Part Number: LAUNCHXL-CC2640R2
Other Parts Discussed in Thread: SIMPLELINK-CC2640R2-SDK, , CC2640
I imported the BLE5 Throughput example using the simplelink-cc2640r2-sdk_1_40_00_45 (acquired from https://github.com/TexasInstruments/ble_examples/tree/simplelink_sdk-1.40), and it works great on two LAUNCHXL-CC2640R2 as originally intended. However, I am now trying to incorporate SPI into the throughput_peripheral example so that I can try to transfer data from a sensor to the throughput central device at high transfer rates, but the original data (counter) does not transfer over if the SPI_init() function is called (i.e. instant rate is 0 kb/s -- please refer to PuTTY screenshot shown below) . I have attached the code that yields this outcome for your reference. Any ideas on why this could be?
File: throughput_peripheral.c
@file throughput_peripheral.c
@brief This file contains the Throughput Peripheral sample application for use
with the CC2650 Bluetooth Low Energy Protocol Stack.
Group: CMCU, SCS
Target Device: CC2640R2
Copyright (c) 2013-2017, Texas Instruments Incorporated
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
* Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
its contributors may be used to endorse or promote products derived
from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* INCLUDES
#include <string.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/knl/Clock.h>
#include <ti/sysbios/knl/Event.h>
#include <ti/sysbios/knl/Queue.h>
#include <ti/display/Display.h>
#include <icall.h>
#include "util.h"
/* This Header file contains all BLE API and icall structure definition */
#include "icall_ble_api.h"
#include "devinfoservice.h"
#include "throughput_service.h"
#include "peripheral.h"
#include "board.h"
#include "board_key.h"
#include "throughput_peripheral_menu.h"
#include "throughput_peripheral.h"
* CONSTANTS
// Advertising interval when device is discoverable (units of 625us, 160=100ms)
#define DEFAULT_ADVERTISING_INTERVAL 160
// Limited discoverable mode advertises for 30.72s, and then stops
// General discoverable mode advertises indefinitely
#define DEFAULT_DISCOVERABLE_MODE GAP_ADTYPE_FLAGS_GENERAL
// Minimum connection interval (units of 1.25ms, 80=100ms) if automatic
// parameter update request is enabled
#define DEFAULT_DESIRED_MIN_CONN_INTERVAL 80
// Maximum connection interval (units of 1.25ms, 800=1000ms) if automatic
#define DEFAULT_DESIRED_MAX_CONN_INTERVAL 800
// Slave latency to use if automatic parameter update request is enabled
#define DEFAULT_DESIRED_SLAVE_LATENCY 0
// Supervision timeout value (units of 10ms, 1000=10s) if automatic parameter
// update request is enabled
#define DEFAULT_DESIRED_CONN_TIMEOUT 100
// Whether to enable automatic parameter update request when a connection is
// formed
#define DEFAULT_ENABLE_UPDATE_REQUEST GAPROLE_LINK_PARAM_UPDATE_WAIT_REMOTE_PARAMS
// Connection Pause Peripheral time value (in seconds)
#define DEFAULT_CONN_PAUSE_PERIPHERAL 6
// Application specific event ID for HCI Connection Event End Events
#define SBP_HCI_CONN_EVT_END_EVT 0x0001
// Type of Display to open
#if !defined(Display_DISABLE_ALL)
#if defined(BOARD_DISPLAY_USE_LCD) && (BOARD_DISPLAY_USE_LCD!=0)
#define SBP_DISPLAY_TYPE Display_Type_LCD
#elif defined (BOARD_DISPLAY_USE_UART) && (BOARD_DISPLAY_USE_UART!=0)
#define SBP_DISPLAY_TYPE Display_Type_UART
#else // !BOARD_DISPLAY_USE_LCD && !BOARD_DISPLAY_USE_UART
#define SBP_DISPLAY_TYPE 0 // Option not supported
#endif // BOARD_DISPLAY_USE_LCD && BOARD_DISPLAY_USE_UART
#else // BOARD_DISPLAY_USE_LCD && BOARD_DISPLAY_USE_UART
#define SBP_DISPLAY_TYPE 0 // No Display
#endif // !Display_DISABLE_ALL
// Task configuration
#define SBP_TASK_PRIORITY 1
#ifndef SBP_TASK_STACK_SIZE
#define SBP_TASK_STACK_SIZE 644
#endif
#define SBP_STATE_CHANGE_EVT 0x0001
//#define SBP_CHAR_CHANGE_EVT 0x0002
#define SBP_KEY_CHANGE_EVT 0x0002
// Internal Events for RTOS application
#define SBP_ICALL_EVT ICALL_MSG_EVENT_ID // Event_Id_31
#define SBP_QUEUE_EVT UTIL_QUEUE_EVENT_ID // Event_Id_30
#define SBP_THROUGHPUT_EVT Event_Id_00
#define SBP_PDU_CHANGE_EVT Event_Id_01
#define SBP_PHY_CHANGE_EVT Event_Id_02
#define SBP_ALL_EVENTS (SBP_ICALL_EVT | \
SBP_QUEUE_EVT | \
SBP_THROUGHPUT_EVT | \
SBP_PDU_CHANGE_EVT | \
SBP_PHY_CHANGE_EVT)
// Row numbers
#define SBP_ROW_RESULT TBM_ROW_APP
#define SBP_ROW_STATUS_1 (TBM_ROW_APP + 1)
#define SBP_ROW_STATUS_2 (TBM_ROW_APP + 2)
#define SBP_ROW_STATUS_3 (TBM_ROW_APP + 3)
#define SBP_ROW_ROLESTATE (TBM_ROW_APP + 4)
#define SBP_ROW_BDADDR (TBM_ROW_APP + 5)
#define SBP_ROW_ROLE (TBM_ROW_APP + 6)
// For DLE
#define DLE_MAX_PDU_SIZE 251
#if defined(PHY_LR_CFG)
#define DLE_MAX_TX_TIME 2120
#else
#define DLE_MAX_TX_TIME 17040
#endif
#define DEFAULT_PDU_SIZE 27
#define DEFAULT_TX_TIME 328
// The combined overhead for L2CAP and ATT notification headers
#define TOTAL_PACKET_OVERHEAD 7
#define RECEIVE_BUF_SIZE (516)
* TYPEDEFS
// App event passed from profiles.
