CC2642R-Q1: CC2642 Exception after IOS active disconnection
Part Number: CC2642R-Q1
May I ask when this problem will be fixed
e2e.ti.com/.../4987824
  • Hello Wangrenli,
    Where you able to open a request on the iOS Apple support to fix this as the behaviour (sending a disable notification request after a disconnection event)?
    From our side, the software team has updated the SDK addressing two similar issues. Therefore you should be able to see the fix soon in the next SDK release (which is the one coming after the one you used to report the issue).
    BR,
    David.
  • Hi,Thank you for your reply
    I consulted with my IOS app development colleagues and I can no longer perform the disable notification request when the user clears the background.
    The version I tested was simplelink_cc13xx_cc26xx_sdk_7_10_01_24, and I found that the current latest version is simplelink_cc13xx_cc26xx_sdk_7_40_00_77, but I don't see a fix for that.
  • Hello Wangrenli,
    Apologies for the confusion, the fix is in the coming SDK.
    BR,
    David.
    Is there an approximate release date
  • Hello Wangrenli,
    Have you tested with simplelink_cc13xx_cc26xx_sdk_7_40? A similar issues was fixed in this SDK version.
    BR,
    David.
