 48656 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::SystemInitializerPollFrequencyManager
0x00001CD4 48656 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 469 ms
0x00001CD4 48656 4  POLL I: TimeToSleep() found shorter sleep time of 469 ms from class DevicePollFrequencyManager
0x00001CD4 48656 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 485 ms
0x00001CD4 48656 4 Cortex_M4_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 48656 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 48656 3 Cortex_M4_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 48656 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 48656 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class MemMapChangeBroadcaster
0x00001CD4 48656 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class MemMapChangeBroadcaster
0x00001CD4 48656 3 Cortex_M4_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 48656 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_ABORT_REQUEST and status EVENT_DSP_HALT
0x00001CD4 48656 3 Cortex_M4_0 POLL C: Firing DSP_MEM_EVENT to class `anonymous namespace'::TpiStatusRegistersImpl
0x00001CD4 48656 3 Cortex_M4_0 POLL C: Firing of DSP_MEM_EVENT complete
0x00001CD4 48656 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::TpiStatusRegistersImpl
0x00001CD4 48656 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 48656 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='C$$IO$$' AND Register_Cache.Processor=35
0x00001CD4 48656 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=35 AND Name='C$$IO$$'
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluation of "C$$IO$$" failed: identifier not found: C$$IO$$
0x00001CD4 48656 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='C$$IOE$$' AND Register_Cache.Processor=35
0x00001CD4 48656 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=35 AND Name='C$$IOE$$'
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluation of "C$$IOE$$" failed: identifier not found: C$$IOE$$
0x00001CD4 48656 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='SVC_Handler' AND Register_Cache.Processor=35
0x00001CD4 48656 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=35 AND Name='SVC_Handler'
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluation of "SVC_Handler" failed: identifier not found: SVC_Handler
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD518 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD518 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD510 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD510 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluation of "0" completed - Value: 0 Location: unknown
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluation of "5" completed - Value: 5 Location: unknown
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluation of "1" completed - Value: 1 Location: unknown
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluation of "80" completed - Value: 80 Location: unknown
0x00001CD4 48656 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='C$$EXIT' AND Register_Cache.Processor=35
0x00001CD4 48656 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=35 AND Name='C$$EXIT'
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluation of "C$$EXIT" failed: identifier not found: C$$EXIT
0x00001CD4 48656 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='C$$EXITE' AND Register_Cache.Processor=35
0x00001CD4 48656 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=35 AND Name='C$$EXITE'
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluation of "C$$EXITE" failed: identifier not found: C$$EXITE
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD478 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD478 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD470 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD470 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD1B8 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD1B8 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD1B0 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD1B0 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD288 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD288 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD280 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD280 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 GEL I: Evaluation of "-(1)" completed - Value: -1 Location: unknown
0x00001CD4 48656 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class DebuggerListeners
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD318 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD318 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD310 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD310 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCFE8 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCFE8 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCFE0 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCFE0 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCCB8 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCCB8 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCCB0 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCCB0 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FC988 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FC988 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FC980 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FC980 ) = 0x00000002
0x00001CD4 48656 2 Cortex_M4_0 GEL I: cc26x2.gel:12	Enter function StartUp
0x00001CD4 48656 3 Cortex_M4_0 POLL C: Firing DSP_MEM_MAP_UPDATED to all DSP_USER's
0x00001CD4 48656 3 Cortex_M4_0 POLL C: Firing of DSP_MEM_MAP_UPDATED complete
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD278 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD278 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD270 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD270 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD508 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD508 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD500 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD500 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD058 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD058 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD050 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD050 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCDF8 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCDF8 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCDF0 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCDF0 ) = 0x00000002
0x00001CD4 48656 2 Cortex_M4_0 GEL I: cc26x2.gel:17	   GEL_LoadGel("$(GEL_file_dir)/cc26xx_connect_util.gel")
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD368 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD368 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD360 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD360 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCA08 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCA08 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCA00 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCA00 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCB78 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCB78 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCB70 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCB70 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCB48 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCB48 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCB40 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCB40 ) = 0x00000002
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD498 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD498 ) = 0x00000000
0x00001CD4 48656 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD490 )
0x00001CD4 48656 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD490 ) = 0x00000002
0x00001CD4 48656 2 Cortex_M4_0 GEL I: cc26x2.gel:18	   GEL_LoadGel("$(GEL_file_dir)/cc26x2_xds.gel")
0x00001CD4 48672 3 Cortex_M4_0 POLL C: Firing DSP_GEL_FILE_LIST_CHANGED to all DSP_USER's
0x00001CD4 48672 3 Cortex_M4_0 POLL C: Firing of DSP_GEL_FILE_LIST_CHANGED complete
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCB78 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCB78 ) = 0x00000000
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCB70 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCB70 ) = 0x00000002
0x00001CD4 48672 3 Cortex_M4_0 POLL C: Firing DSP_NEW_SYMBOLS to all DSP_USER's
0x00001CD4 48672 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class DebuggerListeners
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCB48 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCB48 ) = 0x00000000
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCB40 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCB40 ) = 0x00000002
0x00001CD4 48672 3 Cortex_M4_0 GEL I: Evaluating "C$$IO$$"
0x00001CD4 48672 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 48672 3 Cortex_M4_0 GEL I: Evaluating "C$$IOE$$"
0x00001CD4 48672 3 Cortex_M4_0 GEL I: Evaluating "SVC_Handler"
0x00001CD4 48672 3 Cortex_M4_0 GEL I: Evaluating "C$$EXIT"
0x00001CD4 48672 3 Cortex_M4_0 GEL I: Evaluating "C$$EXITE"
0x00001CD4 48672 3 Cortex_M4_0 POLL C: Firing of DSP_NEW_SYMBOLS complete
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD498 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD498 ) = 0x00000000
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD490 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD490 ) = 0x00000002
0x00001CD4 48672 2 Cortex_M4_0 GEL I: cc26x2.gel:20	   DefineResets(0)
0x00001CD4 48672 3 Cortex_M4_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 48672 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 48672 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 48672 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::SystemInitializerPollFrequencyManager
0x00001CD4 48672 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 469 ms
0x00001CD4 48672 4  POLL I: TimeToSleep() found shorter sleep time of 469 ms from class DevicePollFrequencyManager
0x00001CD4 48672 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 485 ms
0x00001CD4 48672 4 Cortex_M4_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 48672 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 48672 4  POLL I: Yielding to other threads
0x00001CD4 48672 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 48672 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD508 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD508 ) = 0x00000000
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD500 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD500 ) = 0x00000002
0x00001CD4 48672 3 Cortex_M4_0 GEL I: Evaluation of "0" completed - Value: 0 Location: unknown
0x00001CD4 48672 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 453 ms
0x00001CD4 48672 4  POLL I: TimeToSleep() found shorter sleep time of 453 ms from class DevicePollFrequencyManager
0x00001CD4 48672 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 469 ms
0x00001CD4 48672 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class DebuggerListeners
0x00001CD4 48672 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=35 AND Name='C$$IO$$'
0x00001CD4 48672 3 Cortex_M4_0 GEL I: Evaluation of "C$$IO$$" failed: identifier not found: C$$IO$$
0x00001CD4 48672 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=35 AND Name='C$$IOE$$'
0x00001CD4 48672 3 Cortex_M4_0 GEL I: Evaluation of "C$$IOE$$" failed: identifier not found: C$$IOE$$
0x00001CD4 48672 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=35 AND Name='SVC_Handler'
0x00001CD4 48672 3 Cortex_M4_0 GEL I: Evaluation of "SVC_Handler" failed: identifier not found: SVC_Handler
0x00001CD4 48672 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=35 AND Name='C$$EXIT'
0x00001CD4 48672 3 Cortex_M4_0 GEL I: Evaluation of "C$$EXIT" failed: identifier not found: C$$EXIT
0x00001CD4 48672 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=35 AND Name='C$$EXITE'
0x00001CD4 48672 3 Cortex_M4_0 GEL I: Evaluation of "C$$EXITE" failed: identifier not found: C$$EXITE
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD3C8 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD3C8 ) = 0x00000000
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD3C0 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD3C0 ) = 0x00000002
0x00001CD4 48672 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:164	   Enter function DefineResets
0x00001CD4 48672 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='_BoardResetMenuDefined' AND Register_Cache.Processor=35
0x00001CD4 48672 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=35 AND Name='_BoardResetMenuDefined'
0x00001CD4 48672 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:169	      DEBUG_RemoveResets(4)
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD428 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD428 ) = 0x00000000
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD420 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD420 ) = 0x00000002
0x00001CD4 48672 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:172	      DEBUG_DefineReset("Board Reset (automatic connect/disconnect)", "The same as a board reset, but debugger returns to the original connection state (connected or disconnected)", 0, "BoardReset_Automatic()")
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD368 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD368 ) = 0x00000000
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD360 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD360 ) = 0x00000002
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD018 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD018 ) = 0x00000000
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD010 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD010 ) = 0x00000002
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCD28 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FCD28 ) = 0x00000000
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCD20 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FCD20 ) = 0x00000002
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FC998 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FC998 ) = 0x00000000
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FC990 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FC990 ) = 0x00000002
0x00001CD4 48672 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:175	      DEBUG_DefineReset("Reset Emulator", "", 8, "EmulatorReset()")
0x00001CD4 48672 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:178	   Leave function DefineResets
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD048 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD048 ) = 0x00000000
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD040 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD040 ) = 0x00000002
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD548 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD548 ) = 0x00000000
0x00001CD4 48672 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD540 )
0x00001CD4 48672 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD540 ) = 0x00000002
0x00001CD4 48672 2 Cortex_M4_0 GEL I: cc26x2.gel:27	   GEL_AdvancedReset("Board Reset")
0x00001CD4 48672 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_ISSUE_RESET added to polling loop by unknown
0x00001CD4 48672 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_PRE_RESET and status EVENT_DSP_HALT
0x00001CD4 48672 3 Cortex_M4_0 GTI C: GTI_RESET_EX( 0x000001BD362E2770, 0x00000002 )
0x00001CD4 48672 3  XDS110 C: Executing command 0x01 (XDS_CONNECT)
0x00001CD4 48783 3  XDS110 R: Executed command 0x01 (XDS_CONNECT), return code: 0x00000000
0x00001CD4 48783 3  XDS110 C: Executing command 0x03 (XDS_VERSION)
0x00001CD4 48783 3  XDS110 R: Executed command 0x03 (XDS_VERSION), return code: 0x00000000
0x00001CD4 48783 3  XDS110 C: Executing command 0x04 (XDS_SETTCLKDELAY)
0x00001CD4 48783 3  XDS110 R: Executed command 0x04 (XDS_SETTCLKDELAY), return code: 0x00000000
0x00001CD4 48783 3  XDS110 C: Executing command 0x06 (XDS_GETTRST)
0x00001CD4 48783 3  XDS110 R: Executed command 0x06 (XDS_GETTRST), return code: 0x00000000
0x00001CD4 48783 3  XDS110 C: Executing command 0x05 (XDS_SETTRST)
0x00001CD4 48783 3  XDS110 R: Executed command 0x05 (XDS_SETTRST), return code: 0x00000000
0x00001CD4 48783 3  XDS110 C: Executing command 0x07 (XDS_CYCLETCLK)
0x00001CD4 48830 3  XDS110 R: Executed command 0x07 (XDS_CYCLETCLK), return code: 0x00000000
0x00001CD4 48830 3  XDS110 C: Executing command 0x2b (CJTAG_CONNECT)
0x00001CD4 48830 3  XDS110 R: Executed command 0x2b (CJTAG_CONNECT), return code: 0x00000000
0x00001CD4 48830 3  XDS110 C: Executing command 0x19 (SWD_ENABLESWO)
0x00001CD4 48939 3  XDS110 R: Executed command 0x19 (SWD_ENABLESWO), return code: 0x00000000
0x00001CD4 48939 3  XDS110 C: Executing command 0x07 (XDS_CYCLETCLK)
0x00001CD4 48986 3  XDS110 R: Executed command 0x07 (XDS_CYCLETCLK), return code: 0x00000000
0x00001CD4 48986 3  XDS110 C: Executing command 0x0e (XDS_SETSRST)
0x00001CD4 48986 3  XDS110 R: Executed command 0x0e (XDS_SETSRST), return code: 0x00000000
0x00001CD4 48986 3  XDS110 C: Executing command 0x07 (XDS_CYCLETCLK)
0x00001CD4 49049 3  XDS110 R: Executed command 0x07 (XDS_CYCLETCLK), return code: 0x00000000
0x00001CD4 49049 3  XDS110 C: Executing command 0x0e (XDS_SETSRST)
0x00001CD4 49049 3  XDS110 R: Executed command 0x0e (XDS_SETSRST), return code: 0x00000000
0x00001CD4 49049 3  XDS110 C: Executing command 0x07 (XDS_CYCLETCLK)
0x00001CD4 49160 3  XDS110 R: Executed command 0x07 (XDS_CYCLETCLK), return code: 0x00000000
0x00001CD4 49160 3  XDS110 C: Executing command 0x1a (SWD_DISABLESWO)
0x00001CD4 49255 3  XDS110 R: Executed command 0x1a (SWD_DISABLESWO), return code: 0x00000000
0x00001CD4 49255 3  XDS110 C: Executing command 0x2c (CJTAG_DISCONNECT)
0x00001CD4 49255 3  XDS110 R: Executed command 0x2c (CJTAG_DISCONNECT), return code: 0x00000000
0x00001CD4 49255 3  XDS110 C: Executing command 0x02 (XDS_DISCONNECT)
0x00001CD4 49366 3  XDS110 R: Executed command 0x02 (XDS_DISCONNECT), return code: 0x00000000
0x00001CD4 49366 3 Cortex_M4_0 GTI R: GTI_RESET_EX( 0x000001BD362E2770, 0x00000002 ) = 0x00000000
0x00001CD4 49366 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD8B8 = 0x00000000, *0x0000000DAD8FD8B0 = 0x00000000, *0x0000000DAD8FD8C8 = 0x00000000, *0x0000000DAD8FD8E0 = 0x00000000, *0x0000000DAD8FD8E8 = 0x00000000, *0x0000000DAD8FD8D8 = 0x00000000, *0x0000000DAD8FD8D0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 49366 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD8B8 = 0x00000000, *0x0000000DAD8FD8B0 = 0x00000000, *0x0000000DAD8FD8C8 = 0x00000000, *0x0000000DAD8FD8E0 = 0x00000002, *0x0000000DAD8FD8E8 = 0x00000000, *0x0000000DAD8FD8D8 = 0x00000008, *0x0000000DAD8FD8D0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 49366 3 Cortex_M4_0 STATE I: Debugger execution state changed to EVENT_DSP_HALT
0x00001CD4 49366 3 Cortex_M4_0 POLL C: Firing DSP_PRIORITY_RESET_DONE to all DSP_USER's
0x00001CD4 49366 3 Cortex_M4_0 POLL C: Firing of DSP_PRIORITY_RESET_DONE complete
0x00001CD4 49366 3 Cortex_M4_0 POLL C: Firing DSP_RESET_DONE to all DSP_USER's
0x00001CD4 49366 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD8E8 )
0x00001CD4 49366 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD8E8 ) = 0x00000000
0x00001CD4 49366 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD8E0 )
0x00001CD4 49366 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD8E0 ) = 0x00000002
0x00001CD4 49366 2 Cortex_M4_0 GEL I: cc26x2.gel:27	Leave function StartUp
0x00001CD4 49366 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD458 )
0x00001CD4 49366 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD458 ) = 0x00000000
0x00001CD4 49366 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD450 )
0x00001CD4 49366 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD450 ) = 0x00000002
0x00001CD4 49366 3 Cortex_M4_0 GEL I: Evaluation of "StartUp(12, 0, 0, 2795)" completed - Value: 0 Location: unknown
0x00001CD4 49366 3  PERF I: GEL OnStartUp() finished:  0.713994s wall, 0.156250s user + 0.031250s system = 0.187500s CPU (26.3%)
0x00001CD4 49366 3  SEQUENCE I: Finished sequence step at 000001BD35507430
0x00001CD4 49366 3  SEQUENCE I: Beginning class Debugger::LambdaSequenceStep<class <lambda_bcb20481c62572668180f439a17adeae> > at 000001BD3D204200
0x00001CD4 49366 3  SEQUENCE I: Finished sequence step at 000001BD3D204200
0x00001CD4 49366 3 Cortex_M4_0 POLL C: Firing of DSP_RESET_DONE complete
0x00001CD4 49366 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 49366 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 49366 4  POLL I: TimeToSleep() found shorter sleep time of 5000 ms from class `anonymous namespace'::SystemInitializerPollFrequencyManager
0x00001CD4 49366 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 453 ms
0x00001CD4 49366 4  POLL I: TimeToSleep() found shorter sleep time of 453 ms from class DevicePollFrequencyManager
0x00001CD4 49366 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 469 ms
0x00001CD4 49366 4 Cortex_M4_0 POLL I: TimeToPollAgain() target is idle and needs polling in 5000 ms
0x00001CD4 49829 3  PERF I: Configure finished:  1.750050s wall, 0.406250s user + 0.156250s system = 0.562500s CPU (32.1%)
0x00001CD4 49829 3  COM_DBG_IF C: class CoProgressTask::OnCompleted()
0x00001CD4 49829 3  XPCOM C: ( (dsIStringEventCallback*)000001BD3541D940 )->onEvent(  )
0x00001CD4 49829 3  XPCOM R: ( (dsIStringEventCallback*)000001BD3541D940 )->onEvent(  ) = 0x00000000
0x00001CD4 49829 3  COM_DBG_IF R: class CoProgressTask::OnCompleted()
0x00001CD4 49829 3  COM_DBG_IF C: class dsDebugger::OnConfigured()
0x00001CD4 49829 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD351BB6F0 )->onEvent()
0x00001CD4 49829 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD351BB6F0 )->onEvent() = 0x00000000
0x00001CD4 49829 3  COM_DBG_IF R: class dsDebugger::OnConfigured()
0x00001CD4 49829 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 0 ms
0x00001CD4 49829 3 IcePick_C POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 49829 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 49829 3 IcePick_C POLL R: Poll() returning
0x00001CD4 49829 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 0 ms
0x00001CD4 49829 3 CS_DAP_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 49829 4 CS_DAP_0 POLL I: Yielding to other threads
0x00001CD4 49829 3 CS_DAP_0 POLL R: Poll() returning
0x00001CD4 49829 4 Cortex_M4_0 POLL I: TimeToPollAgain() target is idle and needs polling in 3843 ms
0x00001CD4 49829 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 49829 4  POLL I: TimeToSleep() found shorter sleep time of 500 ms from class DevicePollFrequencyManager
0x00001CD4 49829 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00003B78 49829 3  XPCOM C: ( (dsIDebugger*)000001BD35627D80 )->Initialized( 0000000DAE4FED20 )
0x00003B78 49829 3  XPCOM R: ( (dsIDebugger*)000001BD35627D80 )->Initialized( *0000000DAE4FED20 = true ) = 0x00000000
0x00003B78 49829 3  XPCOM C: ( (dsIDebugger*)000001BD35627D80 )->Devices( 0000000DAE4FEB00 )
0x00003B78 49829 3  XPCOM R: ( (dsIDebugger*)000001BD35627D80 )->Devices( *0000000DAE4FEB00 = 000001BD30075100 ) = 0x00000000
0x00003B78 49829 3  XPCOM C: ( (dsIDeviceCollection*)000001BD30075100 )->Count( 0000000DAE4FEBD0 )
0x00003B78 49829 3  XPCOM R: ( (dsIDeviceCollection*)000001BD30075100 )->Count( *0000000DAE4FEBD0 = 0x00000001 ) = 0x00000000
0x00003B78 49829 3  XPCOM C: ( (dsIDeviceCollection*)000001BD30075100 )->item( 0x00000000, 0000000DAE4FEC28 )
0x00003B78 49829 3  XPCOM R: ( (dsIDeviceCollection*)000001BD30075100 )->item( 0x00000000, *0000000DAE4FEC28 = 000001BD2EA19A30 ) = 0x00000000
0x00003B78 49829 3  XPCOM C: ( (dsIDevice*)000001BD2EA19A30 )->Targets( 0000000DAE4FEC20 )
0x00003B78 49829 3  XPCOM R: ( (dsIDevice*)000001BD2EA19A30 )->Targets( *0000000DAE4FEC20 = 000001BD30074A70 ) = 0x00000000
0x00003B78 49829 3  XPCOM C: ( (dsITargetCollection*)000001BD30074A70 )->Count( 0000000DAE4FEB50 )
0x00003B78 49829 3  XPCOM R: ( (dsITargetCollection*)000001BD30074A70 )->Count( *0000000DAE4FEB50 = 0x00000001 ) = 0x00000000
0x00003B78 49845 3  XPCOM C: ( (dsITargetCollection*)000001BD30074A70 )->item( 0x00000000, 0000000DAE4FEBA8 )
0x00003B78 49845 3  XPCOM R: ( (dsITargetCollection*)000001BD30074A70 )->item( 0x00000000, *0000000DAE4FEBA8 = 000001BD297E4270 ) = 0x00000000
0x00003B78 49845 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607B020, 0000000DAE4FEB38 )
0x00003B78 49845 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607B020, *0000000DAE4FEB38 = 000001BD297E4290 ) = 0x00000000
0x00003B78 49850 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607B1E0, 0000000DAE4FEB38 )
0x00003B78 49850 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607B1E0, *0000000DAE4FEB38 = 000001BD297E4278 ) = 0x00000000
0x00003B78 49850 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607B200, 0000000DAE4FEB38 )
0x00003B78 49850 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607B200, *0000000DAE4FEB38 = 000001BD297E4288 ) = 0x00000000
0x00003B78 49850 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607AFC0, 0000000DAE4FEB38 )
0x00003B78 49850 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607AFC0, *0000000DAE4FEB38 = 000001BD297E42A8 ) = 0x00000000
0x00003B78 49850 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607B820, 0000000DAE4FEB38 )
0x00003B78 49850 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607B820, *0000000DAE4FEB38 = 000001BD297E4280 ) = 0x00000000
0x00003B78 49850 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607BA20, 0000000DAE4FEB38 )
0x00003B78 49850 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607BA20, *0000000DAE4FEB38 = 000001BD297E42A0 ) = 0x00000000
0x00003B78 49850 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607B460, 0000000DAE4FEB38 )
0x00003B78 49850 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607B460, *0000000DAE4FEB38 = 000001BD297E42B0 ) = 0x00000000
0x00003B78 49850 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607BB40, 0000000DAE4FEB38 )
0x00003B78 49850 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607BB40, *0000000DAE4FEB38 = 000001BD297E42B8 ) = 0x00000000
0x00003B78 49850 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607B720, 0000000DAE4FEB38 )
0x00003B78 49850 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607B720, *0000000DAE4FEB38 = 000001BD297E42C0 ) = 0x00000000
0x00003B78 49850 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607C080, 0000000DAE4FEB38 )
0x00003B78 49850 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607C080, *0000000DAE4FEB38 = 000001BD297E42C8 ) = 0x00000000
0x00003B78 49850 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607C220, 0000000DAE4FEB38 )
0x00003B78 49850 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607C220, *0000000DAE4FEB38 = 000001BD297E42D0 ) = 0x00000000
0x00003B78 49850 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607BF00, 0000000DAE4FEB38 )
0x00003B78 49850 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607BF00, *0000000DAE4FEB38 = 000001BD297E42D8 ) = 0x00000000
0x00003B78 49850 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607BEC0, 0000000DAE4FEB38 )
0x00003B78 49850 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607BEC0, *0000000DAE4FEB38 = 000001BD297E4298 ) = 0x00000000
0x00003B78 49850 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607BE00, 0000000DAE4FEB28 )
0x00003B78 49850 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3607BE00, *0000000DAE4FEB28 = 000001BD297E4290 ) = 0x00000000
0x00003B78 49850 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4290 )->getProcessorInfo( 0000000DAE4FE8B0, 0000000DAE4FE8C8, 0000000DAE4FE8E0, 0000000DAE4FE8F8, 0000000DAE4FE910, 0000000DAE4FE928 )
0x00003B78 49850 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4290 )->getProcessorInfo( *0000000DAE4FE8B0 = 0x000001D6, *0000000DAE4FE8C8 = 0x0000000E, *0000000DAE4FE8E0 = 0x00000000, *0000000DAE4FE8F8 = 0x00000000, *0000000DAE4FE910 = 0x75803800, *0000000DAE4FE928 = false ) = 0x00000000
0x00003B78 49850 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4290 )->getDriverProperties( 0000000DAE4FE980, 0000000DAE4FE998, 0000000DAE4FE9B0 )
0x00003B78 49850 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4290 )->getDriverProperties( *0000000DAE4FE980 = 0x00000006, *0000000DAE4FE998 = 000001BD29D160D0, *0000000DAE4FE9B0 = 000001BD29D15A90 ) = 0x00000000
0x00003B78 49850 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4290 )->getProcessorInfo( 0000000DAE4FE8A0, 0000000DAE4FE8B8, 0000000DAE4FE8D0, 0000000DAE4FE8E8, 0000000DAE4FE900, 0000000DAE4FE918 )
0x00003B78 49850 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4290 )->getProcessorInfo( *0000000DAE4FE8A0 = 0x000001D6, *0000000DAE4FE8B8 = 0x0000000E, *0000000DAE4FE8D0 = 0x00000000, *0000000DAE4FE8E8 = 0x00000000, *0000000DAE4FE900 = 0x75803800, *0000000DAE4FE918 = false ) = 0x00000000
0x00003B78 49850 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4290 )->getProcessorInfo( 0000000DAE4FE920, 0000000DAE4FE938, 0000000DAE4FE950, 0000000DAE4FE968, 0000000DAE4FE980, 0000000DAE4FE998 )
0x00003B78 49850 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4290 )->getProcessorInfo( *0000000DAE4FE920 = 0x000001D6, *0000000DAE4FE938 = 0x0000000E, *0000000DAE4FE950 = 0x00000000, *0000000DAE4FE968 = 0x00000000, *0000000DAE4FE980 = 0x75803800, *0000000DAE4FE998 = false ) = 0x00000000
0x00003B78 49850 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4290 )->getProcessorInfo( 0000000DAE4FE890, 0000000DAE4FE8A8, 0000000DAE4FE8C0, 0000000DAE4FE8D8, 0000000DAE4FE8F0, 0000000DAE4FE908 )
0x00003B78 49850 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4290 )->getProcessorInfo( *0000000DAE4FE890 = 0x000001D6, *0000000DAE4FE8A8 = 0x0000000E, *0000000DAE4FE8C0 = 0x00000000, *0000000DAE4FE8D8 = 0x00000000, *0000000DAE4FE8F0 = 0x75803800, *0000000DAE4FE908 = false ) = 0x00000000
0x00003B78 49867 3  XPCOM C: ( (dsIGetRegisterServer*)000001BD297E4280 )->getRegisterServer( 0000000DAE4FE910 )
0x00003B78 49867 3  XPCOM R: ( (dsIGetRegisterServer*)000001BD297E4280 )->getRegisterServer( *0000000DAE4FE910 = 000001BD2EA1C670 ) = 0x00000000
0x00003B78 49873 3  XPCOM C: ( (dsIGetBreakpointManager*)000001BD297E4288 )->getBreakpointManager( 0000000DAE4FE7D0 )
0x00003B78 49873 3  XPCOM R: ( (dsIGetBreakpointManager*)000001BD297E4288 )->getBreakpointManager( *0000000DAE4FE7D0 = 000001BD297E5870 ) = 0x00000000
0x00003B78 49873 3  XPCOM C: ( (dsIBreakpointManager*)000001BD297E5870 )->queryInterface( 000001BD3020FB10, 0000000DAE4FE778 )
0x00003B78 49873 3  XPCOM R: ( (dsIBreakpointManager*)000001BD297E5870 )->queryInterface( 000001BD3020FB10, *0000000DAE4FE778 = 000001BD297E5878 ) = 0x00000000
0x00003B78 49873 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onActionListenerAdded( 0000000DAE4FE6F0 )
0x00003B78 49873 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onActionListenerAdded( *0000000DAE4FE6F0 = 000001BD35074DC0 ) = 0x00000000
0x00003B78 49873 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onActionListenerRemoved( 0000000DAE4FE6F0 )
0x00003B78 49873 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onActionListenerRemoved( *0000000DAE4FE6F0 = 000001BD350741F0 ) = 0x00000000
0x00003B78 49873 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onBatchUpdateFinished( 0000000DAE4FE6F0 )
0x00003B78 49873 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onBatchUpdateFinished( *0000000DAE4FE6F0 = 000001BD35074700 ) = 0x00000000
0x00003B78 49873 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onBatchUpdateStarted( 0000000DAE4FE6F0 )
0x00003B78 49873 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onBatchUpdateStarted( *0000000DAE4FE6F0 = 000001BD35074160 ) = 0x00000000
0x00003B78 49873 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onBreakpointAdded( 0000000DAE4FE6F0 )
0x00003B78 49873 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onBreakpointAdded( *0000000DAE4FE6F0 = 000001BD3598BAC0 ) = 0x00000000
0x00003B78 49873 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onBreakpointRemoved( 0000000DAE4FE6F0 )
0x00003B78 49873 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onBreakpointRemoved( *0000000DAE4FE6F0 = 000001BD3598B1C0 ) = 0x00000000
0x00003B78 49873 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onBreakpointDisabled( 0000000DAE4FE6F0 )
0x00003B78 49873 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onBreakpointDisabled( *0000000DAE4FE6F0 = 000001BD35074A60 ) = 0x00000000
0x00003B78 49873 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onBreakpointEnabled( 0000000DAE4FE6F0 )
0x00003B78 49873 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onBreakpointEnabled( *0000000DAE4FE6F0 = 000001BD35074820 ) = 0x00000000
0x00003B78 49873 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onBreakpointHit( 0000000DAE4FE6F0 )
0x00003B78 49873 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onBreakpointHit( *0000000DAE4FE6F0 = 000001BD35074040 ) = 0x00000000
0x00003B78 49873 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onGroupCreated( 0000000DAE4FE6F0 )
0x00003B78 49873 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onGroupCreated( *0000000DAE4FE6F0 = 000001BD350748B0 ) = 0x00000000
0x00003B78 49873 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onGroupDeleted( 0000000DAE4FE6F0 )
0x00003B78 49873 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onGroupDeleted( *0000000DAE4FE6F0 = 000001BD350740D0 ) = 0x00000000
0x00003B78 49873 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onSourceFileResolve( 0000000DAE4FE6F0 )
0x00003B78 49873 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onSourceFileResolve( *0000000DAE4FE6F0 = 000001BD350743A0 ) = 0x00000000
0x00003B78 49899 3  XPCOM C: ( (dsIGetDspUser*)000001BD297E4278 )->createUser( 0000000DAE4FE750 )
0x00003B78 49899 3  XPCOM R: ( (dsIGetDspUser*)000001BD297E4278 )->createUser( *0000000DAE4FE750 = 000001BD29180DE0 ) = 0x00000000
0x00003B78 49903 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD30212470, 0000000DAE4FE758 )
0x00003B78 49903 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD30212470, *0000000DAE4FE758 = 000001BD29180E38 ) = 0x00000000
0x00003B78 49907 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD30212370, 0000000DAE4FE758 )
0x00003B78 49907 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD30212370, *0000000DAE4FE758 = 000001BD29180DF0 ) = 0x00000000
0x00003B78 49909 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D205AE0, 0000000DAE4FE758 )
0x00003B78 49909 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D205AE0, *0000000DAE4FE758 = 000001BD29180DF8 ) = 0x00000000
0x00003B78 49911 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D206220, 0000000DAE4FE758 )
0x00003B78 49911 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D206220, *0000000DAE4FE758 = 000001BD29180E30 ) = 0x00000000
0x00003B78 49912 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D205D40, 0000000DAE4FE758 )
0x00003B78 49912 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D205D40, *0000000DAE4FE758 = 000001BD29180DE8 ) = 0x00000000
0x00003B78 49913 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D205F80, 0000000DAE4FE758 )
0x00003B78 49913 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D205F80, *0000000DAE4FE758 = 000001BD29180E10 ) = 0x00000000
0x00003B78 49914 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D206860, 0000000DAE4FE758 )
0x00003B78 49914 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D206860, *0000000DAE4FE758 = 000001BD29180E00 ) = 0x00000000
0x00003B78 49915 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D206940, 0000000DAE4FE758 )
0x00003B78 49915 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D206940, *0000000DAE4FE758 = 000001BD29180E40 ) = 0x00000000
0x00003B78 49916 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D207040, 0000000DAE4FE758 )
0x00003B78 49916 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D207040, *0000000DAE4FE758 = 000001BD29180E20 ) = 0x00000000
0x00003B78 49917 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D207360, 0000000DAE4FE758 )
0x00003B78 49917 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D207360, *0000000DAE4FE758 = 000001BD29180E50 ) = 0x00000000
0x00003B78 49917 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D206D20, 0000000DAE4FE758 )
0x00003B78 49917 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D206D20, *0000000DAE4FE758 = 000001BD29180E48 ) = 0x00000000
0x00003B78 49919 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D206DA0, 0000000DAE4FE758 )
0x00003B78 49919 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D206DA0, *0000000DAE4FE758 = 000001BD29180E18 ) = 0x00000000
0x00003B78 49921 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D207A60, 0000000DAE4FE758 )
0x00003B78 49921 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D207A60, *0000000DAE4FE758 = 000001BD29180E58 ) = 0x00000000
0x00003B78 49922 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D2075A0, 0000000DAE4FE758 )
0x00003B78 49923 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D2075A0, *0000000DAE4FE758 = 000001BD29180E68 ) = 0x00000000
0x00003B78 49923 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D207AC0, 0000000DAE4FE758 )
0x00003B78 49923 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D207AC0, *0000000DAE4FE758 = 000001BD29180E78 ) = 0x00000000
0x00003B78 49925 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D207EE0, 0000000DAE4FE758 )
0x00003B78 49925 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D207EE0, *0000000DAE4FE758 = 000001BD29180EA0 ) = 0x00000000
0x00003B78 49926 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D207C80, 0000000DAE4FE758 )
0x00003B78 49926 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D207C80, *0000000DAE4FE758 = 000001BD29180E90 ) = 0x00000000
0x00003B78 49926 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D2080C0, 0000000DAE4FE758 )
0x00003B78 49927 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D2080C0, *0000000DAE4FE758 = 000001BD29180E80 ) = 0x00000000
0x00003B78 49927 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D207D40, 0000000DAE4FE758 )
0x00003B78 49927 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D207D40, *0000000DAE4FE758 = 000001BD29180E88 ) = 0x00000000
0x00003B78 49928 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D208080, 0000000DAE4FE758 )
0x00003B78 49928 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D208080, *0000000DAE4FE758 = 000001BD29180E98 ) = 0x00000000
0x00003B78 49928 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29180E18 )->onHalt( 0000000DAE4FE740 )
0x00003B78 49928 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29180E18 )->onHalt( *0000000DAE4FE740 = 000001BD350745E0 ) = 0x00000000
0x00003B78 49928 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29180E18 )->onRunning( 0000000DAE4FE740 )
0x00003B78 49928 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29180E18 )->onRunning( *0000000DAE4FE740 = 000001BD35074670 ) = 0x00000000
0x00003B78 49929 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29180E18 )->onTargetHaltDetected( 0000000DAE4FE770 )
0x00003B78 49929 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29180E18 )->onTargetHaltDetected( *0000000DAE4FE770 = 000001BD350744C0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29180E18 )->onRestart( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29180E18 )->onRestart( *0000000DAE4FE700 = 000001BD35074790 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29180E18 )->onAlreadyRunning( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29180E18 )->onAlreadyRunning( *0000000DAE4FE700 = 000001BD36C32660 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29180E18 )->onPowerStatusChanged( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29180E18 )->onPowerStatusChanged( *0000000DAE4FE700 = 000001BD36C32A50 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29180E18 )->onSecureStatusChanged( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29180E18 )->onSecureStatusChanged( *0000000DAE4FE700 = 000001BD36C331A0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29180E18 )->onExecutionStatusChanged( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29180E18 )->onExecutionStatusChanged( *0000000DAE4FE700 = 000001BD36C325D0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIResetControlEvents*)000001BD29180E20 )->onEmulatorReset( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIResetControlEvents*)000001BD29180E20 )->onEmulatorReset( *0000000DAE4FE700 = 000001BD36C32C00 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIResetControlEvents*)000001BD29180E20 )->onHaltOnResetChanged( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIResetControlEvents*)000001BD29180E20 )->onHaltOnResetChanged( *0000000DAE4FE700 = 000001BD36C32ED0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIResetControlEvents*)000001BD29180E20 )->onHeldInReset( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIResetControlEvents*)000001BD29180E20 )->onHeldInReset( *0000000DAE4FE700 = 000001BD36C32780 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIResetControlEvents*)000001BD29180E20 )->onReset( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIResetControlEvents*)000001BD29180E20 )->onReset( *0000000DAE4FE700 = 000001BD36C326F0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIProgramLoaderEvents*)000001BD29180E48 )->onStartFileLoad( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIProgramLoaderEvents*)000001BD29180E48 )->onStartFileLoad( *0000000DAE4FE700 = 000001BD36C32DB0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIProgramLoaderEvents*)000001BD29180E48 )->onPriorityFileLoaded( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIProgramLoaderEvents*)000001BD29180E48 )->onPriorityFileLoaded( *0000000DAE4FE700 = 000001BD36C32420 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIProgramLoaderEvents*)000001BD29180E48 )->onFileLoaded( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIProgramLoaderEvents*)000001BD29180E48 )->onFileLoaded( *0000000DAE4FE700 = 000001BD36C32D20 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsISymbolManagerEvents*)000001BD29180E40 )->onNewSymbols( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsISymbolManagerEvents*)000001BD29180E40 )->onNewSymbols( *0000000DAE4FE700 = 000001BD36C33110 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsISymbolManagerEvents*)000001BD29180E40 )->onNewSymbolsOffline( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsISymbolManagerEvents*)000001BD29180E40 )->onNewSymbolsOffline( *0000000DAE4FE700 = 000001BD36C32E40 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIMemoryMap*)000001BD29180E30 )->onMemoryMapUpdate( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIMemoryMap*)000001BD29180E30 )->onMemoryMapUpdate( *0000000DAE4FE700 = 000001BD36C329C0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsITargetIO*)000001BD29180E50 )->onStdErr( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsITargetIO*)000001BD29180E50 )->onStdErr( *0000000DAE4FE700 = 000001BD29ADC570 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsITargetIO*)000001BD29180E50 )->onStdOut( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsITargetIO*)000001BD29180E50 )->onStdOut( *0000000DAE4FE700 = 000001BD29ADC8D0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsITargetIO*)000001BD29180E50 )->onStdIn( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsITargetIO*)000001BD29180E50 )->onStdIn( *0000000DAE4FE700 = 000001BD29ADC4E0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIGELTextOutEvent*)000001BD29180E58 )->onGELTextOut( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIGELTextOutEvent*)000001BD29180E58 )->onGELTextOut( *0000000DAE4FE700 = 000001BD29ADC450 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIErrorOutput*)000001BD29180E68 )->onFatal( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIErrorOutput*)000001BD29180E68 )->onFatal( *0000000DAE4FE700 = 000001BD29ADC600 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIErrorOutput*)000001BD29180E68 )->onError( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIErrorOutput*)000001BD29180E68 )->onError( *0000000DAE4FE700 = 000001BD29ADCF00 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIErrorOutput*)000001BD29180E68 )->onWarning( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIErrorOutput*)000001BD29180E68 )->onWarning( *0000000DAE4FE700 = 000001BD29ADC690 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIErrorOutput*)000001BD29180E68 )->onInfo( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIErrorOutput*)000001BD29180E68 )->onInfo( *0000000DAE4FE700 = 000001BD29ADC7B0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIRefreshControl*)000001BD29180E78 )->onAllowedUserAccessesChanged( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIRefreshControl*)000001BD29180E78 )->onAllowedUserAccessesChanged( *0000000DAE4FE700 = 000001BD29ADC9F0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIRefreshEvents*)000001BD29180EA0 )->onRefresh( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIRefreshEvents*)000001BD29180EA0 )->onRefresh( *0000000DAE4FE700 = 000001BD35073FB0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsITargetProperties*)000001BD29180E80 )->onPropertyGet( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsITargetProperties*)000001BD29180E80 )->onPropertyGet( *0000000DAE4FE700 = 000001BD29ADC720 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsITargetProperties*)000001BD29180E80 )->onPropertySet( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsITargetProperties*)000001BD29180E80 )->onPropertySet( *0000000DAE4FE700 = 000001BD29ADCDE0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIControlPointControl*)000001BD29180E90 )->onControlPointHit( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIControlPointControl*)000001BD29180E90 )->onControlPointHit( *0000000DAE4FE700 = 000001BD29ADC0F0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIGelFileListEvents*)000001BD29180E98 )->onGelFileListChanged( 0000000DAE4FE700 )
0x00003B78 49930 3  XPCOM R: ( (dsIGelFileListEvents*)000001BD29180E98 )->onGelFileListChanged( *0000000DAE4FE700 = 000001BD29ADCE70 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsISimpleEvent*)000001BD36C325D0 )->addListener( 000001BD3D208F60 )
0x00003B78 49930 3  XPCOM R: ( (dsISimpleEvent*)000001BD36C325D0 )->addListener( 000001BD3D208F60 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D208EE0, 0000000DAE4FE5C8 )
0x00003B78 49930 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D208EE0, *0000000DAE4FE5C8 = 000001BD29180E08 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIConnectDisconnect*)000001BD29180E08 )->queryInterface( 000001BD3D208EE0, 0000000DAE4FE558 )
0x00003B78 49930 3  XPCOM R: ( (dsIConnectDisconnect*)000001BD29180E08 )->queryInterface( 000001BD3D208EE0, *0000000DAE4FE558 = 000001BD29180E28 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29180E28 )->onConnectFailed( 0000000DAE4FE540 )
0x00003B78 49930 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29180E28 )->onConnectFailed( *0000000DAE4FE540 = 000001BD36C32540 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29180E28 )->onConnected( 0000000DAE4FE540 )
0x00003B78 49930 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29180E28 )->onConnected( *0000000DAE4FE540 = 000001BD36C32810 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29180E28 )->onDisconnecting( 0000000DAE4FE540 )
0x00003B78 49930 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29180E28 )->onDisconnecting( *0000000DAE4FE540 = 000001BD36C32AE0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29180E28 )->onDisconnected( 0000000DAE4FE540 )
0x00003B78 49930 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29180E28 )->onDisconnected( *0000000DAE4FE540 = 000001BD36C32F60 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29180E28 )->onRemoveDebugState( 0000000DAE4FE540 )
0x00003B78 49930 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29180E28 )->onRemoveDebugState( *0000000DAE4FE540 = 000001BD36C328A0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29180E28 )->onRestoreDebugState( 0000000DAE4FE540 )
0x00003B78 49930 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29180E28 )->onRestoreDebugState( *0000000DAE4FE540 = 000001BD36C32FF0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29180E28 )->onWaitingToConnect( 0000000DAE4FE540 )
0x00003B78 49930 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29180E28 )->onWaitingToConnect( *0000000DAE4FE540 = 000001BD36C32B70 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsISimpleEvent*)000001BD36C32540 )->addListener( 000001BD3D209A20 )
0x00003B78 49930 3  XPCOM R: ( (dsISimpleEvent*)000001BD36C32540 )->addListener( 000001BD3D209A20 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsISimpleEvent*)000001BD36C32810 )->addListener( 000001BD3D2095E0 )
0x00003B78 49930 3  XPCOM R: ( (dsISimpleEvent*)000001BD36C32810 )->addListener( 000001BD3D2095E0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsISimpleEvent*)000001BD36C32F60 )->addListener( 000001BD3D2097E0 )
0x00003B78 49930 3  XPCOM R: ( (dsISimpleEvent*)000001BD36C32F60 )->addListener( 000001BD3D2097E0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIBooleanEvent*)000001BD36C32AE0 )->addListener( 000001BD3D209B80 )
0x00003B78 49930 3  XPCOM R: ( (dsIBooleanEvent*)000001BD36C32AE0 )->addListener( 000001BD3D209B80 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsISimpleEvent*)000001BD36C32B70 )->addListener( 000001BD3D209BC0 )
0x00003B78 49930 3  XPCOM R: ( (dsISimpleEvent*)000001BD36C32B70 )->addListener( 000001BD3D209BC0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIBooleanEvent*)000001BD36C33110 )->addListener( 000001BD3D209680 )
0x00003B78 49930 3  XPCOM R: ( (dsIBooleanEvent*)000001BD36C33110 )->addListener( 000001BD3D209680 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsINumberEvent*)000001BD35073FB0 )->addListener( 000001BD3D209520 )
0x00003B78 49930 3  XPCOM R: ( (dsINumberEvent*)000001BD35073FB0 )->addListener( 000001BD3D209520 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsISimpleEvent*)000001BD29ADC9F0 )->addListener( 000001BD3D209860 )
0x00003B78 49930 3  XPCOM R: ( (dsISimpleEvent*)000001BD29ADC9F0 )->addListener( 000001BD3D209860 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D209B60, 0000000DAE4FE878 )
0x00003B78 49930 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3D209B60, *0000000DAE4FE878 = 000001BD29180DE8 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->PathName( 0000000DAE4FE8D0 )
0x00003B78 49930 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->PathName( *0000000DAE4FE8D0 = Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0 ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->TargetType( 0000000DAE4FE8E0 )
0x00003B78 49930 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->TargetType( *0000000DAE4FE8E0 = TMS470REX ) = 0x00000000
0x00003B78 49930 3  XPCOM C: ( (dsIConnectDisconnect*)000001BD29180E08 )->connectionStatus( 0000000DAE4FE5A0 )
0x00003B78 49930 3  XPCOM R: ( (dsIConnectDisconnect*)000001BD29180E08 )->connectionStatus( *0000000DAE4FE5A0 = 0x00000002 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->Name( 0000000DAE4FE120 )
0x00003B78 49946 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->Name( *0000000DAE4FE120 = Cortex_M4_0 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4290 )->Partnum( 0000000DAE4FE120 )
0x00003B78 49946 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4290 )->Partnum( *0000000DAE4FE120 = CC2642R1F ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4290 )->getProcessorInfo( 0000000DAE4FE000, 0000000DAE4FE018, 0000000DAE4FE030, 0000000DAE4FE048, 0000000DAE4FE060, 0000000DAE4FE078 )
0x00003B78 49946 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4290 )->getProcessorInfo( *0000000DAE4FE000 = 0x000001D6, *0000000DAE4FE018 = 0x0000000E, *0000000DAE4FE030 = 0x00000000, *0000000DAE4FE048 = 0x00000000, *0000000DAE4FE060 = 0x75803800, *0000000DAE4FE078 = false ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4290 )->getProcessorInfo( 0000000DAE4FE010, 0000000DAE4FE028, 0000000DAE4FE040, 0000000DAE4FE058, 0000000DAE4FE070, 0000000DAE4FE088 )
0x00003B78 49946 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4290 )->getProcessorInfo( *0000000DAE4FE010 = 0x000001D6, *0000000DAE4FE028 = 0x0000000E, *0000000DAE4FE040 = 0x00000000, *0000000DAE4FE058 = 0x00000000, *0000000DAE4FE070 = 0x75803800, *0000000DAE4FE088 = false ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsIObjectEvent*)000001BD29ADC8D0 )->addListener( 000001BD3CDBDA00 )
0x00003B78 49946 3  XPCOM R: ( (dsIObjectEvent*)000001BD29ADC8D0 )->addListener( 000001BD3CDBDA00 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsIObjectEvent*)000001BD29ADC570 )->addListener( 000001BD3CDBDF20 )
0x00003B78 49946 3  XPCOM R: ( (dsIObjectEvent*)000001BD29ADC570 )->addListener( 000001BD3CDBDF20 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsIStringEvent*)000001BD29ADC600 )->addListener( 000001BD3CDBDC40 )
0x00003B78 49946 3  XPCOM R: ( (dsIStringEvent*)000001BD29ADC600 )->addListener( 000001BD3CDBDC40 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsIStringEvent*)000001BD29ADCF00 )->addListener( 000001BD3CDBE1A0 )
0x00003B78 49946 3  XPCOM R: ( (dsIStringEvent*)000001BD29ADCF00 )->addListener( 000001BD3CDBE1A0 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsIStringEvent*)000001BD29ADC690 )->addListener( 000001BD3CDBDF40 )
0x00003B78 49946 3  XPCOM R: ( (dsIStringEvent*)000001BD29ADC690 )->addListener( 000001BD3CDBDF40 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsIStringEvent*)000001BD29ADC7B0 )->addListener( 000001BD3CDBDB40 )
0x00003B78 49946 3  XPCOM R: ( (dsIStringEvent*)000001BD29ADC7B0 )->addListener( 000001BD3CDBDB40 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->TargetType( 0000000DAE4FE090 )
0x00003B78 49946 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->TargetType( *0000000DAE4FE090 = TMS470REX ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugProperties( Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, TMS470REX, 0000000DAE4FE0A0 )
0x00003B78 49946 3  XPCOM R: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugProperties( Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, TMS470REX, *0000000DAE4FE0A0 = 000001BD2E4139C0 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E4139C0 )->queryInterface( 000001BD3CDBE380, 0000000DAE4FE018 )
0x00003B78 49946 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E4139C0 )->queryInterface( 000001BD3CDBE380, *0000000DAE4FE018 = 000001BD2E4139C8 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2E4139C8 )->onDisableStatusChanged( 0000000DAE4FDFF0 )
0x00003B78 49946 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2E4139C8 )->onDisableStatusChanged( *0000000DAE4FDFF0 = 000001BD2CC675C0 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2E4139C8 )->onPropertyValueChanged( 0000000DAE4FDFF0 )
0x00003B78 49946 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2E4139C8 )->onPropertyValueChanged( *0000000DAE4FDFF0 = 000001BD2CC67380 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->TargetType( 0000000DAE4FE000 )
0x00003B78 49946 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->TargetType( *0000000DAE4FE000 = TMS470REX ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsIGetFlashProgrammerManager*)000001BD297E42C8 )->getFlashProgrammerManager( 0000000DAE4FE070 )
0x00003B78 49946 3  XPCOM R: ( (dsIGetFlashProgrammerManager*)000001BD297E42C8 )->getFlashProgrammerManager( *0000000DAE4FE070 = 000001BD3DBD5D30 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsIDevice*)000001BD2EA19A30 )->NonDebugTargets( 0000000DAE4FEBE0 )
0x00003B78 49946 3  XPCOM R: ( (dsIDevice*)000001BD2EA19A30 )->NonDebugTargets( *0000000DAE4FEBE0 = 000001BD3DBD5F60 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsITargetCollection*)000001BD3DBD5F60 )->Count( 0000000DAE4FEB10 )
0x00003B78 49946 3  XPCOM R: ( (dsITargetCollection*)000001BD3DBD5F60 )->Count( *0000000DAE4FEB10 = 0x00000002 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsITargetCollection*)000001BD3DBD5F60 )->item( 0x00000000, 0000000DAE4FEB68 )
0x00003B78 49946 3  XPCOM R: ( (dsITargetCollection*)000001BD3DBD5F60 )->item( 0x00000000, *0000000DAE4FEB68 = 000001BD297E4070 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEFE0, 0000000DAE4FEAF8 )
0x00003B78 49946 3  XPCOM R: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEFE0, *0000000DAE4FEAF8 = 000001BD297E4090 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEC20, 0000000DAE4FEAF8 )
0x00003B78 49946 3  XPCOM R: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEC20, *0000000DAE4FEAF8 = 000001BD297E4078 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEBC0, 0000000DAE4FEAF8 )
0x00003B78 49946 3  XPCOM R: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEBC0, *0000000DAE4FEAF8 = 000001BD297E4088 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEA40, 0000000DAE4FEAF8 )
0x00003B78 49946 3  XPCOM R: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEA40, *0000000DAE4FEAF8 = 000001BD297E40A8 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEE20, 0000000DAE4FEAF8 )
0x00003B78 49946 3  XPCOM R: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEE20, *0000000DAE4FEAF8 = 000001BD297E4080 ) = 0x00000000
0x00003B78 49946 3  XPCOM C: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEB40, 0000000DAE4FEAF8 )
0x00003B78 49946 3  XPCOM R: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEB40, *0000000DAE4FEAF8 = 000001BD297E40A0 ) = 0x00000000
0x00003B78 49946 3  XPCOM R: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEE20, *0000000DAE4FEAF8 = 000001BD297E40B0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEA40, 0000000DAE4FEAF8 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEA40, *0000000DAE4FEAF8 = 000001BD297E40B8 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEBC0, 0000000DAE4FEAF8 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEBC0, *0000000DAE4FEAF8 = 000001BD297E40C0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEC20, 0000000DAE4FEAF8 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEC20, *0000000DAE4FEAF8 = 000001BD297E40C8 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEE20, 0000000DAE4FEAF8 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEE20, *0000000DAE4FEAF8 = 000001BD297E40D0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBF000, 0000000DAE4FEAF8 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBF000, *0000000DAE4FEAF8 = 000001BD297E40D8 ) = 0x00000000
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBEBC0, *0000000DAE4FEAF8 = 000001BD297E4098 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBF120, 0000000DAE4FEAE8 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDBF120, *0000000DAE4FEAE8 = 000001BD297E4090 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4090 )->getProcessorInfo( 0000000DAE4FE870, 0000000DAE4FE888, 0000000DAE4FE8A0, 0000000DAE4FE8B8, 0000000DAE4FE8D0, 0000000DAE4FE8E8 )
0x00003B78 49961 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4090 )->getProcessorInfo( *0000000DAE4FE870 = 0x000000F0, *0000000DAE4FE888 = 0x00000002, *0000000DAE4FE8A0 = 0x00000000, *0000000DAE4FE8B8 = 0x00000005, *0000000DAE4FE8D0 = 0x3C000805, *0000000DAE4FE8E8 = false ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4090 )->getDriverProperties( 0000000DAE4FE940, 0000000DAE4FE958, 0000000DAE4FE970 )
0x00003B78 49961 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4090 )->getDriverProperties( *0000000DAE4FE940 = 0x00000005, *0000000DAE4FE958 = 000001BD2BAA28B0, *0000000DAE4FE970 = 000001BD2BAA2AC0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4090 )->getProcessorInfo( 0000000DAE4FE860, 0000000DAE4FE878, 0000000DAE4FE890, 0000000DAE4FE8A8, 0000000DAE4FE8C0, 0000000DAE4FE8D8 )
0x00003B78 49961 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4090 )->getProcessorInfo( *0000000DAE4FE860 = 0x000000F0, *0000000DAE4FE878 = 0x00000002, *0000000DAE4FE890 = 0x00000000, *0000000DAE4FE8A8 = 0x00000005, *0000000DAE4FE8C0 = 0x3C000805, *0000000DAE4FE8D8 = false ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4090 )->getProcessorInfo( 0000000DAE4FE8E0, 0000000DAE4FE8F8, 0000000DAE4FE910, 0000000DAE4FE928, 0000000DAE4FE940, 0000000DAE4FE958 )
0x00003B78 49961 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4090 )->getProcessorInfo( *0000000DAE4FE8E0 = 0x000000F0, *0000000DAE4FE8F8 = 0x00000002, *0000000DAE4FE910 = 0x00000000, *0000000DAE4FE928 = 0x00000005, *0000000DAE4FE940 = 0x3C000805, *0000000DAE4FE958 = false ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4070 )->Name( 0000000DAE4FE120 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4070 )->Name( *0000000DAE4FE120 = IcePick_C ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4090 )->Partnum( 0000000DAE4FE120 )
0x00003B78 49961 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4090 )->Partnum( *0000000DAE4FE120 = CC2642R1F ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIGetRegisterServer*)000001BD297E4080 )->getRegisterServer( 0000000DAE4FDFF0 )
0x00003B78 49961 3  XPCOM R: ( (dsIGetRegisterServer*)000001BD297E4080 )->getRegisterServer( *0000000DAE4FDFF0 = 000001BD2F21AB40 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIGetBreakpointManager*)000001BD297E4088 )->getBreakpointManager( 0000000DAE4FDFE0 )
0x00003B78 49961 3  XPCOM R: ( (dsIGetBreakpointManager*)000001BD297E4088 )->getBreakpointManager( *0000000DAE4FDFE0 = 000001BD297E3F70 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManager*)000001BD297E3F70 )->queryInterface( 000001BD3CDBEE20, 0000000DAE4FDF88 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManager*)000001BD297E3F70 )->queryInterface( 000001BD3CDBEE20, *0000000DAE4FDF88 = 000001BD297E3F78 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onActionListenerAdded( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onActionListenerAdded( *0000000DAE4FDF00 = 000001BD2946AC60 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onActionListenerRemoved( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onActionListenerRemoved( *0000000DAE4FDF00 = 000001BD29469F70 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onBatchUpdateFinished( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onBatchUpdateFinished( *0000000DAE4FDF00 = 000001BD2946ACF0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onBatchUpdateStarted( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onBatchUpdateStarted( *0000000DAE4FDF00 = 000001BD2946B950 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onBreakpointAdded( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onBreakpointAdded( *0000000DAE4FDF00 = 000001BD2946A090 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onBreakpointRemoved( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onBreakpointRemoved( *0000000DAE4FDF00 = 000001BD2946BCB0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onBreakpointDisabled( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onBreakpointDisabled( *0000000DAE4FDF00 = 000001BD2946AEA0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onBreakpointEnabled( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onBreakpointEnabled( *0000000DAE4FDF00 = 000001BD2946A120 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onBreakpointHit( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onBreakpointHit( *0000000DAE4FDF00 = 000001BD2946AAB0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onGroupCreated( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onGroupCreated( *0000000DAE4FDF00 = 000001BD29469AF0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onGroupDeleted( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onGroupDeleted( *0000000DAE4FDF00 = 000001BD2946ABD0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onSourceFileResolve( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onSourceFileResolve( *0000000DAE4FDF00 = 000001BD2946B9E0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIGetDspUser*)000001BD297E4078 )->createUser( 0000000DAE4FDF60 )
0x00003B78 49961 3  XPCOM R: ( (dsIGetDspUser*)000001BD297E4078 )->createUser( *0000000DAE4FDF60 = 000001BD29180F60 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF760, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF760, *0000000DAE4FDF68 = 000001BD29180FB8 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF4A0, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF4A0, *0000000DAE4FDF68 = 000001BD29180F70 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF540, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF540, *0000000DAE4FDF68 = 000001BD29180F78 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF900, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF900, *0000000DAE4FDF68 = 000001BD29180FB0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF9A0, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF9A0, *0000000DAE4FDF68 = 000001BD29180F68 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF940, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF940, *0000000DAE4FDF68 = 000001BD29180F90 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF720, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF720, *0000000DAE4FDF68 = 000001BD29180F80 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF860, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF860, *0000000DAE4FDF68 = 000001BD29180FC0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF440, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF440, *0000000DAE4FDF68 = 000001BD29180FA0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF420, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF420, *0000000DAE4FDF68 = 000001BD29180FD0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF780, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF780, *0000000DAE4FDF68 = 000001BD29180FC8 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF2E0, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF2E0, *0000000DAE4FDF68 = 000001BD29180F98 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF840, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF840, *0000000DAE4FDF68 = 000001BD29180FD8 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF6A0, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF6A0, *0000000DAE4FDF68 = 000001BD29180FE8 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF560, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF560, *0000000DAE4FDF68 = 000001BD29180FF8 ) = 0x00000000
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF900, *0000000DAE4FDF68 = 000001BD29181020 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF620, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF620, *0000000DAE4FDF68 = 000001BD29181010 ) = 0x00000000
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF2E0, *0000000DAE4FDF68 = 000001BD29181000 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF380, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF380, *0000000DAE4FDF68 = 000001BD29181008 ) = 0x00000000
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF2E0, *0000000DAE4FDF68 = 000001BD29181018 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29180F98 )->onHalt( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29180F98 )->onHalt( *0000000DAE4FDF40 = 000001BD2946AE10 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29180F98 )->onRunning( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29180F98 )->onRunning( *0000000DAE4FDF40 = 000001BD29469940 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29180F98 )->onTargetHaltDetected( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29180F98 )->onTargetHaltDetected( *0000000DAE4FDF40 = 000001BD2946A630 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29180F98 )->onRestart( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29180F98 )->onRestart( *0000000DAE4FDF40 = 000001BD2946AFC0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29180F98 )->onAlreadyRunning( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29180F98 )->onAlreadyRunning( *0000000DAE4FDF40 = 000001BD2946A6C0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29180F98 )->onPowerStatusChanged( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29180F98 )->onPowerStatusChanged( *0000000DAE4FDF40 = 000001BD2946BB00 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29180F98 )->onSecureStatusChanged( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29180F98 )->onSecureStatusChanged( *0000000DAE4FDF40 = 000001BD294699D0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29180F98 )->onExecutionStatusChanged( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29180F98 )->onExecutionStatusChanged( *0000000DAE4FDF40 = 000001BD2946B710 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIResetControlEvents*)000001BD29180FA0 )->onEmulatorReset( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIResetControlEvents*)000001BD29180FA0 )->onEmulatorReset( *0000000DAE4FDF40 = 000001BD29469DC0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIResetControlEvents*)000001BD29180FA0 )->onHaltOnResetChanged( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIResetControlEvents*)000001BD29180FA0 )->onHaltOnResetChanged( *0000000DAE4FDF40 = 000001BD2946B050 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIResetControlEvents*)000001BD29180FA0 )->onHeldInReset( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIResetControlEvents*)000001BD29180FA0 )->onHeldInReset( *0000000DAE4FDF40 = 000001BD2946A7E0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIResetControlEvents*)000001BD29180FA0 )->onReset( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIResetControlEvents*)000001BD29180FA0 )->onReset( *0000000DAE4FDF40 = 000001BD2946BB90 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProgramLoaderEvents*)000001BD29180FC8 )->onStartFileLoad( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIProgramLoaderEvents*)000001BD29180FC8 )->onStartFileLoad( *0000000DAE4FDF40 = 000001BD2A324740 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProgramLoaderEvents*)000001BD29180FC8 )->onPriorityFileLoaded( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIProgramLoaderEvents*)000001BD29180FC8 )->onPriorityFileLoaded( *0000000DAE4FDF40 = 000001BD2A324980 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProgramLoaderEvents*)000001BD29180FC8 )->onFileLoaded( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIProgramLoaderEvents*)000001BD29180FC8 )->onFileLoaded( *0000000DAE4FDF40 = 000001BD2A324D70 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsISymbolManagerEvents*)000001BD29180FC0 )->onNewSymbols( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsISymbolManagerEvents*)000001BD29180FC0 )->onNewSymbols( *0000000DAE4FDF40 = 000001BD2A323FF0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsISymbolManagerEvents*)000001BD29180FC0 )->onNewSymbolsOffline( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsISymbolManagerEvents*)000001BD29180FC0 )->onNewSymbolsOffline( *0000000DAE4FDF40 = 000001BD2A325040 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIMemoryMap*)000001BD29180FB0 )->onMemoryMapUpdate( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIMemoryMap*)000001BD29180FB0 )->onMemoryMapUpdate( *0000000DAE4FDF40 = 000001BD2A323390 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITargetIO*)000001BD29180FD0 )->onStdErr( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsITargetIO*)000001BD29180FD0 )->onStdErr( *0000000DAE4FDF40 = 000001BD2A323AE0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITargetIO*)000001BD29180FD0 )->onStdOut( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsITargetIO*)000001BD29180FD0 )->onStdOut( *0000000DAE4FDF40 = 000001BD2A322FA0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITargetIO*)000001BD29180FD0 )->onStdIn( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsITargetIO*)000001BD29180FD0 )->onStdIn( *0000000DAE4FDF40 = 000001BD2A323030 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIGELTextOutEvent*)000001BD29180FD8 )->onGELTextOut( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIGELTextOutEvent*)000001BD29180FD8 )->onGELTextOut( *0000000DAE4FDF40 = 000001BD2A323B70 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIErrorOutput*)000001BD29180FE8 )->onFatal( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIErrorOutput*)000001BD29180FE8 )->onFatal( *0000000DAE4FDF40 = 000001BD2A323A50 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIErrorOutput*)000001BD29180FE8 )->onError( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIErrorOutput*)000001BD29180FE8 )->onError( *0000000DAE4FDF40 = 000001BD2A3230C0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIErrorOutput*)000001BD29180FE8 )->onWarning( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIErrorOutput*)000001BD29180FE8 )->onWarning( *0000000DAE4FDF40 = 000001BD2A323300 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIErrorOutput*)000001BD29180FE8 )->onInfo( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIErrorOutput*)000001BD29180FE8 )->onInfo( *0000000DAE4FDF40 = 000001BD2A324E90 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRefreshControl*)000001BD29180FF8 )->onAllowedUserAccessesChanged( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRefreshControl*)000001BD29180FF8 )->onAllowedUserAccessesChanged( *0000000DAE4FDF40 = 000001BD2A3251F0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRefreshEvents*)000001BD29181020 )->onRefresh( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRefreshEvents*)000001BD29181020 )->onRefresh( *0000000DAE4FDF40 = 000001BD2946B4D0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITargetProperties*)000001BD29181000 )->onPropertyGet( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsITargetProperties*)000001BD29181000 )->onPropertyGet( *0000000DAE4FDF40 = 000001BD2A3234B0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITargetProperties*)000001BD29181000 )->onPropertySet( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsITargetProperties*)000001BD29181000 )->onPropertySet( *0000000DAE4FDF40 = 000001BD2A3235D0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIControlPointControl*)000001BD29181010 )->onControlPointHit( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIControlPointControl*)000001BD29181010 )->onControlPointHit( *0000000DAE4FDF40 = 000001BD2A3247D0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIGelFileListEvents*)000001BD29181018 )->onGelFileListChanged( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIGelFileListEvents*)000001BD29181018 )->onGelFileListChanged( *0000000DAE4FDF40 = 000001BD2A322E80 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsISimpleEvent*)000001BD2946B710 )->addListener( 000001BD3CDBF560 )
0x00003B78 49961 3  XPCOM R: ( (dsISimpleEvent*)000001BD2946B710 )->addListener( 000001BD3CDBF560 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF580, 0000000DAE4FDE08 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDBF580, *0000000DAE4FDE08 = 000001BD29180F88 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIConnectDisconnect*)000001BD29180F88 )->queryInterface( 000001BD3CDBF580, 0000000DAE4FDDA8 )
0x00003B78 49961 3  XPCOM R: ( (dsIConnectDisconnect*)000001BD29180F88 )->queryInterface( 000001BD3CDBF580, *0000000DAE4FDDA8 = 000001BD29180FA8 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29180FA8 )->onConnectFailed( 0000000DAE4FDD80 )
0x00003B78 49961 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29180FA8 )->onConnectFailed( *0000000DAE4FDD80 = 000001BD2A323540 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29180FA8 )->onConnected( 0000000DAE4FDD80 )
0x00003B78 49961 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29180FA8 )->onConnected( *0000000DAE4FDD80 = 000001BD2946B0E0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29180FA8 )->onDisconnecting( 0000000DAE4FDD80 )
0x00003B78 49961 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29180FA8 )->onDisconnecting( *0000000DAE4FDD80 = 000001BD2A324E00 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29180FA8 )->onDisconnected( 0000000DAE4FDD80 )
0x00003B78 49961 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29180FA8 )->onDisconnected( *0000000DAE4FDD80 = 000001BD2946B830 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29180FA8 )->onRemoveDebugState( 0000000DAE4FDD80 )
0x00003B78 49961 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29180FA8 )->onRemoveDebugState( *0000000DAE4FDD80 = 000001BD2A324FB0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29180FA8 )->onRestoreDebugState( 0000000DAE4FDD80 )
