CC2340R5: CC2340 error in compiling with PWM.
Part Number: CC2340R5
I added PWM configuration in syscfg, and there was an error during compilation.
**** Clean-only build of configuration Release for project basic_ble_LP_EM_CC2340R5_freertos_ticlang ****
"C:\\ti\\ccs1240\\ccs\\utils\\bin\\gmake" -k -j 8 clean -O
DEL /F  "syscfg\ti_ble_config.h" "syscfg\ti_drivers_config.h" "syscfg\ti_utils_build_linker.cmd.genlibs" "syscfg\syscfg_c.rov.xs" "syscfg\FreeRTOSConfig.h"  "syscfg\ti_ble_config.c" "syscfg\ti_build_config.opt" "syscfg\ti_ble_app_config.opt" "syscfg\ti_devices_config.c" "syscfg\ti_drivers_config.c" "syscfg\ti_utils_build_compiler.opt" "syscfg\ti_freertos_config.c" "syscfg\ti_freertos_portable_config.c"  "basic_ble_LP_EM_CC2340R5_freertos_ticlang.out"
DEL /F "syscfg\ti_ble_config.o" "syscfg\ti_devices_config.o" "syscfg\ti_drivers_config.o" "syscfg\ti_freertos_config.o" "syscfg\ti_freertos_portable_config.o" "main_freertos.o" "Startup\rcl_settings_ble.o" "app\Profiles\app_dev_info.o" "app\Profiles\app_simple_gatt.o" "app\app_broadcaster.o" "app\app_central.o" "app\app_connection.o" "app\app_data.o" "app\app_main.o" "app\app_menu.o" "app\app_observer.o" "app\app_pairing.o" "app\app_peripheral.o" "common\BLEAppUtil\bleapputil_init.o" "common\BLEAppUtil\bleapputil_process.o" "common\BLEAppUtil\bleapputil_stack_callbacks.o" "common\BLEAppUtil\bleapputil_task.o" "common\Drivers\NV\crc.o" "common\Drivers\NV\nvocmp.o" "common\MenuModule\menu_module.o" "common\Profiles\simple_gatt\simple_gatt_profile.o" "common\Services\dev_info\dev_info_service.o" "common\Startup\ble_user_config_stack.o" "common\Startup\osal_icall_ble.o" "common\Startup\rom_init.o" "common\iCall\icall_POSIX.o" "common\iCall\icall_cc23x0.o" "common\iCall\icall_user_config.o" "common\iCallBLE\ble_stack_api.o"
DEL /F "common\iCallBLE\ble_user_config.o" "common\iCallBLE\icall_api_lite.o"
DEL /F "syscfg\ti_ble_config.d" "syscfg\ti_devices_config.d" "syscfg\ti_drivers_config.d" "syscfg\ti_freertos_config.d" "syscfg\ti_freertos_portable_config.d" "main_freertos.d" "Startup\rcl_settings_ble.d" "app\Profiles\app_dev_info.d" "app\Profiles\app_simple_gatt.d" "app\app_broadcaster.d" "app\app_central.d" "app\app_connection.d" "app\app_data.d" "app\app_main.d" "app\app_menu.d" "app\app_observer.d" "app\app_pairing.d" "app\app_peripheral.d" "common\BLEAppUtil\bleapputil_init.d" "common\BLEAppUtil\bleapputil_process.d" "common\BLEAppUtil\bleapputil_stack_callbacks.d" "common\BLEAppUtil\bleapputil_task.d" "common\Drivers\NV\crc.d" "common\Drivers\NV\nvocmp.d" "common\MenuModule\menu_module.d" "common\Profiles\simple_gatt\simple_gatt_profile.d" "common\Services\dev_info\dev_info_service.d" "common\Startup\ble_user_config_stack.d" "common\Startup\osal_icall_ble.d" "common\Startup\rom_init.d" "common\iCall\icall_POSIX.d" "common\iCall\icall_cc23x0.d" "common\iCall\icall_user_config.d" "common\iCallBLE\ble_stack_api.d"
DEL /F "common\iCallBLE\ble_user_config.d" "common\iCallBLE\icall_api_lite.d"
RMDIR /S/Q  "syscfg\"
Finished clean
**** Build Finished ****
**** Build of configuration Release for project basic_ble_LP_EM_CC2340R5_freertos_ticlang ****
"C:\\ti\\ccs1240\\ccs\\utils\\bin\\gmake" -k -j 8 all -O
Building file: "../basic_ble.syscfg"
Invoking: SysConfig
"C:/ti/ccs1240/ccs/utils/sysconfig_1.17.0/sysconfig_cli.bat" -s "C:/ti/simplelink_lowpower_f3_sdk_7_20_00_29/.metadata/product.json" --script "F:/wangrenli/project/cc2340/ti_demo_sdk7_20/workspace/basic_ble_LP_EM_CC2340R5_freertos_ticlang/basic_ble.syscfg" -o "syscfg" --compiler ticlang
Running script...
