Hello Team ,
Good day,
Best Regards
James Man
Hello Team ,
Good day,
Best Regards
James Man
I assume you are referring to SmartRF Flashprogrammer 2 and not SmartRF Flash programmer?
What SDK version are you using
Which tools are you using
which example are you trying to download
Have you done manual changes to the code?
If yes, are you having trouble downloading one of our default examples?
Please give as much details as possible so that we can try to re-create the issue here.
Siri
Hi Siri,
Best Regards
James Man
Hi James
It is still not clear to me exactly what you are trying to do, and why.
Why do you need to enable the Bootloader? This is not necessary to download the file using the flash programmer 2.
You say that you change ccfg via sysconfig. Are you then referring to enabling the bootloader or are you changing anything else?
What is the demo code you are referring to? Is this the modified buttonLed code or something else?
You should be able to take any of our examples, build them and the download the .out file without any issues.
Regarding the bootloader, if you need it for a reason, you can look through this document.
https://www.ti.com/lit/an/swra466
Siri
Hi Siri,
Good day,
Best Regards
James Man
I do not know what can cause the behavior you are referring to and will not be able to provide any more support unless we can get a details description on what is being done, and why.
Start by using one of our default examples and verify that they work as they should.
Then do the changes that you want to do (and explain why you do them, as I still do not know why you are playing around with the Bootloader settings, and what other CCFG settings are being changed).
Once we can do the same changes as you are doing to one of our SDK examples, and reproduce the issue, we can try to figure out why it is behaving the way it does.
Siri
Hi siri,
Good day,
the project can be downloaded multiple times on CC1352R1 eval board, but we are able to flash it only once in
custom board.
Regarding Sample code: Due to having limited boards, and some board getting locked / unable to program,
we are not taking risk to download any code before knowing the exact cause of it
Best Regards
James Man