0x00003B78 49961 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29180FA8 )->onRestoreDebugState( *0000000DAE4FDD80 = 000001BD2A324860 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29180FA8 )->onWaitingToConnect( 0000000DAE4FDD80 )
0x00003B78 49961 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29180FA8 )->onWaitingToConnect( *0000000DAE4FDD80 = 000001BD2A324F20 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsISimpleEvent*)000001BD2A323540 )->addListener( 000001BD3CDC00E0 )
0x00003B78 49961 3  XPCOM R: ( (dsISimpleEvent*)000001BD2A323540 )->addListener( 000001BD3CDC00E0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsISimpleEvent*)000001BD2946B0E0 )->addListener( 000001BD3CDBFD20 )
0x00003B78 49961 3  XPCOM R: ( (dsISimpleEvent*)000001BD2946B0E0 )->addListener( 000001BD3CDBFD20 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsISimpleEvent*)000001BD2946B830 )->addListener( 000001BD3CDBFAC0 )
0x00003B78 49961 3  XPCOM R: ( (dsISimpleEvent*)000001BD2946B830 )->addListener( 000001BD3CDBFAC0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBooleanEvent*)000001BD2A324E00 )->addListener( 000001BD3CDC0080 )
0x00003B78 49961 3  XPCOM R: ( (dsIBooleanEvent*)000001BD2A324E00 )->addListener( 000001BD3CDC0080 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsISimpleEvent*)000001BD2A324F20 )->addListener( 000001BD3CDC0140 )
0x00003B78 49961 3  XPCOM R: ( (dsISimpleEvent*)000001BD2A324F20 )->addListener( 000001BD3CDC0140 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBooleanEvent*)000001BD2A323FF0 )->addListener( 000001BD3CDC0160 )
0x00003B78 49961 3  XPCOM R: ( (dsIBooleanEvent*)000001BD2A323FF0 )->addListener( 000001BD3CDC0160 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsINumberEvent*)000001BD2946B4D0 )->addListener( 000001BD3CDBFCC0 )
0x00003B78 49961 3  XPCOM R: ( (dsINumberEvent*)000001BD2946B4D0 )->addListener( 000001BD3CDBFCC0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsISimpleEvent*)000001BD2A3251F0 )->addListener( 000001BD3CDC00C0 )
0x00003B78 49961 3  XPCOM R: ( (dsISimpleEvent*)000001BD2A3251F0 )->addListener( 000001BD3CDC00C0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4090 )->getProcessorInfo( 0000000DAE4FE000, 0000000DAE4FE018, 0000000DAE4FE030, 0000000DAE4FE048, 0000000DAE4FE060, 0000000DAE4FE078 )
0x00003B78 49961 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4090 )->getProcessorInfo( *0000000DAE4FE000 = 0x000000F0, *0000000DAE4FE018 = 0x00000002, *0000000DAE4FE030 = 0x00000000, *0000000DAE4FE048 = 0x00000005, *0000000DAE4FE060 = 0x3C000805, *0000000DAE4FE078 = false ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4090 )->getProcessorInfo( 0000000DAE4FE010, 0000000DAE4FE028, 0000000DAE4FE040, 0000000DAE4FE058, 0000000DAE4FE070, 0000000DAE4FE088 )
0x00003B78 49961 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4090 )->getProcessorInfo( *0000000DAE4FE010 = 0x000000F0, *0000000DAE4FE028 = 0x00000002, *0000000DAE4FE040 = 0x00000000, *0000000DAE4FE058 = 0x00000005, *0000000DAE4FE070 = 0x3C000805, *0000000DAE4FE088 = false ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIObjectEvent*)000001BD2A322FA0 )->addListener( 000001BD3CDBF9E0 )
0x00003B78 49961 3  XPCOM R: ( (dsIObjectEvent*)000001BD2A322FA0 )->addListener( 000001BD3CDBF9E0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIObjectEvent*)000001BD2A323AE0 )->addListener( 000001BD3CDBFE60 )
0x00003B78 49961 3  XPCOM R: ( (dsIObjectEvent*)000001BD2A323AE0 )->addListener( 000001BD3CDBFE60 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIStringEvent*)000001BD2A323A50 )->addListener( 000001BD3CDBFA20 )
0x00003B78 49961 3  XPCOM R: ( (dsIStringEvent*)000001BD2A323A50 )->addListener( 000001BD3CDBFA20 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIStringEvent*)000001BD2A3230C0 )->addListener( 000001BD3CDBFDE0 )
0x00003B78 49961 3  XPCOM R: ( (dsIStringEvent*)000001BD2A3230C0 )->addListener( 000001BD3CDBFDE0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIStringEvent*)000001BD2A323300 )->addListener( 000001BD3CDBFD40 )
0x00003B78 49961 3  XPCOM R: ( (dsIStringEvent*)000001BD2A323300 )->addListener( 000001BD3CDBFD40 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIStringEvent*)000001BD2A324E90 )->addListener( 000001BD3CDBFF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIStringEvent*)000001BD2A324E90 )->addListener( 000001BD3CDBFF00 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4070 )->PathName( 0000000DAE4FE120 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4070 )->PathName( *0000000DAE4FE120 = Texas Instruments XDS110 USB Debug Probe/IcePick_C ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4070 )->TargetType( 0000000DAE4FE090 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4070 )->TargetType( *0000000DAE4FE090 = ICEPick_C ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugProperties( Texas Instruments XDS110 USB Debug Probe/IcePick_C, ICEPick_C, 0000000DAE4FE0A0 )
0x00003B78 49961 3  XPCOM R: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugProperties( Texas Instruments XDS110 USB Debug Probe/IcePick_C, ICEPick_C, *0000000DAE4FE0A0 = 000001BD2C543570 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDebugProperties*)000001BD2C543570 )->queryInterface( 000001BD3CDBFAE0, 0000000DAE4FE018 )
0x00003B78 49961 3  XPCOM R: ( (dsIDebugProperties*)000001BD2C543570 )->queryInterface( 000001BD3CDBFAE0, *0000000DAE4FE018 = 000001BD2C543578 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2C543578 )->onDisableStatusChanged( 0000000DAE4FDFF0 )
0x00003B78 49961 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2C543578 )->onDisableStatusChanged( *0000000DAE4FDFF0 = 000001BD289B4D70 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2C543578 )->onPropertyValueChanged( 0000000DAE4FDFF0 )
0x00003B78 49961 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2C543578 )->onPropertyValueChanged( *0000000DAE4FDFF0 = 000001BD289B3ED0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIGetFlashProgrammerManager*)000001BD297E40C8 )->getFlashProgrammerManager( 0000000DAE4FE070 )
0x00003B78 49961 3  XPCOM R: ( (dsIGetFlashProgrammerManager*)000001BD297E40C8 )->getFlashProgrammerManager( *0000000DAE4FE070 = 000001BD3DBD6510 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITargetCollection*)000001BD3DBD5F60 )->item( 0x00000001, 0000000DAE4FEB68 )
0x00003B78 49961 3  XPCOM R: ( (dsITargetCollection*)000001BD3DBD5F60 )->item( 0x00000001, *0000000DAE4FEB68 = 000001BD297E4170 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFA80, 0000000DAE4FEAF8 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFA80, *0000000DAE4FEAF8 = 000001BD297E4190 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFE80, 0000000DAE4FEAF8 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFE80, *0000000DAE4FEAF8 = 000001BD297E4178 ) = 0x00000000
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFA80, *0000000DAE4FEAF8 = 000001BD297E4188 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFE00, 0000000DAE4FEAF8 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFE00, *0000000DAE4FEAF8 = 000001BD297E41A8 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFF40, 0000000DAE4FEAF8 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFF40, *0000000DAE4FEAF8 = 000001BD297E4180 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFFA0, 0000000DAE4FEAF8 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFFA0, *0000000DAE4FEAF8 = 000001BD297E41A0 ) = 0x00000000
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFA80, *0000000DAE4FEAF8 = 000001BD297E41B0 ) = 0x00000000
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFA80, *0000000DAE4FEAF8 = 000001BD297E41B8 ) = 0x00000000
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFA80, *0000000DAE4FEAF8 = 000001BD297E41C0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFEC0, 0000000DAE4FEAF8 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFEC0, *0000000DAE4FEAF8 = 000001BD297E41C8 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFB40, 0000000DAE4FEAF8 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFB40, *0000000DAE4FEAF8 = 000001BD297E41D0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDC0020, 0000000DAE4FEAF8 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDC0020, *0000000DAE4FEAF8 = 000001BD297E41D8 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFF60, 0000000DAE4FEAF8 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFF60, *0000000DAE4FEAF8 = 000001BD297E4198 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFB20, 0000000DAE4FEAE8 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDBFB20, *0000000DAE4FEAE8 = 000001BD297E4190 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4190 )->getProcessorInfo( 0000000DAE4FE870, 0000000DAE4FE888, 0000000DAE4FE8A0, 0000000DAE4FE8B8, 0000000DAE4FE8D0, 0000000DAE4FE8E8 )
0x00003B78 49961 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4190 )->getProcessorInfo( *0000000DAE4FE870 = 0x000000E0, *0000000DAE4FE888 = 0x00000001, *0000000DAE4FE8A0 = 0x00000000, *0000000DAE4FE8B8 = 0x00000005, *0000000DAE4FE8D0 = 0x38000405, *0000000DAE4FE8E8 = false ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4190 )->getDriverProperties( 0000000DAE4FE940, 0000000DAE4FE958, 0000000DAE4FE970 )
0x00003B78 49961 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4190 )->getDriverProperties( *0000000DAE4FE940 = 0x00000007, *0000000DAE4FE958 = 000001BD29525530, *0000000DAE4FE970 = 000001BD29526130 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4190 )->getProcessorInfo( 0000000DAE4FE860, 0000000DAE4FE878, 0000000DAE4FE890, 0000000DAE4FE8A8, 0000000DAE4FE8C0, 0000000DAE4FE8D8 )
0x00003B78 49961 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4190 )->getProcessorInfo( *0000000DAE4FE860 = 0x000000E0, *0000000DAE4FE878 = 0x00000001, *0000000DAE4FE890 = 0x00000000, *0000000DAE4FE8A8 = 0x00000005, *0000000DAE4FE8C0 = 0x38000405, *0000000DAE4FE8D8 = false ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4190 )->getProcessorInfo( 0000000DAE4FE8E0, 0000000DAE4FE8F8, 0000000DAE4FE910, 0000000DAE4FE928, 0000000DAE4FE940, 0000000DAE4FE958 )
0x00003B78 49961 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4190 )->getProcessorInfo( *0000000DAE4FE8E0 = 0x000000E0, *0000000DAE4FE8F8 = 0x00000001, *0000000DAE4FE910 = 0x00000000, *0000000DAE4FE928 = 0x00000005, *0000000DAE4FE940 = 0x38000405, *0000000DAE4FE958 = false ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4170 )->Name( 0000000DAE4FE120 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4170 )->Name( *0000000DAE4FE120 = CS_DAP_0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4190 )->Partnum( 0000000DAE4FE120 )
0x00003B78 49961 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4190 )->Partnum( *0000000DAE4FE120 = CC2642R1F ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIGetRegisterServer*)000001BD297E4180 )->getRegisterServer( 0000000DAE4FDFF0 )
0x00003B78 49961 3  XPCOM R: ( (dsIGetRegisterServer*)000001BD297E4180 )->getRegisterServer( *0000000DAE4FDFF0 = 000001BD2F219A00 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIGetBreakpointManager*)000001BD297E4188 )->getBreakpointManager( 0000000DAE4FDFE0 )
0x00003B78 49961 3  XPCOM R: ( (dsIGetBreakpointManager*)000001BD297E4188 )->getBreakpointManager( *0000000DAE4FDFE0 = 000001BD297E5D70 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManager*)000001BD297E5D70 )->queryInterface( 000001BD3CDBFE20, 0000000DAE4FDF88 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManager*)000001BD297E5D70 )->queryInterface( 000001BD3CDBFE20, *0000000DAE4FDF88 = 000001BD297E5D78 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onActionListenerAdded( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onActionListenerAdded( *0000000DAE4FDF00 = 000001BD2A324080 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onActionListenerRemoved( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onActionListenerRemoved( *0000000DAE4FDF00 = 000001BD2A324AA0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onBatchUpdateFinished( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onBatchUpdateFinished( *0000000DAE4FDF00 = 000001BD2A324110 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onBatchUpdateStarted( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onBatchUpdateStarted( *0000000DAE4FDF00 = 000001BD2A322F10 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onBreakpointAdded( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onBreakpointAdded( *0000000DAE4FDF00 = 000001BD2A324590 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onBreakpointRemoved( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onBreakpointRemoved( *0000000DAE4FDF00 = 000001BD2A323DB0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onBreakpointDisabled( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onBreakpointDisabled( *0000000DAE4FDF00 = 000001BD2A323660 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onBreakpointEnabled( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onBreakpointEnabled( *0000000DAE4FDF00 = 000001BD2A3250D0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onBreakpointHit( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onBreakpointHit( *0000000DAE4FDF00 = 000001BD2A325160 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onGroupCreated( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onGroupCreated( *0000000DAE4FDF00 = 000001BD2A323C00 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onGroupDeleted( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onGroupDeleted( *0000000DAE4FDF00 = 000001BD2A324BC0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onSourceFileResolve( 0000000DAE4FDF00 )
0x00003B78 49961 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onSourceFileResolve( *0000000DAE4FDF00 = 000001BD2A3238A0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIGetDspUser*)000001BD297E4178 )->createUser( 0000000DAE4FDF60 )
0x00003B78 49961 3  XPCOM R: ( (dsIGetDspUser*)000001BD297E4178 )->createUser( *0000000DAE4FDF60 = 000001BD291813E0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC02A0, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC02A0, *0000000DAE4FDF68 = 000001BD29181438 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC07C0, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC07C0, *0000000DAE4FDF68 = 000001BD291813F0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC0520, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC0520, *0000000DAE4FDF68 = 000001BD291813F8 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC01E0, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC01E0, *0000000DAE4FDF68 = 000001BD29181430 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC05E0, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC05E0, *0000000DAE4FDF68 = 000001BD291813E8 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC03C0, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC03C0, *0000000DAE4FDF68 = 000001BD29181410 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC0240, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC0240, *0000000DAE4FDF68 = 000001BD29181400 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC06E0, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC06E0, *0000000DAE4FDF68 = 000001BD29181440 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC0860, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC0860, *0000000DAE4FDF68 = 000001BD29181420 ) = 0x00000000
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC0520, *0000000DAE4FDF68 = 000001BD29181450 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC02C0, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC02C0, *0000000DAE4FDF68 = 000001BD29181448 ) = 0x00000000
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC0860, *0000000DAE4FDF68 = 000001BD29181418 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC0960, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC0960, *0000000DAE4FDF68 = 000001BD29181458 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC07E0, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC07E0, *0000000DAE4FDF68 = 000001BD29181468 ) = 0x00000000
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC05E0, *0000000DAE4FDF68 = 000001BD29181478 ) = 0x00000000
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC0520, *0000000DAE4FDF68 = 000001BD291814A0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC02E0, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC02E0, *0000000DAE4FDF68 = 000001BD29181490 ) = 0x00000000
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC02E0, *0000000DAE4FDF68 = 000001BD29181480 ) = 0x00000000
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC0960, *0000000DAE4FDF68 = 000001BD29181488 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC0720, 0000000DAE4FDF68 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC0720, *0000000DAE4FDF68 = 000001BD29181498 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29181418 )->onHalt( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29181418 )->onHalt( *0000000DAE4FDF40 = 000001BD2A3242C0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29181418 )->onRunning( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29181418 )->onRunning( *0000000DAE4FDF40 = 000001BD2A3236F0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29181418 )->onTargetHaltDetected( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29181418 )->onTargetHaltDetected( *0000000DAE4FDF40 = 000001BD2A323780 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29181418 )->onRestart( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29181418 )->onRestart( *0000000DAE4FDF40 = 000001BD2A324A10 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29181418 )->onAlreadyRunning( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29181418 )->onAlreadyRunning( *0000000DAE4FDF40 = 000001BD2A324CE0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29181418 )->onPowerStatusChanged( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29181418 )->onPowerStatusChanged( *0000000DAE4FDF40 = 000001BD2A323810 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29181418 )->onSecureStatusChanged( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29181418 )->onSecureStatusChanged( *0000000DAE4FDF40 = 000001BD2A323150 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRunControlEvents*)000001BD29181418 )->onExecutionStatusChanged( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRunControlEvents*)000001BD29181418 )->onExecutionStatusChanged( *0000000DAE4FDF40 = 000001BD2A3231E0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIResetControlEvents*)000001BD29181420 )->onEmulatorReset( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIResetControlEvents*)000001BD29181420 )->onEmulatorReset( *0000000DAE4FDF40 = 000001BD2A323C90 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIResetControlEvents*)000001BD29181420 )->onHaltOnResetChanged( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIResetControlEvents*)000001BD29181420 )->onHaltOnResetChanged( *0000000DAE4FDF40 = 000001BD2A323930 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIResetControlEvents*)000001BD29181420 )->onHeldInReset( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIResetControlEvents*)000001BD29181420 )->onHeldInReset( *0000000DAE4FDF40 = 000001BD2A324470 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIResetControlEvents*)000001BD29181420 )->onReset( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIResetControlEvents*)000001BD29181420 )->onReset( *0000000DAE4FDF40 = 000001BD2A323270 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProgramLoaderEvents*)000001BD29181448 )->onStartFileLoad( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIProgramLoaderEvents*)000001BD29181448 )->onStartFileLoad( *0000000DAE4FDF40 = 000001BD2A3267E0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProgramLoaderEvents*)000001BD29181448 )->onPriorityFileLoaded( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIProgramLoaderEvents*)000001BD29181448 )->onPriorityFileLoaded( *0000000DAE4FDF40 = 000001BD2A326C60 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProgramLoaderEvents*)000001BD29181448 )->onFileLoaded( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIProgramLoaderEvents*)000001BD29181448 )->onFileLoaded( *0000000DAE4FDF40 = 000001BD2A326870 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsISymbolManagerEvents*)000001BD29181440 )->onNewSymbols( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsISymbolManagerEvents*)000001BD29181440 )->onNewSymbols( *0000000DAE4FDF40 = 000001BD2A325550 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsISymbolManagerEvents*)000001BD29181440 )->onNewSymbolsOffline( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsISymbolManagerEvents*)000001BD29181440 )->onNewSymbolsOffline( *0000000DAE4FDF40 = 000001BD2A3254C0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIMemoryMap*)000001BD29181430 )->onMemoryMapUpdate( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIMemoryMap*)000001BD29181430 )->onMemoryMapUpdate( *0000000DAE4FDF40 = 000001BD2A325430 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITargetIO*)000001BD29181450 )->onStdErr( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsITargetIO*)000001BD29181450 )->onStdErr( *0000000DAE4FDF40 = 000001BD2A325AF0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITargetIO*)000001BD29181450 )->onStdOut( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsITargetIO*)000001BD29181450 )->onStdOut( *0000000DAE4FDF40 = 000001BD2A326B40 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITargetIO*)000001BD29181450 )->onStdIn( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsITargetIO*)000001BD29181450 )->onStdIn( *0000000DAE4FDF40 = 000001BD2A325940 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIGELTextOutEvent*)000001BD29181458 )->onGELTextOut( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIGELTextOutEvent*)000001BD29181458 )->onGELTextOut( *0000000DAE4FDF40 = 000001BD2A3263F0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIErrorOutput*)000001BD29181468 )->onFatal( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIErrorOutput*)000001BD29181468 )->onFatal( *0000000DAE4FDF40 = 000001BD2A326510 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIErrorOutput*)000001BD29181468 )->onError( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIErrorOutput*)000001BD29181468 )->onError( *0000000DAE4FDF40 = 000001BD2A3259D0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIErrorOutput*)000001BD29181468 )->onWarning( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIErrorOutput*)000001BD29181468 )->onWarning( *0000000DAE4FDF40 = 000001BD2A325790 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIErrorOutput*)000001BD29181468 )->onInfo( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIErrorOutput*)000001BD29181468 )->onInfo( *0000000DAE4FDF40 = 000001BD2A326CF0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRefreshControl*)000001BD29181478 )->onAllowedUserAccessesChanged( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRefreshControl*)000001BD29181478 )->onAllowedUserAccessesChanged( *0000000DAE4FDF40 = 000001BD2A3265A0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRefreshEvents*)000001BD291814A0 )->onRefresh( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIRefreshEvents*)000001BD291814A0 )->onRefresh( *0000000DAE4FDF40 = 000001BD2A324C50 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITargetProperties*)000001BD29181480 )->onPropertyGet( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsITargetProperties*)000001BD29181480 )->onPropertyGet( *0000000DAE4FDF40 = 000001BD2A326630 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITargetProperties*)000001BD29181480 )->onPropertySet( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsITargetProperties*)000001BD29181480 )->onPropertySet( *0000000DAE4FDF40 = 000001BD2A325E50 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIControlPointControl*)000001BD29181490 )->onControlPointHit( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIControlPointControl*)000001BD29181490 )->onControlPointHit( *0000000DAE4FDF40 = 000001BD2A326BD0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIGelFileListEvents*)000001BD29181498 )->onGelFileListChanged( 0000000DAE4FDF40 )
0x00003B78 49961 3  XPCOM R: ( (dsIGelFileListEvents*)000001BD29181498 )->onGelFileListChanged( *0000000DAE4FDF40 = 000001BD2A325700 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsISimpleEvent*)000001BD2A3231E0 )->addListener( 000001BD3CDC03A0 )
0x00003B78 49961 3  XPCOM R: ( (dsISimpleEvent*)000001BD2A3231E0 )->addListener( 000001BD3CDC03A0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC03C0, 0000000DAE4FDE08 )
0x00003B78 49961 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC03C0, *0000000DAE4FDE08 = 000001BD29181408 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIConnectDisconnect*)000001BD29181408 )->queryInterface( 000001BD3CDC03C0, 0000000DAE4FDDA8 )
0x00003B78 49961 3  XPCOM R: ( (dsIConnectDisconnect*)000001BD29181408 )->queryInterface( 000001BD3CDC03C0, *0000000DAE4FDDA8 = 000001BD29181428 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29181428 )->onConnectFailed( 0000000DAE4FDD80 )
0x00003B78 49961 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29181428 )->onConnectFailed( *0000000DAE4FDD80 = 000001BD2A3255E0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29181428 )->onConnected( 0000000DAE4FDD80 )
0x00003B78 49961 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29181428 )->onConnected( *0000000DAE4FDD80 = 000001BD2A3243E0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29181428 )->onDisconnecting( 0000000DAE4FDD80 )
0x00003B78 49961 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29181428 )->onDisconnecting( *0000000DAE4FDD80 = 000001BD2A326240 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29181428 )->onDisconnected( 0000000DAE4FDD80 )
0x00003B78 49961 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29181428 )->onDisconnected( *0000000DAE4FDD80 = 000001BD2A3246B0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29181428 )->onRemoveDebugState( 0000000DAE4FDD80 )
0x00003B78 49961 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29181428 )->onRemoveDebugState( *0000000DAE4FDD80 = 000001BD2A326990 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29181428 )->onRestoreDebugState( 0000000DAE4FDD80 )
0x00003B78 49961 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29181428 )->onRestoreDebugState( *0000000DAE4FDD80 = 000001BD2A325310 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIConnectDisconnectEvents*)000001BD29181428 )->onWaitingToConnect( 0000000DAE4FDD80 )
0x00003B78 49961 3  XPCOM R: ( (dsIConnectDisconnectEvents*)000001BD29181428 )->onWaitingToConnect( *0000000DAE4FDD80 = 000001BD2A325EE0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsISimpleEvent*)000001BD2A3255E0 )->addListener( 000001BD3CDC0B40 )
0x00003B78 49961 3  XPCOM R: ( (dsISimpleEvent*)000001BD2A3255E0 )->addListener( 000001BD3CDC0B40 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsISimpleEvent*)000001BD2A3243E0 )->addListener( 000001BD3CDC0E40 )
0x00003B78 49961 3  XPCOM R: ( (dsISimpleEvent*)000001BD2A3243E0 )->addListener( 000001BD3CDC0E40 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsISimpleEvent*)000001BD2A3246B0 )->addListener( 000001BD3CDC0DC0 )
0x00003B78 49961 3  XPCOM R: ( (dsISimpleEvent*)000001BD2A3246B0 )->addListener( 000001BD3CDC0DC0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBooleanEvent*)000001BD2A326240 )->addListener( 000001BD3CDC10E0 )
0x00003B78 49961 3  XPCOM R: ( (dsIBooleanEvent*)000001BD2A326240 )->addListener( 000001BD3CDC10E0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsISimpleEvent*)000001BD2A325EE0 )->addListener( 000001BD3CDC09E0 )
0x00003B78 49961 3  XPCOM R: ( (dsISimpleEvent*)000001BD2A325EE0 )->addListener( 000001BD3CDC09E0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIBooleanEvent*)000001BD2A325550 )->addListener( 000001BD3CDC1020 )
0x00003B78 49961 3  XPCOM R: ( (dsIBooleanEvent*)000001BD2A325550 )->addListener( 000001BD3CDC1020 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsINumberEvent*)000001BD2A324C50 )->addListener( 000001BD3CDC0AE0 )
0x00003B78 49961 3  XPCOM R: ( (dsINumberEvent*)000001BD2A324C50 )->addListener( 000001BD3CDC0AE0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsISimpleEvent*)000001BD2A3265A0 )->addListener( 000001BD3CDC0EC0 )
0x00003B78 49961 3  XPCOM R: ( (dsISimpleEvent*)000001BD2A3265A0 )->addListener( 000001BD3CDC0EC0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4190 )->getProcessorInfo( 0000000DAE4FE000, 0000000DAE4FE018, 0000000DAE4FE030, 0000000DAE4FE048, 0000000DAE4FE060, 0000000DAE4FE078 )
0x00003B78 49961 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4190 )->getProcessorInfo( *0000000DAE4FE000 = 0x000000E0, *0000000DAE4FE018 = 0x00000001, *0000000DAE4FE030 = 0x00000000, *0000000DAE4FE048 = 0x00000005, *0000000DAE4FE060 = 0x38000405, *0000000DAE4FE078 = false ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIProcessorInfo*)000001BD297E4190 )->getProcessorInfo( 0000000DAE4FE010, 0000000DAE4FE028, 0000000DAE4FE040, 0000000DAE4FE058, 0000000DAE4FE070, 0000000DAE4FE088 )
0x00003B78 49961 3  XPCOM R: ( (dsIProcessorInfo*)000001BD297E4190 )->getProcessorInfo( *0000000DAE4FE010 = 0x000000E0, *0000000DAE4FE028 = 0x00000001, *0000000DAE4FE040 = 0x00000000, *0000000DAE4FE058 = 0x00000005, *0000000DAE4FE070 = 0x38000405, *0000000DAE4FE088 = false ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIObjectEvent*)000001BD2A326B40 )->addListener( 000001BD3CDC0E80 )
0x00003B78 49961 3  XPCOM R: ( (dsIObjectEvent*)000001BD2A326B40 )->addListener( 000001BD3CDC0E80 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIObjectEvent*)000001BD2A325AF0 )->addListener( 000001BD3CDC1040 )
0x00003B78 49961 3  XPCOM R: ( (dsIObjectEvent*)000001BD2A325AF0 )->addListener( 000001BD3CDC1040 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIStringEvent*)000001BD2A326510 )->addListener( 000001BD3CDC0A80 )
0x00003B78 49961 3  XPCOM R: ( (dsIStringEvent*)000001BD2A326510 )->addListener( 000001BD3CDC0A80 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIStringEvent*)000001BD2A3259D0 )->addListener( 000001BD3CDC0F00 )
0x00003B78 49961 3  XPCOM R: ( (dsIStringEvent*)000001BD2A3259D0 )->addListener( 000001BD3CDC0F00 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIStringEvent*)000001BD2A325790 )->addListener( 000001BD3CDC0EE0 )
0x00003B78 49961 3  XPCOM R: ( (dsIStringEvent*)000001BD2A325790 )->addListener( 000001BD3CDC0EE0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIStringEvent*)000001BD2A326CF0 )->addListener( 000001BD3CDC0B80 )
0x00003B78 49961 3  XPCOM R: ( (dsIStringEvent*)000001BD2A326CF0 )->addListener( 000001BD3CDC0B80 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4170 )->PathName( 0000000DAE4FE120 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4170 )->PathName( *0000000DAE4FE120 = Texas Instruments XDS110 USB Debug Probe/CS_DAP_0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4170 )->TargetType( 0000000DAE4FE090 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4170 )->TargetType( *0000000DAE4FE090 = CS_DAP_0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugProperties( Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, CS_DAP_0, 0000000DAE4FE0A0 )
0x00003B78 49961 3  XPCOM R: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugProperties( Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, CS_DAP_0, *0000000DAE4FE0A0 = 000001BD2E414D40 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E414D40 )->queryInterface( 000001BD3CDC0CC0, 0000000DAE4FE018 )
0x00003B78 49961 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E414D40 )->queryInterface( 000001BD3CDC0CC0, *0000000DAE4FE018 = 000001BD2E414D48 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2E414D48 )->onDisableStatusChanged( 0000000DAE4FDFF0 )
0x00003B78 49961 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2E414D48 )->onDisableStatusChanged( *0000000DAE4FDFF0 = 000001BD2CC67260 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2E414D48 )->onPropertyValueChanged( 0000000DAE4FDFF0 )
0x00003B78 49961 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2E414D48 )->onPropertyValueChanged( *0000000DAE4FDFF0 = 000001BD2CC67BF0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIGetFlashProgrammerManager*)000001BD297E41C8 )->getFlashProgrammerManager( 0000000DAE4FE070 )
0x00003B78 49961 3  XPCOM R: ( (dsIGetFlashProgrammerManager*)000001BD297E41C8 )->getFlashProgrammerManager( *0000000DAE4FE070 = 000001BD3DBD6660 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4070 )->Identifier( 0000000DAE4FEAC0 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4070 )->Identifier( *0000000DAE4FEAC0 = 0x000001BD3508A1B0 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsITarget*)000001BD297E4170 )->Identifier( 0000000DAE4FEAC0 )
0x00003B78 49961 3  XPCOM R: ( (dsITarget*)000001BD297E4170 )->Identifier( *0000000DAE4FEAC0 = 0x000001BD35082560 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIRunControl*)000001BD29180F90 )->CapableExecutionControl( 0000000DAE4FEAD0 )
0x00003B78 49961 3  XPCOM R: ( (dsIRunControl*)000001BD29180F90 )->CapableExecutionControl( *0000000DAE4FEAD0 = false ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIConnectDisconnect*)000001BD29180F88 )->connectionStatus( 0000000DAE4FE840 )
0x00003B78 49961 3  XPCOM R: ( (dsIConnectDisconnect*)000001BD29180F88 )->connectionStatus( *0000000DAE4FE840 = 0x00000002 ) = 0x00000000
0x00003B78 49961 3  XPCOM C: ( (dsIObjectEvent*)000001BD2A324D70 )->addListener( 000001BD3CDC28A0 )
0x00003B78 49961 3  XPCOM R: ( (dsIObjectEvent*)000001BD2A324D70 )->addListener( 000001BD3CDC28A0 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsISymbolAccess*)000001BD297E40D8 )->SymbolManager( 0000000DAE4FE910 )
0x00003B78 49977 3  XPCOM R: ( (dsISymbolAccess*)000001BD297E40D8 )->SymbolManager( *0000000DAE4FE910 = 000001BD3DBD8810 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDC29C0, 0000000DAE4FE918 )
0x00003B78 49977 3  XPCOM R: ( (dsITarget*)000001BD297E4070 )->queryInterface( 000001BD3CDC29C0, *0000000DAE4FE918 = 000001BD297E40E0 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDC2540, 0000000DAE4FE898 )
0x00003B78 49977 3  XPCOM R: ( (dsIDspUser*)000001BD29180F60 )->queryInterface( 000001BD3CDC2540, *0000000DAE4FE898 = 000001BD29180F70 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsISymbolManager*)000001BD3DBD8810 )->SymbolPackage( 0000000DAE4FE910 )
0x00003B78 49977 3  XPCOM R: ( (dsISymbolManager*)000001BD3DBD8810 )->SymbolPackage( *0000000DAE4FE910 = 000001BD2A325DC0 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsISymbolPackage*)000001BD2A325DC0 )->NumSymbolFiles( 0000000DAE4FE920 )
0x00003B78 49977 3  XPCOM R: ( (dsISymbolPackage*)000001BD2A325DC0 )->NumSymbolFiles( *0000000DAE4FE920 = 0x00000000 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIObjectEvent*)000001BD2A323030 )->addListener( 000001BD3CDC3D80 )
0x00003B78 49977 3  XPCOM R: ( (dsIObjectEvent*)000001BD2A323030 )->addListener( 000001BD3CDC3D80 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIObjectEvent*)000001BD2946A090 )->addListener( 000001BD3CDC47C0 )
0x00003B78 49977 3  XPCOM R: ( (dsIObjectEvent*)000001BD2946A090 )->addListener( 000001BD3CDC47C0 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIObjectEvent*)000001BD2946BCB0 )->addListener( 000001BD3CDC4980 )
0x00003B78 49977 3  XPCOM R: ( (dsIObjectEvent*)000001BD2946BCB0 )->addListener( 000001BD3CDC4980 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIObjectEvent*)000001BD2946A120 )->addListener( 000001BD3CDC4740 )
0x00003B78 49977 3  XPCOM R: ( (dsIObjectEvent*)000001BD2946A120 )->addListener( 000001BD3CDC4740 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIObjectEvent*)000001BD2946AEA0 )->addListener( 000001BD3CDC4440 )
0x00003B78 49977 3  XPCOM R: ( (dsIObjectEvent*)000001BD2946AEA0 )->addListener( 000001BD3CDC4440 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onBeginBreakpointModify( 0000000DAE4FE940 )
0x00003B78 49977 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onBeginBreakpointModify( *0000000DAE4FE940 = 000001BD2946AD80 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsISimpleEvent*)000001BD2946AD80 )->addListener( 000001BD3CDC43E0 )
0x00003B78 49977 3  XPCOM R: ( (dsISimpleEvent*)000001BD2946AD80 )->addListener( 000001BD3CDC43E0 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onBreakpointModified( 0000000DAE4FE940 )
0x00003B78 49977 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E3F78 )->onBreakpointModified( *0000000DAE4FE940 = 000001BD2946AF30 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIObjectEvent*)000001BD2946AF30 )->addListener( 000001BD3CDC4860 )
0x00003B78 49977 3  XPCOM R: ( (dsIObjectEvent*)000001BD2946AF30 )->addListener( 000001BD3CDC4860 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsISimpleEvent*)000001BD29469940 )->addListener( 000001BD3CDC4820 )
0x00003B78 49977 3  XPCOM R: ( (dsISimpleEvent*)000001BD29469940 )->addListener( 000001BD3CDC4820 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIObjectEvent*)000001BD2946AE10 )->addListener( 000001BD3CDC4D80 )
0x00003B78 49977 3  XPCOM R: ( (dsIObjectEvent*)000001BD2946AE10 )->addListener( 000001BD3CDC4D80 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIObjectEvent*)000001BD2946AAB0 )->addListener( 000001BD3CDC4A80 )
0x00003B78 49977 3  XPCOM R: ( (dsIObjectEvent*)000001BD2946AAB0 )->addListener( 000001BD3CDC4A80 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIObjectEvent*)000001BD2946B9E0 )->addListener( 000001BD3CDC5060 )
0x00003B78 49977 3  XPCOM R: ( (dsIObjectEvent*)000001BD2946B9E0 )->addListener( 000001BD3CDC5060 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIRunControl*)000001BD29181410 )->CapableExecutionControl( 0000000DAE4FEAD0 )
0x00003B78 49977 3  XPCOM R: ( (dsIRunControl*)000001BD29181410 )->CapableExecutionControl( *0000000DAE4FEAD0 = false ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIConnectDisconnect*)000001BD29181408 )->connectionStatus( 0000000DAE4FE840 )
0x00003B78 49977 3  XPCOM R: ( (dsIConnectDisconnect*)000001BD29181408 )->connectionStatus( *0000000DAE4FE840 = 0x00000002 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIObjectEvent*)000001BD2A326870 )->addListener( 000001BD3CDC4AC0 )
0x00003B78 49977 3  XPCOM R: ( (dsIObjectEvent*)000001BD2A326870 )->addListener( 000001BD3CDC4AC0 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsISymbolAccess*)000001BD297E41D8 )->SymbolManager( 0000000DAE4FE910 )
0x00003B78 49977 3  XPCOM R: ( (dsISymbolAccess*)000001BD297E41D8 )->SymbolManager( *0000000DAE4FE910 = 000001BD3DBD8650 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDC4B20, 0000000DAE4FE918 )
0x00003B78 49977 3  XPCOM R: ( (dsITarget*)000001BD297E4170 )->queryInterface( 000001BD3CDC4B20, *0000000DAE4FE918 = 000001BD297E41E0 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC4D20, 0000000DAE4FE898 )
0x00003B78 49977 3  XPCOM R: ( (dsIDspUser*)000001BD291813E0 )->queryInterface( 000001BD3CDC4D20, *0000000DAE4FE898 = 000001BD291813F0 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsISymbolManager*)000001BD3DBD8650 )->SymbolPackage( 0000000DAE4FE910 )
0x00003B78 49977 3  XPCOM R: ( (dsISymbolManager*)000001BD3DBD8650 )->SymbolPackage( *0000000DAE4FE910 = 000001BD3CDD0390 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsISymbolPackage*)000001BD3CDD0390 )->NumSymbolFiles( 0000000DAE4FE920 )
0x00003B78 49977 3  XPCOM R: ( (dsISymbolPackage*)000001BD3CDD0390 )->NumSymbolFiles( *0000000DAE4FE920 = 0x00000000 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIObjectEvent*)000001BD2A325940 )->addListener( 000001BD3CDC4E60 )
0x00003B78 49977 3  XPCOM R: ( (dsIObjectEvent*)000001BD2A325940 )->addListener( 000001BD3CDC4E60 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIObjectEvent*)000001BD2A324590 )->addListener( 000001BD3CDC4BE0 )
0x00003B78 49977 3  XPCOM R: ( (dsIObjectEvent*)000001BD2A324590 )->addListener( 000001BD3CDC4BE0 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIObjectEvent*)000001BD2A323DB0 )->addListener( 000001BD3CDC4FE0 )
0x00003B78 49977 3  XPCOM R: ( (dsIObjectEvent*)000001BD2A323DB0 )->addListener( 000001BD3CDC4FE0 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIObjectEvent*)000001BD2A3250D0 )->addListener( 000001BD3CDC4B20 )
0x00003B78 49977 3  XPCOM R: ( (dsIObjectEvent*)000001BD2A3250D0 )->addListener( 000001BD3CDC4B20 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIObjectEvent*)000001BD2A323660 )->addListener( 000001BD3CDC4C80 )
0x00003B78 49977 3  XPCOM R: ( (dsIObjectEvent*)000001BD2A323660 )->addListener( 000001BD3CDC4C80 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onBeginBreakpointModify( 0000000DAE4FE940 )
0x00003B78 49977 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onBeginBreakpointModify( *0000000DAE4FE940 = 000001BD2A324620 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsISimpleEvent*)000001BD2A324620 )->addListener( 000001BD3CDC4C00 )
0x00003B78 49977 3  XPCOM R: ( (dsISimpleEvent*)000001BD2A324620 )->addListener( 000001BD3CDC4C00 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onBreakpointModified( 0000000DAE4FE940 )
0x00003B78 49977 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5D78 )->onBreakpointModified( *0000000DAE4FE940 = 000001BD2A324B30 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIObjectEvent*)000001BD2A324B30 )->addListener( 000001BD3CDC5000 )
0x00003B78 49977 3  XPCOM R: ( (dsIObjectEvent*)000001BD2A324B30 )->addListener( 000001BD3CDC5000 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsISimpleEvent*)000001BD2A3236F0 )->addListener( 000001BD3CDC4C20 )
0x00003B78 49977 3  XPCOM R: ( (dsISimpleEvent*)000001BD2A3236F0 )->addListener( 000001BD3CDC4C20 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIObjectEvent*)000001BD2A3242C0 )->addListener( 000001BD3CDC4C40 )
0x00003B78 49977 3  XPCOM R: ( (dsIObjectEvent*)000001BD2A3242C0 )->addListener( 000001BD3CDC4C40 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIObjectEvent*)000001BD2A325160 )->addListener( 000001BD3CDC5140 )
0x00003B78 49977 3  XPCOM R: ( (dsIObjectEvent*)000001BD2A325160 )->addListener( 000001BD3CDC5140 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIObjectEvent*)000001BD2A3238A0 )->addListener( 000001BD3CDC50A0 )
0x00003B78 49977 3  XPCOM R: ( (dsIObjectEvent*)000001BD2A3238A0 )->addListener( 000001BD3CDC50A0 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->Identifier( 0000000DAE4FEAB0 )
0x00003B78 49977 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->Identifier( *0000000DAE4FEAB0 = 0x000001BD35082890 ) = 0x00000000
0x00003B78 49977 3  XPCOM C: ( (dsIRunControl*)000001BD29180E10 )->CapableExecutionControl( 0000000DAE4FEAD0 )
0x00003B78 49977 3  XPCOM R: ( (dsIRunControl*)000001BD29180E10 )->CapableExecutionControl( *0000000DAE4FEAD0 = true ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsISimpleEvent*)000001BD36C331A0 )->addListener( 000001BD3CDC5840 )
0x00003B78 49992 3  XPCOM R: ( (dsISimpleEvent*)000001BD36C331A0 )->addListener( 000001BD3CDC5840 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsISimpleEvent*)000001BD36C32A50 )->addListener( 000001BD3CDC5460 )
0x00003B78 49992 3  XPCOM R: ( (dsISimpleEvent*)000001BD36C32A50 )->addListener( 000001BD3CDC5460 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3CDC5560, 0000000DAE4FE928 )
0x00003B78 49992 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3CDC5560, *0000000DAE4FE928 = 000001BD29180E70 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsIGlobalBreakpoints*)000001BD29180E70 )->onGlobalBreakpointsChanged( 0000000DAE4FE8A0 )
0x00003B78 49992 3  XPCOM R: ( (dsIGlobalBreakpoints*)000001BD29180E70 )->onGlobalBreakpointsChanged( *0000000DAE4FE8A0 = 000001BD29ADC060 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsIBooleanEvent*)000001BD29ADC060 )->addListener( 000001BD3CDC5740 )
0x00003B78 49992 3  XPCOM R: ( (dsIBooleanEvent*)000001BD29ADC060 )->addListener( 000001BD3CDC5740 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsISimpleEvent*)000001BD36C32780 )->addListener( 000001BD3CDC5960 )
0x00003B78 49992 3  XPCOM R: ( (dsISimpleEvent*)000001BD36C32780 )->addListener( 000001BD3CDC5960 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsISimpleEvent*)000001BD36C32DB0 )->addListener( 000001BD3CDC5560 )
0x00003B78 49992 3  XPCOM R: ( (dsISimpleEvent*)000001BD36C32DB0 )->addListener( 000001BD3CDC5560 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsIObjectEvent*)000001BD36C32D20 )->addListener( 000001BD3CDC5980 )
0x00003B78 49992 3  XPCOM R: ( (dsIObjectEvent*)000001BD36C32D20 )->addListener( 000001BD3CDC5980 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsIRunControl*)000001BD29180E10 )->getExecutionState( 0000000DAE4FE840, 0000000DAE4FE858, 0000000DAE4FE870, 0000000DAE4FE888 )
0x00003B78 49992 3  XPCOM R: ( (dsIRunControl*)000001BD29180E10 )->getExecutionState( *0000000DAE4FE840 = true, *0000000DAE4FE858 = false, *0000000DAE4FE870 = 0x00000005, *0000000DAE4FE888 = 0xFFFFFFFF ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsIGlobalBreakpoints*)000001BD29180E70 )->GlobalBreakpoints( 0000000DAE4FE8E0 )
0x00003B78 49992 3  XPCOM R: ( (dsIGlobalBreakpoints*)000001BD29180E70 )->GlobalBreakpoints( *0000000DAE4FE8E0 = false ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsISymbolAccess*)000001BD297E42D8 )->SymbolManager( 0000000DAE4FE910 )
0x00003B78 49992 3  XPCOM R: ( (dsISymbolAccess*)000001BD297E42D8 )->SymbolManager( *0000000DAE4FE910 = 000001BD3DBD7460 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3CDC5D60, 0000000DAE4FE918 )
0x00003B78 49992 3  XPCOM R: ( (dsITarget*)000001BD297E4270 )->queryInterface( 000001BD3CDC5D60, *0000000DAE4FE918 = 000001BD297E42E0 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3CDC6140, 0000000DAE4FE898 )
0x00003B78 49992 3  XPCOM R: ( (dsIDspUser*)000001BD29180DE0 )->queryInterface( 000001BD3CDC6140, *0000000DAE4FE898 = 000001BD29180DF0 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsISymbolManager*)000001BD3DBD7460 )->SymbolPackage( 0000000DAE4FE910 )
0x00003B78 49992 3  XPCOM R: ( (dsISymbolManager*)000001BD3DBD7460 )->SymbolPackage( *0000000DAE4FE910 = 000001BD3CDD0E40 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsISymbolPackage*)000001BD3CDD0E40 )->NumSymbolFiles( 0000000DAE4FE920 )
0x00003B78 49992 3  XPCOM R: ( (dsISymbolPackage*)000001BD3CDD0E40 )->NumSymbolFiles( *0000000DAE4FE920 = 0x00000000 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsIObjectEvent*)000001BD29ADC4E0 )->addListener( 000001BD3CDC5C80 )
0x00003B78 49992 3  XPCOM R: ( (dsIObjectEvent*)000001BD29ADC4E0 )->addListener( 000001BD3CDC5C80 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsIObjectEvent*)000001BD3598BAC0 )->addListener( 000001BD3CDC5EE0 )
0x00003B78 49992 3  XPCOM R: ( (dsIObjectEvent*)000001BD3598BAC0 )->addListener( 000001BD3CDC5EE0 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsIObjectEvent*)000001BD3598B1C0 )->addListener( 000001BD3CDC61A0 )
0x00003B78 49992 3  XPCOM R: ( (dsIObjectEvent*)000001BD3598B1C0 )->addListener( 000001BD3CDC61A0 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsIObjectEvent*)000001BD35074820 )->addListener( 000001BD3CDC5CA0 )
0x00003B78 49992 3  XPCOM R: ( (dsIObjectEvent*)000001BD35074820 )->addListener( 000001BD3CDC5CA0 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsIObjectEvent*)000001BD35074A60 )->addListener( 000001BD3CDC5A60 )
0x00003B78 49992 3  XPCOM R: ( (dsIObjectEvent*)000001BD35074A60 )->addListener( 000001BD3CDC5A60 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onBeginBreakpointModify( 0000000DAE4FE940 )
0x00003B78 49992 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onBeginBreakpointModify( *0000000DAE4FE940 = 000001BD350749D0 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsISimpleEvent*)000001BD350749D0 )->addListener( 000001BD3CDC5D20 )
0x00003B78 49992 3  XPCOM R: ( (dsISimpleEvent*)000001BD350749D0 )->addListener( 000001BD3CDC5D20 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onBreakpointModified( 0000000DAE4FE940 )
0x00003B78 49992 3  XPCOM R: ( (dsIBreakpointManagerEvents*)000001BD297E5878 )->onBreakpointModified( *0000000DAE4FE940 = 000001BD35074940 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsIObjectEvent*)000001BD35074940 )->addListener( 000001BD3CDC5D60 )
0x00003B78 49992 3  XPCOM R: ( (dsIObjectEvent*)000001BD35074940 )->addListener( 000001BD3CDC5D60 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsISimpleEvent*)000001BD35074670 )->addListener( 000001BD3CDC5D80 )
0x00003B78 49992 3  XPCOM R: ( (dsISimpleEvent*)000001BD35074670 )->addListener( 000001BD3CDC5D80 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsIObjectEvent*)000001BD350745E0 )->addListener( 000001BD3CDC6280 )
0x00003B78 49992 3  XPCOM R: ( (dsIObjectEvent*)000001BD350745E0 )->addListener( 000001BD3CDC6280 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsIObjectEvent*)000001BD35074040 )->addListener( 000001BD3CDC6900 )
0x00003B78 49992 3  XPCOM R: ( (dsIObjectEvent*)000001BD35074040 )->addListener( 000001BD3CDC6900 ) = 0x00000000
0x00003B78 49992 3  XPCOM C: ( (dsIObjectEvent*)000001BD350743A0 )->addListener( 000001BD3CDC6800 )
0x00003B78 49992 3  XPCOM R: ( (dsIObjectEvent*)000001BD350743A0 )->addListener( 000001BD3CDC6800 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugProperties( Texas Instruments XDS110 USB Debug Probe/IcePick_C, ICEPICK_C, 0000000DAA8FE520 )
0x00003E54 49992 3  XPCOM R: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugProperties( Texas Instruments XDS110 USB Debug Probe/IcePick_C, ICEPICK_C, *0000000DAA8FE520 = 000001BD2C543570 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIDebugProperties*)000001BD2C543570 )->queryInterface( 000001BD2F10AF30, 0000000DAA8FE498 )
0x00003E54 49992 3  XPCOM R: ( (dsIDebugProperties*)000001BD2C543570 )->queryInterface( 000001BD2F10AF30, *0000000DAA8FE498 = 000001BD2C543578 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2C543578 )->onDisableStatusChanged( 0000000DAA8FE470 )
0x00003E54 49992 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2C543578 )->onDisableStatusChanged( *0000000DAA8FE470 = 000001BD289B4D70 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2C543578 )->onPropertyValueChanged( 0000000DAA8FE470 )
0x00003E54 49992 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2C543578 )->onPropertyValueChanged( *0000000DAA8FE470 = 000001BD289B3ED0 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIDebugProperties*)000001BD2C543570 )->getProperty( ConnectOnStartup, 0000000DAA8FE5A8 )
0x00003E54 49992 3  XPCOM R: ( (dsIDebugProperties*)000001BD2C543570 )->getProperty( ConnectOnStartup, *0000000DAA8FE5A8 = 000001BD35FC6910 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIProperty*)000001BD35FC6910 )->getPropertyType( 0000000DAA8FE540 )
0x00003E54 49992 3  XPCOM R: ( (dsIProperty*)000001BD35FC6910 )->getPropertyType( *0000000DAA8FE540 = 0x00000000 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIProperty*)000001BD35FC6910 )->queryInterface( 000001BD2F101310, 0000000DAA8FE538 )
0x00003E54 49992 3  XPCOM R: ( (dsIProperty*)000001BD35FC6910 )->queryInterface( 000001BD2F101310, *0000000DAA8FE538 = 000001BD35FC69B0 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIBooleanProperty*)000001BD35FC69B0 )->queryInterface( 000001BD2F101310, 0000000DAA8FE4D8 )
0x00003E54 49992 3  XPCOM R: ( (dsIBooleanProperty*)000001BD35FC69B0 )->queryInterface( 000001BD2F101310, *0000000DAA8FE4D8 = 000001BD35FC69B0 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIBooleanProperty*)000001BD35FC69B0 )->CurValue( 0000000DAA8FE5A0 )
0x00003E54 49992 3  XPCOM R: ( (dsIBooleanProperty*)000001BD35FC69B0 )->CurValue( *0000000DAA8FE5A0 = false ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIDebugProperties*)000001BD2C543570 )->getProperty( EnableInstalledBreakpoint, 0000000DAA8FE598 )
0x00003E54 49992 3  XPCOM R: ( (dsIDebugProperties*)000001BD2C543570 )->getProperty( EnableInstalledBreakpoint, *0000000DAA8FE598 = 000001BD35FC60D0 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIProperty*)000001BD35FC60D0 )->getPropertyType( 0000000DAA8FE530 )
0x00003E54 49992 3  XPCOM R: ( (dsIProperty*)000001BD35FC60D0 )->getPropertyType( *0000000DAA8FE530 = 0x00000000 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIProperty*)000001BD35FC60D0 )->queryInterface( 000001BD2F105CF0, 0000000DAA8FE528 )
0x00003E54 49992 3  XPCOM R: ( (dsIProperty*)000001BD35FC60D0 )->queryInterface( 000001BD2F105CF0, *0000000DAA8FE528 = 000001BD35FC6170 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIBooleanProperty*)000001BD35FC6170 )->queryInterface( 000001BD2F105CF0, 0000000DAA8FE4C8 )
0x00003E54 49992 3  XPCOM R: ( (dsIBooleanProperty*)000001BD35FC6170 )->queryInterface( 000001BD2F105CF0, *0000000DAA8FE4C8 = 000001BD35FC6170 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIBooleanProperty*)000001BD35FC6170 )->CurValue( 0000000DAA8FE590 )
0x00003E54 49992 3  XPCOM R: ( (dsIBooleanProperty*)000001BD35FC6170 )->CurValue( *0000000DAA8FE590 = false ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugProperties( Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, CS_DAP, 0000000DAA8FE520 )
0x00003E54 49992 3  XPCOM R: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugProperties( Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, CS_DAP, *0000000DAA8FE520 = 000001BD2E414D40 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E414D40 )->queryInterface( 000001BD2F10A6F0, 0000000DAA8FE498 )
0x00003E54 49992 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E414D40 )->queryInterface( 000001BD2F10A6F0, *0000000DAA8FE498 = 000001BD2E414D48 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2E414D48 )->onDisableStatusChanged( 0000000DAA8FE470 )
0x00003E54 49992 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2E414D48 )->onDisableStatusChanged( *0000000DAA8FE470 = 000001BD2CC67260 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2E414D48 )->onPropertyValueChanged( 0000000DAA8FE470 )
0x00003E54 49992 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2E414D48 )->onPropertyValueChanged( *0000000DAA8FE470 = 000001BD2CC67BF0 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E414D40 )->getProperty( ConnectOnStartup, 0000000DAA8FE5A8 )
0x00003E54 49992 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E414D40 )->getProperty( ConnectOnStartup, *0000000DAA8FE5A8 = 000001BD30145B30 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIProperty*)000001BD30145B30 )->getPropertyType( 0000000DAA8FE540 )
0x00003E54 49992 3  XPCOM R: ( (dsIProperty*)000001BD30145B30 )->getPropertyType( *0000000DAA8FE540 = 0x00000000 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIProperty*)000001BD30145B30 )->queryInterface( 000001BD2F10AAF0, 0000000DAA8FE538 )
0x00003E54 49992 3  XPCOM R: ( (dsIProperty*)000001BD30145B30 )->queryInterface( 000001BD2F10AAF0, *0000000DAA8FE538 = 000001BD30145BD0 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIBooleanProperty*)000001BD30145BD0 )->queryInterface( 000001BD2F10A630, 0000000DAA8FE4D8 )
0x00003E54 49992 3  XPCOM R: ( (dsIBooleanProperty*)000001BD30145BD0 )->queryInterface( 000001BD2F10A630, *0000000DAA8FE4D8 = 000001BD30145BD0 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIBooleanProperty*)000001BD30145BD0 )->CurValue( 0000000DAA8FE5A0 )
0x00003E54 49992 3  XPCOM R: ( (dsIBooleanProperty*)000001BD30145BD0 )->CurValue( *0000000DAA8FE5A0 = false ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E414D40 )->getProperty( EnableInstalledBreakpoint, 0000000DAA8FE598 )
0x00003E54 49992 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E414D40 )->getProperty( EnableInstalledBreakpoint, *0000000DAA8FE598 = 000001BD301459B0 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIProperty*)000001BD301459B0 )->getPropertyType( 0000000DAA8FE530 )
0x00003E54 49992 3  XPCOM R: ( (dsIProperty*)000001BD301459B0 )->getPropertyType( *0000000DAA8FE530 = 0x00000000 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIProperty*)000001BD301459B0 )->queryInterface( 000001BD2F10A630, 0000000DAA8FE528 )
0x00003E54 49992 3  XPCOM R: ( (dsIProperty*)000001BD301459B0 )->queryInterface( 000001BD2F10A630, *0000000DAA8FE528 = 000001BD30145A50 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIBooleanProperty*)000001BD30145A50 )->queryInterface( 000001BD2F10AAF0, 0000000DAA8FE4C8 )
0x00003E54 49992 3  XPCOM R: ( (dsIBooleanProperty*)000001BD30145A50 )->queryInterface( 000001BD2F10AAF0, *0000000DAA8FE4C8 = 000001BD30145A50 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIBooleanProperty*)000001BD30145A50 )->CurValue( 0000000DAA8FE590 )
0x00003E54 49992 3  XPCOM R: ( (dsIBooleanProperty*)000001BD30145A50 )->CurValue( *0000000DAA8FE590 = false ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugProperties( Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, Cortex_M4, 0000000DAA8FE520 )
0x00003E54 49992 3  XPCOM R: ( (dsIDebugPropertiesManager*)000001BD3CF3FF40 )->getDebugProperties( Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, Cortex_M4, *0000000DAA8FE520 = 000001BD2E4139C0 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E4139C0 )->queryInterface( 000001BD2F10A5B0, 0000000DAA8FE498 )
0x00003E54 49992 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E4139C0 )->queryInterface( 000001BD2F10A5B0, *0000000DAA8FE498 = 000001BD2E4139C8 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2E4139C8 )->onDisableStatusChanged( 0000000DAA8FE470 )
0x00003E54 49992 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2E4139C8 )->onDisableStatusChanged( *0000000DAA8FE470 = 000001BD2CC675C0 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIDebugPropertiesEvents*)000001BD2E4139C8 )->onPropertyValueChanged( 0000000DAA8FE470 )
0x00003E54 49992 3  XPCOM R: ( (dsIDebugPropertiesEvents*)000001BD2E4139C8 )->onPropertyValueChanged( *0000000DAA8FE470 = 000001BD2CC67380 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E4139C0 )->getProperty( ConnectOnStartup, 0000000DAA8FE5A8 )
0x00003E54 49992 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E4139C0 )->getProperty( ConnectOnStartup, *0000000DAA8FE5A8 = 000001BD279CE8D0 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIProperty*)000001BD279CE8D0 )->getPropertyType( 0000000DAA8FE540 )
0x00003E54 49992 3  XPCOM R: ( (dsIProperty*)000001BD279CE8D0 )->getPropertyType( *0000000DAA8FE540 = 0x00000000 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIProperty*)000001BD279CE8D0 )->queryInterface( 000001BD2F10A6F0, 0000000DAA8FE538 )
0x00003E54 49992 3  XPCOM R: ( (dsIProperty*)000001BD279CE8D0 )->queryInterface( 000001BD2F10A6F0, *0000000DAA8FE538 = 000001BD279CE970 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIBooleanProperty*)000001BD279CE970 )->queryInterface( 000001BD2F10A6F0, 0000000DAA8FE4D8 )
0x00003E54 49992 3  XPCOM R: ( (dsIBooleanProperty*)000001BD279CE970 )->queryInterface( 000001BD2F10A6F0, *0000000DAA8FE4D8 = 000001BD279CE970 ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIBooleanProperty*)000001BD279CE970 )->CurValue( 0000000DAA8FE5A0 )
0x00003E54 49992 3  XPCOM R: ( (dsIBooleanProperty*)000001BD279CE970 )->CurValue( *0000000DAA8FE5A0 = true ) = 0x00000000
0x00003E54 49992 3  XPCOM C: ( (dsIConnectDisconnect*)000001BD29180E08 )->DisconnectCapable( 0000000DAA8FE600 )
0x00003E54 49992 3  XPCOM R: ( (dsIConnectDisconnect*)000001BD29180E08 )->DisconnectCapable( *0000000DAA8FE600 = true ) = 0x00000000
0x00003E54 50008 3  XPCOM C: ( (dsIConnectDisconnect*)000001BD29180E08 )->connect()
0x00003E54 50008 3 Cortex_M4_0 POLL C: Firing DSP_PRECONNECT to all DSP_USER's
0x00003E54 50008 3 CS_DAP_0 POLL C: Firing DSP_PRECONNECT to all DSP_USER's
0x00003E54 50008 3 IcePick_C POLL C: Firing DSP_PRECONNECT to all DSP_USER's
0x00003E54 50008 3 IcePick_C POLL C: Firing of DSP_PRECONNECT complete
0x00003E54 50008 3  SEQUENCE I: Finished sequence step at 0000000DAA8FD210
0x00003E54 50008 3  SEQUENCE I: Beginning class Debugger::GelCallbackStep at 000001BD2B56F440
0x00003E54 50008 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAA8FCB08 )
0x00003E54 50008 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAA8FCB08 ) = 0x00000000
0x00003E54 50008 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAA8FCB00 )
0x00003E54 50008 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAA8FCB00 ) = 0x00000002
0x00003E54 50008 3 IcePick_C GEL I: Evaluating "OnPreTargetConnect()"
0x00003E54 50008 3 IcePick_C POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00003E54 50008 3 CS_DAP_0 POLL C: Firing of DSP_PRECONNECT complete
0x00003E54 50008 3 Cortex_M4_0 POLL C: Firing of DSP_PRECONNECT complete
0x00003E54 50008 3  XPCOM R: ( (dsIConnectDisconnect*)000001BD29180E08 )->connect() = 0x00000000
0x00001CD4 50008 3 IcePick_C POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 50008 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 50008 3 IcePick_C POLL R: Poll() returning
0x00001CD4 50008 4 IcePick_C POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 50008 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 50008 4  POLL I: Yielding to other threads
0x00001CD4 50008 3 IcePick_C POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 50008 3 IcePick_C POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 50008 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='OnPreTargetConnect()' AND Register_Cache.Processor=33
0x00001CD4 50008 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=33 AND Name='OnPreTargetConnect()'
0x00001CD4 50008 3 IcePick_C GEL I: Evaluation of "OnPreTargetConnect()" failed: identifier not found: OnPreTargetConnect()
0x00001CD4 50008 3  SEQUENCE I: Finished sequence step at 000001BD2B56F440
0x00001CD4 50008 3  SEQUENCE I: Beginning class Debugger::LambdaSequenceStep<class <lambda_d5c2eaa1b9c646e74fc865fbf49efb9b> > at 000001BD30134FC0
0x00001CD4 50008 3  SEQUENCE I: Finished sequence step at 000001BD30134FC0
0x00001CD4 50008 3 IcePick_C POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 50008 3 IcePick_C POLL C: Polling with state CPU_ST_CONNECT and status EVENT_DSP_HALT
0x00001CD4 50008 3  PERF I: GTI_CONNECT starting...
0x00001CD4 50008 3 IcePick_C GTI C: GTI_CONNECT3( 0x000001BD29E173E0, 0 )
0x00001CD4 50024 3  XDS110 C: Executing command 0x01 (XDS_CONNECT)
0x00001CD4 50119 3  XDS110 R: Executed command 0x01 (XDS_CONNECT), return code: 0x00000000
0x00001CD4 50119 3  XDS110 C: Executing command 0x03 (XDS_VERSION)
0x00001CD4 50119 3  XDS110 R: Executed command 0x03 (XDS_VERSION), return code: 0x00000000
0x00001CD4 50119 3  XDS110 C: Executing command 0x04 (XDS_SETTCLKDELAY)
0x00001CD4 50119 3  XDS110 R: Executed command 0x04 (XDS_SETTCLKDELAY), return code: 0x00000000
0x00001CD4 50119 3  XDS110 C: Executing command 0x06 (XDS_GETTRST)
0x00001CD4 50134 3  XDS110 R: Executed command 0x06 (XDS_GETTRST), return code: 0x00000000
0x00001CD4 50134 3  XDS110 C: Executing command 0x05 (XDS_SETTRST)
0x00001CD4 50134 3  XDS110 R: Executed command 0x05 (XDS_SETTRST), return code: 0x00000000
0x00001CD4 50134 3  XDS110 C: Executing command 0x07 (XDS_CYCLETCLK)
0x00001CD4 50134 3  XDS110 R: Executed command 0x07 (XDS_CYCLETCLK), return code: 0x00000000
0x00001CD4 50182 3  XDS110 R: Executed command 0x07 (XDS_CYCLETCLK), return code: 0x00000000
0x00001CD4 50182 3  XDS110 C: Executing command 0x2b (CJTAG_CONNECT)
0x00001CD4 50182 3  XDS110 R: Executed command 0x2b (CJTAG_CONNECT), return code: 0x00000000
0x00001CD4 50182 3  XDS110 C: Executing command 0x19 (SWD_ENABLESWO)
0x00001CD4 50292 3  XDS110 R: Executed command 0x19 (SWD_ENABLESWO), return code: 0x00000000
0x00001CD4 50292 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50292 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50292 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50292 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50292 3  XDS110 C: Executing command 0x07 (XDS_CYCLETCLK)
0x00001CD4 50292 3  XDS110 R: Executed command 0x07 (XDS_CYCLETCLK), return code: 0x00000000
0x00001CD4 50292 3  XDS110 C: Executing command 0x0a (XDS_FIXEDSCAN)
0x00001CD4 50292 3  XDS110 R: Executed command 0x0a (XDS_FIXEDSCAN), return code: 0x00000000
0x00001CD4 50292 3  XDS110 C: Executing command 0x2d (XDS_SELECTTAP)
0x00001CD4 50308 3  XDS110 R: Executed command 0x2d (XDS_SELECTTAP), return code: 0x00000000
0x00001CD4 50308 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 50308 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 50308 3  XDS110 C: Executing command 0x2d (XDS_SELECTTAP)
0x00001CD4 50308 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50308 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50308 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50308 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50324 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 50324 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 50324 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50324 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50324 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50324 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50340 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50340 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50341 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50341 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50341 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50341 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50356 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50356 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50356 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50356 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50372 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50372 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50372 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50372 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50388 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50388 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50388 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50388 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50403 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50403 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50403 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50403 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50403 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 50403 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 50403 3 IcePick_C GTI R: GTI_CONNECT3( 0x000001BD29E173E0, 0 ) = 0x00000000
0x00001CD4 50403 3  PERF I: GTI_CONNECT finished:  0.408576s wall, 0.015625s user + 0.046875s system = 0.062500s CPU (15.3%)
0x00001CD4 50403 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD878 = 0x00000000, *0x0000000DAD8FD870 = 0x00000000, *0x0000000DAD8FD888 = 0x00000000, *0x0000000DAD8FD8A0 = 0x00000000, *0x0000000DAD8FD8A8 = 0x00000000, *0x0000000DAD8FD898 = 0x00000000, *0x0000000DAD8FD890 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50403 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD878 = 0x00000000, *0x0000000DAD8FD870 = 0x00000000, *0x0000000DAD8FD888 = 0x00000000, *0x0000000DAD8FD8A0 = 0x00000002, *0x0000000DAD8FD8A8 = 0x00000000, *0x0000000DAD8FD898 = 0x00000008, *0x0000000DAD8FD890 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50403 3 IcePick_C STATE I: Connection state changed to 4
0x00001CD4 50403 3 IcePick_C GTI C: GTI_STAT( 0x000001BD29E173E0 )
0x00001CD4 50419 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 50419 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50419 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50419 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50419 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50435 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50435 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50435 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50435 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50450 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50450 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50450 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50450 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50466 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50466 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50466 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50466 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50482 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50482 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50482 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50482 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50497 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50497 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50497 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50497 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50497 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 50497 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 50497 3 IcePick_C GTI R: GTI_STAT( 0x000001BD29E173E0 ) = 0x0000000E
0x00001CD4 50497 3 IcePick_C STATE I: Target execution state changed to STATUS_NON_DEBUG_CHANGE
0x00001CD4 50497 3 IcePick_C STATE I: Debugger execution state changed to EVENT_DSP_HALT
0x00001CD4 50497 3 IcePick_C STATE I: Connection state changed to 0
0x00001CD4 50497 3 IcePick_C GTI C: GTI_GETCAPABILITIES( 0x000001BD29E173E0 )
0x00001CD4 50497 3 IcePick_C GTI R: GTI_GETCAPABILITIES( 0x000001BD29E173E0 ) = 0x85030010
0x00001CD4 50497 3 IcePick_C GTI C: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E173E0, 0 )
0x00001CD4 50497 3 IcePick_C GTI R: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E173E0, 0 ) = 0x85030010
0x00001CD4 50497 3 IcePick_C GTI C: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E173E0, 2 )
0x00001CD4 50497 3 IcePick_C GTI R: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E173E0, 2 ) = 0x04000000
0x00001CD4 50497 3 IcePick_C GTI C: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E173E0, 1 )
0x00001CD4 50497 3 IcePick_C GTI R: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E173E0, 1 ) = 0x00000000
0x00001CD4 50497 3 IcePick_C GTI C: GTI_GET_PROC_ID( 0x000001BD29E173E0 )
0x00001CD4 50497 3 IcePick_C GTI R: GTI_GET_PROC_ID( 0x000001BD29E173E0 ) = 0x3C000805
0x00001CD4 50497 3  LIB C: dlsym( 000001BD38E90000, "GTI_GET_PROC_MINOR_ID" )
0x00001CD4 50497 3  LIB R: dlsym( 000001BD38E90000, "GTI_GET_PROC_MINOR_ID" ) = 0000000000000000
0x00001CD4 50497 3  LIB C: dlsym( 000001BD38E90000, "_GTI_GET_PROC_MINOR_ID" )
0x00001CD4 50497 3  LIB R: dlsym( 000001BD38E90000, "_GTI_GET_PROC_MINOR_ID" ) = 0000000000000000
0x00001CD4 50497 3 IcePick_C GTI C: GTI_GET_TARGET_PROPERTIES( 0x000001BD29E173E0, 0x00000005 )
0x00001CD4 50497 3 IcePick_C GTI R: GTI_GET_TARGET_PROPERTIES( 0x000001BD29E173E0, 0x00000005 ) = 0x00000000
0x00001CD4 50497 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_DESTRUCTOR )
0x00001CD4 50497 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3D1FA7E0, TPI_GEN_CMD_DESTRUCTOR ) = 0x00000000
0x00001CD4 50497 3 IcePick_C TPI C: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_GET_REVISION, *0000000DAD8FDD70 )
0x00001CD4 50497 3 IcePick_C TPI R: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_GET_REVISION, *0000000DAD8FDD70 = 0x00000065 ) = 0x00000000
0x00001CD4 50497 3 IcePick_C TPI C: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_CONSTRUCTOR, 0x0000000D3C000805, 0x00007FFE00000000, 0x000001BD367E9B00 )
0x00001CD4 50497 3 IcePick_C TPI R: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_CONSTRUCTOR, 0x0000000D3C000805, 0x00007FFE00000000, 0x000001BD367E9B00 ) = 0x00000000
0x00001CD4 50497 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_SET_DS_VERSION, 0x0000000D0000000C, 0x00007FFE00000000, 0x000001BD00000000 )
0x00001CD4 50497 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_SET_DS_VERSION, 0x0000000D0000000C, 0x00007FFE00000000, 0x000001BD00000000 ) = 0x00000002
0x00001CD4 50497 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_NUM_PAGES, *0000000DAD8FDD20 )
0x00001CD4 50497 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_NUM_PAGES, *0000000DAD8FDD20 = 0x00000001 ) = 0x00000000
0x00001CD4 50497 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000000 )
0x00001CD4 50497 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000000 ) = 0x00000000
0x00001CD4 50497 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000000, 0x0000000DAD8FDBA8 )
0x00001CD4 50497 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000000, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50497 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000000, *0000000DAD8FDBE8 )
0x00001CD4 50497 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000000, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50497 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000000, *0000000DAD8FDBF0 )
0x00001CD4 50497 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000000, *0000000DAD8FDBF0 = 0xAD8FDD00 ) = 0x00000002
0x00001CD4 50497 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000000, *0000000DAD8FDBEC )
0x00001CD4 50497 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000000, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50497 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_DEFAULT_PAGE, *000001BD290BDA98 )
0x00001CD4 50497 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_DEFAULT_PAGE, *000001BD290BDA98 = 0x00000000 ) = 0x00000002
0x00001CD4 50497 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_REG_PAGES, *0000000DAD8FDD28, *0000000DAD8FDD20 )
0x00001CD4 50497 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_REG_PAGES, *0000000DAD8FDD28 = 0x00000001, *0000000DAD8FDD20 = 0x00000079 ) = 0x00000002
0x00001CD4 50497 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_REGBUS_BITS, 0x0000000DAD8FDBA0, 0x0000000000000079 )
0x00001CD4 50497 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_REGBUS_BITS, 0x0000000DAD8FDBA0, 0x0000000000000079 ) = 0x00000000
0x00001CD4 50497 3 IcePick_C GTI C: GTI_GET_NUM_RESETS( 0x000001BD29E173E0 )
0x00001CD4 50497 3 IcePick_C GTI R: GTI_GET_NUM_RESETS( 0x000001BD29E173E0 ) = 0x00000002
0x00001CD4 50497 3 IcePick_C GTI C: GTI_GET_RESET_INFO( 0x000001BD29E173E0, 0x00000000, *0x0000000DAD8FDB70 = ??? )
0x00001CD4 50497 3 IcePick_C GTI R: GTI_GET_RESET_INFO( 0x000001BD29E173E0, 0x00000000, *0x0000000DAD8FDB70 = ??? ) = 0x00000000
0x00001CD4 50497 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD398 = 0x00000000, *0x0000000DAD8FD390 = 0x00000000, *0x0000000DAD8FD3A8 = 0x00000000, *0x0000000DAD8FD3C0 = 0x00000000, *0x0000000DAD8FD3C8 = 0x00000000, *0x0000000DAD8FD3B8 = 0x00000000, *0x0000000DAD8FD3B0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50497 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD398 = 0x00000000, *0x0000000DAD8FD390 = 0x00000000, *0x0000000DAD8FD3A8 = 0x00000000, *0x0000000DAD8FD3C0 = 0x00000002, *0x0000000DAD8FD3C8 = 0x00000000, *0x0000000DAD8FD3B8 = 0x00000008, *0x0000000DAD8FD3B0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50497 3 IcePick_C GTI C: GTI_GET_RESET_INFO( 0x000001BD29E173E0, 0x00000001, *0x0000000DAD8FDB70 = ??? )
0x00001CD4 50497 3 IcePick_C GTI R: GTI_GET_RESET_INFO( 0x000001BD29E173E0, 0x00000001, *0x0000000DAD8FDB70 = ??? ) = 0x00000000
0x00001CD4 50497 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_SET_CALLBACK, 0x000001BD3CDCA080, 0x00007FFEC49C30E0 )
0x00001CD4 50497 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_SET_CALLBACK, 0x000001BD3CDCA080, 0x00007FFEC49C30E0 ) = 0x00000002
0x00001CD4 50497 3 IcePick_C TA C: QueryInterface( 1 )
0x00001CD4 50497 3 IcePick_C TA R: QueryInterface( 1 ) = 000001BD3D0BAF78
0x00001CD4 50497 3 IcePick_C TA C: QueryInterface( 3 )
0x00001CD4 50497 3 IcePick_C TA R: QueryInterface( 3 ) = 000001BD3D0BAF68
0x00001CD4 50497 3 IcePick_C TA C: QueryInterface( 4 )
0x00001CD4 50497 3 IcePick_C TA R: QueryInterface( 4 ) = 000001BD3D0BAF80
0x00001CD4 50497 3  LIB C: dlsym( 00007FFEDF0F0000, "GetcToolsDBMgrIFDS" )
0x00001CD4 50497 3  LIB R: dlsym( 00007FFEDF0F0000, "GetcToolsDBMgrIFDS" ) = 00007FFEDF182DC0
0x00001CD4 50497 3 IcePick_C CT C: GetcToolsDBMgrIFDS( 000001BD3D0BAF70, 0000000DAD8FDB78 )
0x00001CD4 50497 3 IcePick_C CI C: GetProcessorID()
0x00001CD4 50497 3 IcePick_C CI R: GetProcessorID() = 0x3C000805
0x00001CD4 50497 3 IcePick_C CI C: GetType()
0x00001CD4 50497 3 IcePick_C CI R: GetType() = 0x000007D0
0x00001CD4 50497 3 IcePick_C CI C: GetLabel( 0000000DAD8FD2B0, 260 )
0x00001CD4 50497 3 IcePick_C CI R: GetLabel( *0000000DAD8FD2B0 = Texas Instruments XDS110 USB Debug Probe/IcePick_C, 260 ) = 0
0x00001CD4 50497 3 IcePick_C CT R: GetcToolsDBMgrIFDS( 000001BD3D0BAF70, *0000000DAD8FDB78 = 000001BD2F9C1160 )
0x00001CD4 50497 3  PERF I: Ctools AddTarget() starting...
