Part Number: CC2340R5
Does CC2340 support secondary BLE mac address as CC26x2 does? If not, can users use their own BLE address through software? Where to overwrite the BLE address?
Shuyang
Hi Shuyang,
CC2340 has its ID MAC Address directly burned in the silicon, but in sysconfig you should be able to select the device address when you select the random address, make sure you are using an address Bluetooth compliant (CA:00:00:00:CA works properly for instance).
In sysconfig go to BLE> General Configuration > Address Mode
regards,
