Part Number: CC2340R5
Hi TI team,
I am using CC2340R52E0RGER part in my design and I have few queries please answer on that.
It's having internal crystal oscillator (32.768khz and 48Mhz). So do we require external crystal in any case and if yes than why?
For 32khz crystal, load capacitor are recommended 12pf and 15pf, Is that correct ?
For external 48Mhz crystal oscillator load capacitor suggest do not mount. Is that correct ? and when we have internal 48Mhz cap and its a BLE SOC then why external crystal recommended for radio communication
We operate this device directly by low voltage battery (3V). In that VDDS should be directly connected with battery. what about VDDR ? do we need to provide any voltage on that pin ?
Can we connect VDDR with DCDC pin directly (without any inductor and capacitor)?
what is the use of TVS diode at antenna line ?
We are planning to use F-inverted antenna on top side and it's 4 layer PCB. at bottom side we have some metallic part like switches and battery. Can you provide a path for antenna CAD file. Kindly suggest do's and don't, if any.
Munesh Tripathi