0x00001CD4 50497 3  CT C: JobMgrIFDS::AddTarget( 000001BD3DBD74E0, 0000000000000000 )
0x00001CD4 50497 3 IcePick_C CI C: GetLabel( 0000000DAD8FD690, 1024 )
0x00001CD4 50497 3 IcePick_C CI R: GetLabel( *0000000DAD8FD690 = Texas Instruments XDS110 USB Debug Probe/IcePick_C, 1024 ) = 0
0x00001CD4 50497 3 IcePick_C CI C: GetLabel( 0000000DAD8FD440, 260 )
0x00001CD4 50497 3 IcePick_C CI R: GetLabel( *0000000DAD8FD440 = Texas Instruments XDS110 USB Debug Probe/IcePick_C, 260 ) = 0
0x00001CD4 50497 3 IcePick_C TA C: IsSimulator()
0x00001CD4 50497 3 IcePick_C TA R: IsSimulator() = false
0x00001CD4 50497 3 IcePick_C TA C: GetSiliconRevision()
0x00001CD4 50497 3 IcePick_C GTI C: GTI_GET_TARGET_PROPERTIES( 0x000001BD29E173E0, 0x00000003 )
0x00001CD4 50497 3 IcePick_C GTI R: GTI_GET_TARGET_PROPERTIES( 0x000001BD29E173E0, 0x00000003 ) = 0x00004000
0x00001CD4 50497 3 IcePick_C TA R: GetSiliconRevision() = 16384
0x00001CD4 50497 3 IcePick_C TA C: IsConnected()
0x00001CD4 50497 3 IcePick_C TA R: IsConnected() = true
0x00001CD4 50497 3 IcePick_C CI C: GetLabel( 0000000DAD8FCC80, 260 )
0x00001CD4 50497 3 IcePick_C CI R: GetLabel( *0000000DAD8FCC80 = Texas Instruments XDS110 USB Debug Probe/IcePick_C, 260 ) = 0
0x00001CD4 50513 3  SETUP C: OpenDatabase( C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\targetdb.dat, C:\ti\ccs1200\ccs\ccs_base\common\targetdb\timestamp )
0x00001CD4 50513 3  SETUP I: SELECT sql FROM sqlite_master ORDER BY tbl_name, name
0x00001CD4 50513 3  SETUP R: OpenDatabase( C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\targetdb.dat, C:\ti\ccs1200\ccs\ccs_base\common\targetdb\timestamp ) = 000001BD2BAAB4F0
0x00001CD4 50513 3  SETUP I: Loading repository "C:\ti\ccs1200\ccs\ccs_base\common\targetdb\"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Repositories
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Repositories WHERE dbid=1
0x00001CD4 50513 3  SETUP I: PRAGMA journal_mode = MEMORY
0x00001CD4 50513 3  SETUP I: PRAGMA synchronous = OFF
0x00001CD4 50513 3  SETUP I: BEGIN IMMEDIATE TRANSACTION
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="CS_DAP_0_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=1
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="CS_DAP_PC_0_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=2
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_C_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=3
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_D_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=4
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_M_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=5
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="regids_mapping.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=6
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2000_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=7
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2001_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=8
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2002_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=9
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2003_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=10
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2004_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=11
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2005_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=12
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2006_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=13
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2007_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=14
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2008_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=15
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2010_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=16
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2011_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=17
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2012_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=18
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2013_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=19
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2014_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=20
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2015_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=21
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2026_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=22
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2027_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=23
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2028_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=24
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2029_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=25
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2030_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=26
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2031_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=27
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2032_regids.xml"
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=28
0x00001CD4 50513 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS225C00_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=29
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS225C100_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=30
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C28XX_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=31
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C55XX_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=32
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C64XX_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=33
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C66XX_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=34
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C674X_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=35
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C6XXX_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=36
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C71XX_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=37
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C75XX_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=38
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS3CXX_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=39
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R15X_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=40
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R25X_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=41
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R2X_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=42
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R33X_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=43
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R4X_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=44
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R53X_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=45
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R7X_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=46
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R9X_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=47
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RAX_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=48
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RCX_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=49
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RDX_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=50
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470REX_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=51
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RXX_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=52
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C40XX_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=53
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C41XX_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=54
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C4X_regids.xml"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=55
0x00001CD4 50529 3  SETUP I: END TRANSACTION
0x00001CD4 50529 3  SETUP I: SELECT count(*) FROM TargetDB_Files WHERE State=0
0x00001CD4 50529 3  SETUP I: Scrubbing database
0x00001CD4 50529 3  SETUP I: Loading file "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\2910475632580809234.cache"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="2910475632580809234.cache"
0x00001CD4 50529 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=116
0x00001CD4 50529 3  SETUP I: SELECT Systems.dbid FROM Systems, TargetDB_Files WHERE Systems.Source_File = TargetDB_Files.dbid AND TargetDB_Files.dbid = 116
0x00001CD4 50529 3  SETUP I: SELECT * FROM Systems WHERE dbid=9
0x00001CD4 50529 3  GTI C: JTAGData_CreateJtagDeviceList()
0x00001CD4 50545 3  GTI R: JTAGData_CreateJtagDeviceList() = 000001BD355166A0
0x00001CD4 50545 3  GTI C: JTAGData_AddVariable( 000001BD355166A0, BOARD_DATAFILE_VERSION, *0000000DAD8FBCF0 = 2 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariable( 000001BD355166A0, BOARD_DATAFILE_VERSION, *0000000DAD8FBCF0 = 2 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, SEPK.POD_DRVR, jioxds110.dll )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, SEPK.POD_DRVR, jioxds110.dll ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, SEPK.POD_PORT, 0 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, SEPK.POD_PORT, 0 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, SEPK.POD_SUPPLY, 1 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, SEPK.POD_SUPPLY, 1 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, SEPK.POD_VOLTAGE_SELECTION, 1 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, SEPK.POD_VOLTAGE_SELECTION, 1 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, SEPK.POD_VOLTAGE, 3.3 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, SEPK.POD_VOLTAGE, 3.3 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, SEPK.POD_POWER_ISOLATE, 0 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, SEPK.POD_POWER_ISOLATE, 0 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, PRODUCT.TITLE, Texas Instruments XDS110 USB )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, PRODUCT.TITLE, Texas Instruments XDS110 USB ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, PRODUCT.ALIAS, TI_XDS110_USB )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, PRODUCT.ALIAS, TI_XDS110_USB ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, PRODUCT.NAME, XDS110 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, PRODUCT.NAME, XDS110 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, USCIF.TDOEDGE, FALL )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, USCIF.TDOEDGE, FALL ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, USCIF.TCLK_PROGRAM, DEFAULT )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, USCIF.TCLK_PROGRAM, DEFAULT ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, USCIF.TCLK_FREQUENCY, 5.5MHz )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, USCIF.TCLK_FREQUENCY, 5.5MHz ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, USCIF.JTAG_ISOLATE, disable )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, USCIF.JTAG_ISOLATE, disable ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, DOT7.DTS_USAGE, enable )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, DOT7.DTS_USAGE, enable ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, DOT7.DTS_TYPE, xds110 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, DOT7.DTS_TYPE, xds110 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, DOT7.DTS_PROGRAM, emulator )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, DOT7.DTS_PROGRAM, emulator ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, DOT7.DTS_FREQUENCY, 1.0MHz )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, DOT7.DTS_FREQUENCY, 1.0MHz ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, DOT7.TS_FORMAT, oscan2 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, DOT7.TS_FORMAT, oscan2 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, DOT7.TS_PIN_WIDTH, only_two )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, DOT7.TS_PIN_WIDTH, only_two ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, SWD.SWD_DEBUG, disabled )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, SWD.SWD_DEBUG, disabled ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, SWD.SWO_DATA, tdo_pin )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, SWD.SWO_DATA, tdo_pin ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, SWD.SWJ_DP_DEFAULT_MODE, 0 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, SWD.SWJ_DP_DEFAULT_MODE, 0 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddDeviceEx( 000001BD355166A0, IcePick_C, 240, 2, 0, 5, ROUTER, 4294967295, 0, 2 )
0x00001CD4 50545 3  GTI R: JTAGData_AddDeviceEx( 000001BD355166A0, IcePick_C, 240, 2, 0, 5, ROUTER, 4294967295, 0, 2 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, device.SystemResetSupported, 1 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, device.SystemResetSupported, 1 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, device.SystemResetWhileConnected, 1 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, device.SystemResetWhileConnected, 1 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddSubpath( 000001BD355166A0, subpath_2, IcePick_C, 1 )
0x00001CD4 50545 3  GTI R: JTAGData_AddSubpath( 000001BD355166A0, subpath_2, IcePick_C, 1 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, subpath.address, 0x0 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, subpath.address, 0x0 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, subpath.initial, 0 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, subpath.initial, 0 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, subpath.custom, 1 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, subpath.custom, 1 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, subpath.force, 1 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, subpath.force, 1 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, subpath.cancelreset, 0x1 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, subpath.cancelreset, 0x1 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddDevice( 000001BD355166A0, bypass_0, 1023, 4095, 127, 7, BYPASS, 4 )
0x00001CD4 50545 3  GTI R: JTAGData_AddDevice( 000001BD355166A0, bypass_0, 1023, 4095, 127, 7, BYPASS, 4 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddSubpath( 000001BD355166A0, subpath_0, IcePick_C, 1 )
0x00001CD4 50545 3  GTI R: JTAGData_AddSubpath( 000001BD355166A0, subpath_0, IcePick_C, 1 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, subpath.address, 0x10 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, subpath.address, 0x10 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddDeviceEx( 000001BD355166A0, CS_DAP_0, 224, 1, 0, 5, ROUTER, 4294967295, 0, 1 )
0x00001CD4 50545 3  GTI R: JTAGData_AddDeviceEx( 000001BD355166A0, CS_DAP_0, 224, 1, 0, 5, ROUTER, 4294967295, 0, 1 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, device.identify, 0x4ba00477 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, device.identify, 0x4ba00477 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, device.Revision, Legacy )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, device.Revision, Legacy ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddSubpath( 000001BD355166A0, subpath_1, CS_DAP_0, 1 )
0x00001CD4 50545 3  GTI R: JTAGData_AddSubpath( 000001BD355166A0, subpath_1, CS_DAP_0, 1 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, subpath.type, debug )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, subpath.type, debug ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, subpath.pseudo, 0 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, subpath.pseudo, 0 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddDevice( 000001BD355166A0, Cortex_M4_0, 470, 14, 0, 0, DSP_CPU, -1 )
0x00001CD4 50545 3  GTI R: JTAGData_AddDevice( 000001BD355166A0, Cortex_M4_0, 470, 14, 0, 0, DSP_CPU, -1 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, device.identify, 0x02000000 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, device.identify, 0x02000000 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_AddVariableEx( 000001BD355166A0, device.traceId, 0x0 )
0x00001CD4 50545 3  GTI R: JTAGData_AddVariableEx( 000001BD355166A0, device.traceId, 0x0 ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_Output( 000001BD355166A0, C:\Users\o.gaste\.TI-trace\data\temp0.dat )
0x00001CD4 50545 3  GTI R: JTAGData_Output( 000001BD355166A0, C:\Users\o.gaste\.TI-trace\data\temp0.dat ) = 1
0x00001CD4 50545 3  GTI C: JTAGData_DestroyJtagDeviceList( 000001BD355166A0 )
0x00001CD4 50545 3  GTI R: JTAGData_DestroyJtagDeviceList( 000001BD355166A0 ) = 0000000000000000
0x00001CD4 50545 3  SETUP C: OpenDatabase( C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\targetdb.dat, C:\ti\ccs1200\ccs\ccs_base\common\targetdb\timestamp )
0x00001CD4 50545 3  SETUP I: SELECT sql FROM sqlite_master ORDER BY tbl_name, name
0x00001CD4 50545 3  SETUP R: OpenDatabase( C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\targetdb.dat, C:\ti\ccs1200\ccs\ccs_base\common\targetdb\timestamp ) = 000001BD2BAAB550
0x00001CD4 50545 3  SETUP I: Loading repository "C:\ti\ccs1200\ccs\ccs_base\common\targetdb\"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Repositories
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Repositories WHERE dbid=1
0x00001CD4 50545 3  SETUP I: PRAGMA journal_mode = MEMORY
0x00001CD4 50545 3  SETUP I: PRAGMA synchronous = OFF
0x00001CD4 50545 3  SETUP I: BEGIN IMMEDIATE TRANSACTION
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="CS_DAP_0_regids.xml"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=1
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="CS_DAP_PC_0_regids.xml"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=2
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_C_regids.xml"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=3
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_D_regids.xml"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=4
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_M_regids.xml"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=5
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="regids_mapping.xml"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=6
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2000_regids.xml"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=7
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2001_regids.xml"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=8
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2002_regids.xml"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=9
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2003_regids.xml"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=10
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2004_regids.xml"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=11
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2005_regids.xml"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=12
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2006_regids.xml"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=13
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2007_regids.xml"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=14
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2008_regids.xml"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=15
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2010_regids.xml"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=16
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2011_regids.xml"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=17
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2012_regids.xml"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=18
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2013_regids.xml"
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=19
0x00001CD4 50545 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2014_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=20
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2015_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=21
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2026_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=22
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2027_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=23
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2028_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=24
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2029_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=25
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2030_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=26
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2031_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=27
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2032_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=28
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS225C00_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=29
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS225C100_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=30
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C28XX_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=31
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C55XX_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=32
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C64XX_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=33
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C66XX_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=34
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C674X_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=35
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C6XXX_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=36
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C71XX_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=37
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C75XX_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=38
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS3CXX_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=39
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R15X_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=40
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R25X_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=41
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R2X_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=42
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R33X_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=43
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R4X_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=44
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R53X_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=45
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R7X_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=46
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R9X_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=47
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RAX_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=48
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RCX_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=49
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RDX_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=50
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470REX_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=51
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RXX_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=52
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C40XX_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=53
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C41XX_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=54
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C4X_regids.xml"
0x00001CD4 50560 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=55
0x00001CD4 50560 3  SETUP I: END TRANSACTION
0x00001CD4 50560 3  SETUP I: SELECT count(*) FROM TargetDB_Files WHERE State=0
0x00001CD4 50560 3  SETUP I: Scrubbing database
0x00001CD4 50576 3  SETUP I: Loading file "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\2910475632580809234.cache"
0x00001CD4 50576 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="2910475632580809234.cache"
0x00001CD4 50576 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=116
0x00001CD4 50576 3  SETUP I: SELECT count(*) FROM TargetDB_Files WHERE State=0
0x00001CD4 50576 3  SETUP I: SELECT Systems.dbid FROM Systems, TargetDB_Files WHERE Systems.Source_File = TargetDB_Files.dbid AND TargetDB_Files.dbid = 116
0x00001CD4 50576 3  SETUP I: SELECT * FROM Systems WHERE dbid=9
0x00001CD4 50576 3  GTI C: JTAGData_CreateJtagDeviceList()
0x00001CD4 50576 3  GTI R: JTAGData_CreateJtagDeviceList() = 000001BD35515260
0x00001CD4 50576 3  GTI C: JTAGData_AddVariable( 000001BD35515260, BOARD_DATAFILE_VERSION, *0000000DAD8FBDA0 = 2 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariable( 000001BD35515260, BOARD_DATAFILE_VERSION, *0000000DAD8FBDA0 = 2 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, SEPK.POD_DRVR, jioxds110.dll )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, SEPK.POD_DRVR, jioxds110.dll ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, SEPK.POD_PORT, 0 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, SEPK.POD_PORT, 0 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, SEPK.POD_SUPPLY, 1 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, SEPK.POD_SUPPLY, 1 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, SEPK.POD_VOLTAGE_SELECTION, 1 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, SEPK.POD_VOLTAGE_SELECTION, 1 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, SEPK.POD_VOLTAGE, 3.3 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, SEPK.POD_VOLTAGE, 3.3 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, SEPK.POD_POWER_ISOLATE, 0 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, SEPK.POD_POWER_ISOLATE, 0 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, PRODUCT.TITLE, Texas Instruments XDS110 USB )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, PRODUCT.TITLE, Texas Instruments XDS110 USB ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, PRODUCT.ALIAS, TI_XDS110_USB )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, PRODUCT.ALIAS, TI_XDS110_USB ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, PRODUCT.NAME, XDS110 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, PRODUCT.NAME, XDS110 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, USCIF.TDOEDGE, FALL )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, USCIF.TDOEDGE, FALL ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, USCIF.TCLK_PROGRAM, DEFAULT )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, USCIF.TCLK_PROGRAM, DEFAULT ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, USCIF.TCLK_FREQUENCY, 5.5MHz )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, USCIF.TCLK_FREQUENCY, 5.5MHz ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, USCIF.JTAG_ISOLATE, disable )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, USCIF.JTAG_ISOLATE, disable ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, DOT7.DTS_USAGE, enable )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, DOT7.DTS_USAGE, enable ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, DOT7.DTS_TYPE, xds110 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, DOT7.DTS_TYPE, xds110 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, DOT7.DTS_PROGRAM, emulator )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, DOT7.DTS_PROGRAM, emulator ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, DOT7.DTS_FREQUENCY, 1.0MHz )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, DOT7.DTS_FREQUENCY, 1.0MHz ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, DOT7.TS_FORMAT, oscan2 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, DOT7.TS_FORMAT, oscan2 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, DOT7.TS_PIN_WIDTH, only_two )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, DOT7.TS_PIN_WIDTH, only_two ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, SWD.SWD_DEBUG, disabled )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, SWD.SWD_DEBUG, disabled ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, SWD.SWO_DATA, tdo_pin )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, SWD.SWO_DATA, tdo_pin ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, SWD.SWJ_DP_DEFAULT_MODE, 0 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, SWD.SWJ_DP_DEFAULT_MODE, 0 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddDeviceEx( 000001BD35515260, IcePick_C, 240, 2, 0, 5, ROUTER, 4294967295, 0, 2 )
0x00001CD4 50576 3  GTI R: JTAGData_AddDeviceEx( 000001BD35515260, IcePick_C, 240, 2, 0, 5, ROUTER, 4294967295, 0, 2 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, device.SystemResetSupported, 1 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, device.SystemResetSupported, 1 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, device.SystemResetWhileConnected, 1 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, device.SystemResetWhileConnected, 1 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddSubpath( 000001BD35515260, subpath_2, IcePick_C, 1 )
0x00001CD4 50576 3  GTI R: JTAGData_AddSubpath( 000001BD35515260, subpath_2, IcePick_C, 1 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, subpath.address, 0x0 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, subpath.address, 0x0 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, subpath.initial, 0 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, subpath.initial, 0 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, subpath.custom, 1 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, subpath.custom, 1 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, subpath.force, 1 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, subpath.force, 1 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, subpath.cancelreset, 0x1 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, subpath.cancelreset, 0x1 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddDevice( 000001BD35515260, bypass_0, 1023, 4095, 127, 7, BYPASS, 4 )
0x00001CD4 50576 3  GTI R: JTAGData_AddDevice( 000001BD35515260, bypass_0, 1023, 4095, 127, 7, BYPASS, 4 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddSubpath( 000001BD35515260, subpath_0, IcePick_C, 1 )
0x00001CD4 50576 3  GTI R: JTAGData_AddSubpath( 000001BD35515260, subpath_0, IcePick_C, 1 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, subpath.address, 0x10 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, subpath.address, 0x10 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddDeviceEx( 000001BD35515260, CS_DAP_0, 224, 1, 0, 5, ROUTER, 4294967295, 0, 1 )
0x00001CD4 50576 3  GTI R: JTAGData_AddDeviceEx( 000001BD35515260, CS_DAP_0, 224, 1, 0, 5, ROUTER, 4294967295, 0, 1 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, device.identify, 0x4ba00477 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, device.identify, 0x4ba00477 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, device.Revision, Legacy )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, device.Revision, Legacy ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddSubpath( 000001BD35515260, subpath_1, CS_DAP_0, 1 )
0x00001CD4 50576 3  GTI R: JTAGData_AddSubpath( 000001BD35515260, subpath_1, CS_DAP_0, 1 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, subpath.type, debug )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, subpath.type, debug ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, subpath.pseudo, 0 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, subpath.pseudo, 0 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddDevice( 000001BD35515260, Cortex_M4_0, 470, 14, 0, 0, DSP_CPU, -1 )
0x00001CD4 50576 3  GTI R: JTAGData_AddDevice( 000001BD35515260, Cortex_M4_0, 470, 14, 0, 0, DSP_CPU, -1 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, device.identify, 0x02000000 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, device.identify, 0x02000000 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_AddVariableEx( 000001BD35515260, device.traceId, 0x0 )
0x00001CD4 50576 3  GTI R: JTAGData_AddVariableEx( 000001BD35515260, device.traceId, 0x0 ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_Output( 000001BD35515260, C:\Users\o.gaste\.TI-trace\data\temp0.dat )
0x00001CD4 50576 3  GTI R: JTAGData_Output( 000001BD35515260, C:\Users\o.gaste\.TI-trace\data\temp0.dat ) = 1
0x00001CD4 50576 3  GTI C: JTAGData_DestroyJtagDeviceList( 000001BD35515260 )
0x00001CD4 50576 3  GTI R: JTAGData_DestroyJtagDeviceList( 000001BD35515260 ) = 0000000000000000
0x00001CD4 50654 3 IcePick_C CI C: GetLabel( 0000000DAD8FC6A0, 260 )
0x00001CD4 50654 3 IcePick_C CI R: GetLabel( *0000000DAD8FC6A0 = Texas Instruments XDS110 USB Debug Probe/IcePick_C, 260 ) = 0
0x00001CD4 50654 3 IcePick_C TA C: IsSimulator()
0x00001CD4 50654 3 IcePick_C TA R: IsSimulator() = false
0x00001CD4 50654 3 IcePick_C CI C: GetType()
0x00001CD4 50654 3 IcePick_C CI R: GetType() = 0x000007D0
0x00001CD4 50654 3 IcePick_C TA C: RegisterForEvents( 000001BD359D3640 )
0x00001CD4 50654 3 IcePick_C TA R: RegisterForEvents( 000001BD359D3640 )
0x00001CD4 50654 3  CT R: JobMgrIFDS::AddTarget( 000001BD3DBD74E0, 0000000000000000 ) = 0
0x00001CD4 50654 3  PERF I: Ctools AddTarget() finished:  0.154023s wall, 0.015625s user + 0.078125s system = 0.093750s CPU (60.9%)
0x00001CD4 50654 3  LIB C: dlsym( 00007FFEDF810000, "QueryInterface" )
0x00001CD4 50654 3  LIB R: dlsym( 00007FFEDF810000, "QueryInterface" ) = 00007FFEDF81FA50
0x00001CD4 50654 3  PERF I: Ctools QueryInterface( 0 ) starting...
0x00001CD4 50654 3 IcePick_C CT C: QueryInterface( 000001BD3DBD74E0, 0 )
0x00001CD4 50654 3 IcePick_C CI C: GetLabel( 0000000DAD8FD410, 1024 )
0x00001CD4 50654 3 IcePick_C CI R: GetLabel( *0000000DAD8FD410 = Texas Instruments XDS110 USB Debug Probe/IcePick_C, 1024 ) = 0
0x00001CD4 50654 3 IcePick_C TA C: GetRegisterId( IP_TAPID, 0000000DAD8FD594 )
0x00001CD4 50654 3 IcePick_C TA C: GetRegisterId( IP_TAPID, 0x0000000000000000 )
0x00001CD4 50654 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='IP_TAPID' AND Register_Cache.Processor=33
0x00001CD4 50654 3 IcePick_C TA R: GetRegisterId( IP_TAPID, 0x0000000000000001 ) = 0
0x00001CD4 50654 3 IcePick_C TA R: GetRegisterId( IP_TAPID, *0000000DAD8FD594 = 0x00000001 ) = 0
0x00001CD4 50654 3 IcePick_C TA C: RegisterRead( 0x0000000000000001, 0x0000000000000001 )
0x00001CD4 50654 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775807 AND Register_Cache.Address<=-9223372036854775807 AND Register_Cache.Page=121 AND Register_Cache.Processor=33
0x00001CD4 50654 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000001, *0x0000000DAD8FC818 = 0x00000000 )
0x00001CD4 50654 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 50654 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 50654 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000001, *0x0000000DAD8FC818 = 0x3BB4102F ) = 0x00000000
0x00001CD4 50654 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FBF98 = 0x00000000, *0x0000000DAD8FBF90 = 0x00000000, *0x0000000DAD8FBFA8 = 0x00000000, *0x0000000DAD8FBFC0 = 0x00000000, *0x0000000DAD8FBFC8 = 0x00000000, *0x0000000DAD8FBFB8 = 0x00000000, *0x0000000DAD8FBFB0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50654 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FBF98 = 0x00000000, *0x0000000DAD8FBF90 = 0x00000000, *0x0000000DAD8FBFA8 = 0x00000000, *0x0000000DAD8FBFC0 = 0x00000002, *0x0000000DAD8FBFC8 = 0x00000000, *0x0000000DAD8FBFB8 = 0x00000008, *0x0000000DAD8FBFB0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50654 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FBE68 = 0x00000000, *0x0000000DAD8FBE60 = 0x00000000, *0x0000000DAD8FBE78 = 0x00000000, *0x0000000DAD8FBE90 = 0x00000000, *0x0000000DAD8FBE98 = 0x00000000, *0x0000000DAD8FBE88 = 0x00000000, *0x0000000DAD8FBE80 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50654 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FBE68 = 0x00000000, *0x0000000DAD8FBE60 = 0x00000000, *0x0000000DAD8FBE78 = 0x00000000, *0x0000000DAD8FBE90 = 0x00000002, *0x0000000DAD8FBE98 = 0x00000000, *0x0000000DAD8FBE88 = 0x00000008, *0x0000000DAD8FBE80 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50654 3 IcePick_C TA R: RegisterRead( 0x0000000000000001, 0x000000003BB4102F ) = 0
0x00001CD4 50654 3 IcePick_C TA C: GetRegisterId( CFGAP_USERCODE, 0000000DAD8FD6B0 )
0x00001CD4 50654 3 IcePick_C TA C: GetRegisterId( CFGAP_USERCODE, 0x0000000000000000 )
0x00001CD4 50654 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='CFGAP_USERCODE' AND Register_Cache.Processor=33
0x00001CD4 50654 3 IcePick_C TA R: GetRegisterId( CFGAP_USERCODE, 0x0000000000000000 ) = -1
0x00001CD4 50654 3 IcePick_C TA R: GetRegisterId( CFGAP_USERCODE, *0000000DAD8FD6B0 = 0x00000000 ) = -1
0x00001CD4 50670 3  SETUP C: OpenDatabase( C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\targetdb.dat, C:\ti\ccs1200\ccs\ccs_base\common\targetdb\timestamp )
0x00001CD4 50670 3  SETUP I: SELECT sql FROM sqlite_master ORDER BY tbl_name, name
0x00001CD4 50670 3  SETUP R: OpenDatabase( C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\targetdb.dat, C:\ti\ccs1200\ccs\ccs_base\common\targetdb\timestamp ) = 000001BD2C371820
0x00001CD4 50670 3  SETUP I: Loading repository "C:\ti\ccs1200\ccs\ccs_base\common\targetdb\"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Repositories
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Repositories WHERE dbid=1
0x00001CD4 50670 3  SETUP I: PRAGMA journal_mode = MEMORY
0x00001CD4 50670 3  SETUP I: PRAGMA synchronous = OFF
0x00001CD4 50670 3  SETUP I: BEGIN IMMEDIATE TRANSACTION
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="CS_DAP_0_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=1
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="CS_DAP_PC_0_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=2
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_C_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=3
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_D_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=4
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_M_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=5
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="regids_mapping.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=6
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2000_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=7
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2001_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=8
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2002_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=9
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2003_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=10
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2004_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=11
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2005_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=12
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2006_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=13
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2007_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=14
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2008_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=15
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2010_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=16
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2011_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=17
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2012_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=18
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2013_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=19
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2014_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=20
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2015_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=21
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2026_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=22
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2027_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=23
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2028_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=24
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2029_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=25
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2030_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=26
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2031_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=27
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2032_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=28
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS225C00_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=29
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS225C100_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=30
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C28XX_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=31
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C55XX_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=32
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C64XX_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=33
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C66XX_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=34
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C674X_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=35
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C6XXX_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=36
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C71XX_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=37
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C75XX_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=38
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS3CXX_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=39
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R15X_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=40
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R25X_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=41
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R2X_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=42
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R33X_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=43
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R4X_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=44
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R53X_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=45
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R7X_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=46
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R9X_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=47
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RAX_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=48
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RCX_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=49
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RDX_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=50
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470REX_regids.xml"
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=51
0x00001CD4 50670 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RXX_regids.xml"
0x00001CD4 50685 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=52
0x00001CD4 50685 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C40XX_regids.xml"
0x00001CD4 50685 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=53
0x00001CD4 50685 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C41XX_regids.xml"
0x00001CD4 50685 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=54
0x00001CD4 50685 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C4X_regids.xml"
0x00001CD4 50685 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=55
0x00001CD4 50685 3  SETUP I: END TRANSACTION
0x00001CD4 50685 3  SETUP I: SELECT count(*) FROM TargetDB_Files WHERE State=0
0x00001CD4 50685 3  SETUP I: Scrubbing database
0x00001CD4 50685 3  SETUP I: Loading file "C:\Users\O08A6~1.GAS\AppData\Local\TEXASI~1\CCS\ccs1200\0\0\2910475632580809234.cache"
0x00001CD4 50685 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="2910475632580809234.cache"
0x00001CD4 50685 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=116
0x00001CD4 50685 3  SETUP I: SELECT Systems.dbid FROM Systems, TargetDB_Files WHERE Systems.Source_File = TargetDB_Files.dbid AND TargetDB_Files.dbid = 116
0x00001CD4 50685 3  SETUP I: SELECT * FROM Systems WHERE dbid=9
0x00001CD4 50685 3  GTI C: JTAGData_CreateJtagDeviceList()
0x00001CD4 50685 3  GTI R: JTAGData_CreateJtagDeviceList() = 000001BD35514060
0x00001CD4 50685 3  GTI C: JTAGData_AddVariable( 000001BD35514060, BOARD_DATAFILE_VERSION, *0000000DAD8FCC70 = 2 )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariable( 000001BD35514060, BOARD_DATAFILE_VERSION, *0000000DAD8FCC70 = 2 ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, SEPK.POD_DRVR, jioxds110.dll )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, SEPK.POD_DRVR, jioxds110.dll ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, SEPK.POD_PORT, 0 )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, SEPK.POD_PORT, 0 ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, SEPK.POD_SUPPLY, 1 )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, SEPK.POD_SUPPLY, 1 ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, SEPK.POD_VOLTAGE_SELECTION, 1 )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, SEPK.POD_VOLTAGE_SELECTION, 1 ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, SEPK.POD_VOLTAGE, 3.3 )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, SEPK.POD_VOLTAGE, 3.3 ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, SEPK.POD_POWER_ISOLATE, 0 )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, SEPK.POD_POWER_ISOLATE, 0 ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, PRODUCT.TITLE, Texas Instruments XDS110 USB )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, PRODUCT.TITLE, Texas Instruments XDS110 USB ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, PRODUCT.ALIAS, TI_XDS110_USB )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, PRODUCT.ALIAS, TI_XDS110_USB ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, PRODUCT.NAME, XDS110 )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, PRODUCT.NAME, XDS110 ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, USCIF.TDOEDGE, FALL )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, USCIF.TDOEDGE, FALL ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, USCIF.TCLK_PROGRAM, DEFAULT )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, USCIF.TCLK_PROGRAM, DEFAULT ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, USCIF.TCLK_FREQUENCY, 5.5MHz )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, USCIF.TCLK_FREQUENCY, 5.5MHz ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, USCIF.JTAG_ISOLATE, disable )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, USCIF.JTAG_ISOLATE, disable ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, DOT7.DTS_USAGE, enable )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, DOT7.DTS_USAGE, enable ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, DOT7.DTS_TYPE, xds110 )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, DOT7.DTS_TYPE, xds110 ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, DOT7.DTS_PROGRAM, emulator )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, DOT7.DTS_PROGRAM, emulator ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, DOT7.DTS_FREQUENCY, 1.0MHz )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, DOT7.DTS_FREQUENCY, 1.0MHz ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, DOT7.TS_FORMAT, oscan2 )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, DOT7.TS_FORMAT, oscan2 ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, DOT7.TS_PIN_WIDTH, only_two )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, DOT7.TS_PIN_WIDTH, only_two ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, SWD.SWD_DEBUG, disabled )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, SWD.SWD_DEBUG, disabled ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, SWD.SWO_DATA, tdo_pin )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, SWD.SWO_DATA, tdo_pin ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, SWD.SWJ_DP_DEFAULT_MODE, 0 )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, SWD.SWJ_DP_DEFAULT_MODE, 0 ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddDeviceEx( 000001BD35514060, IcePick_C, 240, 2, 0, 5, ROUTER, 4294967295, 0, 2 )
0x00001CD4 50685 3  GTI R: JTAGData_AddDeviceEx( 000001BD35514060, IcePick_C, 240, 2, 0, 5, ROUTER, 4294967295, 0, 2 ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, device.SystemResetSupported, 1 )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, device.SystemResetSupported, 1 ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, device.SystemResetWhileConnected, 1 )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, device.SystemResetWhileConnected, 1 ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddSubpath( 000001BD35514060, subpath_2, IcePick_C, 1 )
0x00001CD4 50685 3  GTI R: JTAGData_AddSubpath( 000001BD35514060, subpath_2, IcePick_C, 1 ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, subpath.address, 0x0 )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, subpath.address, 0x0 ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, subpath.initial, 0 )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, subpath.initial, 0 ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, subpath.custom, 1 )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, subpath.custom, 1 ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, subpath.force, 1 )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, subpath.force, 1 ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, subpath.cancelreset, 0x1 )
0x00001CD4 50685 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, subpath.cancelreset, 0x1 ) = 1
0x00001CD4 50685 3  GTI C: JTAGData_AddDevice( 000001BD35514060, bypass_0, 1023, 4095, 127, 7, BYPASS, 4 )
0x00001CD4 50701 3  GTI R: JTAGData_AddDevice( 000001BD35514060, bypass_0, 1023, 4095, 127, 7, BYPASS, 4 ) = 1
0x00001CD4 50701 3  GTI C: JTAGData_AddSubpath( 000001BD35514060, subpath_0, IcePick_C, 1 )
0x00001CD4 50701 3  GTI R: JTAGData_AddSubpath( 000001BD35514060, subpath_0, IcePick_C, 1 ) = 1
0x00001CD4 50701 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, subpath.address, 0x10 )
0x00001CD4 50701 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, subpath.address, 0x10 ) = 1
0x00001CD4 50701 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, subpath.initial, 0 )
0x00001CD4 50701 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, subpath.initial, 0 ) = 1
0x00001CD4 50701 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, subpath.custom, 1 )
0x00001CD4 50701 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, subpath.custom, 1 ) = 1
0x00001CD4 50701 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, subpath.force, 1 )
0x00001CD4 50701 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, subpath.force, 1 ) = 1
0x00001CD4 50701 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, subpath.cancelreset, 0x1 )
0x00001CD4 50701 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, subpath.cancelreset, 0x1 ) = 1
0x00001CD4 50701 3  GTI C: JTAGData_AddDeviceEx( 000001BD35514060, CS_DAP_0, 224, 1, 0, 5, ROUTER, 4294967295, 0, 1 )
0x00001CD4 50701 3  GTI R: JTAGData_AddDeviceEx( 000001BD35514060, CS_DAP_0, 224, 1, 0, 5, ROUTER, 4294967295, 0, 1 ) = 1
0x00001CD4 50701 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, device.identify, 0x4ba00477 )
0x00001CD4 50701 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, device.identify, 0x4ba00477 ) = 1
0x00001CD4 50701 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, device.Revision, Legacy )
0x00001CD4 50701 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, device.Revision, Legacy ) = 1
0x00001CD4 50701 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, device.SystemResetWhileConnected, 1 )
0x00001CD4 50701 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, device.SystemResetWhileConnected, 1 ) = 1
0x00001CD4 50701 3  GTI C: JTAGData_AddSubpath( 000001BD35514060, subpath_1, CS_DAP_0, 1 )
0x00001CD4 50701 3  GTI R: JTAGData_AddSubpath( 000001BD35514060, subpath_1, CS_DAP_0, 1 ) = 1
0x00001CD4 50701 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, subpath.address, 0x0 )
0x00001CD4 50701 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, subpath.address, 0x0 ) = 1
0x00001CD4 50701 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, subpath.type, debug )
0x00001CD4 50701 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, subpath.type, debug ) = 1
0x00001CD4 50701 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, subpath.pseudo, 0 )
0x00001CD4 50701 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, subpath.pseudo, 0 ) = 1
0x00001CD4 50701 3  GTI C: JTAGData_AddDevice( 000001BD35514060, Cortex_M4_0, 470, 14, 0, 0, DSP_CPU, -1 )
0x00001CD4 50701 3  GTI R: JTAGData_AddDevice( 000001BD35514060, Cortex_M4_0, 470, 14, 0, 0, DSP_CPU, -1 ) = 1
0x00001CD4 50701 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, device.identify, 0x02000000 )
0x00001CD4 50701 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, device.identify, 0x02000000 ) = 1
0x00001CD4 50701 3  GTI C: JTAGData_AddVariableEx( 000001BD35514060, device.traceId, 0x0 )
0x00001CD4 50701 3  GTI R: JTAGData_AddVariableEx( 000001BD35514060, device.traceId, 0x0 ) = 1
0x00001CD4 50701 3  GTI C: JTAGData_Output( 000001BD35514060, C:\Users\o.gaste\.TI-trace\data\temp0.dat )
0x00001CD4 50701 3  GTI R: JTAGData_Output( 000001BD35514060, C:\Users\o.gaste\.TI-trace\data\temp0.dat ) = 1
0x00001CD4 50701 3  GTI C: JTAGData_DestroyJtagDeviceList( 000001BD35514060 )
0x00001CD4 50701 3  GTI R: JTAGData_DestroyJtagDeviceList( 000001BD35514060 ) = 0000000000000000
0x00001CD4 50701 3 IcePick_C CT R: QueryInterface( 000001BD3DBD74E0, 0 ) = 0000000000000000
0x00001CD4 50701 3  PERF I: Ctools QueryInterface( 0 ) finished:  0.041604s wall, 0.000000s user + 0.046875s system = 0.046875s CPU (112.7%)
0x00001CD4 50701 3  LIB C: dlsym( 00007FFEDF810000, "QueryInterface" )
0x00001CD4 50701 3  LIB R: dlsym( 00007FFEDF810000, "QueryInterface" ) = 00007FFEDF81FA50
0x00001CD4 50701 3  PERF I: Ctools QueryInterface( 3 ) starting...
0x00001CD4 50701 3 IcePick_C CT C: QueryInterface( 000001BD3DBD74E0, 3 )
0x00001CD4 50701 3 IcePick_C CI C: GetLabel( 0000000DAD8FD410, 1024 )
0x00001CD4 50701 3 IcePick_C CI R: GetLabel( *0000000DAD8FD410 = Texas Instruments XDS110 USB Debug Probe/IcePick_C, 1024 ) = 0
0x00001CD4 50701 3 IcePick_C CT R: QueryInterface( 000001BD3DBD74E0, 3 ) = 0000000000000000
0x00001CD4 50701 3  PERF I: Ctools QueryInterface( 3 ) finished:  0.000081s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 50701 3  PERF I: Ctools QueryInterface( 2 ) starting...
0x00001CD4 50701 3 IcePick_C CT C: QueryInterface( 000001BD3DBD74E0, 2 )
0x00001CD4 50701 3 IcePick_C CI C: GetLabel( 0000000DAD8FD670, 1024 )
0x00001CD4 50701 3 IcePick_C CI R: GetLabel( *0000000DAD8FD670 = Texas Instruments XDS110 USB Debug Probe/IcePick_C, 1024 ) = 0
0x00001CD4 50701 3 IcePick_C CT R: QueryInterface( 000001BD3DBD74E0, 2 ) = 0000000000000000
0x00001CD4 50701 3  PERF I: Ctools QueryInterface( 2 ) finished:  0.000053s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 50701 3  PERF I: Ctools QueryInterface( 1 ) starting...
0x00001CD4 50701 3 IcePick_C CT C: QueryInterface( 000001BD3DBD74E0, 1 )
0x00001CD4 50701 3 IcePick_C CI C: GetLabel( 0000000DAD8FD760, 1024 )
0x00001CD4 50701 3 IcePick_C CI R: GetLabel( *0000000DAD8FD760 = Texas Instruments XDS110 USB Debug Probe/IcePick_C, 1024 ) = 0
0x00001CD4 50701 3 IcePick_C CT R: QueryInterface( 000001BD3DBD74E0, 1 ) = 0000000000000000
0x00001CD4 50701 3  PERF I: Ctools QueryInterface( 1 ) finished:  0.000051s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 50701 3  PERF I: GEL OnTargetConnect() starting...
0x00001CD4 50701 3  SEQUENCE I: Finished sequence step at 0000000DAD8FDE20
0x00001CD4 50701 3  SEQUENCE I: Beginning class Debugger::GelCallbackStep at 000001BD2952EC30
0x00001CD4 50701 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD548 )
0x00001CD4 50701 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD548 ) = 0x00000000
0x00001CD4 50701 3 IcePick_C TPI C: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD540 )
0x00001CD4 50701 3 IcePick_C TPI R: TpiSvrGenAPI( *000001BD3CDCA000, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD540 ) = 0x00000002
0x00001CD4 50701 3 IcePick_C GEL I: Evaluating "OnTargetConnect()"
0x00001CD4 50701 3 IcePick_C POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 50701 3 IcePick_C POLL C: Firing DSP_PRIORITY_CONNECTED to all DSP_USER's
0x00001CD4 50701 3 IcePick_C POLL C: Firing of DSP_PRIORITY_CONNECTED complete
0x00001CD4 50701 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 50701 3 IcePick_C POLL R: Poll() returning
0x00001CD4 50701 4 IcePick_C POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 50701 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 50701 4  POLL I: Yielding to other threads
0x00001CD4 50701 3 IcePick_C POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 50701 3 IcePick_C POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 50701 3 IcePick_C POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 50701 2 IcePick_C GEL I: cc26xx_icepick.gel:14	Enter function OnTargetConnect
0x00001CD4 50701 3 IcePick_C POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 50701 2 IcePick_C GEL I: cc26xx_icepick.gel:16	   IP_CC26xx_WAKEUPMCU=1
0x00001CD4 50701 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='IP_CC26xx_WAKEUPMCU' AND Register_Cache.Processor=33
0x00001CD4 50701 3  SETUP I: SELECT count(*) FROM Bitfields WHERE parent_dbid=71
0x00001CD4 50701 3 IcePick_C GTI C: GTI_GET_TARGET_PROPERTIES( 0x000001BD29E173E0, 0x00000001 )
0x00001CD4 50701 3 IcePick_C GTI R: GTI_GET_TARGET_PROPERTIES( 0x000001BD29E173E0, 0x00000001 ) = 0x00000001
0x00001CD4 50701 3 IcePick_C POLL D: New request of type DSP_RQ_WRITE_MEM added to polling loop by class VOT::DspAccessorSetRegister
0x00001CD4 50701 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775763 AND Register_Cache.Address<=-9223372036854775763 AND Register_Cache.Page=121 AND Register_Cache.Processor=33
0x00001CD4 50701 3 IcePick_C POLL C: Polling with state STATE_WRITE and status EVENT_DSP_HALT
0x00001CD4 50701 3 IcePick_C GTI C: GTI_WRITEREG( 0x000001BD29E173E0, 0x0000002D, *0x0000000DAD8FDD70 = 0x00000001 )
0x00001CD4 50701 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 50701 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 50701 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50701 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50701 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50701 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50701 3  XDS110 C: Executing command 0x08 (XDS_GETJTAGSTATE)
0x00001CD4 50701 3  XDS110 R: Executed command 0x08 (XDS_GETJTAGSTATE), return code: 0x00000000
0x00001CD4 50701 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 50701 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 50717 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 50717 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 50717 3  XDS110 C: Executing command 0x08 (XDS_GETJTAGSTATE)
0x00001CD4 50717 3  XDS110 R: Executed command 0x08 (XDS_GETJTAGSTATE), return code: 0x00000000
0x00001CD4 50717 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50717 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50732 3  XDS110 R: Executed command 0x08 (XDS_GETJTAGSTATE), return code: 0x00000000
0x00001CD4 50732 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 50732 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 50732 3  XDS110 C: Executing command 0x08 (XDS_GETJTAGSTATE)
0x00001CD4 50748 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 50748 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50748 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50748 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50748 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50748 3  XDS110 C: Executing command 0x08 (XDS_GETJTAGSTATE)
0x00001CD4 50748 3  XDS110 R: Executed command 0x08 (XDS_GETJTAGSTATE), return code: 0x00000000
0x00001CD4 50748 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 50764 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 50764 3  XDS110 C: Executing command 0x08 (XDS_GETJTAGSTATE)
0x00001CD4 50764 3  XDS110 R: Executed command 0x08 (XDS_GETJTAGSTATE), return code: 0x00000000
0x00001CD4 50764 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 50764 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50764 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50780 3  XDS110 R: Executed command 0x08 (XDS_GETJTAGSTATE), return code: 0x00000000
0x00001CD4 50780 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 50780 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 50780 3  XDS110 C: Executing command 0x08 (XDS_GETJTAGSTATE)
0x00001CD4 50780 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50780 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50780 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 50780 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 50780 3 IcePick_C GTI R: GTI_WRITEREG( 0x000001BD29E173E0, 0x0000002D, *0x0000000DAD8FDD70 = 0x00000001 ) = 0x00000000
0x00001CD4 50780 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD668 = 0x00000000, *0x0000000DAD8FD660 = 0x00000000, *0x0000000DAD8FD678 = 0x00000000, *0x0000000DAD8FD690 = 0x00000000, *0x0000000DAD8FD698 = 0x00000000, *0x0000000DAD8FD688 = 0x00000000, *0x0000000DAD8FD680 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50780 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD668 = 0x00000000, *0x0000000DAD8FD660 = 0x00000000, *0x0000000DAD8FD678 = 0x00000000, *0x0000000DAD8FD690 = 0x00000002, *0x0000000DAD8FD698 = 0x00000000, *0x0000000DAD8FD688 = 0x00000008, *0x0000000DAD8FD680 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50780 3 IcePick_C POLL C: Firing DSP_MEM_EVENT to all DSP_USER's
0x00001CD4 50780 3 IcePick_C POLL C: Firing of DSP_MEM_EVENT complete
0x00001CD4 50780 3 IcePick_C POLL C: Firing DSP_TARGET_ACCESSED to all DSP_USER's
0x00001CD4 50780 3 IcePick_C POLL C: Firing of DSP_TARGET_ACCESSED complete
0x00001CD4 50780 3 IcePick_C POLL C: Firing DSP_REQ_EVENT to class VOT::DspAccessorSetRegister
0x00001CD4 50780 2 IcePick_C GEL I: cc26xx_icepick.gel:16	Leave function OnTargetConnect
0x00001CD4 50780 3 IcePick_C GEL I: Evaluation of "OnTargetConnect()" completed - Value: 0 Location: unknown
0x00001CD4 50780 3  SEQUENCE I: Finished sequence step at 000001BD2952EC30
0x00001CD4 50780 3  SEQUENCE I: Beginning class Debugger::LambdaSequenceStep<class <lambda_20ba4389354718687b046855860a9400> > at 000001BD3CDCBC60
0x00001CD4 50780 3  PERF I: GEL OnTargetConnect() finished:  0.087003s wall, 0.000000s user + 0.015625s system = 0.015625s CPU (18.0%)
0x00001CD4 50780 3  SEQUENCE I: Finished sequence step at 000001BD3CDCBC60
0x00001CD4 50780 3  SEQUENCE I: Beginning class `anonymous namespace'::WaitForValidState at 000001BD2C371A90
0x00001CD4 50780 3  SEQUENCE I: Finished sequence step at 000001BD2C371A90
0x00001CD4 50780 3  SEQUENCE I: Beginning class `anonymous namespace'::CallGelResetStep at 000001BD3DC651C0
0x00001CD4 50780 3  SEQUENCE I: Finished sequence step at 000001BD3DC651C0
0x00001CD4 50780 3  SEQUENCE I: Beginning class Debugger::InitializeFlashMgrStep at 000001BD3CDCC120
0x00001CD4 50780 3 IcePick_C GTI C: GTI_GET_TARGET_PROPERTIES( 0x000001BD29E173E0, 0x00000001 )
0x00001CD4 50780 3 IcePick_C GTI R: GTI_GET_TARGET_PROPERTIES( 0x000001BD29E173E0, 0x00000001 ) = 0x00000001
0x00001CD4 50780 3 IcePick_C FLASH I: Enqueuing a call to FlashOperations::Initialize() on a side thread
0x00001CD4 50780 3 IcePick_C POLL C: Firing DSP_TARGET_WRITE to all DSP_USER's
0x000021B8 50780 3 IcePick_C FLASH I: FlashOperations::Constructor
0x00001CD4 50780 3  COM_DBG_IF C: class DSP_CO_USER::OnRefresh()
0x00001CD4 50780 3  XPCOM C: ( (dsINumberEventCallback*)000001BD29E60350 )->onEvent( 0x000000000000000A )
0x00001CD4 50780 3  XPCOM R: ( (dsINumberEventCallback*)000001BD29E60350 )->onEvent( 0x000000000000000A ) = 0x00000000
0x00001CD4 50780 3  COM_DBG_IF R: class DSP_CO_USER::OnRefresh()
0x00001CD4 50780 3 IcePick_C POLL C: Firing of DSP_TARGET_WRITE complete
0x00001CD4 50780 3 IcePick_C POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 50780 4 IcePick_C POLL I: Yielding to other threads
0x000021B8 50780 3 IcePick_C FLASH C: FlashOperations::Initialize()
0x00001CD4 50780 3 IcePick_C POLL R: Poll() returning
0x000021B8 50780 3 IcePick_C FLASH I: FlashOperations::Initialize(), isSimulator = false
0x000021B8 50780 3 IcePick_C FLASH I: FlashOperations::Initialize(), targetType = ICEPick_C
0x000021B8 50780 3 IcePick_C FLASH I: FlashOperations::Initialize(), fullpath = Texas Instruments XDS110 USB Debug Probe/IcePick_C
0x000021B8 50780 3 IcePick_C FLASH I: FlashOperations::Initialize(), targetVariant = CC2642R1F
0x00001CD4 50780 4 IcePick_C POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 50780 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 50780 4  POLL I: Yielding to other threads for 10 ms
0x000021B8 50780 3 IcePick_C FLASH C: FlashOperations::MatchFlashDLL( JTAG, ICEPick_C, CC2642R1F, C:\ti\ccs1200\ccs\ccs_base\DebugServer\bin\ )
0x000021B8 50780 3 IcePick_C FLASH R: FlashOperations::MatchFlashDLL() = false, DLL name = , m_bNeedsFlashProperties = false, m_bNeedsFlashUtility = false, m_iBackupType = 0
0x000021B8 50780 3 IcePick_C FLASH R: FlashOperations::Initialize(), Flash programming not supported on current device.
0x000021B8 50780 3 IcePick_C POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 50780 3 IcePick_C POLL C: Polling with state STATE_IDLE_STATUS_CHECK and status EVENT_DSP_HALT
0x00001CD4 50780 3 IcePick_C GTI C: GTI_STAT( 0x000001BD29E173E0 )
0x00001CD4 50796 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50796 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50796 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50796 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50811 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50811 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50811 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50811 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50827 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50827 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50827 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50827 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50843 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50843 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50843 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50843 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50858 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50858 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50859 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50859 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50859 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50859 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50875 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50875 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50875 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50875 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50875 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 50875 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 50875 3 IcePick_C GTI R: GTI_STAT( 0x000001BD29E173E0 ) = 0x0000000E
0x00001CD4 50875 3 IcePick_C STATE I: Target execution state changed to STATUS_NON_DEBUG_CHANGE
0x00001CD4 50875 3 IcePick_C STATE I: Debugger execution state changed to EVENT_DSP_HALT
0x00001CD4 50875 3 IcePick_C POLL C: Firing DSP_NON_DEBUG_CHANGE to all DSP_USER's
0x00001CD4 50875 3  COM_DBG_IF C: class DSP_CO_USER::OnRefresh()
0x00001CD4 50875 3  XPCOM C: ( (dsINumberEventCallback*)000001BD29E60350 )->onEvent( 0x0000000000000008 )
0x00001CD4 50875 3  XPCOM R: ( (dsINumberEventCallback*)000001BD29E60350 )->onEvent( 0x0000000000000008 ) = 0x00000000
0x00001CD4 50875 3  COM_DBG_IF R: class DSP_CO_USER::OnRefresh()
0x00001CD4 50875 3 IcePick_C POLL C: Firing of DSP_NON_DEBUG_CHANGE complete
0x00001CD4 50875 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 50875 3 IcePick_C POLL R: Poll() returning
0x00001CD4 50875 4 IcePick_C POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 50875 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 50875 4  POLL I: Yielding to other threads
0x00001CD4 50875 3 IcePick_C POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 50875 3 IcePick_C POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 50875 3 IcePick_C POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 50875 3  SEQUENCE I: Finished sequence step at 0000000DAD8FD9C0
0x00001CD4 50875 3  SEQUENCE I: Beginning class Debugger::InitializeGelPlugInStep at 000001BD3CDC9DA0
0x00001CD4 50875 3 IcePick_C FLASH C: FlashProgrammerManager::TargetSupported()
0x00001CD4 50875 3 IcePick_C FLASH R: FlashProgrammerManager::TargetSupported() = false
0x00001CD4 50875 3  SEQUENCE I: Finished sequence step at 000001BD3CDC9DA0
0x00001CD4 50875 3  SEQUENCE I: Beginning class Debugger::LambdaSequenceStep<class std::function<void __cdecl(void)> > at 000001BD290C0870
0x00001CD4 50875 3  SEQUENCE I: Finished sequence step at 000001BD3CDCC120
0x00001CD4 50875 3  SEQUENCE I: Beginning class Debugger::PriorityEventStep at 000001BD3CDCBAE0
0x00001CD4 50875 3  SEQUENCE I: Finished sequence step at 000001BD3CDCBAE0
0x00001CD4 50875 3  SEQUENCE I: Finished sequence step at 000001BD290C0870
0x00001CD4 50875 3 IcePick_C POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 50875 3 IcePick_C POLL C: Firing DSP_CONNECTED to all DSP_USER's
0x00001CD4 50875 3 IcePick_C TA C: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::eConnected )
0x00001CD4 50875 3 IcePick_C TA R: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::eConnected )
0x00001CD4 50875 3 CS_DAP_0 POLL C: Firing DSP_PRECONNECT to all DSP_USER's
0x00001CD4 50875 3 CS_DAP_0 POLL C: Firing of DSP_PRECONNECT complete
0x00001CD4 50875 3  SEQUENCE I: Finished sequence step at 0000000DAD8FD960
0x00001CD4 50875 3  SEQUENCE I: Beginning class Debugger::GelCallbackStep at 000001BD2952F0B0
0x00001CD4 50875 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD258 )
0x00001CD4 50875 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD258 ) = 0x00000000
0x00001CD4 50875 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD250 )
0x00001CD4 50875 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD250 ) = 0x00000002
0x00001CD4 50875 3 CS_DAP_0 GEL I: Evaluating "OnPreTargetConnect()"
0x00001CD4 50875 3 CS_DAP_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 50875 3  COM_DBG_IF C: class DSP_CO_USER::OnConnected()
0x00001CD4 50875 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD29E5FDD0 )->onEvent()
0x00001CD4 50875 3  XPCOM C: ( (dsIConnectDisconnect*)000001BD29180F88 )->connectionStatus( 0000000DAD8FC4A0 )
0x00001CD4 50875 3  XPCOM R: ( (dsIConnectDisconnect*)000001BD29180F88 )->connectionStatus( *0000000DAD8FC4A0 = 0x00000000 ) = 0x00000000
0x00001CD4 50875 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD29E5FDD0 )->onEvent() = 0x00000000
0x00001CD4 50875 3  COM_DBG_IF R: class DSP_CO_USER::OnConnected()
0x00001CD4 50875 3  XPCOM C: ( (dsINumberEventCallback*)000001BD29E60350 )->onEvent( 0x0000000000000003 )
0x00001CD4 50875 3  XPCOM R: ( (dsINumberEventCallback*)000001BD29E60350 )->onEvent( 0x0000000000000003 ) = 0x00000000
0x00001CD4 50875 3  COM_DBG_IF C: class DSP_CO_USER::OnAllowedUserAccessesChanged()
0x00001CD4 50875 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD29E5FF50 )->onEvent()
0x00003E54 50875 3  XPCOM C: ( (dsIBreakpointManager*)000001BD297E3F70 )->NumBreakpointTypes( 0000000DAA8FE650 )
0x00001CD4 50875 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD29E5FF50 )->onEvent() = 0x00000000
0x00001CD4 50875 3  COM_DBG_IF R: class DSP_CO_USER::OnAllowedUserAccessesChanged()
0x00001CD4 50875 3 IcePick_C POLL C: Firing of DSP_CONNECTED complete
0x00003E54 50875 3  XPCOM R: ( (dsIBreakpointManager*)000001BD297E3F70 )->NumBreakpointTypes( *0000000DAA8FE650 = 0x00000000 ) = 0x00000000
0x00001CD4 50875 3 CS_DAP_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 50875 4 CS_DAP_0 POLL I: Yielding to other threads
0x00001CD4 50875 3 CS_DAP_0 POLL R: Poll() returning
0x00001CD4 50875 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 50875 4  POLL I: TimeToSleep() found shorter sleep time of 500 ms from class DevicePollFrequencyManager
0x00001CD4 50875 4 CS_DAP_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 50875 3 CS_DAP_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00003E54 50875 3  XPCOM C: ( (dsIDebugProperties*)000001BD2C543570 )->getProperty( EnableInstalledBreakpoint, 0000000DAA8FE6F8 )
0x00001CD4 50875 3 CS_DAP_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00003E54 50875 3  XPCOM R: ( (dsIDebugProperties*)000001BD2C543570 )->getProperty( EnableInstalledBreakpoint, *0000000DAA8FE6F8 = 000001BD35FC60D0 ) = 0x00000000
0x00001CD4 50875 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='OnPreTargetConnect()' AND Register_Cache.Processor=34
0x00003E54 50875 3  XPCOM C: ( (dsIProperty*)000001BD35FC60D0 )->getPropertyType( 0000000DAA8FE690 )
0x00003E54 50875 3  XPCOM R: ( (dsIProperty*)000001BD35FC60D0 )->getPropertyType( *0000000DAA8FE690 = 0x00000000 ) = 0x00000000
0x00003E54 50875 3  XPCOM C: ( (dsIProperty*)000001BD35FC60D0 )->queryInterface( 000001BD30135EE0, 0000000DAA8FE688 )
0x00003E54 50875 3  XPCOM R: ( (dsIProperty*)000001BD35FC60D0 )->queryInterface( 000001BD30135EE0, *0000000DAA8FE688 = 000001BD35FC6170 ) = 0x00000000
0x00003E54 50875 3  XPCOM C: ( (dsIBooleanProperty*)000001BD35FC6170 )->queryInterface( 000001BD30135D40, 0000000DAA8FE628 )
0x00003E54 50875 3  XPCOM R: ( (dsIBooleanProperty*)000001BD35FC6170 )->queryInterface( 000001BD30135D40, *0000000DAA8FE628 = 000001BD35FC6170 ) = 0x00000000
0x00003E54 50875 3  XPCOM C: ( (dsIBooleanProperty*)000001BD35FC6170 )->CurValue( 0000000DAA8FE6F0 )
0x00003E54 50875 3  XPCOM R: ( (dsIBooleanProperty*)000001BD35FC6170 )->CurValue( *0000000DAA8FE6F0 = false ) = 0x00000000
0x00001CD4 50875 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=34 AND Name='OnPreTargetConnect()'
0x00001CD4 50875 3 CS_DAP_0 GEL I: Evaluation of "OnPreTargetConnect()" failed: identifier not found: OnPreTargetConnect()
0x00001CD4 50875 3  SEQUENCE I: Finished sequence step at 000001BD2952F0B0
0x00001CD4 50875 3  SEQUENCE I: Beginning class Debugger::LambdaSequenceStep<class <lambda_d5c2eaa1b9c646e74fc865fbf49efb9b> > at 000001BD3CDC9DA0
0x00001CD4 50875 3 CS_DAP_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 50875 3 CS_DAP_0 POLL C: Polling with state CPU_ST_CONNECT and status EVENT_DSP_HALT
0x00001CD4 50875 3  PERF I: GTI_CONNECT starting...
0x00001CD4 50875 3 CS_DAP_0 GTI C: GTI_CONNECT3( 0x000001BD29E1AA40, 0 )
0x00001CD4 50875 3  PRSC C: PRSC_Connect: prscHandle=0x1bd29e1b120,
0x00001CD4 50875 3  PRSC C: GRTR:SubConnect: routerHandle =0x1bd2b9beca0subPathHandle=0x1bd3d1fe4e0 , numConnections=0x0
0x00001CD4 50875 3  PRSC R: GRTR:SUBConnect: rtn=0x0
0x00001CD4 50875 3  PRSC C: GRTR:SubDisConnect: routerHandle =0x1bd2b9beca0subPathHandle=0x1bd3d1fe4e0,numConnections=0x1
0x00001CD4 50875 3  PRSC R: GRTR:SUBDisConnect: rtn=0x0
0x00001CD4 50875 3  PRSC R: PRSC_Connect: error =0x0
0x00001CD4 50875 3  CMAPI C: OpenEx( 000001BD35055790, 0000000DAD8FDC50 )
0x00001CD4 50875 3  XDS110 C: Executing command 0x0f (CMAPI_CONNECT)
0x00001CD4 50875 3  XDS110 I: Depth0: DpRegRead( address = 0x00000000 ) -> 0x4ba00477 = 0
0x00001CD4 50875 3  XDS110 I: Depth0: DpRegWrite( address = 0x00000004, *value = 0x50000032 ) = 0
0x00001CD4 50875 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 50875 3  XDS110 R: Executed command 0x0f (CMAPI_CONNECT), return code: 0x00000000
0x00001CD4 50891 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 50891 3  CMAPI R: OpenEx( 000001BD35055790, 0000000DAD8FDC50 ) = 0
0x00001CD4 50891 3  CMAPI C: Acquire( 000001BD35055790 )
0x00001CD4 50891 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 50891 3  CMAPI R: Acquire( 000001BD35055790 ) = 0
0x00001CD4 50891 3  CMAPI C: DapRegRead( 000001BD35055790, 1, 0, 0x00000000, 000001BD2AE00478 )
0x00001CD4 50891 3  XDS110 C: Executing command 0x15 (CMAPI_DAPREGREAD)
0x00001CD4 50891 3  XDS110 I: Depth0: DpRegRead( address = 0x00000000 ) -> 0x4ba00477 = 0
0x00001CD4 50891 3  XDS110 R: Executed command 0x15 (CMAPI_DAPREGREAD), return code: 0x00000000
0x00001CD4 50891 3  CMAPI R: DapRegRead( 000001BD35055790, 1, 0, 0x00000000, *000001BD2AE00478 = 0x4BA00477 ) = 0
0x00001CD4 50891 3  CMAPI C: Release( 000001BD35055790 )
0x00001CD4 50891 3  CMAPI R: Release( 000001BD35055790 ) = 0
0x00001CD4 50891 3  CMAPI C: GetStatus( 000001BD35055790, 0000000DAD8FDC68 )
0x00001CD4 50891 3  CMAPI R: GetStatus( 000001BD35055790, *0000000DAD8FDC68 = { 1, 1, 1, 1, 1 } ) = 0
0x00001CD4 50891 3 CS_DAP_0 GTI R: GTI_CONNECT3( 0x000001BD29E1AA40, 0 ) = 0x00000000
0x00001CD4 50891 3  PERF I: GTI_CONNECT finished:  0.012682s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 50891 3 CS_DAP_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E1AA40, *0x0000000DAD8FD878 = 0x00000000, *0x0000000DAD8FD870 = 0x00000000, *0x0000000DAD8FD888 = 0x00000000, *0x0000000DAD8FD8A0 = 0x00000000, *0x0000000DAD8FD8A8 = 0x00000000, *0x0000000DAD8FD898 = 0x00000000, *0x0000000DAD8FD890 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50891 3 CS_DAP_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E1AA40, *0x0000000DAD8FD878 = 0x00000000, *0x0000000DAD8FD870 = 0x00000000, *0x0000000DAD8FD888 = 0x00000000, *0x0000000DAD8FD8A0 = 0x00000002, *0x0000000DAD8FD8A8 = 0x00000000, *0x0000000DAD8FD898 = 0x00000008, *0x0000000DAD8FD890 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 STATE I: Connection state changed to 4
0x00001CD4 50891 3 Cortex_M4_0 POLL C: Firing DSP_DOMAIN_POWERED to all DSP_USER's
0x00001CD4 50891 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_GET_RESET_MODE added to polling loop by class CResetManager
0x00001CD4 50891 3 Cortex_M4_0 POLL C: Firing of DSP_DOMAIN_POWERED complete
0x00001CD4 50891 3 CS_DAP_0 GTI C: GTI_STAT( 0x000001BD29E1AA40 )
0x00001CD4 50891 3  CMAPI C: GetStatus( 000001BD35055790, 0000000DAD8FDA28 )
0x00001CD4 50891 3  CMAPI R: GetStatus( 000001BD35055790, *0000000DAD8FDA28 = { 1, 1, 1, 1, 1 } ) = 0
0x00001CD4 50891 3 CS_DAP_0 GTI R: GTI_STAT( 0x000001BD29E1AA40 ) = 0x0000000D
0x00001CD4 50891 3 CS_DAP_0 STATE I: Target execution state changed to STATUS_NON_DEBUG_NORMAL
0x00001CD4 50891 3 CS_DAP_0 STATE I: Debugger execution state changed to EVENT_DSP_HALT
0x00001CD4 50891 3 CS_DAP_0 STATE I: Connection state changed to 0
0x00001CD4 50891 3 CS_DAP_0 GTI C: GTI_GETCAPABILITIES( 0x000001BD29E1AA40 )
0x00001CD4 50891 3 CS_DAP_0 GTI R: GTI_GETCAPABILITIES( 0x000001BD29E1AA40 ) = 0x41030010
0x00001CD4 50891 3 CS_DAP_0 GTI C: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E1AA40, 0 )
0x00001CD4 50891 3 CS_DAP_0 GTI R: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E1AA40, 0 ) = 0x41030010
0x00001CD4 50891 3 CS_DAP_0 GTI C: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E1AA40, 2 )
0x00001CD4 50891 3 CS_DAP_0 GTI R: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E1AA40, 2 ) = 0x00000001
0x00001CD4 50891 3 CS_DAP_0 GTI C: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E1AA40, 1 )
0x00001CD4 50891 3 CS_DAP_0 GTI R: GTI_GET_EXT_CAPABILITIES( 0x000001BD29E1AA40, 1 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 GTI C: GTI_GET_PROC_ID( 0x000001BD29E1AA40 )
0x00001CD4 50891 3 CS_DAP_0 GTI R: GTI_GET_PROC_ID( 0x000001BD29E1AA40 ) = 0x38000405
0x00001CD4 50891 3  LIB C: dlsym( 000001BD38F60000, "GTI_GET_PROC_MINOR_ID" )
0x00001CD4 50891 3  LIB R: dlsym( 000001BD38F60000, "GTI_GET_PROC_MINOR_ID" ) = 000001BD38F6A7A0
0x00001CD4 50891 3 CS_DAP_0 GTI C: GTI_GET_PROC_MINOR_ID( 0x000001BD29E1AA40 )
0x00001CD4 50891 3 CS_DAP_0 GTI R: GTI_GET_PROC_MINOR_ID( 0x000001BD29E1AA40 ) = 0x00000001
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_DESTRUCTOR )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2B9B9F90, TPI_GEN_CMD_DESTRUCTOR ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_GET_REVISION, *0000000DAD8FDD70 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_GET_REVISION, *0000000DAD8FDD70 = 0x00000065 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_CONSTRUCTOR, 0x0000000D38000405, 0x00007FFE00000001, 0x000001BD36175A80 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_CONSTRUCTOR, 0x0000000D38000405, 0x00007FFE00000001, 0x000001BD36175A80 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SET_DS_VERSION, 0x0000000D0000000C, 0x00007FFE00000000, 0x000001BD00000000 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SET_DS_VERSION, 0x0000000D0000000C, 0x00007FFE00000000, 0x000001BD00000000 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_NUM_PAGES, *0000000DAD8FDD20 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_NUM_PAGES, *0000000DAD8FDD20 = 0x00000015 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000000 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000000 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000000, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000000, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000000, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000000, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000000, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000000, *0000000DAD8FDBF0 = 0x00000000 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000000, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000000, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000001 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000001, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000001, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000001, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000001, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000001, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000001, *0000000DAD8FDBF0 = 0x00000000 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000001, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000001, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000002 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000002, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000002, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000002, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000002, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000002, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000002, *0000000DAD8FDBF0 = 0x00000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000002, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000002, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000003 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000003 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000003, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000003, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000003, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000003, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000003, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000003, *0000000DAD8FDBF0 = 0x00000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000003, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000003, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000004 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000004 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000004, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000004, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000004, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000004, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000004, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000004, *0000000DAD8FDBF0 = 0x00000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000004, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000004, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000005 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000005 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000005, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000005, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000005, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000005, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000005, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000005, *0000000DAD8FDBF0 = 0x00000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000005, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000005, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000006 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000006 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000006, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000006, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000006, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000006, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000006, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000006, *0000000DAD8FDBF0 = 0x00000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000006, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000006, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000007 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000007 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000007, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000007, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000007, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000007, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000007, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000007, *0000000DAD8FDBF0 = 0x00000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000007, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000007, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000008 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000008 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000008, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000008, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000008, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000008, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000008, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000008, *0000000DAD8FDBF0 = 0x00000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000008, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000008, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000009 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000009 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000009, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000009, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000009, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000009, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000009, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000009, *0000000DAD8FDBF0 = 0x00000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000009, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000009, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000A )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000A ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000A, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000A, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000A, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000A, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000A, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000A, *0000000DAD8FDBF0 = 0x00000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000A, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000A, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000B )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000B ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000B, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000B, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000B, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000B, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000B, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000B, *0000000DAD8FDBF0 = 0x00000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000B, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000B, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000C )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000C ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000C, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000C, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000C, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000C, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000C, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000C, *0000000DAD8FDBF0 = 0x00000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000C, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000C, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000D )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000D ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000D, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000D, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000D, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000D, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000D, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000D, *0000000DAD8FDBF0 = 0x00000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000D, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000D, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000E )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000E ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000E, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000E, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000E, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000E, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000E, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000E, *0000000DAD8FDBF0 = 0x00000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000E, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000E, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000F )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x000000000000000F ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000F, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x000000000000000F, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000F, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x000000000000000F, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000F, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x000000000000000F, *0000000DAD8FDBF0 = 0x00000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000F, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x000000000000000F, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000010 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000010 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000010, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000010, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000010, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000010, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000010, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000010, *0000000DAD8FDBF0 = 0x00000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000010, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000010, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000011 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000011 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000011, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000011, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000011, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000011, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000011, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000011, *0000000DAD8FDBF0 = 0x00000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000011, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000011, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000012 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000012 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000012, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000012, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000012, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000012, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000012, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000012, *0000000DAD8FDBF0 = 0x00000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000012, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000012, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000013 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000013 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000013, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000013, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000013, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000013, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000013, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000013, *0000000DAD8FDBF0 = 0x00000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000013, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000013, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000014 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000014 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000014, 0x0000000DAD8FDBA8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000014, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000014, *0000000DAD8FDBE8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000014, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000014, *0000000DAD8FDBF0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000014, *0000000DAD8FDBF0 = 0x00000001 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000014, *0000000DAD8FDBEC )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000014, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_PAGE, *000001BD290BFEF8 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_DEFAULT_PAGE, *000001BD290BFEF8 = 0x00000000 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_REG_PAGES, *0000000DAD8FDD28, *0000000DAD8FDD20 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_REG_PAGES, *0000000DAD8FDD28 = 0x00000001, *0000000DAD8FDD20 = 0x00000079 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_REGBUS_BITS, 0x0000000DAD8FDBA0, 0x0000000000000079 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_REGBUS_BITS, 0x0000000DAD8FDBA0, 0x0000000000000079 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 GTI C: GTI_GET_NUM_RESETS( 0x000001BD29E1AA40 )
0x00001CD4 50891 3  PRSC C: PRSC_QueryResetCapabilities: prscHandle=0x1bd29e1b120
0x00001CD4 50891 3  PRSC R: PRSC_QueryResetCapabilities: resetType =0x0
0x00001CD4 50891 3 CS_DAP_0 GTI R: GTI_GET_NUM_RESETS( 0x000001BD29E1AA40 ) = 0x00000000
0x00001CD4 50891 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SET_CALLBACK, 0x000001BD3CDCC2E0, 0x00007FFEC49C30E0 )
0x00001CD4 50891 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_SET_CALLBACK, 0x000001BD3CDCC2E0, 0x00007FFEC49C30E0 ) = 0x00000002
0x00001CD4 50891 3 CS_DAP_0 TA C: QueryInterface( 1 )
0x00001CD4 50891 3 CS_DAP_0 TA R: QueryInterface( 1 ) = 000001BD3E2F4438
0x00001CD4 50891 3 CS_DAP_0 TA C: QueryInterface( 3 )
0x00001CD4 50891 3 CS_DAP_0 TA R: QueryInterface( 3 ) = 000001BD3E2F4428
0x00001CD4 50891 3 CS_DAP_0 TA C: QueryInterface( 4 )
0x00001CD4 50891 3 CS_DAP_0 TA R: QueryInterface( 4 ) = 000001BD3E2F4440
0x00001CD4 50891 3  LIB C: dlsym( 00007FFEDF0F0000, "GetcToolsDBMgrIFDS" )
0x00001CD4 50891 3  LIB R: dlsym( 00007FFEDF0F0000, "GetcToolsDBMgrIFDS" ) = 00007FFEDF182DC0
0x00001CD4 50891 3 CS_DAP_0 CT C: GetcToolsDBMgrIFDS( 000001BD3E2F4430, 0000000DAD8FDB78 )
0x00001CD4 50891 3 CS_DAP_0 CI C: GetProcessorID()
0x00001CD4 50891 3 CS_DAP_0 CI R: GetProcessorID() = 0x38000405
0x00001CD4 50891 3 CS_DAP_0 CI C: GetType()
0x00001CD4 50891 3 CS_DAP_0 CI R: GetType() = 0x000003E8
0x00001CD4 50891 3 CS_DAP_0 CI C: GetLabel( 0000000DAD8FD330, 260 )
0x00001CD4 50891 3 CS_DAP_0 CI R: GetLabel( *0000000DAD8FD330 = Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, 260 ) = 0
0x00001CD4 50891 3 CS_DAP_0 CT R: GetcToolsDBMgrIFDS( 000001BD3E2F4430, *0000000DAD8FDB78 = 000001BD2F9C1160 )
0x00001CD4 50891 3  PERF I: Ctools AddTarget() starting...
