Part Number: CC2642R
Hi team,
Customer use the GATT_Notification function to send data to simple_central in simple_peripheral. The sending method is to send two packets of data continuously every 10ms.
The configuration is as follows: Max Size of PDU is set to 255, Requested Min Conn. Interval and Requested Max Conn. Interval are set to 10ms.
And now it is found that the data loss is serious. The data customer generates is about 36k/s, and the actual received data is only 22k/s.
Could you please kindly help guide us on how to reduce or avoid data loss?
Thanks a lot!
Wendy