typedef struct
appEvtHdr_t hdr; // event header.
} sbpEvt_t;
* GLOBAL VARIABLES
// Display Interface
Display_Handle dispHandle = NULL;
* LOCAL VARIABLES
SPI_Handle masterSpi;
SPI_Params spiParams;
SPI_Transaction transaction;
unsigned char masterRxBuffer[RECEIVE_BUF_SIZE];
unsigned char masterTxBuffer[RECEIVE_BUF_SIZE];
// Entity ID globally used to check for source and/or destination of messages
static ICall_EntityID selfEntity;
// Event globally used to post local events and pend on system and
// local events.
static ICall_SyncHandle syncEvent;
// Queue object used for app messages
static Queue_Struct appMsg;
static Queue_Handle appMsgQueue;
Task_Struct sbpTask;
Char sbpTaskStack[SBP_TASK_STACK_SIZE];
// Profile state and parameters
//static gaprole_States_t gapProfileState = GAPROLE_INIT;
// GAP - SCAN RSP data (max size = 31 bytes)
static uint8_t scanRspData[] =
// complete name
0x12, // length of this data
GAP_ADTYPE_LOCAL_NAME_COMPLETE,
'T',
'h',
'r',
'o',
'u',
'g',
'h',
'p',
'u',
't',
'P',
'e',
'r',
'i',
'p',
'h',
// GAP - Advertisement data (max size = 31 bytes, though this is
// best kept short to conserve power while advertisting)
static uint8_t advertData[] =
// Flags; this sets the device to use limited discoverable
// mode (advertises for 30 seconds at a time) instead of general
// discoverable mode (advertises indefinitely)
0x02, // length of this data
GAP_ADTYPE_FLAGS,
DEFAULT_DISCOVERABLE_MODE | GAP_ADTYPE_FLAGS_BREDR_NOT_SUPPORTED,
// service UUID, to notify central devices what services are included
// in this peripheral
0x03, // length of this data
GAP_ADTYPE_16BIT_MORE, // some of the UUID's, but not all
LO_UINT16(THROUGHPUT_SERVICE_SERV_UUID),
HI_UINT16(THROUGHPUT_SERVICE_SERV_UUID)
// GAP GATT Attributes
static uint8_t attDeviceName[GAP_DEVICE_NAME_LEN] = "Simple Throughput";
// Globals used for ATT Response retransmission
static gattMsgEvent_t *pAttRsp = NULL;
static uint8_t rspTxRetry = 0;
// Flag to Toggle Throughput Demo
static bool throughputOn = false;
// Message counter for Throughput Demo
static uint32 msg_counter = 1;
// Strings for PHY
static uint8_t* phyName[] = {
"1 Mbps", "2 Mbps",
"Coded:S2", "Coded:S8"
// PHY Options
static uint16_t phyOptions = HCI_PHY_OPT_NONE;
* LOCAL FUNCTIONS
static void SimpleBLEPeripheral_init( void );
static void SimpleBLEPeripheral_taskFxn(UArg a0, UArg a1);
static uint8_t SimpleBLEPeripheral_processStackMsg(ICall_Hdr *pMsg);
static uint8_t SimpleBLEPeripheral_processGATTMsg(gattMsgEvent_t *pMsg);
static void SimpleBLEPeripheral_processAppMsg(sbpEvt_t *pMsg);
static void SimpleBLEPeripheral_processStateChangeEvt(gaprole_States_t newState);
static void SimpleBLEPeripheral_processCharValueChangeEvt(uint8_t paramID);
static void SimpleBLEPeripheral_sendAttRsp(void);
static void SimpleBLEPeripheral_freeAttRsp(uint8_t status);
static void SimpleBLEPeripheral_stateChangeCB(gaprole_States_t newState);
static void SimpleBLEPeripheral_charValueChangeCB(uint8_t paramID);
static void SimpleBLEPeripheral_enqueueMsg(uint8_t event, uint8_t state);
static void SBP_throughputOn(void);
static void SBP_throughputOff(void);
void SimpleBLEPeripheral_keyChangeHandler(uint8 keys);
static void SimpleBLEPeripheral_handleKeys(uint8_t keys);
static void SimpleBLEPeripheral_blastData();
* EXTERN FUNCTIONS
extern void AssertHandler(uint8 assertCause, uint8 assertSubcause);
* PROFILE CALLBACKS
// GAP Role Callbacks
static gapRolesCBs_t SimpleBLEPeripheral_gapRoleCBs =
SimpleBLEPeripheral_stateChangeCB // Profile State Change Callbacks
// Throughput GATT Profile Callbacks
static Throughput_ServiceCBs_t SimpleBLEPeripheral_throughputProfileCBs =
SimpleBLEPeripheral_charValueChangeCB // Characteristic value change callback
* PUBLIC FUNCTIONS
* @fn SimpleBLEPeripheral_createTask
* @brief Task creation function for the Simple BLE Peripheral.