0x00001CD4 50891 3  CT C: JobMgrIFDS::AddTarget( 000001BD3DBDCB10, 0000000000000000 )
0x00001CD4 50891 3 CS_DAP_0 CI C: GetLabel( 0000000DAD8FD690, 1024 )
0x00001CD4 50891 3 CS_DAP_0 CI R: GetLabel( *0000000DAD8FD690 = Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, 1024 ) = 0
0x00001CD4 50891 3 CS_DAP_0 CI C: GetLabel( 0000000DAD8FD440, 260 )
0x00001CD4 50891 3 CS_DAP_0 CI R: GetLabel( *0000000DAD8FD440 = Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, 260 ) = 0
0x00001CD4 50891 3 CS_DAP_0 TA C: IsSimulator()
0x00001CD4 50891 3 CS_DAP_0 TA R: IsSimulator() = false
0x00001CD4 50891 3 CS_DAP_0 TA C: GetSiliconRevision()
0x00001CD4 50891 3 CS_DAP_0 GTI C: GTI_GET_TARGET_PROPERTIES( 0x000001BD29E1AA40, 0x00000003 )
0x00001CD4 50907 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 50907 3  CMAPI R: Release( 000001BD35055790 ) = 0
0x00001CD4 50907 3 CS_DAP_0 GTI R: GTI_GET_TARGET_PROPERTIES( 0x000001BD29E1AA40, 0x00000003 ) = 0x00000000
0x00001CD4 50907 3 CS_DAP_0 TA R: GetSiliconRevision() = 0
0x00001CD4 50907 3 CS_DAP_0 TA C: IsConnected()
0x00001CD4 50907 3 CS_DAP_0 TA R: IsConnected() = true
0x00001CD4 50907 3 CS_DAP_0 CI C: GetLabel( 0000000DAD8FCC80, 260 )
0x00001CD4 50907 3 CS_DAP_0 CI R: GetLabel( *0000000DAD8FCC80 = Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, 260 ) = 0
0x00001CD4 50907 3 CS_DAP_0 CI C: GetProcessorID()
0x00001CD4 50907 3 CS_DAP_0 CI R: GetProcessorID() = 0x38000405
0x00001CD4 50907 3 CS_DAP_0 CI C: GetLabel( 0000000DAD8FC6A0, 260 )
0x00001CD4 50907 3 CS_DAP_0 CI R: GetLabel( *0000000DAD8FC6A0 = Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, 260 ) = 0
0x00001CD4 50907 3 CS_DAP_0 TA C: IsSimulator()
0x00001CD4 50907 3 CS_DAP_0 TA R: IsSimulator() = false
0x00001CD4 50907 3 CS_DAP_0 CI C: GetType()
0x00001CD4 50907 3 CS_DAP_0 CI R: GetType() = 0x000003E8
0x00001CD4 50907 3 CS_DAP_0 TA C: RegisterForEvents( 000001BD2BBA62E0 )
0x00001CD4 50907 3 CS_DAP_0 TA R: RegisterForEvents( 000001BD2BBA62E0 )
0x00001CD4 50907 3  CT R: JobMgrIFDS::AddTarget( 000001BD3DBDCB10, 0000000000000000 ) = 1
0x00001CD4 50907 3  PERF I: Ctools AddTarget() finished:  0.013378s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 50907 3  LIB C: dlsym( 00007FFEDF810000, "QueryInterface" )
0x00001CD4 50907 3  LIB R: dlsym( 00007FFEDF810000, "QueryInterface" ) = 00007FFEDF81FA50
0x00001CD4 50907 3  PERF I: Ctools QueryInterface( 0 ) starting...
0x00001CD4 50907 3 CS_DAP_0 CT C: QueryInterface( 000001BD3DBDCB10, 0 )
0x00001CD4 50907 3 CS_DAP_0 CI C: GetLabel( 0000000DAD8FD410, 1024 )
0x00001CD4 50907 3 CS_DAP_0 CI R: GetLabel( *0000000DAD8FD410 = Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, 1024 ) = 0
0x00001CD4 50907 3 CS_DAP_0 CT R: QueryInterface( 000001BD3DBDCB10, 0 ) = 0000000000000000
0x00001CD4 50907 3  PERF I: Ctools QueryInterface( 0 ) finished:  0.000071s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 50907 3  PERF I: Ctools QueryInterface( 3 ) starting...
0x00001CD4 50907 3 CS_DAP_0 CT C: QueryInterface( 000001BD3DBDCB10, 3 )
0x00001CD4 50907 3 CS_DAP_0 CT R: QueryInterface( 000001BD3DBDCB10, 3 ) = 0000000000000000
0x00001CD4 50907 3  PERF I: Ctools QueryInterface( 3 ) finished:  0.000041s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 50907 3  PERF I: Ctools QueryInterface( 2 ) starting...
0x00001CD4 50907 3 CS_DAP_0 CT C: QueryInterface( 000001BD3DBDCB10, 2 )
0x00001CD4 50907 3 CS_DAP_0 CI C: GetLabel( 0000000DAD8FD670, 1024 )
0x00001CD4 50907 3 CS_DAP_0 CI R: GetLabel( *0000000DAD8FD670 = Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, 1024 ) = 0
0x00001CD4 50907 3 CS_DAP_0 CT R: QueryInterface( 000001BD3DBDCB10, 2 ) = 0000000000000000
0x00001CD4 50907 3  PERF I: Ctools QueryInterface( 2 ) finished:  0.000031s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 50907 3  PERF I: Ctools QueryInterface( 1 ) starting...
0x00001CD4 50907 3 CS_DAP_0 CT C: QueryInterface( 000001BD3DBDCB10, 1 )
0x00001CD4 50907 3 CS_DAP_0 CI C: GetLabel( 0000000DAD8FD760, 1024 )
0x00001CD4 50907 3 CS_DAP_0 CI R: GetLabel( *0000000DAD8FD760 = Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, 1024 ) = 0
0x00001CD4 50907 3 CS_DAP_0 CT R: QueryInterface( 000001BD3DBDCB10, 1 ) = 0000000000000000
0x00001CD4 50907 3  PERF I: Ctools QueryInterface( 1 ) finished:  0.000031s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 50907 3  PERF I: GEL OnTargetConnect() starting...
0x00001CD4 50907 3  SEQUENCE I: Finished sequence step at 0000000DAD8FDE20
0x00001CD4 50907 3  SEQUENCE I: Beginning class Debugger::GelCallbackStep at 000001BD2952F730
0x00001CD4 50907 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD548 )
0x00001CD4 50907 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD548 ) = 0x00000000
0x00001CD4 50907 3 CS_DAP_0 TPI C: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD540 )
0x00001CD4 50907 3 CS_DAP_0 TPI R: TpiSvrGenAPI( *000001BD2C376170, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD540 ) = 0x00000002
0x00001CD4 50907 3 CS_DAP_0 GEL I: Evaluating "OnTargetConnect()"
0x00001CD4 50907 3 CS_DAP_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 50907 3 CS_DAP_0 POLL C: Firing DSP_PRIORITY_CONNECTED to all DSP_USER's
0x00001CD4 50907 3 CS_DAP_0 POLL C: Firing of DSP_PRIORITY_CONNECTED complete
0x00001CD4 50907 4 CS_DAP_0 POLL I: Yielding to other threads
0x00001CD4 50907 3 CS_DAP_0 POLL R: Poll() returning
0x00001CD4 50907 3 Cortex_M4_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 50907 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 50907 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 50907 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 50907 4  POLL I: TimeToSleep() found shorter sleep time of 500 ms from class DevicePollFrequencyManager
0x00001CD4 50907 4 CS_DAP_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 50907 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 50907 4  POLL I: Yielding to other threads
0x00001CD4 50907 3 CS_DAP_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 50907 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_GET_WIR_MODE and status EVENT_DSP_HALT
0x00001CD4 50907 3 Cortex_M4_0 GTI C: GTI_GET_WAIT_IN_RESET_MODE( 0x000001BD362E2770, *0x0000000DAD8FDFA0 = 0x00000000 )
0x00001CD4 50907 3  PRSC C: PRSC_GetGlobalChildExtendedStatus: prscHandle =0x1bd29e1cbb0
0x00001CD4 50907 3  PRSC C: prsc_SendRouter: connectionNeeded=0x1
0x00001CD4 50907 3  PRSC C: GRTR:Connected: routerHandle=0x1bd2b9beca0
0x00001CD4 50907 3 IcePick_C TA C: IsConnected()
0x00001CD4 50907 3 IcePick_C TA R: IsConnected() = true
0x00001CD4 50907 3  PRSC R: GRTR:Connected: pbConnected =0x1, ret=0x0
0x00001CD4 50907 3  PRSC C: GRTR:GetExtendedRouterStatus: routerHandle=0x1bd2b9beca0,parentHandle=0x1bd3d0baf60, regIndex=0x2
0x00001CD4 50907 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x0000000DAD8FDAE0 )
0x00001CD4 50907 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775806 AND Register_Cache.Address<=-9223372036854775806 AND Register_Cache.Page=121 AND Register_Cache.Processor=33
0x00001CD4 50907 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FDA68 = 0xAD8FDEA0 )
0x00001CD4 50907 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 50907 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50907 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50907 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50907 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50923 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 50923 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FDA68 = 0x2028233F ) = 0x00000000
0x00001CD4 50923 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD1E8 = 0x00000000, *0x0000000DAD8FD1E0 = 0x00000000, *0x0000000DAD8FD1F8 = 0x00000000, *0x0000000DAD8FD210 = 0x00000000, *0x0000000DAD8FD218 = 0x00000000, *0x0000000DAD8FD208 = 0x00000000, *0x0000000DAD8FD200 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50923 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD1E8 = 0x00000000, *0x0000000DAD8FD1E0 = 0x00000000, *0x0000000DAD8FD1F8 = 0x00000000, *0x0000000DAD8FD210 = 0x00000002, *0x0000000DAD8FD218 = 0x00000000, *0x0000000DAD8FD208 = 0x00000008, *0x0000000DAD8FD200 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50923 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD0B8 = 0x00000000, *0x0000000DAD8FD0B0 = 0x00000000, *0x0000000DAD8FD0C8 = 0x00000000, *0x0000000DAD8FD0E0 = 0x00000000, *0x0000000DAD8FD0E8 = 0x00000000, *0x0000000DAD8FD0D8 = 0x00000000, *0x0000000DAD8FD0D0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50923 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD0B8 = 0x00000000, *0x0000000DAD8FD0B0 = 0x00000000, *0x0000000DAD8FD0C8 = 0x00000000, *0x0000000DAD8FD0E0 = 0x00000002, *0x0000000DAD8FD0E8 = 0x00000000, *0x0000000DAD8FD0D8 = 0x00000008, *0x0000000DAD8FD0D0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50923 3 IcePick_C TA R: RegisterRead( 0x0000000000000002, 0x000000002028233F ) = 0
0x00001CD4 50923 3  PRSC C: GRTR:GetRouterStatus: routerHandle=0x1bd2b9beca0,parentHandle=0x1bd3d0baf60, regIndex=0x2
0x00001CD4 50923 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x0000000DAD8FDA60 )
0x00001CD4 50923 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775806 AND Register_Cache.Address<=-9223372036854775806 AND Register_Cache.Page=121 AND Register_Cache.Processor=33
0x00001CD4 50923 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD9E8 = 0xAD8FDB30 )
0x00001CD4 50923 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 50923 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50923 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50923 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50923 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50923 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD9E8 = 0x2028233F ) = 0x00000000
0x00001CD4 50923 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD168 = 0x00000000, *0x0000000DAD8FD160 = 0x00000000, *0x0000000DAD8FD178 = 0x00000000, *0x0000000DAD8FD190 = 0x00000000, *0x0000000DAD8FD198 = 0x00000000, *0x0000000DAD8FD188 = 0x00000000, *0x0000000DAD8FD180 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50923 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD168 = 0x00000000, *0x0000000DAD8FD160 = 0x00000000, *0x0000000DAD8FD178 = 0x00000000, *0x0000000DAD8FD190 = 0x00000002, *0x0000000DAD8FD198 = 0x00000000, *0x0000000DAD8FD188 = 0x00000008, *0x0000000DAD8FD180 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50923 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD038 = 0x00000000, *0x0000000DAD8FD030 = 0x00000000, *0x0000000DAD8FD048 = 0x00000000, *0x0000000DAD8FD060 = 0x00000000, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD058 = 0x00000000, *0x0000000DAD8FD050 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50923 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD038 = 0x00000000, *0x0000000DAD8FD030 = 0x00000000, *0x0000000DAD8FD048 = 0x00000000, *0x0000000DAD8FD060 = 0x00000002, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD058 = 0x00000008, *0x0000000DAD8FD050 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50923 3  PRSC R: GRTR:GetRouterStatus: powerStatus=0x3, exeStatus=0x1, resetStatus=0x7, resetMode=0xa, activeStatus=0xe, clockStatus=0x9,prscRtn=0x0
0x00001CD4 50923 3 IcePick_C TA C: RegisterWrite( 0x0000000000000002, 0x000000002028233F )
0x00001CD4 50923 3 IcePick_C GTI C: GTI_WRITEREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FDA98 = 0x2028233F )
0x00001CD4 50923 3 IcePick_C GTI R: GTI_WRITEREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FDA98 = 0x2028233F ) = 0x00000000
0x00001CD4 50923 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD218 = 0x00000000, *0x0000000DAD8FD210 = 0x00000000, *0x0000000DAD8FD228 = 0x00000000, *0x0000000DAD8FD240 = 0x00000000, *0x0000000DAD8FD248 = 0x00000000, *0x0000000DAD8FD238 = 0x00000000, *0x0000000DAD8FD230 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50923 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD218 = 0x00000000, *0x0000000DAD8FD210 = 0x00000000, *0x0000000DAD8FD228 = 0x00000000, *0x0000000DAD8FD240 = 0x00000002, *0x0000000DAD8FD248 = 0x00000000, *0x0000000DAD8FD238 = 0x00000008, *0x0000000DAD8FD230 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50923 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD0E8 = 0x00000000, *0x0000000DAD8FD0E0 = 0x00000000, *0x0000000DAD8FD0F8 = 0x00000000, *0x0000000DAD8FD110 = 0x00000000, *0x0000000DAD8FD118 = 0x00000000, *0x0000000DAD8FD108 = 0x00000000, *0x0000000DAD8FD100 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50923 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD0E8 = 0x00000000, *0x0000000DAD8FD0E0 = 0x00000000, *0x0000000DAD8FD0F8 = 0x00000000, *0x0000000DAD8FD110 = 0x00000002, *0x0000000DAD8FD118 = 0x00000000, *0x0000000DAD8FD108 = 0x00000008, *0x0000000DAD8FD100 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50923 3 IcePick_C TA R: RegisterWrite( 0x0000000000000002, 0x000000002028233F ) = 0
0x00001CD4 50923 3  PRSC R: GRTR:GetExtendedRouterStatus: powerStatus=0x3, exeStatus=0x1, resetStatus=0x7, resetMode=0xa, activeStatus=0xe, clockStatus=0x9, haltOnResetStatus=0x12, powerLossDetStatus=0x13, prscRtn=0x0
0x00001CD4 50923 3  PRSC C: prsc_SendRouter: error =0x0
0x00001CD4 50923 3  PRSC R: PRSC_GetGlobalChildExStatus: ret=0x0, activeStatus=0xe, clockStatus=0x9, exeStatus=0x1, powerStatus=0x3, resetMode=0xa, resetStatus=0x7, haltOnResetStatus=0x12, powerLossStatus =0x13
0x00001CD4 50923 3 Cortex_M4_0 GTI R: GTI_GET_WAIT_IN_RESET_MODE( 0x000001BD362E2770, *0x0000000DAD8FDFA0 = 0x00000000 ) = 0x00000000
0x00001CD4 50923 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD7D8 = 0x00000000, *0x0000000DAD8FD7D0 = 0x00000000, *0x0000000DAD8FD7E8 = 0x00000000, *0x0000000DAD8FD800 = 0x00000000, *0x0000000DAD8FD808 = 0x00000000, *0x0000000DAD8FD7F8 = 0x00000000, *0x0000000DAD8FD7F0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50923 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD7D8 = 0x00000000, *0x0000000DAD8FD7D0 = 0x00000000, *0x0000000DAD8FD7E8 = 0x00000000, *0x0000000DAD8FD800 = 0x00000002, *0x0000000DAD8FD808 = 0x00000000, *0x0000000DAD8FD7F8 = 0x00000008, *0x0000000DAD8FD7F0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50923 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class CResetManager
0x00001CD4 50923 3 Cortex_M4_0 POLL C: Firing DSP_RESET_MODE_CHANGED to all DSP_USER's
0x00001CD4 50923 3  COM_DBG_IF C: class DSP_CO_USER::OnHaltOnResetChanged()
0x00001CD4 50923 3  COM_DBG_IF R: class DSP_CO_USER::OnHaltOnResetChanged()
0x00001CD4 50923 3 Cortex_M4_0 POLL C: Firing of DSP_RESET_MODE_CHANGED complete
0x00001CD4 50923 3 Cortex_M4_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 50923 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 50923 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 50923 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 468 ms
0x00001CD4 50923 4  POLL I: TimeToSleep() found shorter sleep time of 468 ms from class DevicePollFrequencyManager
0x00001CD4 50923 4 CS_DAP_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 50923 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 50923 4  POLL I: Yielding to other threads
0x00001CD4 50923 3 CS_DAP_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 50923 3 CS_DAP_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 50923 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='OnTargetConnect()' AND Register_Cache.Processor=34
0x00001CD4 50939 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=34 AND Name='OnTargetConnect()'
0x00001CD4 50939 3 CS_DAP_0 GEL I: Evaluation of "OnTargetConnect()" failed: identifier not found: OnTargetConnect()
0x00001CD4 50939 3  SEQUENCE I: Finished sequence step at 000001BD2952F730
0x00001CD4 50939 3  SEQUENCE I: Beginning class Debugger::LambdaSequenceStep<class <lambda_20ba4389354718687b046855860a9400> > at 000001BD3CDC9B60
0x00001CD4 50939 3  PERF I: GEL OnTargetConnect() finished:  0.021365s wall, 0.000000s user + 0.015625s system = 0.015625s CPU (73.1%)
0x00001CD4 50939 3  SEQUENCE I: Finished sequence step at 000001BD3CDC9B60
0x00001CD4 50939 3  SEQUENCE I: Beginning class `anonymous namespace'::WaitForValidState at 000001BD2C375FF0
0x00001CD4 50939 3  SEQUENCE I: Finished sequence step at 000001BD2C375FF0
0x00001CD4 50939 3  SEQUENCE I: Beginning class `anonymous namespace'::CallGelResetStep at 000001BD3DC6B020
0x00001CD4 50939 3  SEQUENCE I: Finished sequence step at 000001BD3DC6B020
0x00001CD4 50939 3  SEQUENCE I: Beginning class Debugger::InitializeFlashMgrStep at 000001BD3CDC9DA0
0x00001CD4 50939 3 CS_DAP_0 GTI C: GTI_GET_TARGET_PROPERTIES( 0x000001BD29E1AA40, 0x00000001 )
0x00001CD4 50939 3 CS_DAP_0 GTI R: GTI_GET_TARGET_PROPERTIES( 0x000001BD29E1AA40, 0x00000001 ) = 0x00000000
0x00001CD4 50939 3 CS_DAP_0 FLASH I: Enqueuing a call to FlashOperations::Initialize() on a side thread
0x00001CD4 50939 3 CS_DAP_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 50939 4 CS_DAP_0 POLL I: Yielding to other threads
0x00001CD4 50939 3 CS_DAP_0 POLL R: Poll() returning
0x00001CD4 50939 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 452 ms
0x00001CD4 50939 4  POLL I: TimeToSleep() found shorter sleep time of 452 ms from class DevicePollFrequencyManager
0x00001CD4 50939 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 50939 4 Cortex_M4_0 POLL I: TimeToPollAgain() target is idle and needs polling in 4984 ms
0x00004770 50939 3 CS_DAP_0 FLASH I: FlashOperations::Constructor
0x00004770 50939 3 CS_DAP_0 FLASH C: FlashOperations::Initialize()
0x00004770 50939 3 CS_DAP_0 FLASH I: FlashOperations::Initialize(), isSimulator = false
0x00004770 50939 3 CS_DAP_0 FLASH I: FlashOperations::Initialize(), targetType = CS_DAP_0
0x00004770 50939 3 CS_DAP_0 FLASH I: FlashOperations::Initialize(), fullpath = Texas Instruments XDS110 USB Debug Probe/CS_DAP_0
0x00004770 50939 3 CS_DAP_0 FLASH I: FlashOperations::Initialize(), targetVariant = CC2642R1F
0x00004770 50939 3 CS_DAP_0 FLASH C: FlashOperations::MatchFlashDLL( JTAG, CS_DAP_0, CC2642R1F, C:\ti\ccs1200\ccs\ccs_base\DebugServer\bin\ )
0x00004770 50939 3 CS_DAP_0 FLASH R: FlashOperations::MatchFlashDLL() = false, DLL name = , m_bNeedsFlashProperties = false, m_bNeedsFlashUtility = false, m_iBackupType = 0
0x00004770 50939 3 CS_DAP_0 FLASH R: FlashOperations::Initialize(), Flash programming not supported on current device.
0x00004770 50939 3 CS_DAP_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 50939 3 CS_DAP_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 50939 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 436 ms
0x00001CD4 50939 4  POLL I: TimeToSleep() found shorter sleep time of 436 ms from class DevicePollFrequencyManager
0x00001CD4 50939 4 CS_DAP_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 50939 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 50939 4  POLL I: Yielding to other threads
0x00001CD4 50939 3 CS_DAP_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 50939 3 CS_DAP_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 50939 3  SEQUENCE I: Finished sequence step at 0000000DAD8FD9C0
0x00001CD4 50939 3  SEQUENCE I: Beginning class Debugger::InitializeGelPlugInStep at 000001BD3CDCD020
0x00001CD4 50939 3 CS_DAP_0 FLASH C: FlashProgrammerManager::TargetSupported()
0x00001CD4 50939 3 CS_DAP_0 FLASH R: FlashProgrammerManager::TargetSupported() = false
0x00001CD4 50939 3  SEQUENCE I: Finished sequence step at 000001BD3CDCD020
0x00001CD4 50939 3  SEQUENCE I: Beginning class Debugger::LambdaSequenceStep<class std::function<void __cdecl(void)> > at 000001BD290C1890
0x00001CD4 50939 3  SEQUENCE I: Finished sequence step at 000001BD3CDC9DA0
0x00001CD4 50939 3  SEQUENCE I: Beginning class Debugger::PriorityEventStep at 000001BD3CDCBAE0
0x00001CD4 50939 3  SEQUENCE I: Finished sequence step at 000001BD3CDCBAE0
0x00001CD4 50939 3  SEQUENCE I: Finished sequence step at 000001BD290C1890
0x00001CD4 50939 3 CS_DAP_0 POLL C: Firing DSP_CONNECTED to all DSP_USER's
0x00001CD4 50939 3 CS_DAP_0 TA C: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::eConnected )
0x00001CD4 50939 3 CS_DAP_0 TA R: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::eConnected )
0x00001CD4 50939 3 Cortex_M4_0 POLL C: Firing DSP_PRECONNECT to all DSP_USER's
0x00001CD4 50939 3 Cortex_M4_0 POLL C: Firing of DSP_PRECONNECT complete
0x00001CD4 50939 3  SEQUENCE I: Finished sequence step at 0000000DAD8FD960
0x00001CD4 50939 3  SEQUENCE I: Beginning class Debugger::GelCallbackStep at 000001BD2952F830
0x00001CD4 50939 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD258 )
0x00001CD4 50939 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD258 ) = 0x00000000
0x00001CD4 50939 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD250 )
0x00001CD4 50939 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD250 ) = 0x00000002
0x00001CD4 50939 3 Cortex_M4_0 GEL I: Evaluating "OnPreTargetConnect()"
0x00001CD4 50939 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 50939 3  COM_DBG_IF C: class DSP_CO_USER::OnConnected()
0x00001CD4 50939 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD29E63050 )->onEvent()
0x00001CD4 50939 3  XPCOM C: ( (dsIConnectDisconnect*)000001BD29181408 )->connectionStatus( 0000000DAD8FC4A0 )
0x00001CD4 50939 3  XPCOM R: ( (dsIConnectDisconnect*)000001BD29181408 )->connectionStatus( *0000000DAD8FC4A0 = 0x00000000 ) = 0x00000000
0x00001CD4 50939 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD29E63050 )->onEvent() = 0x00000000
0x00001CD4 50939 3  COM_DBG_IF R: class DSP_CO_USER::OnConnected()
0x00001CD4 50939 3  COM_DBG_IF C: class DSP_CO_USER::OnRefresh()
0x00001CD4 50939 3  XPCOM C: ( (dsINumberEventCallback*)000001BD29E62D50 )->onEvent( 0x0000000000000003 )
0x00003E54 50939 3  XPCOM C: ( (dsIBreakpointManager*)000001BD297E5D70 )->NumBreakpointTypes( 0000000DAA8FE650 )
0x00001CD4 50939 3  XPCOM R: ( (dsINumberEventCallback*)000001BD29E62D50 )->onEvent( 0x0000000000000003 ) = 0x00000000
0x00001CD4 50939 3  COM_DBG_IF R: class DSP_CO_USER::OnRefresh()
0x00001CD4 50939 3  COM_DBG_IF C: class DSP_CO_USER::OnAllowedUserAccessesChanged()
0x00001CD4 50939 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD29E62350 )->onEvent()
0x00001CD4 50939 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD29E62350 )->onEvent() = 0x00000000
0x00001CD4 50939 3  COM_DBG_IF R: class DSP_CO_USER::OnAllowedUserAccessesChanged()
0x00001CD4 50939 3 CS_DAP_0 POLL C: Firing of DSP_CONNECTED complete
0x00003E54 50939 3  XPCOM R: ( (dsIBreakpointManager*)000001BD297E5D70 )->NumBreakpointTypes( *0000000DAA8FE650 = 0x00000000 ) = 0x00000000
0x00001CD4 50939 3 Cortex_M4_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 50939 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 50939 3 Cortex_M4_0 POLL R: Poll() returning
0x00003E54 50939 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E414D40 )->getProperty( EnableInstalledBreakpoint, 0000000DAA8FE6F8 )
0x00003E54 50939 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E414D40 )->getProperty( EnableInstalledBreakpoint, *0000000DAA8FE6F8 = 000001BD301459B0 ) = 0x00000000
0x00001CD4 50939 4 Cortex_M4_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00003E54 50939 3  XPCOM C: ( (dsIProperty*)000001BD301459B0 )->getPropertyType( 0000000DAA8FE690 )
0x00003E54 50939 3  XPCOM R: ( (dsIProperty*)000001BD301459B0 )->getPropertyType( *0000000DAA8FE690 = 0x00000000 ) = 0x00000000
0x00003E54 50939 3  XPCOM C: ( (dsIProperty*)000001BD301459B0 )->queryInterface( 000001BD30134FC0, 0000000DAA8FE688 )
0x00003E54 50939 3  XPCOM R: ( (dsIProperty*)000001BD301459B0 )->queryInterface( 000001BD30134FC0, *0000000DAA8FE688 = 000001BD30145A50 ) = 0x00000000
0x00003E54 50939 3  XPCOM C: ( (dsIBooleanProperty*)000001BD30145A50 )->queryInterface( 000001BD30134FC0, 0000000DAA8FE628 )
0x00003E54 50939 3  XPCOM R: ( (dsIBooleanProperty*)000001BD30145A50 )->queryInterface( 000001BD30134FC0, *0000000DAA8FE628 = 000001BD30145A50 ) = 0x00000000
0x00001CD4 50939 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00003E54 50939 3  XPCOM C: ( (dsIBooleanProperty*)000001BD30145A50 )->CurValue( 0000000DAA8FE6F0 )
0x00003E54 50939 3  XPCOM R: ( (dsIBooleanProperty*)000001BD30145A50 )->CurValue( *0000000DAA8FE6F0 = false ) = 0x00000000
0x00001CD4 50939 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 50939 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='OnPreTargetConnect()' AND Register_Cache.Processor=35
0x00001CD4 50939 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=35 AND Name='OnPreTargetConnect()'
0x00001CD4 50939 3 Cortex_M4_0 GEL I: Evaluation of "OnPreTargetConnect()" failed: identifier not found: OnPreTargetConnect()
0x00001CD4 50939 3  SEQUENCE I: Finished sequence step at 000001BD2952F830
0x00001CD4 50939 3  SEQUENCE I: Beginning class Debugger::LambdaSequenceStep<class <lambda_d5c2eaa1b9c646e74fc865fbf49efb9b> > at 000001BD3CDCCEA0
0x00001CD4 50939 3  SEQUENCE I: Finished sequence step at 000001BD3CDCCEA0
0x00001CD4 50939 3 Cortex_M4_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 50939 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_CONNECT and status EVENT_DSP_HALT
0x00001CD4 50939 3  PERF I: GTI_CONNECT starting...
0x00001CD4 50939 3 Cortex_M4_0 GTI C: GTI_CONNECT3( 0x000001BD362E2770, 0 )
0x00001CD4 50939 3  PRSC C: PRSC_Connect: prscHandle=0x1bd29e1cbb0,
0x00001CD4 50939 3  PRSC C: GRTR:SubConnect: routerHandle =0x1bd2b9beca0subPathHandle=0x1bd3d1fdea0 , numConnections=0x0
0x00001CD4 50939 3  PRSC R: GRTR:SUBConnect: rtn=0x0
0x00001CD4 50939 3  PRSC C: GRTR:SubConnect: routerHandle =0x1bd2b9beca0subPathHandle=0x1bd3d1fe4e0 , numConnections=0x0
0x00001CD4 50939 3  PRSC C: PRSC_GetGlobalChildExtendedStatus: prscHandle =0x1bd29e1cbb0
0x00001CD4 50939 3  PRSC C: prsc_SendRouter: connectionNeeded=0x1
0x00001CD4 50939 3  PRSC C: GRTR:Connected: routerHandle=0x1bd2b9beca0
0x00001CD4 50939 3 IcePick_C TA C: IsConnected()
0x00001CD4 50939 3 IcePick_C TA R: IsConnected() = true
0x00001CD4 50939 3  PRSC R: GRTR:Connected: pbConnected =0x1, ret=0x0
0x00001CD4 50939 3  PRSC C: GRTR:GetExtendedRouterStatus: routerHandle=0x1bd2b9beca0, parentHandle=0x1bd3d0baf60, regIndex=0x2
0x00001CD4 50939 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x0000000DAD8FD8B0 )
0x00001CD4 50939 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775806 AND Register_Cache.Address<=-9223372036854775806 AND Register_Cache.Page=121 AND Register_Cache.Processor=33
0x00001CD4 50939 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD838 = 0xAD8FDCD8 )
0x00001CD4 50939 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 50939 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 50939 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50939 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50939 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50939 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50939 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD838 = 0x2008233F ) = 0x00000000
0x00001CD4 50939 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCFB8 = 0x00000000, *0x0000000DAD8FCFB0 = 0x00000000, *0x0000000DAD8FCFC8 = 0x00000000, *0x0000000DAD8FCFE0 = 0x00000000, *0x0000000DAD8FCFE8 = 0x00000000, *0x0000000DAD8FCFD8 = 0x00000000, *0x0000000DAD8FCFD0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50939 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCFB8 = 0x00000000, *0x0000000DAD8FCFB0 = 0x00000000, *0x0000000DAD8FCFC8 = 0x00000000, *0x0000000DAD8FCFE0 = 0x00000002, *0x0000000DAD8FCFE8 = 0x00000000, *0x0000000DAD8FCFD8 = 0x00000008, *0x0000000DAD8FCFD0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50939 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCE88 = 0x00000000, *0x0000000DAD8FCE80 = 0x00000000, *0x0000000DAD8FCE98 = 0x00000000, *0x0000000DAD8FCEB0 = 0x00000000, *0x0000000DAD8FCEB8 = 0x00000000, *0x0000000DAD8FCEA8 = 0x00000000, *0x0000000DAD8FCEA0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50939 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCE88 = 0x00000000, *0x0000000DAD8FCE80 = 0x00000000, *0x0000000DAD8FCE98 = 0x00000000, *0x0000000DAD8FCEB0 = 0x00000002, *0x0000000DAD8FCEB8 = 0x00000000, *0x0000000DAD8FCEA8 = 0x00000008, *0x0000000DAD8FCEA0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50939 3 IcePick_C TA R: RegisterRead( 0x0000000000000002, 0x000000002008233F ) = 0
0x00001CD4 50939 3  PRSC C: GRTR:GetRouterStatus: routerHandle=0x1bd2b9beca0,parentHandle=0x1bd3d0baf60, regIndex=0x2
0x00001CD4 50939 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x0000000DAD8FD830 )
0x00001CD4 50939 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD7B8 = 0xAD8FD910 )
0x00001CD4 50954 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50954 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50954 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 50954 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 50954 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD7B8 = 0x2008233F ) = 0x00000000
0x00001CD4 50954 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF38 = 0x00000000, *0x0000000DAD8FCF30 = 0x00000000, *0x0000000DAD8FCF48 = 0x00000000, *0x0000000DAD8FCF60 = 0x00000000, *0x0000000DAD8FCF68 = 0x00000000, *0x0000000DAD8FCF58 = 0x00000000, *0x0000000DAD8FCF50 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50954 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF38 = 0x00000000, *0x0000000DAD8FCF30 = 0x00000000, *0x0000000DAD8FCF48 = 0x00000000, *0x0000000DAD8FCF60 = 0x00000002, *0x0000000DAD8FCF68 = 0x00000000, *0x0000000DAD8FCF58 = 0x00000008, *0x0000000DAD8FCF50 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50954 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCE08 = 0x00000000, *0x0000000DAD8FCE00 = 0x00000000, *0x0000000DAD8FCE18 = 0x00000000, *0x0000000DAD8FCE30 = 0x00000000, *0x0000000DAD8FCE38 = 0x00000000, *0x0000000DAD8FCE28 = 0x00000000, *0x0000000DAD8FCE20 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50954 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCE08 = 0x00000000, *0x0000000DAD8FCE00 = 0x00000000, *0x0000000DAD8FCE18 = 0x00000000, *0x0000000DAD8FCE30 = 0x00000002, *0x0000000DAD8FCE38 = 0x00000000, *0x0000000DAD8FCE28 = 0x00000008, *0x0000000DAD8FCE20 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50954 3 IcePick_C TA R: RegisterRead( 0x0000000000000002, 0x000000002008233F ) = 0
0x00001CD4 50954 3  PRSC R: GRTR:GetRouterStatus: powerStatus=0x3, exeStatus=0x1, resetStatus=0x7, resetMode=0xa, activeStatus=0xe, clockStatus=0x9,prscRtn=0x0
0x00001CD4 50954 3  PRSC R: GRTR:GetExtendedRouterStatus: powerStatus=0x3, exeStatus=0x1, resetStatus=0x7, resetMode=0xa, activeStatus=0xe, clockStatus=0x9, haltOnResetStatus=0x12, powerLossDetStatus=0x14, powerDownDesired=0x18, clockDownDesired=0x1a, accessibleStatus=0x15, prscRtn=0x0
0x00001CD4 50954 3  PRSC C: prsc_SendRouter: error =0x0
0x00001CD4 50954 3  PRSC R: PRSC_GetGlobalChildExStatus: ret=0x0, activeStatus=0xe, clockStatus=0x9, exeStatus=0x1, powerStatus=0x3, resetMode=0xa, resetStatus=0x7, haltOnResetStatus=0x12, powerLossStatus =0x14, accessibleStatus=0x15, powerDownDeisred=0x18, clockDownDesired=0x1a, retentionStatus=0x1c
0x00001CD4 50954 3  PRSC C: PRSC_EnableDebug: prscHandle =0x1bd29e1cbb0
0x00001CD4 50954 3  PRSC C: prsc_SendRouter: connectionNeeded=0x1
0x00001CD4 50954 3  PRSC C: GRTR:Connected: routerHandle=0x1bd2b9beca0
0x00001CD4 50954 3 IcePick_C TA C: IsConnected()
0x00001CD4 50954 3 IcePick_C TA R: IsConnected() = true
0x00001CD4 50954 3  PRSC R: GRTR:Connected: pbConnected =0x1, ret=0x0
0x00001CD4 50954 3  PRSC C: GRTR:EnableDebug: routerHandle=0x1bd2b9beca0,parentHandle=0x1bd3d0baf60, regIndex=0x2, debugMode=0x0
0x00001CD4 50954 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x0000000000000000 )
0x00001CD4 50954 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775806 AND Register_Cache.Address<=-9223372036854775806 AND Register_Cache.Page=121 AND Register_Cache.Processor=33
0x00001CD4 50954 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD8E8 = 0xAD8FDC80 )
0x00001CD4 50954 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50954 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50954 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD8E8 = 0x2008233F ) = 0x00000000
0x00001CD4 50954 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD060 = 0x00000000, *0x0000000DAD8FD078 = 0x00000000, *0x0000000DAD8FD090 = 0x00000000, *0x0000000DAD8FD098 = 0x00000000, *0x0000000DAD8FD088 = 0x00000000, *0x0000000DAD8FD080 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50954 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD060 = 0x00000000, *0x0000000DAD8FD078 = 0x00000000, *0x0000000DAD8FD090 = 0x00000002, *0x0000000DAD8FD098 = 0x00000000, *0x0000000DAD8FD088 = 0x00000008, *0x0000000DAD8FD080 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50954 3 IcePick_C TA C: RegisterWrite( 0x0000000000000002, 0x000000002008233F )
0x00001CD4 50954 3 IcePick_C GTI C: GTI_WRITEREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD918 = 0x2008233F )
0x00001CD4 50970 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50970 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 50970 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 50970 3 IcePick_C GTI R: GTI_WRITEREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD918 = 0x2008233F ) = 0x00000000
0x00001CD4 50970 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD098 = 0x00000000, *0x0000000DAD8FD090 = 0x00000000, *0x0000000DAD8FD0A8 = 0x00000000, *0x0000000DAD8FD0C0 = 0x00000000, *0x0000000DAD8FD0C8 = 0x00000000, *0x0000000DAD8FD0B8 = 0x00000000, *0x0000000DAD8FD0B0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50970 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD098 = 0x00000000, *0x0000000DAD8FD090 = 0x00000000, *0x0000000DAD8FD0A8 = 0x00000000, *0x0000000DAD8FD0C0 = 0x00000002, *0x0000000DAD8FD0C8 = 0x00000000, *0x0000000DAD8FD0B8 = 0x00000008, *0x0000000DAD8FD0B0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50970 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF68 = 0x00000000, *0x0000000DAD8FCF60 = 0x00000000, *0x0000000DAD8FCF78 = 0x00000000, *0x0000000DAD8FCF90 = 0x00000000, *0x0000000DAD8FCF98 = 0x00000000, *0x0000000DAD8FCF88 = 0x00000000, *0x0000000DAD8FCF80 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50970 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF68 = 0x00000000, *0x0000000DAD8FCF60 = 0x00000000, *0x0000000DAD8FCF78 = 0x00000000, *0x0000000DAD8FCF90 = 0x00000002, *0x0000000DAD8FCF98 = 0x00000000, *0x0000000DAD8FCF88 = 0x00000008, *0x0000000DAD8FCF80 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50970 3 IcePick_C TA R: RegisterWrite( 0x0000000000000002, 0x000000002008233F ) = 0
0x00001CD4 50970 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x00000000FF9DFBBF )
0x00001CD4 50970 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775806 AND Register_Cache.Address<=-9223372036854775806 AND Register_Cache.Page=121 AND Register_Cache.Processor=33
0x00001CD4 50970 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD8E8 = 0x00000000 )
0x00001CD4 50970 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50970 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50970 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50970 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD8E8 = 0x2008233F ) = 0x00000000
0x00001CD4 50970 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD060 = 0x00000000, *0x0000000DAD8FD078 = 0x00000000, *0x0000000DAD8FD090 = 0x00000000, *0x0000000DAD8FD098 = 0x00000000, *0x0000000DAD8FD088 = 0x00000000, *0x0000000DAD8FD080 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50970 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD060 = 0x00000000, *0x0000000DAD8FD078 = 0x00000000, *0x0000000DAD8FD090 = 0x00000002, *0x0000000DAD8FD098 = 0x00000000, *0x0000000DAD8FD088 = 0x00000008, *0x0000000DAD8FD080 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50970 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF38 = 0x00000000, *0x0000000DAD8FCF30 = 0x00000000, *0x0000000DAD8FCF48 = 0x00000000, *0x0000000DAD8FCF60 = 0x00000000, *0x0000000DAD8FCF68 = 0x00000000, *0x0000000DAD8FCF58 = 0x00000000, *0x0000000DAD8FCF50 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50970 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF38 = 0x00000000, *0x0000000DAD8FCF30 = 0x00000000, *0x0000000DAD8FCF48 = 0x00000000, *0x0000000DAD8FCF60 = 0x00000002, *0x0000000DAD8FCF68 = 0x00000000, *0x0000000DAD8FCF58 = 0x00000008, *0x0000000DAD8FCF50 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50970 3 IcePick_C TA R: RegisterRead( 0x0000000000000002, 0x000000002008233F ) = 0
0x00001CD4 50970 3  PRSC R: GRTR:EnableDebug: prscRtn=0x0
0x00001CD4 50970 3  PRSC C: prsc_SendRouter: error =0x0
0x00001CD4 50970 3  PRSC R: PRSC_EnableDebug: prscRtn =0x0
0x00001CD4 50970 3  PRSC C: PRSC_ForceClockPower: prscHandle=0x1bd29e1cbb0,
0x00001CD4 50970 3  PRSC C: prsc_SendRouter: connectionNeeded=0x1
0x00001CD4 50970 3  PRSC C: GRTR:Connected: routerHandle=0x1bd2b9beca0
0x00001CD4 50970 3 IcePick_C TA C: IsConnected()
0x00001CD4 50970 3 IcePick_C TA R: IsConnected() = true
0x00001CD4 50970 3  PRSC R: GRTR:Connected: pbConnected =0x1, ret=0x0
0x00001CD4 50970 3  PRSC C: GRTR:ForceClockPower: routerHandle=0x1bd2b9beca0, parentHandle=0x1bd3d0baf60, regIndex=0x2, subPathForce=0x1
0x00001CD4 50970 3  PRSC C: GRTR:GetForceActiveStatus: routerHandle=0x1bd2b9beca0,parentHandle=0x1bd3d0baf60, regIndex=0x2
0x00001CD4 50970 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x0000000DAD8FD910 )
0x00001CD4 50970 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD898 = 0xAD8FD9B0 )
0x00001CD4 50970 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD898 = 0x2008233F ) = 0x00000000
0x00001CD4 50970 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD018 = 0x00000000, *0x0000000DAD8FD010 = 0x00000000, *0x0000000DAD8FD028 = 0x00000000, *0x0000000DAD8FD040 = 0x00000000, *0x0000000DAD8FD048 = 0x00000000, *0x0000000DAD8FD038 = 0x00000000, *0x0000000DAD8FD030 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50970 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD018 = 0x00000000, *0x0000000DAD8FD010 = 0x00000000, *0x0000000DAD8FD028 = 0x00000000, *0x0000000DAD8FD040 = 0x00000002, *0x0000000DAD8FD048 = 0x00000000, *0x0000000DAD8FD038 = 0x00000008, *0x0000000DAD8FD030 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50970 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCEE8 = 0x00000000, *0x0000000DAD8FCEE0 = 0x00000000, *0x0000000DAD8FCEF8 = 0x00000000, *0x0000000DAD8FCF10 = 0x00000000, *0x0000000DAD8FCF18 = 0x00000000, *0x0000000DAD8FCF08 = 0x00000000, *0x0000000DAD8FCF00 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50970 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCEE8 = 0x00000000, *0x0000000DAD8FCEE0 = 0x00000000, *0x0000000DAD8FCEF8 = 0x00000000, *0x0000000DAD8FCF10 = 0x00000002, *0x0000000DAD8FCF18 = 0x00000000, *0x0000000DAD8FCF08 = 0x00000008, *0x0000000DAD8FCF00 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50970 3  PRSC R: GRTR:GetForceActiveStatus: pbForceActive =0x1,ret=0x0
0x00001CD4 50970 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x0000000000000003 )
0x00001CD4 50970 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD8D8 = 0x38F09753 )
0x00001CD4 50985 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 50985 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 50985 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 50985 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 50985 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 50985 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 50985 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD8D8 = 0x2008233F ) = 0x00000000
0x00001CD4 50985 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD058 = 0x00000000, *0x0000000DAD8FD050 = 0x00000000, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD080 = 0x00000000, *0x0000000DAD8FD088 = 0x00000000, *0x0000000DAD8FD078 = 0x00000000, *0x0000000DAD8FD070 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50985 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD058 = 0x00000000, *0x0000000DAD8FD050 = 0x00000000, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD080 = 0x00000002, *0x0000000DAD8FD088 = 0x00000000, *0x0000000DAD8FD078 = 0x00000008, *0x0000000DAD8FD070 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50985 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF28 = 0x00000000, *0x0000000DAD8FCF20 = 0x00000000, *0x0000000DAD8FCF38 = 0x00000000, *0x0000000DAD8FCF50 = 0x00000000, *0x0000000DAD8FCF58 = 0x00000000, *0x0000000DAD8FCF48 = 0x00000000, *0x0000000DAD8FCF40 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50985 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF28 = 0x00000000, *0x0000000DAD8FCF20 = 0x00000000, *0x0000000DAD8FCF38 = 0x00000000, *0x0000000DAD8FCF50 = 0x00000002, *0x0000000DAD8FCF58 = 0x00000000, *0x0000000DAD8FCF48 = 0x00000008, *0x0000000DAD8FCF40 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50985 3 IcePick_C TA R: RegisterRead( 0x0000000000000002, 0x000000002008233F ) = 0
0x00001CD4 50985 3 IcePick_C TA C: RegisterWrite( 0x0000000000000002, 0x000000002008233F )
0x00001CD4 50985 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775806 AND Register_Cache.Address<=-9223372036854775806 AND Register_Cache.Page=121 AND Register_Cache.Processor=33
0x00001CD4 50985 3 IcePick_C GTI C: GTI_WRITEREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD908 = 0x2008233F )
0x00001CD4 50985 3 IcePick_C GTI R: GTI_WRITEREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD908 = 0x2008233F ) = 0x00000000
0x00001CD4 50985 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD088 = 0x00000000, *0x0000000DAD8FD080 = 0x00000000, *0x0000000DAD8FD098 = 0x00000000, *0x0000000DAD8FD0B0 = 0x00000000, *0x0000000DAD8FD0B8 = 0x00000000, *0x0000000DAD8FD0A8 = 0x00000000, *0x0000000DAD8FD0A0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50985 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD088 = 0x00000000, *0x0000000DAD8FD080 = 0x00000000, *0x0000000DAD8FD098 = 0x00000000, *0x0000000DAD8FD0B0 = 0x00000002, *0x0000000DAD8FD0B8 = 0x00000000, *0x0000000DAD8FD0A8 = 0x00000008, *0x0000000DAD8FD0A0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50985 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF58 = 0x00000000, *0x0000000DAD8FCF50 = 0x00000000, *0x0000000DAD8FCF68 = 0x00000000, *0x0000000DAD8FCF80 = 0x00000000, *0x0000000DAD8FCF88 = 0x00000000, *0x0000000DAD8FCF78 = 0x00000000, *0x0000000DAD8FCF70 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 50985 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF58 = 0x00000000, *0x0000000DAD8FCF50 = 0x00000000, *0x0000000DAD8FCF68 = 0x00000000, *0x0000000DAD8FCF80 = 0x00000002, *0x0000000DAD8FCF88 = 0x00000000, *0x0000000DAD8FCF78 = 0x00000008, *0x0000000DAD8FCF70 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 50985 3 IcePick_C TA R: RegisterWrite( 0x0000000000000002, 0x000000002008233F ) = 0
0x00001CD4 50985 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x00000000FF9DFBBF )
0x00001CD4 50985 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD8D8 = 0x00000000 )
0x00001CD4 51001 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 51001 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51001 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 51001 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51001 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD8D8 = 0x2008233F ) = 0x00000000
0x00001CD4 51001 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD058 = 0x00000000, *0x0000000DAD8FD050 = 0x00000000, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD080 = 0x00000000, *0x0000000DAD8FD088 = 0x00000000, *0x0000000DAD8FD078 = 0x00000000, *0x0000000DAD8FD070 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51001 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD058 = 0x00000000, *0x0000000DAD8FD050 = 0x00000000, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD080 = 0x00000002, *0x0000000DAD8FD088 = 0x00000000, *0x0000000DAD8FD078 = 0x00000008, *0x0000000DAD8FD070 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51001 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF28 = 0x00000000, *0x0000000DAD8FCF20 = 0x00000000, *0x0000000DAD8FCF38 = 0x00000000, *0x0000000DAD8FCF50 = 0x00000000, *0x0000000DAD8FCF58 = 0x00000000, *0x0000000DAD8FCF48 = 0x00000000, *0x0000000DAD8FCF40 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51001 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF28 = 0x00000000, *0x0000000DAD8FCF20 = 0x00000000, *0x0000000DAD8FCF38 = 0x00000000, *0x0000000DAD8FCF50 = 0x00000002, *0x0000000DAD8FCF58 = 0x00000000, *0x0000000DAD8FCF48 = 0x00000008, *0x0000000DAD8FCF40 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51001 3 IcePick_C TA R: RegisterRead( 0x0000000000000002, 0x000000002008233F ) = 0
0x00001CD4 51001 3  PRSC R: GRTR:ForceClockPower: prscRtn=0x0
0x00001CD4 51001 3  PRSC C: prsc_SendRouter: error =0x0
0x00001CD4 51001 3  PRSC R: PRSC_ForceClockPower: prscRtn =0x0
0x00001CD4 51001 3  PRSC R: PRSC_Connect: error =0x0
0x00001CD4 51001 3  CMAPI C: Open( 000001BD35050D30, 000001BD2BD91468 )
0x00001CD4 51001 3  XDS110 C: Executing command 0x0f (CMAPI_CONNECT)
0x00001CD4 51001 3  XDS110 I: Depth0: DpRegRead( address = 0x00000000 ) -> 0x4ba00477 = 0
0x00001CD4 51001 3  XDS110 I: Depth0: DpRegWrite( address = 0x00000004, *value = 0x50000032 ) = 0
0x00001CD4 51001 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51001 3  XDS110 R: Executed command 0x0f (CMAPI_CONNECT), return code: 0x00000000
0x00001CD4 51001 3  CMAPI R: Open( 000001BD35050D30, 000001BD2BD91468 ) = 0
0x00001CD4 51001 3  CMAPI C: Acquire( 000001BD35050D30 )
0x00001CD4 51001 3  CMAPI R: Acquire( 000001BD35050D30 ) = 0
0x00001CD4 51001 3  CMAPI C: DapRegRead( 000001BD35050D30, 0, 0, 0x000000FC, 0000000DAD8FDCC0 )
0x00001CD4 51001 3  XDS110 C: Executing command 0x15 (CMAPI_DAPREGREAD)
0x00001CD4 51001 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x000000fc ) -> 0x000000f0 = 0
0x00001CD4 51001 3  XDS110 I: Depth1: DpRegWrite( address = 0x00000008, *value = 0x000000f0 ) = 0
0x00001CD4 51001 3  XDS110 I: Depth0: DpRegRead( address = 0x0000000c ) -> 0x24770011 = 0
0x00001CD4 51001 3  XDS110 R: Executed command 0x15 (CMAPI_DAPREGREAD), return code: 0x00000000
0x00001CD4 51001 3  CMAPI R: DapRegRead( 000001BD35050D30, 0, 0, 0x000000FC, *0000000DAD8FDCC0 = 0x24770011 ) = 0
0x00001CD4 51017 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x000000fc ) -> 0x00000000 = 0
0x00001CD4 51017 3  XDS110 I: Depth0: DpRegRead( address = 0x0000000c ) -> 0x24770011 = 0
0x00001CD4 51017 3  XDS110 R: Executed command 0x15 (CMAPI_DAPREGREAD), return code: 0x00000000
0x00001CD4 51017 3  CMAPI R: DapRegRead( 000001BD35050D30, 0, 0, 0x000000FC, *0000000DAD8FDCC0 = 0x24770011 ) = 0
0x00001CD4 51017 3  CMAPI C: DapRegRead( 000001BD35050D30, 0, 0, 0x000000F8, 0000000DAD8FDC70 )
0x00001CD4 51017 3  XDS110 C: Executing command 0x15 (CMAPI_DAPREGREAD)
0x00001CD4 51017 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x000000f8 ) -> 0x00000000 = 0
0x00001CD4 51017 3  XDS110 I: Depth0: DpRegRead( address = 0x0000000c ) -> 0xe00ff003 = 0
0x00001CD4 51017 3  CMAPI R: DapRegRead( 000001BD35050D30, 0, 0, 0x000000F8, *0000000DAD8FDC70 = 0xE00FF003 ) = 0
0x00001CD4 51017 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE00FFFE0, 4, 0000000DAD8FDC48, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51017 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x00000000 ) -> 0x00000000 = 0
0x00001CD4 51017 3  XDS110 I: Depth1: DpRegWrite( address = 0x00000008, *value = 0x00000000 ) = 0
0x00001CD4 51017 3  XDS110 I: Depth0: DpRegRead( address = 0x0000000c ) -> 0x23000040 = 0
0x00001CD4 51017 3  XDS110 C: Executing command 0x16 (CMAPI_DAPREGWRITE)
0x00001CD4 51017 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000000, *value = 0x23000040 ) = 0
0x00001CD4 51017 3  XDS110 R: Executed command 0x16 (CMAPI_DAPREGWRITE), return code: 0x00000000
0x00001CD4 51017 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x00000000 ) -> 0x23000040 = 0
0x00001CD4 51017 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51017 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000000, *value = 0x63000052 ) = 0
0x00001CD4 51017 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe00fffe0 ) = 0
0x00001CD4 51017 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x23000040 = 0
0x00001CD4 51017 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x000000c4 = 0
0x00001CD4 51017 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51017 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51017 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE00FFFE0, 4, *0000000DAD8FDC48 = [C4 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51017 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE00FFFE4, 4, 0000000DAD8FDC44, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51017 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000000 = 0
0x00001CD4 51017 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x000000b4 = 0
0x00001CD4 51017 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE00FFFE4, 4, *0000000DAD8FDC44 = [B4 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51017 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE00FFFE8, 4, 0000000DAD8FDC40, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51017 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x0000000b = 0
0x00001CD4 51017 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE00FFFE8, 4, *0000000DAD8FDC40 = [0B 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51017 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE00FFFEC, 4, 0000000DAD8FDC88, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51017 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000000 = 0
0x00001CD4 51017 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE00FFFEC, 4, *0000000DAD8FDC88 = [00 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51017 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE00FFFD0, 4, 0000000DAD8FDC4C, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51017 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe00fffd0 ) = 0
0x00001CD4 51017 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000004 = 0
0x00001CD4 51017 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE00FFFD0, 4, *0000000DAD8FDC4C = [04 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51017 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000ED00, 4, 0000000DAD8FDCD0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51017 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000ed00 ) = 0
0x00001CD4 51017 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000004 = 0
0x00001CD4 51017 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x410fc241 = 0
0x00001CD4 51017 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000ED00, 4, *0000000DAD8FDCD0 = [41 C2 0F 41 ...], 0000000000000000 ) = 0
0x00001CD4 51017 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDCC0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51017 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 51017 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x410fc241 = 0
0x00001CD4 51017 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x03050000 = 0
0x00001CD4 51017 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDCC0 = [00 00 05 03 ...], 0000000000000000 ) = 0
0x00001CD4 51017 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDCC0 = [01 00 5F A0 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51017 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 51032 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 51032 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0xa05f0001 ) = 0
0x00001CD4 51032 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51032 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 51032 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDCC0, 0000000000000000 ) = 0
0x00001CD4 51032 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDCC0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51032 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51032 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x03050000 = 0
0x00001CD4 51032 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00050001 = 0
0x00001CD4 51032 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51032 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDCC0 = [01 00 05 00 ...], 0000000000000000 ) = 0
0x00001CD4 51032 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000ED0C, 4, 0000000DAD8FDDB0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51032 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000ed0c ) = 0
0x00001CD4 51032 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00050001 = 0
0x00001CD4 51032 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0xfa050000 = 0
0x00001CD4 51032 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000ED0C, 4, *0000000DAD8FDDB0 = [00 00 05 FA ...], 0000000000000000 ) = 0
0x00001CD4 51032 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDCD0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51032 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0xfa050000 = 0
0x00001CD4 51032 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDCD0 = [01 00 05 00 ...], 0000000000000000 ) = 0
0x00001CD4 51032 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDC90, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51032 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDC90 = [01 00 05 00 ...], 0000000000000000 ) = 0
0x00001CD4 51032 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDC40, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51032 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDC40 = [01 00 05 00 ...], 0000000000000000 ) = 0
0x00001CD4 51032 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDC90 = [03 00 5F A0 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51032 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 51032 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0xa05f0003 ) = 0
0x00001CD4 51032 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDC90, 0000000000000000 ) = 0
0x00001CD4 51032 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDC98, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51032 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51032 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDC98 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 51032 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDFC, 4, 0000000DAD8FDC98, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51032 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edfc ) = 0
0x00001CD4 51032 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51032 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000000 = 0
0x00001CD4 51032 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDFC, 4, *0000000DAD8FDC98 = [00 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51032 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDFC, 4, *0000000DAD8FDC98 = [01 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51048 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edfc ) = 0
0x00001CD4 51048 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000001 ) = 0
0x00001CD4 51048 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51048 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 51048 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDFC, 4, 0000000DAD8FDC98, 0000000000000000 ) = 0
0x00001CD4 51048 3  CMAPI C: GetStatus( 000001BD35050D30, 0000000DAD8FDC90 )
0x00001CD4 51048 3  CMAPI R: GetStatus( 000001BD35050D30, *0000000DAD8FDC90 = { 1, 1, 1, 1, 1 } ) = 0
0x00001CD4 51048 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDCC8, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51048 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51048 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 51048 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000000 = 0
0x00001CD4 51048 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51048 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51048 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDCC8 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 51048 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDFC, 4, 0000000DAD8FDC48, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51048 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51048 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000001 = 0
0x00001CD4 51048 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDFC, 4, *0000000DAD8FDC48 = [01 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51048 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDFC, 4, *0000000DAD8FDC48 = [01 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51048 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 51048 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDFC, 4, 0000000DAD8FDC48, 0000000000000000 ) = 0
0x00001CD4 51048 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000ED30, 4, 0000000DAD8FDCA0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51048 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000ed30 ) = 0
0x00001CD4 51048 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000001 = 0
0x00001CD4 51048 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000ED30, 4, *0000000DAD8FDCA0 = [01 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51048 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000ED30, 4, *0000000DAD8FDCA0 = [01 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51048 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000ED30, 4, 0000000DAD8FDCA0, 0000000000000000 ) = 0
0x00001CD4 51048 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [00 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51048 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 51048 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000000 ) = 0
0x00001CD4 51048 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDC10, 0000000000000000 ) = 0
0x00001CD4 51048 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDBB0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51048 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDBB0 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 51048 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E38894, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51048 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 51048 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000000 = 0
0x00001CD4 51048 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E38894 = [00 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51048 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [01 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51064 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 51064 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000000 = 0
0x00001CD4 51064 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51064 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51064 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51064 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDBB0 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 51064 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E38898, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51064 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51064 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 51064 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51064 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000004 = 0
0x00001CD4 51064 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E38898 = [04 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51064 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [02 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51064 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 51064 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 51064 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000002 ) = 0
0x00001CD4 51064 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 51064 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDC10, 0000000000000000 ) = 0
0x00001CD4 51064 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDBB0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51064 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000004 = 0
0x00001CD4 51064 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E3889C, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51064 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x40030000 = 0
0x00001CD4 51064 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E3889C = [00 00 03 40 ...], 0000000000000000 ) = 0
0x00001CD4 51064 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [03 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51064 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000003 ) = 0
0x00001CD4 51064 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x40030000 = 0
0x00001CD4 51064 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388A0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51064 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000005 = 0
0x00001CD4 51064 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388A0 = [05 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51064 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [04 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51064 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000004 ) = 0
0x00001CD4 51064 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000005 = 0
0x00001CD4 51064 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388A4, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51080 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 51080 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51080 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x40090000 = 0
0x00001CD4 51080 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51080 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51080 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388A4 = [00 00 09 40 ...], 0000000000000000 ) = 0
0x00001CD4 51080 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [05 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51080 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 51080 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 51080 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000005 ) = 0
0x00001CD4 51080 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 51080 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDC10, 0000000000000000 ) = 0
0x00001CD4 51080 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDBB0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51080 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51080 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 51080 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x40090000 = 0
0x00001CD4 51080 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51080 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDBB0 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 51080 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388A8, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51080 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x40030000 = 0
0x00001CD4 51080 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388A8 = [00 00 03 40 ...], 0000000000000000 ) = 0
0x00001CD4 51080 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [06 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51080 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000006 ) = 0
0x00001CD4 51080 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x40030000 = 0
0x00001CD4 51080 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388AC, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51080 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000003 = 0
0x00001CD4 51080 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388AC = [03 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51080 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [07 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51080 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000007 ) = 0
0x00001CD4 51080 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000003 = 0
0x00001CD4 51080 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388B0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51080 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000000 = 0
0x00001CD4 51080 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388B0 = [00 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51080 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [08 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51095 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 51095 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000008 ) = 0
0x00001CD4 51095 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51095 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 51095 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDC10, 0000000000000000 ) = 0
0x00001CD4 51095 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDBB0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51095 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51095 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 51095 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000000 = 0
0x00001CD4 51095 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51095 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51095 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDBB0 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 51095 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388B4, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51095 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 51095 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51095 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000001 = 0
0x00001CD4 51095 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388B4 = [01 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51095 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [09 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51095 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 51095 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000009 ) = 0
0x00001CD4 51095 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000001 = 0
0x00001CD4 51095 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388B8, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51095 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x40092000 = 0
0x00001CD4 51095 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388B8 = [00 20 09 40 ...], 0000000000000000 ) = 0
0x00001CD4 51095 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [0A 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51095 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x0000000a ) = 0
0x00001CD4 51095 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x40092000 = 0
0x00001CD4 51095 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388BC, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51095 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x40090000 = 0
0x00001CD4 51095 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388BC = [00 00 09 40 ...], 0000000000000000 ) = 0
0x00001CD4 51095 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [0B 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51111 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 51111 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x0000000b ) = 0
0x00001CD4 51111 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51111 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 51111 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDC10, 0000000000000000 ) = 0
0x00001CD4 51111 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDBB0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51111 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51111 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 51111 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x40090000 = 0
0x00001CD4 51111 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51111 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51111 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDBB0 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 51111 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388C0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51111 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 51111 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51111 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x0400000d = 0
0x00001CD4 51111 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388C0 = [0D 00 00 04 ...], 0000000000000000 ) = 0
0x00001CD4 51111 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [0C 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51111 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 51111 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x0000000c ) = 0
0x00001CD4 51111 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x0400000d = 0
0x00001CD4 51111 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388C4, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51111 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00006000 = 0
0x00001CD4 51111 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388C4 = [00 60 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51111 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [0D 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51111 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x0000000d ) = 0
0x00001CD4 51111 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00006000 = 0
0x00001CD4 51111 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388C8, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51111 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x11001ff0 = 0
0x00001CD4 51111 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388C8 = [F0 1F 00 11 ...], 0000000000000000 ) = 0
0x00001CD4 51111 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [0E 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51111 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x0000000e ) = 0
0x00001CD4 51127 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 51127 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x11001ff0 = 0
0x00001CD4 51127 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51127 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51127 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51127 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDBB0 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 51127 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388CC, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51127 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51127 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 51127 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51127 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x100011d1 = 0
0x00001CD4 51127 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388CC = [D1 11 00 10 ...], 0000000000000000 ) = 0
0x00001CD4 51127 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [0F 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51127 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 51127 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 51127 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x0000000f ) = 0
0x00001CD4 51127 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 51127 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDC10, 0000000000000000 ) = 0
0x00001CD4 51127 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDBB0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51127 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x100011d1 = 0
0x00001CD4 51127 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388D0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51127 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x1000118e = 0
0x00001CD4 51127 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388D0 = [8E 11 00 10 ...], 0000000000000000 ) = 0
0x00001CD4 51127 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [10 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51127 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000010 ) = 0
0x00001CD4 51127 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x1000118e = 0
0x00001CD4 51127 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388D4, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51127 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x61000000 = 0
0x00001CD4 51127 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388D4 = [00 00 00 61 ...], 0000000000000000 ) = 0
0x00001CD4 51127 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [11 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51127 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000011 ) = 0
0x00001CD4 51127 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x61000000 = 0
0x00001CD4 51127 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388D8, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51142 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 51142 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51142 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x11001ff0 = 0
0x00001CD4 51142 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51142 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51142 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388D8 = [F0 1F 00 11 ...], 0000000000000000 ) = 0
