Hi,team:
Can "persistent_app" program space be larger than user program space?
Is there a limit requirement for flash partitioning?
thank you
Hi,team:
thank you
Thanks for reaching out!
A: Yes, the "persistent_app" program space may be larger; however, you may have to decrease the program size of the user program space. In other words, you must be mindful of how much heap size there is for both application stacks.
Here is a good resource for debugging heap and stack issues that may arise, and help you figure out the minimum size requirements for your application. Additionally, here is a resource for heap configuration.
A: Do you mind clarifying what you mean by limit requirement?
If you are talking about the block sizes of the flash, it's 8kB. You can find more information on our user's guide, section 8.7 in the CC2642R-Q1 datasheet, and section 8.5 in the Technical Reference Manual.
Nima Behmanesh