* @param None.
* @return None.
void SimpleBLEPeripheral_createTask(void)
Task_Params taskParams;
// Configure task
Task_Params_init(&taskParams);
taskParams.stack = sbpTaskStack;
taskParams.stackSize = SBP_TASK_STACK_SIZE;
taskParams.priority = SBP_TASK_PRIORITY;
Task_construct(&sbpTask, SimpleBLEPeripheral_taskFxn, &taskParams, NULL);
* @fn SimpleBLEPeripheral_init
* @brief Called during initialization and contains application
* specific initialization (ie. hardware initialization/setup,
* table initialization, power up notification, etc), and
* profile initialization/setup.
* @param None.
* @return None.
static void SimpleBLEPeripheral_init(void)
// N0 STACK API CALLS CAN OCCUR BEFORE THIS CALL TO ICall_registerApp
// Register the current thread as an ICall dispatcher application
// so that the application can send and receive messages.
ICall_registerApp(&selfEntity, &syncEvent);
// Create an RTOS queue for message from profile to be sent to app.
appMsgQueue = Util_constructQueue(&appMsg);
dispHandle = Display_open(SBP_DISPLAY_TYPE, NULL);
// Setup the GAP
GAP_SetParamValue(TGAP_CONN_PAUSE_PERIPHERAL, DEFAULT_CONN_PAUSE_PERIPHERAL);
// Setup the GAP Peripheral Role Profile
// For all hardware platforms, device starts advertising upon initialization
uint8_t initialAdvertEnable = TRUE;
// By setting this to zero, the device will go into the waiting state after
// being discoverable for 30.72 second, and will not being advertising again
// until the enabler is set back to TRUE
uint16_t advertOffTime = 0;
uint8_t enableUpdateRequest = DEFAULT_ENABLE_UPDATE_REQUEST;
uint16_t desiredMinInterval = DEFAULT_DESIRED_MIN_CONN_INTERVAL;
uint16_t desiredMaxInterval = DEFAULT_DESIRED_MAX_CONN_INTERVAL;
uint16_t desiredSlaveLatency = DEFAULT_DESIRED_SLAVE_LATENCY;
uint16_t desiredConnTimeout = DEFAULT_DESIRED_CONN_TIMEOUT;
// Set the GAP Role Parameters
GAPRole_SetParameter(GAPROLE_ADVERT_ENABLED, sizeof(uint8_t),
&initialAdvertEnable);
GAPRole_SetParameter(GAPROLE_ADVERT_OFF_TIME, sizeof(uint16_t),
&advertOffTime);
GAPRole_SetParameter(GAPROLE_SCAN_RSP_DATA, sizeof(scanRspData),
scanRspData);
GAPRole_SetParameter(GAPROLE_ADVERT_DATA, sizeof(advertData), advertData);
GAPRole_SetParameter(GAPROLE_PARAM_UPDATE_ENABLE, sizeof(uint8_t),
&enableUpdateRequest);
GAPRole_SetParameter(GAPROLE_MIN_CONN_INTERVAL, sizeof(uint16_t),
&desiredMinInterval);
GAPRole_SetParameter(GAPROLE_MAX_CONN_INTERVAL, sizeof(uint16_t),
&desiredMaxInterval);
GAPRole_SetParameter(GAPROLE_SLAVE_LATENCY, sizeof(uint16_t),
&desiredSlaveLatency);
GAPRole_SetParameter(GAPROLE_TIMEOUT_MULTIPLIER, sizeof(uint16_t),
&desiredConnTimeout);
// Set the GAP Characteristics
GGS_SetParameter(GGS_DEVICE_NAME_ATT, GAP_DEVICE_NAME_LEN, attDeviceName);
// Set advertising interval
uint16_t advInt = DEFAULT_ADVERTISING_INTERVAL;
GAP_SetParamValue(TGAP_LIM_DISC_ADV_INT_MIN, advInt);
GAP_SetParamValue(TGAP_LIM_DISC_ADV_INT_MAX, advInt);
GAP_SetParamValue(TGAP_GEN_DISC_ADV_INT_MIN, advInt);
GAP_SetParamValue(TGAP_GEN_DISC_ADV_INT_MAX, advInt);
// Initialize GATT attributes
GGS_AddService(GATT_ALL_SERVICES); // GAP
GATTServApp_AddService(GATT_ALL_SERVICES); // GATT attributes
DevInfo_AddService(); // Device Information Service
// Setup the Throughput Characteristic Values
// Set Initial Values of Characteristics in GATT Table
uint8_t pdu_size = DEFAULT_PDU_SIZE;
uint8_t phy_supported = LL_PHY_1_MBPS;