0x00001CD4 51142 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [12 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51142 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 51142 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 51142 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000012 ) = 0
0x00001CD4 51142 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 51142 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDC10, 0000000000000000 ) = 0
0x00001CD4 51142 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDBB0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51142 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51142 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 51142 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x11001ff0 = 0
0x00001CD4 51142 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51142 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDBB0 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 51142 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388DC, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51142 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000000 = 0
0x00001CD4 51142 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388DC = [00 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51142 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [13 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51142 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000013 ) = 0
0x00001CD4 51142 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000000 = 0
0x00001CD4 51142 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388E0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51142 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388E0 = [00 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51142 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [14 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51142 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000014 ) = 0
0x00001CD4 51142 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388E4, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51142 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388E4 = [00 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51142 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE0002000, 4, 0000000DAD8FDCC0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51158 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe0002000 ) = 0
0x00001CD4 51158 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000000 = 0
0x00001CD4 51158 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000260 = 0
0x00001CD4 51158 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51158 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51158 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE0002000, 4, *0000000DAD8FDCC0 = [60 02 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51158 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE0002000, 4, *0000000DAD8FDCC0 = [03 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51158 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 51158 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000003 ) = 0
0x00001CD4 51158 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 51158 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE0002000, 4, 0000000DAD8FDCC0, 0000000000000000 ) = 0
0x00001CD4 51158 3  CMAPI C: Release( 000001BD35050D30 )
0x00001CD4 51158 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 51158 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51158 3  CMAPI R: Release( 000001BD35050D30 ) = 0
0x00001CD4 51158 3  CMAPI C: Acquire( 000001BD35050D30 )
0x00001CD4 51158 3  CMAPI R: Acquire( 000001BD35050D30 ) = 0
0x00001CD4 51158 3  CMAPI C: GetStatus( 000001BD35050D30, 0000000DAD8FDC70 )
0x00001CD4 51158 3  CMAPI R: GetStatus( 000001BD35050D30, *0000000DAD8FDC70 = { 1, 1, 1, 1, 1 } ) = 0
0x00001CD4 51158 3 Cortex_M4_0 GTI R: GTI_CONNECT3( 0x000001BD362E2770, 0 ) = 0x00000000
0x00001CD4 51158 3  PERF I: GTI_CONNECT finished:  0.225472s wall, 0.000000s user + 0.062500s system = 0.062500s CPU (27.7%)
0x00001CD4 51158 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD878 = 0x00000000, *0x0000000DAD8FD870 = 0x00000000, *0x0000000DAD8FD888 = 0x00000000, *0x0000000DAD8FD8A0 = 0x00000000, *0x0000000DAD8FD8A8 = 0x00000000, *0x0000000DAD8FD898 = 0x00000000, *0x0000000DAD8FD890 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51158 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD878 = 0x00000000, *0x0000000DAD8FD870 = 0x00000000, *0x0000000DAD8FD888 = 0x00000000, *0x0000000DAD8FD8A0 = 0x00000002, *0x0000000DAD8FD8A8 = 0x00000000, *0x0000000DAD8FD898 = 0x00000008, *0x0000000DAD8FD890 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51158 3 Cortex_M4_0 STATE I: Connection state changed to 4
0x00001CD4 51158 3 Cortex_M4_0 GTI C: GTI_STAT_EX2( 0x000001BD362E2770, *0x0000000DAD8FDCD8 = { 0, 0, 0, 0, 0, 0, 0, 0 } )
0x00001CD4 51158 3  PRSC C: PRSC_GetGlobalChildExtendedStatus: prscHandle =0x1bd29e1cbb0
0x00001CD4 51158 3  PRSC C: prsc_SendRouter: connectionNeeded=0x1
0x00001CD4 51158 3  PRSC C: GRTR:Connected: routerHandle=0x1bd2b9beca0
0x00001CD4 51158 3 IcePick_C TA C: IsConnected()
0x00001CD4 51158 3 IcePick_C TA R: IsConnected() = true
0x00001CD4 51158 3  PRSC R: GRTR:Connected: pbConnected =0x1, ret=0x0
0x00001CD4 51158 3  PRSC C: GRTR:GetExtendedRouterStatus: routerHandle=0x1bd2b9beca0,parentHandle=0x1bd3d0baf60, regIndex=0x2
0x00001CD4 51158 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x0000000DAD8FD720 )
0x00001CD4 51158 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775806 AND Register_Cache.Address<=-9223372036854775806 AND Register_Cache.Page=121 AND Register_Cache.Processor=33
0x00001CD4 51158 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD6A8 = 0xAD8FDBF0 )
0x00001CD4 51158 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 51158 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 51158 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51174 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 51174 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51174 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 51174 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51174 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD6A8 = 0x2008272F ) = 0x00000000
0x00001CD4 51174 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCE28 = 0x00000000, *0x0000000DAD8FCE20 = 0x00000000, *0x0000000DAD8FCE38 = 0x00000000, *0x0000000DAD8FCE50 = 0x00000000, *0x0000000DAD8FCE58 = 0x00000000, *0x0000000DAD8FCE48 = 0x00000000, *0x0000000DAD8FCE40 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51174 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCE28 = 0x00000000, *0x0000000DAD8FCE20 = 0x00000000, *0x0000000DAD8FCE38 = 0x00000000, *0x0000000DAD8FCE50 = 0x00000002, *0x0000000DAD8FCE58 = 0x00000000, *0x0000000DAD8FCE48 = 0x00000008, *0x0000000DAD8FCE40 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51174 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCCF8 = 0x00000000, *0x0000000DAD8FCCF0 = 0x00000000, *0x0000000DAD8FCD08 = 0x00000000, *0x0000000DAD8FCD20 = 0x00000000, *0x0000000DAD8FCD28 = 0x00000000, *0x0000000DAD8FCD18 = 0x00000000, *0x0000000DAD8FCD10 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51174 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCCF8 = 0x00000000, *0x0000000DAD8FCCF0 = 0x00000000, *0x0000000DAD8FCD08 = 0x00000000, *0x0000000DAD8FCD20 = 0x00000002, *0x0000000DAD8FCD28 = 0x00000000, *0x0000000DAD8FCD18 = 0x00000008, *0x0000000DAD8FCD10 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51174 3 IcePick_C TA R: RegisterRead( 0x0000000000000002, 0x000000002008272F ) = 0
0x00001CD4 51174 3  PRSC C: GRTR:GetRouterStatus: routerHandle=0x1bd2b9beca0,parentHandle=0x1bd3d0baf60, regIndex=0x2
0x00001CD4 51174 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x0000000DAD8FD6A0 )
0x00001CD4 51174 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775806 AND Register_Cache.Address<=-9223372036854775806 AND Register_Cache.Page=121 AND Register_Cache.Processor=33
0x00001CD4 51174 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD628 = 0xAD8FD770 )
0x00001CD4 51174 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 51174 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 51174 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD628 = 0x2008272F ) = 0x00000000
0x00001CD4 51174 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCDA8 = 0x00000000, *0x0000000DAD8FCDA0 = 0x00000000, *0x0000000DAD8FCDB8 = 0x00000000, *0x0000000DAD8FCDD0 = 0x00000000, *0x0000000DAD8FCDD8 = 0x00000000, *0x0000000DAD8FCDC8 = 0x00000000, *0x0000000DAD8FCDC0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51174 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCDA8 = 0x00000000, *0x0000000DAD8FCDA0 = 0x00000000, *0x0000000DAD8FCDB8 = 0x00000000, *0x0000000DAD8FCDD0 = 0x00000002, *0x0000000DAD8FCDD8 = 0x00000000, *0x0000000DAD8FCDC8 = 0x00000008, *0x0000000DAD8FCDC0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51174 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCC78 = 0x00000000, *0x0000000DAD8FCC70 = 0x00000000, *0x0000000DAD8FCC88 = 0x00000000, *0x0000000DAD8FCCA0 = 0x00000000, *0x0000000DAD8FCCA8 = 0x00000000, *0x0000000DAD8FCC98 = 0x00000000, *0x0000000DAD8FCC90 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51174 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCC78 = 0x00000000, *0x0000000DAD8FCC70 = 0x00000000, *0x0000000DAD8FCC88 = 0x00000000, *0x0000000DAD8FCCA0 = 0x00000002, *0x0000000DAD8FCCA8 = 0x00000000, *0x0000000DAD8FCC98 = 0x00000008, *0x0000000DAD8FCC90 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51174 3  PRSC R: GRTR:GetRouterStatus: powerStatus=0x3, exeStatus=0x2, resetStatus=0x7, resetMode=0xa, activeStatus=0xe, clockStatus=0x9,prscRtn=0x0
0x00001CD4 51174 3  PRSC R: GRTR:GetExtendedRouterStatus: powerStatus=0x3, exeStatus=0x2, resetStatus=0x7, resetMode=0xa, activeStatus=0xe, clockStatus=0x9, haltOnResetStatus=0x12, powerLossDetStatus=0x14, prscRtn=0x0
0x00001CD4 51174 3  PRSC C: prsc_SendRouter: error =0x0
0x00001CD4 51174 3  PRSC R: PRSC_GetGlobalChildExStatus: ret=0x0, activeStatus=0xe, clockStatus=0x9, exeStatus=0x2, powerStatus=0x3, resetMode=0xa, resetStatus=0x7, haltOnResetStatus=0x12, powerLossStatus =0x14
0x00001CD4 51174 3  CMAPI C: Acquire( 000001BD35050D30 )
0x00001CD4 51174 3  CMAPI R: Acquire( 000001BD35050D30 ) = 0
0x00001CD4 51174 3  CMAPI C: GetStatus( 000001BD35050D30, 0000000DAD8FD810 )
0x00001CD4 51174 3  CMAPI R: GetStatus( 000001BD35050D30, *0000000DAD8FD810 = { 1, 1, 1, 1, 1 } ) = 0
0x00001CD4 51174 3  CMAPI C: Release( 000001BD35050D30 )
0x00001CD4 51189 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51189 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 51189 3  CMAPI R: Release( 000001BD35050D30 ) = 0
0x00001CD4 51189 3  CMAPI C: Acquire( 000001BD35050D30 )
0x00001CD4 51189 3  CMAPI R: Acquire( 000001BD35050D30 ) = 0
0x00001CD4 51189 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FD848, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51189 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51189 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000000, *value = 0x63000052 ) = 0
0x00001CD4 51189 3  XDS110 I: Depth1: DpRegWrite( address = 0x00000008, *value = 0x00000000 ) = 0
0x00001CD4 51189 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 51189 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000260 = 0
0x00001CD4 51189 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51189 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51189 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51189 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FD848 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 51189 3  CMAPI C: Release( 000001BD35050D30 )
0x00001CD4 51189 3 Cortex_M4_0 GTI R: GTI_STAT_EX2( 0x000001BD362E2770, *0x0000000DAD8FDCD8 = { 4, 100, 202, 301, 400, 0, 0, 0 } ) = 0x00000000
0x00001CD4 51189 3 Cortex_M4_0 STATE I: Target execution state changed to STATUS_HALTED
0x00001CD4 51189 3 Cortex_M4_0 STATE I: Connection state changed to 0
0x00001CD4 51189 3 Cortex_M4_0 GTI C: GTI_GETCAPABILITIES( 0x000001BD362E2770 )
0x00001CD4 51189 3 Cortex_M4_0 GTI R: GTI_GETCAPABILITIES( 0x000001BD362E2770 ) = 0x11DA041B
0x00001CD4 51189 3 Cortex_M4_0 GTI C: GTI_GET_EXT_CAPABILITIES( 0x000001BD362E2770, 0 )
0x00001CD4 51189 3 Cortex_M4_0 GTI R: GTI_GET_EXT_CAPABILITIES( 0x000001BD362E2770, 0 ) = 0x11DA041B
0x00001CD4 51189 3 Cortex_M4_0 GTI C: GTI_GET_EXT_CAPABILITIES( 0x000001BD362E2770, 2 )
0x00001CD4 51189 3 Cortex_M4_0 GTI R: GTI_GET_EXT_CAPABILITIES( 0x000001BD362E2770, 2 ) = 0x00000017
0x00001CD4 51189 3 Cortex_M4_0 GTI C: GTI_GET_EXT_CAPABILITIES( 0x000001BD362E2770, 1 )
0x00001CD4 51189 3 Cortex_M4_0 GTI R: GTI_GET_EXT_CAPABILITIES( 0x000001BD362E2770, 1 ) = 0x00000000
0x00001CD4 51189 3 Cortex_M4_0 GTI C: GTI_GET_PROC_ID( 0x000001BD362E2770 )
0x00001CD4 51189 3 Cortex_M4_0 GTI R: GTI_GET_PROC_ID( 0x000001BD362E2770 ) = 0x75803800
0x00001CD4 51189 3  LIB C: dlsym( 000001BD39090000, "GTI_GET_PROC_MINOR_ID" )
0x00001CD4 51189 3  LIB R: dlsym( 000001BD39090000, "GTI_GET_PROC_MINOR_ID" ) = 000001BD39093C50
0x00001CD4 51189 3 Cortex_M4_0 GTI C: GTI_GET_PROC_MINOR_ID( 0x000001BD362E2770 )
0x00001CD4 51205 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51205 3  CMAPI R: Release( 000001BD35050D30 ) = 0
0x00001CD4 51205 3 Cortex_M4_0 GTI R: GTI_GET_PROC_MINOR_ID( 0x000001BD362E2770 ) = 0x00000001
0x00001CD4 51205 3 Cortex_M4_0 GTI C: GTI_GET_NON_INTRUSIVE_CAPABILITIES( 0x000001BD362E2770 )
0x00001CD4 51205 3 Cortex_M4_0 GTI R: GTI_GET_NON_INTRUSIVE_CAPABILITIES( 0x000001BD362E2770 ) = 0x0000003F
0x00001CD4 51205 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_DESTRUCTOR )
0x00001CD4 51205 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_DESTRUCTOR ) = 0x00000000
0x00001CD4 51205 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_GET_REVISION, *0000000DAD8FDD70 )
0x00001CD4 51205 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_GET_REVISION, *0000000DAD8FDD70 = 0x00000065 ) = 0x00000000
0x00001CD4 51205 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_CONSTRUCTOR, 0x0000000D75803800, 0x00007FFE00000001, 0x000001BD3D1D98E0 )
0x00001CD4 51205 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *0000000000000000, TPI_GEN_CMD_CONSTRUCTOR, 0x0000000D75803800, 0x00007FFE00000001, 0x000001BD3D1D98E0 ) = 0x00000000
0x00001CD4 51205 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_SET_DS_VERSION, 0x0000000D0000000C, 0x00007FFE00000000, 0x000001BD00000000 )
0x00001CD4 51205 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_SET_DS_VERSION, 0x0000000D0000000C, 0x00007FFE00000000, 0x000001BD00000000 ) = 0x00000002
0x00001CD4 51205 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_NUM_PAGES, *0000000DAD8FDD20 )
0x00001CD4 51205 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_NUM_PAGES, *0000000DAD8FDD20 = 0x00000001 ) = 0x00000000
0x00001CD4 51205 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000000 )
0x00001CD4 51205 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_PAGE_NAME, 0x0000000000000000 ) = 0x00000000
0x00001CD4 51205 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000000, 0x0000000DAD8FDBA8 )
0x00001CD4 51205 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_MEMBUS_BITS, 0x0000000000000000, 0x0000000DAD8FDBA8 ) = 0x00000000
0x00001CD4 51205 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000000, *0000000DAD8FDBE8 )
0x00001CD4 51205 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_ENDIAN, 0x0000000000000000, *0000000DAD8FDBE8 = 0x00000002 ) = 0x00000000
0x00001CD4 51205 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000000, *0000000DAD8FDBF0 )
0x00001CD4 51205 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_SHOULD_HIDE_PAGE, 0x0000000000000000, *0000000DAD8FDBF0 = 0xAD8FDD00 ) = 0x00000002
0x00001CD4 51205 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000000, *0000000DAD8FDBEC )
0x00001CD4 51205 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_DEFAULT_ACCESS_SIZE, 0x0000000000000000, *0000000DAD8FDBEC = 0x00000004 ) = 0x00000002
0x00001CD4 51205 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_DEFAULT_PAGE, *000001BD290C1D58 )
0x00001CD4 51205 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_DEFAULT_PAGE, *000001BD290C1D58 = 0x00000000 ) = 0x00000002
0x00001CD4 51205 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_REG_PAGES, *0000000DAD8FDD28, *0000000DAD8FDD20 )
0x00001CD4 51205 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_REG_PAGES, *0000000DAD8FDD28 = 0x00000001, *0000000DAD8FDD20 = 0x00000079 ) = 0x00000002
0x00001CD4 51205 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_REGBUS_BITS, 0x0000000DAD8FDBA0, 0x0000000000000079 )
0x00001CD4 51205 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_REGBUS_BITS, 0x0000000DAD8FDBA0, 0x0000000000000079 ) = 0x00000000
0x00001CD4 51205 3 Cortex_M4_0 GTI C: GTI_GET_NUM_RESETS( 0x000001BD362E2770 )
0x00001CD4 51205 3  PRSC C: PRSC_QueryResetCapabilities: prscHandle=0x1bd29e1cbb0
0x00001CD4 51205 3  PRSC C: prsc_SendRouter: connectionNeeded=0x0
0x00001CD4 51205 3  PRSC C: GRTR:QueryResetGlobal: routerHandle=0x1bd2b9beca0
0x00001CD4 51205 3 IcePick_C TA C: GetNumResets()
0x00001CD4 51205 3 IcePick_C TA R: GetNumResets() = 2
0x00001CD4 51205 3  PRSC R: GRTR:QueryResetCapGlobal rstCAP=0x1
0x00001CD4 51205 3  PRSC C: prsc_SendRouter: error =0x0
0x00001CD4 51205 3  PRSC C: GRTR:QueryResetLoc: routerHandle=0x1bd2b9beca0
0x00001CD4 51205 3  PRSC R: GRTR:QueryResetCapLoc rstCAP=0x10
0x00001CD4 51205 3  PRSC R: PRSC_QueryResetCapabilities: resetType =0x11
0x00001CD4 51205 3 Cortex_M4_0 GTI R: GTI_GET_NUM_RESETS( 0x000001BD362E2770 ) = 0x00000004
0x00001CD4 51205 3 Cortex_M4_0 GTI C: GTI_GET_RESET_INFO( 0x000001BD362E2770, 0x00000000, *0x0000000DAD8FDB70 = ??? )
0x00001CD4 51205 3 Cortex_M4_0 GTI R: GTI_GET_RESET_INFO( 0x000001BD362E2770, 0x00000000, *0x0000000DAD8FDB70 = ??? ) = 0x00000000
0x00001CD4 51205 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD398 = 0x00000000, *0x0000000DAD8FD390 = 0x00000000, *0x0000000DAD8FD3A8 = 0x00000000, *0x0000000DAD8FD3C0 = 0x00000000, *0x0000000DAD8FD3C8 = 0x00000000, *0x0000000DAD8FD3B8 = 0x00000000, *0x0000000DAD8FD3B0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51205 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD398 = 0x00000000, *0x0000000DAD8FD390 = 0x00000000, *0x0000000DAD8FD3A8 = 0x00000000, *0x0000000DAD8FD3C0 = 0x00000002, *0x0000000DAD8FD3C8 = 0x00000000, *0x0000000DAD8FD3B8 = 0x00000008, *0x0000000DAD8FD3B0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51205 3 Cortex_M4_0 GTI C: GTI_GET_RESET_INFO( 0x000001BD362E2770, 0x00000001, *0x0000000DAD8FDB70 = ??? )
0x00001CD4 51205 3  PRSC C: PRSC_GetResetInfo: prscHandle=0x1bd29e1cbb0, resetType=0x1
0x00001CD4 51205 3  PRSC C: GRTR:GetResetInfoGlb: routerHandle=0x1bd2b9beca0
0x00001CD4 51205 3 IcePick_C TA C: QueryResetType( 0, 0000000DAD8FD610 )
0x00001CD4 51205 3 IcePick_C TA R: QueryResetType( 0, *0000000DAD8FD610 = 000001BD3D1FE400 ) = 0
0x00001CD4 51205 3  RA C: ResetAdapterImpl::GetName()
0x00001CD4 51205 3  RA R: ResetAdapterImpl::GetName() = GetReset().GetName().c_str()
0x00001CD4 51205 3  RA C: ResetAdapterImpl::GetToolTip()
0x00001CD4 51205 3  RA R: ResetAdapterImpl::GetToolTip() = GetReset().GetToolTip().c_str()
0x00001CD4 51205 3  PRSC R: GRTR:GetResetInfoGlb: pName=System Reset, pToolTip =ICEPick Generated System Warm Reset, pRequires=0x0, ret=0x0
0x00001CD4 51205 3  PRSC R: PRSC:GetResetInfo: ret=0x0, pName=System Reset, pToolTip =ICEPick Generated System Warm Reset, pRequires=0x0
0x00001CD4 51205 3 Cortex_M4_0 GTI R: GTI_GET_RESET_INFO( 0x000001BD362E2770, 0x00000001, *0x0000000DAD8FDB70 = ??? ) = 0x00000000
0x00001CD4 51205 3 Cortex_M4_0 GTI C: GTI_GET_RESET_INFO( 0x000001BD362E2770, 0x00000002, *0x0000000DAD8FDB70 = ??? )
0x00001CD4 51205 3 Cortex_M4_0 GTI R: GTI_GET_RESET_INFO( 0x000001BD362E2770, 0x00000002, *0x0000000DAD8FDB70 = ??? ) = 0x00000000
0x00001CD4 51205 3 Cortex_M4_0 GTI C: GTI_GET_RESET_INFO( 0x000001BD362E2770, 0x00000003, *0x0000000DAD8FDB70 = ??? )
0x00001CD4 51205 3 Cortex_M4_0 GTI R: GTI_GET_RESET_INFO( 0x000001BD362E2770, 0x00000003, *0x0000000DAD8FDB70 = ??? ) = 0x00000000
0x00001CD4 51205 3 Cortex_M4_0 GTI C: GTI_QUERY_INTERFACE( 0x000001BD362E2770, "IOperationServer", 0x00000002, *0x0000000DAD8FDDA0 = 0x0000000000000000, *0x0000000DAD8FDD98 = 0x00000000, *0x0000000DAD8FDD90 = 0, *0x0000000000000000 = (nullptr) )
0x00001CD4 51205 3 Cortex_M4_0 GTI R: GTI_QUERY_INTERFACE( 0x000001BD362E2770, "IOperationServer", 0x00000002, *0x0000000DAD8FDDA0 = 0x0000000000000000, *0x0000000DAD8FDD98 = 0x00000000, *0x0000000DAD8FDD90 = 0, *0x0000000000000000 = (nullptr) ) = 0xFFFFFFFF
0x00001CD4 51205 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_SET_CALLBACK, 0x000001BD3CDCCC80, 0x00007FFEC49C30E0 )
0x00001CD4 51205 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_SET_CALLBACK, 0x000001BD3CDCCC80, 0x00007FFEC49C30E0 ) = 0x00000000
0x00001CD4 51205 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_STATUS_REG, *0000000DAD8FDE40 )
0x00001CD4 51205 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_STATUS_REG, *0000000DAD8FDE40 = 0x392D2440 ) = 0x00000000
0x00001CD4 51205 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_READ_MEM added to polling loop by class `anonymous namespace'::TpiStatusRegistersImpl
0x00001CD4 51205 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD858 )
0x00001CD4 51205 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_VALUE_BITS, 0x0000000DAD8FD858 ) = 0x00000000
0x00001CD4 51205 3 Cortex_M4_0 TPI C: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD850 )
0x00001CD4 51205 3 Cortex_M4_0 TPI R: TpiSvrGenAPI( *000001BD2B9BBBB0, TPI_GEN_CMD_GET_EFFECTIVE_VALUE_BITS, 0x0000000DAD8FD850 ) = 0x00000002
0x00001CD4 51205 3 Cortex_M4_0 TA C: QueryInterface( 1 )
0x00001CD4 51205 3 Cortex_M4_0 TA R: QueryInterface( 1 ) = 000001BD36329068
0x00001CD4 51205 3 Cortex_M4_0 TA C: QueryInterface( 3 )
0x00001CD4 51205 3 Cortex_M4_0 TA R: QueryInterface( 3 ) = 000001BD36329058
0x00001CD4 51205 3 Cortex_M4_0 TA C: QueryInterface( 4 )
0x00001CD4 51205 3 Cortex_M4_0 TA R: QueryInterface( 4 ) = 000001BD36329070
0x00001CD4 51205 3  LIB C: dlsym( 00007FFEDF0F0000, "GetcToolsDBMgrIFDS" )
0x00001CD4 51205 3  LIB R: dlsym( 00007FFEDF0F0000, "GetcToolsDBMgrIFDS" ) = 00007FFEDF182DC0
0x00001CD4 51205 3 Cortex_M4_0 CT C: GetcToolsDBMgrIFDS( 000001BD36329060, 0000000DAD8FDB78 )
0x00001CD4 51205 3 Cortex_M4_0 CI C: GetProcessorID()
0x00001CD4 51205 3 Cortex_M4_0 CI R: GetProcessorID() = 0x75803800
0x00001CD4 51205 3 Cortex_M4_0 CI C: GetType()
0x00001CD4 51205 3 Cortex_M4_0 CI R: GetType() = 0x02CD6070
0x00001CD4 51205 3 Cortex_M4_0 CI C: GetLabel( 0000000DAD8FD330, 260 )
0x00001CD4 51205 3 Cortex_M4_0 CI R: GetLabel( *0000000DAD8FD330 = Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, 260 ) = 0
0x00001CD4 51205 3 Cortex_M4_0 CT R: GetcToolsDBMgrIFDS( 000001BD36329060, *0000000DAD8FDB78 = 000001BD2F9C1160 )
0x00001CD4 51205 3  PERF I: Ctools AddTarget() starting...
0x00001CD4 51205 3  CT C: JobMgrIFDS::AddTarget( 000001BD3CDCF630, 0000000000000000 )
0x00001CD4 51205 3 Cortex_M4_0 CI C: GetLabel( 0000000DAD8FD690, 1024 )
0x00001CD4 51205 3 Cortex_M4_0 CI R: GetLabel( *0000000DAD8FD690 = Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, 1024 ) = 0
0x00001CD4 51205 3 Cortex_M4_0 CI C: GetLabel( 0000000DAD8FD440, 260 )
0x00001CD4 51205 3 Cortex_M4_0 CI R: GetLabel( *0000000DAD8FD440 = Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, 260 ) = 0
0x00001CD4 51205 3 Cortex_M4_0 TA C: IsSimulator()
0x00001CD4 51205 3 Cortex_M4_0 TA R: IsSimulator() = false
0x00001CD4 51205 3 Cortex_M4_0 TA C: GetSiliconRevision()
0x00001CD4 51205 3 Cortex_M4_0 GTI C: GTI_GET_TARGET_PROPERTIES( 0x000001BD362E2770, 0x00000003 )
0x00001CD4 51205 3  CMAPI C: Acquire( 000001BD35050D30 )
0x00001CD4 51205 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 51205 3  CMAPI R: Acquire( 000001BD35050D30 ) = 0
0x00001CD4 51205 3  CMAPI C: Release( 000001BD35050D30 )
0x00001CD4 51205 3 Cortex_M4_0 GTI R: GTI_GET_TARGET_PROPERTIES( 0x000001BD362E2770, 0x00000003 ) = 0x00000001
0x00001CD4 51205 3 Cortex_M4_0 TA R: GetSiliconRevision() = 1
0x00001CD4 51205 3 Cortex_M4_0 TA C: IsConnected()
0x00001CD4 51205 3 Cortex_M4_0 TA R: IsConnected() = true
0x00001CD4 51205 3 Cortex_M4_0 CI C: GetLabel( 0000000DAD8FCC80, 260 )
0x00001CD4 51205 3 Cortex_M4_0 CI R: GetLabel( *0000000DAD8FCC80 = Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, 260 ) = 0
0x00001CD4 51205 3 Cortex_M4_0 TA C: GetParent()
0x00001CD4 51205 3 Cortex_M4_0 TA R: GetParent() = 000001BD3E2F4420
0x00001CD4 51205 3 CS_DAP_0 CI C: GetProcessorID()
0x00001CD4 51205 3 CS_DAP_0 CI R: GetProcessorID() = 0x38000405
0x00001CD4 51205 3 Cortex_M4_0 CI C: GetLabel( 0000000DAD8FC140, 260 )
0x00001CD4 51205 3 Cortex_M4_0 CI R: GetLabel( *0000000DAD8FC140 = Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, 260 ) = 0
0x00001CD4 51205 3 Cortex_M4_0 CI C: GetLabel( 0000000DAD8FC660, 80 )
0x00001CD4 51205 3 Cortex_M4_0 CI R: GetLabel( *0000000DAD8FC660 = Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, 80 ) = 0
0x00001CD4 51205 3 Cortex_M4_0 CI C: GetLabel( 0000000DAD8FC200, 260 )
0x00001CD4 51205 3 Cortex_M4_0 CI R: GetLabel( *0000000DAD8FC200 = Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, 260 ) = 0
0x00001CD4 51205 3 Cortex_M4_0 TA C: GetRegisterId( REG_VECTOR_CATCH, 0000000DAD8FC170 )
0x00001CD4 51205 3 Cortex_M4_0 TA C: GetRegisterId( REG_VECTOR_CATCH, 0x0000000000000000 )
0x00001CD4 51205 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='REG_VECTOR_CATCH' AND Register_Cache.Processor=35
0x00001CD4 51205 3 Cortex_M4_0 TA R: GetRegisterId( REG_VECTOR_CATCH, 0x0000000060000007 ) = 0
0x00001CD4 51205 3 Cortex_M4_0 TA R: GetRegisterId( REG_VECTOR_CATCH, *0000000DAD8FC170 = 0x60000007 ) = 0
0x00001CD4 51205 3 Cortex_M4_0 TA C: RegisterRead( 0x0000000060000007, 0x0000000060000007 )
0x00001CD4 51205 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372035244163065 AND Register_Cache.Address<=-9223372035244163065 AND Register_Cache.Page=121 AND Register_Cache.Processor=35
0x00001CD4 51205 3 Cortex_M4_0 GTI C: GTI_READREG( 0x000001BD362E2770, 0x60000007, *0x0000000DAD8FB408 = 0x2952F970 )
0x00001CD4 51221 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51221 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 51221 3  CMAPI R: Acquire( 000001BD35050D30 ) = 0
0x00001CD4 51221 3  CMAPI C: Release( 000001BD35050D30 )
0x00001CD4 51221 3  CMAPI R: Release( 000001BD35050D30 ) = 0
0x00001CD4 51221 3 Cortex_M4_0 GTI R: GTI_READREG( 0x000001BD362E2770, 0x60000007, *0x0000000DAD8FB408 = 0x00000000 ) = 0x00000000
0x00001CD4 51221 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FAB88 = 0x00000000, *0x0000000DAD8FAB80 = 0x00000000, *0x0000000DAD8FAB98 = 0x00000000, *0x0000000DAD8FABB0 = 0x00000000, *0x0000000DAD8FABB8 = 0x00000000, *0x0000000DAD8FABA8 = 0x00000000, *0x0000000DAD8FABA0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51221 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FAB88 = 0x00000000, *0x0000000DAD8FAB80 = 0x00000000, *0x0000000DAD8FAB98 = 0x00000000, *0x0000000DAD8FABB0 = 0x00000002, *0x0000000DAD8FABB8 = 0x00000000, *0x0000000DAD8FABA8 = 0x00000008, *0x0000000DAD8FABA0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51221 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FAA58 = 0x00000000, *0x0000000DAD8FAA50 = 0x00000000, *0x0000000DAD8FAA68 = 0x00000000, *0x0000000DAD8FAA80 = 0x00000000, *0x0000000DAD8FAA88 = 0x00000000, *0x0000000DAD8FAA78 = 0x00000000, *0x0000000DAD8FAA70 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51221 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FAA58 = 0x00000000, *0x0000000DAD8FAA50 = 0x00000000, *0x0000000DAD8FAA68 = 0x00000000, *0x0000000DAD8FAA80 = 0x00000002, *0x0000000DAD8FAA88 = 0x00000000, *0x0000000DAD8FAA78 = 0x00000008, *0x0000000DAD8FAA70 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51221 3 Cortex_M4_0 TA R: RegisterRead( 0x0000000060000007, 0x0000000000000000 ) = 0
0x00001CD4 51221 3 IcePick_C CI C: GetLabel( 000001BD29C7FA90, 120 )
0x00001CD4 51221 3 IcePick_C CI R: GetLabel( *000001BD29C7FA90 = Texas Instruments XDS110 USB Debug Probe/IcePick_C, 120 ) = 0
0x00001CD4 51221 3 CS_DAP_0 CI C: GetLabel( 000001BD29C7FA90, 120 )
0x00001CD4 51221 3 CS_DAP_0 CI R: GetLabel( *000001BD29C7FA90 = Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, 120 ) = 0
0x00001CD4 51221 3 Cortex_M4_0 TA C: RegisterWrite( 0x0000000060000007, 0x0000000001000000 )
0x00001CD4 51221 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372035244163065 AND Register_Cache.Address<=-9223372035244163065 AND Register_Cache.Page=121 AND Register_Cache.Processor=35
0x00001CD4 51221 3 Cortex_M4_0 GTI C: GTI_WRITEREG( 0x000001BD362E2770, 0x60000007, *0x0000000DAD8FB5F8 = 0x01000000 )
0x00001CD4 51221 3  CMAPI C: Acquire( 000001BD35050D30 )
0x00001CD4 51221 3 Cortex_M4_0 GTI R: GTI_WRITEREG( 0x000001BD362E2770, 0x60000007, *0x0000000DAD8FB5F8 = 0x01000000 ) = 0x00000000
0x00001CD4 51221 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FAD78 = 0x00000000, *0x0000000DAD8FAD70 = 0x00000000, *0x0000000DAD8FAD88 = 0x00000000, *0x0000000DAD8FADA0 = 0x00000000, *0x0000000DAD8FADA8 = 0x00000000, *0x0000000DAD8FAD98 = 0x00000000, *0x0000000DAD8FAD90 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51221 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FAD78 = 0x00000000, *0x0000000DAD8FAD70 = 0x00000000, *0x0000000DAD8FAD88 = 0x00000000, *0x0000000DAD8FADA0 = 0x00000002, *0x0000000DAD8FADA8 = 0x00000000, *0x0000000DAD8FAD98 = 0x00000008, *0x0000000DAD8FAD90 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51221 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FAC48 = 0x00000000, *0x0000000DAD8FAC40 = 0x00000000, *0x0000000DAD8FAC58 = 0x00000000, *0x0000000DAD8FAC70 = 0x00000000, *0x0000000DAD8FAC78 = 0x00000000, *0x0000000DAD8FAC68 = 0x00000000, *0x0000000DAD8FAC60 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51221 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FAC48 = 0x00000000, *0x0000000DAD8FAC40 = 0x00000000, *0x0000000DAD8FAC58 = 0x00000000, *0x0000000DAD8FAC70 = 0x00000002, *0x0000000DAD8FAC78 = 0x00000000, *0x0000000DAD8FAC68 = 0x00000008, *0x0000000DAD8FAC60 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51221 3 Cortex_M4_0 TA R: RegisterWrite( 0x0000000060000007, 0x0000000001000000 ) = 0
0x00001CD4 51221 3 Cortex_M4_0 TA C: GetRegisterId( FP_CTRL, 0000000DAD8FC0C0 )
0x00001CD4 51221 3 Cortex_M4_0 TA C: GetRegisterId( FP_CTRL, 0x0000000000000000 )
0x00001CD4 51221 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='FP_CTRL' AND Register_Cache.Processor=35
0x00001CD4 51221 3 Cortex_M4_0 TA R: GetRegisterId( FP_CTRL, 0x0000000064100000 ) = 0
0x00001CD4 51221 3 Cortex_M4_0 TA R: GetRegisterId( FP_CTRL, *0000000DAD8FC0C0 = 0x64100000 ) = 0
0x00001CD4 51221 3 Cortex_M4_0 TA C: RegisterRead( 0x0000000064100000, 0x0000000064100000 )
0x00001CD4 51221 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372035176005632 AND Register_Cache.Address<=-9223372035176005632 AND Register_Cache.Page=121 AND Register_Cache.Processor=35
0x00001CD4 51221 3 Cortex_M4_0 GTI C: GTI_READREG( 0x000001BD362E2770, 0x64100000, *0x0000000DAD8FB348 = 0x2952F970 )
0x00001CD4 51221 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE0002000, 4, 0000000DAD8FB228, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51221 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51236 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000000, *value = 0x63000052 ) = 0
0x00001CD4 51236 3  XDS110 I: Depth1: DpRegWrite( address = 0x00000008, *value = 0x00000000 ) = 0
0x00001CD4 51236 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe0002000 ) = 0
0x00001CD4 51236 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51236 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000261 = 0
0x00001CD4 51236 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51236 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51236 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE0002000, 4, *0000000DAD8FB228 = [61 02 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 51236 3  CMAPI C: Release( 000001BD35050D30 )
0x00001CD4 51236 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 51236 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51236 3  CMAPI R: Release( 000001BD35050D30 ) = 0
0x00001CD4 51236 3 Cortex_M4_0 GTI R: GTI_READREG( 0x000001BD362E2770, 0x64100000, *0x0000000DAD8FB348 = 0x00000261 ) = 0x00000000
0x00001CD4 51236 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FAAC8 = 0x00000000, *0x0000000DAD8FAAC0 = 0x00000000, *0x0000000DAD8FAAD8 = 0x00000000, *0x0000000DAD8FAAF0 = 0x00000000, *0x0000000DAD8FAAF8 = 0x00000000, *0x0000000DAD8FAAE8 = 0x00000000, *0x0000000DAD8FAAE0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51236 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FAAC8 = 0x00000000, *0x0000000DAD8FAAC0 = 0x00000000, *0x0000000DAD8FAAD8 = 0x00000000, *0x0000000DAD8FAAF0 = 0x00000002, *0x0000000DAD8FAAF8 = 0x00000000, *0x0000000DAD8FAAE8 = 0x00000008, *0x0000000DAD8FAAE0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51236 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FA998 = 0x00000000, *0x0000000DAD8FA990 = 0x00000000, *0x0000000DAD8FA9A8 = 0x00000000, *0x0000000DAD8FA9C0 = 0x00000000, *0x0000000DAD8FA9C8 = 0x00000000, *0x0000000DAD8FA9B8 = 0x00000000, *0x0000000DAD8FA9B0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51236 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FA998 = 0x00000000, *0x0000000DAD8FA990 = 0x00000000, *0x0000000DAD8FA9A8 = 0x00000000, *0x0000000DAD8FA9C0 = 0x00000002, *0x0000000DAD8FA9C8 = 0x00000000, *0x0000000DAD8FA9B8 = 0x00000008, *0x0000000DAD8FA9B0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51236 3 Cortex_M4_0 TA R: RegisterRead( 0x0000000064100000, 0x0000000000000261 ) = 0
0x00001CD4 51236 3 IcePick_C CI C: GetLabel( 000001BD29C7F810, 120 )
0x00001CD4 51236 3 IcePick_C CI R: GetLabel( *000001BD29C7F810 = Texas Instruments XDS110 USB Debug Probe/IcePick_C, 120 ) = 0
0x00001CD4 51236 3 CS_DAP_0 CI C: GetLabel( 000001BD29C7F810, 120 )
0x00001CD4 51236 3 CS_DAP_0 CI R: GetLabel( *000001BD29C7F810 = Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, 120 ) = 0
0x00001CD4 51236 3 Cortex_M4_0 TA C: GetRegisterId( DWT_CTRL, 0000000DAD8FC0B8 )
0x00001CD4 51236 3 Cortex_M4_0 TA C: GetRegisterId( DWT_CTRL, 0x0000000000000000 )
0x00001CD4 51236 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='DWT_CTRL' AND Register_Cache.Processor=35
0x00001CD4 51236 3 Cortex_M4_0 TA R: GetRegisterId( DWT_CTRL, 0x0000000064200000 ) = 0
0x00001CD4 51236 3 Cortex_M4_0 TA R: GetRegisterId( DWT_CTRL, *0000000DAD8FC0B8 = 0x64200000 ) = 0
0x00001CD4 51236 3 Cortex_M4_0 TA C: RegisterRead( 0x0000000064200000, 0x0000000064200000 )
0x00001CD4 51236 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372035174957056 AND Register_Cache.Address<=-9223372035174957056 AND Register_Cache.Page=121 AND Register_Cache.Processor=35
0x00001CD4 51236 3 Cortex_M4_0 GTI C: GTI_READREG( 0x000001BD362E2770, 0x64200000, *0x0000000DAD8FB348 = 0x2952F970 )
0x00001CD4 51236 3  CMAPI C: Acquire( 000001BD35050D30 )
0x00001CD4 51236 3  CMAPI R: Acquire( 000001BD35050D30 ) = 0
0x00001CD4 51236 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE0001000, 4, 0000000DAD8FB228, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51236 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51236 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe0001000 ) = 0
0x00001CD4 51236 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000261 = 0
0x00001CD4 51236 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x40000000 = 0
0x00001CD4 51236 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE0001000, 4, *0000000DAD8FB228 = [00 00 00 40 ...], 0000000000000000 ) = 0
0x00001CD4 51236 3 Cortex_M4_0 GTI R: GTI_READREG( 0x000001BD362E2770, 0x64200000, *0x0000000DAD8FB348 = 0x40000000 ) = 0x00000000
0x00001CD4 51236 3 Cortex_M4_0 TA R: RegisterRead( 0x0000000064200000, 0x0000000040000000 ) = 0
0x00001CD4 51236 3 IcePick_C CI C: GetLabel( 000001BD29C80410, 120 )
0x00001CD4 51236 3 IcePick_C CI R: GetLabel( *000001BD29C80410 = Texas Instruments XDS110 USB Debug Probe/IcePick_C, 120 ) = 0
0x00001CD4 51236 3 CS_DAP_0 CI C: GetLabel( 000001BD29C80410, 120 )
0x00001CD4 51236 3 CS_DAP_0 CI R: GetLabel( *000001BD29C80410 = Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, 120 ) = 0
0x00001CD4 51236 3 Cortex_M4_0 TA C: GetRegisterId( DWT_CTRL, 0000000DAD8FC170 )
0x00001CD4 51236 3 Cortex_M4_0 TA R: GetRegisterId( DWT_CTRL, *0000000DAD8FC170 = 0x64200000 ) = 0
0x00001CD4 51236 3 Cortex_M4_0 GTI C: GTI_READREG( 0x000001BD362E2770, 0x64200000, *0x0000000DAD8FB408 = 0x2952F970 )
0x00001CD4 51236 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE0001000, 4, 0000000DAD8FB2E8, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51252 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000000, *value = 0x63000052 ) = 0
0x00001CD4 51252 3  XDS110 I: Depth1: DpRegWrite( address = 0x00000008, *value = 0x00000000 ) = 0
0x00001CD4 51252 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe0001000 ) = 0
0x00001CD4 51252 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x40000000 = 0
0x00001CD4 51252 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x40000000 = 0
0x00001CD4 51252 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51252 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51252 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE0001000, 4, *0000000DAD8FB2E8 = [00 00 00 40 ...], 0000000000000000 ) = 0
0x00001CD4 51252 3  CMAPI C: Release( 000001BD35050D30 )
0x00001CD4 51252 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 51252 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51252 3  CMAPI R: Release( 000001BD35050D30 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 GTI R: GTI_READREG( 0x000001BD362E2770, 0x64200000, *0x0000000DAD8FB408 = 0x40000000 ) = 0x00000000
0x00001CD4 51252 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FAB88 = 0x00000000, *0x0000000DAD8FAB80 = 0x00000000, *0x0000000DAD8FAB98 = 0x00000000, *0x0000000DAD8FABB0 = 0x00000000, *0x0000000DAD8FABB8 = 0x00000000, *0x0000000DAD8FABA8 = 0x00000000, *0x0000000DAD8FABA0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51252 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FAB88 = 0x00000000, *0x0000000DAD8FAB80 = 0x00000000, *0x0000000DAD8FAB98 = 0x00000000, *0x0000000DAD8FABB0 = 0x00000002, *0x0000000DAD8FABB8 = 0x00000000, *0x0000000DAD8FABA8 = 0x00000008, *0x0000000DAD8FABA0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51252 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FAA58 = 0x00000000, *0x0000000DAD8FAA50 = 0x00000000, *0x0000000DAD8FAA68 = 0x00000000, *0x0000000DAD8FAA80 = 0x00000000, *0x0000000DAD8FAA88 = 0x00000000, *0x0000000DAD8FAA78 = 0x00000000, *0x0000000DAD8FAA70 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51252 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FAA58 = 0x00000000, *0x0000000DAD8FAA50 = 0x00000000, *0x0000000DAD8FAA68 = 0x00000000, *0x0000000DAD8FAA80 = 0x00000002, *0x0000000DAD8FAA88 = 0x00000000, *0x0000000DAD8FAA78 = 0x00000008, *0x0000000DAD8FAA70 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51252 3 Cortex_M4_0 TA R: RegisterRead( 0x0000000064200000, 0x0000000040000000 ) = 0
0x00001CD4 51252 3 IcePick_C CI C: GetLabel( 000001BD29C80610, 120 )
0x00001CD4 51252 3 IcePick_C CI R: GetLabel( *000001BD29C80610 = Texas Instruments XDS110 USB Debug Probe/IcePick_C, 120 ) = 0
0x00001CD4 51252 3 CS_DAP_0 CI C: GetLabel( 000001BD29C80610, 120 )
0x00001CD4 51252 3 CS_DAP_0 CI R: GetLabel( *000001BD29C80610 = Texas Instruments XDS110 USB Debug Probe/CS_DAP_0, 120 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_CTRL, 000001BD29C80764 )
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_CTRL, 0x0000000000000000 )
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_CTRL, 0x0000000064200000 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_CTRL, *000001BD29C80764 = 0x64200000 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_CYCCNT, 000001BD29C80768 )
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_CYCCNT, 0x0000000000000000 )
0x00001CD4 51252 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='DWT_CYCCNT' AND Register_Cache.Processor=35
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_CYCCNT, 0x0000000064200004 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_CYCCNT, *000001BD29C80768 = 0x64200004 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( REG_VECTOR_CATCH, 000001BD29C8076C )
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( REG_VECTOR_CATCH, 0x0000000000000000 )
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( REG_VECTOR_CATCH, 0x0000000060000007 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( REG_VECTOR_CATCH, *000001BD29C8076C = 0x60000007 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_CTRL, 000001BD29C7F1E4 )
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_CTRL, *000001BD29C7F1E4 = 0x64200000 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_CPICNT, 000001BD29C7F1E8 )
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_CPICNT, 0x0000000000000000 )
0x00001CD4 51252 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='DWT_CPICNT' AND Register_Cache.Processor=35
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_CPICNT, 0x0000000064200008 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_CPICNT, *000001BD29C7F1E8 = 0x64200008 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( REG_VECTOR_CATCH, 000001BD29C7F1EC )
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( REG_VECTOR_CATCH, *000001BD29C7F1EC = 0x60000007 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_CTRL, 000001BD29C7EB64 )
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_CTRL, *000001BD29C7EB64 = 0x64200000 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_EXCCNT, 000001BD29C7EB68 )
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_EXCCNT, 0x0000000000000000 )
0x00001CD4 51252 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='DWT_EXCCNT' AND Register_Cache.Processor=35
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_EXCCNT, 0x000000006420000C ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_EXCCNT, *000001BD29C7EB68 = 0x6420000C ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( REG_VECTOR_CATCH, 000001BD29C7EB6C )
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( REG_VECTOR_CATCH, *000001BD29C7EB6C = 0x60000007 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_CTRL, 000001BD29C80864 )
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_CTRL, *000001BD29C80864 = 0x64200000 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_SLEEPCNT, 000001BD29C80868 )
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_SLEEPCNT, 0x0000000000000000 )
0x00001CD4 51252 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='DWT_SLEEPCNT' AND Register_Cache.Processor=35
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_SLEEPCNT, 0x0000000064200010 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_SLEEPCNT, *000001BD29C80868 = 0x64200010 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( REG_VECTOR_CATCH, 000001BD29C8086C )
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( REG_VECTOR_CATCH, *000001BD29C8086C = 0x60000007 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_CTRL, 000001BD29C7F564 )
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_CTRL, *000001BD29C7F564 = 0x64200000 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_LSUCNT, 000001BD29C7F568 )
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_LSUCNT, 0x0000000000000000 )
0x00001CD4 51252 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='DWT_LSUCNT' AND Register_Cache.Processor=35
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_LSUCNT, 0x0000000064200014 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_LSUCNT, *000001BD29C7F568 = 0x64200014 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( REG_VECTOR_CATCH, 000001BD29C7F56C )
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( REG_VECTOR_CATCH, *000001BD29C7F56C = 0x60000007 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_CTRL, 000001BD29C7EAE4 )
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_CTRL, *000001BD29C7EAE4 = 0x64200000 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_FOLDCNT, 000001BD29C7EAE8 )
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_FOLDCNT, 0x0000000000000000 )
0x00001CD4 51252 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='DWT_FOLDCNT' AND Register_Cache.Processor=35
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_FOLDCNT, 0x0000000064200018 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_FOLDCNT, *000001BD29C7EAE8 = 0x64200018 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( REG_VECTOR_CATCH, 000001BD29C7EAEC )
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( REG_VECTOR_CATCH, *000001BD29C7EAEC = 0x60000007 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_CTRL, 000001BD35CA16BC )
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_CTRL, *000001BD35CA16BC = 0x64200000 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( REG_VECTOR_CATCH, 000001BD35CA16C0 )
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( REG_VECTOR_CATCH, *000001BD35CA16C0 = 0x60000007 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( DWT_CYCCNT, 000001BD35CA16C4 )
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( DWT_CYCCNT, *000001BD35CA16C4 = 0x64200004 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( ICEC_DEBUG_CSR, 000001BD350500D4 )
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( ICEC_DEBUG_CSR, 0x0000000000000000 )
0x00001CD4 51252 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='ICEC_DEBUG_CSR' AND Register_Cache.Processor=35
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( ICEC_DEBUG_CSR, 0x0000000065100002 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( ICEC_DEBUG_CSR, *000001BD350500D4 = 0x65100002 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( ICEC_TRIGGER_CONTROL, 000001BD350500D8 )
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( ICEC_TRIGGER_CONTROL, 0x0000000000000000 )
0x00001CD4 51252 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='ICEC_TRIGGER_CONTROL' AND Register_Cache.Processor=35
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( ICEC_TRIGGER_CONTROL, 0x0000000065100003 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( ICEC_TRIGGER_CONTROL, *000001BD350500D8 = 0x65100003 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( ICEC_DCON, 000001BD350500DC )
0x00001CD4 51252 3 Cortex_M4_0 TA C: GetRegisterId( ICEC_DCON, 0x0000000000000000 )
0x00001CD4 51252 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='ICEC_DCON' AND Register_Cache.Processor=35
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( ICEC_DCON, 0x0000000065100008 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA R: GetRegisterId( ICEC_DCON, *000001BD350500DC = 0x65100008 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 CI C: GetLabel( 0000000DAD8FC6A0, 260 )
0x00001CD4 51252 3 Cortex_M4_0 CI R: GetLabel( *0000000DAD8FC6A0 = Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, 260 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: IsSimulator()
0x00001CD4 51252 3 Cortex_M4_0 TA R: IsSimulator() = false
0x00001CD4 51252 3 Cortex_M4_0 CI C: GetType()
0x00001CD4 51252 3 Cortex_M4_0 CI R: GetType() = 0x02CD6070
0x00001CD4 51252 3 Cortex_M4_0 CI C: GetLabel( 0000000DAD8FCC80, 260 )
0x00001CD4 51252 3 Cortex_M4_0 CI R: GetLabel( *0000000DAD8FCC80 = Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, 260 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 TA C: RegisterForEvents( 000001BD35C9F430 )
0x00001CD4 51252 3 Cortex_M4_0 TA R: RegisterForEvents( 000001BD35C9F430 )
0x00001CD4 51252 3  CT R: JobMgrIFDS::AddTarget( 000001BD3CDCF630, 0000000000000000 ) = 2
0x00001CD4 51252 3  PERF I: Ctools AddTarget() finished:  0.050775s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 51252 3  LIB C: dlsym( 00007FFEDF810000, "QueryInterface" )
0x00001CD4 51252 3  LIB R: dlsym( 00007FFEDF810000, "QueryInterface" ) = 00007FFEDF81FA50
0x00001CD4 51252 3  PERF I: Ctools QueryInterface( 0 ) starting...
0x00001CD4 51252 3 Cortex_M4_0 CT C: QueryInterface( 000001BD3CDCF630, 0 )
0x00001CD4 51252 3 Cortex_M4_0 CI C: GetLabel( 0000000DAD8FD410, 1024 )
0x00001CD4 51252 3 Cortex_M4_0 CI R: GetLabel( *0000000DAD8FD410 = Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, 1024 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 CT R: QueryInterface( 000001BD3CDCF630, 0 ) = 000001BD3DBDEFF0
0x00001CD4 51252 3  PERF I: Ctools QueryInterface( 0 ) finished:  0.001765s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 51252 3  LIB C: dlopen( "BreakpointLogger.dll", 0 )
0x00001CD4 51252 3  LIB R: dlopen( "BreakpointLogger.dll", 0 ) = 0000000000000000
0x00001CD4 51252 3  PERF I: Ctools QueryInterface( 3 ) starting...
0x00001CD4 51252 3 Cortex_M4_0 CT C: QueryInterface( 000001BD3CDCF630, 3 )
0x00001CD4 51252 3 Cortex_M4_0 CT R: QueryInterface( 000001BD3CDCF630, 3 ) = 000001BD358854B0
0x00001CD4 51252 3  PERF I: Ctools QueryInterface( 3 ) finished:  0.000042s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 51252 3  PERF I: Ctools QueryInterface( 2 ) starting...
0x00001CD4 51252 3 Cortex_M4_0 CT C: QueryInterface( 000001BD3CDCF630, 2 )
0x00001CD4 51252 3 Cortex_M4_0 CI C: GetLabel( 0000000DAD8FD670, 1024 )
0x00001CD4 51252 3 Cortex_M4_0 CI R: GetLabel( *0000000DAD8FD670 = Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, 1024 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 CT R: QueryInterface( 000001BD3CDCF630, 2 ) = 000001BD290C3930
0x00001CD4 51252 3  PERF I: Ctools QueryInterface( 2 ) finished:  0.000042s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 51252 3  PERF I: Ctools QueryInterface( 1 ) starting...
0x00001CD4 51252 3 Cortex_M4_0 CT C: QueryInterface( 000001BD3CDCF630, 1 )
0x00001CD4 51252 3 Cortex_M4_0 CI C: GetLabel( 0000000DAD8FD760, 1024 )
0x00001CD4 51252 3 Cortex_M4_0 CI R: GetLabel( *0000000DAD8FD760 = Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0, 1024 ) = 0
0x00001CD4 51252 3 Cortex_M4_0 CT R: QueryInterface( 000001BD3CDCF630, 1 ) = 000001BD29C7FCF0
0x00001CD4 51252 3  PERF I: Ctools QueryInterface( 1 ) finished:  0.000039s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 51252 3 Cortex_M4_0 CT C: SyncMode::QueryInterface( ReferenceCounting::IDSyncMode2 )
0x00001CD4 51252 3 Cortex_M4_0 CT C: SyncMode::QueryInterface( ReferenceCounting::IDSyncMode2 ) = 000001BD29C7FC90
0x00001CD4 51252 3 Cortex_M4_0 CT C: SyncMode::GetNumCrossTriggeringGroups()
0x00001CD4 51252 3 Cortex_M4_0 CT R: SyncMode::GetNumCrossTriggeringGroups() = 0
0x00001CD4 51252 3 Cortex_M4_0 CT C: SyncMode::ModifiableWhileRunning()
0x00001CD4 51252 3 Cortex_M4_0 CT R: SyncMode::ModifiableWhileRunning() = 0
0x00001CD4 51252 3  PERF I: GEL OnTargetConnect() starting...
0x00001CD4 51252 3  SEQUENCE I: Finished sequence step at 0000000DAD8FDE20
0x00001CD4 51252 3  SEQUENCE I: Beginning class Debugger::GelCallbackStep at 000001BD29530630
0x00001CD4 51252 3 Cortex_M4_0 GEL I: Evaluating "OnTargetConnect()"
0x00001CD4 51252 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 51252 3 Cortex_M4_0 POLL C: Firing DSP_PRIORITY_CONNECTED to all DSP_USER's
0x00001CD4 51252 3 Cortex_M4_0 POLL C: Firing of DSP_PRIORITY_CONNECTED complete
0x00001CD4 51252 3 Cortex_M4_0 STATE I: Debugger execution state changed to EVENT_DSP_HALT
0x00001CD4 51252 3 Cortex_M4_0 GTI C: GTI_GET_TARGET_PROPERTIES( 0x000001BD362E2770, 0x00000001 )
0x00001CD4 51252 3  CMAPI C: Acquire( 000001BD35050D30 )
0x00001CD4 51252 3  CMAPI R: Acquire( 000001BD35050D30 ) = 0
0x00001CD4 51267 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51267 3  CMAPI R: Release( 000001BD35050D30 ) = 0
0x00001CD4 51267 3 Cortex_M4_0 GTI R: GTI_GET_TARGET_PROPERTIES( 0x000001BD362E2770, 0x00000001 ) = 0x00000000
0x00001CD4 51267 3 Cortex_M4_0 TPI C: TpiSvrStepAPI( *0000000000000000, TPI_STEP_CMD_GET_REVISION, *0000000DAD8FD8D0 )
0x00001CD4 51267 3 Cortex_M4_0 TPI R: TpiSvrStepAPI( *0000000000000000, TPI_STEP_CMD_GET_REVISION, *0000000DAD8FD8D0 = 0x00000064 ) = 0x00000000
0x00001CD4 51267 3 Cortex_M4_0 TPI C: TpiSvrStepAPI( *0000000000000000, TPI_STEP_CMD_CONSTRUCTOR, 0x0000000D75803800, 0x0000000000000001, 0x000001BD3D1FEC80, 0x00007FFEC49C3380, 0x000001BD2B5B9598 )
0x00001CD4 51267 3 Cortex_M4_0 TPI R: TpiSvrStepAPI( *0000000000000000, TPI_STEP_CMD_CONSTRUCTOR, 0x0000000D75803800, 0x0000000000000001, 0x000001BD3D1FEC80, 0x00007FFEC49C3380, 0x000001BD2B5B9598 ) = 0x00000000
0x00001CD4 51267 3 Cortex_M4_0 TPI C: TpiSvrStepAPI( *000001BD35C906C0, TPI_STEP_CMD_GET_CACHE_SIZE, *0000000DAD8FD700 )
0x00001CD4 51267 3 Cortex_M4_0 TPI R: TpiSvrStepAPI( *000001BD35C906C0, TPI_STEP_CMD_GET_CACHE_SIZE, *0000000DAD8FD700 = 0x00000010 ) = 0x00000000
0x00001CD4 51267 3 Cortex_M4_0 TPI C: TpiSvrStepAPI( *000001BD35C906C0, TPI_STEP_CMD_GET_STATUS_REG, 0x0000000DAD8FD758, *0000000DAD8FD8D8, *0000000DAD8FD8C8, *0000000DAD8FD8C0 )
0x00001CD4 51267 3 Cortex_M4_0 TPI R: TpiSvrStepAPI( *000001BD35C906C0, TPI_STEP_CMD_GET_STATUS_REG, 0x0000000DAD8FD758, *0000000DAD8FD8D8 = 0x0000000000000000, *0000000DAD8FD8C8 = 0x00000001, *0000000DAD8FD8C0 = 0x00000079 ) = 0x00000000
0x00001CD4 51267 3 Cortex_M4_0 TPI C: TpiSvrStepAPI( *0000000000000000, TPI_STEP_CMD_CONSTRUCTOR, 0x0000000D75803800, 0x0000000000000001, 0x000001BD3D1FEE40, 0x00007FFEC49C3380, 0x000001BD3D611688 )
0x00001CD4 51267 3 Cortex_M4_0 TPI R: TpiSvrStepAPI( *0000000000000000, TPI_STEP_CMD_CONSTRUCTOR, 0x0000000D75803800, 0x0000000000000001, 0x000001BD3D1FEE40, 0x00007FFEC49C3380, 0x000001BD3D611688 ) = 0x00000000
0x00001CD4 51267 3 Cortex_M4_0 TPI C: TpiSvrStepAPI( *000001BD35C906F0, TPI_STEP_CMD_GET_CACHE_SIZE, *0000000DAD8FD700 )
0x00001CD4 51267 3 Cortex_M4_0 TPI R: TpiSvrStepAPI( *000001BD35C906F0, TPI_STEP_CMD_GET_CACHE_SIZE, *0000000DAD8FD700 = 0x00000010 ) = 0x00000000
0x00001CD4 51267 3 Cortex_M4_0 TPI C: TpiSvrStepAPI( *000001BD35C906F0, TPI_STEP_CMD_GET_STATUS_REG, 0x0000000DAD8FD758, *0000000DAD8FD8D8, *0000000DAD8FD8C8, *0000000DAD8FD8C0 )
0x00001CD4 51267 3 Cortex_M4_0 TPI R: TpiSvrStepAPI( *000001BD35C906F0, TPI_STEP_CMD_GET_STATUS_REG, 0x0000000DAD8FD758, *0000000DAD8FD8D8 = 0x0000000000000000, *0000000DAD8FD8C8 = 0x00000001, *0000000DAD8FD8C0 = 0x00000079 ) = 0x00000000
0x00001CD4 51267 4 Cortex_M4_0 EX_STEP I: A halt was requested by the user
0x00001CD4 51267 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 51267 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 51267 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 436 ms
0x00001CD4 51267 4  POLL I: TimeToSleep() found shorter sleep time of 436 ms from class DevicePollFrequencyManager
0x00001CD4 51267 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 51267 4 Cortex_M4_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 51267 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 51267 4  POLL I: Yielding to other threads
0x00001CD4 51267 3 Cortex_M4_0 POLL C: Polling with state STATE_GET_PC and status EVENT_DSP_HALT
0x00001CD4 51267 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775281 AND Register_Cache.Address<=-9223372036854775281 AND Register_Cache.Page=121 AND Register_Cache.Processor=35
0x00001CD4 51267 3 Cortex_M4_0 GTI C: GTI_READREG( 0x000001BD362E2770, 0x0000020F, *0x0000000DAD8FDCD0 = 0x00000000 )
0x00001CD4 51267 3  CMAPI C: Acquire( 000001BD35050D30 )
0x00001CD4 51267 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 51267 3  CMAPI R: Acquire( 000001BD35050D30 ) = 0
0x00001CD4 51267 3  CMAPI C: Release( 000001BD35050D30 )
0x00001CD4 51267 3 Cortex_M4_0 GTI R: GTI_READREG( 0x000001BD362E2770, 0x0000020F, *0x0000000DAD8FDCD0 = 0x1000118E ) = 0x00000000
0x00001CD4 51267 3  SETUP I: SELECT * FROM Module_Instances WHERE dbid=581
0x00001CD4 51267 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD5C8 = 0x00000000, *0x0000000DAD8FD5C0 = 0x00000000, *0x0000000DAD8FD5D8 = 0x00000000, *0x0000000DAD8FD5F0 = 0x00000000, *0x0000000DAD8FD5F8 = 0x00000000, *0x0000000DAD8FD5E8 = 0x00000000, *0x0000000DAD8FD5E0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51267 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD5C8 = 0x00000000, *0x0000000DAD8FD5C0 = 0x00000000, *0x0000000DAD8FD5D8 = 0x00000000, *0x0000000DAD8FD5F0 = 0x00000002, *0x0000000DAD8FD5F8 = 0x00000000, *0x0000000DAD8FD5E8 = 0x00000008, *0x0000000DAD8FD5E0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51267 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD7D8 = 0x00000000, *0x0000000DAD8FD7D0 = 0x00000000, *0x0000000DAD8FD7E8 = 0x00000000, *0x0000000DAD8FD800 = 0x00000000, *0x0000000DAD8FD808 = 0x00000000, *0x0000000DAD8FD7F8 = 0x00000000, *0x0000000DAD8FD7F0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51267 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD7D8 = 0x00000000, *0x0000000DAD8FD7D0 = 0x00000000, *0x0000000DAD8FD7E8 = 0x00000000, *0x0000000DAD8FD800 = 0x00000002, *0x0000000DAD8FD808 = 0x00000000, *0x0000000DAD8FD7F8 = 0x00000008, *0x0000000DAD8FD7F0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51267 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 108 ms
0x00001CD4 51267 4  POLL I: TimeToSleep() found shorter sleep time of 108 ms from class DevicePollFrequencyManager
0x00001CD4 51267 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 172 ms
0x00001CD4 51267 3 Cortex_M4_0 POLL C: Polling with state STATE_GET_CLK and status EVENT_DSP_HALT
0x00001CD4 51267 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775283 AND Register_Cache.Address<=-9223372036854775283 AND Register_Cache.Page=121 AND Register_Cache.Processor=35
0x00001CD4 51267 3 Cortex_M4_0 GTI C: GTI_READREG( 0x000001BD362E2770, 0x0000020D, *0x0000000DAD8FDCD0 = 0x00000000 )
0x00001CD4 51267 3 Cortex_M4_0 GTI R: GTI_READREG( 0x000001BD362E2770, 0x0000020D, *0x0000000DAD8FDCD0 = 0x11001FF0 ) = 0x00000000
0x00001CD4 51267 3 Cortex_M4_0 POLL C: Firing DSP_TARGET_HALT_DETECTED to all DSP_USER's
0x00001CD4 51267 3  COM_DBG_IF C: class DSP_CO_USER::OnTargetHaltDetected()
0x00001CD4 51267 3  COM_DBG_IF R: class DSP_CO_USER::OnTargetHaltDetected()
0x00001CD4 51267 3 Cortex_M4_0 POLL C: Firing of DSP_TARGET_HALT_DETECTED complete
0x00001CD4 51267 3 Cortex_M4_0 TPI C: TpiSvrStepAPI( *0000000000000000, TPI_STEP_CMD_GET_REVISION, *0000000DAD8FDAB0 )
0x00001CD4 51267 3 Cortex_M4_0 TPI R: TpiSvrStepAPI( *0000000000000000, TPI_STEP_CMD_GET_REVISION, *0000000DAD8FDAB0 = 0x00000064 ) = 0x00000000
0x00001CD4 51267 3 Cortex_M4_0 TPI C: TpiSvrStepAPI( *0000000000000000, TPI_STEP_CMD_CONSTRUCTOR, 0x0000000D75803800, 0x0000000000000001, 0x000001BD3D1FEEE0, 0x00007FFEC49C3380, 0x000001BD36C176A8 )
0x00001CD4 51267 3 Cortex_M4_0 TPI R: TpiSvrStepAPI( *0000000000000000, TPI_STEP_CMD_CONSTRUCTOR, 0x0000000D75803800, 0x0000000000000001, 0x000001BD3D1FEEE0, 0x00007FFEC49C3380, 0x000001BD36C176A8 ) = 0x00000000
0x00001CD4 51267 3 Cortex_M4_0 TPI C: TpiSvrStepAPI( *000001BD35C8FC40, TPI_STEP_CMD_GET_CACHE_SIZE, *0000000DAD8FD8E0 )
0x00001CD4 51267 3 Cortex_M4_0 TPI R: TpiSvrStepAPI( *000001BD35C8FC40, TPI_STEP_CMD_GET_CACHE_SIZE, *0000000DAD8FD8E0 = 0x00000010 ) = 0x00000000
0x00001CD4 51267 3 Cortex_M4_0 TPI C: TpiSvrStepAPI( *000001BD35C8FC40, TPI_STEP_CMD_GET_STATUS_REG, 0x0000000DAD8FD938, *0000000DAD8FDAB8, *0000000DAD8FDAA8, *0000000DAD8FDAA0 )
0x00001CD4 51267 3 Cortex_M4_0 TPI R: TpiSvrStepAPI( *000001BD35C8FC40, TPI_STEP_CMD_GET_STATUS_REG, 0x0000000DAD8FD938, *0000000DAD8FDAB8 = 0x0000000000000000, *0000000DAD8FDAA8 = 0x00000001, *0000000DAD8FDAA0 = 0x00000079 ) = 0x00000000
0x00001CD4 51267 3 Cortex_M4_0 STATE I: Debugger execution state changed to EVENT_DSP_HALT
0x00001CD4 51267 3 Cortex_M4_0 GEL I: Evaluating "OnHalt()"
0x00001CD4 51267 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 51267 3 Cortex_M4_0 POLL C: Firing DSP_BKPT_EVENT to all DSP_USER's
0x00001CD4 51267 3 Cortex_M4_0 TA C: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::eHalted )
0x00001CD4 51267 3 Cortex_M4_0 TA R: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::eHalted )
0x00001CD4 51267 3  COM_DBG_IF C: class DSP_CO_USER::OnHalt()
0x00001CD4 51267 3  XPCOM C: ( (dsIObjectEventCallback*)000001BD29E5BE50 )->onEvent( 000001BD29C7F250 )
0x00001CD4 51267 3  XPCOM R: ( (dsIObjectEventCallback*)000001BD29E5BE50 )->onEvent( 000001BD29C7F250 ) = 0x00000000
0x00001CD4 51267 3  COM_DBG_IF R: class DSP_CO_USER::OnHalt()
0x00001CD4 51267 3  COM_DBG_IF C: class DSP_CO_USER::OnAllowedUserAccessesChanged()
0x00001CD4 51267 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD29E60F50 )->onEvent()
0x00001CD4 51283 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD29E60F50 )->onEvent() = 0x00000000
0x00001CD4 51283 3  COM_DBG_IF R: class DSP_CO_USER::OnAllowedUserAccessesChanged()
0x00001CD4 51283 3  COM_DBG_IF C: class DSP_CO_USER::OnExecutionStatusChanged()
0x00001CD4 51283 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD29E60050 )->onEvent()
0x00001CD4 51283 3  XPCOM C: ( (dsIRunControl*)000001BD29180E10 )->getExecutionState( 0000000DAD8FC080, 0000000DAD8FC098, 0000000DAD8FC0B0, 0000000DAD8FC0C8 )
0x00001CD4 51283 3  XPCOM R: ( (dsIRunControl*)000001BD29180E10 )->getExecutionState( *0000000DAD8FC080 = true, *0000000DAD8FC098 = false, *0000000DAD8FC0B0 = 0x00000000, *0000000DAD8FC0C8 = 0x00000000 ) = 0x00000000
0x00001CD4 51284 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD29E60050 )->onEvent() = 0x00000000
0x00001CD4 51284 3  COM_DBG_IF R: class DSP_CO_USER::OnExecutionStatusChanged()
0x00001CD4 51284 3 Cortex_M4_0 POLL C: Firing of DSP_BKPT_EVENT complete
0x00001CD4 51284 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 51284 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 51284 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 108 ms
0x00001CD4 51284 4  POLL I: TimeToSleep() found shorter sleep time of 108 ms from class DevicePollFrequencyManager
0x00001CD4 51284 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 172 ms
0x00001CD4 51284 4 Cortex_M4_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 51284 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 51284 4  POLL I: Yielding to other threads
0x00001CD4 51284 3 Cortex_M4_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 51284 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372035227381758 AND Register_Cache.Address<=-9223372035227381758 AND Register_Cache.Page=121 AND Register_Cache.Processor=35
0x00001CD4 51284 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 91 ms
0x00001CD4 51284 4  POLL I: TimeToSleep() found shorter sleep time of 91 ms from class DevicePollFrequencyManager
0x00001CD4 51284 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 155 ms
0x00001CD4 51284 3 Cortex_M4_0 POLL C: Polling with state STATE_READ and status EVENT_DSP_HALT
0x00001CD4 51284 3 Cortex_M4_0 GTI C: GTI_READREG( 0x000001BD362E2770, 0x61001002, *0x0000000DAD8FDD10 = 0x00000000 )
0x00001CD4 51284 3  CMAPI C: Acquire( 000001BD35050D30 )
0x00001CD4 51284 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 51284 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51284 3  CMAPI R: Acquire( 000001BD35050D30 ) = 0
0x00001CD4 51284 3  CMAPI C: Release( 000001BD35050D30 )
0x00001CD4 51284 3  CMAPI R: Release( 000001BD35050D30 ) = 0
0x00001CD4 51284 3 Cortex_M4_0 GTI R: GTI_READREG( 0x000001BD362E2770, 0x61001002, *0x0000000DAD8FDD10 = 0x00000000 ) = 0x00000000
0x00001CD4 51284 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD608 = 0x00000000, *0x0000000DAD8FD600 = 0x00000000, *0x0000000DAD8FD618 = 0x00000000, *0x0000000DAD8FD630 = 0x00000000, *0x0000000DAD8FD638 = 0x00000000, *0x0000000DAD8FD628 = 0x00000000, *0x0000000DAD8FD620 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51284 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD608 = 0x00000000, *0x0000000DAD8FD600 = 0x00000000, *0x0000000DAD8FD618 = 0x00000000, *0x0000000DAD8FD630 = 0x00000002, *0x0000000DAD8FD638 = 0x00000000, *0x0000000DAD8FD628 = 0x00000008, *0x0000000DAD8FD620 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51284 3 Cortex_M4_0 POLL C: Firing DSP_MEM_EVENT to class `anonymous namespace'::TpiStatusRegistersImpl
0x00001CD4 51284 3 Cortex_M4_0 POLL C: Firing of DSP_MEM_EVENT complete
0x00001CD4 51284 3 Cortex_M4_0 POLL C: Firing DSP_TARGET_ACCESSED to all DSP_USER's
0x00001CD4 51284 3 Cortex_M4_0 POLL C: Firing of DSP_TARGET_ACCESSED complete
0x00001CD4 51284 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::TpiStatusRegistersImpl
0x00001CD4 51284 3 Cortex_M4_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 51284 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 51284 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:20	Enter function OnTargetConnect
0x00001CD4 51284 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 51284 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='OnHalt()' AND Register_Cache.Processor=35
0x00001CD4 51284 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=35 AND Name='OnHalt()'
0x00001CD4 51284 3 Cortex_M4_0 GEL I: Evaluation of "OnHalt()" failed: identifier not found: OnHalt()
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:23	   memorymap_init()
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:143	   Enter function memorymap_init
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:144	      GEL_MapOff()
0x00001CD4 51284 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class MemMapChangeBroadcaster
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:145	      GEL_MapReset()
0x00001CD4 51284 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class MemMapChangeBroadcaster
0x00001CD4 51284 3 Cortex_M4_0 POLL C: Firing DSP_MEM_MAP_UPDATED to all DSP_USER's
0x00001CD4 51284 3  COM_DBG_IF C: class DSP_CO_USER::OnMemoryMapUpdate()
0x00001CD4 51284 3  COM_DBG_IF R: class DSP_CO_USER::OnMemoryMapUpdate()
0x00001CD4 51284 3 Cortex_M4_0 POLL C: Firing of DSP_MEM_MAP_UPDATED complete
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:146	      GEL_MapOn()
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:79	      Enter function IsCC13x1CC26x1
0x00001CD4 51284 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='_deviceId' AND Register_Cache.Processor=35
0x00001CD4 51284 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=35 AND Name='_deviceId'
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:85	         result
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:85	      Leave function IsCC13x1CC26x1 lv = LValue with Location: GEL local
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:179	      GEL_MapAddStr(0x21000000, 0, 0x00001000, "R|W", 0)
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:180	      GEL_MapAddStr(0x21004000, 0, 0x00002000, "R|W", 0)
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:183	      GEL_MapAddStr(0x21008000, 0, 0x00000800, "R|W", 0)
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:184	      GEL_MapAddStr(0x2100C000, 0, 0x00000800, "R|W", 0)
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:185	      GEL_MapAddStr(0x40000000, 0, 0x000E1028, "R|W", 0)
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:186	      GEL_MapAddStr(0x40031000, 0, 0x00001000, "NONE", 0)
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:187	      GEL_MapAddStr(0x50001000, 0, 0x00000800, "R", 0)
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:188	      GEL_MapAddStr(0x50002000, 0, 0x00000800, "R", 0)
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:189	      GEL_MapAddStr(0x50003000, 0, 0x00002000, "R", 0)
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:190	      GEL_MapAddStr(0xE0000000, 0, 0x00003000, "R|W", 0)
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:191	      GEL_MapAddStr(0xE000E000, 0, 0x00001000, "R|W", 0)
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:192	      GEL_MapAddStr(0xE0040000, 0, 0x00001000, "R|W", 0)
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:193	      GEL_MapAddStr(0xE00FE000, 0, 0x00001000, "R|W", 0)
0x00001CD4 51284 2 Cortex_M4_0 GEL I: cc26x2.gel:198	      _deviceId=*((unsigned int) 0x50001318)
0x00001CD4 51284 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_READ_MEM added to polling loop by class VOT::DspAccessorGet
0x00001CD4 51284 3 Cortex_M4_0 GTI C: GTI_READMEM_WITH_STAT( 0x000001BD362E2770, 0x50001318, 0x00000000, 0x00000004, 0x00000001, "R", 0x00000000, 0x00000000, *0x000001BD3D178744 = 0x00007FFE, 0xFFFFFFFF, *0x000001BD3D198744 = { 0, 0x00000000 } )
0x00001CD4 51284 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0x50001318, 4, 000001BD3D178744, *0000000DAD8FD610 = { 4, 1, 0 } )
0x00001CD4 51284 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51300 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000000, *value = 0x63000052 ) = 0
0x00001CD4 51300 3  XDS110 I: Depth1: DpRegWrite( address = 0x00000008, *value = 0x00000000 ) = 0
0x00001CD4 51300 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0x50001318 ) = 0
0x00001CD4 51300 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x40000000 = 0
0x00001CD4 51300 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x3bb4102f = 0
0x00001CD4 51300 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51300 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51300 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0x50001318, 4, *000001BD3D178744 = [2F 10 B4 3B ...], 0000000DAD8FD610 ) = 0
0x00001CD4 51300 3  CMAPI C: Release( 000001BD35050D30 )
0x00001CD4 51300 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 51300 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51300 3  CMAPI R: Release( 000001BD35050D30 ) = 0
0x00001CD4 51300 3 Cortex_M4_0 GTI R: GTI_READMEM_WITH_STAT( 0x000001BD362E2770, 0x50001318, 0x00000000, 0x00000004, 0x00000001, "R", 0x00000000, 0x00000000, *0x000001BD3D178744 = 0x0000002F, 0xFFFFFFFF, *0x000001BD3D198744 = { 0, 0x00000000 } ) = 0x00000000
0x00001CD4 51300 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD538 = 0x00000000, *0x0000000DAD8FD530 = 0x00000000, *0x0000000DAD8FD548 = 0x00000000, *0x0000000DAD8FD560 = 0x00000000, *0x0000000DAD8FD568 = 0x00000000, *0x0000000DAD8FD558 = 0x00000000, *0x0000000DAD8FD550 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51300 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD538 = 0x00000000, *0x0000000DAD8FD530 = 0x00000000, *0x0000000DAD8FD548 = 0x00000000, *0x0000000DAD8FD560 = 0x00000002, *0x0000000DAD8FD568 = 0x00000000, *0x0000000DAD8FD558 = 0x00000008, *0x0000000DAD8FD550 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51300 3 Cortex_M4_0 POLL C: Firing DSP_TARGET_ACCESSED to all DSP_USER's
0x00001CD4 51300 3 Cortex_M4_0 POLL C: Firing of DSP_TARGET_ACCESSED complete
0x00001CD4 51300 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class VOT::DspAccessorGet
0x00001CD4 51300 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 51300 3 Cortex_M4_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 51300 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 51300 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 51300 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 91 ms
0x00001CD4 51300 4  POLL I: TimeToSleep() found shorter sleep time of 91 ms from class DevicePollFrequencyManager
0x00001CD4 51300 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 155 ms
0x00001CD4 51300 4 Cortex_M4_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 51300 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 51300 4  POLL I: Yielding to other threads
0x00001CD4 51300 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 51300 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 51300 2 Cortex_M4_0 GEL I: cc26x2.gel:68	      Enter function IsCC13x2CC26x2x7
0x00001CD4 51300 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 75 ms
0x00001CD4 51300 4  POLL I: TimeToSleep() found shorter sleep time of 75 ms from class DevicePollFrequencyManager
0x00001CD4 51300 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 139 ms
0x00001CD4 51300 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=35 AND Name='_deviceId'
0x00001CD4 51300 2 Cortex_M4_0 GEL I: cc26x2.gel:74	         result
0x00001CD4 51300 2 Cortex_M4_0 GEL I: cc26x2.gel:74	      Leave function IsCC13x2CC26x2x7 lv = LValue with Location: GEL local
0x00001CD4 51300 2 Cortex_M4_0 GEL I: cc26x2.gel:207	      GEL_MapAddStr(0x00000000, 0, 0x00058000, "R", 0)
0x00001CD4 51300 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class MemMapChangeBroadcaster
0x00001CD4 51300 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class MemMapChangeBroadcaster
0x00001CD4 51300 2 Cortex_M4_0 GEL I: cc26x2.gel:79	      Enter function IsCC13x1CC26x1
0x00001CD4 51300 3 Cortex_M4_0 POLL C: Firing DSP_MEM_MAP_UPDATED to all DSP_USER's
0x00001CD4 51300 3  COM_DBG_IF C: class DSP_CO_USER::OnMemoryMapUpdate()
0x00001CD4 51300 3  COM_DBG_IF R: class DSP_CO_USER::OnMemoryMapUpdate()
0x00001CD4 51300 3 Cortex_M4_0 POLL C: Firing of DSP_MEM_MAP_UPDATED complete
0x00001CD4 51300 2 Cortex_M4_0 GEL I: cc26x2.gel:85	         result
0x00001CD4 51300 2 Cortex_M4_0 GEL I: cc26x2.gel:85	      Leave function IsCC13x1CC26x1 lv = LValue with Location: GEL local
0x00001CD4 51300 2 Cortex_M4_0 GEL I: cc26x2.gel:216	      GEL_MapAddStr(0x10000000, 0, 0x00040000, "R", 0)
0x00001CD4 51300 2 Cortex_M4_0 GEL I: cc26x2.gel:219	      GEL_MapAddStr(0x11000000, 0, 0x00002000, "R|W", 0)
0x00001CD4 51300 2 Cortex_M4_0 GEL I: cc26x2.gel:231	      GEL_MapAddStr(0x20000000, 0, 0x00014000, "R|W", 0)
0x00001CD4 51300 2 Cortex_M4_0 GEL I: cc26x2.gel:234	      GEL_TextOut("Memory Map Initialization Complete.\n")
0x00001CD4 51300 3  COM_DBG_IF C: class dsDebugger::OnInfo()
0x00001CD4 51300 3  XPCOM C: ( (dsIStringEventCallback*)000001BD358D8730 )->onEvent( Cortex_M4_0: GEL Output: Memory Map Initialization Complete.
