CC2640R2F: Scanning Coded PHY Extended Advertisements
Part Number: CC2640R2F
Our application is to receive drone Remote ID data over BLE Coded PHY (125 kbps) Extended Advertisements. The data payload of the Remote ID messages is contained in the extended advertisement. Therefore, we need the ability scan Coded PHY Extended Advertisements and access the data payload contained in the extended advertisement without making a connection to the Bluetooth device that is broadcasting Remote ID data.
We are wondering if this chip and its corresponding SDK support this capability? (If not, can TI suggest a different chip?)
  • Hi Michael,
    What's your currently used SDK? The CC2640R2F can definitely support this feature, it's the example simple_central, you need to use the BLE5 stack to do so.
    Otherwise, the new chip CC2340, will be release in few days and will fit perfectly with your project.
    It will be available on ti.com/cc2340.