Throughput_Service_SetParameter(THROUGHPUT_SERVICE_UPDATE_PDU, sizeof(uint8_t),
&pdu_size);
Throughput_Service_SetParameter(THROUGHPUT_SERVICE_UPDATE_PHY, sizeof(uint8_t),
&phy_supported);
// Initialize the GATT attributes
Throughput_Service_AddService(); // Throughput Service
// Register callbacks with Throughput Profile
Throughput_Service_RegisterAppCBs(&SimpleBLEPeripheral_throughputProfileCBs);
// Register with GAP for HCI/Host messages. This is needed to receive HCI
// events. For more information, see the section in the User's Guide:
// http://software-dl.ti.com/lprf/ble5stack-docs-latest/docs/ble5stack/ble_user_guide/html/ble-stack/hci.html
GAP_RegisterForMsgs(selfEntity);
// Register for GATT local events and ATT Responses pending for transmission
GATT_RegisterForMsgs(selfEntity);
// Init key debouncer
Board_initKeys(SimpleBLEPeripheral_keyChangeHandler);
// Set the title of the main menu
TBM_SET_TITLE(&sbpMenuMain, "Texas Instruments Bluetooth 5 Demo");
// Initialize Two-Button Menu module
tbm_setItemStatus(&sbpMenuMain, TBM_ITEM_NONE, TBM_ITEM_ALL);
tbm_initTwoBtnMenu(dispHandle, &sbpMenuMain, 3, NULL);
// By Default Allow Central to support any and all PHYs
HCI_LE_SetDefaultPhyCmd(LL_PHY_USE_ANY_PHY, LL_PHY_1_MBPS | LL_PHY_2_MBPS| HCI_PHY_CODED, LL_PHY_1_MBPS | LL_PHY_2_MBPS| HCI_PHY_CODED);
// Set the Transmit Power of the Device to +5dBm
HCI_EXT_SetTxPowerCmd(HCI_EXT_TX_POWER_5_DBM);
// Set the RX Gain to be highest
HCI_EXT_SetRxGainCmd(HCI_EXT_RX_GAIN_HIGH);
// Start the Device
VOID GAPRole_StartDevice(&SimpleBLEPeripheral_gapRoleCBs);
* @fn SimpleBLEPeripheral_taskFxn
* @brief Application task entry point for the Simple BLE Peripheral.
* @param a0, a1 - not used.
* @return None.
// Initialize application
SimpleBLEPeripheral_init();
/* Open SPI as master (default) */
SPI_init();
SPI_Params_init(&spiParams);
spiParams.frameFormat = SPI_POL1_PHA1;
spiParams.bitRate = 8000000;
masterSpi = SPI_open(CC2640R2_LAUNCHXL_SPI0, &spiParams);
/* Initialize master SPI transaction structure */
memset((void *) masterRxBuffer, 0, RECEIVE_BUF_SIZE);
transaction.count = 2;
transaction.txBuf = (void *) masterTxBuffer;
transaction.rxBuf = (void *) masterRxBuffer;
// Application main loop
for (;;)
uint32_t events;
// Waits for an event to be posted associated with the calling thread.
// Note that an event associated with a thread is posted when a
// message is queued to the message receive queue of the thread
events = Event_pend(syncEvent, Event_Id_NONE, SBP_ALL_EVENTS,
ICALL_TIMEOUT_FOREVER);
if (events)
ICall_EntityID dest;
ICall_ServiceEnum src;
ICall_HciExtEvt *pMsg = NULL;
if (ICall_fetchServiceMsg(&src, &dest,
(void **)&pMsg) == ICALL_ERRNO_SUCCESS)
uint8 safeToDealloc = TRUE;
if ((src == ICALL_SERVICE_CLASS_BLE) && (dest == selfEntity))
ICall_Stack_Event *pEvt = (ICall_Stack_Event *)pMsg;
// Check for BLE stack events first
if (pEvt->signature == 0xffff)
if (pEvt->event_flag & SBP_HCI_CONN_EVT_END_EVT)
// Try to retransmit pending ATT Response (if any)
SimpleBLEPeripheral_sendAttRsp();
else
// Process inter-task message
safeToDealloc = SimpleBLEPeripheral_processStackMsg((ICall_Hdr *)pMsg);
if (pMsg && safeToDealloc)
ICall_freeMsg(pMsg);
// If RTOS queue is not empty, process app message.
if (events & SBP_QUEUE_EVT)
while (!Queue_empty(appMsgQueue))
sbpEvt_t *pMsg = (sbpEvt_t *)Util_dequeueMsg(appMsgQueue);
if (pMsg)
// Process message.