Validating...
warning: /ti/drivers/RNG noiseConditioningKeyW3: This the default noise conditioning key provided by TI, which is acceptable per NIST SP 800-90B. However, TI recommends you change this default value to a custom random value for your product
Generating Code (basic_ble.syscfg)...
subdir_rules.mk:9: recipe for target 'build-33521327' failed
0 error(s), 1 warning(s)
Error: No such resource: /ti/drivers/pwm/PWMTimer.Board.h.xdt
Paths searched:
C:\ti\simplelink_lowpower_f3_sdk_7_20_00_29\source\ti\drivers\pwm\PWMTimer.Board.h.xdt
C:\ti\simplelink_lowpower_f3_sdk_7_20_00_29\source\ti\drivers\pwm\.meta\PWMTimer.Board.h.xdt
C:\ti\simplelink_lowpower_f3_sdk_7_20_00_29\source\ti\drivers\.meta\pwm\PWMTimer.Board.h.xdt
C:\ti\simplelink_lowpower_f3_sdk_7_20_00_29\source\ti\.meta\drivers\pwm\PWMTimer.Board.h.xdt
C:\ti\simplelink_lowpower_f3_sdk_7_20_00_29\source\.meta\ti\drivers\pwm\PWMTimer.Board.h.xdt
C:\ti\simplelink_lowpower_f3_sdk_7_20_00_29\kernel\ti\drivers\pwm\PWMTimer.Board.h.xdt
C:\ti\simplelink_lowpower_f3_sdk_7_20_00_29\kernel\ti\drivers\pwm\.meta\PWMTimer.Board.h.xdt
C:\ti\simplelink_lowpower_f3_sdk_7_20_00_29\kernel\ti\drivers\.meta\pwm\PWMTimer.Board.h.xdt
C:\ti\simplelink_lowpower_f3_sdk_7_20_00_29\kernel\ti\.meta\drivers\pwm\PWMTimer.Board.h.xdt
C:\ti\simplelink_lowpower_f3_sdk_7_20_00_29\kernel\.meta\ti\drivers\pwm\PWMTimer.Board.h.xdt
F:\wangrenli\project\cc2340\ti_demo_sdk7_20\workspace\basic_ble_LP_EM_CC2340R5_freertos_ticlang\ti\drivers\pwm\PWMTimer.Board.h.xdt
F:\wangrenli\project\cc2340\ti_demo_sdk7_20\workspace\basic_ble_LP_EM_CC2340R5_freertos_ticlang\ti\drivers\pwm\.meta\PWMTimer.Board.h.xdt
F:\wangrenli\project\cc2340\ti_demo_sdk7_20\workspace\basic_ble_LP_EM_CC2340R5_freertos_ticlang\ti\drivers\.meta\pwm\PWMTimer.Board.h.xdt
F:\wangrenli\project\cc2340\ti_demo_sdk7_20\workspace\basic_ble_LP_EM_CC2340R5_freertos_ticlang\ti\.meta\drivers\pwm\PWMTimer.Board.h.xdt
F:\wangrenli\project\cc2340\ti_demo_sdk7_20\workspace\basic_ble_LP_EM_CC2340R5_freertos_ticlang\.meta\ti\drivers\pwm\PWMTimer.Board.h.xdt
    at t.ResourceLoader.findPathAndLoader (C:\ti\ccs1240\ccs\utils\sysconfig_1.17.0\dist\webpack:\src\pinmux\services\resources\metaContentLoaders\resourceLoader.ts:287:11)
    at t.ResourceLoader.loadResource (C:\ti\ccs1240\ccs\utils\sysconfig_1.17.0\dist\webpack:\src\pinmux\services\resources\metaContentLoaders\resourceLoader.ts:230:43)
    at t.ResourceLoader.getResource (C:\ti\ccs1240\ccs\utils\sysconfig_1.17.0\dist\webpack:\src\pinmux\services\resources\metaContentLoaders\resourceLoader.ts:338:15)
    at Object.getTemplate (C:\ti\ccs1240\ccs\utils\sysconfig_1.17.0\dist\webpack:\src\pinmux\services\resources\runtime.ts:102:46)
    at templateFunc (C:\ti\simplelink_lowpower_f3_sdk_7_20_00_29\source\ti\drivers\.meta\templates\Board.h.xdt:72:19)
    at func (C:\ti\ccs1240\ccs\utils\sysconfig_1.17.0\dist\webpack:\src\pinmux\services\codeGeneration\templateRunner.ts:29:39)
    at Object.allowPathVisibility (C:\ti\ccs1240\ccs\utils\sysconfig_1.17.0\dist\webpack:\src\pinmux\services\pathsVisibility.ts:11:10)
    at Object.runTemplate (C:\ti\ccs1240\ccs\utils\sysconfig_1.17.0\dist\webpack:\src\pinmux\services\codeGeneration\templateRunner.ts:29:13)
    at t.CodeGenerator.generate (C:\ti\ccs1240\ccs\utils\sysconfig_1.17.0\dist\webpack:\src\pinmux\services\codeGeneration\codeGenerator.ts:115:10)
    at C:\ti\ccs1240\ccs\utils\sysconfig_1.17.0\dist\webpack:\src\pinmux\services\codeGeneration\codeGenerator.ts:120:26
gmake: *** [build-33521327] Error 1
gmake: Target 'all' not remade because of errors.
