Part Number: CC2642R
The PCB trace antenna is used with CC2642R. As current choice, SWRU120D is choosed as target design. But as checked in the reference design, the dxf file in document 'swrr034c' use the wrong parameters. It looks like the dxf used unit inch to replace mil by mistake. In the meanwhile, the unit in the gerber file is correct.
Could you please check if it's the true?
And give me your proposal if there is one.
Thnaks.
