Other Parts Discussed in Thread: SYSCONFIG, SYSBIOS
I am attempting to build tag `lpf2-7.10.01.24` from https://github.com/TexasInstruments/cc13xx_cc26xx_sdk. During the build, I see errors about certain instructions requiring floating-point registers:
SYSCONFIG_TOOL=/opt/ti/sysconfig_1.17.0/sysconfig_cli.sh TICLANG_ARMCOMPILER=/opt/ti/ti_cgt_tiarmclang_2.1.2.LTS CMAKE=/usr/bin/cmake make build-ticlang
-- The ASM compiler identification is ARMClang
-- Found assembler: /opt/ti/ti_cgt_tiarmclang_2.1.2.LTS/bin/tiarmclang
-- Supported platforms: cc13x1, cc26x1, cc13x2, cc26x2, cc13x2x7, cc26x2x7, cc13x4, cc26x3, cc26x4
-- Supported architectures: m4, m4f, m33f
-- Package search paths:
-- /home/pcrowley/projects/701x/xtag/xtag_v4/submodules/cc13xx_cc26xx_sdk/source/cmake/platforms/ticlang
-- /home/pcrowley/projects/701x/xtag/xtag_v4/submodules/cc13xx_cc26xx_sdk/source/cmake/wrappers/ticlang
-- Configuring done (0.2s)
-- Generating done (0.3s)
-- Build files have been written to: /home/pcrowley/projects/701x/xtag/xtag_v4/submodules/cc13xx_cc26xx_sdk/build/ticlang
make[1]: Entering directory '/home/pcrowley/projects/701x/xtag/xtag_v4/submodules/cc13xx_cc26xx_sdk/build/ticlang'
make[2]: Entering directory '/home/pcrowley/projects/701x/xtag/xtag_v4/submodules/cc13xx_cc26xx_sdk/build/ticlang'
make[3]: Entering directory '/home/pcrowley/projects/701x/xtag/xtag_v4/submodules/cc13xx_cc26xx_sdk/build/ticlang'
make[3]: Leaving directory '/home/pcrowley/projects/701x/xtag/xtag_v4/submodules/cc13xx_cc26xx_sdk/build/ticlang'
[ 0%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x1.dir/NoRTOS.c.obj
[ 0%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x1.dir/dpl/posix_sleep.c.obj
[ 0%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x1.dir/dpl/DebugP_nortos.c.obj
[ 0%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x1.dir/dpl/MutexP_nortos.c.obj
[ 0%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x1.dir/dpl/SemaphoreP_nortos.c.obj
[ 1%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x1.dir/dpl/SwiP_nortos.c.obj
[ 1%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x1.dir/dpl/SystemP_nortos.c.obj
[ 1%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x1.dir/dpl/ClockPTimer_nortos.c.obj
[ 1%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x1.dir/dpl/QueueP_nortos.c.obj
[ 1%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x1.dir/dpl/HwiPCC26XX_nortos.c.obj
[ 1%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x1.dir/dpl/PowerCC26X2_nortos.c.obj
[ 1%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x1.dir/dpl/TimerPCC26XX_nortos.c.obj
[ 1%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x1.dir/dpl/TimestampPCC26XX_nortos.c.obj
[ 1%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x1.dir/startup/startup_cc13x1_cc26x1_ticlang.c.obj
[ 1%] Linking C static library lib/ticlang/m4/nortos_cc13x1/nortos_cc13x1.a
[ 1%] Built target nortos_cc13x1
[ 1%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x1.dir/NoRTOS.c.obj
[ 1%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x1.dir/dpl/posix_sleep.c.obj
[ 1%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x1.dir/dpl/DebugP_nortos.c.obj
[ 2%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x1.dir/dpl/MutexP_nortos.c.obj
[ 2%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x1.dir/dpl/SemaphoreP_nortos.c.obj
[ 2%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x1.dir/dpl/SwiP_nortos.c.obj
[ 2%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x1.dir/dpl/SystemP_nortos.c.obj
[ 2%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x1.dir/dpl/ClockPTimer_nortos.c.obj
[ 2%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x1.dir/dpl/QueueP_nortos.c.obj
[ 2%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x1.dir/dpl/HwiPCC26XX_nortos.c.obj
[ 2%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x1.dir/dpl/PowerCC26X2_nortos.c.obj
[ 2%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x1.dir/dpl/TimerPCC26XX_nortos.c.obj
[ 2%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x1.dir/dpl/TimestampPCC26XX_nortos.c.obj
[ 2%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x1.dir/startup/startup_cc13x1_cc26x1_ticlang.c.obj
[ 2%] Linking C static library lib/ticlang/m4/nortos_cc26x1/nortos_cc26x1.a
[ 2%] Built target nortos_cc26x1
[ 2%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2.dir/NoRTOS.c.obj
[ 2%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2.dir/dpl/posix_sleep.c.obj