0x00001CD4 51300 3  XPCOM R: ( (dsIStringEventCallback*)000001BD358D8730 )->onEvent( Cortex_M4_0: GEL Output: Memory Map Initialization Complete.
 ) = 0x00000000
0x00001CD4 51300 3  COM_DBG_IF R: class dsDebugger::OnInfo()
0x00001CD4 51300 3 Cortex_M4_0 POLL C: Firing DSP_TASK_ERROR_MESSAGE_INFO to all DSP_USER's
0x00001CD4 51300 3  COM_DBG_IF C: class DSP_CO_USER::OnInfo()
0x00001CD4 51300 3  XPCOM C: ( (dsIStringEventCallback*)000001BD29E603D0 )->onEvent( Cortex_M4_0: GEL Output: Memory Map Initialization Complete.
0x00001CD4 51300 3  XPCOM R: ( (dsIStringEventCallback*)000001BD29E603D0 )->onEvent( Cortex_M4_0: GEL Output: Memory Map Initialization Complete.
 ) = 0x00000000
0x00001CD4 51300 3  COM_DBG_IF R: class DSP_CO_USER::OnInfo()
0x00001CD4 51300 3 Cortex_M4_0 POLL C: Firing of DSP_TASK_ERROR_MESSAGE_INFO complete
0x00001CD4 51300 2 Cortex_M4_0 GEL I: cc26x2.gel:234	   Leave function memorymap_init
0x00001CD4 51300 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:26	   CompleteTrimOnEngrDevice()
0x00001CD4 51300 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:118	   Enter function CompleteTrimOnEngrDevice
0x00001CD4 51300 3  SETUP I: SELECT count(*) FROM Bitfields WHERE parent_dbid=2148
0x00001CD4 51300 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_READ_MEM added to polling loop by class VOT::DspAccessorGetRegister
0x00001CD4 51300 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775281 AND Register_Cache.Address<=-9223372036854775281 AND Register_Cache.Page=121 AND Register_Cache.Processor=35
0x00001CD4 51300 3 Cortex_M4_0 POLL C: Polling with state STATE_READ and status EVENT_DSP_HALT
0x00001CD4 51300 3 Cortex_M4_0 GTI C: GTI_READREG( 0x000001BD362E2770, 0x0000020F, *0x0000000DAD8FDD10 = 0xAD8FE270 )
0x00001CD4 51300 3  CMAPI C: Acquire( 000001BD35050D30 )
0x00001CD4 51311 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51311 3  CMAPI R: Acquire( 000001BD35050D30 ) = 0
0x00001CD4 51311 3  CMAPI C: Release( 000001BD35050D30 )
0x00001CD4 51311 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 51313 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51313 3  CMAPI R: Release( 000001BD35050D30 ) = 0
0x00001CD4 51313 3 Cortex_M4_0 GTI R: GTI_READREG( 0x000001BD362E2770, 0x0000020F, *0x0000000DAD8FDD10 = 0x1000118E ) = 0x00000000
0x00001CD4 51313 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD608 = 0x00000000, *0x0000000DAD8FD600 = 0x00000000, *0x0000000DAD8FD618 = 0x00000000, *0x0000000DAD8FD630 = 0x00000000, *0x0000000DAD8FD638 = 0x00000000, *0x0000000DAD8FD628 = 0x00000000, *0x0000000DAD8FD620 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51313 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD608 = 0x00000000, *0x0000000DAD8FD600 = 0x00000000, *0x0000000DAD8FD618 = 0x00000000, *0x0000000DAD8FD630 = 0x00000002, *0x0000000DAD8FD638 = 0x00000000, *0x0000000DAD8FD628 = 0x00000008, *0x0000000DAD8FD620 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51313 3 Cortex_M4_0 POLL C: Firing DSP_TARGET_ACCESSED to all DSP_USER's
0x00001CD4 51313 3 Cortex_M4_0 POLL C: Firing of DSP_TARGET_ACCESSED complete
0x00001CD4 51313 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class VOT::DspAccessorGetRegister
0x00001CD4 51313 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 51313 3 Cortex_M4_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 51313 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 51313 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 51313 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 75 ms
0x00001CD4 51313 4  POLL I: TimeToSleep() found shorter sleep time of 75 ms from class DevicePollFrequencyManager
0x00001CD4 51313 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 139 ms
0x00001CD4 51313 4 Cortex_M4_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 51313 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 51313 4  POLL I: Yielding to other threads
0x00001CD4 51313 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 51313 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 51313 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 62 ms
0x00001CD4 51313 4  POLL I: TimeToSleep() found shorter sleep time of 62 ms from class DevicePollFrequencyManager
0x00001CD4 51313 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 126 ms
0x00001CD4 51313 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:143	   Leave function CompleteTrimOnEngrDevice
0x00001CD4 51313 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:28	   DefineResets(1)
0x00001CD4 51313 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:164	   Enter function DefineResets
0x00001CD4 51313 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=35 AND Name='_BoardResetMenuDefined'
0x00001CD4 51313 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:169	      DEBUG_RemoveResets(4)
0x00001CD4 51313 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:172	      DEBUG_DefineReset("Board Reset (automatic connect/disconnect)", "The same as a board reset, but debugger returns to the original connection state (connected or disconnected)", 0, "BoardReset_Automatic()")
0x00001CD4 51313 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:175	      DEBUG_DefineReset("Reset Emulator", "", 8, "EmulatorReset()")
0x00001CD4 51313 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:180	      _BoardResetMenuDefined=1
0x00001CD4 51313 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:180	   Leave function DefineResets
0x00001CD4 51313 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:28	Leave function OnTargetConnect
0x00001CD4 51313 3 Cortex_M4_0 GEL I: Evaluation of "OnTargetConnect()" completed - Value: 0 Location: unknown
0x00001CD4 51313 3  SEQUENCE I: Finished sequence step at 000001BD29530630
0x00001CD4 51313 3  SEQUENCE I: Beginning class Debugger::LambdaSequenceStep<class <lambda_20ba4389354718687b046855860a9400> > at 000001BD3D1FE2C0
0x00001CD4 51313 3  PERF I: GEL OnTargetConnect() finished:  0.053431s wall, 0.015625s user + 0.015625s system = 0.031250s CPU (58.5%)
0x00001CD4 51313 3  SEQUENCE I: Finished sequence step at 000001BD3D1FE2C0
0x00001CD4 51313 3  SEQUENCE I: Beginning class `anonymous namespace'::WaitForValidState at 000001BD35C90480
0x00001CD4 51313 3  SEQUENCE I: Finished sequence step at 000001BD35C90480
0x00001CD4 51313 3  SEQUENCE I: Beginning class `anonymous namespace'::CallGelResetStep at 000001BD3DC6E0E0
0x00001CD4 51313 3  SEQUENCE I: Finished sequence step at 000001BD3DC6E0E0
0x00001CD4 51313 3  SEQUENCE I: Beginning class Debugger::InitializeFlashMgrStep at 000001BD3D1FE340
0x00001CD4 51313 3 Cortex_M4_0 FLASH I: Enqueuing a call to FlashOperations::Initialize() on a side thread
0x00001CD4 51313 4 Cortex_M4_0 POLL I: TimeToPollAgain() target is idle and needs polling in 5000 ms
0x000011E8 51313 3 Cortex_M4_0 FLASH I: FlashOperations::Constructor
0x000011E8 51313 3 Cortex_M4_0 FLASH C: FlashOperations::Initialize()
0x000011E8 51313 3 Cortex_M4_0 FLASH I: FlashOperations::Initialize(), isSimulator = false
0x000011E8 51313 3 Cortex_M4_0 FLASH I: FlashOperations::Initialize(), targetType = TMS470REX
0x000011E8 51313 3 Cortex_M4_0 FLASH I: FlashOperations::Initialize(), fullpath = Texas Instruments XDS110 USB Debug Probe/Cortex_M4_0
0x000011E8 51313 3 Cortex_M4_0 FLASH I: FlashOperations::Initialize(), targetVariant = CC2642R1F
0x000011E8 51313 3 Cortex_M4_0 FLASH C: FlashOperations::MatchFlashDLL( JTAG, TMS470REX, CC2642R1F, C:\ti\ccs1200\ccs\ccs_base\DebugServer\bin\ )
0x000011E8 51313 3 Cortex_M4_0 FLASH R: FlashOperations::MatchFlashDLL() = true, DLL name = FlashCC26x2, m_bNeedsFlashProperties = true, m_bNeedsFlashUtility = true, m_iBackupType = 0
0x000011E8 51313 3 Cortex_M4_0 FLASH I: FlashOperations::Initialize(), DLL path: C:\ti\ccs1200\ccs\ccs_base\DebugServer\bin\FlashCC26x2.dll
0x000011E8 51313 3  LIB C: dlopen( "C:\ti\ccs1200\ccs\ccs_base\DebugServer\bin\FlashCC26x2.dll", 0 )
0x000011E8 51313 3  LIB R: dlopen( "C:\ti\ccs1200\ccs\ccs_base\DebugServer\bin\FlashCC26x2.dll", 0 ) = 00007FFEDCC90000
0x000011E8 51313 3 Cortex_M4_0 FLASH I: FlashOperations::Initialize(), DLL Load Successful
0x000011E8 51313 3 Cortex_M4_0 FLASH I: FlashOperations::Initialize(), Utility object was created.
0x000011E8 51313 3  LIB C: dlsym( 00007FFEDCC90000, "CreateFlashDevice" )
0x000011E8 51313 3  LIB R: dlsym( 00007FFEDCC90000, "CreateFlashDevice" ) = 0000000000000000
0x000011E8 51313 3  LIB C: dlsym( 00007FFEDCC90000, "CreateFlashDevice2" )
0x000011E8 51313 3  LIB R: dlsym( 00007FFEDCC90000, "CreateFlashDevice2" ) = 00007FFEDCC91FA0
0x000011E8 51313 3  LIB C: dlsym( 00007FFEDCC90000, "CreateFlashDevice3" )
0x000011E8 51313 3  LIB R: dlsym( 00007FFEDCC90000, "CreateFlashDevice3" ) = 0000000000000000
0x000011E8 51313 3  LIB C: dlsym( 00007FFEDCC90000, "CreateFlashDevice4" )
0x000011E8 51313 3  LIB R: dlsym( 00007FFEDCC90000, "CreateFlashDevice4" ) = 0000000000000000
0x000011E8 51313 3 Cortex_M4_0 FLASH I: FlashOperations::Initialize(), Entry point found
0x000011E8 51313 3 Cortex_M4_0 FLASH I: IFlashDevice::FlashDevice() m_pImpl_2 => 000001BD35CA45C0 m_pImpl_3 => 0000000000000000
0x000011E8 51313 3 Cortex_M4_0 FLASH I: FlashOperations::Initialize(), Flash Device interface created successfully.
0x000011E8 51313 5  COM_DBG_IF I: Final Release for class DbgProperties::Properties (this = 000001BD308AD468)
0x000011E8 51313 5  COM_DBG_IF I: Final Release for class DbgProperties::Properties (this = 000001BD308AC338)
0x000011E8 51313 5  COM_DBG_IF I: Final Release for class DbgProperties::Properties (this = 000001BD308AD008)
0x000011E8 51313 5  COM_DBG_IF I: Final Release for class DbgProperties::Properties (this = 000001BD308AE6D8)
0x000011E8 51313 5  COM_DBG_IF I: Final Release for class DbgProperties::Properties (this = 000001BD308ADD28)
0x000011E8 51313 5  COM_DBG_IF I: Final Release for class DbgProperties::Properties (this = 000001BD308AD968)
0x000011E8 51313 5  COM_DBG_IF I: Final Release for class DbgProperties::Properties (this = 000001BD308ADAF8)
0x000011E8 51313 5  COM_DBG_IF I: Final Release for class DbgProperties::Properties (this = 000001BD308ADDC8)
0x000011E8 51313 5  COM_DBG_IF I: Final Release for class DbgProperties::Properties (this = 000001BD308AD648)
0x000011E8 51313 3 Cortex_M4_0 FLASH C: IFlashDevice::Initialize()
0x000011E8 51313 3 Cortex_M4_0 FLASH C: FlashProgrammerUtility::GetValueOfProperty( FlashVerboseMode )
0x000011E8 51313 3 Cortex_M4_0 FLASH R: FlashProgrammerUtility::GetValueOfProperty( FlashVerboseMode ) = 1
0x000011E8 51313 3 Cortex_M4_0 FLASH C: FlashProgrammerUtility::ReportInfo( Flashloader: Verbose output enabled. )
0x000011E8 51313 3  COM_DBG_IF C: class dsDebugger::OnInfo()
0x000011E8 51313 3  XPCOM C: ( (dsIStringEventCallback*)000001BD358D8730 )->onEvent( Cortex_M4_0: Flashloader: Verbose output enabled.
0x000011E8 51313 3  XPCOM R: ( (dsIStringEventCallback*)000001BD358D8730 )->onEvent( Cortex_M4_0: Flashloader: Verbose output enabled.
 ) = 0x00000000
0x000011E8 51313 3  COM_DBG_IF R: class dsDebugger::OnInfo()
0x000011E8 51313 3 Cortex_M4_0 POLL C: Firing DSP_TASK_ERROR_MESSAGE_INFO to all DSP_USER's
0x000011E8 51313 3  COM_DBG_IF C: class DSP_CO_USER::OnInfo()
0x000011E8 51313 3  XPCOM C: ( (dsIStringEventCallback*)000001BD29E603D0 )->onEvent( Cortex_M4_0: Flashloader: Verbose output enabled.
0x000011E8 51313 3  XPCOM R: ( (dsIStringEventCallback*)000001BD29E603D0 )->onEvent( Cortex_M4_0: Flashloader: Verbose output enabled.
 ) = 0x00000000
0x000011E8 51313 3  COM_DBG_IF R: class DSP_CO_USER::OnInfo()
0x000011E8 51313 3 Cortex_M4_0 POLL C: Firing of DSP_TASK_ERROR_MESSAGE_INFO complete
0x000011E8 51313 3 Cortex_M4_0 FLASH R: FlashProgrammerUtility::ReportInfo( Flashloader: Verbose output enabled. ) = (null)
0x000011E8 51313 3 Cortex_M4_0 FLASH C: FlashProgrammerUtility::SetCore( IcePick )
0x000011E8 51313 3 Cortex_M4_0 FLASH R: FlashProgrammerUtility::SetCore( IcePick ) = (null)
0x000011E8 51313 3 Cortex_M4_0 FLASH C: FlashProgrammerUtility::ReadRegister( 1, ??? )
0x000011E8 51319 3 IcePick_C POLL D: New request of type DSP_RQ_READ_MEM added to polling loop by class DSTargetAccess
0x00001CD4 51319 3 IcePick_C POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 51319 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775807 AND Register_Cache.Address<=-9223372036854775807 AND Register_Cache.Page=121 AND Register_Cache.Processor=33
0x00001CD4 51319 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 51319 3 IcePick_C POLL R: Poll() returning
0x00001CD4 51319 4 IcePick_C POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 51319 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 51319 4  POLL I: Yielding to other threads
0x00001CD4 51319 3 IcePick_C POLL C: Polling with state STATE_READ and status EVENT_DSP_HALT
0x00001CD4 51319 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000001, *0x0000000DAD8FDD10 = 0x00000000 )
0x00001CD4 51319 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 51319 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51319 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000001, *0x0000000DAD8FDD10 = 0x3BB4102F ) = 0x00000000
0x00001CD4 51319 3  SETUP I: SELECT * FROM Module_Instances WHERE dbid=583
0x00001CD4 51319 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD608 = 0x00000000, *0x0000000DAD8FD600 = 0x00000000, *0x0000000DAD8FD618 = 0x00000000, *0x0000000DAD8FD630 = 0x00000000, *0x0000000DAD8FD638 = 0x00000000, *0x0000000DAD8FD628 = 0x00000000, *0x0000000DAD8FD620 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51319 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD608 = 0x00000000, *0x0000000DAD8FD600 = 0x00000000, *0x0000000DAD8FD618 = 0x00000000, *0x0000000DAD8FD630 = 0x00000002, *0x0000000DAD8FD638 = 0x00000000, *0x0000000DAD8FD628 = 0x00000008, *0x0000000DAD8FD620 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51319 3 IcePick_C POLL C: Firing DSP_MEM_EVENT to all DSP_USER's
0x00001CD4 51319 3 IcePick_C POLL C: Firing of DSP_MEM_EVENT complete
0x00001CD4 51319 3 IcePick_C POLL C: Firing DSP_TARGET_ACCESSED to all DSP_USER's
0x00001CD4 51319 3 IcePick_C POLL C: Firing of DSP_TARGET_ACCESSED complete
0x00001CD4 51319 3 IcePick_C POLL C: Firing DSP_REQ_EVENT to class DSTargetAccess
0x00001CD4 51319 3 IcePick_C POLL C: Firing of DSP_REQ_EVENT complete
0x000011E8 51319 3 Cortex_M4_0 FLASH R: FlashProgrammerUtility::ReadRegister( 1, 1001656367 ) = (null)
0x000011E8 51319 3 Cortex_M4_0 FLASH C: FlashProgrammerUtility::SetCore( Cortex )
0x00001CD4 51319 3 IcePick_C POLL C: Polling with state STATE_IDLE_STATUS_CHECK and status EVENT_DSP_HALT
0x00001CD4 51319 3 IcePick_C GTI C: GTI_STAT( 0x000001BD29E173E0 )
0x00001CD4 51319 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 51319 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 51319 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51319 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 51335 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 51335 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51335 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 51335 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 51350 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 51350 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51351 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 51351 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51352 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 51352 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 51352 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 51352 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51368 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 51368 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51368 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 51368 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 51384 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 51384 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51384 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 51384 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 51399 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 51399 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 51399 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 51399 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51415 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 51415 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51415 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 51415 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 51431 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 51431 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 51431 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 51431 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51431 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 51431 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51431 3 IcePick_C GTI R: GTI_STAT( 0x000001BD29E173E0 ) = 0x0000000E
0x00001CD4 51431 3 IcePick_C STATE I: Target execution state changed to STATUS_NON_DEBUG_CHANGE
0x00001CD4 51431 3 IcePick_C STATE I: Debugger execution state changed to EVENT_DSP_HALT
0x00001CD4 51431 3 IcePick_C POLL C: Firing DSP_NON_DEBUG_CHANGE to all DSP_USER's
0x00001CD4 51431 3  COM_DBG_IF C: class DSP_CO_USER::OnRefresh()
0x00001CD4 51431 3  XPCOM C: ( (dsINumberEventCallback*)000001BD29E60350 )->onEvent( 0x0000000000000008 )
0x00001CD4 51431 3  XPCOM R: ( (dsINumberEventCallback*)000001BD29E60350 )->onEvent( 0x0000000000000008 ) = 0x00000000
0x00001CD4 51431 3  COM_DBG_IF R: class DSP_CO_USER::OnRefresh()
0x00001CD4 51431 3 IcePick_C POLL C: Firing of DSP_NON_DEBUG_CHANGE complete
0x00001CD4 51431 4 IcePick_C POLL I: Yielding to other threads
0x000011E8 51431 3 Cortex_M4_0 FLASH R: FlashProgrammerUtility::SetCore( Cortex ) = (null)
0x00001CD4 51431 3 IcePick_C POLL R: Poll() returning
0x000011E8 51431 3 Cortex_M4_0 FLASH C: FlashProgrammerUtility::GetValueOfProperty( DeviceInfoRevisionTranslation )
0x00001CD4 51431 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 51431 4  POLL I: TimeToSleep() found shorter sleep time of 500 ms from class DevicePollFrequencyManager
0x00001CD4 51431 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 120 ms
0x00001CD4 51431 4  POLL I: TimeToSleep() found shorter sleep time of 120 ms from class DevicePollFrequencyManager
0x00001CD4 51431 4 Cortex_M4_0 POLL I: TimeToPollAgain() target is idle and needs polling in 4994 ms
0x000011E8 51431 3 Cortex_M4_0 FLASH R: FlashProgrammerUtility::GetValueOfProperty( DeviceInfoRevisionTranslation ) = 0:1.0:A:1:1.01:B:2:1.1:C:3:2.1:E
0x000011E8 51431 3 Cortex_M4_0 FLASH C: FlashProgrammerUtility::ReadMemory( 000001BD35CA462C, 1, 0x000000004003002C, 1, 4 )
0x000011E8 51431 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_READ_MEM added to polling loop by class DSTargetAccess
0x00001CD4 51431 3 Cortex_M4_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 51431 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 51431 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 51431 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 388 ms
0x00001CD4 51431 4  POLL I: TimeToSleep() found shorter sleep time of 388 ms from class DevicePollFrequencyManager
0x00001CD4 51431 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 8 ms
0x00001CD4 51431 4  POLL I: TimeToSleep() found shorter sleep time of 8 ms from class DevicePollFrequencyManager
0x00001CD4 51431 4 Cortex_M4_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 51431 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 51431 4  POLL I: Yielding to other threads
0x00001CD4 51431 3 Cortex_M4_0 POLL C: Polling with state STATE_READ and status EVENT_DSP_HALT
0x00001CD4 51431 3 Cortex_M4_0 GTI C: GTI_READMEM_WITH_STAT( 0x000001BD362E2770, 0x4003002C, 0x00000000, 0x00000004, 0x00000003, "R|W", 0x00000000, 0x00000000, *0x000001BD3D178744 = 0x0000002F, 0xFFFFFFFF, *0x000001BD3D198744 = { 0, 0x00000000 } )
0x00001CD4 51431 3  CMAPI C: Acquire( 000001BD35050D30 )
0x00001CD4 51431 3  CMAPI R: Acquire( 000001BD35050D30 ) = 0
0x00001CD4 51431 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0x4003002C, 4, 000001BD3D178744, *0000000DAD8FD610 = { 4, 1, 0 } )
0x00001CD4 51431 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51431 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000000, *value = 0x63000052 ) = 0
0x00001CD4 51431 3  XDS110 I: Depth1: DpRegWrite( address = 0x00000008, *value = 0x00000000 ) = 0
0x00001CD4 51431 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0x4003002c ) = 0
0x00001CD4 51431 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x3bb4102f = 0
0x00001CD4 51431 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x0000002c = 0
0x00001CD4 51431 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51431 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51431 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0x4003002C, 4, *000001BD3D178744 = [2C 00 00 00 ...], 0000000DAD8FD610 ) = 0
0x00001CD4 51431 3  CMAPI C: Release( 000001BD35050D30 )
0x00001CD4 51431 3  CMAPI R: Release( 000001BD35050D30 ) = 0
0x00001CD4 51431 3 Cortex_M4_0 GTI R: GTI_READMEM_WITH_STAT( 0x000001BD362E2770, 0x4003002C, 0x00000000, 0x00000004, 0x00000003, "R|W", 0x00000000, 0x00000000, *0x000001BD3D178744 = 0x0000002C, 0xFFFFFFFF, *0x000001BD3D198744 = { 0, 0x00000000 } ) = 0x00000000
0x00001CD4 51431 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD538 = 0x00000000, *0x0000000DAD8FD530 = 0x00000000, *0x0000000DAD8FD548 = 0x00000000, *0x0000000DAD8FD560 = 0x00000000, *0x0000000DAD8FD568 = 0x00000000, *0x0000000DAD8FD558 = 0x00000000, *0x0000000DAD8FD550 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51431 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD538 = 0x00000000, *0x0000000DAD8FD530 = 0x00000000, *0x0000000DAD8FD548 = 0x00000000, *0x0000000DAD8FD560 = 0x00000002, *0x0000000DAD8FD568 = 0x00000000, *0x0000000DAD8FD558 = 0x00000008, *0x0000000DAD8FD550 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51431 3 Cortex_M4_0 POLL C: Firing DSP_MEM_EVENT to all DSP_USER's
0x00001CD4 51431 3 Cortex_M4_0 POLL C: Firing of DSP_MEM_EVENT complete
0x00001CD4 51431 3 Cortex_M4_0 POLL C: Firing DSP_TARGET_ACCESSED to all DSP_USER's
0x00001CD4 51431 3 Cortex_M4_0 POLL C: Firing of DSP_TARGET_ACCESSED complete
0x00001CD4 51431 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class DSTargetAccess
0x00001CD4 51431 3 Cortex_M4_0 POLL C: Firing of DSP_REQ_EVENT complete
0x000011E8 51431 3 Cortex_M4_0 FLASH R: FlashProgrammerUtility::ReadMemory( 000001BD35CA462C, 1, 0x000000004003002C, 1, 4 ) = (null)
0x000011E8 51431 3 Cortex_M4_0 FLASH C: FlashProgrammerUtility::ReadMemory( 0000000DAF4FF0E0, 1, 0x0000000040082250, 1, 4 )
0x00001CD4 51431 4 Cortex_M4_0 POLL I: TimeToPollAgain() target is idle and needs polling in 5000 ms
0x00001CD4 51431 3 Cortex_M4_0 GTI C: GTI_READMEM_WITH_STAT( 0x000001BD362E2770, 0x40082250, 0x00000000, 0x00000004, 0x00000003, "R|W", 0x00000000, 0x00000000, *0x000001BD3D178744 = 0x0000002C, 0xFFFFFFFF, *0x000001BD3D198744 = { 0, 0x00000000 } )
0x00001CD4 51431 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0x40082250, 4, 000001BD3D178744, *0000000DAD8FD610 = { 4, 1, 0 } )
0x00001CD4 51431 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0x40082250 ) = 0
0x00001CD4 51431 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x0000002c = 0
0x00001CD4 51431 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000003 = 0
0x00001CD4 51431 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0x40082250, 4, *000001BD3D178744 = [03 00 00 00 ...], 0000000DAD8FD610 ) = 0
0x00001CD4 51431 3 Cortex_M4_0 GTI R: GTI_READMEM_WITH_STAT( 0x000001BD362E2770, 0x40082250, 0x00000000, 0x00000004, 0x00000003, "R|W", 0x00000000, 0x00000000, *0x000001BD3D178744 = 0x00000003, 0xFFFFFFFF, *0x000001BD3D198744 = { 0, 0x00000000 } ) = 0x00000000
0x000011E8 51431 3 Cortex_M4_0 FLASH R: FlashProgrammerUtility::ReadMemory( 0000000DAF4FF0E0, 1, 0x0000000040082250, 1, 4 ) = (null)
0x000011E8 51431 3 Cortex_M4_0 FLASH C: FlashProgrammerUtility::SetValueOfProperty( DeviceInfoFlashSize, 352 KB (44 sectors) )
0x000011E8 51431 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnPropertyChanged()
0x000011E8 51431 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnPropertyChanged()
0x000011E8 51431 3  COM_DBG_IF C: class DbgProperties::DebugProperties::OnPropertyValueChanged()
0x000011E8 51431 3  COM_DBG_IF R: class DbgProperties::DebugProperties::OnPropertyValueChanged()
0x000011E8 51431 3 Cortex_M4_0 FLASH R: FlashProgrammerUtility::SetValueOfProperty( DeviceInfoFlashSize, 352 KB (44 sectors) ) = null
0x000011E8 51431 3 Cortex_M4_0 FLASH C: FlashProgrammerUtility::SetValueOfProperty( DeviceInfoRAMSize, 80 KB )
0x000011E8 51431 3 Cortex_M4_0 FLASH R: FlashProgrammerUtility::SetValueOfProperty( DeviceInfoRAMSize, 80 KB ) = null
0x000011E8 51431 3 Cortex_M4_0 FLASH C: FlashProgrammerUtility::SetValueOfProperty( DeviceInfoRevision, E (2.1) )
0x000011E8 51431 3 Cortex_M4_0 FLASH R: FlashProgrammerUtility::SetValueOfProperty( DeviceInfoRevision, E (2.1) ) = null
0x000011E8 51431 3 Cortex_M4_0 FLASH R: IFlashDevice::Initialize() = true, Erase, EraseSectors, ReadPriBle, ReadSecBle, WriteSecBle, ReadPriIeee, ReadSecIeee, WriteSecIeee, BlankCheck, (null)
0x000011E8 51431 3 Cortex_M4_0 FLASH R: FlashOperations::Initialize()
0x000011E8 51431 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 51431 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 51431 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 51431 3  SEQUENCE I: Finished sequence step at 0000000DAD8FD9C0
0x00001CD4 51431 3  SEQUENCE I: Beginning class Debugger::InitializeGelPlugInStep at 000001BD362FCF10
0x00001CD4 51431 3 Cortex_M4_0 FLASH C: FlashProgrammerManager::TargetSupported()
0x00001CD4 51431 3 Cortex_M4_0 FLASH R: FlashProgrammerManager::TargetSupported() = true
0x00001CD4 51431 3 Cortex_M4_0 FLASH I: Enqueuing a call to FlashOperations::GetGelFunctionNames() on a side thread
0x000011E8 51431 3 Cortex_M4_0 FLASH C: FlashOperations::GetGelFunctionNames()
0x000011E8 51431 3 Cortex_M4_0 FLASH R: FlashOperations::GetGelFunctionNames()
0x00001CD4 51431 3  SEQUENCE I: Finished sequence step at 000001BD362FCF10
0x00001CD4 51431 3  SEQUENCE I: Beginning class Debugger::LambdaSequenceStep<class std::function<void __cdecl(void)> > at 000001BD3D20CFF0
0x00001CD4 51431 3  SEQUENCE I: Finished sequence step at 000001BD3D1FE340
0x00001CD4 51431 3  SEQUENCE I: Beginning class Debugger::PriorityEventStep at 000001BD3D1FE080
0x00001CD4 51431 3  SEQUENCE I: Finished sequence step at 000001BD3D1FE080
0x00001CD4 51431 3  SEQUENCE I: Finished sequence step at 000001BD3D20CFF0
0x00001CD4 51431 3 Cortex_M4_0 POLL C: Firing DSP_CONNECTED to all DSP_USER's
0x00001CD4 51431 3 Cortex_M4_0 TA C: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::eConnected )
0x00001CD4 51431 3 Cortex_M4_0 TA R: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::eConnected )
0x00001CD4 51431 3  COM_DBG_IF C: class DSP_CO_USER::OnConnected()
0x00001CD4 51431 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD29E5F7D0 )->onEvent()
0x00001CD4 51431 3  XPCOM C: ( (dsIRegisterServer*)000001BD2EA1C670 )->findRegisterByName( MPU_CONTROL, 0000000DAD8FC5A8 )
0x00001CD4 51431 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='MPU_CONTROL' AND Register_Cache.Processor=35
0x00001CD4 51431 3  XPCOM R: ( (dsIRegisterServer*)000001BD2EA1C670 )->findRegisterByName( MPU_CONTROL, *0000000DAD8FC5A8 = 000001BD3D20D9B0 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20D9B0 )->getAddress( 0000000DAD8FC5B0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20D9B0 )->getAddress( *0000000DAD8FC5B0 = 0x0000000068000004 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterAccess*)000001BD29180DE8 )->createDspRegister( 0x0000000068000004, 0x00000001, 0000000DAD8FC5B0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterAccess*)000001BD29180DE8 )->createDspRegister( 0x0000000068000004, 0x00000001, *0000000DAD8FC5B0 = 000001BD2A3BC000 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterServer*)000001BD2EA1C670 )->findRegisterByName( MPU_CONTROL, 0000000DAD8FC5A8 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterServer*)000001BD2EA1C670 )->findRegisterByName( MPU_CONTROL, *0000000DAD8FC5A8 = 000001BD3D20D8F0 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIMemoryAccess*)000001BD29180DF8 )->createTargetData64( 0x0013, 0x0000000000000000, 0000000DAD8FC5A0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIMemoryAccess*)000001BD29180DF8 )->createTargetData64( 0x0013, 0x0000000000000000, *0000000DAD8FC5A0 = 000001BD2A3BCC40 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20D8F0 )->getBitLength( 0000000DAD8FC5A0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20D8F0 )->getBitLength( *0000000DAD8FC5A0 = 0x00000020 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20D8F0 )->getPage( 0000000DAD8FC5A0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20D8F0 )->getPage( *0000000DAD8FC5A0 = 0x00000079 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsITargetData*)000001BD2A3BCC40 )->bestMatchedUDataType( 0x00000020, 0x0079, 0000000DAD8FC5C0 )
0x00001CD4 51446 3  XPCOM R: ( (dsITargetData*)000001BD2A3BCC40 )->bestMatchedUDataType( 0x00000020, 0x0079, *0000000DAD8FC5C0 = 0x000B ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsITargetData*)000001BD2A3BCC40 )->typeCast( 0x000B, 0x00000000, 0000000DAD8FC5B0 )
0x00001CD4 51446 3  XPCOM R: ( (dsITargetData*)000001BD2A3BCC40 )->typeCast( 0x000B, 0x00000000, *0000000DAD8FC5B0 = 000001BD2A3BB440 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterServer*)000001BD2EA1C670 )->findRegisterByName( REG_VECTOR_CATCH, 0000000DAD8FC5A8 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterServer*)000001BD2EA1C670 )->findRegisterByName( REG_VECTOR_CATCH, *0000000DAD8FC5A8 = 000001BD3D20D470 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20D470 )->getAddress( 0000000DAD8FC5B0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20D470 )->getAddress( *0000000DAD8FC5B0 = 0x0000000060000007 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterAccess*)000001BD29180DE8 )->createDspRegister( 0x0000000060000007, 0x00000001, 0000000DAD8FC5B0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterAccess*)000001BD29180DE8 )->createDspRegister( 0x0000000060000007, 0x00000001, *0000000DAD8FC5B0 = 000001BD2A3BB280 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterServer*)000001BD2EA1C670 )->findRegisterByName( REG_VECTOR_CATCH, *0000000DAD8FC5A8 = 000001BD3D20CFF0 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIMemoryAccess*)000001BD29180DF8 )->createTargetData64( 0x0013, 0x0000000000000000, *0000000DAD8FC5A0 = 000001BD2A3BC640 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20CFF0 )->getBitLength( 0000000DAD8FC5A0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20CFF0 )->getBitLength( *0000000DAD8FC5A0 = 0x00000020 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20CFF0 )->getPage( 0000000DAD8FC5A0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20CFF0 )->getPage( *0000000DAD8FC5A0 = 0x00000079 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsITargetData*)000001BD2A3BC640 )->bestMatchedUDataType( 0x00000020, 0x0079, 0000000DAD8FC5C0 )
0x00001CD4 51446 3  XPCOM R: ( (dsITargetData*)000001BD2A3BC640 )->bestMatchedUDataType( 0x00000020, 0x0079, *0000000DAD8FC5C0 = 0x000B ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsITargetData*)000001BD2A3BC640 )->typeCast( 0x000B, 0x00000000, 0000000DAD8FC5B0 )
0x00001CD4 51446 3  XPCOM R: ( (dsITargetData*)000001BD2A3BC640 )->typeCast( 0x000B, 0x00000000, *0000000DAD8FC5B0 = 000001BD2A3BBBC0 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterServer*)000001BD2EA1C670 )->findRegisterByName( REG_VECTOR_CATCH, *0000000DAD8FC5A8 = 000001BD3D20DAD0 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20DAD0 )->getAddress( 0000000DAD8FC5B0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20DAD0 )->getAddress( *0000000DAD8FC5B0 = 0x0000000060000007 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterAccess*)000001BD29180DE8 )->createDspRegister( 0x0000000060000007, 0x00000001, *0000000DAD8FC5B0 = 000001BD2A3BC780 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterServer*)000001BD2EA1C670 )->findRegisterByName( REG_VECTOR_CATCH, *0000000DAD8FC5A8 = 000001BD3D20DFB0 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIMemoryAccess*)000001BD29180DF8 )->createTargetData64( 0x0013, 0x0000000000000000, *0000000DAD8FC5A0 = 000001BD2A3BB4C0 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20DFB0 )->getBitLength( 0000000DAD8FC5A0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20DFB0 )->getBitLength( *0000000DAD8FC5A0 = 0x00000020 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20DFB0 )->getPage( 0000000DAD8FC5A0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20DFB0 )->getPage( *0000000DAD8FC5A0 = 0x00000079 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsITargetData*)000001BD2A3BB4C0 )->bestMatchedUDataType( 0x00000020, 0x0079, 0000000DAD8FC5C0 )
0x00001CD4 51446 3  XPCOM R: ( (dsITargetData*)000001BD2A3BB4C0 )->bestMatchedUDataType( 0x00000020, 0x0079, *0000000DAD8FC5C0 = 0x000B ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsITargetData*)000001BD2A3BB4C0 )->typeCast( 0x000B, 0x00000000, 0000000DAD8FC5B0 )
0x00001CD4 51446 3  XPCOM R: ( (dsITargetData*)000001BD2A3BB4C0 )->typeCast( 0x000B, 0x00000000, *0000000DAD8FC5B0 = 000001BD2A3BC8C0 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterServer*)000001BD2EA1C670 )->findRegisterByName( REG_VECTOR_CATCH, *0000000DAD8FC5A8 = 000001BD3D20E010 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20E010 )->getAddress( 0000000DAD8FC5B0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20E010 )->getAddress( *0000000DAD8FC5B0 = 0x0000000060000007 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterAccess*)000001BD29180DE8 )->createDspRegister( 0x0000000060000007, 0x00000001, *0000000DAD8FC5B0 = 000001BD2A3BCC80 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterServer*)000001BD2EA1C670 )->findRegisterByName( REG_VECTOR_CATCH, *0000000DAD8FC5A8 = 000001BD3D20DCB0 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIMemoryAccess*)000001BD29180DF8 )->createTargetData64( 0x0013, 0x0000000000000000, *0000000DAD8FC5A0 = 000001BD2A3BCD40 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20DCB0 )->getBitLength( 0000000DAD8FC5A0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20DCB0 )->getBitLength( *0000000DAD8FC5A0 = 0x00000020 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20DCB0 )->getPage( 0000000DAD8FC5A0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20DCB0 )->getPage( *0000000DAD8FC5A0 = 0x00000079 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsITargetData*)000001BD2A3BCD40 )->bestMatchedUDataType( 0x00000020, 0x0079, 0000000DAD8FC5C0 )
0x00001CD4 51446 3  XPCOM R: ( (dsITargetData*)000001BD2A3BCD40 )->bestMatchedUDataType( 0x00000020, 0x0079, *0000000DAD8FC5C0 = 0x000B ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsITargetData*)000001BD2A3BCD40 )->typeCast( 0x000B, 0x00000000, 0000000DAD8FC5B0 )
0x00001CD4 51446 3  XPCOM R: ( (dsITargetData*)000001BD2A3BCD40 )->typeCast( 0x000B, 0x00000000, *0000000DAD8FC5B0 = 000001BD2A3BADC0 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterServer*)000001BD2EA1C670 )->findRegisterByName( REG_VECTOR_CATCH, *0000000DAD8FC5A8 = 000001BD3D20D410 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20D410 )->getAddress( 0000000DAD8FC5B0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20D410 )->getAddress( *0000000DAD8FC5B0 = 0x0000000060000007 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterAccess*)000001BD29180DE8 )->createDspRegister( 0x0000000060000007, 0x00000001, *0000000DAD8FC5B0 = 000001BD2A3BB800 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterServer*)000001BD2EA1C670 )->findRegisterByName( REG_VECTOR_CATCH, *0000000DAD8FC5A8 = 000001BD3D20CC30 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIMemoryAccess*)000001BD29180DF8 )->createTargetData64( 0x0013, 0x0000000000000000, *0000000DAD8FC5A0 = 000001BD2A3BAE40 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20CC30 )->getBitLength( 0000000DAD8FC5A0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20CC30 )->getBitLength( *0000000DAD8FC5A0 = 0x00000020 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20CC30 )->getPage( 0000000DAD8FC5A0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20CC30 )->getPage( *0000000DAD8FC5A0 = 0x00000079 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsITargetData*)000001BD2A3BAE40 )->bestMatchedUDataType( 0x00000020, 0x0079, 0000000DAD8FC5C0 )
0x00001CD4 51446 3  XPCOM R: ( (dsITargetData*)000001BD2A3BAE40 )->bestMatchedUDataType( 0x00000020, 0x0079, *0000000DAD8FC5C0 = 0x000B ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsITargetData*)000001BD2A3BAE40 )->typeCast( 0x000B, 0x00000000, 0000000DAD8FC5B0 )
0x00001CD4 51446 3  XPCOM R: ( (dsITargetData*)000001BD2A3BAE40 )->typeCast( 0x000B, 0x00000000, *0000000DAD8FC5B0 = 000001BD2A3BBA40 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterServer*)000001BD2EA1C670 )->findRegisterByName( REG_VECTOR_CATCH, *0000000DAD8FC5A8 = 000001BD3D20DA10 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20DA10 )->getAddress( 0000000DAD8FC5B0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20DA10 )->getAddress( *0000000DAD8FC5B0 = 0x0000000060000007 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterAccess*)000001BD29180DE8 )->createDspRegister( 0x0000000060000007, 0x00000001, *0000000DAD8FC5B0 = 000001BD2A3BAE80 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterServer*)000001BD2EA1C670 )->findRegisterByName( REG_VECTOR_CATCH, *0000000DAD8FC5A8 = 000001BD3D20D950 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIMemoryAccess*)000001BD29180DF8 )->createTargetData64( 0x0013, 0x0000000000000000, *0000000DAD8FC5A0 = 000001BD2A3BB0C0 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20D950 )->getBitLength( 0000000DAD8FC5A0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20D950 )->getBitLength( *0000000DAD8FC5A0 = 0x00000020 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20D950 )->getPage( 0000000DAD8FC5A0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20D950 )->getPage( *0000000DAD8FC5A0 = 0x00000079 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsITargetData*)000001BD2A3BB0C0 )->bestMatchedUDataType( 0x00000020, 0x0079, 0000000DAD8FC5C0 )
0x00001CD4 51446 3  XPCOM R: ( (dsITargetData*)000001BD2A3BB0C0 )->bestMatchedUDataType( 0x00000020, 0x0079, *0000000DAD8FC5C0 = 0x000B ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsITargetData*)000001BD2A3BB0C0 )->typeCast( 0x000B, 0x00000000, 0000000DAD8FC5B0 )
0x00001CD4 51446 3  XPCOM R: ( (dsITargetData*)000001BD2A3BB0C0 )->typeCast( 0x000B, 0x00000000, *0000000DAD8FC5B0 = 000001BD2A3BCF40 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterServer*)000001BD2EA1C670 )->findRegisterByName( REG_VECTOR_CATCH, *0000000DAD8FC5A8 = 000001BD3D20D0B0 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20D0B0 )->getAddress( 0000000DAD8FC5B0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20D0B0 )->getAddress( *0000000DAD8FC5B0 = 0x0000000060000007 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterAccess*)000001BD29180DE8 )->createDspRegister( 0x0000000060000007, 0x00000001, *0000000DAD8FC5B0 = 000001BD2A3BD280 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterServer*)000001BD2EA1C670 )->findRegisterByName( REG_VECTOR_CATCH, *0000000DAD8FC5A8 = 000001BD3D20D4D0 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIMemoryAccess*)000001BD29180DF8 )->createTargetData64( 0x0013, 0x0000000000000000, *0000000DAD8FC5A0 = 000001BD2A3BE8C0 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20D4D0 )->getBitLength( 0000000DAD8FC5A0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20D4D0 )->getBitLength( *0000000DAD8FC5A0 = 0x00000020 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20D4D0 )->getPage( 0000000DAD8FC5A0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20D4D0 )->getPage( *0000000DAD8FC5A0 = 0x00000079 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsITargetData*)000001BD2A3BE8C0 )->bestMatchedUDataType( 0x00000020, 0x0079, 0000000DAD8FC5C0 )
0x00001CD4 51446 3  XPCOM R: ( (dsITargetData*)000001BD2A3BE8C0 )->bestMatchedUDataType( 0x00000020, 0x0079, *0000000DAD8FC5C0 = 0x000B ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsITargetData*)000001BD2A3BE8C0 )->typeCast( 0x000B, 0x00000000, 0000000DAD8FC5B0 )
0x00001CD4 51446 3  XPCOM R: ( (dsITargetData*)000001BD2A3BE8C0 )->typeCast( 0x000B, 0x00000000, *0000000DAD8FC5B0 = 000001BD2A3BD640 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterServer*)000001BD2EA1C670 )->findRegisterByName( REG_VECTOR_CATCH, *0000000DAD8FC5A8 = 000001BD3D20C990 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20C990 )->getAddress( 0000000DAD8FC5B0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20C990 )->getAddress( *0000000DAD8FC5B0 = 0x0000000060000007 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterAccess*)000001BD29180DE8 )->createDspRegister( 0x0000000060000007, 0x00000001, *0000000DAD8FC5B0 = 000001BD2A3BD300 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterServer*)000001BD2EA1C670 )->findRegisterByName( REG_VECTOR_CATCH, *0000000DAD8FC5A8 = 000001BD3D20DE90 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsIMemoryAccess*)000001BD29180DF8 )->createTargetData64( 0x0013, 0x0000000000000000, *0000000DAD8FC5A0 = 000001BD2A3BE5C0 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20DE90 )->getBitLength( 0000000DAD8FC5A0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20DE90 )->getBitLength( *0000000DAD8FC5A0 = 0x00000020 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRegisterInfo*)000001BD3D20DE90 )->getPage( 0000000DAD8FC5A0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRegisterInfo*)000001BD3D20DE90 )->getPage( *0000000DAD8FC5A0 = 0x00000079 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsITargetData*)000001BD2A3BE5C0 )->bestMatchedUDataType( 0x00000020, 0x0079, 0000000DAD8FC5C0 )
0x00001CD4 51446 3  XPCOM R: ( (dsITargetData*)000001BD2A3BE5C0 )->bestMatchedUDataType( 0x00000020, 0x0079, *0000000DAD8FC5C0 = 0x000B ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsITargetData*)000001BD2A3BE5C0 )->typeCast( 0x000B, 0x00000000, 0000000DAD8FC5B0 )
0x00001CD4 51446 3  XPCOM R: ( (dsITargetData*)000001BD2A3BE5C0 )->typeCast( 0x000B, 0x00000000, *0000000DAD8FC5B0 = 000001BD2A3BD740 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIConnectDisconnect*)000001BD29180E08 )->connectionStatus( 0000000DAD8FC4A0 )
0x00001CD4 51446 3  XPCOM R: ( (dsIConnectDisconnect*)000001BD29180E08 )->connectionStatus( *0000000DAD8FC4A0 = 0x00000000 ) = 0x00000000
0x00001CD4 51446 3  XPCOM C: ( (dsIRunControl*)000001BD29180E10 )->getExecutionState( 0000000DAD8FC520, 0000000DAD8FC538, 0000000DAD8FC550, 0000000DAD8FC568 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRunControl*)000001BD29180E10 )->getExecutionState( *0000000DAD8FC520 = true, *0000000DAD8FC538 = false, *0000000DAD8FC550 = 0x00000000, *0000000DAD8FC568 = 0x00000000 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD29E5F7D0 )->onEvent() = 0x00000000
0x00001CD4 51446 3  COM_DBG_IF R: class DSP_CO_USER::OnConnected()
0x00001CD4 51446 3  COM_DBG_IF C: class DSP_CO_USER::OnRefresh()
0x00001CD4 51446 3  XPCOM C: ( (dsINumberEventCallback*)000001BD29E60650 )->onEvent( 0x0000000000000003 )
0x00003E54 51446 3  XPCOM C: ( (dsIBreakpointManager*)000001BD297E5870 )->NumBreakpointTypes( 0000000DAA8FE650 )
0x00001CD4 51446 3  XPCOM C: ( (dsIRunControl*)000001BD29180E10 )->getExecutionState( 0000000DAD8FC3F0, 0000000DAD8FC408, 0000000DAD8FC420, 0000000DAD8FC438 )
0x00001CD4 51446 3  XPCOM R: ( (dsIRunControl*)000001BD29180E10 )->getExecutionState( *0000000DAD8FC3F0 = true, *0000000DAD8FC408 = false, *0000000DAD8FC420 = 0x00000000, *0000000DAD8FC438 = 0x00000000 ) = 0x00000000
0x00001CD4 51446 3  XPCOM R: ( (dsINumberEventCallback*)000001BD29E60650 )->onEvent( 0x0000000000000003 ) = 0x00000000
0x00001CD4 51446 3  COM_DBG_IF R: class DSP_CO_USER::OnRefresh()
0x00001CD4 51446 3  COM_DBG_IF C: class DSP_CO_USER::OnAllowedUserAccessesChanged()
0x00001CD4 51446 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD29E60F50 )->onEvent()
0x00001CD4 51446 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD29E60F50 )->onEvent() = 0x00000000
0x00001CD4 51446 3  COM_DBG_IF R: class DSP_CO_USER::OnAllowedUserAccessesChanged()
0x00001CD4 51446 3 Cortex_M4_0 TPI C: TpiSvrStepAPI( *0000000000000000, TPI_STEP_CMD_GET_REVISION, *0000000DAD8FDC20 )
0x00001CD4 51446 3 Cortex_M4_0 TPI R: TpiSvrStepAPI( *0000000000000000, TPI_STEP_CMD_GET_REVISION, *0000000DAD8FDC20 = 0x00000064 ) = 0x00000000
0x00001CD4 51446 3 Cortex_M4_0 TPI C: TpiSvrStepAPI( *0000000000000000, TPI_STEP_CMD_CONSTRUCTOR, 0x0000000D75803800, 0x0000000D00000001, 0x000001BD2E7EEA70, 0x00007FFEC49C3380, 0x000001BD3D611688 )
0x00001CD4 51446 3 Cortex_M4_0 TPI R: TpiSvrStepAPI( *0000000000000000, TPI_STEP_CMD_CONSTRUCTOR, 0x0000000D75803800, 0x0000000D00000001, 0x000001BD2E7EEA70, 0x00007FFEC49C3380, 0x000001BD3D611688 ) = 0x00000000
0x00001CD4 51446 3 Cortex_M4_0 TPI C: TpiSvrStepAPI( *000001BD303A2580, TPI_STEP_CMD_GET_CACHE_SIZE, *0000000DAD8FDA50 )
0x00001CD4 51446 3 Cortex_M4_0 TPI R: TpiSvrStepAPI( *000001BD303A2580, TPI_STEP_CMD_GET_CACHE_SIZE, *0000000DAD8FDA50 = 0x00000010 ) = 0x00000000
0x00001CD4 51446 3 Cortex_M4_0 TPI C: TpiSvrStepAPI( *000001BD303A2580, TPI_STEP_CMD_GET_STATUS_REG, 0x0000000DAD8FDAA8, *0000000DAD8FDC28, *0000000DAD8FDC18, *0000000DAD8FDC10 )
0x00001CD4 51446 3 Cortex_M4_0 TPI R: TpiSvrStepAPI( *000001BD303A2580, TPI_STEP_CMD_GET_STATUS_REG, 0x0000000DAD8FDAA8, *0000000DAD8FDC28 = 0x0000000000000000, *0000000DAD8FDC18 = 0x00000001, *0000000DAD8FDC10 = 0x00000079 ) = 0x00000000
0x00001CD4 51446 3 Cortex_M4_0 POLL C: Firing of DSP_CONNECTED complete
0x00001CD4 51446 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00003E54 51446 3  XPCOM R: ( (dsIBreakpointManager*)000001BD297E5870 )->NumBreakpointTypes( *0000000DAA8FE650 = 0x00000003 ) = 0x00000000
0x00003E54 51446 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E4139C0 )->getProperty( EnableInstalledBreakpoint, 0000000DAA8FE6F8 )
0x00003E54 51446 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E4139C0 )->getProperty( EnableInstalledBreakpoint, *0000000DAA8FE6F8 = 000001BD279CE810 ) = 0x00000000
0x00003E54 51446 3  XPCOM C: ( (dsIProperty*)000001BD279CE810 )->getPropertyType( 0000000DAA8FE690 )
0x00003E54 51446 3  XPCOM R: ( (dsIProperty*)000001BD279CE810 )->getPropertyType( *0000000DAA8FE690 = 0x00000000 ) = 0x00000000
0x00001CD4 51446 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 51446 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 388 ms
0x00001CD4 51446 4  POLL I: TimeToSleep() found shorter sleep time of 388 ms from class DevicePollFrequencyManager
0x00001CD4 51446 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 8 ms
0x00001CD4 51446 4  POLL I: TimeToSleep() found shorter sleep time of 8 ms from class DevicePollFrequencyManager
0x00001CD4 51446 4 Cortex_M4_0 POLL I: TimeToPollAgain() target is idle and needs polling in 5000 ms
0x00003E54 51446 3  XPCOM C: ( (dsIProperty*)000001BD279CE810 )->queryInterface( 000001BD2EFB3CD0, 0000000DAA8FE688 )
0x00003E54 51446 3  XPCOM R: ( (dsIProperty*)000001BD279CE810 )->queryInterface( 000001BD2EFB3CD0, *0000000DAA8FE688 = 000001BD279CE8B0 ) = 0x00000000
0x00003E54 51446 3  XPCOM C: ( (dsIBooleanProperty*)000001BD279CE8B0 )->queryInterface( 000001BD2EFB3CD0, 0000000DAA8FE628 )
0x00003E54 51446 3  XPCOM R: ( (dsIBooleanProperty*)000001BD279CE8B0 )->queryInterface( 000001BD2EFB3CD0, *0000000DAA8FE628 = 000001BD279CE8B0 ) = 0x00000000
0x00003E54 51446 3  XPCOM C: ( (dsIBooleanProperty*)000001BD279CE8B0 )->CurValue( 0000000DAA8FE6F0 )
0x00003E54 51446 3  XPCOM R: ( (dsIBooleanProperty*)000001BD279CE8B0 )->CurValue( *0000000DAA8FE6F0 = true ) = 0x00000000
0x00003E54 51446 3  XPCOM C: ( (dsIConnectDisconnect*)000001BD29180E08 )->restoreDebugState()
0x00003E54 51446 3  XPCOM R: ( (dsIConnectDisconnect*)000001BD29180E08 )->restoreDebugState() = 0x00000001
0x00001CD4 51462 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 357 ms
0x00001CD4 51462 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 0 ms
0x00001CD4 51462 3 CS_DAP_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 51462 3 CS_DAP_0 GTI C: GTI_STAT( 0x000001BD29E1AA40 )
0x00001CD4 51462 3  CMAPI C: Acquire( 000001BD35055790 )
0x00001CD4 51462 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00003E54 51462 3  XPCOM C: ( (dsIBreakpointManager*)000001BD297E5870 )->setSkipBreakpoints( false, 0000000DAA8FE508 )
0x00001CD4 51462 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51462 3  CMAPI R: Acquire( 000001BD35055790 ) = 0
0x00001CD4 51462 3  CMAPI C: GetStatus( 000001BD35055790, 0000000DAD8FDA48 )
0x00001CD4 51462 3  CMAPI R: GetStatus( 000001BD35055790, *0000000DAD8FDA48 = { 1, 1, 1, 1, 1 } ) = 0
0x00001CD4 51462 3  CMAPI C: Release( 000001BD35055790 )
0x00001CD4 51462 3  CMAPI R: Release( 000001BD35055790 ) = 0
0x00001CD4 51462 3 CS_DAP_0 GTI R: GTI_STAT( 0x000001BD29E1AA40 ) = 0x0000000D
0x00001CD4 51462 3 CS_DAP_0 STATE I: Target execution state changed to STATUS_NON_DEBUG_NORMAL
0x00001CD4 51462 3 CS_DAP_0 STATE I: Debugger execution state changed to EVENT_DSP_HALT
0x00001CD4 51462 4 CS_DAP_0 POLL I: Yielding to other threads
0x00003E54 51462 3  XPCOM R: ( (dsIBreakpointManager*)000001BD297E5870 )->setSkipBreakpoints( false, *0000000DAA8FE508 = 0000000000000000 ) = 0x00000000
0x00001CD4 51462 3 CS_DAP_0 POLL R: Poll() returning
0x00001CD4 51462 4 Cortex_M4_0 POLL I: TimeToPollAgain() target is idle and needs polling in 4969 ms
0x00001CD4 51462 4  POLL I: TimeToSleep() found shorter sleep time of 357 ms from class DevicePollFrequencyManager
0x00001CD4 51462 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00003E54 51462 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E4139C0 )->getProperty( EnableInstalledBreakpoint, 0000000DAA8FE598 )
0x00003E54 51462 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E4139C0 )->getProperty( EnableInstalledBreakpoint, *0000000DAA8FE598 = 000001BD279CE810 ) = 0x00000000
0x00003E54 51462 3  XPCOM C: ( (dsIProperty*)000001BD279CE810 )->getPropertyType( 0000000DAA8FE530 )
0x00003E54 51462 3  XPCOM R: ( (dsIProperty*)000001BD279CE810 )->getPropertyType( *0000000DAA8FE530 = 0x00000000 ) = 0x00000000
0x00003E54 51462 3  XPCOM C: ( (dsIProperty*)000001BD279CE810 )->queryInterface( 000001BD2EFB37F0, 0000000DAA8FE528 )
0x00003E54 51462 3  XPCOM R: ( (dsIProperty*)000001BD279CE810 )->queryInterface( 000001BD2EFB37F0, *0000000DAA8FE528 = 000001BD279CE8B0 ) = 0x00000000
0x00003E54 51462 3  XPCOM C: ( (dsIBooleanProperty*)000001BD279CE8B0 )->queryInterface( 000001BD2EFB37F0, 0000000DAA8FE4C8 )
0x00003E54 51462 3  XPCOM R: ( (dsIBooleanProperty*)000001BD279CE8B0 )->queryInterface( 000001BD2EFB37F0, *0000000DAA8FE4C8 = 000001BD279CE8B0 ) = 0x00000000
0x00003E54 51462 3  XPCOM C: ( (dsIBooleanProperty*)000001BD279CE8B0 )->CurValue( 0000000DAA8FE590 )
0x00003E54 51462 3  XPCOM R: ( (dsIBooleanProperty*)000001BD279CE8B0 )->CurValue( *0000000DAA8FE590 = true ) = 0x00000000
0x00003E54 51462 3  XPCOM C: ( (dsIConnectDisconnect*)000001BD29180E08 )->restoreDebugState()
0x00003E54 51462 3  XPCOM R: ( (dsIConnectDisconnect*)000001BD29180E08 )->restoreDebugState() = 0x00000001
0x00003E54 51462 3  XPCOM C: ( (dsIProgramLoader*)000001BD297E42E0 )->CapableLoadWhileDisconnected( 0000000DAA8FE600 )
0x00003E54 51462 3  XPCOM R: ( (dsIProgramLoader*)000001BD297E42E0 )->CapableLoadWhileDisconnected( *0000000DAA8FE600 = false ) = 0x00000000
0x00003E54 51462 3  XPCOM C: ( (dsIProgramLoader*)000001BD297E42E0 )->CapableLoad( 0000000DAA8FE5A0 )
0x00003E54 51462 3  XPCOM R: ( (dsIProgramLoader*)000001BD297E42E0 )->CapableLoad( *0000000DAA8FE5A0 = true ) = 0x00000000
0x00003E54 51462 3  XPCOM C: ( (dsIExpressionEvaluation*)000001BD29180DF0 )->requestCExprEval( GEL_Load( "C:\\Users\\o.gaste\\workspace_v12\\project_zero_CC26X2R1_LAUNCHXL_tirtos7_ticlang\\Debug\\project_zero_CC26X2R1_LAUNCHXL_tirtos7_ticlang.out" ), false, true, 000001BD2EFB4630, 0000000DAA8FE510 )
0x00003E54 51462 3 Cortex_M4_0 GEL I: Evaluating "GEL_Load("C:\Users\o.gaste\workspace_v12\project_zero_CC26X2R1_LAUNCHXL_tirtos7_ticlang\Debug\project_zero_CC26X2R1_LAUNCHXL_tirtos7_ticlang.out")"
0x00003E54 51462 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00003E54 51462 3  XPCOM R: ( (dsIExpressionEvaluation*)000001BD29180DF0 )->requestCExprEval( GEL_Load( "C:\\Users\\o.gaste\\workspace_v12\\project_zero_CC26X2R1_LAUNCHXL_tirtos7_ticlang\\Debug\\project_zero_CC26X2R1_LAUNCHXL_tirtos7_ticlang.out" ), false, true, 000001BD2EFB4630, *0000000DAA8FE510 = 000001BD2B5E9800 ) = 0x00000000
0x00001CD4 51462 3 Cortex_M4_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 51462 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 51462 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 51462 4 Cortex_M4_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 51462 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 51462 4  POLL I: Yielding to other threads
0x00001CD4 51462 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 51462 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 51462 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 51462 3 Cortex_M4_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 51462 3  PERF I: Program Load starting...
