Part Number: CC2640R2L
Hi team,
Here's a request from customer:
When customer was doing the broadcast packet cutting test, he found that the power consumption of the timer was high, which affected his experimental results.
The figure above is a waveform without any processing of the timer event, the working time of the timer is close to 3ms, and the current reaches about 4mA.
The SDK is simplelink_cc2640r2_sdk_4_30_00_08 and the example is modified by C:\ti\simplelink_cc2640r2_sdk_4_30_00_08\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral.
Can you help for checking this point?
Thanks and Regards,
Nick