[ 3%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2.dir/dpl/DebugP_nortos.c.obj
[ 3%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2.dir/dpl/MutexP_nortos.c.obj
[ 3%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2.dir/dpl/SemaphoreP_nortos.c.obj
[ 3%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2.dir/dpl/SwiP_nortos.c.obj
[ 3%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2.dir/dpl/SystemP_nortos.c.obj
[ 3%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2.dir/dpl/ClockPTimer_nortos.c.obj
[ 3%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2.dir/dpl/QueueP_nortos.c.obj
[ 3%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2.dir/dpl/HwiPCC26XX_nortos.c.obj
[ 3%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2.dir/dpl/PowerCC26X2_nortos.c.obj
[ 3%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2.dir/dpl/TimerPCC26XX_nortos.c.obj
[ 3%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2.dir/dpl/TimestampPCC26XX_nortos.c.obj
[ 3%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2.dir/startup/startup_cc13x2_cc26x2_ticlang.c.obj
[ 4%] Linking C static library lib/ticlang/m4f/nortos_cc13x2/nortos_cc13x2.a
[ 4%] Built target nortos_cc13x2
[ 5%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2.dir/NoRTOS.c.obj
[ 5%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2.dir/dpl/posix_sleep.c.obj
[ 5%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2.dir/dpl/DebugP_nortos.c.obj
[ 5%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2.dir/dpl/MutexP_nortos.c.obj
[ 5%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2.dir/dpl/SemaphoreP_nortos.c.obj
[ 5%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2.dir/dpl/SwiP_nortos.c.obj
[ 5%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2.dir/dpl/SystemP_nortos.c.obj
[ 5%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2.dir/dpl/ClockPTimer_nortos.c.obj
[ 5%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2.dir/dpl/QueueP_nortos.c.obj
[ 5%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2.dir/dpl/HwiPCC26XX_nortos.c.obj
[ 5%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2.dir/dpl/PowerCC26X2_nortos.c.obj
[ 5%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2.dir/dpl/TimerPCC26XX_nortos.c.obj
[ 6%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2.dir/dpl/TimestampPCC26XX_nortos.c.obj
[ 6%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2.dir/startup/startup_cc13x2_cc26x2_ticlang.c.obj
[ 6%] Linking C static library lib/ticlang/m4f/nortos_cc26x2/nortos_cc26x2.a
[ 6%] Built target nortos_cc26x2
[ 6%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2x7.dir/NoRTOS.c.obj
[ 6%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2x7.dir/dpl/posix_sleep.c.obj
[ 6%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2x7.dir/dpl/DebugP_nortos.c.obj
[ 6%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2x7.dir/dpl/MutexP_nortos.c.obj
[ 6%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2x7.dir/dpl/SemaphoreP_nortos.c.obj
[ 6%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2x7.dir/dpl/SwiP_nortos.c.obj
[ 6%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2x7.dir/dpl/SystemP_nortos.c.obj
[ 6%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2x7.dir/dpl/ClockPTimer_nortos.c.obj
[ 6%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2x7.dir/dpl/QueueP_nortos.c.obj
[ 6%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2x7.dir/dpl/HwiPCC26XX_nortos.c.obj
[ 6%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2x7.dir/dpl/PowerCC26X2_nortos.c.obj
[ 7%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2x7.dir/dpl/TimerPCC26XX_nortos.c.obj
[ 7%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2x7.dir/dpl/TimestampPCC26XX_nortos.c.obj
[ 7%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x2x7.dir/startup/startup_cc13x2_cc26x2_ticlang.c.obj
[ 7%] Linking C static library lib/ticlang/m4f/nortos_cc13x2x7/nortos_cc13x2x7.a
[ 7%] Built target nortos_cc13x2x7
[ 7%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2x7.dir/NoRTOS.c.obj
[ 7%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2x7.dir/dpl/posix_sleep.c.obj
[ 7%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2x7.dir/dpl/DebugP_nortos.c.obj
[ 7%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2x7.dir/dpl/MutexP_nortos.c.obj
[ 7%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2x7.dir/dpl/SemaphoreP_nortos.c.obj
[ 7%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2x7.dir/dpl/SwiP_nortos.c.obj
