Part Number: CC2340R5
・Is it possible to change the advertised PHY to CodedPHY?
(The evaluation board stated that only 1MPHY is supported, but is this possible if the CC2340R5 module is installed in the actual machine?)
・I want to create a program that turns on the LED on the central side while pressing the switch on the peripheral side, and turns off the LED when the switch is off.
Could you support a sample program that actually exchanges commands between central and peripheral?