0x00001CD4 51462 3 Cortex_M4_0 STATE I: Debugger execution state changed to EVENT_DSP_HALT
0x00001CD4 51462 4 Cortex_M4_0 EX_STEP I: A halt was requested by the user
0x00001CD4 51462 3 Cortex_M4_0 GEL I: Evaluating "OnPreFileLoaded()"
0x00001CD4 51462 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:32	Enter function OnPreFileLoaded
0x00001CD4 51462 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:35	   BoardReset_Automatic()
0x00001CD4 51462 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:81	   Enter function BoardReset_Automatic
0x00001CD4 51462 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:83	      ConnectStateStore()
0x00001CD4 51462 2 Cortex_M4_0 GEL I: cc26xx_connect_util.gel:11	      Enter function ConnectStateStore
0x00001CD4 51462 2 Cortex_M4_0 GEL I: cc26xx_connect_util.gel:12	         _prevState=GEL_IsConnected()
0x00001CD4 51462 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='_prevState' AND Register_Cache.Processor=35
0x00001CD4 51462 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=35 AND Name='_prevState'
0x00001CD4 51462 2 Cortex_M4_0 GEL I: cc26xx_connect_util.gel:13	         _prevState
0x00001CD4 51462 2 Cortex_M4_0 GEL I: cc26xx_connect_util.gel:13	      Leave function ConnectStateStore lv = LValue with Location: GEL local
0x00001CD4 51462 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:84	      GEL_EvalOnTarget("<parent>", "ConnectStateStore()", 1)
0x00001CD4 51462 3 CS_DAP_0 GEL I: Evaluating "ConnectStateStore()"
0x00001CD4 51462 3 CS_DAP_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 51462 4 CS_DAP_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 51462 3 CS_DAP_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 51462 3 CS_DAP_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 51462 2 CS_DAP_0 GEL I: cc26xx_connect_util.gel:11	Enter function ConnectStateStore
0x00001CD4 51462 3 CS_DAP_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 51462 2 CS_DAP_0 GEL I: cc26xx_connect_util.gel:12	   _prevState=GEL_IsConnected()
0x00001CD4 51462 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='_prevState' AND Register_Cache.Processor=34
0x00001CD4 51462 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=34 AND Name='_prevState'
0x00001CD4 51462 2 CS_DAP_0 GEL I: cc26xx_connect_util.gel:13	   _prevState
0x00001CD4 51462 2 CS_DAP_0 GEL I: cc26xx_connect_util.gel:13	Leave function ConnectStateStore lv = LValue with Location: GEL local
0x00001CD4 51462 3 CS_DAP_0 GEL I: Evaluation of "ConnectStateStore()" completed - Value: 1 Location: GEL local
0x00001CD4 51462 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:85	      GEL_EvalOnTarget("<parent>", "GEL_EvalOnTarget("<parent>","ConnectStateStore()", 1)", 1)
0x00001CD4 51462 3 CS_DAP_0 GEL I: Evaluating "GEL_EvalOnTarget("<parent>", "ConnectStateStore()", 1)"
0x00001CD4 51462 3 IcePick_C GEL I: Evaluating "ConnectStateStore()"
0x00001CD4 51462 3 IcePick_C POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 51462 4 IcePick_C POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 51462 3 IcePick_C POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 51462 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 51462 3 IcePick_C POLL R: Poll() returning
0x00001CD4 51462 3 IcePick_C POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 51462 3 IcePick_C POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 51462 2 IcePick_C GEL I: cc26xx_connect_util.gel:11	Enter function ConnectStateStore
0x00001CD4 51462 3 IcePick_C POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 51462 2 IcePick_C GEL I: cc26xx_connect_util.gel:12	   _prevState=GEL_IsConnected()
0x00001CD4 51462 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Name='_prevState' AND Register_Cache.Processor=33
0x00001CD4 51462 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=33 AND Name='_prevState'
0x00001CD4 51462 2 IcePick_C GEL I: cc26xx_connect_util.gel:13	   _prevState
0x00001CD4 51462 2 IcePick_C GEL I: cc26xx_connect_util.gel:13	Leave function ConnectStateStore lv = LValue with Location: GEL local
0x00001CD4 51462 3 IcePick_C GEL I: Evaluation of "ConnectStateStore()" completed - Value: 1 Location: GEL local
0x00001CD4 51462 3 CS_DAP_0 GEL I: Evaluation of "GEL_EvalOnTarget("<parent>", "ConnectStateStore()", 1)" completed - Value: 1 Location: GEL local
0x00001CD4 51462 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:88	      DisconnectIfConnected()
0x00001CD4 51462 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 51462 4  POLL I: TimeToSleep() found shorter sleep time of 500 ms from class DevicePollFrequencyManager
0x00001CD4 51462 2 Cortex_M4_0 GEL I: cc26xx_connect_util.gel:47	      Enter function DisconnectIfConnected
0x00001CD4 51462 2 Cortex_M4_0 GEL I: cc26xx_connect_util.gel:50	         GEL_Disconnect()
0x00001CD4 51462 3 Cortex_M4_0 POLL C: Firing DSP_PREDISCONNECT to all DSP_USER's
0x00001CD4 51462 3 Cortex_M4_0 POLL C: Firing of DSP_PREDISCONNECT complete
0x00001CD4 51462 3 Cortex_M4_0 STATE I: Connection state changed to 3
0x00001CD4 51462 3 Cortex_M4_0 POLL C: Firing DSP_DISCONNECTING to all DSP_USER's
0x00001CD4 51462 3 Cortex_M4_0 TA C: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::ePreDisconnect )
0x00001CD4 51462 3 Cortex_M4_0 TA R: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::ePreDisconnect )
0x00001CD4 51462 3  COM_DBG_IF C: class DSP_CO_USER::OnDisconnecting()
0x00001CD4 51462 3  XPCOM C: ( (dsIBooleanEventCallback*)000001BD29E601D0 )->onEvent( false )
0x00001CD4 51462 3  XPCOM C: ( (dsIConnectDisconnect*)000001BD29180E08 )->connectionStatus( 0000000DAD8FBC40 )
0x00001CD4 51462 3  XPCOM R: ( (dsIConnectDisconnect*)000001BD29180E08 )->connectionStatus( *0000000DAD8FBC40 = 0x00000003 ) = 0x00000000
0x00001CD4 51462 3  XPCOM C: ( (dsIRunControl*)000001BD29180E10 )->getExecutionState( 0000000DAD8FBCC0, 0000000DAD8FBCD8, 0000000DAD8FBCF0, 0000000DAD8FBD08 )
0x00001CD4 51462 3  XPCOM R: ( (dsIRunControl*)000001BD29180E10 )->getExecutionState( *0000000DAD8FBCC0 = true, *0000000DAD8FBCD8 = false, *0000000DAD8FBCF0 = 0x00000000, *0000000DAD8FBD08 = 0x00000000 ) = 0x00000000
0x00001CD4 51462 3  XPCOM R: ( (dsIBooleanEventCallback*)000001BD29E601D0 )->onEvent( false ) = 0x00000000
0x00001CD4 51462 3  COM_DBG_IF R: class DSP_CO_USER::OnDisconnecting()
0x00001CD4 51462 3  COM_DBG_IF C: class DSP_CO_USER::OnAllowedUserAccessesChanged()
0x00001CD4 51462 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD29E60F50 )->onEvent()
0x00001CD4 51462 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD29E60F50 )->onEvent() = 0x00000000
0x00001CD4 51462 3  COM_DBG_IF R: class DSP_CO_USER::OnAllowedUserAccessesChanged()
0x00001CD4 51462 3 Cortex_M4_0 POLL C: Firing of DSP_DISCONNECTING complete
0x00001CD4 51462 3 Cortex_M4_0 POLL C: Firing DSP_REMOVE_DEBUG_STATE to all DSP_USER's
0x00001CD4 51478 3  COM_DBG_IF C: class CoBreakpointManager::OnBatchUpdateStarted()
0x00001CD4 51478 3  COM_DBG_IF R: class CoBreakpointManager::OnBatchUpdateStarted()
0x00001CD4 51478 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class DebuggerListeners
0x00001CD4 51478 3  COM_DBG_IF C: class DSP_CO_USER::OnRemoveDebugState()
0x00001CD4 51478 3  COM_DBG_IF R: class DSP_CO_USER::OnRemoveDebugState()
0x00001CD4 51478 3 Cortex_M4_0 POLL C: Firing of DSP_REMOVE_DEBUG_STATE complete
0x00001CD4 51478 3 Cortex_M4_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 51478 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 51478 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 51478 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 51478 4  POLL I: TimeToSleep() found shorter sleep time of 500 ms from class DevicePollFrequencyManager
0x00001CD4 51478 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 51478 4 Cortex_M4_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 51478 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 51478 4  POLL I: Yielding to other threads
0x00001CD4 51478 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 51478 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class DebuggerListeners
0x00001CD4 51478 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 485 ms
0x00001CD4 51478 4  POLL I: TimeToSleep() found shorter sleep time of 485 ms from class DevicePollFrequencyManager
0x00001CD4 51478 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 485 ms
0x00001CD4 51478 3  COM_DBG_IF C: class CoBreakpointManager::OnBatchUpdateFinished()
0x00001CD4 51478 3  COM_DBG_IF R: class CoBreakpointManager::OnBatchUpdateFinished()
0x00001CD4 51478 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_DISCONNECT and status EVENT_DSP_HALT
0x00001CD4 51478 3 Cortex_M4_0 GTI C: GTI_DONE_REMOVING_DEBUG_STATE( 0x000001BD362E2770 )
0x00001CD4 51478 3 Cortex_M4_0 GTI R: GTI_DONE_REMOVING_DEBUG_STATE( 0x000001BD362E2770 ) = 0x00000000
0x00001CD4 51478 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD918 = 0x00000000, *0x0000000DAD8FD910 = 0x00000000, *0x0000000DAD8FD928 = 0x00000000, *0x0000000DAD8FD940 = 0x00000000, *0x0000000DAD8FD948 = 0x00000000, *0x0000000DAD8FD938 = 0x00000000, *0x0000000DAD8FD930 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51478 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD918 = 0x00000000, *0x0000000DAD8FD910 = 0x00000000, *0x0000000DAD8FD928 = 0x00000000, *0x0000000DAD8FD940 = 0x00000002, *0x0000000DAD8FD948 = 0x00000000, *0x0000000DAD8FD938 = 0x00000008, *0x0000000DAD8FD930 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51478 3  PERF I: GTI_DISCONNECT starting...
0x00001CD4 51478 3 Cortex_M4_0 GTI C: GTI_DISCONNECT( 0x000001BD362E2770 )
0x00001CD4 51478 3  CMAPI C: Acquire( 000001BD35050D30 )
0x00001CD4 51478 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 51478 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51478 3  CMAPI R: Acquire( 000001BD35050D30 ) = 0
0x00001CD4 51478 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE0002000, 4, *0000000DAD8FDF00 = [02 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51478 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 51478 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000000, *value = 0x63000052 ) = 0
0x00001CD4 51478 3  XDS110 I: Depth1: DpRegWrite( address = 0x00000008, *value = 0x00000000 ) = 0
0x00001CD4 51478 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe0002000 ) = 0
0x00001CD4 51478 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000002 ) = 0
0x00001CD4 51478 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51478 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 51478 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE0002000, 4, 0000000DAD8FDF00, 0000000000000000 ) = 0
0x00001CD4 51478 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, *0000000DAD8FDEA8 = [00 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51478 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 51478 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000000 ) = 0
0x00001CD4 51478 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, 0000000DAD8FDEA8, 0000000000000000 ) = 0
0x00001CD4 51478 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [00 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51478 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 51478 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00010000 ) = 0
0x00001CD4 51478 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDEA0, 0000000000000000 ) = 0
0x00001CD4 51478 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDE40, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51478 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51478 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 51478 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000003 = 0
0x00001CD4 51478 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51478 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51478 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDE40 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 51478 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, *0000000DAD8FDEA8 = [04 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51494 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 51494 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000004 ) = 0
0x00001CD4 51494 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51494 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 51494 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, 0000000DAD8FDEA8, 0000000000000000 ) = 0
0x00001CD4 51494 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [01 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51494 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 51494 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 51494 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00010001 ) = 0
0x00001CD4 51494 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDEA0, 0000000000000000 ) = 0
0x00001CD4 51494 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDE40, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51494 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51494 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 51494 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51494 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51494 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51494 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDE40 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 51494 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, *0000000DAD8FDEA8 = [00 00 03 40 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51498 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 51498 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x40030000 ) = 0
0x00001CD4 51498 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51498 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 51498 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, 0000000DAD8FDEA8, 0000000000000000 ) = 0
0x00001CD4 51498 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [02 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51498 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 51498 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 51498 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00010002 ) = 0
0x00001CD4 51498 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDEA0, 0000000000000000 ) = 0
0x00001CD4 51498 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDE40, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51498 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51502 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 51502 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51502 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51502 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51502 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51502 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDE40 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 51502 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, *0000000DAD8FDEA8 = [05 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51502 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 51502 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 51502 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000005 ) = 0
0x00001CD4 51502 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 51502 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, 0000000DAD8FDEA8, 0000000000000000 ) = 0
0x00001CD4 51502 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [03 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51502 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 51502 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00010003 ) = 0
0x00001CD4 51502 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDEA0, 0000000000000000 ) = 0
0x00001CD4 51502 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDE40, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51502 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51502 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, *0000000DAD8FDEA8 = [00 00 09 40 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51502 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x40090000 ) = 0
0x00001CD4 51502 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [04 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51502 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00010004 ) = 0
0x00001CD4 51502 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, *0000000DAD8FDEA8 = [00 00 03 40 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51502 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x40030000 ) = 0
0x00001CD4 51502 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [05 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51518 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 51518 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00010005 ) = 0
0x00001CD4 51518 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51518 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 51518 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDEA0, 0000000000000000 ) = 0
0x00001CD4 51518 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDE40, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51518 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51518 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 51518 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51518 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51518 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51518 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDE40 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 51518 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, *0000000DAD8FDEA8 = [03 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51518 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 51518 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 51518 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000003 ) = 0
0x00001CD4 51518 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, 0000000DAD8FDEA8, 0000000000000000 ) = 0
0x00001CD4 51518 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [06 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51518 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00010006 ) = 0
0x00001CD4 51518 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, *0000000DAD8FDEA8 = [00 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51518 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000000 ) = 0
0x00001CD4 51518 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [07 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51518 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00010007 ) = 0
0x00001CD4 51518 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, *0000000DAD8FDEA8 = [01 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51518 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000001 ) = 0
0x00001CD4 51518 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [08 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51518 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00010008 ) = 0
0x00001CD4 51518 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, *0000000DAD8FDEA8 = [00 20 09 40 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51518 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x40092000 ) = 0
0x00001CD4 51518 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [09 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51518 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00010009 ) = 0
0x00001CD4 51518 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, *0000000DAD8FDEA8 = [00 00 09 40 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51518 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x40090000 ) = 0
0x00001CD4 51518 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [0A 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51518 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x0001000a ) = 0
0x00001CD4 51533 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 51533 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51533 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51533 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51533 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51533 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDE40 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 51533 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, *0000000DAD8FDEA8 = [0D 00 00 04 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51533 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 51533 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 51533 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x0400000d ) = 0
0x00001CD4 51533 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 51533 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, 0000000DAD8FDEA8, 0000000000000000 ) = 0
0x00001CD4 51533 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [0B 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51533 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 51533 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x0001000b ) = 0
0x00001CD4 51533 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDEA0, 0000000000000000 ) = 0
0x00001CD4 51533 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDE40, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51533 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51533 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, *0000000DAD8FDEA8 = [00 60 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51533 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00006000 ) = 0
0x00001CD4 51533 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [0C 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51533 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x0001000c ) = 0
0x00001CD4 51533 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, *0000000DAD8FDEA8 = [F0 1F 00 11 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51533 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x11001ff0 ) = 0
0x00001CD4 51533 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [0D 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51533 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x0001000d ) = 0
0x00001CD4 51533 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, *0000000DAD8FDEA8 = [D1 11 00 10 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51533 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x100011d1 ) = 0
0x00001CD4 51533 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [0E 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51533 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x0001000e ) = 0
0x00001CD4 51533 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, *0000000DAD8FDEA8 = [8E 11 00 10 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51533 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x1000118e ) = 0
0x00001CD4 51533 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [0F 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51533 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x0001000f ) = 0
0x00001CD4 51533 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, *0000000DAD8FDEA8 = [00 00 00 61 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51549 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 51549 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x61000000 ) = 0
0x00001CD4 51549 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 51549 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 51549 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, 0000000DAD8FDEA8, 0000000000000000 ) = 0
0x00001CD4 51549 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [10 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51549 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 51549 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 51549 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00010010 ) = 0
0x00001CD4 51549 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDEA0, 0000000000000000 ) = 0
0x00001CD4 51549 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDE40, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51549 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 51549 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 51549 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51549 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 51549 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 51549 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDE40 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 51549 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, *0000000DAD8FDEA8 = [F0 1F 00 11 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51549 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x11001ff0 ) = 0
0x00001CD4 51549 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [11 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51549 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00010011 ) = 0
0x00001CD4 51549 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF8, 4, *0000000DAD8FDEA8 = [00 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51549 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000000 ) = 0
0x00001CD4 51549 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [12 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51549 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00010012 ) = 0
0x00001CD4 51549 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [13 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51549 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00010013 ) = 0
0x00001CD4 51549 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDEA0 = [14 00 01 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51549 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00010014 ) = 0
0x00001CD4 51549 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDFC, 4, *0000000DAD8FDED8 = [00 00 00 01 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51549 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edfc ) = 0
0x00001CD4 51549 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x01000000 ) = 0
0x00001CD4 51549 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDFC, 4, 0000000DAD8FDED8, 0000000000000000 ) = 0
0x00001CD4 51549 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDED0 = [00 00 5F A0 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 51580 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 51580 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0xa05f0000 ) = 0
0x00001CD4 51580 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0x00000000 = 0
0x00001CD4 51580 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 51580 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDED0, 0000000000000000 ) = 0
0x00001CD4 51580 3  CMAPI C: Release( 000001BD35050D30 )
0x00001CD4 51580 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 51580 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51580 3  CMAPI R: Release( 000001BD35050D30 ) = 0
0x00001CD4 51580 3  CMAPI C: Close( 000001BD35050D30 )
0x00001CD4 51580 3  CMAPI R: Close( 000001BD35050D30 ) = 0
0x00001CD4 51580 3  PRSC C: PRSC_DisConnect: prscHandle=0x1bd29e1cbb0,
0x00001CD4 51580 3  PRSC C: PRSC_ReleaseClockPower: prscHandle=0x1bd29e1cbb0,
0x00001CD4 51580 3  PRSC C: prsc_SendRouter: connectionNeeded=0x1
0x00001CD4 51580 3  PRSC C: GRTR:Connected: routerHandle=0x1bd2b9beca0
0x00001CD4 51580 3 IcePick_C TA C: IsConnected()
0x00001CD4 51580 3 IcePick_C TA R: IsConnected() = true
0x00001CD4 51580 3  PRSC R: GRTR:Connected: pbConnected =0x1, ret=0x0
0x00001CD4 51580 3  PRSC C: GRTR:ReleaseClockPower: routerHandle=0x1bd2b9beca0, parentHandle=0x1bd3d0baf60, regIndex=0x2, subPathForce=0x1
0x00001CD4 51580 3  PRSC R: GRTR:ReleaseClockPower: prscRtn=0x0
0x00001CD4 51580 3  PRSC C: prsc_SendRouter: error =0x0
0x00001CD4 51580 3  PRSC R: PRSC_ReleaseClockPower: prscRtn =0x0
0x00001CD4 51580 3  PRSC C: GRTR:SubDisConnect: routerHandle =0x1bd2b9beca0subPathHandle=0x1bd3d1fdea0,numConnections=0x1
0x00001CD4 51580 3  PRSC R: GRTR:SUBDisConnect: rtn=0x0
0x00001CD4 51580 3  PRSC C: GRTR:SubDisConnect: routerHandle =0x1bd2b9beca0subPathHandle=0x1bd3d1fe4e0,numConnections=0x1
0x00001CD4 51580 3  PRSC R: PRSC_DisConnect: error =0x0
0x00001CD4 51580 3 Cortex_M4_0 GTI R: GTI_DISCONNECT( 0x000001BD362E2770 ) = 0x00000000
0x00001CD4 51580 3  PERF I: GTI_DISCONNECT finished:  0.107414s wall, 0.015625s user + 0.000000s system = 0.015625s CPU (14.5%)
0x00001CD4 51580 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD9D8 = 0x00000000, *0x0000000DAD8FD9D0 = 0x00000000, *0x0000000DAD8FD9E8 = 0x00000000, *0x0000000DAD8FDA00 = 0x00000000, *0x0000000DAD8FDA08 = 0x00000000, *0x0000000DAD8FD9F8 = 0x00000000, *0x0000000DAD8FD9F0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51580 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD9D8 = 0x00000000, *0x0000000DAD8FD9D0 = 0x00000000, *0x0000000DAD8FD9E8 = 0x00000000, *0x0000000DAD8FDA00 = 0x00000002, *0x0000000DAD8FDA08 = 0x00000000, *0x0000000DAD8FD9F8 = 0x00000008, *0x0000000DAD8FD9F0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51580 3 Cortex_M4_0 GTI C: GTI_STAT_EX2( 0x000001BD362E2770, *0x0000000DAD8FE048 = { 0, 0, 0, 0, 0, 0, 0, 0 } )
0x00001CD4 51580 3 Cortex_M4_0 GTI R: GTI_STAT_EX2( 0x000001BD362E2770, *0x0000000DAD8FE048 = { 1, 100, 202, 301, 401, 0, 0, 0 } ) = 0x00000000
0x00001CD4 51580 3 Cortex_M4_0 STATE I: Target execution state changed to STATUS_RUNNING
0x00001CD4 51580 3 Cortex_M4_0 STATE I: Connection state changed to 2
0x00001CD4 51580 3 Cortex_M4_0 POLL C: Firing DSP_DISCONNECTED to all DSP_USER's
0x00001CD4 51580 3 Cortex_M4_0 TA C: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::eDisconnected )
0x00001CD4 51580 3 Cortex_M4_0 TA R: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::eDisconnected )
0x00001CD4 51580 3 CS_DAP_0 POLL C: Firing DSP_PREDISCONNECT to all DSP_USER's
0x00001CD4 51580 3 CS_DAP_0 POLL C: Firing of DSP_PREDISCONNECT complete
0x00001CD4 51580 3 CS_DAP_0 STATE I: Connection state changed to 3
0x00001CD4 51580 3 CS_DAP_0 POLL C: Firing DSP_DISCONNECTING to all DSP_USER's
0x00001CD4 51580 3 CS_DAP_0 TA C: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::ePreDisconnect )
0x00001CD4 51580 3 CS_DAP_0 TA R: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::ePreDisconnect )
0x00001CD4 51580 3  COM_DBG_IF C: class DSP_CO_USER::OnDisconnecting()
0x00001CD4 51580 3  XPCOM C: ( (dsIBooleanEventCallback*)000001BD29E62550 )->onEvent( false )
0x00001CD4 51580 3  XPCOM R: ( (dsIBooleanEventCallback*)000001BD29E62550 )->onEvent( false ) = 0x00000000
0x00001CD4 51580 3  COM_DBG_IF R: class DSP_CO_USER::OnDisconnecting()
0x00001CD4 51580 3  COM_DBG_IF C: class DSP_CO_USER::OnAllowedUserAccessesChanged()
0x00001CD4 51580 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD29E62350 )->onEvent()
0x00001CD4 51580 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD29E62350 )->onEvent() = 0x00000000
0x00001CD4 51580 3  COM_DBG_IF R: class DSP_CO_USER::OnAllowedUserAccessesChanged()
0x00001CD4 51580 3 CS_DAP_0 POLL C: Firing of DSP_DISCONNECTING complete
0x00001CD4 51580 3 CS_DAP_0 POLL C: Firing DSP_REMOVE_DEBUG_STATE to all DSP_USER's
0x00001CD4 51580 3  COM_DBG_IF C: class CoBreakpointManager::OnBatchUpdateStarted()
0x00001CD4 51580 3  COM_DBG_IF R: class CoBreakpointManager::OnBatchUpdateStarted()
0x00001CD4 51580 3 CS_DAP_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class DebuggerListeners
0x00001CD4 51580 3  COM_DBG_IF C: class DSP_CO_USER::OnRemoveDebugState()
0x00001CD4 51580 3  COM_DBG_IF R: class DSP_CO_USER::OnRemoveDebugState()
0x00001CD4 51580 3 CS_DAP_0 POLL C: Firing of DSP_REMOVE_DEBUG_STATE complete
0x00001CD4 51580 3  COM_DBG_IF C: class DSP_CO_USER::OnDisconnected()
0x00001CD4 51580 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD29E605D0 )->onEvent()
0x00001CD4 51580 3  XPCOM C: ( (dsIConnectDisconnect*)000001BD29180E08 )->connectionStatus( 0000000DAD8FC2B0 )
0x00001CD4 51580 3  XPCOM R: ( (dsIConnectDisconnect*)000001BD29180E08 )->connectionStatus( *0000000DAD8FC2B0 = 0x00000002 ) = 0x00000000
0x00001CD4 51580 3  XPCOM C: ( (dsIRunControl*)000001BD29180E10 )->getExecutionState( 0000000DAD8FC330, 0000000DAD8FC348, 0000000DAD8FC360, 0000000DAD8FC378 )
0x00001CD4 51580 3  XPCOM R: ( (dsIRunControl*)000001BD29180E10 )->getExecutionState( *0000000DAD8FC330 = true, *0000000DAD8FC348 = false, *0000000DAD8FC360 = 0x00000005, *0000000DAD8FC378 = 0x00000001 ) = 0x00000000
0x00001CD4 51580 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD29E605D0 )->onEvent() = 0x00000000
0x00001CD4 51580 3  COM_DBG_IF R: class DSP_CO_USER::OnDisconnected()
0x00001CD4 51580 2 Cortex_M4_0 GEL I: cc26xx_connect_util.gel:50	      Leave function DisconnectIfConnected
0x00001CD4 51580 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 51580 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:89	      GEL_EvalOnTarget("<parent>", "DisconnectIfConnected()", 1)
0x00001CD4 51580 3 Cortex_M4_0 POLL C: Firing of DSP_DISCONNECTED complete
0x00001CD4 51580 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 51580 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 51580 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 485 ms
0x00001CD4 51580 4  POLL I: TimeToSleep() found shorter sleep time of 485 ms from class DevicePollFrequencyManager
0x00001CD4 51580 4 CS_DAP_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 51580 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 51580 4  POLL I: Yielding to other threads
0x00001CD4 51580 3 CS_DAP_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 51580 4 CS_DAP_0 POLL I: Yielding to other threads
0x00001CD4 51580 3 CS_DAP_0 POLL R: Poll() returning
0x00001CD4 51580 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 51580 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 51580 3 Cortex_M4_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 51580 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 382 ms
0x00001CD4 51580 4  POLL I: TimeToSleep() found shorter sleep time of 382 ms from class DevicePollFrequencyManager
0x00001CD4 51580 3 CS_DAP_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 51580 3 CS_DAP_0 POLL C: Firing DSP_REQ_EVENT to class DebuggerListeners
0x00001CD4 51580 3 CS_DAP_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 51580 3 CS_DAP_0 GEL I: Evaluating "DisconnectIfConnected()"
0x00001CD4 51580 3 CS_DAP_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 51580 3  COM_DBG_IF C: class CoBreakpointManager::OnBatchUpdateFinished()
0x00001CD4 51580 3  COM_DBG_IF R: class CoBreakpointManager::OnBatchUpdateFinished()
0x00001CD4 51580 3 CS_DAP_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 51580 2 CS_DAP_0 GEL I: cc26xx_connect_util.gel:47	Enter function DisconnectIfConnected
0x00001CD4 51580 2 CS_DAP_0 GEL I: cc26xx_connect_util.gel:48	Leave function DisconnectIfConnected
0x00001CD4 51580 3 CS_DAP_0 GEL I: Evaluation of "DisconnectIfConnected()" completed - Value: 0 Location: unknown
0x00001CD4 51580 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:90	      GEL_EvalOnTarget("<parent>", "GEL_EvalOnTarget("<parent>","DisconnectIfConnected()", 1)", 1)
0x00001CD4 51580 3 Cortex_M4_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 51580 3 CS_DAP_0 POLL C: Polling with state CPU_ST_DISCONNECT and status EVENT_DSP_HALT
0x00001CD4 51580 3 CS_DAP_0 GTI C: GTI_DONE_REMOVING_DEBUG_STATE( 0x000001BD29E1AA40 )
0x00001CD4 51580 3 CS_DAP_0 GTI R: GTI_DONE_REMOVING_DEBUG_STATE( 0x000001BD29E1AA40 ) = 0x00000000
0x00001CD4 51580 3 CS_DAP_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E1AA40, *0x0000000DAD8FD918 = 0x00000000, *0x0000000DAD8FD910 = 0x00000000, *0x0000000DAD8FD928 = 0x00000000, *0x0000000DAD8FD940 = 0x00000000, *0x0000000DAD8FD948 = 0x00000000, *0x0000000DAD8FD938 = 0x00000000, *0x0000000DAD8FD930 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51580 3 CS_DAP_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E1AA40, *0x0000000DAD8FD918 = 0x00000000, *0x0000000DAD8FD910 = 0x00000000, *0x0000000DAD8FD928 = 0x00000000, *0x0000000DAD8FD940 = 0x00000002, *0x0000000DAD8FD948 = 0x00000000, *0x0000000DAD8FD938 = 0x00000008, *0x0000000DAD8FD930 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51580 3  PERF I: GTI_DISCONNECT starting...
0x00001CD4 51580 3 CS_DAP_0 GTI C: GTI_DISCONNECT( 0x000001BD29E1AA40 )
0x00001CD4 51580 3  CMAPI C: DapRegRead( 000001BD35055790, 1, 0, 0x00000004, 0000000DAD8FDF30 )
0x00001CD4 51580 3  XDS110 C: Executing command 0x15 (CMAPI_DAPREGREAD)
0x00001CD4 51627 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0x03000001 = -1170
0x00001CD4 51627 3  XDS110 I: Depth1: DpRegWrite( address = 0x00000004, *value = 0x50000032 ) = 0
0x00001CD4 51627 3  XDS110 R: Executed command 0x15 (CMAPI_DAPREGREAD), return code: 0xfffffb6e
0x00001CD4 51627 3  CMAPI R: DapRegRead( 000001BD35055790, 1, 0, 0x00000004, *0000000DAD8FDF30 = 0x00000000 ) = -1170
0x00001CD4 51627 3  CMAPI C: Close( 000001BD35055790 )
0x00001CD4 51627 3  CMAPI R: Close( 000001BD35055790 ) = 0
0x00001CD4 51627 3  PRSC C: PRSC_DisConnect: prscHandle=0x1bd29e1b120,
0x00001CD4 51627 3  PRSC R: PRSC_DisConnect: error =0x0
0x00001CD4 51627 3 CS_DAP_0 GTI R: GTI_DISCONNECT( 0x000001BD29E1AA40 ) = 0x00000000
0x00001CD4 51627 3  PERF I: GTI_DISCONNECT finished:  0.049528s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 51627 3 CS_DAP_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E1AA40, *0x0000000DAD8FD9D8 = 0x00000000, *0x0000000DAD8FD9D0 = 0x00000000, *0x0000000DAD8FD9E8 = 0x00000000, *0x0000000DAD8FDA00 = 0x00000000, *0x0000000DAD8FDA08 = 0x00000000, *0x0000000DAD8FD9F8 = 0x00000000, *0x0000000DAD8FD9F0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51627 3 CS_DAP_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E1AA40, *0x0000000DAD8FD9D8 = 0x00000000, *0x0000000DAD8FD9D0 = 0x00000000, *0x0000000DAD8FD9E8 = 0x00000000, *0x0000000DAD8FDA00 = 0x00000002, *0x0000000DAD8FDA08 = 0x00000000, *0x0000000DAD8FD9F8 = 0x00000008, *0x0000000DAD8FD9F0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51627 3 CS_DAP_0 GTI C: GTI_STAT( 0x000001BD29E1AA40 )
0x00001CD4 51627 3 CS_DAP_0 GTI R: GTI_STAT( 0x000001BD29E1AA40 ) = 0x0000000B
0x00001CD4 51627 3 CS_DAP_0 STATE I: Target execution state changed to STATUS_RUNNING
0x00001CD4 51627 3 CS_DAP_0 STATE I: Connection state changed to 2
0x00001CD4 51627 3 CS_DAP_0 POLL C: Firing DSP_DISCONNECTED to all DSP_USER's
0x00001CD4 51627 3 CS_DAP_0 TA C: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::eDisconnected )
0x00001CD4 51627 3 CS_DAP_0 TA R: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::eDisconnected )
0x00001CD4 51627 3 IcePick_C POLL C: Firing DSP_PREDISCONNECT to all DSP_USER's
0x00001CD4 51627 3 IcePick_C POLL C: Firing of DSP_PREDISCONNECT complete
0x00001CD4 51627 3 IcePick_C STATE I: Connection state changed to 3
0x00001CD4 51627 3 IcePick_C POLL C: Firing DSP_DISCONNECTING to all DSP_USER's
0x00001CD4 51627 3 IcePick_C TA C: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::ePreDisconnect )
0x00001CD4 51627 3 IcePick_C TA R: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::ePreDisconnect )
0x00001CD4 51627 3  COM_DBG_IF C: class DSP_CO_USER::OnDisconnecting()
0x00001CD4 51627 3  XPCOM C: ( (dsIBooleanEventCallback*)000001BD29E61150 )->onEvent( false )
0x00001CD4 51627 3  XPCOM R: ( (dsIBooleanEventCallback*)000001BD29E61150 )->onEvent( false ) = 0x00000000
0x00001CD4 51627 3  COM_DBG_IF R: class DSP_CO_USER::OnDisconnecting()
0x00001CD4 51627 3  COM_DBG_IF C: class DSP_CO_USER::OnAllowedUserAccessesChanged()
0x00001CD4 51627 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD29E5FF50 )->onEvent()
0x00001CD4 51627 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD29E5FF50 )->onEvent() = 0x00000000
0x00001CD4 51627 3  COM_DBG_IF R: class DSP_CO_USER::OnAllowedUserAccessesChanged()
0x00001CD4 51627 3 IcePick_C POLL C: Firing of DSP_DISCONNECTING complete
0x00001CD4 51627 3 IcePick_C POLL C: Firing DSP_REMOVE_DEBUG_STATE to all DSP_USER's
0x00001CD4 51627 3  COM_DBG_IF C: class CoBreakpointManager::OnBatchUpdateStarted()
0x00001CD4 51627 3  COM_DBG_IF R: class CoBreakpointManager::OnBatchUpdateStarted()
0x00001CD4 51627 3 IcePick_C POLL D: New request of type DSP_RQ_NONE added to polling loop by class DebuggerListeners
0x00001CD4 51627 3  COM_DBG_IF C: class DSP_CO_USER::OnRemoveDebugState()
0x00001CD4 51627 3  COM_DBG_IF R: class DSP_CO_USER::OnRemoveDebugState()
0x00001CD4 51627 3 IcePick_C POLL C: Firing of DSP_REMOVE_DEBUG_STATE complete
0x00001CD4 51627 3  COM_DBG_IF C: class DSP_CO_USER::OnDisconnected()
0x00001CD4 51627 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD29E618D0 )->onEvent()
0x00001CD4 51627 3  XPCOM C: ( (dsIConnectDisconnect*)000001BD29181408 )->connectionStatus( 0000000DAD8FC330 )
0x00001CD4 51627 3  XPCOM R: ( (dsIConnectDisconnect*)000001BD29181408 )->connectionStatus( *0000000DAD8FC330 = 0x00000002 ) = 0x00000000
0x00001CD4 51627 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD29E618D0 )->onEvent() = 0x00000000
0x00001CD4 51627 3  COM_DBG_IF R: class DSP_CO_USER::OnDisconnected()
0x00001CD4 51627 3 CS_DAP_0 POLL C: Firing of DSP_DISCONNECTED complete
0x00001CD4 51627 4 CS_DAP_0 POLL I: Yielding to other threads
0x00001CD4 51627 3 CS_DAP_0 POLL R: Poll() returning
0x00001CD4 51627 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 51627 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 51627 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 51627 3 Cortex_M4_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 51627 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 51627 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 51627 4 IcePick_C POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 51627 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 51627 4  POLL I: Yielding to other threads
0x00001CD4 51627 3 IcePick_C POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 51627 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 51627 3 IcePick_C POLL R: Poll() returning
0x00001CD4 51643 3 CS_DAP_0 GEL I: Evaluating "GEL_EvalOnTarget("<parent>", "DisconnectIfConnected()", 1)"
0x00001CD4 51643 3 CS_DAP_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 51643 3 Cortex_M4_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 51643 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 51643 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 51643 4 IcePick_C POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 51643 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 51643 4  POLL I: Yielding to other threads
0x00001CD4 51643 3 IcePick_C POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 51643 3 IcePick_C POLL C: Firing DSP_REQ_EVENT to class DebuggerListeners
0x00001CD4 51643 3 IcePick_C POLL D: New request of type DSP_RQ_NONE added to polling loop by class DebuggerListeners
0x00001CD4 51643 3 IcePick_C POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 51643 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 51643 3 IcePick_C POLL R: Poll() returning
0x00001CD4 51643 3 CS_DAP_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 51643 4 CS_DAP_0 POLL I: Yielding to other threads
0x00001CD4 51643 3 CS_DAP_0 POLL R: Poll() returning
0x00001CD4 51643 3  COM_DBG_IF C: class CoBreakpointManager::OnBatchUpdateFinished()
0x00001CD4 51643 3  COM_DBG_IF R: class CoBreakpointManager::OnBatchUpdateFinished()
0x00001CD4 51643 3 CS_DAP_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 51643 3 CS_DAP_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 51643 3 CS_DAP_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 51643 3 IcePick_C POLL C: Polling with state CPU_ST_DISCONNECT and status EVENT_DSP_HALT
0x00001CD4 51643 3 IcePick_C GTI C: GTI_DONE_REMOVING_DEBUG_STATE( 0x000001BD29E173E0 )
0x00001CD4 51643 3 IcePick_C GTI R: GTI_DONE_REMOVING_DEBUG_STATE( 0x000001BD29E173E0 ) = 0x00000000
0x00001CD4 51643 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD918 = 0x00000000, *0x0000000DAD8FD910 = 0x00000000, *0x0000000DAD8FD928 = 0x00000000, *0x0000000DAD8FD940 = 0x00000000, *0x0000000DAD8FD948 = 0x00000000, *0x0000000DAD8FD938 = 0x00000000, *0x0000000DAD8FD930 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51643 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD918 = 0x00000000, *0x0000000DAD8FD910 = 0x00000000, *0x0000000DAD8FD928 = 0x00000000, *0x0000000DAD8FD940 = 0x00000002, *0x0000000DAD8FD948 = 0x00000000, *0x0000000DAD8FD938 = 0x00000008, *0x0000000DAD8FD930 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51643 3  PERF I: GTI_DISCONNECT starting...
0x00001CD4 51643 3 IcePick_C GTI C: GTI_DISCONNECT( 0x000001BD29E173E0 )
0x00001CD4 51643 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 51643 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51643 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 51643 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 51643 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 51643 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 51643 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51643 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 51659 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 51659 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 51660 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 51660 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 51660 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 51660 3  XDS110 C: Executing command 0x07 (XDS_CYCLETCLK)
0x00001CD4 51660 3  XDS110 R: Executed command 0x07 (XDS_CYCLETCLK), return code: 0x00000000
0x00001CD4 51660 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 51660 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 51660 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51660 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 51660 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 51660 3  XDS110 C: Executing command 0x0a (XDS_FIXEDSCAN)
0x00001CD4 51660 3  XDS110 R: Executed command 0x0a (XDS_FIXEDSCAN), return code: 0x00000000
0x00001CD4 51676 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 51676 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51676 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 51676 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 51676 3  XDS110 C: Executing command 0x07 (XDS_CYCLETCLK)
0x00001CD4 51676 3  XDS110 R: Executed command 0x07 (XDS_CYCLETCLK), return code: 0x00000000
0x00001CD4 51676 3  XDS110 C: Executing command 0x0a (XDS_FIXEDSCAN)
0x00001CD4 51676 3  XDS110 R: Executed command 0x0a (XDS_FIXEDSCAN), return code: 0x00000000
0x00001CD4 51676 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 51676 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 51691 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 51691 3  XDS110 C: Executing command 0x0a (XDS_FIXEDSCAN)
0x00001CD4 51691 3  XDS110 R: Executed command 0x0a (XDS_FIXEDSCAN), return code: 0x00000000
0x00001CD4 51691 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 51707 3  XDS110 R: Executed command 0x0a (XDS_FIXEDSCAN), return code: 0x00000000
0x00001CD4 51707 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 51707 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 51707 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51707 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 51707 3  XDS110 C: Executing command 0x0a (XDS_FIXEDSCAN)
0x00001CD4 51723 3  XDS110 R: Executed command 0x0a (XDS_FIXEDSCAN), return code: 0x00000000
0x00001CD4 51723 3  XDS110 C: Executing command 0x0a (XDS_FIXEDSCAN)
0x00001CD4 51723 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51723 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 51723 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 51723 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 51738 3  XDS110 R: Executed command 0x0a (XDS_FIXEDSCAN), return code: 0x00000000
0x00001CD4 51738 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 51738 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 51738 3  XDS110 C: Executing command 0x0a (XDS_FIXEDSCAN)
0x00001CD4 51738 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51738 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 51754 3  XDS110 R: Executed command 0x0a (XDS_FIXEDSCAN), return code: 0x00000000
0x00001CD4 51754 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 51754 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 51754 3  XDS110 C: Executing command 0x0a (XDS_FIXEDSCAN)
0x00001CD4 51754 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 51754 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 51769 3  XDS110 R: Executed command 0x0a (XDS_FIXEDSCAN), return code: 0x00000000
0x00001CD4 51769 3  XDS110 C: Executing command 0x1a (SWD_DISABLESWO)
0x00001CD4 51864 3  XDS110 R: Executed command 0x1a (SWD_DISABLESWO), return code: 0x00000000
0x00001CD4 51864 3  XDS110 C: Executing command 0x2c (CJTAG_DISCONNECT)
0x00001CD4 51864 3  XDS110 R: Executed command 0x2c (CJTAG_DISCONNECT), return code: 0x00000000
0x00001CD4 51864 3  XDS110 C: Executing command 0x02 (XDS_DISCONNECT)
0x00001CD4 51975 3  XDS110 R: Executed command 0x02 (XDS_DISCONNECT), return code: 0x00000000
0x00001CD4 51975 3 IcePick_C GTI R: GTI_DISCONNECT( 0x000001BD29E173E0 ) = 0x00000000
0x00001CD4 51975 3  PERF I: GTI_DISCONNECT finished:  0.339729s wall, 0.000000s user + 0.015625s system = 0.015625s CPU (4.6%)
0x00001CD4 51975 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD9D8 = 0x00000000, *0x0000000DAD8FD9D0 = 0x00000000, *0x0000000DAD8FD9E8 = 0x00000000, *0x0000000DAD8FDA00 = 0x00000000, *0x0000000DAD8FDA08 = 0x00000000, *0x0000000DAD8FD9F8 = 0x00000000, *0x0000000DAD8FD9F0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 51975 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD9D8 = 0x00000000, *0x0000000DAD8FD9D0 = 0x00000000, *0x0000000DAD8FD9E8 = 0x00000000, *0x0000000DAD8FDA00 = 0x00000002, *0x0000000DAD8FDA08 = 0x00000000, *0x0000000DAD8FD9F8 = 0x00000008, *0x0000000DAD8FD9F0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 51975 3 IcePick_C GTI C: GTI_STAT( 0x000001BD29E173E0 )
0x00001CD4 51975 3 IcePick_C GTI R: GTI_STAT( 0x000001BD29E173E0 ) = 0x0000000B
0x00001CD4 51975 3 IcePick_C STATE I: Target execution state changed to STATUS_RUNNING
0x00001CD4 51975 3 IcePick_C STATE I: Connection state changed to 2
0x00001CD4 51975 3 IcePick_C POLL C: Firing DSP_DISCONNECTED to all DSP_USER's
0x00001CD4 51975 3 IcePick_C TA C: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::eDisconnected )
0x00001CD4 51975 3 IcePick_C TA R: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::eDisconnected )
0x00001CD4 51975 3  COM_DBG_IF C: class DSP_CO_USER::OnDisconnected()
0x00001CD4 51975 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD29E5FE50 )->onEvent()
0x00001CD4 51975 3  XPCOM C: ( (dsIConnectDisconnect*)000001BD29180F88 )->connectionStatus( 0000000DAD8FC330 )
0x00001CD4 51975 3  XPCOM R: ( (dsIConnectDisconnect*)000001BD29180F88 )->connectionStatus( *0000000DAD8FC330 = 0x00000002 ) = 0x00000000
0x00001CD4 51975 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD29E5FE50 )->onEvent() = 0x00000000
0x00001CD4 51975 3  COM_DBG_IF R: class DSP_CO_USER::OnDisconnected()
0x00001CD4 51975 3 IcePick_C POLL C: Firing of DSP_DISCONNECTED complete
0x00001CD4 51975 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 51975 3 IcePick_C POLL R: Poll() returning
0x00001CD4 51975 3 CS_DAP_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 51975 3 CS_DAP_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 51975 3 IcePick_C GEL I: Evaluating "DisconnectIfConnected()"
0x00001CD4 51975 3 IcePick_C POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 51975 3 CS_DAP_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 51975 4 CS_DAP_0 POLL I: Yielding to other threads
0x00001CD4 51975 3 CS_DAP_0 POLL R: Poll() returning
0x00001CD4 51975 4 IcePick_C POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 51975 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 51975 4  POLL I: Yielding to other threads
0x00001CD4 51975 3 IcePick_C POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 51975 3 IcePick_C POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 51975 3 IcePick_C POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 51975 2 IcePick_C GEL I: cc26xx_connect_util.gel:47	Enter function DisconnectIfConnected
0x00001CD4 51975 3 IcePick_C POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 51975 2 IcePick_C GEL I: cc26xx_connect_util.gel:48	Leave function DisconnectIfConnected
0x00001CD4 51975 3 IcePick_C GEL I: Evaluation of "DisconnectIfConnected()" completed - Value: 0 Location: unknown
0x00001CD4 51975 3 CS_DAP_0 GEL I: Evaluation of "GEL_EvalOnTarget("<parent>", "DisconnectIfConnected()", 1)" completed - Value: 0 Location: unknown
0x00001CD4 51975 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 51975 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:93	      GEL_AdvancedReset("Board Reset")
0x00001CD4 51975 3 Cortex_M4_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 51975 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 51975 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 51975 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 51975 4  POLL I: TimeToSleep() found shorter sleep time of 500 ms from class DevicePollFrequencyManager
0x00001CD4 51975 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 169 ms
0x00001CD4 51975 4  POLL I: TimeToSleep() found shorter sleep time of 169 ms from class DevicePollFrequencyManager
0x00001CD4 51975 4 Cortex_M4_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 51975 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 51975 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 51975 3 Cortex_M4_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 51975 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_ISSUE_RESET added to polling loop by unknown
0x00001CD4 51975 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_PRE_RESET and status EVENT_DSP_HALT
0x00001CD4 51975 3 Cortex_M4_0 GTI C: GTI_RESET_EX( 0x000001BD362E2770, 0x00000002 )
0x00001CD4 51990 3  XDS110 C: Executing command 0x01 (XDS_CONNECT)
0x00001CD4 52100 3  XDS110 R: Executed command 0x01 (XDS_CONNECT), return code: 0x00000000
0x00001CD4 52100 3  XDS110 C: Executing command 0x03 (XDS_VERSION)
0x00001CD4 52100 3  XDS110 R: Executed command 0x03 (XDS_VERSION), return code: 0x00000000
0x00001CD4 52100 3  XDS110 C: Executing command 0x04 (XDS_SETTCLKDELAY)
0x00001CD4 52100 3  XDS110 R: Executed command 0x04 (XDS_SETTCLKDELAY), return code: 0x00000000
0x00001CD4 52100 3  XDS110 C: Executing command 0x06 (XDS_GETTRST)
0x00001CD4 52100 3  XDS110 R: Executed command 0x06 (XDS_GETTRST), return code: 0x00000000
0x00001CD4 52100 3  XDS110 C: Executing command 0x05 (XDS_SETTRST)
0x00001CD4 52100 3  XDS110 R: Executed command 0x05 (XDS_SETTRST), return code: 0x00000000
0x00001CD4 52100 3  XDS110 C: Executing command 0x07 (XDS_CYCLETCLK)
0x00001CD4 52100 3  XDS110 R: Executed command 0x07 (XDS_CYCLETCLK), return code: 0x00000000
0x00001CD4 52146 3  XDS110 R: Executed command 0x07 (XDS_CYCLETCLK), return code: 0x00000000
0x00001CD4 52146 3  XDS110 C: Executing command 0x2b (CJTAG_CONNECT)
0x00001CD4 52146 3  XDS110 R: Executed command 0x2b (CJTAG_CONNECT), return code: 0x00000000
0x00001CD4 52146 3  XDS110 C: Executing command 0x19 (SWD_ENABLESWO)
0x00001CD4 52256 3  XDS110 R: Executed command 0x19 (SWD_ENABLESWO), return code: 0x00000000
0x00001CD4 52256 3  XDS110 C: Executing command 0x07 (XDS_CYCLETCLK)
0x00001CD4 52303 3  XDS110 R: Executed command 0x07 (XDS_CYCLETCLK), return code: 0x00000000
0x00001CD4 52303 3  XDS110 C: Executing command 0x0e (XDS_SETSRST)
0x00001CD4 52303 3  XDS110 R: Executed command 0x0e (XDS_SETSRST), return code: 0x00000000
0x00001CD4 52303 3  XDS110 C: Executing command 0x07 (XDS_CYCLETCLK)
0x00001CD4 52367 3  XDS110 R: Executed command 0x07 (XDS_CYCLETCLK), return code: 0x00000000
0x00001CD4 52367 3  XDS110 C: Executing command 0x0e (XDS_SETSRST)
0x00001CD4 52367 3  XDS110 R: Executed command 0x0e (XDS_SETSRST), return code: 0x00000000
0x00001CD4 52367 3  XDS110 C: Executing command 0x07 (XDS_CYCLETCLK)
0x00001CD4 52477 3  XDS110 R: Executed command 0x07 (XDS_CYCLETCLK), return code: 0x00000000
0x00001CD4 52477 3  XDS110 C: Executing command 0x1a (SWD_DISABLESWO)
0x00001CD4 52570 3  XDS110 R: Executed command 0x1a (SWD_DISABLESWO), return code: 0x00000000
0x00001CD4 52570 3  XDS110 C: Executing command 0x2c (CJTAG_DISCONNECT)
0x00001CD4 52586 3  XDS110 R: Executed command 0x2c (CJTAG_DISCONNECT), return code: 0x00000000
0x00001CD4 52586 3  XDS110 C: Executing command 0x02 (XDS_DISCONNECT)
0x00001CD4 52681 3  XDS110 R: Executed command 0x02 (XDS_DISCONNECT), return code: 0x00000000
0x00001CD4 52681 3 Cortex_M4_0 GTI R: GTI_RESET_EX( 0x000001BD362E2770, 0x00000002 ) = 0x00000000
0x00001CD4 52681 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD918 = 0x00000000, *0x0000000DAD8FD910 = 0x00000000, *0x0000000DAD8FD928 = 0x00000000, *0x0000000DAD8FD940 = 0x00000000, *0x0000000DAD8FD948 = 0x00000000, *0x0000000DAD8FD938 = 0x00000000, *0x0000000DAD8FD930 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 52681 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD918 = 0x00000000, *0x0000000DAD8FD910 = 0x00000000, *0x0000000DAD8FD928 = 0x00000000, *0x0000000DAD8FD940 = 0x00000002, *0x0000000DAD8FD948 = 0x00000000, *0x0000000DAD8FD938 = 0x00000008, *0x0000000DAD8FD930 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 52681 3 Cortex_M4_0 STATE I: Debugger execution state changed to EVENT_DSP_HALT
0x00001CD4 52681 3 Cortex_M4_0 POLL C: Firing DSP_PRIORITY_RESET_DONE to all DSP_USER's
0x00001CD4 52681 3 Cortex_M4_0 POLL C: Firing of DSP_PRIORITY_RESET_DONE complete
0x00001CD4 52681 3 Cortex_M4_0 POLL C: Firing DSP_RESET_DONE to all DSP_USER's
0x00001CD4 52681 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 52681 2 Cortex_M4_0 GEL I: cc26x2_xds.gel:96	      ConnectStateRestore()
0x00001CD4 52681 3 Cortex_M4_0 POLL C: Firing of DSP_RESET_DONE complete
0x00001CD4 52681 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 52681 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 52681 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 52681 4  POLL I: TimeToSleep() found shorter sleep time of 500 ms from class DevicePollFrequencyManager
0x00001CD4 52681 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 169 ms
0x00001CD4 52681 4  POLL I: TimeToSleep() found shorter sleep time of 169 ms from class DevicePollFrequencyManager
0x00001CD4 52681 4 Cortex_M4_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 52681 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 52681 4  POLL I: Yielding to other threads
0x00001CD4 52681 3 Cortex_M4_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 52681 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 0 ms
0x00001CD4 52681 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 52681 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 52681 2 Cortex_M4_0 GEL I: cc26xx_connect_util.gel:18	      Enter function ConnectStateRestore
0x00001CD4 52681 3 Cortex_M4_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 52681 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=35 AND Name='_prevState'
0x00001CD4 52681 2 Cortex_M4_0 GEL I: cc26xx_connect_util.gel:27	         ConnectIfDisconnected()
0x00001CD4 52681 2 Cortex_M4_0 GEL I: cc26xx_connect_util.gel:38	         Enter function ConnectIfDisconnected
0x00001CD4 52681 2 Cortex_M4_0 GEL I: cc26xx_connect_util.gel:41	            GEL_Connect()
0x00001CD4 52681 3 Cortex_M4_0 POLL C: Firing DSP_PRECONNECT to all DSP_USER's
0x00001CD4 52681 3 CS_DAP_0 POLL C: Firing DSP_PRECONNECT to all DSP_USER's
0x00001CD4 52681 3 IcePick_C POLL C: Firing DSP_PRECONNECT to all DSP_USER's
0x00001CD4 52681 3 IcePick_C POLL C: Firing of DSP_PRECONNECT complete
0x00001CD4 52681 3  SEQUENCE I: Finished sequence step at 0000000DAD8FCD50
0x00001CD4 52681 3  SEQUENCE I: Beginning class Debugger::GelCallbackStep at 000001BD3538A9B0
0x00001CD4 52681 3 IcePick_C GEL I: Evaluating "OnPreTargetConnect()"
0x00001CD4 52681 3 IcePick_C POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 52681 3 CS_DAP_0 POLL C: Firing of DSP_PRECONNECT complete
0x00001CD4 52681 3 Cortex_M4_0 POLL C: Firing of DSP_PRECONNECT complete
0x00001CD4 52681 4 IcePick_C POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 52681 3 IcePick_C POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 52681 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 52681 3 IcePick_C POLL R: Poll() returning
0x00001CD4 52681 3 IcePick_C POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 52681 3 IcePick_C POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 52681 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=33 AND Name='OnPreTargetConnect()'
0x00001CD4 52681 3 IcePick_C GEL I: Evaluation of "OnPreTargetConnect()" failed: identifier not found: OnPreTargetConnect()
0x00001CD4 52681 3  SEQUENCE I: Finished sequence step at 000001BD3538A9B0
0x00001CD4 52681 3  SEQUENCE I: Beginning class Debugger::LambdaSequenceStep<class <lambda_d5c2eaa1b9c646e74fc865fbf49efb9b> > at 000001BD2E7EECB0
0x00001CD4 52681 3  SEQUENCE I: Finished sequence step at 000001BD2E7EECB0
0x00001CD4 52681 3 IcePick_C POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 52681 3 IcePick_C POLL C: Polling with state CPU_ST_CONNECT and status EVENT_DSP_HALT
0x00001CD4 52681 3  PERF I: GTI_CONNECT starting...
0x00001CD4 52681 3 IcePick_C GTI C: GTI_CONNECT3( 0x000001BD29E173E0, 0 )
0x00001CD4 52696 3  XDS110 C: Executing command 0x01 (XDS_CONNECT)
0x00001CD4 52807 3  XDS110 R: Executed command 0x01 (XDS_CONNECT), return code: 0x00000000
0x00001CD4 52807 3  XDS110 C: Executing command 0x03 (XDS_VERSION)
0x00001CD4 52807 3  XDS110 R: Executed command 0x03 (XDS_VERSION), return code: 0x00000000
0x00001CD4 52807 3  XDS110 C: Executing command 0x04 (XDS_SETTCLKDELAY)
0x00001CD4 52807 3  XDS110 R: Executed command 0x04 (XDS_SETTCLKDELAY), return code: 0x00000000
0x00001CD4 52807 3  XDS110 C: Executing command 0x06 (XDS_GETTRST)
0x00001CD4 52807 3  XDS110 R: Executed command 0x06 (XDS_GETTRST), return code: 0x00000000
0x00001CD4 52807 3  XDS110 C: Executing command 0x05 (XDS_SETTRST)
0x00001CD4 52807 3  XDS110 R: Executed command 0x05 (XDS_SETTRST), return code: 0x00000000
0x00001CD4 52807 3  XDS110 C: Executing command 0x07 (XDS_CYCLETCLK)
0x00001CD4 52807 3  XDS110 R: Executed command 0x07 (XDS_CYCLETCLK), return code: 0x00000000
0x00001CD4 52854 3  XDS110 R: Executed command 0x07 (XDS_CYCLETCLK), return code: 0x00000000
0x00001CD4 52854 3  XDS110 C: Executing command 0x2b (CJTAG_CONNECT)
0x00001CD4 52854 3  XDS110 R: Executed command 0x2b (CJTAG_CONNECT), return code: 0x00000000
0x00001CD4 52854 3  XDS110 C: Executing command 0x19 (SWD_ENABLESWO)
0x00001CD4 52963 3  XDS110 R: Executed command 0x19 (SWD_ENABLESWO), return code: 0x00000000
0x00001CD4 52963 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 52963 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 52963 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 52963 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 52963 3  XDS110 C: Executing command 0x07 (XDS_CYCLETCLK)
0x00001CD4 52963 3  XDS110 R: Executed command 0x07 (XDS_CYCLETCLK), return code: 0x00000000
0x00001CD4 52963 3  XDS110 C: Executing command 0x0a (XDS_FIXEDSCAN)
0x00001CD4 52979 3  XDS110 R: Executed command 0x0a (XDS_FIXEDSCAN), return code: 0x00000000
0x00001CD4 52979 3  XDS110 C: Executing command 0x2d (XDS_SELECTTAP)
0x00001CD4 52979 3  XDS110 R: Executed command 0x2d (XDS_SELECTTAP), return code: 0x00000000
0x00001CD4 52979 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 52979 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 52979 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 52979 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 52979 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 52979 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 52994 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 52994 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 52994 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 52994 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 52994 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 52994 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53010 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53010 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53010 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53010 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53026 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53026 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53026 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53026 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53041 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53041 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53041 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53041 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53057 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53057 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53057 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53057 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53063 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53063 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53063 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53063 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53066 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53066 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53066 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53066 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53082 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53082 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53082 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53082 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53082 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 53082 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 53082 3 IcePick_C GTI R: GTI_CONNECT3( 0x000001BD29E173E0, 0 ) = 0x00000000
0x00001CD4 53082 3  PERF I: GTI_CONNECT finished:  0.395884s wall, 0.031250s user + 0.000000s system = 0.031250s CPU (7.9%)
0x00001CD4 53082 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD878 = 0x00000000, *0x0000000DAD8FD870 = 0x00000000, *0x0000000DAD8FD888 = 0x00000000, *0x0000000DAD8FD8A0 = 0x00000000, *0x0000000DAD8FD8A8 = 0x00000000, *0x0000000DAD8FD898 = 0x00000000, *0x0000000DAD8FD890 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53082 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD878 = 0x00000000, *0x0000000DAD8FD870 = 0x00000000, *0x0000000DAD8FD888 = 0x00000000, *0x0000000DAD8FD8A0 = 0x00000002, *0x0000000DAD8FD8A8 = 0x00000000, *0x0000000DAD8FD898 = 0x00000008, *0x0000000DAD8FD890 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53082 3 IcePick_C STATE I: Connection state changed to 4
0x00001CD4 53082 3 IcePick_C GTI C: GTI_STAT( 0x000001BD29E173E0 )
0x00001CD4 53098 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53098 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53098 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53098 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53114 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53114 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53114 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53114 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53131 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53131 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53131 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53131 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53147 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53147 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53147 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53147 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53162 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53162 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53162 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53162 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53178 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53178 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53178 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53178 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53194 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53194 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53194 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53194 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53194 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 53194 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 53194 3 IcePick_C GTI R: GTI_STAT( 0x000001BD29E173E0 ) = 0x0000000E
0x00001CD4 53194 3 IcePick_C STATE I: Target execution state changed to STATUS_NON_DEBUG_CHANGE
0x00001CD4 53194 3 IcePick_C STATE I: Debugger execution state changed to EVENT_DSP_HALT
0x00001CD4 53194 3 IcePick_C STATE I: Connection state changed to 0
0x00001CD4 53194 3  PERF I: GEL OnTargetConnect() starting...
0x00001CD4 53194 3  SEQUENCE I: Finished sequence step at 0000000DAD8FDE20
0x00001CD4 53194 3  SEQUENCE I: Beginning class Debugger::GelCallbackStep at 000001BD2B4CAA60
0x00001CD4 53194 3 IcePick_C GEL I: Evaluating "OnTargetConnect()"
0x00001CD4 53194 3 IcePick_C POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 53194 3 IcePick_C POLL C: Firing DSP_PRIORITY_CONNECTED to all DSP_USER's
0x00001CD4 53194 3 IcePick_C POLL C: Firing of DSP_PRIORITY_CONNECTED complete
0x00001CD4 53194 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 53194 3 IcePick_C POLL R: Poll() returning
0x00001CD4 53194 4 IcePick_C POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 53194 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 53194 4  POLL I: Yielding to other threads
0x00001CD4 53194 3 IcePick_C POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 53194 3 IcePick_C POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 53194 3 IcePick_C POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 53194 2 IcePick_C GEL I: cc26xx_icepick.gel:14	Enter function OnTargetConnect
0x00001CD4 53194 3 IcePick_C POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 53194 2 IcePick_C GEL I: cc26xx_icepick.gel:16	   IP_CC26xx_WAKEUPMCU=1
0x00001CD4 53194 3 IcePick_C GTI C: GTI_GET_TARGET_PROPERTIES( 0x000001BD29E173E0, 0x00000001 )
0x00001CD4 53194 3 IcePick_C GTI R: GTI_GET_TARGET_PROPERTIES( 0x000001BD29E173E0, 0x00000001 ) = 0x00000001
0x00001CD4 53194 3 IcePick_C POLL D: New request of type DSP_RQ_WRITE_MEM added to polling loop by class VOT::DspAccessorSetRegister
0x00001CD4 53194 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775763 AND Register_Cache.Address<=-9223372036854775763 AND Register_Cache.Page=121 AND Register_Cache.Processor=33
0x00001CD4 53194 3 IcePick_C POLL C: Polling with state STATE_WRITE and status EVENT_DSP_HALT
0x00001CD4 53194 3 IcePick_C GTI C: GTI_WRITEREG( 0x000001BD29E173E0, 0x0000002D, *0x0000000DAD8FDD70 = 0x00000001 )
0x00001CD4 53209 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 53209 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53209 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53209 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53209 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53209 3  XDS110 C: Executing command 0x08 (XDS_GETJTAGSTATE)
0x00001CD4 53209 3  XDS110 R: Executed command 0x08 (XDS_GETJTAGSTATE), return code: 0x00000000
0x00001CD4 53209 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 53209 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 53225 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 53225 3  XDS110 C: Executing command 0x08 (XDS_GETJTAGSTATE)
0x00001CD4 53225 3  XDS110 R: Executed command 0x08 (XDS_GETJTAGSTATE), return code: 0x00000000
0x00001CD4 53225 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 53225 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53225 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53240 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53240 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53240 3  XDS110 C: Executing command 0x08 (XDS_GETJTAGSTATE)
0x00001CD4 53240 3  XDS110 R: Executed command 0x08 (XDS_GETJTAGSTATE), return code: 0x00000000
0x00001CD4 53240 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 53240 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 53256 3  XDS110 R: Executed command 0x08 (XDS_GETJTAGSTATE), return code: 0x00000000
0x00001CD4 53256 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 53256 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 53256 3  XDS110 C: Executing command 0x08 (XDS_GETJTAGSTATE)
0x00001CD4 53256 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53256 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53256 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53272 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53272 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53272 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53272 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53272 3  XDS110 C: Executing command 0x08 (XDS_GETJTAGSTATE)
0x00001CD4 53272 3  XDS110 R: Executed command 0x08 (XDS_GETJTAGSTATE), return code: 0x00000000
0x00001CD4 53272 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 53272 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 53287 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 53287 3  XDS110 C: Executing command 0x08 (XDS_GETJTAGSTATE)
0x00001CD4 53287 3  XDS110 R: Executed command 0x08 (XDS_GETJTAGSTATE), return code: 0x00000000
0x00001CD4 53287 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 53287 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53303 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53303 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53303 3  XDS110 C: Executing command 0x08 (XDS_GETJTAGSTATE)
0x00001CD4 53303 3  XDS110 R: Executed command 0x08 (XDS_GETJTAGSTATE), return code: 0x00000000
0x00001CD4 53303 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 53303 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 53319 3  XDS110 R: Executed command 0x09 (XDS_GOTOJTAGSTATE), return code: 0x00000000
0x00001CD4 53319 3  XDS110 C: Executing command 0x08 (XDS_GETJTAGSTATE)
0x00001CD4 53319 3  XDS110 R: Executed command 0x08 (XDS_GETJTAGSTATE), return code: 0x00000000
0x00001CD4 53319 3  XDS110 C: Executing command 0x09 (XDS_GOTOJTAGSTATE)
0x00001CD4 53319 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53319 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53319 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 53335 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 53335 3 IcePick_C GTI R: GTI_WRITEREG( 0x000001BD29E173E0, 0x0000002D, *0x0000000DAD8FDD70 = 0x00000001 ) = 0x00000000
0x00001CD4 53335 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD668 = 0x00000000, *0x0000000DAD8FD660 = 0x00000000, *0x0000000DAD8FD678 = 0x00000000, *0x0000000DAD8FD690 = 0x00000000, *0x0000000DAD8FD698 = 0x00000000, *0x0000000DAD8FD688 = 0x00000000, *0x0000000DAD8FD680 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53335 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD668 = 0x00000000, *0x0000000DAD8FD660 = 0x00000000, *0x0000000DAD8FD678 = 0x00000000, *0x0000000DAD8FD690 = 0x00000002, *0x0000000DAD8FD698 = 0x00000000, *0x0000000DAD8FD688 = 0x00000008, *0x0000000DAD8FD680 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53335 3 IcePick_C POLL C: Firing DSP_MEM_EVENT to all DSP_USER's
0x00001CD4 53335 3 IcePick_C POLL C: Firing of DSP_MEM_EVENT complete
0x00001CD4 53335 3 IcePick_C POLL C: Firing DSP_TARGET_ACCESSED to all DSP_USER's
0x00001CD4 53335 3 IcePick_C POLL C: Firing of DSP_TARGET_ACCESSED complete
0x00001CD4 53335 3 IcePick_C POLL C: Firing DSP_REQ_EVENT to class VOT::DspAccessorSetRegister
0x00001CD4 53335 2 IcePick_C GEL I: cc26xx_icepick.gel:16	Leave function OnTargetConnect
0x00001CD4 53335 3 IcePick_C GEL I: Evaluation of "OnTargetConnect()" completed - Value: 0 Location: unknown
0x00001CD4 53335 3  SEQUENCE I: Finished sequence step at 000001BD2B4CAA60
0x00001CD4 53335 3  SEQUENCE I: Beginning class Debugger::LambdaSequenceStep<class <lambda_bb017b12012eedddadf10144bef98de7> > at 000001BD2E7F2B30
0x00001CD4 53335 3  PERF I: GEL OnTargetConnect() finished:  0.128491s wall, 0.015625s user + 0.015625s system = 0.031250s CPU (24.3%)
0x00001CD4 53335 3  SEQUENCE I: Finished sequence step at 000001BD2E7F2B30
0x00001CD4 53335 3  SEQUENCE I: Beginning class `anonymous namespace'::WaitForValidState at 000001BD303A54F0
0x00001CD4 53335 3  SEQUENCE I: Finished sequence step at 000001BD303A54F0
0x00001CD4 53335 3  SEQUENCE I: Beginning class `anonymous namespace'::CallGelResetStep at 000001BD2B8C0B10
0x00001CD4 53335 3  SEQUENCE I: Finished sequence step at 000001BD2B8C0B10
0x00001CD4 53335 3  SEQUENCE I: Beginning class Debugger::PriorityEventStep at 000001BD2E7F2A10
0x00001CD4 53335 3  SEQUENCE I: Finished sequence step at 000001BD2E7F2A10
0x00001CD4 53335 3 IcePick_C POLL C: Firing DSP_TARGET_WRITE to all DSP_USER's
0x00001CD4 53335 3  COM_DBG_IF C: class DSP_CO_USER::OnRefresh()
0x00001CD4 53335 3  XPCOM C: ( (dsINumberEventCallback*)000001BD29E60350 )->onEvent( 0x000000000000000A )
0x00001CD4 53335 3  XPCOM R: ( (dsINumberEventCallback*)000001BD29E60350 )->onEvent( 0x000000000000000A ) = 0x00000000
0x00001CD4 53335 3  COM_DBG_IF R: class DSP_CO_USER::OnRefresh()
0x00001CD4 53335 3 IcePick_C POLL C: Firing of DSP_TARGET_WRITE complete
0x00001CD4 53335 3 IcePick_C POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 53335 3 IcePick_C POLL C: Firing DSP_CONNECTED to all DSP_USER's
0x00001CD4 53335 3 IcePick_C TA C: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::eConnected )
0x00001CD4 53335 3 IcePick_C TA R: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::eConnected )
0x00001CD4 53335 3 CS_DAP_0 POLL C: Firing DSP_PRECONNECT to all DSP_USER's
0x00001CD4 53335 3 CS_DAP_0 POLL C: Firing of DSP_PRECONNECT complete
0x00001CD4 53335 3  SEQUENCE I: Finished sequence step at 0000000DAD8FD960
0x00001CD4 53335 3  SEQUENCE I: Beginning class Debugger::GelCallbackStep at 000001BD2B4CA6A0
0x00001CD4 53335 3 CS_DAP_0 GEL I: Evaluating "OnPreTargetConnect()"
0x00001CD4 53335 3 CS_DAP_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 53335 3  COM_DBG_IF C: class DSP_CO_USER::OnConnected()
0x00001CD4 53335 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD29E5FDD0 )->onEvent()
0x00001CD4 53335 3  XPCOM C: ( (dsIConnectDisconnect*)000001BD29180F88 )->connectionStatus( 0000000DAD8FC4A0 )
0x00001CD4 53335 3  XPCOM R: ( (dsIConnectDisconnect*)000001BD29180F88 )->connectionStatus( *0000000DAD8FC4A0 = 0x00000000 ) = 0x00000000
0x00001CD4 53335 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD29E5FDD0 )->onEvent() = 0x00000000
0x00001CD4 53335 3  COM_DBG_IF R: class DSP_CO_USER::OnConnected()
0x00001CD4 53335 3  XPCOM C: ( (dsINumberEventCallback*)000001BD29E60350 )->onEvent( 0x0000000000000003 )
0x00001CD4 53335 3  XPCOM R: ( (dsINumberEventCallback*)000001BD29E60350 )->onEvent( 0x0000000000000003 ) = 0x00000000
0x00001CD4 53335 3  COM_DBG_IF C: class DSP_CO_USER::OnAllowedUserAccessesChanged()
0x00001CD4 53335 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD29E5FF50 )->onEvent()
0x00001CD4 53335 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD29E5FF50 )->onEvent() = 0x00000000
0x00001CD4 53335 3  COM_DBG_IF R: class DSP_CO_USER::OnAllowedUserAccessesChanged()
0x00001CD4 53335 3 IcePick_C POLL C: Firing of DSP_CONNECTED complete
0x00001CD4 53335 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 53335 3 IcePick_C POLL R: Poll() returning
0x00001CD4 53335 3 CS_DAP_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 53335 4 CS_DAP_0 POLL I: Yielding to other threads
0x00001CD4 53335 3 CS_DAP_0 POLL R: Poll() returning
0x00001CD4 53335 4 IcePick_C POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 53335 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 53335 4  POLL I: Yielding to other threads
0x00001CD4 53335 3 IcePick_C POLL C: Polling with state STATE_IDLE_STATUS_CHECK and status EVENT_DSP_HALT
0x00003E54 53335 3  XPCOM C: ( (dsIDebugProperties*)000001BD2C543570 )->getProperty( EnableInstalledBreakpoint, 0000000DAA8FE6F8 )
0x00001CD4 53335 3 IcePick_C GTI C: GTI_STAT( 0x000001BD29E173E0 )
0x00003E54 53335 3  XPCOM R: ( (dsIDebugProperties*)000001BD2C543570 )->getProperty( EnableInstalledBreakpoint, *0000000DAA8FE6F8 = 000001BD35FC60D0 ) = 0x00000000
0x00001CD4 53335 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00003E54 53335 3  XPCOM C: ( (dsIProperty*)000001BD35FC60D0 )->getPropertyType( 0000000DAA8FE690 )
0x00003E54 53335 3  XPCOM R: ( (dsIProperty*)000001BD35FC60D0 )->getPropertyType( *0000000DAA8FE690 = 0x00000000 ) = 0x00000000
0x00003E54 53335 3  XPCOM C: ( (dsIProperty*)000001BD35FC60D0 )->queryInterface( 000001BD2EFB54D0, 0000000DAA8FE688 )
0x00003E54 53335 3  XPCOM R: ( (dsIProperty*)000001BD35FC60D0 )->queryInterface( 000001BD2EFB54D0, *0000000DAA8FE688 = 000001BD35FC6170 ) = 0x00000000
0x00003E54 53335 3  XPCOM C: ( (dsIBooleanProperty*)000001BD35FC6170 )->queryInterface( 000001BD2EFB5190, 0000000DAA8FE628 )
0x00003E54 53335 3  XPCOM R: ( (dsIBooleanProperty*)000001BD35FC6170 )->queryInterface( 000001BD2EFB5190, *0000000DAA8FE628 = 000001BD35FC6170 ) = 0x00000000
0x00003E54 53335 3  XPCOM C: ( (dsIBooleanProperty*)000001BD35FC6170 )->CurValue( 0000000DAA8FE6F0 )
0x00003E54 53335 3  XPCOM R: ( (dsIBooleanProperty*)000001BD35FC6170 )->CurValue( *0000000DAA8FE6F0 = false ) = 0x00000000
0x00001CD4 53335 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53335 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53335 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53335 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53351 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53351 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53351 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53351 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53367 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53367 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53367 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53367 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53383 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53383 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53383 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53383 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53398 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53398 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53398 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53398 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53414 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53414 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53414 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53414 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53429 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53429 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53429 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53429 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53445 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53445 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53445 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53445 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53461 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53461 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53461 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53461 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53461 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 53461 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 53461 3 IcePick_C GTI R: GTI_STAT( 0x000001BD29E173E0 ) = 0x0000000E
0x00001CD4 53461 3 IcePick_C STATE I: Target execution state changed to STATUS_NON_DEBUG_CHANGE
0x00001CD4 53461 3 IcePick_C STATE I: Debugger execution state changed to EVENT_DSP_HALT
0x00001CD4 53461 3 IcePick_C POLL C: Firing DSP_NON_DEBUG_CHANGE to all DSP_USER's
0x00001CD4 53461 3  COM_DBG_IF C: class DSP_CO_USER::OnRefresh()
0x00001CD4 53461 3  XPCOM C: ( (dsINumberEventCallback*)000001BD29E60350 )->onEvent( 0x0000000000000008 )
0x00001CD4 53461 3  XPCOM R: ( (dsINumberEventCallback*)000001BD29E60350 )->onEvent( 0x0000000000000008 ) = 0x00000000
0x00001CD4 53461 3  COM_DBG_IF R: class DSP_CO_USER::OnRefresh()
0x00001CD4 53461 3 IcePick_C POLL C: Firing of DSP_NON_DEBUG_CHANGE complete
0x00001CD4 53461 4 IcePick_C POLL I: Yielding to other threads
0x00001CD4 53461 3 IcePick_C POLL R: Poll() returning
0x00001CD4 53461 3 CS_DAP_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 53461 3 CS_DAP_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 53461 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=34 AND Name='OnPreTargetConnect()'
0x00001CD4 53461 3 CS_DAP_0 GEL I: Evaluation of "OnPreTargetConnect()" failed: identifier not found: OnPreTargetConnect()
0x00001CD4 53461 3  SEQUENCE I: Finished sequence step at 000001BD2B4CA6A0
0x00001CD4 53461 3  SEQUENCE I: Beginning class Debugger::LambdaSequenceStep<class <lambda_d5c2eaa1b9c646e74fc865fbf49efb9b> > at 000001BD2E7F2850
0x00001CD4 53461 3  SEQUENCE I: Finished sequence step at 000001BD2E7F2850
0x00001CD4 53461 3 CS_DAP_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 53461 4 CS_DAP_0 POLL I: Yielding to other threads
0x00001CD4 53461 3 CS_DAP_0 POLL R: Poll() returning
0x00001CD4 53461 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 53461 4  POLL I: TimeToSleep() found shorter sleep time of 500 ms from class DevicePollFrequencyManager
0x00001CD4 53461 4 CS_DAP_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 53461 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 53461 4  POLL I: Yielding to other threads
0x00001CD4 53461 3 CS_DAP_0 POLL C: Polling with state CPU_ST_CONNECT and status EVENT_DSP_HALT
0x00001CD4 53461 3  PERF I: GTI_CONNECT starting...