SimpleBLEPeripheral_processAppMsg(pMsg);
// Free the space from the message.
ICall_free(pMsg);
if (events & SBP_THROUGHPUT_EVT)
// Begin Throughput Demo in App Task
if (events & SBP_PDU_CHANGE_EVT)
// Variables needed
uint8_t newValue = 0;
uint16_t connectionHandle = 0;
// Get Prereq data.
Throughput_Service_GetParameter(THROUGHPUT_SERVICE_UPDATE_PDU, &newValue);
GAPRole_GetParameter(GAPROLE_CONNHANDLE, &connectionHandle);
// DLE HCI command to adjust PDU size
HCI_LE_SetDataLenCmd(connectionHandle, newValue, DLE_MAX_TX_TIME);
if (events & SBP_PHY_CHANGE_EVT)
// Variables needed
// Get Prereq data.
Throughput_Service_GetParameter(THROUGHPUT_SERVICE_UPDATE_PHY, &newValue);
// Which PHY is picked?
static uint8_t phy[] = {
HCI_PHY_1_MBPS, HCI_PHY_2_MBPS, HCI_PHY_CODED, HCI_PHY_CODED
// Swtich to determine PHY options (needed for coded S2 and S8 mode)
switch(newValue)
case 0:
case 1:
break;
case 2:
phyOptions = HCI_PHY_OPT_S2;
break;
case 3:
phyOptions = HCI_PHY_OPT_S8;
break;
// Set this device's Phy Preference on the current connection.
HCI_LE_SetPhyCmd(connectionHandle, LL_PHY_USE_PHY_PARAM, phy[newValue], phy[newValue], phyOptions);
* @fn SimpleBLEPeripheral_processStackMsg
* @brief Process an incoming stack message.
* @param pMsg - message to process
* @return TRUE if safe to deallocate incoming message, FALSE otherwise.
uint8_t safeToDealloc = TRUE;
switch (pMsg->event)
case GATT_MSG_EVENT:
// Process GATT message
safeToDealloc = SimpleBLEPeripheral_processGATTMsg((gattMsgEvent_t *)pMsg);
break;
case HCI_GAP_EVENT_EVENT:
// Process HCI message
switch(pMsg->status)
case HCI_COMMAND_COMPLETE_EVENT_CODE:
// Process HCI Command Complete Event
break;
case HCI_COMMAND_STATUS_EVENT_CODE:
hciEvt_CommandStatus_t *hciStat
= (hciEvt_CommandStatus_t *)pMsg;
if(hciStat->cmdOpcode == HCI_LE_SET_PHY)
Display_print1(dispHandle, SBP_ROW_STATUS_1, 0, "PHY Change Status: %d", hciStat->cmdStatus);
break;
case HCI_BLE_HARDWARE_ERROR_EVENT_CODE:
AssertHandler(HAL_ASSERT_CAUSE_HARDWARE_ERROR,0);
break;
case HCI_LE_EVENT_CODE:
hciEvt_BLEPhyUpdateComplete_t *pPUC
= (hciEvt_BLEPhyUpdateComplete_t*) pMsg;
if (pPUC->BLEEventCode == HCI_BLE_PHY_UPDATE_COMPLETE_EVENT)
if (pPUC->status != SUCCESS)
Display_print0(dispHandle, SBP_ROW_STATUS_1, 0, "PHY Change failure");
else
Display_print0(dispHandle, SBP_ROW_STATUS_1, 0, "PHY Update Complete");
uint8_t index = 0;
switch(pPUC->rxPhy)
case HCI_PHY_1_MBPS:
index = 0;
break;
case HCI_PHY_2_MBPS:
index = 1;
break;
case HCI_PHY_CODED:
if(phyOptions == HCI_PHY_OPT_S2)
index = 2;
else if (phyOptions == HCI_PHY_OPT_S8)
index = 3;
break;
Display_print1(dispHandle, SBP_ROW_STATUS_3, 0, "Current PHY: %s",
phyName[index]);
// Start Throughput
SBP_throughputOn();
if (pPUC->BLEEventCode == HCI_BLE_DATA_LENGTH_CHANGE_EVENT)
// TX PDU Size Updated
hciEvt_BLEDataLengthChange_t *dleEvt = (hciEvt_BLEDataLengthChange_t *)pMsg;
Display_print1(dispHandle, SBP_ROW_STATUS_2, 0, "PDU Size: %dB", dleEvt->maxTxOctets);
// Start Throughput
SBP_throughputOn();
break;
default:
break;
break;
default:
// do nothing
break;
return (safeToDealloc);
* @fn SimpleBLEPeripheral_processGATTMsg
* @brief Process GATT messages and events.
