CC2674P10: Chip Antenna Selection
Part Number: CC2674P10
Hello All,
For BLE Class 1, I am using CC2674P10 to achieve 100mtr LOS range. Being a prodigy in RF antenna design, I need support for chip antenna selection. Due to PCB space limitation, I need to go ahead with chip antenna.
I am referring to Antenna Quick selection guide by TI.
Quick support appreciated.
Prafulla S.
  • Prafulla,
    Thanks for you inquiry. I am not entirely sure what type of support you are asking, since chip antennas are quite straightforward to use as long as you follow the manufacturer's recommendations.
    To have an idea about range tied to the antenna gain and range based on the manufacturer's specifications, I point out the RF Range Estimator spreadsheet that we have available at:
    https://www.ti.com/tool/RF-RANGE-ESTIMATOR
    For CC2674P, you can approximate using the CC13x2/CC26x2 radio.
    Hope this helps,
    Rafael
