Other Parts Discussed in Thread: SYSCONFIG,
Hi ,
We are using the simplelink_lowpower_f3_sdk_7_40_00_64 , which provides the basic ble example which is written using FreeRTOS.
Question #1: Sys config tool get crash when we try to change Advertisement parameter values in sysonfig. Why is that happening? What is the fix for it ?
We want to experiment with the BLE as a broadcaster role. So we selected that in sysconfig. There is a tool crash when we are trying to update the advertising parameter configuration. in sys config
See the below image
Even though the sys config tool crashed. It is generating some default advertisement configuration parameters.
Code was able to compile and i am able to see the adv data.
Question#2:
In order to send our user data in advertisement packet . I was referring
Scanning and Advertising Basics from TI website , it is giving information. about how to change advertisement packet. I tried in similar way for broadcast example. It is crash in
below code line . What is that we are doing wrong. Please provide us with some other example or some other material through which shall help us in achieving this function.
status = GapAdv_prepareLoadByHandle(broadcasterAdvHandle_1, GAP_ADV_FREE_OPTION_DONT_FREE); if (status != SUCCESS) for(;;); // Loop
/** New Code **/ BLEAppUtil_AdvEventData_t * pkt = (BLEAppUtil_AdvEventData_t *)pMsgData; if (pkt->pBuf->advHandle == broadcasterAdvHandle_1) { bStatus_t status = FAILURE; status = GapAdv_prepareLoadByHandle(broadcasterAdvHandle_1, GAP_ADV_FREE_OPTION_DONT_FREE); if (status != SUCCESS) for(;;); // Loop uint8_t ADV_DATA2_LEN = 11; uint8_t *advData2 = ICall_malloc(ADV_DATA2_LEN); advData2[0] = 0x02; advData2[1] = GAP_ADTYPE_FLAGS; advData2[2] = GAP_ADTYPE_FLAGS_BREDR_NOT_SUPPORTED | GAP_ADTYPE_FLAGS_GENERAL; advData2[3] = 0x07; advData2[4] = GAP_ADTYPE_MANUFACTURER_SPECIFIC; advData2[5] = data[0]; advData2[6] = data[1]; advData2[7] = data[2]; advData2[8] = data[3]; advData2[9] = data[4]; advData2[10] = data[5]; broadcasterAdvHandler.eventMask = BLEAPPUTIL_ADV_END_AFTER_DISABLE | BLEAPPUTIL_ADV_SET_TERMINATED; //| BLEAPPUTIL_SCAN_REQ_RECEIVED; data[5] += 0x01; if(data[5] == 0xFF) { data[5] = 0x01; } status = GapAdv_loadByHandle(broadcasterAdvHandle_1, GAP_ADV_DATA_TYPE_ADV, ADV_DATA2_LEN, advData2); if (status != SUCCESS) for(;;); /** End New Code **/ }
attaching the modified source code for your reference
/****************************************************************************** @file app_broadcaster.c @brief This example file demonstrates how to activate the broadcaster role with the help of BLEAppUtil APIs. BroadcasterAdvHandler structure is used for define advertising event handling callback function and eventMask is used to specify the events that will be received and handled. In addition, fill the BLEAppUtil_AdvInit_t structure with variables generated by the Sysconfig. In the events handler functions, write what actions are done after each event. In this example, A message will be printed after enabling/disabling advertising. In the Peripheral_start() function at the bottom of the file, registration, initialization and activation are done using the BLEAppUtil API functions, using the structures defined in the file. More details on the functions and structures can be seen next to the usage. Group: WCS, BTS Target Device: cc23xx ****************************************************************************** Copyright (c) 2022-2023, Texas Instruments Incorporated All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met: * Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer. * Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution. * Neither the name of Texas Instruments Incorporated nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission. THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. ****************************************************************************** *****************************************************************************/ #if defined( HOST_CONFIG ) && ( HOST_CONFIG & ( BROADCASTER_CFG ) ) //***************************************************************************** //! Includes //***************************************************************************** #include "ti_ble_config.h" #include <ti/bleapp/ble_app_util/inc/bleapputil_api.h> #include <ti/bleapp/menu_module/menu_module.h> #include <app_main.h> //***************************************************************************** //! Prototypes //***************************************************************************** void Broadcaster_AdvEventHandler(uint32 event, BLEAppUtil_msgHdr_t *pMsgData); //***************************************************************************** //! Globals //***************************************************************************** BLEAppUtil_EventHandler_t broadcasterAdvHandler = { .handlerType = BLEAPPUTIL_GAP_ADV_TYPE, .pEventHandler = Broadcaster_AdvEventHandler, .eventMask = BLEAPPUTIL_ADV_START_AFTER_ENABLE | BLEAPPUTIL_ADV_END_AFTER_DISABLE }; //! Store handle needed for each advertise set uint8 broadcasterAdvHandle_1; const BLEAppUtil_AdvInit_t broadcasterInitAdvSet1 = { /* Advertise data and length */ .advDataLen = sizeof(advData1), .advData = advData1, /* Scan respond data and length */ .scanRespDataLen = 0, .scanRespData = NULL, .advParam = &advParams1 }; const BLEAppUtil_AdvStart_t broadcasterStartAdvSet1 = { /* Use the maximum possible value. This is the spec-defined maximum for */ /* directed advertising and infinite advertising for all other types */ .enableOptions = GAP_ADV_ENABLE_OPTIONS_USE_MAX, .durationOrMaxEvents = 0 }; //***************************************************************************** //! Functions //***************************************************************************** /********************************************************************* * @fn Broadcaster_AdvEventHandler * * @brief The purpose of this function is to handle advertise events * that rise from the GAP and were registered in * @ref BLEAppUtil_RegisterGAPEvent * * @param event - message event. * @param pMsgData - pointer to message data. * * @return none */ void Broadcaster_AdvEventHandler(uint32 event, BLEAppUtil_msgHdr_t *pMsgData) { #if 1 static char data[6]= {'h','e','l','l','o','1'}; #endif switch(event) { case BLEAPPUTIL_ADV_START_AFTER_ENABLE: { MenuModule_printf(APP_MENU_ADV_EVENT, 0, "Adv status: Started - handle: " MENU_MODULE_COLOR_YELLOW "%d" MENU_MODULE_COLOR_RESET, ((BLEAppUtil_AdvEventData_t *)pMsgData)->pBuf->advHandle); #if 1 /** New Code **/ BLEAppUtil_AdvEventData_t * pkt = (BLEAppUtil_AdvEventData_t *)pMsgData; if (pkt->pBuf->advHandle == broadcasterAdvHandle_1) { bStatus_t status = FAILURE; status = GapAdv_prepareLoadByHandle(broadcasterAdvHandle_1, GAP_ADV_FREE_OPTION_DONT_FREE); if (status != SUCCESS) for(;;); // Loop uint8_t ADV_DATA2_LEN = 11; uint8_t *advData2 = ICall_malloc(ADV_DATA2_LEN); advData2[0] = 0x02; advData2[1] = GAP_ADTYPE_FLAGS; advData2[2] = GAP_ADTYPE_FLAGS_BREDR_NOT_SUPPORTED | GAP_ADTYPE_FLAGS_GENERAL; advData2[3] = 0x07; advData2[4] = GAP_ADTYPE_MANUFACTURER_SPECIFIC; advData2[5] = data[0]; advData2[6] = data[1]; advData2[7] = data[2]; advData2[8] = data[3]; advData2[9] = data[4]; advData2[10] = data[5]; broadcasterAdvHandler.eventMask = BLEAPPUTIL_ADV_END_AFTER_DISABLE | BLEAPPUTIL_ADV_SET_TERMINATED; //| BLEAPPUTIL_SCAN_REQ_RECEIVED; data[5] += 0x01; if(data[5] == 0xFF) { data[5] = 0x01; } status = GapAdv_loadByHandle(broadcasterAdvHandle_1, GAP_ADV_DATA_TYPE_ADV, ADV_DATA2_LEN, advData2); if (status != SUCCESS) for(;;); /** End New Code **/ } #endif break; } case BLEAPPUTIL_ADV_END_AFTER_DISABLE: { MenuModule_printf(APP_MENU_ADV_EVENT, 0, "Adv status: Ended - handle: " MENU_MODULE_COLOR_YELLOW "%d" MENU_MODULE_COLOR_RESET, ((BLEAppUtil_AdvEventData_t *)pMsgData)->pBuf->advHandle); break; } default: { break; } } } /********************************************************************* * @fn Broadcaster_start * * @brief This function is called after stack initialization, * the purpose of this function is to initialize and * register the specific events handlers of the broadcaster * application module * * @return SUCCESS, errorInfo */ bStatus_t Broadcaster_start() { bStatus_t status = SUCCESS; status = BLEAppUtil_registerEventHandler(&broadcasterAdvHandler); if(status != SUCCESS) { // Return status value return(status); } status = BLEAppUtil_initAdvSet(&broadcasterAdvHandle_1, &broadcasterInitAdvSet1); if(status != SUCCESS) { // Return status value return(status); } status = BLEAppUtil_advStart(broadcasterAdvHandle_1, &broadcasterStartAdvSet1); if(status != SUCCESS) { // Return status value return(status); } // Return status value return(status); } #endif // ( HOST_CONFIG & ( BROADCASTER_CFG ) )
With Regards
Ilanchezhian T