[ 7%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2x7.dir/dpl/SystemP_nortos.c.obj
[ 7%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2x7.dir/dpl/ClockPTimer_nortos.c.obj
[ 7%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2x7.dir/dpl/QueueP_nortos.c.obj
[ 8%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2x7.dir/dpl/HwiPCC26XX_nortos.c.obj
[ 8%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2x7.dir/dpl/PowerCC26X2_nortos.c.obj
[ 8%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2x7.dir/dpl/TimerPCC26XX_nortos.c.obj
[ 8%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2x7.dir/dpl/TimestampPCC26XX_nortos.c.obj
[ 8%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x2x7.dir/startup/startup_cc13x2_cc26x2_ticlang.c.obj
[ 8%] Linking C static library lib/ticlang/m4f/nortos_cc26x2x7/nortos_cc26x2x7.a
[ 8%] Built target nortos_cc26x2x7
[ 8%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4.dir/NoRTOS.c.obj
[ 8%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4.dir/dpl/posix_sleep.c.obj
[ 8%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4.dir/dpl/DebugP_nortos.c.obj
[ 8%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4.dir/dpl/MutexP_nortos.c.obj
[ 8%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4.dir/dpl/SemaphoreP_nortos.c.obj
[ 8%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4.dir/dpl/SwiP_nortos.c.obj
[ 8%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4.dir/dpl/SystemP_nortos.c.obj
[ 8%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4.dir/dpl/ClockPTimer_nortos.c.obj
[ 8%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4.dir/dpl/QueueP_nortos.c.obj
[ 9%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4.dir/dpl/HwiPCC26XX_nortos.c.obj
[ 9%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4.dir/dpl/PowerCC26X2_nortos.c.obj
[ 9%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4.dir/dpl/TimerPCC26XX_nortos.c.obj
[ 9%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4.dir/dpl/TimestampPCC26XX_nortos.c.obj
[ 9%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4.dir/startup/startup_cc13x4_cc26x4_ticlang.c.obj
[ 9%] Linking C static library lib/ticlang/m33f/nortos_cc13x4/nortos_cc13x4.a
[ 9%] Built target nortos_cc13x4
[ 9%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4.dir/NoRTOS.c.obj
[ 9%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4.dir/dpl/posix_sleep.c.obj
[ 9%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4.dir/dpl/DebugP_nortos.c.obj
[ 9%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4.dir/dpl/MutexP_nortos.c.obj
[ 9%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4.dir/dpl/SemaphoreP_nortos.c.obj
[ 9%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4.dir/dpl/SwiP_nortos.c.obj
[ 10%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4.dir/dpl/SystemP_nortos.c.obj
[ 10%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4.dir/dpl/ClockPTimer_nortos.c.obj
[ 10%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4.dir/dpl/QueueP_nortos.c.obj
[ 10%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4.dir/dpl/HwiPCC26XX_nortos.c.obj
[ 10%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4.dir/dpl/PowerCC26X2_nortos.c.obj
[ 10%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4.dir/dpl/TimerPCC26XX_nortos.c.obj
[ 10%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4.dir/dpl/TimestampPCC26XX_nortos.c.obj
[ 10%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4.dir/startup/startup_cc13x4_cc26x4_ticlang.c.obj
[ 10%] Linking C static library lib/ticlang/m33f/nortos_cc26x4/nortos_cc26x4.a
[ 10%] Built target nortos_cc26x4
[ 10%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4_ns.dir/NoRTOS.c.obj
[ 10%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4_ns.dir/dpl/posix_sleep.c.obj
[ 10%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4_ns.dir/dpl/DebugP_nortos.c.obj
[ 10%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4_ns.dir/dpl/MutexP_nortos.c.obj
[ 10%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4_ns.dir/dpl/SemaphoreP_nortos.c.obj
[ 10%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4_ns.dir/dpl/SwiP_nortos.c.obj
[ 11%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4_ns.dir/dpl/SystemP_nortos.c.obj
[ 11%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4_ns.dir/dpl/ClockPTimer_nortos.c.obj
[ 11%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4_ns.dir/dpl/QueueP_nortos.c.obj