// See if GATT server was unable to transmit an ATT response
if (pMsg->hdr.status == blePending)
// No HCI buffer was available. Let's try to retransmit the response
// on the next connection event.
if (HCI_EXT_ConnEventNoticeCmd(pMsg->connHandle, selfEntity,
SBP_HCI_CONN_EVT_END_EVT) == SUCCESS)
// First free any pending response
SimpleBLEPeripheral_freeAttRsp(FAILURE);
// Hold on to the response message for retransmission
pAttRsp = pMsg;
// Don't free the response message yet
return (FALSE);
else if (pMsg->method == ATT_FLOW_CTRL_VIOLATED_EVENT)
// ATT request-response or indication-confirmation flow control is
// violated. All subsequent ATT requests or indications will be dropped.
// The app is informed in case it wants to drop the connection.
// Display the opcode of the message that caused the violation.
Display_print1(dispHandle, SBP_ROW_RESULT, 0, "FC Violated: %d", pMsg->msg.flowCtrlEvt.opcode);
else if (pMsg->method == ATT_MTU_UPDATED_EVENT)
// MTU size updated
Display_print1(dispHandle, SBP_ROW_RESULT, 0, "MTU Size: %d", pMsg->msg.mtuEvt.MTU);
// Free message payload. Needed only for ATT Protocol messages
GATT_bm_free(&pMsg->msg, pMsg->method);
// It's safe to free the incoming message
return (TRUE);
* @fn SimpleBLEPeripheral_sendAttRsp
* @brief Send a pending ATT response message.
* @param none
* @return none
// See if there's a pending ATT Response to be transmitted
if (pAttRsp != NULL)
uint8_t status;
// Increment retransmission count
rspTxRetry++;
// Try to retransmit ATT response till either we're successful or
// the ATT Client times out (after 30s) and drops the connection.
status = GATT_SendRsp(pAttRsp->connHandle, pAttRsp->method, &(pAttRsp->msg));
if ((status != blePending) && (status != MSG_BUFFER_NOT_AVAIL))
// Disable connection event end notice
HCI_EXT_ConnEventNoticeCmd(pAttRsp->connHandle, selfEntity, 0);
// We're done with the response message
SimpleBLEPeripheral_freeAttRsp(status);
else
// Continue retrying
Display_print1(dispHandle, SBP_ROW_STATUS_1, 0, "Rsp send retry: %d", rspTxRetry);
* @fn SimpleBLEPeripheral_freeAttRsp
* @brief Free ATT response message.
* @param status - response transmit status
* @return none
// See if there's a pending ATT response message
// See if the response was sent out successfully
if (status == SUCCESS)
Display_print1(dispHandle, SBP_ROW_STATUS_1, 0, "Rsp sent retry: %d", rspTxRetry);
else
// Free response payload
GATT_bm_free(&pAttRsp->msg, pAttRsp->method);
Display_print1(dispHandle, SBP_ROW_STATUS_1, 0, "Rsp retry failed: %d", rspTxRetry);
// Free response message
ICall_freeMsg(pAttRsp);
// Reset our globals
pAttRsp = NULL;
rspTxRetry = 0;
* @fn SimpleBLEPeripheral_processAppMsg
* @brief Process an incoming callback from a profile.
* @return None.
switch (pMsg->hdr.event)
case SBP_STATE_CHANGE_EVT:
SimpleBLEPeripheral_processStateChangeEvt((gaprole_States_t)pMsg->
hdr.state);
break;
// case SBP_CHAR_CHANGE_EVT:
// SimpleBLEPeripheral_processCharValueChangeEvt(pMsg->hdr.state);
// break;
case SBP_KEY_CHANGE_EVT:
SimpleBLEPeripheral_handleKeys(pMsg->hdr.state);
break;
default:
// Do nothing.
break;
* @fn SimpleBLEPeripheral_stateChangeCB
* @brief Callback from GAP Role indicating a role state change.
* @param newState - new state
* @return None.
SimpleBLEPeripheral_enqueueMsg(SBP_STATE_CHANGE_EVT, newState);
* @fn SimpleBLEPeripheral_processStateChangeEvt
* @brief Process a pending GAP Role state change event.
* @return None.