0x00001CD4 53461 3 CS_DAP_0 GTI C: GTI_CONNECT3( 0x000001BD29E1AA40, 0 )
0x00001CD4 53461 3  PRSC C: PRSC_Connect: prscHandle=0x1bd29e1b120,
0x00001CD4 53461 3  PRSC C: GRTR:SubConnect: routerHandle =0x1bd2b9beca0subPathHandle=0x1bd3d1fe4e0 , numConnections=0x0
0x00001CD4 53461 3  PRSC R: GRTR:SUBConnect: rtn=0x0
0x00001CD4 53461 3  PRSC C: GRTR:SubDisConnect: routerHandle =0x1bd2b9beca0subPathHandle=0x1bd3d1fe4e0,numConnections=0x1
0x00001CD4 53461 3  PRSC R: GRTR:SUBDisConnect: rtn=0x0
0x00001CD4 53461 3  PRSC R: PRSC_Connect: error =0x0
0x00001CD4 53461 3  CMAPI C: OpenEx( 000001BD35055790, 0000000DAD8FDC50 )
0x00001CD4 53461 3  XDS110 C: Executing command 0x0f (CMAPI_CONNECT)
0x00001CD4 53461 3  XDS110 I: Depth0: DpRegRead( address = 0x00000000 ) -> 0x4ba00477 = 0
0x00001CD4 53461 3  XDS110 I: Depth0: DpRegWrite( address = 0x00000004, *value = 0x50000032 ) = 0
0x00001CD4 53461 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 53461 3  XDS110 R: Executed command 0x0f (CMAPI_CONNECT), return code: 0x00000000
0x00001CD4 53461 3  CMAPI R: OpenEx( 000001BD35055790, 0000000DAD8FDC50 ) = 0
0x00001CD4 53461 3  CMAPI C: Acquire( 000001BD35055790 )
0x00001CD4 53477 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 53477 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 53477 3  CMAPI R: Acquire( 000001BD35055790 ) = 0
0x00001CD4 53477 3  CMAPI C: DapRegRead( 000001BD35055790, 1, 0, 0x00000000, 000001BD2AE00478 )
0x00001CD4 53477 3  XDS110 C: Executing command 0x15 (CMAPI_DAPREGREAD)
0x00001CD4 53477 3  XDS110 I: Depth0: DpRegRead( address = 0x00000000 ) -> 0x4ba00477 = 0
0x00001CD4 53477 3  XDS110 R: Executed command 0x15 (CMAPI_DAPREGREAD), return code: 0x00000000
0x00001CD4 53477 3  CMAPI R: DapRegRead( 000001BD35055790, 1, 0, 0x00000000, *000001BD2AE00478 = 0x4BA00477 ) = 0
0x00001CD4 53477 3  CMAPI C: Release( 000001BD35055790 )
0x00001CD4 53477 3  CMAPI R: Release( 000001BD35055790 ) = 0
0x00001CD4 53477 3  CMAPI C: Acquire( 000001BD35055790 )
0x00001CD4 53477 3  CMAPI C: GetStatus( 000001BD35055790, 0000000DAD8FDC68 )
0x00001CD4 53477 3  CMAPI R: GetStatus( 000001BD35055790, *0000000DAD8FDC68 = { 1, 1, 1, 1, 1 } ) = 0
0x00001CD4 53477 3 CS_DAP_0 GTI R: GTI_CONNECT3( 0x000001BD29E1AA40, 0 ) = 0x00000000
0x00001CD4 53477 3  PERF I: GTI_CONNECT finished:  0.019537s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 53477 3 CS_DAP_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E1AA40, *0x0000000DAD8FD878 = 0x00000000, *0x0000000DAD8FD870 = 0x00000000, *0x0000000DAD8FD888 = 0x00000000, *0x0000000DAD8FD8A0 = 0x00000000, *0x0000000DAD8FD8A8 = 0x00000000, *0x0000000DAD8FD898 = 0x00000000, *0x0000000DAD8FD890 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53477 3 CS_DAP_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E1AA40, *0x0000000DAD8FD878 = 0x00000000, *0x0000000DAD8FD870 = 0x00000000, *0x0000000DAD8FD888 = 0x00000000, *0x0000000DAD8FD8A0 = 0x00000002, *0x0000000DAD8FD8A8 = 0x00000000, *0x0000000DAD8FD898 = 0x00000008, *0x0000000DAD8FD890 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53477 3 CS_DAP_0 STATE I: Connection state changed to 4
0x00001CD4 53477 3 Cortex_M4_0 POLL C: Firing DSP_DOMAIN_POWERED to all DSP_USER's
0x00001CD4 53477 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_GET_RESET_MODE added to polling loop by class CResetManager
0x00001CD4 53477 3 Cortex_M4_0 POLL C: Firing of DSP_DOMAIN_POWERED complete
0x00001CD4 53477 3 CS_DAP_0 GTI C: GTI_STAT( 0x000001BD29E1AA40 )
0x00001CD4 53477 3  CMAPI C: GetStatus( 000001BD35055790, 0000000DAD8FDA28 )
0x00001CD4 53477 3  CMAPI R: GetStatus( 000001BD35055790, *0000000DAD8FDA28 = { 1, 1, 1, 1, 1 } ) = 0
0x00001CD4 53492 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 53492 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 53492 3  CMAPI R: Release( 000001BD35055790 ) = 0
0x00001CD4 53492 3 CS_DAP_0 GTI R: GTI_STAT( 0x000001BD29E1AA40 ) = 0x0000000D
0x00001CD4 53492 3 CS_DAP_0 STATE I: Target execution state changed to STATUS_NON_DEBUG_NORMAL
0x00001CD4 53492 3 CS_DAP_0 STATE I: Debugger execution state changed to EVENT_DSP_HALT
0x00001CD4 53492 3 CS_DAP_0 STATE I: Connection state changed to 0
0x00001CD4 53492 3  PERF I: GEL OnTargetConnect() starting...
0x00001CD4 53492 3  SEQUENCE I: Finished sequence step at 0000000DAD8FDE20
0x00001CD4 53492 3  SEQUENCE I: Beginning class Debugger::GelCallbackStep at 000001BD2B4CA7A0
0x00001CD4 53492 3 CS_DAP_0 GEL I: Evaluating "OnTargetConnect()"
0x00001CD4 53492 3 CS_DAP_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 53492 3 CS_DAP_0 POLL C: Firing DSP_PRIORITY_CONNECTED to all DSP_USER's
0x00001CD4 53492 3 CS_DAP_0 POLL C: Firing of DSP_PRIORITY_CONNECTED complete
0x00001CD4 53492 4 CS_DAP_0 POLL I: Yielding to other threads
0x00001CD4 53492 3 CS_DAP_0 POLL R: Poll() returning
0x00001CD4 53492 3 Cortex_M4_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 53492 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 53492 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 53492 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 374 ms
0x00001CD4 53492 4  POLL I: TimeToSleep() found shorter sleep time of 374 ms from class DevicePollFrequencyManager
0x00001CD4 53492 4 CS_DAP_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 53492 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 53492 4  POLL I: Yielding to other threads
0x00001CD4 53492 3 CS_DAP_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 53492 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_GET_WIR_MODE and status EVENT_DSP_HALT
0x00001CD4 53492 3 Cortex_M4_0 GTI C: GTI_GET_WAIT_IN_RESET_MODE( 0x000001BD362E2770, *0x0000000DAD8FDFA0 = 0x00000000 )
0x00001CD4 53492 3  PRSC C: PRSC_GetGlobalChildExtendedStatus: prscHandle =0x1bd29e1cbb0
0x00001CD4 53492 3  PRSC C: prsc_SendRouter: connectionNeeded=0x1
0x00001CD4 53492 3  PRSC C: GRTR:Connected: routerHandle=0x1bd2b9beca0
0x00001CD4 53492 3 IcePick_C TA C: IsConnected()
0x00001CD4 53492 3 IcePick_C TA R: IsConnected() = true
0x00001CD4 53492 3  PRSC R: GRTR:Connected: pbConnected =0x1, ret=0x0
0x00001CD4 53492 3  PRSC C: GRTR:GetExtendedRouterStatus: routerHandle=0x1bd2b9beca0,parentHandle=0x1bd3d0baf60, regIndex=0x2
0x00001CD4 53492 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x0000000DAD8FDAE0 )
0x00001CD4 53492 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775806 AND Register_Cache.Address<=-9223372036854775806 AND Register_Cache.Page=121 AND Register_Cache.Processor=33
0x00001CD4 53492 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FDA68 = 0xAD8FDEA0 )
0x00001CD4 53492 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53492 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53492 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53492 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53492 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FDA68 = 0x2028233F ) = 0x00000000
0x00001CD4 53492 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD1E8 = 0x00000000, *0x0000000DAD8FD1E0 = 0x00000000, *0x0000000DAD8FD1F8 = 0x00000000, *0x0000000DAD8FD210 = 0x00000000, *0x0000000DAD8FD218 = 0x00000000, *0x0000000DAD8FD208 = 0x00000000, *0x0000000DAD8FD200 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53492 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD1E8 = 0x00000000, *0x0000000DAD8FD1E0 = 0x00000000, *0x0000000DAD8FD1F8 = 0x00000000, *0x0000000DAD8FD210 = 0x00000002, *0x0000000DAD8FD218 = 0x00000000, *0x0000000DAD8FD208 = 0x00000008, *0x0000000DAD8FD200 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53492 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD0B8 = 0x00000000, *0x0000000DAD8FD0B0 = 0x00000000, *0x0000000DAD8FD0C8 = 0x00000000, *0x0000000DAD8FD0E0 = 0x00000000, *0x0000000DAD8FD0E8 = 0x00000000, *0x0000000DAD8FD0D8 = 0x00000000, *0x0000000DAD8FD0D0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53492 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD0B8 = 0x00000000, *0x0000000DAD8FD0B0 = 0x00000000, *0x0000000DAD8FD0C8 = 0x00000000, *0x0000000DAD8FD0E0 = 0x00000002, *0x0000000DAD8FD0E8 = 0x00000000, *0x0000000DAD8FD0D8 = 0x00000008, *0x0000000DAD8FD0D0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53492 3 IcePick_C TA R: RegisterRead( 0x0000000000000002, 0x000000002028233F ) = 0
0x00001CD4 53492 3  PRSC C: GRTR:GetRouterStatus: routerHandle=0x1bd2b9beca0,parentHandle=0x1bd3d0baf60, regIndex=0x2
0x00001CD4 53492 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x0000000DAD8FDA60 )
0x00001CD4 53492 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD9E8 = 0xAD8FDB30 )
0x00001CD4 53508 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53508 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 53508 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 53508 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD9E8 = 0x2028233F ) = 0x00000000
0x00001CD4 53508 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD168 = 0x00000000, *0x0000000DAD8FD160 = 0x00000000, *0x0000000DAD8FD178 = 0x00000000, *0x0000000DAD8FD190 = 0x00000000, *0x0000000DAD8FD198 = 0x00000000, *0x0000000DAD8FD188 = 0x00000000, *0x0000000DAD8FD180 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53508 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD168 = 0x00000000, *0x0000000DAD8FD160 = 0x00000000, *0x0000000DAD8FD178 = 0x00000000, *0x0000000DAD8FD190 = 0x00000002, *0x0000000DAD8FD198 = 0x00000000, *0x0000000DAD8FD188 = 0x00000008, *0x0000000DAD8FD180 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53508 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD038 = 0x00000000, *0x0000000DAD8FD030 = 0x00000000, *0x0000000DAD8FD048 = 0x00000000, *0x0000000DAD8FD060 = 0x00000000, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD058 = 0x00000000, *0x0000000DAD8FD050 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53508 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD038 = 0x00000000, *0x0000000DAD8FD030 = 0x00000000, *0x0000000DAD8FD048 = 0x00000000, *0x0000000DAD8FD060 = 0x00000002, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD058 = 0x00000008, *0x0000000DAD8FD050 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53508 3 IcePick_C TA R: RegisterRead( 0x0000000000000002, 0x000000002028233F ) = 0
0x00001CD4 53508 3  PRSC R: GRTR:GetRouterStatus: powerStatus=0x3, exeStatus=0x1, resetStatus=0x7, resetMode=0xa, activeStatus=0xe, clockStatus=0x9,prscRtn=0x0
0x00001CD4 53508 3 IcePick_C TA C: RegisterWrite( 0x0000000000000002, 0x000000002028233F )
0x00001CD4 53508 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775806 AND Register_Cache.Address<=-9223372036854775806 AND Register_Cache.Page=121 AND Register_Cache.Processor=33
0x00001CD4 53508 3 IcePick_C GTI C: GTI_WRITEREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FDA98 = 0x2028233F )
0x00001CD4 53508 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53508 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53508 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53508 3 IcePick_C GTI R: GTI_WRITEREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FDA98 = 0x2028233F ) = 0x00000000
0x00001CD4 53508 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD218 = 0x00000000, *0x0000000DAD8FD210 = 0x00000000, *0x0000000DAD8FD228 = 0x00000000, *0x0000000DAD8FD240 = 0x00000000, *0x0000000DAD8FD248 = 0x00000000, *0x0000000DAD8FD238 = 0x00000000, *0x0000000DAD8FD230 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53508 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD218 = 0x00000000, *0x0000000DAD8FD210 = 0x00000000, *0x0000000DAD8FD228 = 0x00000000, *0x0000000DAD8FD240 = 0x00000002, *0x0000000DAD8FD248 = 0x00000000, *0x0000000DAD8FD238 = 0x00000008, *0x0000000DAD8FD230 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53508 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD0E8 = 0x00000000, *0x0000000DAD8FD0E0 = 0x00000000, *0x0000000DAD8FD0F8 = 0x00000000, *0x0000000DAD8FD110 = 0x00000000, *0x0000000DAD8FD118 = 0x00000000, *0x0000000DAD8FD108 = 0x00000000, *0x0000000DAD8FD100 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53508 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD0E8 = 0x00000000, *0x0000000DAD8FD0E0 = 0x00000000, *0x0000000DAD8FD0F8 = 0x00000000, *0x0000000DAD8FD110 = 0x00000002, *0x0000000DAD8FD118 = 0x00000000, *0x0000000DAD8FD108 = 0x00000008, *0x0000000DAD8FD100 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53508 3 IcePick_C TA R: RegisterWrite( 0x0000000000000002, 0x000000002028233F ) = 0
0x00001CD4 53508 3  PRSC R: GRTR:GetExtendedRouterStatus: powerStatus=0x3, exeStatus=0x1, resetStatus=0x7, resetMode=0xa, activeStatus=0xe, clockStatus=0x9, haltOnResetStatus=0x12, powerLossDetStatus=0x13, prscRtn=0x0
0x00001CD4 53508 3  PRSC C: prsc_SendRouter: error =0x0
0x00001CD4 53508 3  PRSC R: PRSC_GetGlobalChildExStatus: ret=0x0, activeStatus=0xe, clockStatus=0x9, exeStatus=0x1, powerStatus=0x3, resetMode=0xa, resetStatus=0x7, haltOnResetStatus=0x12, powerLossStatus =0x13
0x00001CD4 53508 3 Cortex_M4_0 GTI R: GTI_GET_WAIT_IN_RESET_MODE( 0x000001BD362E2770, *0x0000000DAD8FDFA0 = 0x00000000 ) = 0x00000000
0x00001CD4 53508 3 Cortex_M4_0 GTI C: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD7D8 = 0x00000000, *0x0000000DAD8FD7D0 = 0x00000000, *0x0000000DAD8FD7E8 = 0x00000000, *0x0000000DAD8FD800 = 0x00000000, *0x0000000DAD8FD808 = 0x00000000, *0x0000000DAD8FD7F8 = 0x00000000, *0x0000000DAD8FD7F0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53508 3 Cortex_M4_0 GTI R: GTI_GETERRSTR_EX3( 0x000001BD362E2770, *0x0000000DAD8FD7D8 = 0x00000000, *0x0000000DAD8FD7D0 = 0x00000000, *0x0000000DAD8FD7E8 = 0x00000000, *0x0000000DAD8FD800 = 0x00000002, *0x0000000DAD8FD808 = 0x00000000, *0x0000000DAD8FD7F8 = 0x00000008, *0x0000000DAD8FD7F0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53508 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class CResetManager
0x00001CD4 53508 3 Cortex_M4_0 POLL C: Firing DSP_RESET_MODE_CHANGED to all DSP_USER's
0x00001CD4 53508 3  COM_DBG_IF C: class DSP_CO_USER::OnHaltOnResetChanged()
0x00001CD4 53508 3  COM_DBG_IF R: class DSP_CO_USER::OnHaltOnResetChanged()
0x00001CD4 53508 3 Cortex_M4_0 POLL C: Firing of DSP_RESET_MODE_CHANGED complete
0x00001CD4 53508 3 Cortex_M4_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 53508 4 Cortex_M4_0 POLL I: Yielding to other threads
0x00001CD4 53508 3 Cortex_M4_0 POLL R: Poll() returning
0x00001CD4 53508 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 343 ms
0x00001CD4 53508 4  POLL I: TimeToSleep() found shorter sleep time of 343 ms from class DevicePollFrequencyManager
0x00001CD4 53508 4 CS_DAP_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 53508 4  POLL I: TimeToSleep() found shorter sleep time of 0 ms from class DevicePollFrequencyManager
0x00001CD4 53508 4  POLL I: Yielding to other threads
0x00001CD4 53508 3 CS_DAP_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 53508 3 CS_DAP_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 53508 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=34 AND Name='OnTargetConnect()'
0x00001CD4 53508 3 CS_DAP_0 GEL I: Evaluation of "OnTargetConnect()" failed: identifier not found: OnTargetConnect()
0x00001CD4 53508 3  SEQUENCE I: Finished sequence step at 000001BD2B4CA7A0
0x00001CD4 53508 3  SEQUENCE I: Beginning class Debugger::LambdaSequenceStep<class <lambda_bb017b12012eedddadf10144bef98de7> > at 000001BD2E7EE990
0x00001CD4 53508 3  PERF I: GEL OnTargetConnect() finished:  0.025033s wall, 0.000000s user + 0.000000s system = 0.000000s CPU (n/a%)
0x00001CD4 53508 3  SEQUENCE I: Finished sequence step at 000001BD2E7EE990
0x00001CD4 53508 3  SEQUENCE I: Beginning class `anonymous namespace'::WaitForValidState at 000001BD35E8E5F0
0x00001CD4 53508 3  SEQUENCE I: Finished sequence step at 000001BD35E8E5F0
0x00001CD4 53508 3  SEQUENCE I: Beginning class `anonymous namespace'::CallGelResetStep at 000001BD2B8C0F20
0x00001CD4 53508 3  SEQUENCE I: Finished sequence step at 000001BD2B8C0F20
0x00001CD4 53508 3  SEQUENCE I: Beginning class Debugger::PriorityEventStep at 000001BD2E7EE730
0x00001CD4 53508 3  SEQUENCE I: Finished sequence step at 000001BD2E7EE730
0x00001CD4 53508 3 CS_DAP_0 POLL C: Firing of DSP_REQ_EVENT complete
0x00001CD4 53508 3 CS_DAP_0 POLL C: Firing DSP_CONNECTED to all DSP_USER's
0x00001CD4 53508 3 CS_DAP_0 TA C: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::eConnected )
0x00001CD4 53508 3 CS_DAP_0 TA R: TargetAdapterEvent::OnTargetStateChange( Ti::Sds::Ctools::eConnected )
0x00001CD4 53508 3 Cortex_M4_0 POLL C: Firing DSP_PRECONNECT to all DSP_USER's
0x00001CD4 53508 3 Cortex_M4_0 POLL C: Firing of DSP_PRECONNECT complete
0x00001CD4 53508 3  SEQUENCE I: Finished sequence step at 0000000DAD8FD960
0x00001CD4 53508 3  SEQUENCE I: Beginning class Debugger::GelCallbackStep at 000001BD2B4CA520
0x00001CD4 53508 3 Cortex_M4_0 GEL I: Evaluating "OnPreTargetConnect()"
0x00001CD4 53508 3 Cortex_M4_0 POLL D: New request of type DSP_RQ_NONE added to polling loop by class `anonymous namespace'::NullRequestNotification
0x00001CD4 53508 3  COM_DBG_IF C: class DSP_CO_USER::OnConnected()
0x00001CD4 53508 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD29E63050 )->onEvent()
0x00001CD4 53508 3  XPCOM C: ( (dsIConnectDisconnect*)000001BD29181408 )->connectionStatus( 0000000DAD8FC4A0 )
0x00001CD4 53508 3  XPCOM R: ( (dsIConnectDisconnect*)000001BD29181408 )->connectionStatus( *0000000DAD8FC4A0 = 0x00000000 ) = 0x00000000
0x00001CD4 53508 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD29E63050 )->onEvent() = 0x00000000
0x00001CD4 53508 3  COM_DBG_IF R: class DSP_CO_USER::OnConnected()
0x00001CD4 53508 3  COM_DBG_IF C: class DSP_CO_USER::OnRefresh()
0x00001CD4 53508 3  XPCOM C: ( (dsINumberEventCallback*)000001BD29E62D50 )->onEvent( 0x0000000000000003 )
0x00001CD4 53508 3  XPCOM R: ( (dsINumberEventCallback*)000001BD29E62D50 )->onEvent( 0x0000000000000003 ) = 0x00000000
0x00001CD4 53508 3  COM_DBG_IF R: class DSP_CO_USER::OnRefresh()
0x00001CD4 53508 3  COM_DBG_IF C: class DSP_CO_USER::OnAllowedUserAccessesChanged()
0x00001CD4 53508 3  XPCOM C: ( (dsISimpleEventCallback*)000001BD29E62350 )->onEvent()
0x00001CD4 53508 3  XPCOM R: ( (dsISimpleEventCallback*)000001BD29E62350 )->onEvent() = 0x00000000
0x00001CD4 53508 3  COM_DBG_IF R: class DSP_CO_USER::OnAllowedUserAccessesChanged()
0x00001CD4 53508 3 CS_DAP_0 POLL C: Firing of DSP_CONNECTED complete
0x00001CD4 53508 4 CS_DAP_0 POLL I: Yielding to other threads
0x00001CD4 53508 3 CS_DAP_0 POLL R: Poll() returning
0x00001CD4 53508 3 Cortex_M4_0 POLL C: Polling with state STATE_IDLE and status EVENT_DSP_HALT
0x00001CD4 53508 4 IcePick_C POLL I: TimeToPollAgain() target is idle and needs polling in 327 ms
0x00001CD4 53508 4  POLL I: TimeToSleep() found shorter sleep time of 327 ms from class DevicePollFrequencyManager
0x00001CD4 53508 4 CS_DAP_0 POLL I: TimeToPollAgain() target is idle and needs polling in 500 ms
0x00001CD4 53508 4 Cortex_M4_0 POLL I: TimeToPollAgain() target servicing a request or event
0x00001CD4 53508 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_HANDLE_NULL_REQUEST and status EVENT_DSP_HALT
0x00001CD4 53508 3 Cortex_M4_0 POLL C: Firing DSP_REQ_EVENT to class `anonymous namespace'::NullRequestNotification
0x00001CD4 53508 3  SETUP I: SELECT * FROM Module_Instances WHERE Processor=35 AND Name='OnPreTargetConnect()'
0x00001CD4 53508 3 Cortex_M4_0 GEL I: Evaluation of "OnPreTargetConnect()" failed: identifier not found: OnPreTargetConnect()
0x00001CD4 53508 3  SEQUENCE I: Finished sequence step at 000001BD2B4CA520
0x00001CD4 53508 3  SEQUENCE I: Beginning class Debugger::LambdaSequenceStep<class <lambda_d5c2eaa1b9c646e74fc865fbf49efb9b> > at 000001BD2E7F29D0
0x00001CD4 53508 3  SEQUENCE I: Finished sequence step at 000001BD2E7F29D0
0x00001CD4 53508 3 Cortex_M4_0 POLL C: Polling with state CPU_ST_CONNECT and status EVENT_DSP_HALT
0x00003E54 53508 3  XPCOM C: ( (dsIDebugProperties*)000001BD2E414D40 )->getProperty( EnableInstalledBreakpoint, 0000000DAA8FE6F8 )
0x00001CD4 53508 3  PERF I: GTI_CONNECT starting...
0x00003E54 53508 3  XPCOM R: ( (dsIDebugProperties*)000001BD2E414D40 )->getProperty( EnableInstalledBreakpoint, *0000000DAA8FE6F8 = 000001BD301459B0 ) = 0x00000000
0x00001CD4 53508 3 Cortex_M4_0 GTI C: GTI_CONNECT3( 0x000001BD362E2770, 0 )
0x00001CD4 53508 3  PRSC C: PRSC_Connect: prscHandle=0x1bd29e1cbb0,
0x00001CD4 53508 3  PRSC C: GRTR:SubConnect: routerHandle =0x1bd2b9beca0subPathHandle=0x1bd3d1fdea0 , numConnections=0x0
0x00001CD4 53508 3  PRSC R: GRTR:SUBConnect: rtn=0x0
0x00001CD4 53508 3  PRSC C: GRTR:SubConnect: routerHandle =0x1bd2b9beca0subPathHandle=0x1bd3d1fe4e0 , numConnections=0x0
0x00001CD4 53508 3  PRSC C: PRSC_GetGlobalChildExtendedStatus: prscHandle =0x1bd29e1cbb0
0x00001CD4 53508 3  PRSC C: prsc_SendRouter: connectionNeeded=0x1
0x00001CD4 53508 3  PRSC C: GRTR:Connected: routerHandle=0x1bd2b9beca0
0x00001CD4 53508 3 IcePick_C TA C: IsConnected()
0x00001CD4 53508 3 IcePick_C TA R: IsConnected() = true
0x00001CD4 53508 3  PRSC R: GRTR:Connected: pbConnected =0x1, ret=0x0
0x00001CD4 53508 3  PRSC C: GRTR:GetExtendedRouterStatus: routerHandle=0x1bd2b9beca0, parentHandle=0x1bd3d0baf60, regIndex=0x2
0x00001CD4 53508 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x0000000DAD8FD8B0 )
0x00003E54 53508 3  XPCOM C: ( (dsIProperty*)000001BD301459B0 )->getPropertyType( 0000000DAA8FE690 )
0x00003E54 53508 3  XPCOM R: ( (dsIProperty*)000001BD301459B0 )->getPropertyType( *0000000DAA8FE690 = 0x00000000 ) = 0x00000000
0x00003E54 53508 3  XPCOM C: ( (dsIProperty*)000001BD301459B0 )->queryInterface( 000001BD2EFB5450, 0000000DAA8FE688 )
0x00003E54 53508 3  XPCOM R: ( (dsIProperty*)000001BD301459B0 )->queryInterface( 000001BD2EFB5450, *0000000DAA8FE688 = 000001BD30145A50 ) = 0x00000000
0x00003E54 53508 3  XPCOM C: ( (dsIBooleanProperty*)000001BD30145A50 )->queryInterface( 000001BD2EFB5510, 0000000DAA8FE628 )
0x00003E54 53508 3  XPCOM R: ( (dsIBooleanProperty*)000001BD30145A50 )->queryInterface( 000001BD2EFB5510, *0000000DAA8FE628 = 000001BD30145A50 ) = 0x00000000
0x00003E54 53508 3  XPCOM C: ( (dsIBooleanProperty*)000001BD30145A50 )->CurValue( 0000000DAA8FE6F0 )
0x00003E54 53508 3  XPCOM R: ( (dsIBooleanProperty*)000001BD30145A50 )->CurValue( *0000000DAA8FE6F0 = false ) = 0x00000000
0x00001CD4 53508 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD838 = 0xAD8FDCD8 )
0x00001CD4 53524 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53524 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53524 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53524 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 53524 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 53524 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD838 = 0x2008233F ) = 0x00000000
0x00001CD4 53524 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCFB8 = 0x00000000, *0x0000000DAD8FCFB0 = 0x00000000, *0x0000000DAD8FCFC8 = 0x00000000, *0x0000000DAD8FCFE0 = 0x00000000, *0x0000000DAD8FCFE8 = 0x00000000, *0x0000000DAD8FCFD8 = 0x00000000, *0x0000000DAD8FCFD0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53524 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCFB8 = 0x00000000, *0x0000000DAD8FCFB0 = 0x00000000, *0x0000000DAD8FCFC8 = 0x00000000, *0x0000000DAD8FCFE0 = 0x00000002, *0x0000000DAD8FCFE8 = 0x00000000, *0x0000000DAD8FCFD8 = 0x00000008, *0x0000000DAD8FCFD0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53524 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCE88 = 0x00000000, *0x0000000DAD8FCE80 = 0x00000000, *0x0000000DAD8FCE98 = 0x00000000, *0x0000000DAD8FCEB0 = 0x00000000, *0x0000000DAD8FCEB8 = 0x00000000, *0x0000000DAD8FCEA8 = 0x00000000, *0x0000000DAD8FCEA0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53524 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCE88 = 0x00000000, *0x0000000DAD8FCE80 = 0x00000000, *0x0000000DAD8FCE98 = 0x00000000, *0x0000000DAD8FCEB0 = 0x00000002, *0x0000000DAD8FCEB8 = 0x00000000, *0x0000000DAD8FCEA8 = 0x00000008, *0x0000000DAD8FCEA0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53524 3 IcePick_C TA R: RegisterRead( 0x0000000000000002, 0x000000002008233F ) = 0
0x00001CD4 53524 3  PRSC C: GRTR:GetRouterStatus: routerHandle=0x1bd2b9beca0,parentHandle=0x1bd3d0baf60, regIndex=0x2
0x00001CD4 53524 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x0000000DAD8FD830 )
0x00001CD4 53524 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775806 AND Register_Cache.Address<=-9223372036854775806 AND Register_Cache.Page=121 AND Register_Cache.Processor=33
0x00001CD4 53524 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD7B8 = 0xAD8FD910 )
0x00001CD4 53524 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53524 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD7B8 = 0x2008233F ) = 0x00000000
0x00001CD4 53524 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF38 = 0x00000000, *0x0000000DAD8FCF30 = 0x00000000, *0x0000000DAD8FCF48 = 0x00000000, *0x0000000DAD8FCF60 = 0x00000000, *0x0000000DAD8FCF68 = 0x00000000, *0x0000000DAD8FCF58 = 0x00000000, *0x0000000DAD8FCF50 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53524 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF38 = 0x00000000, *0x0000000DAD8FCF30 = 0x00000000, *0x0000000DAD8FCF48 = 0x00000000, *0x0000000DAD8FCF60 = 0x00000002, *0x0000000DAD8FCF68 = 0x00000000, *0x0000000DAD8FCF58 = 0x00000008, *0x0000000DAD8FCF50 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53524 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCE08 = 0x00000000, *0x0000000DAD8FCE00 = 0x00000000, *0x0000000DAD8FCE18 = 0x00000000, *0x0000000DAD8FCE30 = 0x00000000, *0x0000000DAD8FCE38 = 0x00000000, *0x0000000DAD8FCE28 = 0x00000000, *0x0000000DAD8FCE20 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53524 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCE08 = 0x00000000, *0x0000000DAD8FCE00 = 0x00000000, *0x0000000DAD8FCE18 = 0x00000000, *0x0000000DAD8FCE30 = 0x00000002, *0x0000000DAD8FCE38 = 0x00000000, *0x0000000DAD8FCE28 = 0x00000008, *0x0000000DAD8FCE20 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53524 3  PRSC R: GRTR:GetRouterStatus: powerStatus=0x3, exeStatus=0x1, resetStatus=0x7, resetMode=0xa, activeStatus=0xe, clockStatus=0x9,prscRtn=0x0
0x00001CD4 53524 3  PRSC R: GRTR:GetExtendedRouterStatus: powerStatus=0x3, exeStatus=0x1, resetStatus=0x7, resetMode=0xa, activeStatus=0xe, clockStatus=0x9, haltOnResetStatus=0x12, powerLossDetStatus=0x14, powerDownDesired=0x18, clockDownDesired=0x1a, accessibleStatus=0x15, prscRtn=0x0
0x00001CD4 53524 3  PRSC C: prsc_SendRouter: error =0x0
0x00001CD4 53524 3  PRSC R: PRSC_GetGlobalChildExStatus: ret=0x0, activeStatus=0xe, clockStatus=0x9, exeStatus=0x1, powerStatus=0x3, resetMode=0xa, resetStatus=0x7, haltOnResetStatus=0x12, powerLossStatus =0x14, accessibleStatus=0x15, powerDownDeisred=0x18, clockDownDesired=0x1a, retentionStatus=0x1c
0x00001CD4 53524 3  PRSC C: PRSC_EnableDebug: prscHandle =0x1bd29e1cbb0
0x00001CD4 53524 3  PRSC C: prsc_SendRouter: connectionNeeded=0x1
0x00001CD4 53524 3  PRSC C: GRTR:Connected: routerHandle=0x1bd2b9beca0
0x00001CD4 53524 3 IcePick_C TA C: IsConnected()
0x00001CD4 53524 3 IcePick_C TA R: IsConnected() = true
0x00001CD4 53524 3  PRSC R: GRTR:Connected: pbConnected =0x1, ret=0x0
0x00001CD4 53524 3  PRSC C: GRTR:EnableDebug: routerHandle=0x1bd2b9beca0,parentHandle=0x1bd3d0baf60, regIndex=0x2, debugMode=0x0
0x00001CD4 53524 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x0000000000000000 )
0x00001CD4 53524 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD8E8 = 0xAD8FDC80 )
0x00001CD4 53540 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53540 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53540 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 53540 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 53540 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD8E8 = 0x2008233F ) = 0x00000000
0x00001CD4 53540 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD060 = 0x00000000, *0x0000000DAD8FD078 = 0x00000000, *0x0000000DAD8FD090 = 0x00000000, *0x0000000DAD8FD098 = 0x00000000, *0x0000000DAD8FD088 = 0x00000000, *0x0000000DAD8FD080 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53540 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD060 = 0x00000000, *0x0000000DAD8FD078 = 0x00000000, *0x0000000DAD8FD090 = 0x00000002, *0x0000000DAD8FD098 = 0x00000000, *0x0000000DAD8FD088 = 0x00000008, *0x0000000DAD8FD080 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53540 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF38 = 0x00000000, *0x0000000DAD8FCF30 = 0x00000000, *0x0000000DAD8FCF48 = 0x00000000, *0x0000000DAD8FCF60 = 0x00000000, *0x0000000DAD8FCF68 = 0x00000000, *0x0000000DAD8FCF58 = 0x00000000, *0x0000000DAD8FCF50 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53540 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF38 = 0x00000000, *0x0000000DAD8FCF30 = 0x00000000, *0x0000000DAD8FCF48 = 0x00000000, *0x0000000DAD8FCF60 = 0x00000002, *0x0000000DAD8FCF68 = 0x00000000, *0x0000000DAD8FCF58 = 0x00000008, *0x0000000DAD8FCF50 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53540 3 IcePick_C TA R: RegisterRead( 0x0000000000000002, 0x000000002008233F ) = 0
0x00001CD4 53540 3 IcePick_C TA C: RegisterWrite( 0x0000000000000002, 0x000000002008233F )
0x00001CD4 53540 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775806 AND Register_Cache.Address<=-9223372036854775806 AND Register_Cache.Page=121 AND Register_Cache.Processor=33
0x00001CD4 53540 3 IcePick_C GTI C: GTI_WRITEREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD918 = 0x2008233F )
0x00001CD4 53540 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53540 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53540 3 IcePick_C GTI R: GTI_WRITEREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD918 = 0x2008233F ) = 0x00000000
0x00001CD4 53540 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD098 = 0x00000000, *0x0000000DAD8FD090 = 0x00000000, *0x0000000DAD8FD0A8 = 0x00000000, *0x0000000DAD8FD0C0 = 0x00000000, *0x0000000DAD8FD0C8 = 0x00000000, *0x0000000DAD8FD0B8 = 0x00000000, *0x0000000DAD8FD0B0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53540 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD098 = 0x00000000, *0x0000000DAD8FD090 = 0x00000000, *0x0000000DAD8FD0A8 = 0x00000000, *0x0000000DAD8FD0C0 = 0x00000002, *0x0000000DAD8FD0C8 = 0x00000000, *0x0000000DAD8FD0B8 = 0x00000008, *0x0000000DAD8FD0B0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53540 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF68 = 0x00000000, *0x0000000DAD8FCF60 = 0x00000000, *0x0000000DAD8FCF78 = 0x00000000, *0x0000000DAD8FCF90 = 0x00000000, *0x0000000DAD8FCF98 = 0x00000000, *0x0000000DAD8FCF88 = 0x00000000, *0x0000000DAD8FCF80 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53540 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF68 = 0x00000000, *0x0000000DAD8FCF60 = 0x00000000, *0x0000000DAD8FCF78 = 0x00000000, *0x0000000DAD8FCF90 = 0x00000002, *0x0000000DAD8FCF98 = 0x00000000, *0x0000000DAD8FCF88 = 0x00000008, *0x0000000DAD8FCF80 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53540 3 IcePick_C TA R: RegisterWrite( 0x0000000000000002, 0x000000002008233F ) = 0
0x00001CD4 53540 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x00000000FF9DFBBF )
0x00001CD4 53540 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD8E8 = 0x00000000 )
0x00001CD4 53556 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53556 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53556 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 53556 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 53556 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD8E8 = 0x2008233F ) = 0x00000000
0x00001CD4 53556 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD060 = 0x00000000, *0x0000000DAD8FD078 = 0x00000000, *0x0000000DAD8FD090 = 0x00000000, *0x0000000DAD8FD098 = 0x00000000, *0x0000000DAD8FD088 = 0x00000000, *0x0000000DAD8FD080 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53556 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD060 = 0x00000000, *0x0000000DAD8FD078 = 0x00000000, *0x0000000DAD8FD090 = 0x00000002, *0x0000000DAD8FD098 = 0x00000000, *0x0000000DAD8FD088 = 0x00000008, *0x0000000DAD8FD080 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53556 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF38 = 0x00000000, *0x0000000DAD8FCF30 = 0x00000000, *0x0000000DAD8FCF48 = 0x00000000, *0x0000000DAD8FCF60 = 0x00000000, *0x0000000DAD8FCF68 = 0x00000000, *0x0000000DAD8FCF58 = 0x00000000, *0x0000000DAD8FCF50 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53556 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF38 = 0x00000000, *0x0000000DAD8FCF30 = 0x00000000, *0x0000000DAD8FCF48 = 0x00000000, *0x0000000DAD8FCF60 = 0x00000002, *0x0000000DAD8FCF68 = 0x00000000, *0x0000000DAD8FCF58 = 0x00000008, *0x0000000DAD8FCF50 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53556 3 IcePick_C TA R: RegisterRead( 0x0000000000000002, 0x000000002008233F ) = 0
0x00001CD4 53556 3  PRSC R: GRTR:EnableDebug: prscRtn=0x0
0x00001CD4 53556 3  PRSC C: prsc_SendRouter: error =0x0
0x00001CD4 53556 3  PRSC R: PRSC_EnableDebug: prscRtn =0x0
0x00001CD4 53556 3  PRSC C: PRSC_ForceClockPower: prscHandle=0x1bd29e1cbb0,
0x00001CD4 53556 3  PRSC C: prsc_SendRouter: connectionNeeded=0x1
0x00001CD4 53556 3  PRSC C: GRTR:Connected: routerHandle=0x1bd2b9beca0
0x00001CD4 53556 3 IcePick_C TA C: IsConnected()
0x00001CD4 53556 3 IcePick_C TA R: IsConnected() = true
0x00001CD4 53556 3  PRSC R: GRTR:Connected: pbConnected =0x1, ret=0x0
0x00001CD4 53556 3  PRSC C: GRTR:ForceClockPower: routerHandle=0x1bd2b9beca0, parentHandle=0x1bd3d0baf60, regIndex=0x2, subPathForce=0x1
0x00001CD4 53556 3  PRSC C: GRTR:GetForceActiveStatus: routerHandle=0x1bd2b9beca0,parentHandle=0x1bd3d0baf60, regIndex=0x2
0x00001CD4 53556 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x0000000DAD8FD910 )
0x00001CD4 53556 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775806 AND Register_Cache.Address<=-9223372036854775806 AND Register_Cache.Page=121 AND Register_Cache.Processor=33
0x00001CD4 53556 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD898 = 0xAD8FD9B0 )
0x00001CD4 53556 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53556 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53556 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD898 = 0x2008233F ) = 0x00000000
0x00001CD4 53556 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD018 = 0x00000000, *0x0000000DAD8FD010 = 0x00000000, *0x0000000DAD8FD028 = 0x00000000, *0x0000000DAD8FD040 = 0x00000000, *0x0000000DAD8FD048 = 0x00000000, *0x0000000DAD8FD038 = 0x00000000, *0x0000000DAD8FD030 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53556 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD018 = 0x00000000, *0x0000000DAD8FD010 = 0x00000000, *0x0000000DAD8FD028 = 0x00000000, *0x0000000DAD8FD040 = 0x00000002, *0x0000000DAD8FD048 = 0x00000000, *0x0000000DAD8FD038 = 0x00000008, *0x0000000DAD8FD030 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53556 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCEE8 = 0x00000000, *0x0000000DAD8FCEE0 = 0x00000000, *0x0000000DAD8FCEF8 = 0x00000000, *0x0000000DAD8FCF10 = 0x00000000, *0x0000000DAD8FCF18 = 0x00000000, *0x0000000DAD8FCF08 = 0x00000000, *0x0000000DAD8FCF00 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53556 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCEE8 = 0x00000000, *0x0000000DAD8FCEE0 = 0x00000000, *0x0000000DAD8FCEF8 = 0x00000000, *0x0000000DAD8FCF10 = 0x00000002, *0x0000000DAD8FCF18 = 0x00000000, *0x0000000DAD8FCF08 = 0x00000008, *0x0000000DAD8FCF00 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53556 3  PRSC R: GRTR:GetForceActiveStatus: pbForceActive =0x1,ret=0x0
0x00001CD4 53556 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x0000000000000003 )
0x00001CD4 53556 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD8D8 = 0x38F09753 )
0x00001CD4 53572 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53572 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53572 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 53572 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 53572 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD8D8 = 0x2008233F ) = 0x00000000
0x00001CD4 53572 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD058 = 0x00000000, *0x0000000DAD8FD050 = 0x00000000, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD080 = 0x00000000, *0x0000000DAD8FD088 = 0x00000000, *0x0000000DAD8FD078 = 0x00000000, *0x0000000DAD8FD070 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53572 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD058 = 0x00000000, *0x0000000DAD8FD050 = 0x00000000, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD080 = 0x00000002, *0x0000000DAD8FD088 = 0x00000000, *0x0000000DAD8FD078 = 0x00000008, *0x0000000DAD8FD070 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53572 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF28 = 0x00000000, *0x0000000DAD8FCF20 = 0x00000000, *0x0000000DAD8FCF38 = 0x00000000, *0x0000000DAD8FCF50 = 0x00000000, *0x0000000DAD8FCF58 = 0x00000000, *0x0000000DAD8FCF48 = 0x00000000, *0x0000000DAD8FCF40 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53572 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF28 = 0x00000000, *0x0000000DAD8FCF20 = 0x00000000, *0x0000000DAD8FCF38 = 0x00000000, *0x0000000DAD8FCF50 = 0x00000002, *0x0000000DAD8FCF58 = 0x00000000, *0x0000000DAD8FCF48 = 0x00000008, *0x0000000DAD8FCF40 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53572 3 IcePick_C TA R: RegisterRead( 0x0000000000000002, 0x000000002008233F ) = 0
0x00001CD4 53572 3 IcePick_C TA C: RegisterWrite( 0x0000000000000002, 0x000000002008233F )
0x00001CD4 53572 3  SETUP I: SELECT Registers.dbid AS dbid, Register_Cache.Name AS Name, Register_Cache.Alias AS Alias, Register_Cache.Address AS Offset, Register_Cache.Page AS Page, Registers.Width AS Width, Register_Cache.Module AS Module, Registers.Description AS Description, Register_Cache.Hidden AS Hidden, Register_Cache.Is_Array_Element AS Is_Array_Element, Registers.Halted_Read_Access AS Halted_Read_Access, Registers.Halted_Write_Access AS Halted_Write_Access, Registers.Running_Read_Access AS Running_Read_Access, Registers.Running_Write_Access AS Running_Write_Access FROM Register_Cache, Registers WHERE Register_Cache.Register=Registers.dbid AND Register_Cache.Address>=-9223372036854775806 AND Register_Cache.Address<=-9223372036854775806 AND Register_Cache.Page=121 AND Register_Cache.Processor=33
0x00001CD4 53572 3 IcePick_C GTI C: GTI_WRITEREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD908 = 0x2008233F )
0x00001CD4 53572 3  XDS110 C: Executing command 0x0b (XDS_SENDSCAN)
0x00001CD4 53572 3  XDS110 R: Executed command 0x0b (XDS_SENDSCAN), return code: 0x00000000
0x00001CD4 53572 3 IcePick_C GTI R: GTI_WRITEREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD908 = 0x2008233F ) = 0x00000000
0x00001CD4 53572 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD088 = 0x00000000, *0x0000000DAD8FD080 = 0x00000000, *0x0000000DAD8FD098 = 0x00000000, *0x0000000DAD8FD0B0 = 0x00000000, *0x0000000DAD8FD0B8 = 0x00000000, *0x0000000DAD8FD0A8 = 0x00000000, *0x0000000DAD8FD0A0 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53572 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD088 = 0x00000000, *0x0000000DAD8FD080 = 0x00000000, *0x0000000DAD8FD098 = 0x00000000, *0x0000000DAD8FD0B0 = 0x00000002, *0x0000000DAD8FD0B8 = 0x00000000, *0x0000000DAD8FD0A8 = 0x00000008, *0x0000000DAD8FD0A0 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53572 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF58 = 0x00000000, *0x0000000DAD8FCF50 = 0x00000000, *0x0000000DAD8FCF68 = 0x00000000, *0x0000000DAD8FCF80 = 0x00000000, *0x0000000DAD8FCF88 = 0x00000000, *0x0000000DAD8FCF78 = 0x00000000, *0x0000000DAD8FCF70 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53572 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF58 = 0x00000000, *0x0000000DAD8FCF50 = 0x00000000, *0x0000000DAD8FCF68 = 0x00000000, *0x0000000DAD8FCF80 = 0x00000002, *0x0000000DAD8FCF88 = 0x00000000, *0x0000000DAD8FCF78 = 0x00000008, *0x0000000DAD8FCF70 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53572 3 IcePick_C TA R: RegisterWrite( 0x0000000000000002, 0x000000002008233F ) = 0
0x00001CD4 53572 3 IcePick_C TA C: RegisterRead( 0x0000000000000002, 0x00000000FF9DFBBF )
0x00001CD4 53572 3 IcePick_C GTI C: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD8D8 = 0x00000000 )
0x00001CD4 53587 3  XDS110 R: Executed command 0x0c (XDS_SENDRECVSCAN), return code: 0x00000000
0x00001CD4 53587 3  XDS110 C: Executing command 0x0c (XDS_SENDRECVSCAN)
0x00001CD4 53587 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 53587 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 53587 3 IcePick_C GTI R: GTI_READREG( 0x000001BD29E173E0, 0x00000002, *0x0000000DAD8FD8D8 = 0x2008233F ) = 0x00000000
0x00001CD4 53587 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD058 = 0x00000000, *0x0000000DAD8FD050 = 0x00000000, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD080 = 0x00000000, *0x0000000DAD8FD088 = 0x00000000, *0x0000000DAD8FD078 = 0x00000000, *0x0000000DAD8FD070 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53587 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FD058 = 0x00000000, *0x0000000DAD8FD050 = 0x00000000, *0x0000000DAD8FD068 = 0x00000000, *0x0000000DAD8FD080 = 0x00000002, *0x0000000DAD8FD088 = 0x00000000, *0x0000000DAD8FD078 = 0x00000008, *0x0000000DAD8FD070 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53587 3 IcePick_C GTI C: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF28 = 0x00000000, *0x0000000DAD8FCF20 = 0x00000000, *0x0000000DAD8FCF38 = 0x00000000, *0x0000000DAD8FCF50 = 0x00000000, *0x0000000DAD8FCF58 = 0x00000000, *0x0000000DAD8FCF48 = 0x00000000, *0x0000000DAD8FCF40 = 0x00000000, "", 0x00000040, "", 0x00000400 )
0x00001CD4 53587 3 IcePick_C GTI R: GTI_GETERRSTR_EX3( 0x000001BD29E173E0, *0x0000000DAD8FCF28 = 0x00000000, *0x0000000DAD8FCF20 = 0x00000000, *0x0000000DAD8FCF38 = 0x00000000, *0x0000000DAD8FCF50 = 0x00000002, *0x0000000DAD8FCF58 = 0x00000000, *0x0000000DAD8FCF48 = 0x00000008, *0x0000000DAD8FCF40 = 0x00000000, "", 0x00000040, "", 0x00000400 ) = 0x00000000
0x00001CD4 53587 3 IcePick_C TA R: RegisterRead( 0x0000000000000002, 0x000000002008233F ) = 0
0x00001CD4 53587 3  PRSC R: GRTR:ForceClockPower: prscRtn=0x0
0x00001CD4 53587 3  PRSC C: prsc_SendRouter: error =0x0
0x00001CD4 53587 3  PRSC R: PRSC_ForceClockPower: prscRtn =0x0
0x00001CD4 53587 3  PRSC R: PRSC_Connect: error =0x0
0x00001CD4 53587 3  CMAPI C: Open( 000001BD35050D30, 000001BD2BD91468 )
0x00001CD4 53587 3  XDS110 C: Executing command 0x0f (CMAPI_CONNECT)
0x00001CD4 53587 3  XDS110 I: Depth0: DpRegRead( address = 0x00000000 ) -> 0x4ba00477 = 0
0x00001CD4 53587 3  XDS110 I: Depth0: DpRegWrite( address = 0x00000004, *value = 0x50000032 ) = 0
0x00001CD4 53587 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 53587 3  XDS110 R: Executed command 0x0f (CMAPI_CONNECT), return code: 0x00000000
0x00001CD4 53587 3  CMAPI R: Open( 000001BD35050D30, 000001BD2BD91468 ) = 0
0x00001CD4 53587 3  CMAPI C: Acquire( 000001BD35050D30 )
0x00001CD4 53603 3  XDS110 C: Executing command 0x0d (XDS_SETAMBLEDELAY)
0x00001CD4 53603 3  XDS110 R: Executed command 0x0d (XDS_SETAMBLEDELAY), return code: 0x00000000
0x00001CD4 53603 3  CMAPI R: Acquire( 000001BD35050D30 ) = 0
0x00001CD4 53603 3  CMAPI C: DapRegRead( 000001BD35050D30, 0, 0, 0x000000FC, 0000000DAD8FDCC0 )
0x00001CD4 53603 3  XDS110 C: Executing command 0x15 (CMAPI_DAPREGREAD)
0x00001CD4 53603 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x000000fc ) -> 0x000000f0 = 0
0x00001CD4 53603 3  XDS110 I: Depth1: DpRegWrite( address = 0x00000008, *value = 0x000000f0 ) = 0
0x00001CD4 53603 3  XDS110 I: Depth0: DpRegRead( address = 0x0000000c ) -> 0x24770011 = 0
0x00001CD4 53603 3  XDS110 R: Executed command 0x15 (CMAPI_DAPREGREAD), return code: 0x00000000
0x00001CD4 53603 3  CMAPI R: DapRegRead( 000001BD35050D30, 0, 0, 0x000000FC, *0000000DAD8FDCC0 = 0x24770011 ) = 0
0x00001CD4 53603 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x000000fc ) -> 0x00000000 = 0
0x00001CD4 53603 3  CMAPI C: DapRegRead( 000001BD35050D30, 0, 0, 0x000000F8, 0000000DAD8FDC70 )
0x00001CD4 53603 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x000000f8 ) -> 0x00000000 = 0
0x00001CD4 53603 3  XDS110 I: Depth0: DpRegRead( address = 0x0000000c ) -> 0xe00ff003 = 0
0x00001CD4 53603 3  CMAPI R: DapRegRead( 000001BD35050D30, 0, 0, 0x000000F8, *0000000DAD8FDC70 = 0xE00FF003 ) = 0
0x00001CD4 53603 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE00FFFE0, 4, 0000000DAD8FDC48, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53603 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 53603 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000000, *value = 0x63000052 ) = 0
0x00001CD4 53603 3  XDS110 I: Depth1: DpRegWrite( address = 0x00000008, *value = 0x00000000 ) = 0
0x00001CD4 53603 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe00fffe0 ) = 0
0x00001CD4 53603 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0xe00ff003 = 0
0x00001CD4 53603 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x000000c4 = 0
0x00001CD4 53603 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 53603 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 53603 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE00FFFE0, 4, *0000000DAD8FDC48 = [C4 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 53603 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE00FFFE4, 4, 0000000DAD8FDC44, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53603 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000000 = 0
0x00001CD4 53603 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x000000b4 = 0
0x00001CD4 53603 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE00FFFE4, 4, *0000000DAD8FDC44 = [B4 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 53603 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE00FFFE8, 4, 0000000DAD8FDC40, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53603 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x0000000b = 0
0x00001CD4 53603 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE00FFFE8, 4, *0000000DAD8FDC40 = [0B 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 53603 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE00FFFEC, 4, 0000000DAD8FDC88, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53603 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000000 = 0
0x00001CD4 53603 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE00FFFEC, 4, *0000000DAD8FDC88 = [00 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 53603 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE00FFFD0, 4, 0000000DAD8FDC4C, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53603 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe00fffd0 ) = 0
0x00001CD4 53603 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000004 = 0
0x00001CD4 53603 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE00FFFD0, 4, *0000000DAD8FDC4C = [04 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 53603 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000ED00, 4, 0000000DAD8FDCD0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53619 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000ed00 ) = 0
0x00001CD4 53619 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000004 = 0
0x00001CD4 53619 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x410fc241 = 0
0x00001CD4 53619 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 53619 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 53619 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000ED00, 4, *0000000DAD8FDCD0 = [41 C2 0F 41 ...], 0000000000000000 ) = 0
0x00001CD4 53619 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDCC0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53619 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 53619 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 53619 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x410fc241 = 0
0x00001CD4 53619 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x03050000 = 0
0x00001CD4 53619 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDCC0 = [00 00 05 03 ...], 0000000000000000 ) = 0
0x00001CD4 53619 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDCC0 = [01 00 5F A0 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53619 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 53619 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0xa05f0001 ) = 0
0x00001CD4 53619 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 53619 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDCC0, 0000000000000000 ) = 0
0x00001CD4 53619 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x03050000 = 0
0x00001CD4 53619 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00050001 = 0
0x00001CD4 53619 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDCC0 = [01 00 05 00 ...], 0000000000000000 ) = 0
0x00001CD4 53619 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000ED0C, 4, 0000000DAD8FDDB0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53619 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000ed0c ) = 0
0x00001CD4 53619 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00050001 = 0
0x00001CD4 53619 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0xfa050000 = 0
0x00001CD4 53619 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000ED0C, 4, *0000000DAD8FDDB0 = [00 00 05 FA ...], 0000000000000000 ) = 0
0x00001CD4 53619 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDCD0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53619 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0xfa050000 = 0
0x00001CD4 53619 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDCD0 = [01 00 05 00 ...], 0000000000000000 ) = 0
0x00001CD4 53619 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDC90, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53619 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDC90 = [01 00 05 00 ...], 0000000000000000 ) = 0
0x00001CD4 53619 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDC40, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53619 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDC40 = [01 00 05 00 ...], 0000000000000000 ) = 0
0x00001CD4 53619 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDC90 = [03 00 5F A0 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53619 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0xa05f0003 ) = 0
0x00001CD4 53619 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDC90, 0000000000000000 ) = 0
0x00001CD4 53619 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDC98, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53634 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 53634 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00050001 = 0
0x00001CD4 53634 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 53634 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 53634 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 53634 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDC98 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 53634 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDFC, 4, 0000000DAD8FDC98, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53634 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 53634 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edfc ) = 0
0x00001CD4 53634 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 53634 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000000 = 0
0x00001CD4 53634 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDFC, 4, *0000000DAD8FDC98 = [00 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 53634 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDFC, 4, *0000000DAD8FDC98 = [01 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53634 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 53634 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000001 ) = 0
0x00001CD4 53634 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 53634 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDFC, 4, 0000000DAD8FDC98, 0000000000000000 ) = 0
0x00001CD4 53634 3  CMAPI C: GetStatus( 000001BD35050D30, 0000000DAD8FDC90 )
0x00001CD4 53634 3  CMAPI R: GetStatus( 000001BD35050D30, *0000000DAD8FDC90 = { 1, 1, 1, 1, 1 } ) = 0
0x00001CD4 53634 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDCC8, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53634 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000000 = 0
0x00001CD4 53634 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDCC8 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 53634 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDFC, 4, 0000000DAD8FDC48, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53634 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000001 = 0
0x00001CD4 53634 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDFC, 4, *0000000DAD8FDC48 = [01 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 53634 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDFC, 4, *0000000DAD8FDC48 = [01 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53634 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDFC, 4, 0000000DAD8FDC48, 0000000000000000 ) = 0
0x00001CD4 53634 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000ED30, 4, 0000000DAD8FDCA0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53634 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000ed30 ) = 0
0x00001CD4 53634 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000001 = 0
0x00001CD4 53634 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000ED30, 4, *0000000DAD8FDCA0 = [01 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 53634 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000ED30, 4, *0000000DAD8FDCA0 = [01 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53634 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000ED30, 4, 0000000DAD8FDCA0, 0000000000000000 ) = 0
0x00001CD4 53634 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [00 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53634 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 53634 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000000 ) = 0
0x00001CD4 53634 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDC10, 0000000000000000 ) = 0
0x00001CD4 53634 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDBB0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53634 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDBB0 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 53634 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E38894, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53650 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 53650 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 53650 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000000 = 0
0x00001CD4 53650 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 53650 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 53650 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E38894 = [00 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 53650 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [01 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53650 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 53650 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 53650 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000001 ) = 0
0x00001CD4 53650 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 53650 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDC10, 0000000000000000 ) = 0
0x00001CD4 53650 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDBB0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53650 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 53650 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 53650 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000000 = 0
0x00001CD4 53650 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 53650 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDBB0 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 53650 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E38898, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53650 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000004 = 0
0x00001CD4 53650 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E38898 = [04 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 53650 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [02 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53650 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000002 ) = 0
0x00001CD4 53650 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000004 = 0
0x00001CD4 53650 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E3889C, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53650 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x40030000 = 0
0x00001CD4 53650 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E3889C = [00 00 03 40 ...], 0000000000000000 ) = 0
0x00001CD4 53650 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [03 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53650 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000003 ) = 0
0x00001CD4 53650 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x40030000 = 0
0x00001CD4 53650 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388A0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53650 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000005 = 0
0x00001CD4 53650 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388A0 = [05 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 53650 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [04 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53666 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 53666 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000004 ) = 0
0x00001CD4 53666 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 53666 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 53666 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDC10, 0000000000000000 ) = 0
0x00001CD4 53666 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDBB0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53666 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 53666 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 53666 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000005 = 0
0x00001CD4 53666 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 53666 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 53666 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDBB0 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 53666 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388A4, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53666 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 53666 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 53666 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x40090000 = 0
0x00001CD4 53666 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388A4 = [00 00 09 40 ...], 0000000000000000 ) = 0
0x00001CD4 53666 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [05 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53666 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 53666 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000005 ) = 0
0x00001CD4 53666 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x40090000 = 0
0x00001CD4 53666 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388A8, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53666 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x40030000 = 0
0x00001CD4 53666 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388A8 = [00 00 03 40 ...], 0000000000000000 ) = 0
0x00001CD4 53666 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [06 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53666 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000006 ) = 0
0x00001CD4 53666 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x40030000 = 0
0x00001CD4 53666 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388AC, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53666 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000003 = 0
0x00001CD4 53666 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388AC = [03 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 53666 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [07 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53666 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000007 ) = 0
0x00001CD4 53681 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 53681 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000003 = 0
0x00001CD4 53681 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 53681 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 53681 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 53681 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDBB0 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 53681 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388B0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53681 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 53681 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 53681 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 53681 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000000 = 0
0x00001CD4 53681 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388B0 = [00 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 53681 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [08 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53681 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 53681 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 53681 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000008 ) = 0
0x00001CD4 53681 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 53681 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDC10, 0000000000000000 ) = 0
0x00001CD4 53681 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDBB0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53681 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000000 = 0
0x00001CD4 53681 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388B4, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53681 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00000001 = 0
0x00001CD4 53681 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388B4 = [01 00 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 53681 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [09 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53681 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000009 ) = 0
0x00001CD4 53681 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00000001 = 0
0x00001CD4 53681 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388B8, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53681 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x40092000 = 0
0x00001CD4 53681 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388B8 = [00 20 09 40 ...], 0000000000000000 ) = 0
0x00001CD4 53681 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [0A 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53681 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x0000000a ) = 0
0x00001CD4 53697 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 53697 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x40092000 = 0
0x00001CD4 53697 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 53697 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 53697 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 53697 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDBB0 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 53697 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388BC, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53697 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 53697 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 53697 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 53697 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x40090000 = 0
0x00001CD4 53697 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388BC = [00 00 09 40 ...], 0000000000000000 ) = 0
0x00001CD4 53697 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [0B 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53697 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 53697 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 53697 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x0000000b ) = 0
0x00001CD4 53697 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 53697 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDC10, 0000000000000000 ) = 0
0x00001CD4 53697 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDBB0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53697 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x40090000 = 0
0x00001CD4 53697 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388C0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53697 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x0400000d = 0
0x00001CD4 53697 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388C0 = [0D 00 00 04 ...], 0000000000000000 ) = 0
0x00001CD4 53697 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [0C 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53697 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x0000000c ) = 0
0x00001CD4 53697 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x0400000d = 0
0x00001CD4 53697 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388C4, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53697 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00006000 = 0
0x00001CD4 53697 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388C4 = [00 60 00 00 ...], 0000000000000000 ) = 0
0x00001CD4 53697 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [0D 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53697 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x0000000d ) = 0
0x00001CD4 53697 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00006000 = 0
0x00001CD4 53697 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388C8, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53712 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 53712 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 53712 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x11001ff0 = 0
0x00001CD4 53712 3  XDS110 I: Depth0: DpRegRead( address = 0x00000004 ) -> 0xf0000000 = 0
0x00001CD4 53712 3  XDS110 R: Executed command 0x13 (CMAPI_MEMREAD), return code: 0x00000000
0x00001CD4 53712 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388C8 = [F0 1F 00 11 ...], 0000000000000000 ) = 0
0x00001CD4 53712 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [0E 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53712 3  XDS110 C: Executing command 0x14 (CMAPI_MEMWRITE)
0x00001CD4 53712 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf4 ) = 0
0x00001CD4 53712 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x0000000e ) = 0
0x00001CD4 53712 3  XDS110 R: Executed command 0x14 (CMAPI_MEMWRITE), return code: 0x00000000
0x00001CD4 53712 3  CMAPI R: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, 0000000DAD8FDC10, 0000000000000000 ) = 0
0x00001CD4 53712 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, 0000000DAD8FDBB0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53712 3  XDS110 C: Executing command 0x13 (CMAPI_MEMREAD)
0x00001CD4 53712 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf0 ) = 0
0x00001CD4 53712 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x11001ff0 = 0
0x00001CD4 53712 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x00030003 = 0
0x00001CD4 53712 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF0, 4, *0000000DAD8FDBB0 = [03 00 03 00 ...], 0000000000000000 ) = 0
0x00001CD4 53712 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388CC, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53712 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x100011d1 = 0
0x00001CD4 53712 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388CC = [D1 11 00 10 ...], 0000000000000000 ) = 0
0x00001CD4 53712 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [0F 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53712 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x0000000f ) = 0
0x00001CD4 53712 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x100011d1 = 0
0x00001CD4 53712 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388D0, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53712 3  XDS110 I: Depth0: FinalRdbuff( address = 0x0000000c ) -> 0x1000118e = 0
0x00001CD4 53712 3  CMAPI R: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, *000001BD29E388D0 = [8E 11 00 10 ...], 0000000000000000 ) = 0
0x00001CD4 53712 3  CMAPI C: MemWrite( 000001BD35050D30, 0, 0xE000EDF4, 4, *0000000DAD8FDC10 = [10 00 00 00 ...], *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53712 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x0000000c, *value = 0x00000010 ) = 0
0x00001CD4 53712 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, address = 0x0000000c ) -> 0x1000118e = 0
0x00001CD4 53712 3  CMAPI C: MemRead( 000001BD35050D30, 0, 0xE000EDF8, 4, 000001BD29E388D4, *0000000000000000 = { 0, 1, 0 } )
0x00001CD4 53728 3  XDS110 I: Depth0: ApRegWrite( apNumber = 0, address = 0x00000004, *value = 0xe000edf8 ) = 0
0x00001CD4 53728 3  XDS110 I: Depth0: ApRegRead( apNumber = 0, addr