[ 11%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4_ns.dir/dpl/HwiPCC26XX_nortos.c.obj
[ 11%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4_ns.dir/dpl/PowerCC26X2_nortos.c.obj
[ 11%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4_ns.dir/dpl/TimerPCC26XX_nortos.c.obj
[ 11%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4_ns.dir/dpl/TimestampPCC26XX_nortos.c.obj
[ 11%] Building C object kernel/nortos/CMakeFiles/nortos_cc13x4_ns.dir/startup/startup_cc13x4_cc26x4_ticlang_ns.c.obj
[ 11%] Linking C static library lib/ticlang/m33f/nortos_cc13x4_ns/nortos_cc13x4_ns.a
[ 11%] Built target nortos_cc13x4_ns
[ 11%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4_ns.dir/NoRTOS.c.obj
[ 11%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4_ns.dir/dpl/posix_sleep.c.obj
[ 11%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4_ns.dir/dpl/DebugP_nortos.c.obj
[ 12%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4_ns.dir/dpl/MutexP_nortos.c.obj
[ 12%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4_ns.dir/dpl/SemaphoreP_nortos.c.obj
[ 12%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4_ns.dir/dpl/SwiP_nortos.c.obj
[ 12%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4_ns.dir/dpl/SystemP_nortos.c.obj
[ 12%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4_ns.dir/dpl/ClockPTimer_nortos.c.obj
[ 12%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4_ns.dir/dpl/QueueP_nortos.c.obj
[ 12%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4_ns.dir/dpl/HwiPCC26XX_nortos.c.obj
[ 12%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4_ns.dir/dpl/PowerCC26X2_nortos.c.obj
[ 12%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4_ns.dir/dpl/TimerPCC26XX_nortos.c.obj
[ 12%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4_ns.dir/dpl/TimestampPCC26XX_nortos.c.obj
[ 12%] Building C object kernel/nortos/CMakeFiles/nortos_cc26x4_ns.dir/startup/startup_cc13x4_cc26x4_ticlang_ns.c.obj
[ 12%] Linking C static library lib/ticlang/m33f/nortos_cc26x4_ns/nortos_cc26x4_ns.a
[ 12%] Built target nortos_cc26x4_ns
[ 13%] Building ASM object kernel/tirtos7/packages/ti/sysbios/CMakeFiles/tirtos7_m0p.dir/family/arm/v6m/TaskSupport_asm_gcc.o
tiarmclang: warning: argument unused during compilation: '-D BIOS_mpeEnabled_D=0' [-Wunused-command-line-argument]
tiarmclang: warning: argument unused during compilation: '-D BIOS_smpEnabled_D=0' [-Wunused-command-line-argument]
tiarmclang: warning: argument unused during compilation: '-D Hwi_dispatcherSwiSupport_D' [-Wunused-command-line-argument]
tiarmclang: warning: argument unused during compilation: '-D TaskSupport_usesMonitors__D' [-Wunused-command-line-argument]
tiarmclang: warning: argument unused during compilation: '-std=c11' [-Wunused-command-line-argument]
[ 13%] Building ASM object kernel/tirtos7/packages/ti/sysbios/CMakeFiles/tirtos7_m0p.dir/family/arm/v6m/Hwi_asm_gcc.o
[ 13%] Building ASM object kernel/tirtos7/packages/ti/sysbios/CMakeFiles/tirtos7_m0p.dir/family/arm/v6m/Hwi_asm_switch_gcc.o
[ 13%] Building C object kernel/tirtos7/packages/ti/sysbios/CMakeFiles/tirtos7_m0p.dir/family/arm/vxm/boot/boot_cortex_m.c.obj
[ 13%] Linking C static library lib/ticlang/m0p/sysbios/sysbios.a
[ 13%] Built target tirtos7_m0p
[ 13%] Building ASM object kernel/tirtos7/packages/ti/sysbios/CMakeFiles/tirtos7_m4.dir/family/arm/m3/TaskSupport_asm_gcc.o
/home/pcrowley/projects/701x/xtag/xtag_v4/submodules/cc13xx_cc26xx_sdk/kernel/tirtos7/packages/ti/sysbios/family/arm/m3/TaskSupport_asm_gcc.s:60:9: error: instruction requires: fp registers
vpush {d8-d15}
/home/pcrowley/projects/701x/xtag/xtag_v4/submodules/cc13xx_cc26xx_sdk/kernel/tirtos7/packages/ti/sysbios/family/arm/m3/TaskSupport_asm_gcc.s:77:9: error: instruction requires: fp registers
vpop {d8-d15} @ pop vfp caller regs
make[3]: *** [kernel/tirtos7/packages/ti/sysbios/CMakeFiles/tirtos7_m4.dir/build.make:75: kernel/tirtos7/packages/ti/sysbios/CMakeFiles/tirtos7_m4.dir/family/arm/m3/TaskSupport_asm_gcc.o] Error 1
make[2]: *** [CMakeFiles/Makefile2:679: kernel/tirtos7/packages/ti/sysbios/CMakeFiles/tirtos7_m4.dir/all] Error 2
make[2]: Leaving directory '/home/pcrowley/projects/701x/xtag/xtag_v4/submodules/cc13xx_cc26xx_sdk/build/ticlang'
make[1]: *** [Makefile:136: all] Error 2
make[1]: Leaving directory '/home/pcrowley/projects/701x/xtag/xtag_v4/submodules/cc13xx_cc26xx_sdk/build/ticlang'
make: *** [Makefile:19: build-ticlang] Error 2
What have I done wrong?
Peter
