Part Number: BLE-STACK
Hii, i am using CC2340 basic_ble example and changing the advertising name in runtime using UART command and i am able to use do this succesfully but the problem is after changing the scan response or advertising data i am disabling the advertisement using GapAdv_disable to restart the advertisement to take changed data in effet and the code only works once. After that , by giving command on UART the callback function is not triggerd and when i dont use GapAdv_disable function the callback function is triggering every time perfectly. I dont know much about RTOS i am using GapAdv_disable in void *BLEAppUtil_Task(void *arg) in for loop
// Register to the stack and create queue and event
BLEAppUtil_stackRegister();
#ifdef CC23X0
// Set the BD Address
status = osal_snv_read(SNV_ID_ADDR, BUF_LEN, (uint8 *)Address_buf);
if(status != SUCCESS)
HCI_EXT_SetBDADDRCmd(ownAddr);
else
HCI_EXT_SetBDADDRCmd(Address_buf);
#endif
// Init the ble stack
BLEAppUtil_stackInit();
// Application main loop
for (;;)
if(change_addr || Change_name)
Change_name = 0;
status = osal_snv_write(SNV_ID_NAME, NAME_LEN, (uint8 *)buf);
UART2_write(uart, "WRITE FAIL",10 , NULL);
else
for(uint8 i=0;i<9;i++)
prin_sacn_resp_data_1[i+2] = buf[i];
UART2_write(uart, "NAMEdone:",9 , NULL);
status = BLEAppUtil_advStop(peripheralAdvHandle_1);
status = BLEAppUtil_initAdvSet(&peripheralAdvHandle_2, &advSetInitParamsSet_2);
status = BLEAppUtil_advStart(peripheralAdvHandle_2, &advSetStartParamsSet_1);
BLEAppUtil_appEvt_t pAppEvt;
// wait until receive queue message
if (mq_receive(BLEAppUtil_theardEntity.queueHandle, (char*)&pAppEvt, sizeof(pAppEvt), NULL) > 0)
BLEAppUtil_msgHdr_t *pMsgData = (BLEAppUtil_msgHdr_t *)pAppEvt.pData;
bool freeMsg = FALSE;
switch (pAppEvt.event)
case BLEAPPUTIL_EVT_STACK_CALLBACK:
// Set the flag to true to indicate that BLEAppUtil_freeMsg
// should be used to free the msg
freeMsg = TRUE;
switch (pMsgData->event)
case GAP_MSG_EVENT:
BLEAppUtil_processGAPEvents(pMsgData);
break;
case GATT_MSG_EVENT:
BLEAppUtil_processGATTEvents(pMsgData);
break;
case L2CAP_DATA_EVENT:
BLEAppUtil_processL2CAPDataMsg(pMsgData);
break;
case L2CAP_SIGNAL_EVENT:
BLEAppUtil_processL2CAPSignalEvents(pMsgData);
break;
case HCI_GAP_EVENT_EVENT:
BLEAppUtil_processHCIGAPEvents(pMsgData);
break;
case HCI_DATA_EVENT:
BLEAppUtil_processHCIDataEvents(pMsgData);
break;
case HCI_SMP_EVENT_EVENT:
BLEAppUtil_processHCISMPEvents(pMsgData);
break;
case HCI_SMP_META_EVENT_EVENT:
BLEAppUtil_processHCISMPMetaEvents(pMsgData);
break;
case HCI_CTRL_TO_HOST_EVENT:
BLEAppUtil_processHCICTRLToHostEvents(pMsgData);
hciPacket_t *pBuf = (hciPacket_t *)pMsgData;
switch (pBuf->pData[0])
case HCI_ACL_DATA_PACKET:
case HCI_SCO_DATA_PACKET:
BM_free(pBuf->pData);
default:
break;
break;
default:
break;
break;
case BLEAPPUTIL_EVT_ADV_CB_EVENT:
BLEAppUtil_processAdvEventMsg(pMsgData);
if (((BLEAppUtil_AdvEventData_t *)pMsgData)->event != BLEAPPUTIL_ADV_INSUFFICIENT_MEMORY &&
((BLEAppUtil_AdvEventData_t *)pMsgData)->pBuf)
BLEAppUtil_free(((BLEAppUtil_AdvEventData_t *)pMsgData)->pBuf);
break;
case BLEAPPUTIL_EVT_SCAN_CB_EVENT:
BLEAppUtil_processScanEventMsg(pMsgData);
if (((BLEAppUtil_ScanEventData_t *)pMsgData)->event == BLEAPPUTIL_ADV_REPORT &&
((BLEAppUtil_ScanEventData_t *)pMsgData)->pBuf->pAdvReport.pData)
BLEAppUtil_free(((BLEAppUtil_ScanEventData_t *)pMsgData)->pBuf->pAdvReport.pData);
if (((BLEAppUtil_ScanEventData_t *)pMsgData)->event != BLEAPPUTIL_SCAN_INSUFFICIENT_MEMORY &&
((BLEAppUtil_ScanEventData_t *)pMsgData)->pBuf)
BLEAppUtil_free(((BLEAppUtil_ScanEventData_t *)pMsgData)->pBuf);
break;
case BLEAPPUTIL_EVT_PAIRING_STATE_CB:
BLEAppUtil_processPairStateMsg(pMsgData);
break;
case BLEAPPUTIL_EVT_PASSCODE_NEEDED_CB:
BLEAppUtil_processPasscodeMsg(pMsgData);
break;
case BLEAPPUTIL_EVT_CONN_EVENT_CB:
BLEAppUtil_processConnEventMsg(pMsgData);
break;
case BLEAPPUTIL_EVT_CALL_IN_BLEAPPUTIL_CONTEXT:
((BLEAppUtil_CallbackToInvoke_t *)pMsgData)->callback(((BLEAppUtil_CallbackToInvoke_t *)pMsgData)->data);
// Verify that the data is not NULL before freeing it
if(((BLEAppUtil_CallbackToInvoke_t *)pMsgData)->data != NULL)
BLEAppUtil_free(((BLEAppUtil_CallbackToInvoke_t *)pMsgData)->data);
break;
default:
break;
// Free the data
if (pMsgData && freeMsg)
// Use freeMsg
BLEAppUtil_freeMsg(pMsgData);
else if (pMsgData)
// Use free
BLEAppUtil_free(pMsgData);