switch ( newState )
case GAPROLE_STARTED:
uint8_t ownAddress[B_ADDR_LEN];
uint8_t systemId[DEVINFO_SYSTEM_ID_LEN];
GAPRole_GetParameter(GAPROLE_BD_ADDR, ownAddress);
// use 6 bytes of device address for 8 bytes of system ID value
systemId[0] = ownAddress[0];
systemId[1] = ownAddress[1];
systemId[2] = ownAddress[2];
// set middle bytes to zero
systemId[4] = 0x00;
systemId[3] = 0x00;
// shift three bytes up
systemId[7] = ownAddress[5];
systemId[6] = ownAddress[4];
systemId[5] = ownAddress[3];
DevInfo_SetParameter(DEVINFO_SYSTEM_ID, DEVINFO_SYSTEM_ID_LEN, systemId);
// Display device address
Display_print1(dispHandle, SBP_ROW_BDADDR, 0, "This Device's BDADDR : %s", Util_convertBdAddr2Str(ownAddress));
Display_print0(dispHandle, SBP_ROW_ROLESTATE, 0, "GAP STATE: Initialized");
Display_print0(dispHandle, SBP_ROW_ROLE, 0, "Device GAP Role: Peripheral");
break;
case GAPROLE_ADVERTISING:
Display_print0(dispHandle, SBP_ROW_ROLESTATE, 0, "Advertising");
break;
case GAPROLE_CONNECTED:
linkDBInfo_t linkInfo;
uint8_t numActive = 0;
numActive = linkDB_NumActive();
// Use numActive to determine the connection handle of the last
// connection
if ( linkDB_GetInfo( numActive - 1, &linkInfo ) == SUCCESS )
Display_print1(dispHandle, SBP_ROW_ROLESTATE, 0, "Num Conns: %d", (uint16_t)numActive);
Display_print0(dispHandle, SBP_ROW_STATUS_1, 0, Util_convertBdAddr2Str(linkInfo.addr));
else
uint8_t peerAddress[B_ADDR_LEN];
GAPRole_GetParameter(GAPROLE_CONN_BD_ADDR, peerAddress);
Display_print0(dispHandle, SBP_ROW_ROLESTATE, 0, "Connected");
Display_print0(dispHandle, SBP_ROW_STATUS_1, 0, Util_convertBdAddr2Str(peerAddress));
tbm_setItemStatus(&sbpMenuMain, TBM_ITEM_ALL, TBM_ITEM_NONE);
break;
case GAPROLE_CONNECTED_ADV:
Display_print0(dispHandle, SBP_ROW_ROLESTATE, 0, "Connected Advertising");
break;
case GAPROLE_WAITING:
SimpleBLEPeripheral_freeAttRsp(bleNotConnected);
Display_print0(dispHandle, SBP_ROW_ROLESTATE, 0, "Disconnected");
// Disable PHY change
// Clear remaining lines
Display_clearLines(dispHandle, SBP_ROW_RESULT, SBP_ROW_STATUS_2);
Display_clearLines(dispHandle, SBP_ROW_RESULT, SBP_ROW_STATUS_3);
break;
case GAPROLE_WAITING_AFTER_TIMEOUT:
Display_print0(dispHandle, SBP_ROW_RESULT, 0, "Timed Out");
Display_clearLines(dispHandle, SBP_ROW_STATUS_1, SBP_ROW_STATUS_2);
break;
case GAPROLE_ERROR:
Display_print0(dispHandle, SBP_ROW_RESULT, 0, "Error");
break;
default:
break;
// Update the state
//gapProfileState = newState;
* @fn SimpleBLEPeripheral_charValueChangeCB
* @brief Callback from Simple Profile indicating a characteristic
* value change.
* @param paramID - parameter ID of the value that was changed.
* @return None.
// If we wish to process the message in the Application Context
// We would utilize inter process communications such as below
// SimpleBLEPeripheral_enqueueMsg(SBP_CHAR_CHANGE_EVT, paramID);
// However, due to the throughput taking up all application task
// processor time, we'll process the value change in the stack
// context: here
SimpleBLEPeripheral_processCharValueChangeEvt(paramID);
// Note that if this takes too long, BLE connect can drop
// This needs to be minimized to allow the stack to continue
// to function correctly
* @fn SimpleBLEPeripheral_processCharValueChangeEvt
* @brief Process a pending Simple Profile characteristic value change
* event.
* @param paramID - parameter index of characteristic changed
* @return None.
switch(paramID)
case THROUGHPUT_SERVICE_UPDATE_PDU:
// Turn off Throughput - to allow application to process profile value change
SBP_throughputOff();
// Inform Application to update PDU
Event_post(syncEvent, SBP_PDU_CHANGE_EVT);
break;
case THROUGHPUT_SERVICE_UPDATE_PHY:
Event_post(syncEvent, SBP_PHY_CHANGE_EVT);
break;
case THROUGHPUT_SERVICE_TOGGLE_THROUGHPUT:
// Turn on Throughput - Turns on Throughput
SimpleBLEPeripheral_doThroughputDemo(0);
break;
default:
// should not reach here!
break;
* @fn SimpleBLEPeripheral_keyChangeHandler
* @brief Key event handler function
* @param keys - bitmap of pressed keys
* @return none
SimpleBLEPeripheral_enqueueMsg(SBP_KEY_CHANGE_EVT, keys);
* @fn SimpleBLEPeripheral_enqueueMsg
* @brief Creates a message and puts the message in RTOS queue.
* @param event - message event.
* @param state - message state.
* @return None.
sbpEvt_t *pMsg;
// Create dynamic pointer to message.
if ((pMsg = ICall_malloc(sizeof(sbpEvt_t))))
pMsg->hdr.event = event;
pMsg->hdr.state = state;
// Enqueue the message.
Util_enqueueMsg(appMsgQueue, syncEvent, (uint8*)pMsg);
* @fn SimpleBLEPeripheral_handleKeys
* @brief Handles all key events for this device.
