Other Parts Discussed in Thread: SYSCONFIG,
I used a board from your company and then the sample code mutil_role, sdk version (simplelink_cc13xx_cc26xx_sdk_7_10_00_98),
and after it was burned, It is possible to search for the mutil_role Bluetooth signal, but RSSI only has -40dBm, how do I turn on the gain signal of 20dBm?
what‘s more,Multi_role_init function Finally, call HCI_EXT_SetRxGainCmd(HCI_EXT_TX_POWER_P2_20_DBM);, or -40dBm after the device runs, No change, how do you change it?