* @param keys - bit field for key events. Valid entries:
* KEY_LEFT
* KEY_RIGHT
* @return none
if (keys & KEY_LEFT)
// Check if the key is still pressed. WA for possible bouncing.
if (PIN_getInputValue(Board_PIN_BUTTON0) == 0)
tbm_buttonLeft();
else if (keys & KEY_RIGHT)
if (PIN_getInputValue(Board_PIN_BUTTON1) == 0)
tbm_buttonRight();
* @fn SimpleBLEPeripheral_doSetPhy
* @brief Set PHY preference.
* @param index - 0, 1, 2(, 3, 4)
* @return always true
bool SimpleBLEPeripheral_doSetPhy(uint8 index)
uint8_t gapRoleState;
uint16_t connectionHandle;
"1 Mbps", "2 Mbps",
"Coded:S2", "Coded:S8",
HCI_PHY_CODED, HCI_PHY_CODED,
static uint8_t options[] = {
HCI_PHY_OPT_NONE, HCI_PHY_OPT_NONE,
HCI_PHY_OPT_S2, HCI_PHY_OPT_S8,
// Turn off Throughput while operation is in progress
// Assign phyOptions
phyOptions = options[index];
GAPRole_GetParameter(GAPROLE_STATE, &gapRoleState);
// Set Phy Preference on the current connection. Apply the same value
// for RX and TX.
HCI_LE_SetPhyCmd(connectionHandle, 0, phy[index], phy[index], phyOptions);
Display_print1(dispHandle, SBP_ROW_RESULT, 0, "PHY preference: %s", phyName[index]);
Display_clearLine(dispHandle, SBP_ROW_STATUS_1);
return true;
* @fn SimpleBLEPeripheral_doSetDLEPDU
* @brief Set PDU preference.
bool SimpleBLEPeripheral_doSetDLEPDU(uint8 index)
// Vars to keep track of active packet length settings
uint16_t txOctets;
uint16_t txTime;
switch (index)
case 0:
txOctets = DEFAULT_PDU_SIZE;
txTime = DEFAULT_TX_TIME;
break;
case 1:
txOctets = DLE_MAX_PDU_SIZE;
txTime = DLE_MAX_TX_TIME;
break;
// Get GAP Params
if (GAPROLE_CONNECTED == gapRoleState)
HCI_LE_SetDataLenCmd(connectionHandle, txOctets, txTime);
else
// if not connected, write suggested default
HCI_LE_WriteSuggestedDefaultDataLenCmd(txOctets, txTime);
if (GAPROLE_INIT == gapRoleState)
// Go to Main Menu
tbm_goTo(&sbpMenuMain);
Display_print1(dispHandle, SBP_ROW_RESULT, 0, "PDU Size preference: %s Bytes",
(txOctets == DEFAULT_PDU_SIZE) ? "27" : "251");
return true;
// Turn on Throughput Demo & signal application
throughputOn = true;
Display_print0(dispHandle, SBP_ROW_RESULT, 0, "Throughput ON");
Event_post(syncEvent, SBP_THROUGHPUT_EVT);
// Turn off Throughput Demo
Display_print0(dispHandle, SBP_ROW_RESULT, 0, "Throughput OFF");
* @fn SimpleBLEPeripheral_doThroughputDemo
bool SimpleBLEPeripheral_doThroughputDemo(uint8 index)
// ignore unused error
(void) index;
if(throughputOn)
else
return true;
* @fn SimpleBLEPeripheral_blastData
* @brief Sends ATT notifications in a tight while loop to demo
* throughput
* @param none
* @return none
// Subtract the total packet overhead of ATT and L2CAP layer from notification payload
uint16_t len = MAX_PDU_SIZE-TOTAL_PACKET_OVERHEAD;
attHandleValueNoti_t noti;
bStatus_t status;
noti.handle = 0x1E;
noti.len = len;
// Store hte connection handle for future reference
while(throughputOn)
// We need to process the app message here in the case of a keypress
if (pMsg)
// Process message.
ICall_free(pMsg);
noti.pValue = (uint8 *)GATT_bm_alloc( connectionHandle, ATT_HANDLE_VALUE_NOTI, GATT_MAX_MTU, &len );
if ( noti.pValue != NULL ) //if allocated
// Place index
noti.pValue[0] = (msg_counter >> 24) & 0xFF;
noti.pValue[1] = (msg_counter >> 16) & 0xFF;
noti.pValue[2] = (msg_counter >> 8) & 0xFF;
noti.pValue[3] = msg_counter & 0xFF;
// Attempt to send the notification w/ no authentication
status = GATT_Notification( connectionHandle, ¬i, 0);
if ( status != SUCCESS ) //if noti not sent
GATT_bm_free( (gattMsg_t *)¬i, ATT_HANDLE_VALUE_NOTI );
else
// Notification is successfully sent, increment counters
msg_counter++;
else
// bleNoResources was returned
asm(" NOP ");
Thank you,
Imran
